Re: [U-Boot] policy regarding unused code
From: Jean-Jacques Hiblot [mailto:jjhiblot@ti.com] Sent: Wednesday, December 12, 2018 8:00 PM To: Tom Rini Cc: U-Boot; Rick Jian-Zhi Chen(陳建志) Subject: Re: [U-Boot] policy regarding unused code
Tom, Rick,
On 11/12/2018 19:17, Tom Rini wrote:
On Tue, Dec 11, 2018 at 06:01:23PM +0100, Jean-Jacques Hiblot wrote:
On 11/12/2018 17:35, Tom Rini wrote:
On Tue, Dec 11, 2018 at 04:46:01PM +0100, Jean-Jacques Hiblot wrote:
On 11/12/2018 16:25, Jean-Jacques Hiblot wrote: > Hi Tom, > > Is there such a policy described somewhere ? > > There are quite a pieces of code that are not used/compiled > because no config enables it. > > A random pick among many others: > > - CONFIG_FPGA_LATTICE > > - CONFIG_MESON_SPIFC > > - CONFIG_POWER_BATTERY_TRATS2 > > - CONFIG_UPDATE_TFTP > > Here a more complete list of suspects (there may be options that do not even exist)
Suspect means that the variable is probably referenced in a Makefile but not in configs/ nor in include/configs
This is not a small list and a lot of them we probably want to keep.
['CONFIG_MX8M', 'CONFIG_POWER_PMIC_MAX77693', 'CONFIG_TPM2_TIS_SANDBOX', 'CONFIG_TPM_ST33ZP24_SPI', 'CONFIG_USB_SL811HS', 'CONFIG_RAM_SUPPORT',
'CONFIG_BCM2835_WDT',
'CONFIG_ENV_IS_IN_SATA', 'CONFIG_IO64', 'CONFIG_NAND_SUPPORT', 'CONFIG_NOR_SUPPORT', 'CONFIG_RISCV_ISA_A',
'CONFIG_I2C_MUX_GPIO',
'CONFIG_POWER_FG_MAX17042', 'CONFIG_DNET', 'CONFIG_CMD_SH_ZIMAGEBOOT', 'CONFIG_USE_DEFAULT_ENV_FILE', 'CONFIG_CMD_IOTRACE', 'CONFIG_ALI152X', 'CONFIG_M5271', 'CONFIG_CPU_MPC83XX', 'CONFIG_NXP_TDA19988', 'CONFIG_IMX', 'CONFIG_ADI_GPIO2', 'CONFIG_BUILD_ENVCRC', 'CONFIG_FTMAC110', 'CONFIG_CMD_CONITRACE', 'CONFIG_USB_DAVINCI', 'CONFIG_TARGET_XTFPGA', 'CONFIG_DLVISION_10G',
'CONFIG_CMD_KGDB',
'CONFIG_USB_SDP_SUPPORT',
'CONFIG_MESON_GX_VPU_POWER_DOMAIN',
'CONFIG_FSL_DMA', 'CONFIG_IHS_VIDEO_OUT', 'CONFIG_CMD_ZFS', 'CONFIG_P2020DS', 'CONFIG_RTC_DS1388',
'CONFIG_POWER_MUIC_MAX8997',
'CONFIG_TPM2_TIS_SPI', 'CONFIG_TEST_FDTDEC', 'CONFIG_AIS_CONFIG_FILE', 'CONFIG_GDSYS_SOC',
'CONFIG_CMD_DTIMG',
'CONFIG_DFU_SUPPORT', 'CONFIG_SYS_JFFS2_SORT_FRAGMENTS', 'CONFIG_ATF', 'CONFIG_BLOBLIST', 'CONFIG_NAND_SPEAR', 'CONFIG_MPC8XXX_GPIO', 'CONFIG_ULP_WATCHDOG',
'CONFIG_RTC_MK48T59',
'CONFIG_CMD_FITUPD', 'CONFIG_MODVERSIONS', 'CONFIG_CPU_SH3', 'CONFIG_CMD_BEDBUG', 'CONFIG_AT91_USB_CLK',
'CONFIG_CMD_UNIVERSE',
'CONFIG_DEBUG_UART_UNIPHIER', 'CONFIG_CMD_DISPLAY', 'CONFIG_ETH_SANDBOX_RAW', 'CONFIG_SANDBOX', 'CONFIG_CPU_SH2', 'CONFIG_SATA_SUPPORT', 'CONFIG_IOCON', 'CONFIG_MESON_SPIFC', 'CONFIG_NS8382X', 'CONFIG_SOC_DM355',
'CONFIG_BOARD_GAZERBEAM',
'CONFIG_CMD_AVB', 'CONFIG_MW_EEPROM',
'CONFIG_SHA1_CHECK_UB_IMG',
'CONFIG_IHS_FPGA', 'CONFIG_USE_PLUGIN', 'CONFIG_VIDEO_SIMPLE', 'CONFIG_CLK_VEXPRESS_OSC', 'CONFIG_MIPS_TUNE_14KC', 'CONFIG_MPC83XX_SDRAM', 'CONFIG_XIP_SUPPORT', 'CONFIG_MIPS_TUNE_34KC', 'CONFIG_ALTERA_UART',
'CONFIG_LOAD_FIT',
'CONFIG_RTC_DS1339', 'CONFIG_ENV_SUPPORT', 'CONFIG_DEFAULT_ENV_FILE', 'CONFIG_TPM_ST33ZP24_I2C', 'CONFIG_PCH_SUPPORT', 'CONFIG_UBOOT_PAD_TO', 'CONFIG_LYNXKDI', 'CONFIG_CMD_SMC', 'CONFIG_BOOTCOUNT_AT91',
'CONFIG_OF_PLATDATA',
'CONFIG_CONSOLE_TRUETYPE_NIMBUS', 'CONFIG_S6E8AX0', 'CONFIG_FPGA_ACEX1K', 'CONFIG_MVEBU_EFUSE', 'CONFIG_CONSOLE_TRUETYPE_RUFSCRIPT', 'CONFIG_XILINX_MICROBLAZE0_HW_VER', 'CONFIG_CONSOLE_TRUETYPE_ANKACODER', 'CONFIG_RTC_M41T60', 'CONFIG_CMD_ZIP', 'CONFIG_USB_SUPPORT', 'CONFIG_SPI_FLASH_SUPPORT', 'CONFIG_FLASH_PIC32',
'CONFIG_SAVEENV',
'CONFIG_FPGA_STRATIX_II', 'CONFIG_TEE', 'CONFIG_PIC32_SPI', 'CONFIG_FAT_SUPPORT', 'CONFIG_SERIAL_SUPPORT',
'CONFIG_RTC_DS174x',
'CONFIG_RTC_RS5C372A', 'CONFIG_DM_DEBUG', 'CONFIG_DISPLAY_ROCKCHIP_LVDS', 'CONFIG_CMD_ZYNQ_RSA', 'CONFIG_VEXPRESS_CONFIG', 'CONFIG_SPI_SUPPORT', 'CONFIG_POWER_BATTERY_TRATS2', 'CONFIG_CS8900', 'CONFIG_DRIVERS_MISC_SUPPORT', 'CONFIG_YMODEM_SUPPORT', 'CONFIG_MPC83XX_SERDES', 'CONFIG_NAND_KB9202',
'CONFIG_PL022_SPI',
'CONFIG_RTC_PCF2127', 'CONFIG_ARMV8_PSCI', 'CONFIG_KALLSYMS', 'CONFIG_LAN91C96', 'CONFIG_SHELL', 'CONFIG_SOC_DM646X', 'CONFIG_HASH_SUPPORT', 'CONFIG_ARMADA_39X',
'CONFIG_CMD_STRINGS',
'CONFIG_ARCH_RV32I', 'CONFIG_RTC_M48T35A', 'CONFIG_DATAFLASH_MMC_SELECT', 'CONFIG_UPDATE_TFTP', 'CONFIG_CPU_SA1100', 'CONFIG_NAND_PLAT', 'CONFIG_GPIO_SUPPORT', 'CONFIG_RTC_DS1306', 'CONFIG_LOG_TEST', 'CONFIG_IHS_AXI', 'CONFIG_XWAY_SWAP_BYTES', 'CONFIG_CPU_SH4',
'CONFIG_RTC_MAX6900',
'CONFIG_TEGRA210_QSPI', 'CONFIG_SYS_I2C_VERSATILE', 'CONFIG_PCI_SUPPORT', 'CONFIG_SPI_LOAD', 'CONFIG_NAND_FSL_UPM', 'CONFIG_RTC_DS1556', 'CONFIG_DRIVER_AX88180', 'CONFIG_E1000_SPI', 'CONFIG_ONENAND_U_BOOT', 'CONFIG_CMD_TERMINAL',
'CONFIG_MODULES',
'CONFIG_ONENAND_SUPPORT', 'CONFIG_SH_SDHI', 'CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED', 'CONFIG_BUILD', 'CONFIG_VIDEO_ARM_MALIDP', 'CONFIG_POWER_BATTERY_TRATS', 'CONFIG_DRIVER_SMC911X', 'CONFIG_UBI',
'CONFIG_MMC_SDHCI_SPEAR',
'CONFIG_USB_OHCI_DA8XX', 'CONFIG_UDP_FUNCTION_FASTBOOT', 'CONFIG_EXT_SUPPORT', 'CONFIG_USB_EHCI_FARADAY', 'CONFIG_TARGET_AXS103', 'CONFIG_PHY_MSCC', 'CONFIG_FTPCI100', 'CONFIG_PCIE_INTEL_FPGA', 'CONFIG_IO', 'CONFIG_SECURED_MODE_CSK_INDEX', 'CONFIG_SYSRESET_MCP83XX', 'CONFIG_BOOTROM_SUPPORT', 'CONFIG_POWER_MUIC_MAX77693', 'CONFIG_MMC_SUPPORT', 'CONFIG_LOGICORE_DP_TX',
'CONFIG_GDSYS_IOEP',
'CONFIG_XILINX_MICROBLAZE0_USE_PCMP_INSTR', 'CONFIG_RMOBILE', 'CONFIG_CMD_AES', 'CONFIG_RTC_S3C24X0', 'CONFIG_NATSEMI', 'CONFIG_NS87308', 'CONFIG_CBMEM_CONSOLE',
'CONFIG_MARUBUN_PCCARD',
'CONFIG_XILINX_SPI', 'CONFIG_FS_LOADER', 'CONFIG_YAFFS2', 'CONFIG_DM644X_GPIO', 'CONFIG_SOC_DM365', 'CONFIG_ARC_TIMER', 'CONFIG_POWER_MAX8998', 'CONFIG_CMD_FDC',
'CONFIG_RTC_RV3029',
'CONFIG_RTC_AT91SAM9_RTT', 'CONFIG_EXYNOS_PWM_BL', 'CONFIG_CLK_MPC83XX', 'CONFIG_RTC_DS1302', 'CONFIG_TPM_TIS_SANDBOX', 'CONFIG_MPC83XX_TIMER', 'CONFIG_ICS8N3QV01', 'CONFIG_ARCH_P1011', 'CONFIG_I2C_SUPPORT', 'CONFIG_GDSYS_RXAUI_CTRL', 'CONFIG_POWER_FG_MAX77693', 'CONFIG_PINCTRL_QCA953x', 'CONFIG_CMD_SHA1SUM', 'CONFIG_RTC_DAVINCI', 'CONFIG_NET_SUPPORT',
'CONFIG_FPGA_LATTICE',
'CONFIG_RTC_M41T94', 'CONFIG_MPC8XX_SPI',
'CONFIG_LPC32XX_HSUART',
'CONFIG_CMD_YAFFS2', 'CONFIG_W1_EEPROM_DS2502',
'CONFIG_VIDEO_MX3',
'CONFIG_UT_UNICODE', 'CONFIG_RTC_MX27', 'CONFIG_LIBAVB', 'CONFIG_RTC_DS164x', 'CONFIG_CMD_HVC', 'CONFIG_CPU_V7', 'CONFIG_FPGA_VIRTEX2', 'CONFIG_POWER_MAX8997', 'CONFIG_MVEBU_SPL_BOOT_DEVICE_UART', 'CONFIG_ETH_SANDBOX', 'CONFIG_DEBUG_LL', 'CONFIG_MCR3000', 'CONFIG_USB_EHCI_RMOBILE', 'CONFIG_DB8500_GPIO', 'CONFIG_SECURED_MODE_IMAGE', 'CONFIG_CMD_TRACE', 'CONFIG_AVB_VERIFY',
'CONFIG_NULLDEV_SERIAL',
'CONFIG_CMD_INI', 'CONFIG_VIRTIO_SANDBOX', 'CONFIG_MACH_DAVINCI_DA830_EVM', 'CONFIG_USB_ETHER_LAN75XX', 'CONFIG_SUN4I_SPI', 'CONFIG_CMD_BINOP', 'CONFIG_RTC_SUPPORT', 'CONFIG_USB_DA8XX', 'CONFIG_SOC_DM644X', 'CONFIG_ALTERA_SPI', 'CONFIG_SYS_FPGA_COMMON', 'CONFIG_TOOLS_DEBUG', 'CONFIG_USB_GADGET_FOTG210', 'CONFIG_RTC_X1205', 'CONFIG_FPGA_SPARTAN2', 'CONFIG_CMD_MFSL', 'CONFIG_RISCV_ISA_C']
I suspect this splits into three categories:
- Dead symbols and code to drop.
- Typos/thinkos
- Mistake in your grep? I see CONFIG_VIRTIO_SANDBOX is used today for example.
Oh yes. the code is far from perfect. this is a list of 'suspects'. It could be made more accurate but I would have to download a ton of toolchains to produce the exact configuration file for every board. So the script is taking shortcuts and only give suspects.
It also indicates non existing variable like CONFIG_SERIAL_SUPPORT because CONFIG_SPL_SERIAL_SUPPORT does exist.
So this list must be taken with (big) grain of salt.
I suspect there's enough false positives in there to make it problematic to find the really bad symbols. To get all of the toolchains: $ for A in aarch64 arm m68k microblaze mips powerpc riscv64 sh2 i386; do \ ./tools/buildman/buildman --fetch-arch $A;done
I've been trying to use the nds32 toolchain but get a lot of errors.
I saw the discussion thread you started on 04/23/2018 "[U-Boot] NDS32 toolchain?". Even with the toolchains cited in the thread, it doesn't work.
Rick,
Can you point to a working toolchain ?
Hi JJ
You can get nds32 toolchain as below https://github.com/vincentzwc/prebuilt-nds32-toolchain/releases/download/201... I have verified and it can compile pass.
But it need some fix that -GO shall be removed: arch/nds32/config.mk -PLATFORM_CPPFLAGS += -D__nds32__ -G0 -ffixed-10 -fpie +PLATFORM_CPPFLAGS += -D__nds32__ -ffixed-10 -fpie
I will send a patch to fix it later.
The path have been changed since then when I inform Tom to get it in the middle of the period, but I don't know. I am sorry about that.
Thanks Rick
Thanks
JJ
Rick Chen
