[U-Boot] MPC850: strange problem with icache
Hi Folks,
I'm porting u-boot-1.3.1 to customer board, which includes MPC850 and 32MB SDRAM. When I turned off icache, bus can work correctly under 25MHz/50MHz clock frequence. Note that CPU is working under 50MHz. However, the board only can work with bus frequence of 25MHz with enabled icache. If I tried to set bus frequence to 50MHz with enabled icache, it will crash with MCE.
I don't know why. Since it can work at 25MHz with enabled icache, the UPM words seem ok. Thanks for your advices!
Gavin
Dear Guowen SHAN,
In message cf7369060903290628p2768907p9a0c2e40c898601b@mail.gmail.com you wrote:
Easy problem - actually FAQ: please see http://www.denx.de/wiki/view/DULG/UBootCrashAfterRelocation
Keep in mind that the UPM setup is only part of the required RAM initialization sequence. Follow the instructions in the chip manufacturer's manual to the letter.
Dear Guowen SHAN,
32MB SDRAM.
frequence.
with bus
to 50MHz with
I don't understand it completely. 25MHz with enabled icache could use burst to fecth instructions from RAM, which should have proved the UPM words and initialization sequence was ok, right?
words seem
Guowen SHAN
