[PATCH] arm: mvebu: Espressobin: Disable slot when emmc is not present
This change extends previous commit 061c6d1b238a ("arm: mvebu: Espressobin: Detect presence of emmc at runtime") and when emmc is not present then emmc is removed from U-Boot DM and corresponding slot is disabled. Therefore on Espressobin board without soldered emmc, state of emmc hw should be same as if emmc was disabled in DTS.
Signed-off-by: Pali Rohár pali@kernel.org --- board/Marvell/mvebu_armada-37xx/board.c | 15 ++++++++++++--- drivers/mmc/xenon_sdhci.c | 19 +++++++++++++++++++ 2 files changed, 31 insertions(+), 3 deletions(-)
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index f67b04b78c..1b9e7520cc 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <dm/device-internal.h> #include <env.h> #include <i2c.h> #include <init.h> @@ -84,12 +85,10 @@ int board_init(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { + struct udevice *dev; struct mmc *mmc_dev; bool ddr4, emmc;
- if (env_get("fdtfile")) - return 0; - if (!of_machine_is_compatible("globalscale,espressobin")) return 0;
@@ -101,6 +100,16 @@ int board_late_init(void) mmc_dev = find_mmc_device(1); emmc = (mmc_dev && mmc_init(mmc_dev) == 0);
+ /* if eMMC is not present then remove it from DM */ + if (!emmc && mmc_dev) { + dev = mmc_dev->dev; + device_remove(dev, DM_REMOVE_NORMAL); + device_unbind(dev); + } + + if (env_get("fdtfile")) + return 0; + if (ddr4 && emmc) env_set("fdtfile", "marvell/armada-3720-espressobin-v7-emmc.dtb"); else if (ddr4) diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 6ce9d00d0a..da9882cbf6 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -350,6 +350,16 @@ static void xenon_mmc_enable_slot(struct sdhci_host *host, u8 slot) sdhci_writel(host, var, SDHC_SYS_OP_CTRL); }
+/* Disable specific slot */ +static void xenon_mmc_disable_slot(struct sdhci_host *host, u8 slot) +{ + u32 var; + + var = sdhci_readl(host, SDHC_SYS_OP_CTRL); + var &= ~(SLOT_MASK(slot) << SLOT_ENABLE_SHIFT); + sdhci_writel(host, var, SDHC_SYS_OP_CTRL); +} + /* Enable Parallel Transfer Mode */ static void xenon_mmc_enable_parallel_tran(struct sdhci_host *host, u8 slot) { @@ -515,6 +525,14 @@ static int xenon_sdhci_probe(struct udevice *dev) return ret; }
+static int xenon_sdhci_remove(struct udevice *dev) +{ + struct sdhci_host *host = dev_get_priv(dev); + + xenon_mmc_disable_slot(host, XENON_MMC_SLOT_ID_HYPERION); + return 0; +} + static int xenon_sdhci_ofdata_to_platdata(struct udevice *dev) { struct sdhci_host *host = dev_get_priv(dev); @@ -564,6 +582,7 @@ U_BOOT_DRIVER(xenon_sdhci_drv) = { .ops = &sdhci_ops, .bind = xenon_sdhci_bind, .probe = xenon_sdhci_probe, + .remove = xenon_sdhci_remove, .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv), .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat), };
Thanks, Stefan
- struct udevice *dev; struct mmc *mmc_dev; bool ddr4, emmc;
- /* if eMMC is not present then remove it from DM */
- if (!emmc && mmc_dev) {
dev = mmc_dev->dev;
device_unbind(dev);
- if (ddr4 && emmc) env_set("fdtfile", "marvell/armada-3720-espressobin-v7-emmc.dtb"); else if (ddr4)
- u32 var;
- var = sdhci_readl(host, SDHC_SYS_OP_CTRL);
- var &= ~(SLOT_MASK(slot) << SLOT_ENABLE_SHIFT);
- sdhci_writel(host, var, SDHC_SYS_OP_CTRL);
- /* Enable Parallel Transfer Mode */ static void xenon_mmc_enable_parallel_tran(struct sdhci_host *host, u8 slot) {
- struct sdhci_host *host = dev_get_priv(dev);
- xenon_mmc_disable_slot(host, XENON_MMC_SLOT_ID_HYPERION);
- static int xenon_sdhci_ofdata_to_platdata(struct udevice *dev) { struct sdhci_host *host = dev_get_priv(dev);
- .remove = xenon_sdhci_remove, .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv), .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat), };
Viele Grüße, Stefan
Pali Rohár
Stefan Roese
