[PATCH v9 1/2] spi: ca_sflash: Add CAxxxx SPI Flash Controller
From: Pengpeng Chen pengpeng.chen@cortina-access.com
Add SPI Flash controller driver for Cortina Access CAxxxx SoCs
Signed-off-by: Pengpeng Chen pengpeng.chen@cortina-access.com Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com CC: Jagan Teki jagan@amarulasolutions.com CC: Vignesh R vigneshr@ti.com CC: Tom Rini trini@konsulko.com
Changes in v9: - Clean up MAINTAINERS changes
Changes in v8: - No code change - Split out individual driver from Cortina Package 2 patch series to help streamline acceptence into master
Changes in v7: - Replace substring "OPCODE" with "OP" in MACROs to help reduce code line lengths - Replace substring "_MASK" with "_MSK" in MACROs to help reduce code line lengths
Changes in v5: None Changes in v3: - Fixup syntax issues related to checkpatch.pl cleanup
MAINTAINERS | 2 + drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/ca_sflash.c | 576 ++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 587 insertions(+) create mode 100644 drivers/spi/ca_sflash.c
diff --git a/MAINTAINERS b/MAINTAINERS index 8add9d4..a503f98 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -181,6 +181,7 @@ F: drivers/gpio/cortina_gpio.c F: drivers/watchdog/cortina_wdt.c F: drivers/serial/serial_cortina.c F: drivers/mmc/ca_dw_mmc.c +F: drivers/spi/ca_sflash.c
ARM/CZ.NIC TURRIS MOX SUPPORT M: Marek Behun marek.behun@nic.cz @@ -732,6 +733,7 @@ F: drivers/gpio/cortina_gpio.c F: drivers/watchdog/cortina_wdt.c F: drivers/serial/serial_cortina.c F: drivers/mmc/ca_dw_mmc.c +F: drivers/spi/ca_sflash.c
MIPS MSCC M: Gregory CLEMENT gregory.clement@bootlin.com diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index dccd5ea..09f2a2a 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -106,6 +106,14 @@ config BCMSTB_SPI be used to access the SPI flash on platforms embedding this Broadcom SPI core.
+config CORTINA_SFLASH + bool "Cortina-Access Serial Flash controller driver" + depends on DM_SPI && SPI_MEM + help + Enable the Cortina-Access Serial Flash controller driver. This driver + can be used to access the SPI NOR/NAND flash on platforms embedding this + Cortina-Access IP core. + config CADENCE_QSPI bool "Cadence QSPI driver" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 6441694..5e53f11 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_BCM63XX_SPI) += bcm63xx_spi.o obj-$(CONFIG_BCMSTB_SPI) += bcmstb_spi.o obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CF_SPI) += cf_spi.o +obj-$(CONFIG_CORTINA_SFLASH) += ca_sflash.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o diff --git a/drivers/spi/ca_sflash.c b/drivers/spi/ca_sflash.c new file mode 100644 index 0000000..00af6bf --- /dev/null +++ b/drivers/spi/ca_sflash.c @@ -0,0 +1,576 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Driver for Cortina SPI-FLASH Controller + * + * Copyright (C) 2020 Cortina Access Inc. All Rights Reserved. + * + * Author: PengPeng Chen pengpeng.chen@cortina-access.com + */ + +#include <common.h> +#include <malloc.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <linux/compat.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/ioport.h> +#include <linux/sizes.h> +#include <spi.h> +#include <spi-mem.h> +#include <reset.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct ca_sflash_regs { + u32 idr; /* 0x00:Flash word ID Register */ + u32 tc; /* 0x04:Flash Timeout Counter Register */ + u32 sr; /* 0x08:Flash Status Register */ + u32 tr; /* 0x0C:Flash Type Register */ + u32 asr; /* 0x10:Flash ACCESS START/BUSY Register */ + u32 isr; /* 0x14:Flash Interrupt Status Register */ + u32 imr; /* 0x18:Flash Interrupt Mask Register */ + u32 fcr; /* 0x1C:NAND Flash FIFO Control Register */ + u32 ffsr; /* 0x20:Flash FIFO Status Register */ + u32 ffar; /* 0x24:Flash FIFO ADDRESS Register */ + u32 ffmar; /* 0x28:Flash FIFO MATCHING ADDRESS Register */ + u32 ffdr; /* 0x2C:Flash FIFO Data Register */ + u32 ar; /* 0x30:Serial Flash Access Register */ + u32 ear; /* 0x34:Serial Flash Extend Access Register */ + u32 adr; /* 0x38:Serial Flash ADdress Register */ + u32 dr; /* 0x3C:Serial Flash Data Register */ + u32 tmr; /* 0x40:Serial Flash Timing Register */ +}; + +/* + * FLASH_TYPE + */ +#define CA_FLASH_TR_PIN BIT(15) +#define CA_FLASH_TR_TYPE_MSK GENMASK(14, 12) +#define CA_FLASH_TR_TYPE(tp) (((tp) << 12) & CA_FLASH_TR_TYPE_MSK) +#define CA_FLASH_TR_WIDTH BIT(11) +#define CA_FLASH_TR_SIZE_MSK GENMASK(10, 9) +#define CA_FLASH_TR_SIZE(sz) (((sz) << 9) & CA_FLASH_TR_SIZE_MSK) + +/* + * FLASH_FLASH_ACCESS_START + */ +#define CA_FLASH_ASR_IND_START_EN BIT(1) +#define CA_FLASH_ASR_DMA_START_EN BIT(3) +#define CA_FLASH_ASR_WR_ACCESS_EN BIT(9) + +/* + * FLASH_FLASH_INTERRUPT + */ +#define CA_FLASH_ISR_REG_IRQ BIT(1) +#define CA_FLASH_ISR_FIFO_IRQ BIT(2) + +/* + * FLASH_SF_ACCESS + */ +#define CA_SF_AR_OP_MSK GENMASK(7, 0) +#define CA_SF_AR_OP(op) ((op) << 0 & CA_SF_AR_OP_MSK) +#define CA_SF_AR_ACCODE_MSK GENMASK(11, 8) +#define CA_SF_AR_ACCODE(ac) (((ac) << 8) & CA_SF_AR_ACCODE_MSK) +#define CA_SF_AR_FORCE_TERM BIT(12) +#define CA_SF_AR_FORCE_BURST BIT(13) +#define CA_SF_AR_AUTO_MODE_EN BIT(15) +#define CA_SF_AR_CHIP_EN_ALT BIT(16) +#define CA_SF_AR_HI_SPEED_RD BIT(17) +#define CA_SF_AR_MIO_INF_DC BIT(24) +#define CA_SF_AR_MIO_INF_AC BIT(25) +#define CA_SF_AR_MIO_INF_CC BIT(26) +#define CA_SF_AR_DDR_MSK GENMASK(29, 28) +#define CA_SF_AR_DDR(ddr) (((ddr) << 28) & CA_SF_AR_DDR_MSK) +#define CA_SF_AR_MIO_INF_MSK GENMASK(31, 30) +#define CA_SF_AR_MIO_INF(io) (((io) << 30) & CA_SF_AR_MIO_INF_MSK) + +/* + * FLASH_SF_EXT_ACCESS + */ +#define CA_SF_EAR_OP_MSK GENMASK(7, 0) +#define CA_SF_EAR_OP(op) (((op) << 0) & CA_SF_EAR_OP_MSK) +#define CA_SF_EAR_DATA_CNT_MSK GENMASK(20, 8) +#define CA_SF_EAR_DATA_CNT(cnt) (((cnt) << 8) & CA_SF_EAR_DATA_CNT_MSK) +#define CA_SF_EAR_DATA_CNT_MAX (4096) +#define CA_SF_EAR_ADDR_CNT_MSK GENMASK(23, 21) +#define CA_SF_EAR_ADDR_CNT(cnt) (((cnt) << 21) & CA_SF_EAR_ADDR_CNT_MSK) +#define CA_SF_EAR_ADDR_CNT_MAX (5) +#define CA_SF_EAR_DUMY_CNT_MSK GENMASK(29, 24) +#define CA_SF_EAR_DUMY_CNT(cnt) (((cnt) << 24) & CA_SF_EAR_DUMY_CNT_MSK) +#define CA_SF_EAR_DUMY_CNT_MAX (32) +#define CA_SF_EAR_DRD_CMD_EN BIT(31) + +/* + * FLASH_SF_ADDRESS + */ +#define CA_SF_ADR_REG_MSK GENMASK(31, 0) +#define CA_SF_ADR_REG(addr) (((addr) << 0) & CA_SF_ADR_REG_MSK) + +/* + * FLASH_SF_DATA + */ +#define CA_SF_DR_REG_MSK GENMASK(31, 0) +#define CA_SF_DR_REG(addr) (((addr) << 0) & CA_SF_DR_REG_MSK) + +/* + * FLASH_SF_TIMING + */ +#define CA_SF_TMR_IDLE_MSK GENMASK(7, 0) +#define CA_SF_TMR_IDLE(idle) (((idle) << 0) & CA_SF_TMR_IDLE_MSK) +#define CA_SF_TMR_HOLD_MSK GENMASK(15, 8) +#define CA_SF_TMR_HOLD(hold) (((hold) << 8) & CA_SF_TMR_HOLD_MSK) +#define CA_SF_TMR_SETUP_MSK GENMASK(23, 16) +#define CA_SF_TMR_SETUP(setup) (((setup) << 16) & CA_SF_TMR_SETUP_MSK) +#define CA_SF_TMR_CLK_MSK GENMASK(26, 24) +#define CA_SF_TMR_CLK(clk) (((clk) << 24) & CA_SF_TMR_CLK_MSK) + +#define CA_SFLASH_IND_WRITE 0 +#define CA_SFLASH_IND_READ 1 +#define CA_SFLASH_MEM_MAP 3 +#define CA_SFLASH_FIFO_TIMEOUT_US 30000 +#define CA_SFLASH_BUSY_TIMEOUT_US 40000 + +#define CA_SF_AC_OP 0x00 +#define CA_SF_AC_OP_1_DATA 0x01 +#define CA_SF_AC_OP_2_DATA 0x02 +#define CA_SF_AC_OP_3_DATA 0x03 +#define CA_SF_AC_OP_4_DATA 0x04 +#define CA_SF_AC_OP_3_ADDR 0x05 +#define CA_SF_AC_OP_4_ADDR (CA_SF_AC_OP_3_ADDR) +#define CA_SF_AC_OP_3_ADDR_1_DATA 0x06 +#define CA_SF_AC_OP_4_ADDR_1_DATA (CA_SF_AC_OP_3_ADDR_1_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_2_DATA 0x07 +#define CA_SF_AC_OP_4_ADDR_2_DATA (CA_SF_AC_OP_3_ADDR_2_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_3_DATA 0x08 +#define CA_SF_AC_OP_4_ADDR_3_DATA (CA_SF_AC_OP_3_ADDR_3_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_4_DATA 0x09 +#define CA_SF_AC_OP_4_ADDR_4_DATA (CA_SF_AC_OP_3_ADDR_4_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_X_1_DATA 0x0A +#define CA_SF_AC_OP_4_ADDR_X_1_DATA (CA_SF_AC_OP_3_ADDR_X_1_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_X_2_DATA 0x0B +#define CA_SF_AC_OP_4_ADDR_X_2_DATA (CA_SF_AC_OP_3_ADDR_X_2_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_X_3_DATA 0x0C +#define CA_SF_AC_OP_4_ADDR_X_3_DATA (CA_SF_AC_OP_3_ADDR_X_3_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_X_4_DATA 0x0D +#define CA_SF_AC_OP_4_ADDR_X_4_DATA (CA_SF_AC_OP_3_ADDR_X_4_DATA << 2) +#define CA_SF_AC_OP_3_ADDR_4X_1_DATA 0x0E +#define CA_SF_AC_OP_4_ADDR_4X_1_DATA (CA_SF_AC_OP_3_ADDR_4X_1_DATA << 2) +#define CA_SF_AC_OP_EXTEND 0x0F + +#define CA_SF_ACCESS_MIO_SINGLE 0 +#define CA_SF_ACCESS_MIO_DUAL 1 +#define CA_SF_ACCESS_MIO_QUARD 2 + +enum access_type { + RD_ACCESS, + WR_ACCESS, +}; + +struct ca_sflash_priv { + struct ca_sflash_regs *regs; + u8 rx_width; + u8 tx_width; +}; + +/* + * This function doesn't do anything except help with debugging + */ +static int ca_sflash_claim_bus(struct udevice *dev) +{ + debug("%s:\n", __func__); + return 0; +} + +static int ca_sflash_release_bus(struct udevice *dev) +{ + debug("%s:\n", __func__); + return 0; +} + +static int ca_sflash_set_speed(struct udevice *dev, uint speed) +{ + debug("%s:\n", __func__); + return 0; +} + +static int ca_sflash_set_mode(struct udevice *dev, uint mode) +{ + struct ca_sflash_priv *priv = dev_get_priv(dev); + + if (mode & SPI_RX_QUAD) + priv->rx_width = 4; + else if (mode & SPI_RX_DUAL) + priv->rx_width = 2; + else + priv->rx_width = 1; + + if (mode & SPI_TX_QUAD) + priv->tx_width = 4; + else if (mode & SPI_TX_DUAL) + priv->tx_width = 2; + else + priv->tx_width = 1; + + debug("%s: mode=%d, rx_width=%d, tx_width=%d\n", + __func__, mode, priv->rx_width, priv->tx_width); + + return 0; +} + +static int _ca_sflash_wait_for_not_busy(struct ca_sflash_priv *priv) +{ + u32 asr; + + if (readl_poll_timeout(&priv->regs->asr, asr, + !(asr & CA_FLASH_ASR_IND_START_EN), + CA_SFLASH_BUSY_TIMEOUT_US)) { + pr_err("busy timeout (stat:%#x)\n", asr); + return -1; + } + + return 0; +} + +static int _ca_sflash_wait_cmd(struct ca_sflash_priv *priv, + enum access_type type) +{ + if (type == WR_ACCESS) { + /* Enable write access and start the sflash indirect access */ + clrsetbits_le32(&priv->regs->asr, GENMASK(31, 0), + CA_FLASH_ASR_WR_ACCESS_EN + | CA_FLASH_ASR_IND_START_EN); + } else if (type == RD_ACCESS) { + /* Start the sflash indirect access */ + clrsetbits_le32(&priv->regs->asr, GENMASK(31, 0), + CA_FLASH_ASR_IND_START_EN); + } else { + printf("%s: !error access type.\n", __func__); + return -1; + } + + /* Wait til the action(rd/wr) completed */ + return _ca_sflash_wait_for_not_busy(priv); +} + +static int _ca_sflash_read(struct ca_sflash_priv *priv, + u8 *buf, unsigned int data_len) +{ + u32 reg_data; + int len; + + len = data_len; + while (len >= 4) { + if (_ca_sflash_wait_cmd(priv, RD_ACCESS)) + return -1; + reg_data = readl(&priv->regs->dr); + *buf++ = reg_data & 0xFF; + *buf++ = (reg_data >> 8) & 0xFF; + *buf++ = (reg_data >> 16) & 0xFF; + *buf++ = (reg_data >> 24) & 0xFF; + len -= 4; + debug("%s: reg_data=%#08x\n", + __func__, reg_data); + } + + if (len > 0) { + if (_ca_sflash_wait_cmd(priv, RD_ACCESS)) + return -1; + reg_data = readl(&priv->regs->dr); + debug("%s: reg_data=%#08x\n", + __func__, reg_data); + } + + switch (len) { + case 3: + *buf++ = reg_data & 0xFF; + *buf++ = (reg_data >> 8) & 0xFF; + *buf++ = (reg_data >> 16) & 0xFF; + break; + case 2: + *buf++ = reg_data & 0xFF; + *buf++ = (reg_data >> 8) & 0xFF; + break; + case 1: + *buf++ = reg_data & 0xFF; + break; + case 0: + break; + default: + printf("%s: error data_length %d!\n", __func__, len); + } + + return 0; +} + +static int _ca_sflash_mio_set(struct ca_sflash_priv *priv, + u8 width) +{ + if (width == 4) { + setbits_le32(&priv->regs->ar, + CA_SF_AR_MIO_INF_DC + | CA_SF_AR_MIO_INF(CA_SF_ACCESS_MIO_QUARD) + | CA_SF_AR_FORCE_BURST); + } else if (width == 2) { + setbits_le32(&priv->regs->ar, + CA_SF_AR_MIO_INF_DC + | CA_SF_AR_MIO_INF(CA_SF_ACCESS_MIO_DUAL) + | CA_SF_AR_FORCE_BURST); + } else if (width == 1) { + setbits_le32(&priv->regs->ar, + CA_SF_AR_MIO_INF(CA_SF_ACCESS_MIO_SINGLE) + | CA_SF_AR_FORCE_BURST); + } else { + printf("%s: error rx/tx width %d!\n", __func__, width); + return -1; + } + + return 0; +} + +static int _ca_sflash_write(struct ca_sflash_priv *priv, + u8 *buf, unsigned int data_len) +{ + u32 reg_data; + int len; + + len = data_len; + while (len > 0) { + reg_data = buf[0] + | (buf[1] << 8) + | (buf[2] << 16) + | (buf[3] << 24); + + debug("%s: reg_data=%#08x\n", + __func__, reg_data); + /* Fill data */ + clrsetbits_le32(&priv->regs->dr, GENMASK(31, 0), reg_data); + + if (_ca_sflash_wait_cmd(priv, WR_ACCESS)) + return -1; + + len -= 4; + buf += 4; + } + + return 0; +} + +static int _ca_sflash_access_data(struct ca_sflash_priv *priv, + struct spi_mem_op *op) +{ + int total_cnt; + unsigned int len; + unsigned int data_cnt = op->data.nbytes; + u64 addr_offset = op->addr.val; + u8 addr_cnt = op->addr.nbytes; + u8 *data_buf = NULL; + u8 *buf = NULL; + + if (op->data.dir == SPI_MEM_DATA_IN) + data_buf = (u8 *)op->data.buf.in; + else + data_buf = (u8 *)op->data.buf.out; + + if (data_cnt > CA_SF_EAR_DATA_CNT_MAX) + buf = malloc(CA_SF_EAR_DATA_CNT_MAX); + else + buf = malloc(data_cnt); + + total_cnt = data_cnt; + while (total_cnt > 0) { + /* Fill address */ + if (addr_cnt > 0) + clrsetbits_le32(&priv->regs->adr, + GENMASK(31, 0), (u32)addr_offset); + + if (total_cnt > CA_SF_EAR_DATA_CNT_MAX) { + len = CA_SF_EAR_DATA_CNT_MAX; + addr_offset += CA_SF_EAR_DATA_CNT_MAX; + /* Clear start bit before next bulk read */ + clrbits_le32(&priv->regs->asr, GENMASK(31, 0)); + } else { + len = total_cnt; + } + + memset(buf, 0, len); + if (op->data.dir == SPI_MEM_DATA_IN) { + if (_ca_sflash_read(priv, buf, len)) + break; + memcpy(data_buf, buf, len); + } else { + memcpy(buf, data_buf, len); + if (_ca_sflash_write(priv, buf, len)) + break; + } + + total_cnt -= len; + data_buf += len; + } + if (buf) + free(buf); + + return total_cnt > 0 ? -1 : 0; +} + +static int _ca_sflash_issue_cmd(struct ca_sflash_priv *priv, + struct spi_mem_op *op, u8 opcode) +{ + u8 dummy_cnt = op->dummy.nbytes; + u8 addr_cnt = op->addr.nbytes; + u8 mio_width; + unsigned int data_cnt = op->data.nbytes; + u64 addr_offset = op->addr.val; + + /* Set the access register */ + clrsetbits_le32(&priv->regs->ar, + GENMASK(31, 0), CA_SF_AR_ACCODE(opcode)); + + if (opcode == CA_SF_AC_OP_EXTEND) { /* read_data, write_data */ + if (data_cnt > 6) { + if (op->data.dir == SPI_MEM_DATA_IN) + mio_width = priv->rx_width; + else + mio_width = priv->tx_width; + if (_ca_sflash_mio_set(priv, mio_width)) + return -1; + } + debug("%s: FLASH ACCESS reg=%#08x\n", + __func__, readl(&priv->regs->ar)); + + /* Use command in extend_access register */ + clrsetbits_le32(&priv->regs->ear, + GENMASK(31, 0), CA_SF_EAR_OP(op->cmd.opcode) + | CA_SF_EAR_DUMY_CNT(dummy_cnt * 8 - 1) + | CA_SF_EAR_ADDR_CNT(addr_cnt - 1) + | CA_SF_EAR_DATA_CNT(4 - 1) + | CA_SF_EAR_DRD_CMD_EN); + debug("%s: FLASH EXT ACCESS reg=%#08x\n", + __func__, readl(&priv->regs->ear)); + + if (_ca_sflash_access_data(priv, op)) + return -1; + } else { /* reset_op, wr_enable, wr_disable */ + setbits_le32(&priv->regs->ar, + CA_SF_AR_OP(op->cmd.opcode)); + debug("%s: FLASH ACCESS reg=%#08x\n", + __func__, readl(&priv->regs->ar)); + + if (opcode == CA_SF_AC_OP_4_ADDR) { /* erase_op */ + /* Configure address length */ + if (addr_cnt > 3) /* 4 Bytes address */ + setbits_le32(&priv->regs->tr, + CA_FLASH_TR_SIZE(2)); + else /* 3 Bytes address */ + clrbits_le32(&priv->regs->tr, + CA_FLASH_TR_SIZE_MSK); + + /* Fill address */ + if (addr_cnt > 0) + clrsetbits_le32(&priv->regs->adr, + GENMASK(31, 0), + (u32)addr_offset); + } + + if (_ca_sflash_wait_cmd(priv, RD_ACCESS)) + return -1; + } + /* elapse 10us before issuing any other command */ + udelay(10); + + return 0; +} + +static int ca_sflash_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + struct ca_sflash_priv *priv = dev_get_priv(slave->dev->parent); + u8 opcode; + + debug("%s: cmd:%#02x addr.val:%#llx addr.len:%#x data.len:%#x data.dir:%#x\n", + __func__, op->cmd.opcode, op->addr.val, + op->addr.nbytes, op->data.nbytes, op->data.dir); + + if (op->data.nbytes == 0 && op->addr.nbytes == 0) { + opcode = CA_SF_AC_OP; + } else if (op->data.nbytes == 0 && op->addr.nbytes > 0) { + opcode = CA_SF_AC_OP_4_ADDR; + } else if (op->data.nbytes > 0) { + opcode = CA_SF_AC_OP_EXTEND; + } else { + printf("%s: can't support cmd.opcode:(%#02x) type currently!\n", + __func__, op->cmd.opcode); + return -1; + } + + return _ca_sflash_issue_cmd(priv, (struct spi_mem_op *)op, opcode); +} + +static void ca_sflash_init(struct ca_sflash_priv *priv) +{ + /* Set FLASH_TYPE as serial flash, value: 0x0400*/ + clrsetbits_le32(&priv->regs->tr, + GENMASK(31, 0), CA_FLASH_TR_SIZE(2)); + debug("%s: FLASH_TYPE reg=%#x\n", + __func__, readl(&priv->regs->tr)); + + /* Minimize flash timing, value: 0x07010101 */ + clrsetbits_le32(&priv->regs->tmr, + GENMASK(31, 0), + CA_SF_TMR_CLK(0x07) + | CA_SF_TMR_SETUP(0x01) + | CA_SF_TMR_HOLD(0x01) + | CA_SF_TMR_IDLE(0x01)); + debug("%s: FLASH_TIMING reg=%#x\n", + __func__, readl(&priv->regs->tmr)); +} + +static int ca_sflash_probe(struct udevice *dev) +{ + struct ca_sflash_priv *priv = dev_get_priv(dev); + struct resource res; + int ret; + + /* Map the registers */ + ret = dev_read_resource_byname(dev, "sflash-regs", &res); + if (ret) { + dev_err(dev, "can't get regs base addresses(ret = %d)!\n", ret); + return ret; + } + priv->regs = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(priv->regs)) + return PTR_ERR(priv->regs); + + ca_sflash_init(priv); + + printf("SFLASH: Controller probed ready\n"); + return 0; +} + +static const struct spi_controller_mem_ops ca_sflash_mem_ops = { + .exec_op = ca_sflash_exec_op, +}; + +static const struct dm_spi_ops ca_sflash_ops = { + .claim_bus = ca_sflash_claim_bus, + .release_bus = ca_sflash_release_bus, + .set_speed = ca_sflash_set_speed, + .set_mode = ca_sflash_set_mode, + .mem_ops = &ca_sflash_mem_ops, +}; + +static const struct udevice_id ca_sflash_ids[] = { + {.compatible = "cortina,ca-sflash"}, + {} +}; + +U_BOOT_DRIVER(ca_sflash) = { + .name = "ca_sflash", + .id = UCLASS_SPI, + .of_match = ca_sflash_ids, + .ops = &ca_sflash_ops, + .priv_auto_alloc_size = sizeof(struct ca_sflash_priv), + .probe = ca_sflash_probe, +};
Add SPI NOR support for Cortina Access Presidio Engineering Board
Changes in v9: None Changes in v8: None Changes in v7: None Changes in v5: - NAND support removed from presidio-asic board DT.
Changes in v3: None
arch/arm/dts/ca-presidio-engboard.dts | 6 +-- board/cortina/presidio-asic/presidio.c | 16 ++++++- configs/cortina_presidio-asic-spi-nand_defconfig | 48 +++++++++++++++++++ configs/cortina_presidio-asic-spi-nor_defconfig | 59 ++++++++++++++++++++++++ 4 files changed, 124 insertions(+), 5 deletions(-) create mode 100644 configs/cortina_presidio-asic-spi-nand_defconfig create mode 100644 configs/cortina_presidio-asic-spi-nor_defconfig
diff --git a/arch/arm/dts/ca-presidio-engboard.dts b/arch/arm/dts/ca-presidio-engboard.dts index c03dacc..34148b9 100644 --- a/arch/arm/dts/ca-presidio-engboard.dts +++ b/arch/arm/dts/ca-presidio-engboard.dts @@ -55,15 +55,13 @@ };
sflash: sflash-controller@f4324000 { - #address-cells = <2>; - #size-cells = <1>; compatible = "cortina,ca-sflash"; reg = <0x0 0xf4324000 0x50>; reg-names = "sflash-regs"; flash@0 { compatible = "jedec,spi-nor"; - spi-rx-bus-width = <1>; - spi-max-frequency = <108000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; }; }; }; diff --git a/board/cortina/presidio-asic/presidio.c b/board/cortina/presidio-asic/presidio.c index 3c132f1..883bd2e 100644 --- a/board/cortina/presidio-asic/presidio.c +++ b/board/cortina/presidio-asic/presidio.c @@ -16,7 +16,7 @@ #include <asm/psci.h> #include <cpu_func.h> #include <asm/armv8/mmu.h> - +#include <dm/uclass.h> DECLARE_GLOBAL_DATA_PTR;
#define CA_PERIPH_BASE 0xE0000000UL @@ -72,9 +72,23 @@ static noinline int invoke_psci_fn_smc(u64 function_id, u64 arg0, u64 arg1, return function_id; }
+#ifdef CONFIG_CORTINA_SFLASH +static int init_sflash(void) +{ + struct udevice *dev; + + uclass_first_device(UCLASS_SPI, &dev); + + return 0; +} +#endif + int board_early_init_r(void) { dcache_disable(); +#ifdef CONFIG_CORTINA_SFLASH + init_sflash(); +#endif return 0; }
diff --git a/configs/cortina_presidio-asic-spi-nand_defconfig b/configs/cortina_presidio-asic-spi-nand_defconfig new file mode 100644 index 0000000..515ad22 --- /dev/null +++ b/configs/cortina_presidio-asic-spi-nand_defconfig @@ -0,0 +1,48 @@ +CONFIG_ARM=y +# CONFIG_SYS_ARCH_TIMER is not set +CONFIG_TARGET_PRESIDIO_ASIC=y +CONFIG_SYS_TEXT_BASE=0x04000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DM_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_IDENT_STRING="Presidio-SoC" +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTDELAY=3 +CONFIG_LOGLEVEL=7 +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SYS_PROMPT="G3#" +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PART=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_SMC=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_MTDPARTS=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_DEFAULT_DEVICE_TREE="ca-presidio-engboard" +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_CORTINA_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CA=y +CONFIG_DM_MMC=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_CORTINA=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_SPI_NAND=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DM_SERIAL=y +CONFIG_CORTINA_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CORTINA_SFLASH=y +CONFIG_WDT=y +CONFIG_WDT_CORTINA=y diff --git a/configs/cortina_presidio-asic-spi-nor_defconfig b/configs/cortina_presidio-asic-spi-nor_defconfig new file mode 100644 index 0000000..d7ecec3 --- /dev/null +++ b/configs/cortina_presidio-asic-spi-nor_defconfig @@ -0,0 +1,59 @@ +CONFIG_ARM=y +# CONFIG_SYS_ARCH_TIMER is not set +CONFIG_TARGET_PRESIDIO_ASIC=y +CONFIG_SYS_TEXT_BASE=0x04000000 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DM_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_IDENT_STRING="Presidio-SoC" +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTDELAY=3 +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SYS_PROMPT="G3#" +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PART=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_WDT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_SMC=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_MTDPARTS=y +CONFIG_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_DEFAULT_DEVICE_TREE="ca-presidio-engboard" +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_CORTINA_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CA=y +CONFIG_LED=y +CONFIG_LED_CORTINA=y +CONFIG_DM_MMC=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_CORTINA=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DM_SERIAL=y +CONFIG_CORTINA_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CORTINA_SFLASH=y +CONFIG_WDT=y +CONFIG_WDT_CORTINA=y
On Tue, Jun 2, 2020 at 1:56 AM Alex Nemirovsky alex.nemirovsky@cortina-access.com wrote:
Changes in v3: None
What is the need of this explicit probe? we have sf to probe the flash?
Jagan.
Hi Jagan,
Seems that this patch set may have stalled. Its marked as change requested but we are unaware of any outstanding change request. Could you look into it?
TIA Alex
On Jun 1, 2020, at 1:26 PM, Alex Nemirovsky alex.nemirovsky@cortina-access.com wrote:
Changes in v9:
Changes in v8:
- No code change
Changes in v7:
- bool "Cortina-Access Serial Flash controller driver"
- depends on DM_SPI && SPI_MEM
- help
- Driver for Cortina SPI-FLASH Controller
- Copyright (C) 2020 Cortina Access Inc. All Rights Reserved.
- Author: PengPeng Chen pengpeng.chen@cortina-access.com
- u32 idr; /* 0x00:Flash word ID Register */
- u32 tc; /* 0x04:Flash Timeout Counter Register */
- u32 sr; /* 0x08:Flash Status Register */
- u32 tr; /* 0x0C:Flash Type Register */
- u32 asr; /* 0x10:Flash ACCESS START/BUSY Register */
- u32 isr; /* 0x14:Flash Interrupt Status Register */
- u32 imr; /* 0x18:Flash Interrupt Mask Register */
- u32 fcr; /* 0x1C:NAND Flash FIFO Control Register */
- u32 ffsr; /* 0x20:Flash FIFO Status Register */
- u32 ffar; /* 0x24:Flash FIFO ADDRESS Register */
- u32 ffmar; /* 0x28:Flash FIFO MATCHING ADDRESS Register */
- u32 ffdr; /* 0x2C:Flash FIFO Data Register */
- u32 ar; /* 0x30:Serial Flash Access Register */
- u32 ear; /* 0x34:Serial Flash Extend Access Register */
- u32 adr; /* 0x38:Serial Flash ADdress Register */
- u32 dr; /* 0x3C:Serial Flash Data Register */
- u32 tmr; /* 0x40:Serial Flash Timing Register */
- FLASH_TYPE
- FLASH_FLASH_ACCESS_START
- FLASH_FLASH_INTERRUPT
- FLASH_SF_ACCESS
- FLASH_SF_EXT_ACCESS
- FLASH_SF_ADDRESS
- FLASH_SF_DATA
- FLASH_SF_TIMING
+enum access_type {
- RD_ACCESS,
- WR_ACCESS,
- struct ca_sflash_regs *regs;
- u8 rx_width;
- u8 tx_width;
- This function doesn't do anything except help with debugging
- debug("%s:\n", __func__);
- struct ca_sflash_priv *priv = dev_get_priv(dev);
- if (mode & SPI_RX_QUAD)
priv->rx_width = 4;
- else if (mode & SPI_RX_DUAL)
priv->rx_width = 2;
- else
priv->rx_width = 1;
- if (mode & SPI_TX_QUAD)
priv->tx_width = 4;
- else if (mode & SPI_TX_DUAL)
priv->tx_width = 2;
- else
priv->tx_width = 1;
- debug("%s: mode=%d, rx_width=%d, tx_width=%d\n",
- u32 asr;
- if (readl_poll_timeout(&priv->regs->asr, asr,
return -1;
- if (type == WR_ACCESS) {
- } else if (type == RD_ACCESS) {
- } else {
return -1;
- /* Wait til the action(rd/wr) completed */
- return _ca_sflash_wait_for_not_busy(priv);
- u32 reg_data;
- int len;
- len = data_len;
- while (len >= 4) {
return -1;
len -= 4;
- if (len > 0) {
return -1;
- switch (len) {
- case 3:
break;
- case 2:
break;
- case 1:
break;
- case 0:
break;
- default:
u8 width)
- if (width == 4) {
CA_SF_AR_MIO_INF_DC
- } else if (width == 2) {
CA_SF_AR_MIO_INF_DC
- } else if (width == 1) {
- } else {
return -1;
- u32 reg_data;
- int len;
- len = data_len;
- while (len > 0) {
reg_data = buf[0]
| (buf[1] << 8)
| (buf[2] << 16)
| (buf[3] << 24);
/* Fill data */
return -1;
len -= 4;
buf += 4;
- int total_cnt;
- unsigned int len;
- unsigned int data_cnt = op->data.nbytes;
- u64 addr_offset = op->addr.val;
- u8 addr_cnt = op->addr.nbytes;
- u8 *data_buf = NULL;
- u8 *buf = NULL;
- if (op->data.dir == SPI_MEM_DATA_IN)
- else
- if (data_cnt > CA_SF_EAR_DATA_CNT_MAX)
- else
- total_cnt = data_cnt;
- while (total_cnt > 0) {
/* Fill address */
if (addr_cnt > 0)
} else {
len = total_cnt;
break;
} else {
break;
total_cnt -= len;
data_buf += len;
- if (buf)
free(buf);
- return total_cnt > 0 ? -1 : 0;
- u8 dummy_cnt = op->dummy.nbytes;
- u8 mio_width;
- /* Set the access register */
- clrsetbits_le32(&priv->regs->ar,
- if (opcode == CA_SF_AC_OP_EXTEND) { /* read_data, write_data */
if (data_cnt > 6) {
else
return -1;
return -1;
- } else { /* reset_op, wr_enable, wr_disable */
/* Fill address */
if (addr_cnt > 0)
GENMASK(31, 0),
(u32)addr_offset);
return -1;
- /* elapse 10us before issuing any other command */
- udelay(10);
- struct ca_sflash_priv *priv = dev_get_priv(slave->dev->parent);
- u8 opcode;
- debug("%s: cmd:%#02x addr.val:%#llx addr.len:%#x data.len:%#x data.dir:%#x\n",
- if (op->data.nbytes == 0 && op->addr.nbytes == 0) {
- } else if (op->data.nbytes == 0 && op->addr.nbytes > 0) {
- } else if (op->data.nbytes > 0) {
- } else {
return -1;
- return _ca_sflash_issue_cmd(priv, (struct spi_mem_op *)op, opcode);
- /* Set FLASH_TYPE as serial flash, value: 0x0400*/
- clrsetbits_le32(&priv->regs->tr,
- debug("%s: FLASH_TYPE reg=%#x\n",
- /* Minimize flash timing, value: 0x07010101 */
- clrsetbits_le32(&priv->regs->tmr,
GENMASK(31, 0),
CA_SF_TMR_CLK(0x07)
- debug("%s: FLASH_TIMING reg=%#x\n",
- struct resource res;
- int ret;
- /* Map the registers */
- ret = dev_read_resource_byname(dev, "sflash-regs", &res);
- if (ret) {
return ret;
- priv->regs = devm_ioremap(dev, res.start, resource_size(&res));
- if (IS_ERR(priv->regs))
- ca_sflash_init(priv);
- printf("SFLASH: Controller probed ready\n");
- .exec_op = ca_sflash_exec_op,
- .claim_bus = ca_sflash_claim_bus,
- .release_bus = ca_sflash_release_bus,
- .set_speed = ca_sflash_set_speed,
- .set_mode = ca_sflash_set_mode,
- .mem_ops = &ca_sflash_mem_ops,
- {.compatible = "cortina,ca-sflash"},
- .name = "ca_sflash",
- .id = UCLASS_SPI,
- .of_match = ca_sflash_ids,
- .ops = &ca_sflash_ops,
- .priv_auto_alloc_size = sizeof(struct ca_sflash_priv),
- .probe = ca_sflash_probe,
2.7.4
Alex Nemirovsky
Alex Nemirovsky
Jagan Teki
