[U-Boot] Pull request: u-boot-x86/master
Wolfgang,
I believe I missed the 2011.03 merge window - I'm happy for these to go into 2011.06
The following changes since commit d1a79b71f7c5fd9e277e0feb35f049289df1ed0e:
Merge branch 'master' of git://git.denx.de/u-boot-mpc85xx (2011-02-11 21:23:33 +0100)
git://git.denx.de/u-boot-x86.git master
Graeme Russ (32): x86: Fix definition of global_data struct for asm-offsets.c x86: Align config.mk and linker scripts with other arches eNET: Create distinct board configurations x86: Parametize values used in linker script sc520: Sort Makefile x86: Fix mangled umlauts x86: Add stack dump to register dump x86: Move Global Descriptor Table defines to processor.h x86: Add processor flags header from linux x86: Call early_board_init when warm booting x86: Make cpu init functions weak sc520: Define MMCR address in include file sc520: Move board specific settings to board init function sc520: Remove printf calls from cpu_init_f eNET: Fix eNET Interrupt Setup for Linux eNET: Add RTC support to eNET eNET: Define MMCR values in config.h eNET: Rearrange PAR assignments eNET: General code cleanup x86: Move initial gd to fixed location x86: Use Cache-As-RAM for initial stack sc520: Move RAM sizing code from asm to C x86: Defer setup of final stack x86: Move call to dram_init_f into board_init_f x86: Move test for cold boot into init functions x86: Move console initialisation into board_init_f x86: Fix incorrect usage of relocation offset x86: Split board_init_f() into init_fnc_t compatible functions x86: Rearrange function calls in board_init_f x86: Convert board_init_f to use an init_sequence sc520: Release CAR and enable caching eNET: Move initial Global Data into CAR
arch/i386/config.mk | 15 +- arch/i386/cpu/config.mk | 10 +- arch/i386/cpu/cpu.c | 35 +- arch/i386/cpu/interrupts.c | 19 +- arch/i386/cpu/sc520/Makefile | 5 +- arch/i386/cpu/sc520/sc520.c | 148 +------ arch/i386/cpu/sc520/sc520_asm.S | 615 --------------------------- arch/i386/cpu/sc520/sc520_car.S | 94 ++++ arch/i386/cpu/sc520/sc520_sdram.c | 532 +++++++++++++++++++++++ arch/i386/cpu/start.S | 107 +++--- arch/i386/cpu/start16.S | 5 +- {board/eNET => arch/i386/cpu}/u-boot.lds | 24 +- arch/i386/include/asm/global_data.h | 21 +- arch/i386/include/asm/ic/sc520.h | 93 ++++- arch/i386/include/asm/processor-flags.h | 100 +++++ arch/i386/include/asm/processor.h | 9 +- arch/i386/include/asm/u-boot-i386.h | 3 + arch/i386/lib/board.c | 146 ++++--- arch/i386/lib/realmode.c | 8 +- board/eNET/config.mk | 6 +- board/eNET/eNET.c | 192 +++++---- board/eNET/eNET_start.S | 7 - board/eNET/eNET_start16.S | 15 +- boards.cfg | 3 +- drivers/rtc/mc146818.c | 6 + include/configs/eNET.h | 679 ++++++++++++++++++++++------- 26 files changed, 1699 insertions(+), 1198 deletions(-) delete mode 100644 arch/i386/cpu/sc520/sc520_asm.S create mode 100644 arch/i386/cpu/sc520/sc520_car.S create mode 100644 arch/i386/cpu/sc520/sc520_sdram.c rename {board/eNET => arch/i386/cpu}/u-boot.lds (75%) create mode 100644 arch/i386/include/asm/processor-flags.h
Dear Graeme Russ,
In message 4D560FD2.4000401@gmail.com you wrote:
Wolfgang,
Applied, thanks.
seems that all these commits are missing your s-o-b. please watch for that a bit more in the future. -mike
Graeme Russ (32):
[snip]
Oops, stg commit does not add the signed-off-by: line like git commit - It needs to be set when creating a new patch or explicitly added in the patch description.
Thanks for picking that up Mike
Regards,
Graeme
Graeme Russ
Mike Frysinger
