Please pull u-boot-dm
Hi Tom,
https://source.denx.de/u-boot/custodians/u-boot-dm/-/commit/f21954750aa8ed44...
The following changes since commit fb63362c63c7aeacb1dfde330ee8f692da7972f9:
lib: fix buggy strcmp and strncmp (2022-10-27 09:10:08 -0400)
git://git.denx.de/u-boot-dm.git tags/dm-pull-29oct22
for you to fetch changes up to f21954750aa8ed445ab83998bb099e366136c428:
dm: core: Do not stop uclass iteration on error (2022-10-29 07:36:33 -0600)
---------------------------------------------------------------- Fix pylibfdt warnings and use setuptools to build Various minor changes to core dm and sandbox
---------------------------------------------------------------- Heinrich Schuchardt (3): x86: fix longjmp() implementation x86: provide typedef jmp_buf sandbox: typo Fictionnal
Michal Suchanek (10): dm: doc: Fix serial howto u-boot,dm-pre-reloc typo dm: pci: Fix doc typo first -> next libfdt: Fix invalid version warning libfdt: Fix build with python 3.10 tests: Build correct sandbox configuration on 32bit dm: core: Switch uclass_*_device_err to use uclass_*_device_check dm: core: Document return value of device bind functions dm: core: Add note about device_probe idempotence dm: treewide: Do not use the return value of simple uclass iterator dm: core: Do not stop uclass iteration on error
Neha Malcom Francis (1): binman: Add support for symlinking images
Patrick Delaunay (1): fdt_support: cosmetic: remove fdt_fixup_nor_flash_size prototype
Rasmus Villemoes (1): gpio-uclass: fix gpio lookup by label
Simon Glass (4): dm: core: Fix lists_bind_fdt() using non-existent of_match event: Drop the path when checking event-list filenames test: Drop unwanted option in event_dump.py fdt: Move to setuptools
Sughosh Ganu (1): thermal: sandbox: Enable thermal uclass for sandbox64 variant
William Zhang (1): dm: tpl: Add fdt address translation support in TPL
arch/sandbox/Kconfig | 18 +---- arch/x86/cpu/i386/setjmp.S | 5 ++ arch/x86/include/asm/setjmp.h | 6 +- board/sandbox/sandbox.c | 2 +- cmd/virtio.c | 9 +-- configs/sandbox64_defconfig | 2 + doc/develop/driver-model/serial-howto.rst | 4 +- drivers/core/Kconfig | 14 ++++ drivers/core/lists.c | 4 +- drivers/core/uclass.c | 30 +++++---- drivers/dma/dma-uclass.c | 7 +- drivers/gpio/gpio-uclass.c | 18 ++--- drivers/pci/pci-uclass.c | 22 ++----- drivers/sysinfo/sysinfo-uclass.c | 10 ++- drivers/w1/w1-uclass.c | 9 +-- include/dm/device-internal.h | 4 +- include/dm/lists.h | 2 + include/dm/uclass.h | 25 +++---- include/fdt_support.h | 2 - include/pci.h | 2 +- scripts/Kconfig.include | 4 ++ scripts/dtc/README | 106 ++++++++++++++++++++++++++++++ scripts/dtc/pylibfdt/Makefile | 5 +- scripts/dtc/pylibfdt/libfdt.i_shipped | 4 ++ scripts/dtc/pylibfdt/setup.py | 57 +++++++++++++--- scripts/event_dump.py | 2 - test/dm/core.c | 10 ++- test/dm/test-fdt.c | 27 ++++++-- test/py/tests/test_event_dump.py | 6 +- tools/binman/binman.rst | 3 + tools/binman/ftest.py | 9 +++ tools/binman/image.py | 6 ++ tools/binman/test/259_symlink.dts | 16 +++++ 33 files changed, 328 insertions(+), 122 deletions(-) create mode 100644 scripts/dtc/README create mode 100644 tools/binman/test/259_symlink.dts
On Sat, Oct 29, 2022 at 04:43:13PM -0600, Simon Glass wrote:
Hi Tom,
