[U-Boot] [PATCH 0/4] Use THUMB mode for VCMA9 U-Boot builts
Patch 1 fixes a bug in the calling of board_init_r() in THUMB mode. Patch 2-3 enable THUMB support for the ARM920T architecture. Patch 4 finally activates THUMB mode for VCMA9.
Signed-off-by: David Müller d.mueller@elsoft.ch --- arch/arm/lib/crt0.S | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 2f4c14e..8415f77 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -167,8 +167,12 @@ clbss_l:cmp r0, r1 /* while not at end of BSS */ mov r0, r9 /* gd_t */ ldr r1, [r9, #GD_RELOCADDR] /* dest_addr */ /* call board_init_r */ +#if defined(CONFIG_SYS_THUMB_BUILD) + ldr lr, =board_init_r /* this is auto-relocated! */ + bx lr +#else ldr pc, =board_init_r /* this is auto-relocated! */ - +#endif /* we should not return here. */ #endif
- ldr lr, =board_init_r /* this is auto-relocated! */
- bx lr
In general, my preference is always to use the thumb compatible way, can you rework like that and explain in the commit message? Thanks!
Hello
- bx lr
AFAIK, the "bx" instruction is undefined on non-THUMB capable architectures. I therefore don't see a way to avoid some kind of #if/#else/#endif construct.
Dave
On Wed, Feb 10, 2016 at 08:57:38AM +0100, David Müller (ELSOFT AG) wrote:
Hello
- bx lr
Ah, OK, nevermind then, thanks.
Signed-off-by: David Müller d.mueller@elsoft.ch --- arch/arm/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index cd7d880..6defdfb 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -9,7 +9,7 @@ endif
# This selects which instruction set is used. arch-$(CONFIG_CPU_ARM720T) =-march=armv4 -arch-$(CONFIG_CPU_ARM920T) =-march=armv4 +arch-$(CONFIG_CPU_ARM920T) =-march=armv4t arch-$(CONFIG_CPU_ARM926EJS) =-march=armv5te arch-$(CONFIG_CPU_ARM946ES) =-march=armv4 arch-$(CONFIG_CPU_SA1100) =-march=armv4
Signed-off-by: David Müller d.mueller@elsoft.ch --- arch/arm/cpu/arm920t/Makefile | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/cpu/arm920t/Makefile b/arch/arm/cpu/arm920t/Makefile index 6582938..1832b9d 100644 --- a/arch/arm/cpu/arm920t/Makefile +++ b/arch/arm/cpu/arm920t/Makefile @@ -13,3 +13,9 @@ obj-$(CONFIG_USE_IRQ) += interrupts.o obj-$(CONFIG_EP93XX) += ep93xx/ obj-$(CONFIG_IMX) += imx/ obj-$(CONFIG_S3C24X0) += s3c24x0/ + +# some files can only build in ARM mode + +ifdef CONFIG_SYS_THUMB_BUILD +CFLAGS_cpu.o := -marm +endif
Signed-off-by: David Müller d.mueller@elsoft.ch --- include/configs/VCMA9.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 42af34f..de7d5c2 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -20,6 +20,8 @@ * High Level Configuration Options * (easy to change) */ +#define CONFIG_SYS_THUMB_BUILD + #define CONFIG_S3C24X0 /* This is a SAMSUNG S3C24x0-type SoC */ #define CONFIG_S3C2410 /* specifically a SAMSUNG S3C2410 SoC */ #define CONFIG_VCMA9 /* on a MPL VCMA9 Board */
David Müller
