[U-Boot] [PATCH] dfu: ram: fix number base of RAM entity parameters
U-Boot typically interprets unprefixed numbers as base 16, and DFU RAM entity parsing has historically done so. Reverse the change to default to base 10, so that values in previously working command-lines aren't mis-parsed, causing RAM corruption, crashes, hangs, etc.
Fixes: 6aeb877afef0 ("drivers: dfu: ram: fix a crash with dfu ram with invalid dfu_alt_info env")
Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Tom Rini trini@konsulko.com Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/dfu/dfu_ram.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/dfu/dfu_ram.c b/drivers/dfu/dfu_ram.c index 1391a0d52b6d..c1b00217c911 100644 --- a/drivers/dfu/dfu_ram.c +++ b/drivers/dfu/dfu_ram.c @@ -72,8 +72,8 @@ int dfu_fill_entity_ram(struct dfu_entity *dfu, char *devstr, char *s) }
dfu->layout = DFU_RAM_ADDR; - dfu->data.ram.start = (void *)simple_strtoul(argv[1], NULL, 0); - dfu->data.ram.size = simple_strtoul(argv[2], NULL, 0); + dfu->data.ram.start = (void *)simple_strtoul(argv[1], NULL, 16); + dfu->data.ram.size = simple_strtoul(argv[2], NULL, 16);
dfu->write_medium = dfu_write_medium_ram; dfu->get_medium_size = dfu_get_medium_size_ram;
Reviewed-by: Mugunthan V N mugunthanvnm@ti.com
Regards Mugunthan V N
Hi Mugunthan,
I assume that you have also tested this patch on your setup?
Would it be possible to also receive Tested-by: from you?
On Monday 25 April 2016 12:58 PM, Lukasz Majewski wrote:
Hi Mugunthan,
Tested the patch successfully on AM335x BBB.
Tested-by: Mugunthan V N mugunthanvnm@ti.com
Lukasz Majewski
Mugunthan V N
Stephen Warren
