[U-Boot] [PATCH] mmc_write.c: Make mmc_berase do 32bit safe 64bit math
We want to see if the requested start or total block count are unaligned. We discard the whole numbers and only care about the remainder. Update the code to use div_u64_rem here and add a comment.
Cc: Hans de Goede hdegoede@redhat.com Cc: Pantelis Antoniou pantelis.antoniou@konsulko.com Cc: Bernhard Nortmann bernhard.nortmann@web.de Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com --- drivers/mmc/mmc_write.c | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc_write.c b/drivers/mmc/mmc_write.c index 3db9669..7aea7e9 100644 --- a/drivers/mmc/mmc_write.c +++ b/drivers/mmc/mmc_write.c @@ -10,6 +10,8 @@ #include <config.h> #include <common.h> #include <part.h> +#include <div64.h> +#include <linux/math64.h> #include "mmc_private.h"
static ulong mmc_erase_t(struct mmc *mmc, ulong start, lbaint_t blkcnt) @@ -66,6 +68,7 @@ err_out: unsigned long mmc_berase(int dev_num, lbaint_t start, lbaint_t blkcnt) { int err = 0; + u32 start_rem, blkcnt_rem; struct mmc *mmc = find_mmc_device(dev_num); lbaint_t blk = 0, blk_r = 0; int timeout = 1000; @@ -73,7 +76,14 @@ unsigned long mmc_berase(int dev_num, lbaint_t start, lbaint_t blkcnt) if (!mmc) return -1;
- if ((start % mmc->erase_grp_size) || (blkcnt % mmc->erase_grp_size)) + /* + * We want to see if the requested start or total block count are + * unaligned. We discard the whole numbers and only care about the + * remainder. + */ + err = div_u64_rem(start, mmc->erase_grp_size, &start_rem); + err = div_u64_rem(blkcnt, mmc->erase_grp_size, &blkcnt_rem); + if (start_rem || blkcnt_rem) printf("\n\nCaution! Your devices Erase group is 0x%x\n" "The erase range would be change to " "0x" LBAF "~0x" LBAF "\n\n",
Tom Rini <trini <at> konsulko.com> writes:
Hi Tom!
I can confirm that this patch solves the CONFIG_SYS_64BIT_LBA compilation issue with armhf for me (gcc 4.8.3 armv7a-hardfloat-linux-gnueabi, on a Banana Pi = sun7i/A20).
So I'll add a Tested-by: Bernhard Nortmann bernhard.nortmann@web.de
BTW: There's a small typo you also might want to fix: "The erase range would be change to " -> "The erase range would be changed to "
Regards, B. Nortmann
Cc: Hans de Goede hdegoede@redhat.com Cc: Pantelis Antoniou pantelis.antoniou@konsulko.com Cc: Bernhard Nortmann bernhard.nortmann@web.de Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com Tested-by: Bernhard Nortmann bernhard.nortmann@web.de
Thanks for this, looks good to me:
Reviewed-by: Hans de Goede hdegoede@redhat.com
Regards,
Hans
- u32 start_rem, blkcnt_rem; struct mmc *mmc = find_mmc_device(dev_num); lbaint_t blk = 0, blk_r = 0; int timeout = 1000;
* remainder.
- err = div_u64_rem(start, mmc->erase_grp_size, &start_rem);
- err = div_u64_rem(blkcnt, mmc->erase_grp_size, &blkcnt_rem);
- if (start_rem || blkcnt_rem) printf("\n\nCaution! Your devices Erase group is 0x%x\n" "The erase range would be change to " "0x" LBAF "~0x" LBAF "\n\n",
Cc: Hans de Goede hdegoede@redhat.com Cc: Pantelis Antoniou pantelis.antoniou@konsulko.com Cc: Bernhard Nortmann bernhard.nortmann@web.de Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@konsulko.com Tested-by: Bernhard Nortmann bernhard.nortmann@web.de Reviewed-by: Hans de Goede hdegoede@redhat.com
Bernhard Nortmann
Hans de Goede
