[U-Boot-Users] [PATCH] ppc4xx: Support for ATI Radeon 9200 card on sequoia
Adds configuration option for ATI Radeon 9200 card support to sequoia config file. If CONFIG_VIDEO is enabled, TEXT_BASE should be changed to 0xFFF80000.
Signed-off-by: Anatolij Gustschin agust@denx.de --- include/configs/sequoia.h | 26 +++++++++++++++++++++++++- 1 files changed, 25 insertions(+), 1 deletions(-)
diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index cd0ae6d..52952a9 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -43,7 +43,13 @@ #define CONFIG_SYS_CLK_FREQ ((in8(CFG_BCSR_BASE + 3) & 0x80) ? \ 33333333 : 33000000)
-#if 0 +/* + * Define this if you want support for video console with radeon 9200 pci card + * Also set TEXT_BASE to 0xFFF80000 in board/amcc/sequoia/config.mk in this case + */ +#undef CONFIG_VIDEO + +#ifdef CONFIG_VIDEO /* * 44x dcache supported is working now on sequoia, but we don't enable * it yet since it needs further testing @@ -58,8 +64,13 @@ * Base addresses -- Note these are effective addresses where the actual * resources get mapped (not physical addresses). */ +#ifndef CONFIG_VIDEO #define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kiB for Monitor */ #define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kiB for malloc() */ +#else +#define CFG_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Monitor */ +#define CFG_MALLOC_LEN (1024 * 1024) /* Reserve 1024 kB for malloc() */ +#endif
#define CFG_TLB_FOR_BOOT_FLASH 0x0003 #define CFG_BOOT_BASE_ADDR 0xf0000000 @@ -571,4 +582,17 @@ #define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
+#ifdef CONFIG_VIDEO +#define CONFIG_BIOSEMU /* x86 bios emulator for vga bios */ +#define CONFIG_ATI_RADEON_FB /* use radeon framebuffer driver */ +#define VIDEO_IO_OFFSET 0xe8000000 +#define CFG_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET +#define CONFIG_VIDEO_SW_CURSOR +#define CONFIG_VIDEO_LOGO +#define CONFIG_CFB_CONSOLE +#define CONFIG_SPLASH_SCREEN +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_CMD_BMP +#endif + #endif /* __CONFIG_H */
Applied, thanks.
Anatolij Gustschin
