[U-Boot] [PATCH 0/7 V4] EXYNOS5: Enable SPI support
This patch set adds SPI driver for EXYNOS5 and enables same. This patch set is based on latest Mainline u-boot.git tree.
Changes in V2: - Correted the Commit message. Changes in V3: - Removed SPI_SLAVE Flag. - Corrected warning messages. Changes on V4: - Rebased on mainline u-boot.git - Incorporated review comments for SPI driver.
Rajeshwari Shinde (7): EXYNOS5: Add pinmux support for SPI SPI: Add W25Q32 to Winbond SPI flash table EXYNOS: Add clock for SPI. EXYNOS5: Add base address for SPI. SPI: Add SPI Driver for EXYNOS. EXYNOS5: Enable SPI EXYNOS5: Enable SPI booting.
arch/arm/cpu/armv7/exynos/clock.c | 124 +++++++ arch/arm/cpu/armv7/exynos/pinmux.c | 51 +++- arch/arm/include/asm/arch-exynos/clk.h | 4 +- arch/arm/include/asm/arch-exynos/cpu.h | 6 + arch/arm/include/asm/arch-exynos/periph.h | 5 + arch/arm/include/asm/arch-exynos/spi.h | 78 +++++ board/samsung/smdk5250/Makefile | 2 +- board/samsung/smdk5250/smdk5250.c | 4 + board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} | 31 ++- drivers/mtd/spi/winbond.c | 8 + drivers/spi/Makefile | 1 + drivers/spi/exynos_spi.c | 364 +++++++++++++++++++++ include/configs/smdk5250.h | 28 ++- 13 files changed, 700 insertions(+), 6 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/spi.h rename board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} (66%) create mode 100644 drivers/spi/exynos_spi.c
This patch adds pinmux support for SPI channels
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None. Changes in V3: - Removed the slave flag for SPI. Changes in V4: - Rebased on Mainline u-boot.git. arch/arm/cpu/armv7/exynos/pinmux.c | 51 ++++++++++++++++++++++++++++- arch/arm/include/asm/arch-exynos/periph.h | 5 +++ 2 files changed, 55 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index d28f055..415d7fa 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -226,6 +226,49 @@ static void exynos5_i2c_config(int peripheral, int flags) } }
+void exynos5_spi_config(int peripheral) +{ + int cfg = 0, pin = 0, i; + struct s5p_gpio_bank *bank = NULL; + struct exynos5_gpio_part1 *gpio1 = + (struct exynos5_gpio_part1 *) samsung_get_base_gpio_part1(); + struct exynos5_gpio_part2 *gpio2 = + (struct exynos5_gpio_part2 *) samsung_get_base_gpio_part2(); + + switch (peripheral) { + case PERIPH_ID_SPI0: + bank = &gpio1->a2; + cfg = GPIO_FUNC(0x2); + pin = 0; + break; + case PERIPH_ID_SPI1: + bank = &gpio1->a2; + cfg = GPIO_FUNC(0x2); + pin = 4; + break; + case PERIPH_ID_SPI2: + bank = &gpio1->b1; + cfg = GPIO_FUNC(0x5); + pin = 1; + break; + case PERIPH_ID_SPI3: + bank = &gpio2->f1; + cfg = GPIO_FUNC(0x2); + pin = 0; + break; + case PERIPH_ID_SPI4: + for (i = 2; i < 4; i++) + s5p_gpio_cfg_pin(&gpio2->f0, i, GPIO_FUNC(0x4)); + for (i = 4; i < 6; i++) + s5p_gpio_cfg_pin(&gpio2->e0, i, GPIO_FUNC(0x4)); + break; + } + if (peripheral != PERIPH_ID_SPI4) { + for (i = pin; i < pin + 4; i++) + s5p_gpio_cfg_pin(bank, i, cfg); + } +} + static int exynos5_pinmux_config(int peripheral, int flags) { switch (peripheral) { @@ -253,11 +296,17 @@ static int exynos5_pinmux_config(int peripheral, int flags) case PERIPH_ID_I2C7: exynos5_i2c_config(peripheral, flags); break; + case PERIPH_ID_SPI0: + case PERIPH_ID_SPI1: + case PERIPH_ID_SPI2: + case PERIPH_ID_SPI3: + case PERIPH_ID_SPI4: + exynos5_spi_config(peripheral); + break; default: debug("%s: invalid peripheral %d", __func__, peripheral); return -1; } - return 0; }
diff --git a/arch/arm/include/asm/arch-exynos/periph.h b/arch/arm/include/asm/arch-exynos/periph.h index b861d7d..dafc3f3 100644 --- a/arch/arm/include/asm/arch-exynos/periph.h +++ b/arch/arm/include/asm/arch-exynos/periph.h @@ -43,6 +43,11 @@ enum periph_id { PERIPH_ID_SDMMC2, PERIPH_ID_SDMMC3, PERIPH_ID_SROMC, + PERIPH_ID_SPI0, + PERIPH_ID_SPI1, + PERIPH_ID_SPI2, + PERIPH_ID_SPI3, + PERIPH_ID_SPI4, PERIPH_ID_UART0, PERIPH_ID_UART1, PERIPH_ID_UART2,
SMDK EVT1 has a different Winbond part, added its part details to the SPI flash table
Signed-off-by: Abhilash Kesavan a.kesavan@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Corrected the commit message. Changes in V3: - None. Changes in V4: - Rebased on Mainline u-boot.git. drivers/mtd/spi/winbond.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/winbond.c b/drivers/mtd/spi/winbond.c index 427b71f..ae4e48a 100644 --- a/drivers/mtd/spi/winbond.c +++ b/drivers/mtd/spi/winbond.c @@ -62,6 +62,14 @@ static const struct winbond_spi_flash_params winbond_spi_flash_table[] = { .nr_blocks = 256, .name = "W25Q128", }, + { + .id = 0x5014, + .l2_page_size = 8, + .pages_per_sector = 16, + .sectors_per_block = 16, + .nr_blocks = 128, + .name = "W25Q80", + }, };
struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode)
On Thursday 02 August 2012 11:19:16 Mike Frysinger wrote:
thanks, merged in my sf branch
actually, you didn't rebase it. half the fields in there no longer exist in master which is why i asked you to rebase it in the first place.
at any rate, i fixed it for you now. please at least *compile* test your patches in the future. -mike
Hi Rajeshwari.
2012/8/2 Rajeshwari Shinde rajeshwari.s@samsung.com:
.id = 0x5014,
.l2_page_size = 8,
Above three fields is removed from commit a4ed3b653163367628d4ad173dfe3faf388da0ac, but in spi_flash_probe_winbond()
flash->page_size = 4096;
original codes are
/* Assuming power-of-two page size initially. */ page_size = 1 << params->l2_page_size; ... flash->page_size = page_size;
so i think flash->page_size is 256 or (1 << 8).
When flash->page_size is 4096, is your spi_flash device working well?
.nr_blocks = 128,
.name = "W25Q80",
1.7.4.4
Thanks.
.id = 0x5014,
.l2_page_size = 8,
that was mentioned & fixed already
this was also reported & fixed independently -mike
This patch adds api to calculate and set the clock for SPI channels
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None Changes in V3: - Corrected Warning messages. Changes in V4: - Rebased on Mainline u-boot.git. arch/arm/cpu/armv7/exynos/clock.c | 124 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/clk.h | 4 +- 2 files changed, 127 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index f7829b2..9b015a6 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -601,6 +601,122 @@ static unsigned long exynos5_get_i2c_clk(void) return aclk_66; }
+/** + * Linearly searches for the most accurate main and fine stage clock scalars + * (divisors) for a specified target frequency and scalar bit sizes by checking + * all multiples of main_scalar_bits values. Will always return scalars up to or + * slower than target. + * + * @param main_scalar_bits Number of main scalar bits, must be > 0 and < 32 + * @param fine_scalar_bits Number of fine scalar bits, must be > 0 and < 32 + * @param input_freq Clock frequency to be scaled in Hz + * @param target_freq Desired clock frequency in Hz + * @param best_fine_scalar Pointer to store the fine stage divisor + * + * @return best_main_scalar Main scalar for desired frequency or -1 if none + * found + */ +static int clock_calc_best_scalar(unsigned int main_scaler_bits, + unsigned int fine_scalar_bits, unsigned int input_rate, + unsigned int target_rate, unsigned int *best_fine_scalar) +{ + int i; + int best_main_scalar = -1; + unsigned int best_error = target_rate; + const unsigned int cap = (1 << fine_scalar_bits) - 1; + const unsigned int loops = 1 << main_scaler_bits; + + debug("Input Rate is %u, Target is %u, Cap is %u\n", input_rate, + target_rate, cap); + + assert(best_fine_scalar != NULL); + assert(main_scaler_bits <= fine_scalar_bits); + + *best_fine_scalar = 1; + + if (input_rate == 0 || target_rate == 0) + return -1; + + if (target_rate >= input_rate) + return 1; + + for (i = 1; i <= loops; i++) { + const unsigned int effective_div = max(min(input_rate / i / + target_rate, cap), 1); + const unsigned int effective_rate = input_rate / i / + effective_div; + const int error = target_rate - effective_rate; + + debug("%d|effdiv:%u, effrate:%u, error:%d\n", i, effective_div, + effective_rate, error); + + if (error >= 0 && error <= best_error) { + best_error = error; + best_main_scalar = i; + *best_fine_scalar = effective_div; + } + } + + return best_main_scalar; +} + +static int exynos5_spi_set_clock_rate(enum periph_id periph_id, + unsigned int rate) +{ + struct exynos5_clock *clk = + (struct exynos5_clock *)samsung_get_base_clock(); + int main; + unsigned int fine; + unsigned shift, pre_shift; + unsigned mask = 0xff; + u32 *reg; + + main = clock_calc_best_scalar(4, 8, 400000000, rate, &fine); + if (main < 0) { + debug("%s: Cannot set clock rate for periph %d", + __func__, periph_id); + return -1; + } + main = main - 1; + fine = fine - 1; + + switch (periph_id) { + case PERIPH_ID_SPI0: + reg = &clk->div_peric1; + shift = 0; + pre_shift = 8; + break; + case PERIPH_ID_SPI1: + reg = &clk->div_peric1; + shift = 16; + pre_shift = 24; + break; + case PERIPH_ID_SPI2: + reg = &clk->div_peric2; + shift = 0; + pre_shift = 8; + break; + case PERIPH_ID_SPI3: + reg = &clk->sclk_div_isp; + shift = 0; + pre_shift = 4; + break; + case PERIPH_ID_SPI4: + reg = &clk->sclk_div_isp; + shift = 12; + pre_shift = 16; + break; + default: + debug("%s: Unsupported peripheral ID %d\n", __func__, + periph_id); + return -1; + } + clrsetbits_le32(reg, mask << shift, (main & mask) << shift); + clrsetbits_le32(reg, mask << pre_shift, (fine & mask) << pre_shift); + + return 0; +} + unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) @@ -670,3 +786,11 @@ void set_mipi_clk(void) if (cpu_is_exynos4()) exynos4_set_mipi_clk(); } + +int spi_set_clock_rate(enum periph_id periph_id, unsigned int rate) +{ + if (cpu_is_exynos5()) + return exynos5_spi_set_clock_rate(periph_id, rate); + else + return 0; +} diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index 72dc655..401931c 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -22,6 +22,8 @@ #ifndef __ASM_ARM_ARCH_CLK_H_ #define __ASM_ARM_ARCH_CLK_H_
+#include <asm/arch/pinmux.h> + #define APLL 0 #define MPLL 1 #define EPLL 2 @@ -37,5 +39,5 @@ void set_mmc_clk(int dev_index, unsigned int div); unsigned long get_lcd_clk(void); void set_lcd_clk(void); void set_mipi_clk(void); - +int spi_set_clock_rate(enum periph_id periph_id, unsigned int rate); #endif
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None Changes in V3: - None. Changes in V4: - Rebased on Mainline u-boot.git. arch/arm/include/asm/arch-exynos/cpu.h | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index 0e6ea87..89c2dd3 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -51,11 +51,13 @@ #define EXYNOS4_UART_BASE 0x13800000 #define EXYNOS4_I2C_BASE 0x13860000 #define EXYNOS4_ADC_BASE 0x13910000 +#define EXYNOS4_SPI_BASE 0x13920000 #define EXYNOS4_PWMTIMER_BASE 0x139D0000 #define EXYNOS4_MODEM_BASE 0x13A00000 #define EXYNOS4_USBPHY_CONTROL 0x10020704
#define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4_SPI_ISP_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS5 */ #define EXYNOS5_I2C_SPACING 0x10000 @@ -80,7 +82,9 @@ #define EXYNOS5_SROMC_BASE 0x12250000 #define EXYNOS5_UART_BASE 0x12C00000 #define EXYNOS5_I2C_BASE 0x12C60000 +#define EXYNOS5_SPI_BASE 0x12D20000 #define EXYNOS5_PWMTIMER_BASE 0x12DD0000 +#define EXYNOS5_SPI_ISP_BASE 0x131A0000 #define EXYNOS5_GPIO_PART2_BASE 0x13400000 #define EXYNOS5_FIMD_BASE 0x14400000
@@ -170,6 +174,8 @@ SAMSUNG_BASE(usb_ehci, USB_HOST_EHCI_BASE) SAMSUNG_BASE(usb_otg, USBOTG_BASE) SAMSUNG_BASE(watchdog, WATCHDOG_BASE) SAMSUNG_BASE(power, POWER_BASE) +SAMSUNG_BASE(spi, SPI_BASE) +SAMSUNG_BASE(spi_isp, SPI_ISP_BASE) #endif
#endif /* _EXYNOS4_CPU_H */
This patch adds SPI driver for EXYNOS.
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Padmavathi Venna padma.v@samsung.com Signed-off-by: Gabe Black gabeblack@google.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None. Changes in V3: - Removed SPI_SLAVE flag. Changes in V4: - Rebased on Mainline u-boot.git. - Removed variable bus_count and DECLARE_GLOBAL_DATA_PTR; - Function spi_flush_fifo made static. arch/arm/include/asm/arch-exynos/spi.h | 78 +++++++ drivers/spi/Makefile | 1 + drivers/spi/exynos_spi.c | 364 ++++++++++++++++++++++++++++++++ 3 files changed, 443 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/spi.h create mode 100644 drivers/spi/exynos_spi.c
diff --git a/arch/arm/include/asm/arch-exynos/spi.h b/arch/arm/include/asm/arch-exynos/spi.h new file mode 100644 index 0000000..7cab1e9 --- /dev/null +++ b/arch/arm/include/asm/arch-exynos/spi.h @@ -0,0 +1,78 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Padmavathi Venna padma.v@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#ifndef __ASM_ARCH_EXYNOS_COMMON_SPI_H_ +#define __ASM_ARCH_EXYNOS_COMMON_SPI_H_ + +#ifndef __ASSEMBLY__ + +/* SPI peripheral register map; padded to 64KB */ +struct exynos_spi { + unsigned int ch_cfg; /* 0x00 */ + unsigned char reserved0[4]; + unsigned int mode_cfg; /* 0x08 */ + unsigned int cs_reg; /* 0x0c */ + unsigned char reserved1[4]; + unsigned int spi_sts; /* 0x14 */ + unsigned int tx_data; /* 0x18 */ + unsigned int rx_data; /* 0x1c */ + unsigned int pkt_cnt; /* 0x20 */ + unsigned char reserved2[4]; + unsigned char reserved3[4]; + unsigned int fb_clk; /* 0x2c */ + unsigned char padding[0xffd0]; +}; + +#define EXYNOS_SPI_MAX_FREQ 50000000 + +#define SPI_TIMEOUT_MS 10 + +/* SPI_CHCFG */ +#define SPI_CH_HS_EN (1 << 6) +#define SPI_CH_RST (1 << 5) +#define SPI_SLAVE_MODE (1 << 4) +#define SPI_CH_CPOL_L (1 << 3) +#define SPI_CH_CPHA_B (1 << 2) +#define SPI_RX_CH_ON (1 << 1) +#define SPI_TX_CH_ON (1 << 0) + +/* SPI_MODECFG */ +#define SPI_MODE_CH_WIDTH_WORD (0x2 << 29) +#define SPI_MODE_BUS_WIDTH_WORD (0x2 << 17) + +/* SPI_CSREG */ +#define SPI_SLAVE_SIG_INACT (1 << 0) + +/* SPI_STS */ +#define SPI_ST_TX_DONE (1 << 25) +#define SPI_FIFO_LVL_MASK 0x1ff +#define SPI_TX_LVL_OFFSET 6 +#define SPI_RX_LVL_OFFSET 15 + +/* Feedback Delay */ +#define SPI_CLK_BYPASS (0 << 0) +#define SPI_FB_DELAY_90 (1 << 0) +#define SPI_FB_DELAY_180 (2 << 0) +#define SPI_FB_DELAY_270 (3 << 0) + +/* Packet Count */ +#define SPI_PACKET_CNT_EN (1 << 16) + +#endif /* __ASSEMBLY__ */ +#endif diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index cd3f9fa..4d02a18 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -33,6 +33,7 @@ COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o COBJS-$(CONFIG_CF_SPI) += cf_spi.o COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +COBJS-$(CONFIG_EXYNOS_SPI) += exynos_spi.o COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o diff --git a/drivers/spi/exynos_spi.c b/drivers/spi/exynos_spi.c new file mode 100644 index 0000000..e4d41eb --- /dev/null +++ b/drivers/spi/exynos_spi.c @@ -0,0 +1,364 @@ +/* + * (C) Copyright 2012 SAMSUNG Electronics + * Padmavathi Venna padma.v@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/arch/clk.h> +#include <asm/arch/clock.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pinmux.h> +#include <asm/arch-exynos/spi.h> +#include <asm/io.h> + +/* Information about each SPI controller */ +struct spi_bus { + enum periph_id periph_id; + s32 frequency; /* Default clock frequency, -1 for none */ + struct exynos_spi *regs; + int inited; /* 1 if this bus is ready for use */ +}; + +/* A list of spi buses that we know about */ +static struct spi_bus spi_bus[EXYNOS5_SPI_NUM_CONTROLLERS]; + +struct exynos_spi_slave { + struct spi_slave slave; + struct exynos_spi *regs; + unsigned int freq; /* Default frequency */ + unsigned int mode; + enum periph_id periph_id; /* Peripheral ID for this device */ + unsigned int fifo_size; +}; + +static struct spi_bus *spi_get_bus(unsigned dev_index) +{ + if (dev_index < EXYNOS5_SPI_NUM_CONTROLLERS) + return &spi_bus[dev_index]; + debug("%s: invalid bus %d", __func__, dev_index); + + return NULL; +} + +static inline struct exynos_spi_slave *to_exynos_spi(struct spi_slave *slave) +{ + return container_of(slave, struct exynos_spi_slave, slave); +} + +/** + * Setup the driver private data + * + * @param bus ID of the bus that the slave is attached to + * @param cs ID of the chip select connected to the slave + * @param max_hz Required spi frequency + * @param mode Required spi mode (clk polarity, clk phase and + * master or slave) + * @return new device or NULL + */ +struct spi_slave *spi_setup_slave(unsigned int busnum, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct exynos_spi_slave *spi_slave; + struct spi_bus *bus; + + if (!spi_cs_is_valid(busnum, cs)) { + debug("%s: Invalid bus/chip select %d, %d\n", __func__, + busnum, cs); + return NULL; + } + + spi_slave = malloc(sizeof(*spi_slave)); + if (!spi_slave) { + debug("%s: Could not allocate spi_slave\n", __func__); + return NULL; + } + + bus = &spi_bus[busnum]; + spi_slave->slave.bus = busnum; + spi_slave->slave.cs = cs; + spi_slave->regs = bus->regs; + spi_slave->mode = mode; + spi_slave->periph_id = bus->periph_id; + if (bus->periph_id == PERIPH_ID_SPI0) + spi_slave->fifo_size = 256; + else + spi_slave->fifo_size = 64; + + spi_slave->freq = bus->frequency; + if (max_hz) + spi_slave->freq = min(max_hz, spi_slave->freq); + + return &spi_slave->slave; +} + +/** + * Free spi controller + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + */ +void spi_free_slave(struct spi_slave *slave) +{ + struct exynos_spi_slave *spi_slave = to_exynos_spi(slave); + + free(spi_slave); +} + +/** + * Flush spi tx, rx fifos and reset the SPI controller + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + */ +static void spi_flush_fifo(struct spi_slave *slave) +{ + struct exynos_spi_slave *spi_slave = to_exynos_spi(slave); + struct exynos_spi *regs = spi_slave->regs; + + clrsetbits_le32(®s->ch_cfg, SPI_CH_HS_EN, SPI_CH_RST); + clrbits_le32(®s->ch_cfg, SPI_CH_RST); + setbits_le32(®s->ch_cfg, SPI_TX_CH_ON | SPI_RX_CH_ON); +} + +/** + * Initialize the spi base registers, set the required clock frequency and + * initialize the gpios + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + * @return zero on success else a negative value + */ +int spi_claim_bus(struct spi_slave *slave) +{ + struct exynos_spi_slave *spi_slave = to_exynos_spi(slave); + struct exynos_spi *regs = spi_slave->regs; + u32 reg = 0; + int ret; + + ret = spi_set_clock_rate(spi_slave->periph_id, + spi_slave->freq); + if (ret < 0) { + debug("%s: Failed to setup spi clock\n", __func__); + return ret; + } + + exynos_pinmux_config(spi_slave->periph_id, PINMUX_FLAG_NONE); + + spi_flush_fifo(slave); + + reg = readl(®s->ch_cfg); + reg &= ~(SPI_CH_CPHA_B | SPI_CH_CPOL_L); + + if (spi_slave->mode & SPI_CPHA) + reg |= SPI_CH_CPHA_B; + + if (spi_slave->mode & SPI_CPOL) + reg |= SPI_CH_CPOL_L; + + writel(reg, ®s->ch_cfg); + writel(SPI_FB_DELAY_180, ®s->fb_clk); + + return 0; +} + +/** + * Reset the spi H/W and flush the tx and rx fifos + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + */ +void spi_release_bus(struct spi_slave *slave) +{ + spi_flush_fifo(slave); +} + +static void spi_get_fifo_levels(struct exynos_spi *regs, + int *rx_lvl, int *tx_lvl) +{ + uint32_t spi_sts = readl(®s->spi_sts); + + *rx_lvl = (spi_sts >> SPI_RX_LVL_OFFSET) & SPI_FIFO_LVL_MASK; + *tx_lvl = (spi_sts >> SPI_TX_LVL_OFFSET) & SPI_FIFO_LVL_MASK; +} + +/** + * If there's something to transfer, do a software reset and set a + * transaction size. + * + * @param regs SPI peripheral registers + * @param count Number of bytes to transfer + */ +static void spi_request_bytes(struct exynos_spi *regs, int count) +{ + assert(count && count < (1 << 16)); + setbits_le32(®s->ch_cfg, SPI_CH_RST); + clrbits_le32(®s->ch_cfg, SPI_CH_RST); + writel(count | SPI_PACKET_CNT_EN, ®s->pkt_cnt); +} + +static void spi_rx_tx(struct exynos_spi_slave *spi_slave, int todo, + void **dinp, void const **doutp) +{ + struct exynos_spi *regs = spi_slave->regs; + uchar *rxp = *dinp; + const uchar *txp = *doutp; + int rx_lvl, tx_lvl; + uint out_bytes, in_bytes; + + out_bytes = in_bytes = todo; + + /* + * If there's something to send, do a software reset and set a + * transaction size. + */ + spi_request_bytes(regs, todo); + + /* + * Bytes are transmitted/received in pairs. Wait to receive all the + * data because then transmission will be done as well. + */ + while (in_bytes) { + int temp; + + /* Keep the fifos full/empty. */ + spi_get_fifo_levels(regs, &rx_lvl, &tx_lvl); + if (tx_lvl < spi_slave->fifo_size && out_bytes) { + temp = txp ? *txp++ : 0xff; + writel(temp, ®s->tx_data); + out_bytes--; + } + if (rx_lvl > 0 && in_bytes) { + temp = readl(®s->rx_data); + if (rxp) + *rxp++ = temp; + in_bytes--; + } + } + *dinp = rxp; + *doutp = txp; +} + +/** + * Transfer and receive data + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + * @param bitlen No of bits to tranfer or receive + * @param dout Pointer to transfer buffer + * @param din Pointer to receive buffer + * @param flags Flags for transfer begin and end + * @return zero on success else a negative value + */ +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct exynos_spi_slave *spi_slave = to_exynos_spi(slave); + int upto, todo; + int bytelen; + + /* spi core configured to do 8 bit transfers */ + if (bitlen % 8) { + debug("Non byte aligned SPI transfer.\n"); + return -1; + } + + /* Start the transaction, if necessary. */ + if ((flags & SPI_XFER_BEGIN)) + spi_cs_activate(slave); + + /* Exynos SPI limits each transfer to 65535 bytes */ + bytelen = bitlen / 8; + for (upto = 0; upto < bytelen; upto += todo) { + todo = min(bytelen - upto, (1 << 16) - 1); + spi_rx_tx(spi_slave, todo, &din, &dout); + } + + /* Stop the transaction, if necessary. */ + if ((flags & SPI_XFER_END)) + spi_cs_deactivate(slave); + + return 0; +} + +/** + * Validates the bus and chip select numbers + * + * @param bus ID of the bus that the slave is attached to + * @param cs ID of the chip select connected to the slave + * @return one on success else zero + */ +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return spi_get_bus(bus) && cs == 0; +} + +/** + * Activate the CS by driving it LOW + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + */ +void spi_cs_activate(struct spi_slave *slave) +{ + struct exynos_spi_slave *spi_slave = to_exynos_spi(slave); + + clrbits_le32(&spi_slave->regs->cs_reg, SPI_SLAVE_SIG_INACT); + debug("Activate CS, bus %d\n", spi_slave->slave.bus); +} + +/** + * Deactivate the CS by driving it HIGH + * + * @param slave Pointer to spi_slave to which controller has to + * communicate with + */ +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct exynos_spi_slave *spi_slave = to_exynos_spi(slave); + + setbits_le32(&spi_slave->regs->cs_reg, SPI_SLAVE_SIG_INACT); + debug("Deactivate CS, bus %d\n", spi_slave->slave.bus); +} + +static inline struct exynos_spi *get_spi_base(int dev_index) +{ + if (dev_index < 3) + return (struct exynos_spi *)samsung_get_base_spi() + dev_index; + else + return (struct exynos_spi *)samsung_get_base_spi_isp() + + (dev_index - 3); +} + +/* Sadly there is no error return from this function */ +void spi_init(void) +{ + int i; + struct spi_bus *bus; + for (i = 0; i < EXYNOS5_SPI_NUM_CONTROLLERS; i++) { + bus = &spi_bus[i]; + bus->regs = get_spi_base(i); + bus->periph_id = PERIPH_ID_SPI0 + i; + if (i == 1) + bus->frequency = 2500000; + else + bus->frequency = 500000; + bus->inited = 1; + } +}
Acked-by: Mike Frysinger vapier@gentoo.org -mike
I tested this driver is working at the exynos5250
Tested-by: jy0922.shim@samsung.com
Hi Joonyoung,
Thank you for testing.
Regards, Rajeshwari Shinde
- Joonyoung Shim
This patch enables SPI driver for EXYNOS5.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None. Changes in V3: - Corrected the warning message. Changes in V4: - Rebased on Mainline u-boot.git. board/samsung/smdk5250/smdk5250.c | 4 ++++ include/configs/smdk5250.h | 23 ++++++++++++++++++++++- 2 files changed, 26 insertions(+), 1 deletions(-)
diff --git a/board/samsung/smdk5250/smdk5250.c b/board/samsung/smdk5250/smdk5250.c index fae7d6f..7e20a3c 100644 --- a/board/samsung/smdk5250/smdk5250.c +++ b/board/samsung/smdk5250/smdk5250.c @@ -24,6 +24,7 @@ #include <asm/io.h> #include <i2c.h> #include <netdev.h> +#include <spi.h> #include <asm/arch/cpu.h> #include <asm/arch/gpio.h> #include <asm/arch/mmc.h> @@ -63,6 +64,9 @@ static int smc9115_pre_init(void) int board_init(void) { gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); +#ifdef CONFIG_EXYNOS_SPI + spi_init(); +#endif return 0; }
diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index eb1466c..0f85be6 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -162,7 +162,7 @@ #undef CONFIG_CMD_IMLS #define CONFIG_IDENT_STRING " for SMDK5250"
-#define CONFIG_ENV_IS_IN_MMC +/*#define CONFIG_ENV_IS_IN_MMC*/ #define CONFIG_SYS_MMC_ENV_DEV 0
#define CONFIG_SECURE_BL1_ONLY @@ -211,6 +211,27 @@ #define CONFIG_ENV_SROM_BANK 1 #endif /*CONFIG_CMD_NET*/
+/* SPI */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SPI_FLASH + +#ifdef CONFIG_SPI_FLASH +#define CONFIG_EXYNOS_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 50000000 +#define EXYNOS5_SPI_NUM_CONTROLLERS 5 +#endif + +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_MODE SPI_MODE_0 +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_SPI_BUS 1 +#define CONFIG_ENV_SPI_MAX_HZ 50000000 +#endif + /* Enable devicetree support */ #define CONFIG_OF_LIBFDT
This patch enables SPI Booting for EXYNOS5
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - None. Changes in V3: - None. Changes in V4: - Rebased on Mainline u-boot.git. - Corrected the Commit message. board/samsung/smdk5250/Makefile | 2 +- board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} | 31 +++++++++++++++++++- include/configs/smdk5250.h | 5 +++ 3 files changed, 35 insertions(+), 3 deletions(-) rename board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} (66%)
diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile index 226db1f..9cfde0f 100644 --- a/board/samsung/smdk5250/Makefile +++ b/board/samsung/smdk5250/Makefile @@ -35,7 +35,7 @@ COBJS += smdk5250.o endif
ifdef CONFIG_SPL_BUILD -COBJS += mmc_boot.o +COBJS += spl_boot.o endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/board/samsung/smdk5250/mmc_boot.c b/board/samsung/smdk5250/spl_boot.c similarity index 66% rename from board/samsung/smdk5250/mmc_boot.c rename to board/samsung/smdk5250/spl_boot.c index 449a919..d8f3c1e 100644 --- a/board/samsung/smdk5250/mmc_boot.c +++ b/board/samsung/smdk5250/spl_boot.c @@ -23,6 +23,16 @@ #include<common.h> #include<config.h>
+enum boot_mode { + BOOT_MODE_MMC = 4, + BOOT_MODE_SERIAL = 20, + /* Boot based on Operating Mode pin settings */ + BOOT_MODE_OM = 32, + BOOT_MODE_USB, /* Boot using USB download */ +}; + + typedef u32 (*spi_copy_func_t)(u32 offset, u32 nblock, u32 dst); + /* * Copy U-boot from mmc to RAM: * COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains @@ -30,9 +40,26 @@ */ void copy_uboot_to_ram(void) { - u32 (*copy_bl2)(u32, u32, u32) = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; + spi_copy_func_t spi_copy; + enum boot_mode bootmode; + u32 (*copy_bl2)(u32, u32, u32); + + bootmode = readl(EXYNOS5_POWER_BASE) & OM_STAT;
- copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, CONFIG_SYS_TEXT_BASE); + switch (bootmode) { + case BOOT_MODE_SERIAL: + spi_copy = *(spi_copy_func_t *)EXYNOS_COPY_SPI_FNPTR_ADDR; + spi_copy(SPI_FLASH_UBOOT_POS, CONFIG_BL2_SIZE, + CONFIG_SYS_TEXT_BASE); + break; + case BOOT_MODE_MMC: + copy_bl2 = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; + copy_bl2(BL2_START_OFFSET, BL2_SIZE_BLOC_COUNT, + CONFIG_SYS_TEXT_BASE); + break; + default: + break; + } }
void board_init_f(unsigned long bootflag) diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 0f85be6..a926a7e 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -187,6 +187,11 @@ /* U-boot copy size from boot Media to DRAM.*/ #define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) #define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) + +#define OM_STAT (0x1f << 1) +#define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 +#define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE) + #define CONFIG_DOS_PARTITION
#define CONFIG_IRAM_STACK 0x02050000
Hi Mike,
I verified the SF branch and found that only patch 2 "Winbond part details for WQ5232" is added. Other patches of the same patch set are not yet merged. Please do let me know which tree would merge the remaining patches if not SF branch.
On Thu, Aug 2, 2012 at 12:55 PM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
-- 1.7.4.4
Hi Minkyu Kang,
I have a confusion will this patch set me merged in u-boot-samsung branch or in sf branch, since only one patch "Winbond part details for WQ5232" is merged in sf branch.
Thanks and Regards, Rajeshwari Shinde.
On Tue, Aug 14, 2012 at 12:06 PM, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Hi Mike,
-- 1.7.4.4
Dear Rajeshwari Birje,
On 4 September 2012 15:28, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Hi Minkyu Kang,
I didn't merge this patchset in u-boot-samsung. Do I need to something for you? If so, please let me know.
Thanks. Minkyu Kang.
Hi Minkyu Kang,
Thank you for response. I feel this patch set is specific to EXYNOS and hence would be merged in u-boot-samsung. These patches are tested by Joonyoung Shim. Hence except the second patch "Winbond part details for WQ5232" all other patches can be merged in our samsung tree as there is no separate maintainer for SPI.
Regards, Rajeshwari Shinde. On Tue, Sep 4, 2012 at 12:40 PM, Minkyu Kang promsoft@gmail.com wrote:
Hi Minkyu Kang,
Thanks. Minkyu Kang. -- from. prom. www.promsoft.net
participants (5)
Joonyoung Shim
Mike Frysinger
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
