[U-Boot-Users] [PATCH] [UPDATED] POWERPC: Change 86xx platforms to use CONFIG_NR_CPUS
Currently, they use CONFIG_NUM_CPUS, which is different than 85xx for no good reason.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- Note: This is a resend; the first version accidentally changed the NR_CPUs on 8610 to 2.
cpu/mpc86xx/start.S | 4 ++-- include/configs/MPC8610HPCD.h | 2 +- include/configs/MPC8641HPCN.h | 2 +- include/configs/sbc8641d.h | 2 +- 4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index 03f2128..83072bb 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -183,7 +183,7 @@ boot_warm: /* if this is a multi-core system we need to check which cpu * this is, if it is not cpu 0 send the cpu to the linux reset * vector */ -#if (CONFIG_NUM_CPUS > 1) +#if (CONFIG_NR_CPUS > 1) mfspr r0, MSSCR0 andi. r0, r0, 0x0020 rlwinm r0,r0,27,31,31 @@ -979,7 +979,7 @@ unlock_ram_in_cache: * Sri: Much of this initialization is not required. Linux * rewrites the bats, and the sprs and also enables the L1 cache. */ -#if (CONFIG_NUM_CPUS > 1) +#if (CONFIG_NR_CPUS > 1) .globl secondary_cpu_setup secondary_cpu_setup: /* Do only core setup on all cores except cpu0 */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 1cba270..50a05f2 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -17,7 +17,7 @@ #define CONFIG_MPC86xx 1 /* MPC86xx */ #define CONFIG_MPC8610 1 /* MPC8610 specific */ #define CONFIG_MPC8610HPCD 1 /* MPC8610HPCD board specific */ -#define CONFIG_NUM_CPUS 1 /* Number of CPUs in the system */ +#define CONFIG_NR_CPUS 1 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */
#define CONFIG_FSL_DIU_FB 1 /* FSL DIU */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index ccba409..78a9d11 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -36,7 +36,7 @@ #define CONFIG_MPC86xx 1 /* MPC86xx */ #define CONFIG_MPC8641 1 /* MPC8641 specific */ #define CONFIG_MPC8641HPCN 1 /* MPC8641HPCN board specific */ -#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */ +#define CONFIG_NR_CPUS 2 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */
#ifdef RUN_DIAG diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 3cd9ff8..76712fd 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -40,7 +40,7 @@ #define CONFIG_MPC86xx 1 /* MPC86xx */ #define CONFIG_MPC8641 1 /* MPC8641 specific */ #define CONFIG_SBC8641D 1 /* SBC8641D board specific */ -#define CONFIG_NUM_CPUS 2 /* Number of CPUs in the system */ +#define CONFIG_NR_CPUS 2 /* Number of CPUs in the system */ #define CONFIG_LINUX_RESET_VEC 0x100 /* Reset vector used by Linux */
#ifdef RUN_DIAG
I have ACKed Kumar's version of this patch!
jdl
Becky Bruce
Jon Loeliger
