[U-Boot] [Patch V2] ARM: da850evm_direct_nor_defconfig: Enable DM_SERIAL
With DM enabled, this patch enables DM_SERIAL and removes the NS16550 initialization from da850_lowlevel since the driver will take care of that itself.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Rebase against Master Use CONFIG_IS_ENABLED instead of defined so this can be enabled/disabled in SPL independently. Enable CONFIG_SYS_MALLOC_F to allow relocation allowing the serial to build correctly diff --git a/arch/arm/mach-davinci/da850_lowlevel.c b/arch/arm/mach-davinci/da850_lowlevel.c index 95dc93a24f..822e0dc4a1 100644 --- a/arch/arm/mach-davinci/da850_lowlevel.c +++ b/arch/arm/mach-davinci/da850_lowlevel.c @@ -288,10 +288,10 @@ int arch_cpu_init(void) /* GPIO setup */ board_gpio_init();
- +#if !CONFIG_IS_ENABLED(DM_SERIAL) NS16550_init((NS16550_t)(CONFIG_SYS_NS16550_COM1), CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE); - +#endif /* * Fix Power and Emulation Management Register * see sprufw3a.pdf page 37 Table 24 diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 4039d0ee59..42cb4127fd 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -5,7 +5,6 @@ CONFIG_TARGET_DA850EVM=y CONFIG_DA850_LOWLEVEL=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=1 -# CONFIG_SYS_MALLOC_F is not set CONFIG_SYS_EXTRA_OPTIONS="USE_NOR,DIRECT_NOR_BOOT" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -50,6 +49,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MII=y CONFIG_DRIVER_TI_EMAC=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y
Adam Ford
