[PATCH v2] serial: Fix SIFIVE debug serial dependency
The commit 4cc24aeaf420 ("serial: Add missing Kconfig dependencies for debug consoles") has added incorrect dependency for SIFIVE debug uart which should depend on SIFIVE driver instead of PL01x.
Fixes: 4cc24aeaf420 ("serial: Add missing Kconfig dependencies for debug consoles") Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: - Add fixes tag - asked by Simon
drivers/serial/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 17d0e7362379..006cb5a50140 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -359,7 +359,7 @@ config DEBUG_UART_SANDBOX
config DEBUG_UART_SIFIVE bool "SiFive UART" - depends on PL01X_SERIAL + depends on SIFIVE_SERIAL help Select this to enable a debug UART using the serial_sifive driver. You will need to provide parameters to make this work. The driver will
Changes in v2:
Changes in v2:
Reviewed-by: Bin Meng bin.meng@windriver.com
Changes in v2:
- depends on SIFIVE_SERIAL help Select this to enable a debug UART using the serial_sifive driver. You will need to provide parameters to make this work. The driver will
-- 2.27.0
Reviewed-by: Leo Liang ycliang@andestech.com
Changes in v2:
Reviewed-by: Sean Anderson seanga2@gmail.com
participants (5)
Bin Meng
Leo Liang
Michal Simek
Sean Anderson
