[U-Boot] [PATCH v3] sf: Fix to compute proper sector_size
Upto now flash sector_size is assigned from params which isn't necessarily a sector size from vendor, so based on the SECT_* flags from flash_params the erase_size will compute and it will become the sector_size finally.
Bug report (from Bin Meng): => sf probe SF: Detected SST25VF016B with page size 256 Bytes, erase size 4 KiB, total 2 MiB, mapped at ffe00000
=> sf erase 0 +100 SF: 65536 bytes @ 0x0 Erased: OK
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Reported-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com --- Changes for v3: - Updated comments Changes for v2: - Minimize the code logic
drivers/mtd/spi/sf_internal.h | 3 ++- drivers/mtd/spi/sf_probe.c | 3 +++ 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index bd834dc..4158e13 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -119,7 +119,8 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) * @ext_jedec: Device ext_jedec ID - * @sector_size: Sector size of this device + * @sector_size: Isn't necessarily a sector size from vendor, + * the size listed here is what works with CMD_ERASE_64K * @nr_sectors: No.of sectors on this device * @e_rd_cmd: Enum list for read commands * @flags: Important param, for flash specific behaviour diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index de8d0b7..3f6b882 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -184,6 +184,9 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, flash->erase_size = flash->sector_size; }
+ /* Now erase size becomes valid sector size */ + flash->sector_size = flash->erase_size; + /* Look for the fastest read cmd */ cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); if (cmd) {
On 27 April 2015 at 21:06, Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com wrote:
- @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO])
- @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id])
- @ext_jedec: Device ext_jedec ID
- @sector_size: Sector size of this device
- @sector_size: Isn't necessarily a sector size from vendor,
- @nr_sectors: No.of sectors on this device
- @e_rd_cmd: Enum list for read commands
- @flags: Important param, for flash specific behaviour
-- 1.9.1
Applied to u-boot-spi/master
thanks!
Jagan Teki
