[U-Boot] [PATCH] [PoC] basic kbuild output support
I know at first blush this isn't going to be supported, but it's just a PoC that things are (mostly) possible without much effort.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- Makefile | 54 ++++++++++++++++++++++------------------- common/kgdb.c | 52 +++++++++++++++++++++------------------ config.mk | 30 ++++++++++++++++++---- examples/api/Makefile | 11 +++++--- examples/standalone/Makefile | 9 ++++-- tools/Makefile | 48 +++++++++++++++++++++---------------- 6 files changed, 121 insertions(+), 83 deletions(-)
diff --git a/Makefile b/Makefile index 43a9145..407bf22 100644 --- a/Makefile +++ b/Makefile @@ -53,18 +53,12 @@ SHELL := $(shell if [ -x "$$BASH" ]; then echo $$BASH; \
export HOSTARCH HOSTOS SHELL
+MAKEFLAGS += --no-print-directory + # Deal with colliding definitions from tcsh etc. VENDOR=
######################################################################### -# Allow for silent builds -ifeq (,$(findstring s,$(MAKEFLAGS))) -XECHO = echo -else -XECHO = : -endif - -######################################################################### # # U-boot build supports producing a object files to the separate external # directory. Two use cases are supported: @@ -327,25 +321,31 @@ ALL += $(obj)u-boot.srec $(obj)u-boot.bin $(obj)System.map $(U_BOOT_NAND) $(U_BO all: $(ALL)
$(obj)u-boot.hex: $(obj)u-boot - $(OBJCOPY) ${OBJCFLAGS} -O ihex $< $@ + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) ${OBJCFLAGS} -O ihex $< $@
$(obj)u-boot.srec: $(obj)u-boot - $(OBJCOPY) -O srec $< $@ + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) -O srec $< $@
$(obj)u-boot.bin: $(obj)u-boot - $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ $(BOARD_SIZE_CHECK)
$(obj)u-boot.ldr: $(obj)u-boot - $(CREATE_LDR_ENV) - $(LDR) -T $(CONFIG_BFIN_CPU) -c $@ $< $(LDR_FLAGS) + @$(XECHO) " LDR $@" + $(Q)$(CREATE_LDR_ENV) + $(Q)$(LDR) -T $(CONFIG_BFIN_CPU) -c $@ $< $(LDR_FLAGS) $(BOARD_SIZE_CHECK)
$(obj)u-boot.ldr.hex: $(obj)u-boot.ldr - $(OBJCOPY) ${OBJCFLAGS} -O ihex $< $@ -I binary + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) ${OBJCFLAGS} -O ihex $< $@ -I binary
$(obj)u-boot.ldr.srec: $(obj)u-boot.ldr - $(OBJCOPY) ${OBJCFLAGS} -O srec $< $@ -I binary + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) ${OBJCFLAGS} -O srec $< $@ -I binary
$(obj)u-boot.img: $(obj)u-boot.bin $(obj)tools/mkimage -A $(ARCH) -T firmware -C none \ @@ -376,29 +376,32 @@ GEN_UBOOT = \ -Map u-boot.map -o u-boot $(obj)u-boot: depend \ $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(obj)u-boot.lds - $(GEN_UBOOT) + @$(XECHO) " LD $@" + $(Q)$(GEN_UBOOT) ifeq ($(CONFIG_KALLSYMS),y) - smap=`$(call SYSTEM_MAP,u-boot) | \ + @$(XECHO) " SYMMAP $@" + $(Q)smap=`$(call SYSTEM_MAP,u-boot) | \ awk '$$2 ~ /[tTwW]/ {printf $$1 $$3 "\\000"}'` ; \ $(CC) $(CFLAGS) -DSYSTEM_MAP=""$${smap}"" \ -c common/system_map.c -o $(obj)common/system_map.o - $(GEN_UBOOT) $(obj)common/system_map.o + @$(XECHO) " LD $@" + $(Q)$(GEN_UBOOT) $(obj)common/system_map.o endif
$(OBJS): depend - $(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@)) + $(Q)$(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@))
$(LIBS): depend $(SUBDIRS) - $(MAKE) -C $(dir $(subst $(obj),,$@)) + $(Q)$(MAKE) -C $(dir $(subst $(obj),,$@))
$(LIBBOARD): depend $(LIBS) - $(MAKE) -C $(dir $(subst $(obj),,$@)) + $(Q)$(MAKE) -C $(dir $(subst $(obj),,$@))
$(SUBDIRS): depend - $(MAKE) -C $@ all + $(Q)$(MAKE) -C $@ all
$(LDSCRIPT): depend - $(MAKE) -C $(dir $@) $(notdir $@) + $(Q)$(MAKE) -C $(dir $@) $(notdir $@)
# The linker script lacks proper dependency information atm, so force it # to be regenerated on every link. This shouldn't be to big of an issue @@ -407,7 +410,8 @@ $(LDSCRIPT): depend # board config file ... .PHONY: $(obj)u-boot.lds $(obj)u-boot.lds: $(LDSCRIPT) - $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + @$(XECHO) " CPP $@" + $(Q)$(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@
$(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) depend $(MAKE) -C nand_spl/board/$(BOARDDIR) all @@ -442,7 +446,7 @@ updater: depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ $(obj)include/autoconf.mk \ $(obj)include/generated/generic-asm-offsets.h - for dir in $(SUBDIRS) $(CPUDIR) $(dir $(LDSCRIPT)) ; do \ + $(Q)for dir in $(SUBDIRS) $(CPUDIR) $(dir $(LDSCRIPT)) ; do \ $(MAKE) -C $$dir _depend ; done
TAG_SUBDIRS = $(SUBDIRS) diff --git a/common/kgdb.c b/common/kgdb.c index 8a621ad..5bfd58d 100644 --- a/common/kgdb.c +++ b/common/kgdb.c @@ -87,13 +87,13 @@ * ****************************************************************************/
+#define DEBUG 1 + #include <common.h>
#include <kgdb.h> #include <command.h>
-#undef KGDB_DEBUG - /* * BUFMAX defines the maximum number of characters in inbound/outbound buffers */ @@ -107,7 +107,8 @@ static int kgdb_active = 0, first_entry = 1; static struct pt_regs entry_regs; static long error_jmp_buf[BUFMAX/2]; static int longjmp_on_fault = 0; -#ifdef KGDB_DEBUG + +#ifdef DEBUG static int kdebug = 1; #endif
@@ -230,16 +231,13 @@ getpacket(char *buffer) int count; unsigned char ch;
+ debugX(kdebug, "waiting for $...# packet\n"); + do { /* wait around for the start character, ignore all other * characters */ - while ((ch = (getDebugChar() & 0x7f)) != '$') { -#ifdef KGDB_DEBUG - if (kdebug) - putc(ch); -#endif + while ((ch = (getDebugChar() & 0x7f)) != '$') ; - }
checksum = 0; xmitcsum = -1; @@ -287,8 +285,12 @@ static void putpacket(unsigned char *buffer) { unsigned char checksum; - int count; + int count, i, j; unsigned char ch, recv; + char buf[256]; + + i = 0; + debugX(kdebug, "waiting for '+' ack packet\n");
/* $<packet info>#<checksum>. */ do { @@ -306,7 +308,15 @@ putpacket(unsigned char *buffer) putDebugChar(hexchars[checksum >> 4]); putDebugChar(hexchars[checksum & 0xf]); recv = getDebugChar(); + buf[i++] = recv; +// if ((recv & 0x7f) != '+') +// debugX(kdebug, "waiting for '+', but got %i:%c\n", recv, recv); } while ((recv & 0x7f) != '+'); + + debug("got back: "); + for (j = 0; j < i; ++j) + debug("%i:%c ", buf[j], buf[j]); + debug("\n"); }
/* @@ -378,12 +388,12 @@ handle_exception (struct pt_regs *regs)
*ptr = 0;
-#ifdef KGDB_DEBUG - if (kdebug) - printf("kgdb: remcomOutBuffer: %s\n", remcomOutBuffer); -#endif + debugX(kdebug, "kgdb: remcomOutBuffer: %s\n", remcomOutBuffer);
- putpacket((unsigned char *)&remcomOutBuffer); + while (serial_tstc()) + serial_getc(); + +// putpacket((unsigned char *)&remcomOutBuffer);
while (1) { volatile int errnum; @@ -393,10 +403,7 @@ handle_exception (struct pt_regs *regs) getpacket(remcomInBuffer); ptr = &remcomInBuffer[1];
-#ifdef KGDB_DEBUG - if (kdebug) - printf("kgdb: remcomInBuffer: %s\n", remcomInBuffer); -#endif + debugX(kdebug, "kgdb: remcomInBuffer: %s\n", remcomInBuffer);
errnum = kgdb_setjmp(error_jmp_buf);
@@ -409,7 +416,7 @@ handle_exception (struct pt_regs *regs) remcomOutBuffer[3] = 0; break;
-#ifdef KGDB_DEBUG +#ifdef DEBUG case 'd': /* toggle debug flag */ kdebug ^= 1; @@ -521,10 +528,7 @@ handle_exception (struct pt_regs *regs) if (errnum != 0) sprintf(remcomOutBuffer, "E%02d", errnum);
/* reply to the request */ putpacket((unsigned char *)&remcomOutBuffer); diff --git a/config.mk b/config.mk index 97d2631..653d52d 100644 --- a/config.mk +++ b/config.mk @@ -45,6 +45,16 @@ PLATFORM_CPPFLAGS = PLATFORM_LDFLAGS =
######################################################################### +# Allow for silent builds +ifeq (,$(findstring s,$(MAKEFLAGS))) +XECHO = echo +Q = @ +else +XECHO = : +Q = +endif + +#########################################################################
HOSTCFLAGS = -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer \ $(HOSTCPPFLAGS) @@ -253,21 +263,29 @@ BCURDIR = $(subst $(SRCTREE)/,,$(CURDIR:$(obj)%=%)) ALL_AFLAGS = $(AFLAGS) $(AFLAGS_$(BCURDIR)/$(@F)) $(AFLAGS_$(BCURDIR)) ALL_CFLAGS = $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) $(obj)%.s: %.S - $(CPP) $(ALL_AFLAGS) -o $@ $< + @$(XECHO) " CPP $@" + $(Q)$(CPP) $(ALL_AFLAGS) -o $@ $< $(obj)%.o: %.S - $(CC) $(ALL_AFLAGS) -o $@ $< -c + @$(XECHO) " CC $@" + $(Q)$(CC) $(ALL_AFLAGS) -o $@ $< -c $(obj)%.o: %.c - $(CC) $(ALL_CFLAGS) -o $@ $< -c + @$(XECHO) " CC $@" + $(Q)$(CC) $(ALL_CFLAGS) -o $@ $< -c $(obj)%.i: %.c - $(CPP) $(ALL_CFLAGS) -o $@ $< -c + @$(XECHO) " CPP $@" + $(Q)$(CPP) $(ALL_CFLAGS) -o $@ $< -c $(obj)%.s: %.c - $(CC) $(ALL_CFLAGS) -o $@ $< -c -S + @$(XECHO) " CC $@" + $(Q)$(CC) $(ALL_CFLAGS) -o $@ $< -c -S
# If the list of objects to link is empty, just create an empty built-in.o cmd_link_o_target = $(if $(strip $1),\ + @$(XECHO) " LD $@"; \ $(LD) $(LDFLAGS) -r -o $@ $1,\ - rm -f $@; $(AR) rcs $@ ) + @rm -f $@; \ + $(XECHO) " LD $@"; \ + $(AR) rcs $@)
######################################################################### diff --git a/examples/api/Makefile b/examples/api/Makefile index 5b5f7a6..9b3757c 100644 --- a/examples/api/Makefile +++ b/examples/api/Makefile @@ -71,16 +71,19 @@ all: $(obj).depend $(OUTPUT) #########################################################################
$(OUTPUT): $(OBJS) - $(LD) -Ttext $(LOAD_ADDR) -o $@ $^ -L$(gcclibdir) -lgcc - $(OBJCOPY) -O binary $@ $(OUTPUT).bin 2>/dev/null + @$(XECHO) " LD $@" + $(Q)$(LD) -Ttext $(LOAD_ADDR) -o $@ $^ -L$(gcclibdir) -lgcc + $(Q)$(OBJCOPY) -O binary $@ $(OUTPUT).bin 2>/dev/null
# Rule to build generic library C files $(obj)%.o: $(SRCTREE)/lib/%.c - $(CC) -g $(CFLAGS) -c -o $@ $< + @$(XECHO) " CC $@" + $(Q)$(CC) -g $(CFLAGS) -c -o $@ $<
# Rule to build architecture-specific library assembly files $(obj)%.o: $(SRCTREE)/arch/$(ARCH)/lib/%.S - $(CC) -g $(CFLAGS) -c -o $@ $< + @$(XECHO) " CC $@" + $(Q)$(CC) -g $(CFLAGS) -c -o $@ $<
diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index c1dfdce..6b97d00 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -95,17 +95,20 @@ $(LIB): $(obj).depend $(LIBOBJS)
$(ELF): $(obj)%: $(obj)%.o $(LIB) - $(LD) -g -Ttext $(STANDALONE_LOAD_ADDR) \ + @$(XECHO) " CC $@" + $(Q)$(LD) -g -Ttext $(STANDALONE_LOAD_ADDR) \ -o $@ -e $(SYM_PREFIX)$(notdir $(<:.o=)) $< $(LIB) \ -L$(gcclibdir) -lgcc
$(SREC): $(obj)%.srec: $(obj)% - $(OBJCOPY) -O srec $< $@ 2>/dev/null + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) -O srec $< $@ 2>/dev/null
$(BIN): $(obj)%.bin: $(obj)% - $(OBJCOPY) -O binary $< $@ 2>/dev/null + @$(XECHO) " OBJCOPY $@" + $(Q)$(OBJCOPY) -O binary $< $@ 2>/dev/null
diff --git a/tools/Makefile b/tools/Makefile index 97f83f8..121cc62 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -156,28 +156,37 @@ HOSTCPPFLAGS = -idirafter $(SRCTREE)/include \
all: $(obj).depend $(BINS) $(LOGO-y) subdirs
-$(obj)bin2header$(SFX): $(obj)bin2header.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ +cmd_host_link = \ + @set -e; \ + $(XECHO) " HOSTCC $@"; \ + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^; \ $(HOSTSTRIP) $@ +cmd_host_cc_noped = \ + @set -e; \ + $(XECHO) " HOSTCC $@"; \ + $(HOSTCC) -g $(HOSTCFLAGS_NOPED) -c -o $@ $< +cmd_host_cc = \ + @set -e; \ + $(XECHO) " HOSTCC $@"; \ + $(HOSTCC) -g $(HOSTCFLAGS) -c -o $@ $< + +$(obj)bin2header$(SFX): $(obj)bin2header.o + $(cmd_host_link)
$(obj)bmp_logo$(SFX): $(obj)bmp_logo.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)envcrc$(SFX): $(obj)crc32.o $(obj)env_embedded.o $(obj)envcrc.o $(obj)sha1.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(cmd_host_link)
$(obj)gen_eth_addr$(SFX): $(obj)gen_eth_addr.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)img2srec$(SFX): $(obj)img2srec.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)inca-swap-bytes$(SFX): $(obj)inca-swap-bytes.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)default_image.o \ @@ -190,29 +199,26 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)os_support.o \ $(obj)sha1.o \ $(LIBFDT_OBJS) - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)mpc86x_clk$(SFX): $(obj)mpc86x_clk.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)ncb$(SFX): $(obj)ncb.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ - $(HOSTSTRIP) $@ + $(cmd_host_link)
$(obj)ubsha1$(SFX): $(obj)os_support.o $(obj)sha1.o $(obj)ubsha1.o - $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(cmd_host_link)
# Some of the tool objects need to be accessed from outside the tools directory $(obj)%.o: $(SRCTREE)/common/%.c - $(HOSTCC) -g $(HOSTCFLAGS_NOPED) -c -o $@ $< + $(cmd_host_cc_noped)
$(obj)%.o: $(SRCTREE)/lib/%.c - $(HOSTCC) -g $(HOSTCFLAGS) -c -o $@ $< + $(cmd_host_cc)
$(obj)%.o: $(SRCTREE)/lib/libfdt/%.c - $(HOSTCC) -g $(HOSTCFLAGS_NOPED) -c -o $@ $< + $(cmd_host_cc_noped)
subdirs: ifeq ($(TOOLSUBDIRS),)
Mike Frysinger
