[PATCH 00/30] Finish some Kconfig migrations
Hey all,
As things stand today we have over 200 symbols that have a Kconfig entry but also are being manipulated by config headers. While there are a few of these which are going to require some real work to figure out the best path forward (for example CONFIG_BOOTCOMMAND is not a good entry today but many of the unconverted examples are so very complex it shows where some real thought is neede) we have many more that are cases of "migration happened, out of tree boards came in, things weren't caught" and then further "unconverted example copied to another board". This is the first part of a series to convert things over. I stopped after catching all of CONFIG_[ABC]. I'll be doing another series on top of this but as it gets unwieldy to track down when there is a size change (because it fixes an underlying bug, for exapmle CONFIG_CONSOLE_MUX not being enabled as expected).
This converts the following to Kconfig: CONFIG_AM335X_LCD
Signed-off-by: Tom Rini trini@konsulko.com --- configs/brxre1_defconfig | 1 + drivers/video/Kconfig | 1 - include/configs/brxre1.h | 3 --- 3 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 5d3246ac8c72..456e4507c8c6 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -89,6 +89,7 @@ CONFIG_USB_MUSB_TI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_AM335X_LCD=y CONFIG_LCD=y CONFIG_SPL_TINY_MEMSET=y # CONFIG_OF_LIBFDT_OVERLAY is not set diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 38123543a539..05c173b9331c 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -475,7 +475,6 @@ config ATMEL_HLCD
config AM335X_LCD bool "Enable AM335x video support" - depends on DM_VIDEO help Supports video output to an attached LCD panel.
diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 9db011358eba..3a18aec5d332 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -15,9 +15,6 @@ #include <configs/bur_am335x_common.h> #include <linux/stringify.h> /* ------------------------------------------------------------------------- */ -#if !defined(CONFIG_AM335X_LCD) -#define CONFIG_AM335X_LCD -#endif #define LCD_BPP LCD_COLOR32
/* memory */
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT
Signed-off-by: Tom Rini trini@konsulko.com --- configs/apalis-tk1_defconfig | 1 + configs/chiliboard_defconfig | 1 + include/configs/apalis-tk1.h | 2 -- include/configs/chiliboard.h | 1 - 4 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 868303a29cca..6538f9a5b8cd 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_ARCH_MISC_INIT=y CONFIG_SYS_PROMPT="Apalis TK1 # " # CONFIG_CMD_IMI is not set CONFIG_CMD_GPIO=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 30100a3151d0..afc73dc89c52 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=1 # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DEFAULT_FDT_FILE="am335x-chiliboard.dtb" +CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index 965259c5e1e9..af008e4f4404 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -12,8 +12,6 @@
#include "tegra124-common.h"
-#define CONFIG_ARCH_MISC_INIT - /* Board-specific serial config */ #define CONFIG_TEGRA_ENABLE_UARTA #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index f4dcc54508ce..a2d198c5197b 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -147,7 +147,6 @@ /* NAND: SPL related configs */
/* USB configuration */ -#define CONFIG_ARCH_MISC_INIT #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_HOST
This converts the following to Kconfig: CONFIG_ARM_PL180_MMCI
Signed-off-by: Tom Rini trini@konsulko.com --- configs/vexpress_ca15_tc2_defconfig | 1 + configs/vexpress_ca5x2_defconfig | 1 + configs/vexpress_ca9x4_defconfig | 1 + drivers/mmc/Kconfig | 1 - include/configs/vexpress_common.h | 1 - 5 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index d2a59774420d..2c78e12df6a1 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xFF80000 +CONFIG_ARM_PL180_MMCI=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index bedf99a7e163..8395bb74cdb2 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xFF80000 +CONFIG_ARM_PL180_MMCI=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 8234b5d1bbcf..1811782128ff 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x47F80000 +CONFIG_ARM_PL180_MMCI=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 3c4f057373fc..12d03dc36e57 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -66,7 +66,6 @@ config MMC_SPI_CRC_ON
config ARM_PL180_MMCI bool "ARM AMBA Multimedia Card Interface and compatible support" - depends on DM_MMC && OF_CONTROL help This selects the ARM(R) AMBA(R) PrimeCell Multimedia Card Interface (PL180, PL181 and compatible) support. diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index ca765579e821..ffc3b43fc557 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -135,7 +135,6 @@ #define CONFIG_SYS_SERIAL0 V2M_UART0 #define CONFIG_SYS_SERIAL1 V2M_UART1
-#define CONFIG_ARM_PL180_MMCI #define CONFIG_ARM_PL180_MMCI_BASE V2M_MMCI #define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 #define CONFIG_ARM_PL180_MMCI_CLOCK_FREQ 6250000
This converts the following to Kconfig: CONFIG_ARMV7_PSCI CONFIG_ARMV7_PSCI_NR_CPUS
Cc: Tom Warren twarren@nvidia.com Cc: Peter.Chubb@data61.csiro.au Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-tegra/tegra124/Kconfig | 1 + include/configs/cei-tk1-som.h | 2 -- 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index 6fa31ea0a16c..fb016aa46c90 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -19,6 +19,7 @@ config TARGET_JETSON_TK1
config TARGET_CEI_TK1_SOM bool "Colorado Engineering Inc Tegra124 TK1-som board" + select ARCH_SUPPORT_PSCI select BOARD_LATE_INIT select CPU_V7_HAS_NONSEC if !SPL_BUILD select CPU_V7_HAS_VIRT if !SPL_BUILD diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h index dbebef34e386..2541f2fc27c2 100644 --- a/include/configs/cei-tk1-som.h +++ b/include/configs/cei-tk1-som.h @@ -32,8 +32,6 @@ #include "tegra-common-usb-gadget.h" #include "tegra-common-post.h"
-#define CONFIG_ARMV7_PSCI 1 -#define CONFIG_ARMV7_PSCI_NR_CPUS 4 /* Reserve top 1M for secure RAM */ #define CONFIG_ARMV7_SECURE_BASE 0xfff00000 #define CONFIG_ARMV7_SECURE_RESERVE_SIZE 0x00100000
This converts the following to Kconfig: CONFIG_AT91_GPIO
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-at91/include/mach/at91rm9200.h | 2 -- configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/axm_defconfig | 1 + configs/corvus_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/taurus_defconfig | 1 + configs/vinco_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + drivers/gpio/Kconfig | 1 - include/configs/at91-sama5_common.h | 5 ----- include/configs/corvus.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/smartweb.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/taurus.h | 1 - include/configs/wb45n.h | 1 - include/configs/wb50n.h | 3 --- 24 files changed, 13 insertions(+), 18 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/at91rm9200.h b/arch/arm/mach-at91/include/mach/at91rm9200.h index 3412df0f06c7..309039347c84 100644 --- a/arch/arm/mach-at91/include/mach/at91rm9200.h +++ b/arch/arm/mach-at91/include/mach/at91rm9200.h @@ -5,8 +5,6 @@ #ifndef __AT91RM9200_H__ #define __AT91RM9200_H__
-#define CONFIG_AT91_GPIO /* and require always gpio features */ - /* Periperial Identifiers */
#define ATMEL_ID_SYS 1 /* System Peripheral */ diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 0b025911d69c..2aaf87904562 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x10040000 +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 09c996b8b225..9d2fc473430b 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x10040000 +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 78e6c8d34569..1615d8af0eba 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -58,6 +58,7 @@ CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_CLK=y CONFIG_CLK_AT91=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 0eedaa93667a..c6e5955bf329 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -48,6 +48,7 @@ CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index 0d1a46315bd3..a679c0f6700b 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-gurnard" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_AT91_GPIO=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 0157f5172e13..2921f2dfd4f7 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -39,6 +39,7 @@ CONFIG_ENV_IS_IN_FAT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_AT91_GPIO=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 8f9a19f695ba..4545c7075b3f 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -49,6 +49,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index c684e2b20a11..9e44395f03f0 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_AT91_GPIO=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 3ef091fab48f..e1c5c2ef4c1f 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_AT91_GPIO=y CONFIG_CMD_PCA953X=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index d9a2d61ecb60..16a804b879f0 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -66,6 +66,7 @@ CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y +CONFIG_AT91_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 2684324cace6..8ca7556772b8 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -31,6 +31,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-vinco" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_AT91_GPIO=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index 5728cfb45481..d770e007a655 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_AT91_GPIO=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index 86a8549406bf..e764c303d069 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -33,6 +33,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_AT91_GPIO=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index d87f6cc10517..af608b7b0ef1 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -77,7 +77,6 @@ config DWAPB_GPIO
config AT91_GPIO bool "AT91 PIO GPIO driver" - depends on DM_GPIO default n help Say yes here to select AT91 PIO GPIO driver. AT91 PIO diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 624b05ad08ce..53629743d9d4 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -19,11 +19,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
-/* general purpose I/O */ -#if !CONFIG_IS_ENABLED(DM_GPIO) -#define CONFIG_AT91_GPIO -#endif - /* * BOOTP options */ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index e9064a200d32..1dc946d78990 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -36,7 +36,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 2747c0cb9307..94d9111cbaae 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -28,7 +28,6 @@
/* serial console */ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index aacdd1263e7b..8c964087131d 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -85,7 +85,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO /* enable the GPIO features */ #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 35cd7f69c1d8..32dd544a6c75 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -62,7 +62,6 @@
/* GPIOs and IO expander */ #define CONFIG_ATMEL_LEGACY -#define CONFIG_AT91_GPIO #define CONFIG_AT91_GPIO_PULLUP 1 #define CONFIG_PCA953X #define CONFIG_SYS_I2C_PCA953X_ADDR 0x28 diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index fcd35b715ce1..db4fd9be247f 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -60,7 +60,6 @@
/* UARTs/Serial console */ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 9990c9340a3d..b9b9292502e1 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -41,7 +41,6 @@
#define CONFIG_USART_BASE ATMEL_BASE_DBGU diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h index d256ce8e4b9b..f13ad112f793 100644 --- a/include/configs/wb45n.h +++ b/include/configs/wb45n.h @@ -20,7 +20,6 @@
/* serial console */ #define CONFIG_ATMEL_USART diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index bb4deeac9b7d..ffcc9877eddb 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -20,9 +20,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
-/* general purpose I/O */ -#define CONFIG_AT91_GPIO - /* serial console */ #define CONFIG_ATMEL_USART #define CONFIG_USART_BASE ATMEL_BASE_DBGU
This converts the following to Kconfig: CONFIG_ATMEL_HLCD
Signed-off-by: Tom Rini trini@konsulko.com --- configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + drivers/video/Kconfig | 1 - include/configs/at91sam9n12ek.h | 1 - 5 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 6f159aaccfa0..5a147a0bf628 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -61,4 +61,5 @@ CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_ATMEL_HLCD=y CONFIG_LCD=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 490addbedfd6..8263ffb1312e 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -62,4 +62,5 @@ CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_ATMEL_HLCD=y CONFIG_LCD=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 688f0c3a286e..0e95cff73363 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -63,4 +63,5 @@ CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_ATMEL_HLCD=y CONFIG_LCD=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 05c173b9331c..026c6572489d 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -469,7 +469,6 @@ config NXP_TDA19988
config ATMEL_HLCD bool "Enable ATMEL video support using HLCDC" - depends on DM_VIDEO help HLCDC supports video output to an attached LCD panel.
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 706217fef9a4..c2d4e485a9d3 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -25,7 +25,6 @@ #define CONFIG_LCD_LOGO #define CONFIG_LCD_INFO #define CONFIG_LCD_INFO_BELOW_LOGO -#define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565
This converts the following to Kconfig: CONFIG_ATMEL_NAND_HW_PMECC CONFIG_ATMEL_NAND_HWECC CONFIG_NAND_ATMEL CONFIG_PMECC_CAP CONFIG_PMECC_SECTOR_SIZE
Signed-off-by: Tom Rini trini@konsulko.com --- configs/sam9x60ek_nandflash_defconfig | 4 ++++ configs/sam9x60ek_qspiflash_defconfig | 4 ++++ include/configs/sam9x60ek.h | 7 ------- 3 files changed, 8 insertions(+), 7 deletions(-)
diff --git a/configs/sam9x60ek_nandflash_defconfig b/configs/sam9x60ek_nandflash_defconfig index b59e4be4be80..d09f78828fa8 100644 --- a/configs/sam9x60ek_nandflash_defconfig +++ b/configs/sam9x60ek_nandflash_defconfig @@ -50,6 +50,10 @@ CONFIG_MICROCHIP_FLEXCOM=y CONFIG_DM_MMC=y CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y +# CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_NAND_ATMEL=y +CONFIG_ATMEL_NAND_HW_PMECC=y +CONFIG_PMECC_CAP=8 CONFIG_PHY_MICREL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sam9x60ek_qspiflash_defconfig b/configs/sam9x60ek_qspiflash_defconfig index 37de4044e9dc..6c4f534974e8 100644 --- a/configs/sam9x60ek_qspiflash_defconfig +++ b/configs/sam9x60ek_qspiflash_defconfig @@ -60,6 +60,10 @@ CONFIG_GENERIC_ATMEL_MCI=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y +# CONFIG_SYS_NAND_USE_FLASH_BBT is not set +CONFIG_NAND_ATMEL=y +CONFIG_ATMEL_NAND_HW_PMECC=y +CONFIG_PMECC_CAP=8 CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/include/configs/sam9x60ek.h b/include/configs/sam9x60ek.h index 9b439a644161..19714402ca45 100644 --- a/include/configs/sam9x60ek.h +++ b/include/configs/sam9x60ek.h @@ -44,7 +44,6 @@
/* NAND flash */ #ifdef CONFIG_CMD_NAND -#define CONFIG_NAND_ATMEL #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_MASK_ALE BIT(21) @@ -54,12 +53,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION #endif
-/* PMECC & PMERRLOC */ -#define CONFIG_ATMEL_NAND_HWECC -#define CONFIG_ATMEL_NAND_HW_PMECC -#define CONFIG_PMECC_CAP 8 -#define CONFIG_PMECC_SECTOR_SIZE 512 - #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#ifdef CONFIG_SD_BOOT
This converts the following to Kconfig: CONFIG_ATMEL_USART
Signed-off-by: Tom Rini trini@konsulko.com --- configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/vinco_defconfig | 1 + configs/wb45n_defconfig | 1 + configs/wb50n_defconfig | 1 + include/configs/at91rm9200ek.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/smartweb.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/vinco.h | 1 - include/configs/wb45n.h | 1 - include/configs/wb50n.h | 1 - 18 files changed, 10 insertions(+), 8 deletions(-)
diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 2aaf87904562..a990360794f4 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -29,6 +29,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MII=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 9d2fc473430b..143346158b47 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -30,6 +30,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_MII=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index a679c0f6700b..5e0d6f7c2329 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -39,6 +39,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_ATMEL_NAND_HWECC=y CONFIG_PHYLIB=y +CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 2921f2dfd4f7..03783a2af067 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -40,6 +40,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_AT91_GPIO=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 4545c7075b3f..e7edb01c41d9 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -56,6 +56,7 @@ CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y CONFIG_PHYLIB=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 9e44395f03f0..fa4697989b85 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -37,5 +37,6 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index e1c5c2ef4c1f..abe033373459 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -36,5 +36,6 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SYS_NAND_USE_FLASH_BBT is not set CONFIG_NAND_ATMEL=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 8ca7556772b8..d4852eafe0d4 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -38,6 +38,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_PHY_SMSC=y CONFIG_ETH_DESIGNWARE=y +CONFIG_ATMEL_USART=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index d770e007a655..ef069a672cc2 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -40,6 +40,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_NAND_ATMEL=y CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y +CONFIG_ATMEL_USART=y CONFIG_LZMA=y CONFIG_LZO=y CONFIG_OF_LIBFDT=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index e764c303d069..1b444f07529d 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -43,5 +43,6 @@ CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_ATMEL_USART=y CONFIG_LZMA=y CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 378f9dc48be4..5e1e59074758 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -96,7 +96,6 @@ * CONFIG_DBGU is DBGU unit on J10 * CONFIG_USART1 is USART1 on J14 */ -#define CONFIG_ATMEL_USART #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID 0/* ignored in arm */
diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 94d9111cbaae..3eb70d5e7821 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -31,7 +31,6 @@ #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
/* serial console */ -#define CONFIG_ATMEL_USART #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS
diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 8c964087131d..9498513f76f1 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -88,7 +88,6 @@ #define CONFIG_AT91_GPIO_PULLUP 1 /* keep pullups on peripheral pins */
diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 32dd544a6c75..cbef61877e28 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x28, 16} }
/* UARTs/Serial console */ -#define CONFIG_ATMEL_USART #ifndef CONFIG_DM_SERIAL #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index db4fd9be247f..24bbea7d03b5 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -63,7 +63,6 @@ #define CONFIG_AT91_GPIO_PULLUP 1
/* Boot options */ #define CONFIG_SYS_LOAD_ADDR 0x23000000 diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 83ec78dc4315..496c228b58ea 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -17,7 +17,6 @@ /* The value in the common file is too far away for the VInCo platform */
/* serial console */ -#define CONFIG_ATMEL_USART #define CONFIG_USART_BASE 0xfc00c000 #define CONFIG_USART_ID 30
diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h index f13ad112f793..8b333de8cffd 100644 --- a/include/configs/wb45n.h +++ b/include/configs/wb45n.h @@ -22,7 +22,6 @@ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */
diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index ffcc9877eddb..c2112763a2bb 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -21,7 +21,6 @@ #endif
/* serial console */ -#define CONFIG_ATMEL_USART #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_DBGU
This converts the following to Kconfig: CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_STOP_STR
Signed-off-by: Tom Rini trini@konsulko.com --- configs/bk4r1_defconfig | 3 +++ include/configs/bk4r1.h | 6 ------ 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 8c2bda6984ae..bcad243dd2bd 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -18,6 +18,9 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Enter passphrase to stop autoboot, booting in %d seconds\n" +CONFIG_AUTOBOOT_STOP_STR="123" # CONFIG_CMD_ELF is not set CONFIG_CMD_MEMTEST=y CONFIG_SYS_MEMTEST_START=0x80010000 diff --git a/include/configs/bk4r1.h b/include/configs/bk4r1.h index f88172a05c55..300b9c7b7afb 100644 --- a/include/configs/bk4r1.h +++ b/include/configs/bk4r1.h @@ -57,12 +57,6 @@ "saveenv; " \ "fi; "
-/* Autoboot options */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "Enter passphrase to stop autoboot, booting in %d seconds\n" -#define CONFIG_AUTOBOOT_STOP_STR "123" - #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
This converts the following to Kconfig: CONFIG_BAUDRATE
Signed-off-by: Tom Rini trini@konsulko.com --- README | 5 ----- include/configs/apalis-imx8.h | 3 --- include/configs/bcm_northstar2.h | 1 - include/configs/bcmstb.h | 1 - include/configs/colibri-imx8x.h | 3 --- include/configs/controlcenterdc.h | 2 -- include/configs/dh_imx6.h | 1 - include/configs/display5.h | 1 - include/configs/grpeach.h | 3 --- include/configs/imx8mq_evk.h | 2 -- include/configs/imx8qm_mek.h | 3 --- include/configs/imx8qm_rom7720.h | 3 --- include/configs/imx8qxp_mek.h | 3 --- include/configs/ls1021atsn.h | 2 -- include/configs/ls1028a_common.h | 1 - include/configs/ls1088a_common.h | 1 - include/configs/lx2160a_common.h | 1 - include/configs/mx53ppd.h | 1 - include/configs/mx6memcal.h | 1 - include/configs/mx7ulp_evk.h | 1 - include/configs/owl-common.h | 3 --- include/configs/pdu001.h | 1 - include/configs/pico-imx8mq.h | 2 -- include/configs/presidio_asic.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3368_common.h | 1 - include/configs/wb50n.h | 2 -- 27 files changed, 50 deletions(-)
diff --git a/README b/README index bcf198363111..a0f54645fc26 100644 --- a/README +++ b/README @@ -670,11 +670,6 @@ The following options need to be configured: Define this variable to enable hw flow control in serial driver. Current user of this option is drivers/serial/nsl16550.c driver
-- Console Baudrate: - CONFIG_BAUDRATE - in bps - Select one of the baudrates listed in - CONFIG_SYS_BAUDRATE_TABLE, see below. - - Autoboot Command: CONFIG_BOOTCOMMAND Only needed when CONFIG_BOOTDELAY is enabled; diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index 08d34db1061e..6dad8216e969 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -103,9 +103,6 @@ #define PHYS_SDRAM_1_SIZE SZ_2G /* 2 GB */ #define PHYS_SDRAM_2_SIZE SZ_2G /* 2 GB */
-/* Serial */ -#define CONFIG_BAUDRATE 115200 - /* Monitor Command Prompt */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE SZ_2K diff --git a/include/configs/bcm_northstar2.h b/include/configs/bcm_northstar2.h index 45dc7b29c9e4..fbfab288b372 100644 --- a/include/configs/bcm_northstar2.h +++ b/include/configs/bcm_northstar2.h @@ -31,7 +31,6 @@ #define CONFIG_SYS_NS16550_COM2 0x66110000 #define CONFIG_SYS_NS16550_COM3 0x66120000 #define CONFIG_SYS_NS16550_COM4 0x66130000 -#define CONFIG_BAUDRATE 115200
/* console configuration */ #define CONFIG_SYS_CBSIZE SZ_1K diff --git a/include/configs/bcmstb.h b/include/configs/bcmstb.h index 24569f7d94a8..01cfed0b869d 100644 --- a/include/configs/bcmstb.h +++ b/include/configs/bcmstb.h @@ -115,7 +115,6 @@ extern phys_addr_t prior_stage_fdt_address; /* * Serial console configuration. */ -#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, \ 115200}
diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index da9226e2fbed..0ac4e7095de9 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -135,9 +135,6 @@ #define PHYS_SDRAM_1_SIZE SZ_2G /* 2 GB */ #define PHYS_SDRAM_2_SIZE 0x00000000 /* 0 GB */
-/* Serial */ -#define CONFIG_BAUDRATE 115200 - /* Monitor Command Prompt */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE SZ_2K diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 00e5c8f7943e..0c36ea661057 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -112,8 +112,6 @@ */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_BAUDRATE 115200 - #define CONFIG_HOSTNAME "ccdc" #define CONFIG_ROOTPATH "/opt/nfsroot" #define CONFIG_BOOTFILE "ccdc.img" diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 5bfdf4044bee..0b6617fa82e9 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -62,7 +62,6 @@ /* UART */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_BAUDRATE 115200
/* USB Configs */ #ifdef CONFIG_CMD_USB diff --git a/include/configs/display5.h b/include/configs/display5.h index 3348ecc7c7ba..94baa6561022 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -66,7 +66,6 @@
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_BAUDRATE 115200
#ifndef CONFIG_BOOTCOMMAND #define CONFIG_BOOTCOMMAND "if run check_em_pad; then " \ diff --git a/include/configs/grpeach.h b/include/configs/grpeach.h index 001e9d385ba1..bde168d47505 100644 --- a/include/configs/grpeach.h +++ b/include/configs/grpeach.h @@ -11,9 +11,6 @@ /* Board Clock , P1 clock frequency (XTAL=13.33MHz) */ #define CONFIG_SYS_CLK_FREQ 66666666
-/* Serial Console */ -#define CONFIG_BAUDRATE 115200 - /* Miscellaneous */ #define CONFIG_SYS_PBSIZE 256 #define CONFIG_CMDLINE_TAG diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index f71efd45abdb..33a301409520 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -175,8 +175,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0xC0000000 /* 3GB DDR */
-#define CONFIG_BAUDRATE 115200 - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE_ADDR
diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 8324767eb557..fd68c4f052e7 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -175,9 +175,6 @@ #define PHYS_SDRAM_1_SIZE 0x80000000 /* 2 GB */ #define PHYS_SDRAM_2_SIZE 0x100000000 /* 4 GB */
-/* Serial */ -#define CONFIG_BAUDRATE 115200 - /* Generic Timer Definitions */ #define COUNTER_FREQUENCY 8000000 /* 8MHz */
diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h index 89d7adabea84..9808e72474f0 100644 --- a/include/configs/imx8qm_rom7720.h +++ b/include/configs/imx8qm_rom7720.h @@ -163,9 +163,6 @@ /* LPDDR4 board total DDR is 6GB, DDR4 board total DDR is 4 GB */ #define PHYS_SDRAM_2_SIZE 0x80000000 /* 2 GB */
diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index a58f68c17e6c..b442b48becf5 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -175,9 +175,6 @@ /* LPDDR4 board total DDR is 3GB */ #define PHYS_SDRAM_2_SIZE 0x40000000 /* 1 GB */
diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index 46c60aaf5cbc..ec2ed7c60969 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -104,8 +104,6 @@ #endif #define CONFIG_SYS_NS16550_CLK get_serial_clock()
-#define CONFIG_BAUDRATE 115200 - /* I2C */ #ifndef CONFIG_DM_I2C #define CONFIG_SYS_I2C diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index f9040e661d01..44f2dc8f9b41 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2)
-#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
/* Miscellaneous configurable options */ diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 596f14bf3e9e..3ea16752de09 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -64,7 +64,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2)
#if !defined(SPL_NO_IFC) || defined(CONFIG_TARGET_LS1088AQDS) diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 5ab924457efb..a8636d398eeb 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -78,7 +78,6 @@ (void *)CONFIG_SYS_SERIAL1, \ (void *)CONFIG_SYS_SERIAL2, \ (void *)CONFIG_SYS_SERIAL3 } -#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
/* MC firmware */ diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index bb6d82d32749..2ee66612c21b 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -33,7 +33,6 @@
/* Command definition */
diff --git a/include/configs/mx6memcal.h b/include/configs/mx6memcal.h index b774b167f648..0a28d61703a2 100644 --- a/include/configs/mx6memcal.h +++ b/include/configs/mx6memcal.h @@ -27,7 +27,6 @@ #else #error please define serial console (CONFIG_SERIAL_CONSOLE_UARTx) #endif -#define CONFIG_BAUDRATE 115200
#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + 16)
diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 942b7dd41483..5e05b8c16693 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -39,7 +39,6 @@
#define CONFIG_SYS_CACHELINE_SIZE 64
diff --git a/include/configs/owl-common.h b/include/configs/owl-common.h index f77a5fa4c114..98b5a96cf61c 100644 --- a/include/configs/owl-common.h +++ b/include/configs/owl-common.h @@ -29,9 +29,6 @@ */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + 0x7ff00)
-/* UART Definitions */ -#define CONFIG_BAUDRATE 115200 - /* Console configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ #define CONFIG_SYS_MAXARGS 64 diff --git a/include/configs/pdu001.h b/include/configs/pdu001.h index d524f3cbcf01..e4b14c5ecd6b 100644 --- a/include/configs/pdu001.h +++ b/include/configs/pdu001.h @@ -73,6 +73,5 @@ #define CONFIG_SYS_NS16550_COM4 UART3_BASE #define CONFIG_SYS_NS16550_COM5 UART4_BASE #define CONFIG_SYS_NS16550_COM6 UART5_BASE -#define CONFIG_BAUDRATE 115200
#endif /* ! __CONFIG_PDU001_H */ diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 2ae13b30ee53..7b7d633f2828 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -150,8 +150,6 @@ #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ (PHYS_SDRAM_SIZE >> 1))
diff --git a/include/configs/presidio_asic.h b/include/configs/presidio_asic.h index 51177f44feed..34235b5a00c1 100644 --- a/include/configs/presidio_asic.h +++ b/include/configs/presidio_asic.h @@ -41,7 +41,6 @@ #define CORTINA_SERIAL_PORTS {(void *)CONFIG_SYS_SERIAL0, \ (void *)CONFIG_SYS_SERIAL1}
-#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_SERIAL0 PER_UART0_CFG #define CONFIG_SYS_SERIAL1 PER_UART1_CFG
diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index d0c9e5c809df..8f1d508b8ce2 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -9,7 +9,6 @@ #include "rockchip-common.h"
#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index e57d0efa7f92..f178a06945db 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -15,7 +15,6 @@
#define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000 -#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index c2112763a2bb..a210449dae49 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -72,8 +72,6 @@ #define CONFIG_BOOTARGS \ "rw rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs"
-#define CONFIG_BAUDRATE 115200 - #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \
This converts the following to Kconfig: CONFIG_BOARD_EARLY_INIT_F CONFIG_BOARD_EARLY_INIT_R
Signed-off-by: Tom Rini trini@konsulko.com --- configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 + configs/deneb_defconfig | 1 + configs/giedi_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8mq_phanbell_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/mscc_jr2_defconfig | 1 + configs/mscc_luton_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mscc_serval_defconfig | 1 + configs/mscc_servalt_defconfig | 1 + configs/mx7ulp_evk_defconfig | 1 + configs/mx7ulp_evk_plugin_defconfig | 1 + configs/pico-imx8mq_defconfig | 1 + configs/xilinx_zynqmp_mini_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_defconfig | 1 + configs/xilinx_zynqmp_mini_nand_single_defconfig | 1 + configs/xilinx_zynqmp_mini_qspi_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + include/configs/capricorn-common.h | 2 -- include/configs/imx8mq_evk.h | 2 -- include/configs/imx8mq_phanbell.h | 2 -- include/configs/imx8qm_mek.h | 2 -- include/configs/imx8qxp_mek.h | 2 -- include/configs/lx2160a_common.h | 1 - include/configs/mx7ulp_evk.h | 2 -- include/configs/pico-imx8mq.h | 2 -- include/configs/vcoreiii.h | 1 - include/configs/xilinx_zynqmp.h | 2 -- 32 files changed, 22 insertions(+), 18 deletions(-)
diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 030d28a5dfc7..227a5416c63f 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_OS_BOOT=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_MEMTEST_START=0x00000000 diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index 9682cb7ca1a2..31a68f824025 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -23,6 +23,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/siemens/capricorn/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index 4e22a02aacd5..5dd34227af01 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -23,6 +23,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/siemens/capricorn/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 871f784b49b0..caa56e38c525 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_HUSH_PARSER=y # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index 5364b58b7bff..65d952503f74 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg" CONFIG_SD_BOOT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_HUSH_PARSER=y # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index dc490bcf573a..5f68f9cac258 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -21,6 +21,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/imx8qm_mek/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index 9a31fb8e80ed..5f8513ae53c2 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -21,6 +21,7 @@ CONFIG_OF_SYSTEM_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/imx8qxp_mek/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index 9bd90ddc3d70..ab4f9b6255ba 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="jr2 # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index a57d033d30a9..55edb199993b 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="luton # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index 32f4148e755f..3fe9e060bb56 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="ocelot # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index e35219e3ce48..e423fc4efc52 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -16,6 +16,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="serval # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index 669d9f6c23ff..49d8468226fc 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -15,6 +15,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="servalt # " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index 6908aeb2cc3f..32169c72403d 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -9,6 +9,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7ulp_evk/imximage.cfg" CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index 4cc7cca349fe..6c8e40b5b77a 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -8,6 +8,7 @@ CONFIG_TARGET_MX7ULP_EVK=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7ulp_evk/imximage.cfg" CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_MEMTEST_START=0x60000000 diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index 2eeec09f1bbd..c51cfcc3a2bb 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg" CONFIG_BOARD_LATE_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_HUSH_PARSER=y # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 4305db405839..0ca126f92961 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -10,6 +10,7 @@ CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index b041b40b84b9..7590f2f9ffbc 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -11,6 +11,7 @@ CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index bd5603a6a13d..7e1ca1220894 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -11,6 +11,7 @@ CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index 4f4efa0cfabf..834b344328bc 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index 3f780f746cfc..38d42d60212d 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 1f36f5c8e90a..866faddbeed6 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -14,6 +14,7 @@ CONFIG_ZYNQMP_NO_DDR=y # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 7886d5a38f29..fe60d10c991d 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index c671cb50afce..c2e9d0f11f9c 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -42,8 +42,6 @@
#define CONFIG_REMAKE_ELF
-#define CONFIG_BOARD_EARLY_INIT_F - /* Commands */
#undef CONFIG_BOOTM_NETBSD diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 33a301409520..b564f3831e8c 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -58,8 +58,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F - /* ENET Config */ /* ENET1 */ #if defined(CONFIG_CMD_NET) diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 6d038f21b74f..c655bb24a0ae 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -55,8 +55,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F - /* ENET Config */ /* ENET1 */ #if defined(CONFIG_CMD_NET) diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index fd68c4f052e7..1864374a4fc8 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -35,8 +35,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F - /* Flat Device Tree Definitions */ #define CONFIG_OF_BOARD_SETUP
diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index b442b48becf5..5fdb67f0ece6 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -35,8 +35,6 @@
diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index a8636d398eeb..9bc287f7aa43 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_FLASH_BASE 0x20000000
#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_BOARD_EARLY_INIT_F 1
/* DDR */ #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 5e05b8c16693..9e932690746a 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -32,8 +32,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (8 * SZ_1M)
-#define CONFIG_BOARD_EARLY_INIT_F - /* UART */ #define LPUART_BASE LPUART4_RBASE
diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 7b7d633f2828..da2842934b5c 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -54,8 +54,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F - /* ENET Config */ /* ENET1 */ #if defined(CONFIG_CMD_NET) diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index d5b2a785bcf7..020f02caae9c 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -40,7 +40,6 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
-#define CONFIG_BOARD_EARLY_INIT_R #if defined(CONFIG_MTDIDS_DEFAULT) && defined(CONFIG_MTDPARTS_DEFAULT) #define VCOREIII_DEFAULT_MTD_ENV \ "mtdparts="CONFIG_MTDPARTS_DEFAULT"\0" \ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index e868c1341657..e7cfebee7c46 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -256,6 +256,4 @@ # error "Disable CONFIG_SPL_SYS_MALLOC_SIMPLE. Full malloc needs to be used" #endif
-#define CONFIG_BOARD_EARLY_INIT_F - #endif /* __XILINX_ZYNQMP_H */
This converts the following to Kconfig: CONFIG_BOOTARGS
Signed-off-by: Tom Rini trini@konsulko.com --- configs/grpeach_defconfig | 2 ++ configs/imx28_xea_defconfig | 2 ++ configs/sama5d2_icp_mmc_defconfig | 1 + configs/socfpga_agilex_defconfig | 2 ++ configs/socfpga_secu1_defconfig | 2 ++ configs/socfpga_stratix10_defconfig | 2 ++ configs/stmark2_defconfig | 2 ++ configs/wb45n_defconfig | 2 ++ configs/wb50n_defconfig | 2 ++ include/configs/grpeach.h | 3 --- include/configs/sama5d27_som1_ek.h | 6 ------ include/configs/sama5d2_icp.h | 3 --- include/configs/socfpga_arria5_secu1.h | 4 ---- include/configs/socfpga_soc64_common.h | 1 - include/configs/stmark2.h | 6 ------ include/configs/wb45n.h | 4 ---- include/configs/wb50n.h | 3 --- include/configs/xea.h | 1 - 18 files changed, 17 insertions(+), 31 deletions(-)
diff --git a/configs/grpeach_defconfig b/configs/grpeach_defconfig index 417938a512ed..c4a2b449d676 100644 --- a/configs/grpeach_defconfig +++ b/configs/grpeach_defconfig @@ -9,6 +9,8 @@ CONFIG_DM_GPIO=y CONFIG_RZA1=y CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set diff --git a/configs/imx28_xea_defconfig b/configs/imx28_xea_defconfig index d4feb661629f..592f3e387cc0 100644 --- a/configs/imx28_xea_defconfig +++ b/configs/imx28_xea_defconfig @@ -22,6 +22,8 @@ CONFIG_SPL_TEXT_BASE=0x1000 CONFIG_SPL_PAYLOAD="u-boot.img" CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200n8" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set diff --git a/configs/sama5d2_icp_mmc_defconfig b/configs/sama5d2_icp_mmc_defconfig index dc4e815ec127..8f3efd81a032 100644 --- a/configs/sama5d2_icp_mmc_defconfig +++ b/configs/sama5d2_icp_mmc_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DISPLAY_PRINT=y diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_agilex_defconfig index 35316d7c252f..60397a8ccea6 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_agilex_defconfig @@ -12,6 +12,8 @@ CONFIG_IDENT_STRING="socfpga_agilex" CONFIG_SPL_FS_FAT=y CONFIG_SPL_TEXT_BASE=0xFFE00000 CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon" CONFIG_SPL_CACHE=y CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y diff --git a/configs/socfpga_secu1_defconfig b/configs/socfpga_secu1_defconfig index df30c7c5f0e2..8ebbf73148a4 100644 --- a/configs/socfpga_secu1_defconfig +++ b/configs/socfpga_secu1_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_BUILD_TARGET="u-boot-with-nand-spl.sfp" CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 ubi.fm_autoconvert=1 uio_pdrv_genirq.of_id="idq,regbank"" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 21014f9f8cde..16ae0feb6807 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -12,6 +12,8 @@ CONFIG_IDENT_STRING="socfpga_stratix10" CONFIG_SPL_FS_FAT=y CONFIG_SPL_TEXT_BASE=0xFFE00000 CONFIG_BOOTDELAY=5 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="earlycon" CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SOCFPGA_STRATIX10 # " diff --git a/configs/stmark2_defconfig b/configs/stmark2_defconfig index 036ff707d19a..262f169d6cca 100644 --- a/configs/stmark2_defconfig +++ b/configs/stmark2_defconfig @@ -5,6 +5,8 @@ CONFIG_ENV_OFFSET=0x40000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_TARGET_STMARK2=y CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=30000000" +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 rw rootfstype=ramfs rdinit=/bin/init devtmpfs.mount=1" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y # CONFIG_CMDLINE_EDITING is not set diff --git a/configs/wb45n_defconfig b/configs/wb45n_defconfig index ef069a672cc2..0a0120fe5edf 100644 --- a/configs/wb45n_defconfig +++ b/configs/wb45n_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk rw noinitrd mem=64M rootfstype=ubifs root=ubi0:rootfs ubi.mtd=6" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/wb50n_defconfig b/configs/wb50n_defconfig index 1b444f07529d..b2f490a03c54 100644 --- a/configs/wb50n_defconfig +++ b/configs/wb50n_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_TEXT_BASE=0x300000 CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="rw rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/grpeach.h b/include/configs/grpeach.h index bde168d47505..67301fabeb62 100644 --- a/include/configs/grpeach.h +++ b/include/configs/grpeach.h @@ -29,9 +29,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024)
-/* Kernel Boot */ -#define CONFIG_BOOTARGS "ignore_loglevel" - /* Network interface */ #define CONFIG_SH_ETHER_USE_PORT 0 #define CONFIG_SH_ETHER_PHY_ADDR 0 diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 8e98254e2d39..4d66490cd68f 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -39,12 +39,6 @@ "bootz 0x22000000 - 0x21000000" #endif
-#ifdef CONFIG_QSPI_BOOT -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTARGS \ - "console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" -#endif - /* SPL */ #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 diff --git a/include/configs/sama5d2_icp.h b/include/configs/sama5d2_icp.h index 2d1ba757fe74..7d6886ea73e1 100644 --- a/include/configs/sama5d2_icp.h +++ b/include/configs/sama5d2_icp.h @@ -44,9 +44,6 @@ #define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 at91-sama5d2_icp.dtb; " \ "fatload mmc 0:1 0x22000000 zImage; " \ "bootz 0x22000000 - 0x21000000" -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTARGS \ - "console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" #endif
/* SPL */ diff --git a/include/configs/socfpga_arria5_secu1.h b/include/configs/socfpga_arria5_secu1.h index ad4c3c0786c1..77914438bfa0 100644 --- a/include/configs/socfpga_arria5_secu1.h +++ b/include/configs/socfpga_arria5_secu1.h @@ -30,10 +30,6 @@ /* Booting Linux */ #define CONFIG_BOOTDELAY 2 #define CONFIG_BOOTFILE "zImage" -#define CONFIG_BOOTARGS \ - "console=ttyS0," __stringify(CONFIG_BAUDRATE) \ - " ubi.fm_autoconvert=1" \ - " uio_pdrv_genirq.of_id="idq,regbank""
#define CONFIG_BOOTCOMMAND \ "setenv bootcmd '" \ diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index 7237ec95e345..775a122f1f12 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -79,7 +79,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * CONFIG_BOOTARGS goes into the environment value "bootargs". * Do note the value will override also the chosen node in FDT blob. */ -#define CONFIG_BOOTARGS "earlycon" #define CONFIG_BOOTCOMMAND "run fatscript; run mmcload;run linux_qspi_enable;" \ "run mmcboot"
diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index b5bfac77f1b1..d9c79907acdb 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -19,12 +19,6 @@
#define CONFIG_TIMESTAMP
-#define CONFIG_BOOTARGS \ - "console=ttyS0,115200 root=/dev/ram0 rw " \ - "rootfstype=ramfs " \ - "rdinit=/bin/init " \ - "devtmpfs.mount=1" - #define CONFIG_BOOTCOMMAND \ "sf probe 0:1 50000000; " \ "sf read ${loadaddr} 0x100000 ${kern_size}; " \ diff --git a/include/configs/wb45n.h b/include/configs/wb45n.h index 8b333de8cffd..6ae777507f8f 100644 --- a/include/configs/wb45n.h +++ b/include/configs/wb45n.h @@ -83,10 +83,6 @@ #error No boot method selected, please select 'CONFIG_SYS_USE_NANDFLASH' #endif
-#define CONFIG_BOOTARGS "console=ttyS0,115200 earlyprintk " \ - "rw noinitrd mem=64M " \ - "rootfstype=ubifs root=ubi0:rootfs ubi.mtd=6" - #define CONFIG_EXTRA_ENV_SETTINGS \ "_mtd=mtdparts default; setenv bootargs ${bootargs} ${mtdparts}\0" \ "autoload=no\0" \ diff --git a/include/configs/wb50n.h b/include/configs/wb50n.h index a210449dae49..c65e59134257 100644 --- a/include/configs/wb50n.h +++ b/include/configs/wb50n.h @@ -69,9 +69,6 @@ "nand read 0x22000000 0x000e0000 0x500000; " \ "bootm"
-#define CONFIG_BOOTARGS \ - "rw rootfstype=ubifs ubi.mtd=6 root=ubi0:rootfs" - #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/xea.h b/include/configs/xea.h index 65109566d3b8..144f62e8f980 100644 --- a/include/configs/xea.h +++ b/include/configs/xea.h @@ -43,7 +43,6 @@
/* Booting Linux */ #define CONFIG_BOOTFILE "uImage" -#define CONFIG_BOOTARGS "console=ttyAMA0,115200n8 " #define CONFIG_BOOTCOMMAND "run ${bootpri} ; run ${bootsec}" #define CONFIG_LOADADDR 0x42000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
This converts the following to Kconfig: CONFIG_BCH
Signed-off-by: Tom Rini trini@konsulko.com --- configs/ge_bx50v3_defconfig | 1 + configs/mx53ppd_defconfig | 1 + include/configs/ge_bx50v3.h | 2 -- include/configs/mx53ppd.h | 2 -- 4 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 58778e670c99..d61c23804656 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -99,4 +99,5 @@ CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_WATCHDOG_TIMEOUT_MSECS=6000 CONFIG_IMX_WATCHDOG=y +CONFIG_BCH=y # CONFIG_EFI_LOADER is not set diff --git a/configs/mx53ppd_defconfig b/configs/mx53ppd_defconfig index 1dca2455c819..4b561adc7d31 100644 --- a/configs/mx53ppd_defconfig +++ b/configs/mx53ppd_defconfig @@ -77,3 +77,4 @@ CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_VIDEO_IPUV3=y CONFIG_WATCHDOG_TIMEOUT_MSECS=8000 CONFIG_IMX_WATCHDOG=y +CONFIG_BCH=y diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 47c5974b2ed8..a959488cb9bd 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -176,6 +176,4 @@ #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(1, 5)
-#define CONFIG_BCH - #endif /* __GE_BX50V3_CONFIG_H */ diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index 2ee66612c21b..8c7d1395d087 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -144,8 +144,6 @@
#define CONFIG_FSL_IIM
-#define CONFIG_BCH - /* Backlight Control */ #define CONFIG_IMX6_PWM_PER_CLK 66666000
This converts the following to Kconfig: CONFIG_BOARD_TYPES
Signed-off-by: Tom Rini trini@konsulko.com --- configs/brsmarc1_defconfig | 1 + configs/mscc_jr2_defconfig | 1 + configs/mscc_luton_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mscc_serval_defconfig | 1 + configs/mscc_servalt_defconfig | 1 + include/configs/brsmarc1.h | 1 - include/configs/vcoreiii.h | 2 -- 8 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index a7cf98fc746c..8333038c61b7 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_TYPES=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index ab4f9b6255ba..d9173f408666 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -19,6 +19,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="jr2 # " # CONFIG_CMD_BDI is not set diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 55edb199993b..d5639016958d 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -21,6 +21,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="luton # " # CONFIG_CMD_BDI is not set diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index 3fe9e060bb56..a0e04bd4c749 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -18,6 +18,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="ocelot # " # CONFIG_CMD_BDI is not set diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index e423fc4efc52..1c86c0dca39b 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -16,6 +16,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="serval # " # CONFIG_CMD_BDI is not set diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index 49d8468226fc..91347682eef3 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -15,6 +15,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" CONFIG_LOGLEVEL=7 CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_R=y CONFIG_SYS_PROMPT="servalt # " # CONFIG_CMD_BDI is not set diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h index 5aa68d1d4695..acf13b830a2e 100644 --- a/include/configs/brsmarc1.h +++ b/include/configs/brsmarc1.h @@ -16,7 +16,6 @@ #include <configs/bur_am335x_common.h> #include <linux/stringify.h> /* ------------------------------------------------------------------------- */ -#define CONFIG_BOARD_TYPES
/* memory */ #define CONFIG_SYS_MALLOC_LEN (5 * 1024 * 1024) diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 020f02caae9c..460433cb00bf 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -23,8 +23,6 @@ #endif #define CONFIG_SYS_NS16550_CLK CONFIG_SYS_MIPS_TIMER_FREQ
-#define CONFIG_BOARD_TYPES - #define CONFIG_SYS_SDRAM_BASE 0x80000000 #if defined(CONFIG_DDRTYPE_H5TQ1G63BFA) || defined(CONFIG_DDRTYPE_MT47H128M8HQ) #define CONFIG_SYS_SDRAM_SIZE (128 * SZ_1M)
This converts the following to Kconfig: CONFIG_BOOTCOUNT_ENV CONFIG_BOOTCOUNT_LIMIT
Cc: Anatolij Gustschin agust@denx.de Signed-off-by: Tom Rini trini@konsulko.com --- configs/deneb_defconfig | 2 ++ configs/giedi_defconfig | 2 ++ include/configs/capricorn-common.h | 3 --- 3 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index 31a68f824025..5377b4fed513 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -62,6 +62,8 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_SPL_CLK=y CONFIG_CLK_IMX8=y CONFIG_CPU=y diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index 5dd34227af01..dfac924bbb08 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -62,6 +62,8 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_SPL_CLK=y CONFIG_CLK_IMX8=y CONFIG_CPU=y diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index c2e9d0f11f9c..b107e0ce3f96 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -138,9 +138,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR #define CONFIG_SYS_INIT_SP_ADDR 0x80200000
-#define CONFIG_BOOTCOUNT_LIMIT -#define CONFIG_BOOTCOUNT_ENV - /* Environment organisation */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1, eMMC */
This converts the following to Kconfig: CONFIG_BOOTDELAY
Cc: Holger Brunck holger.brunck@ch.abb.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/socfpga_arria5_secu1.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/socfpga_arria5_secu1.h b/include/configs/socfpga_arria5_secu1.h index 77914438bfa0..eb17470ae6bc 100644 --- a/include/configs/socfpga_arria5_secu1.h +++ b/include/configs/socfpga_arria5_secu1.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_I2C_RTC_ADDR 0x68
/* Booting Linux */ -#define CONFIG_BOOTDELAY 2 #define CONFIG_BOOTFILE "zImage"
Hello Tom,
2.17.1
Acked-By: Holger Brunck holger.brunck@ch.abb.com
Best regards Holger
This converts the following to Kconfig: CONFIG_BOOTP_DNS2 CONFIG_BOOTP_PXE_CLIENTARCH
Signed-off-by: Tom Rini trini@konsulko.com --- configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_guardian_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am335x_hs_evm_uart_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/apf27_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/pepper_defconfig | 1 + configs/phycore-am335x-r2-wega_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tools-only_defconfig | 1 + include/configs/am335x_shc.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/apf27.h | 1 - include/configs/da850evm.h | 1 - include/configs/devkit8000.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/s32v234evb.h | 5 ----- include/configs/sandbox.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_am335x_common.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - 73 files changed, 57 insertions(+), 20 deletions(-)
diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 2781d49daf5f..76f2a9421b34 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 64c1c537f933..b161b3bbc3cf 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -29,6 +29,7 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" CONFIG_ENV_IS_IN_MMC=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 8d8276ba5612..b8333eb4b8bc 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_SPL_NAND_OFS=0x00080000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)" diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 01333e7d9346..b88e4d9970f7 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_MTD=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_LED is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 393665fcf377..4faab7fa5bce 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_MTD_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)" diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index a8afad9e0be8..fb4e11d1c7c8 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_MTD_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)" diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 633c35f77bc3..5295b6ac81cb 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 94c513457c2a..6401375250b7 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_PINMUX is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 6650b3eb6d79..fea34a34242f 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_PINMUX is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index f03f1fa0ae71..84e43603f20f 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_PINMUX is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 13b36864177b..14589a32e629 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_PINMUX is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 238164a55fe1..55170309c68b 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-sl50" diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 6dd04a4c1725..1e0baebc17ab 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_SPL_WRITE_SIZE=0x20000 CONFIG_CMD_NAND=y # CONFIG_CMD_SPI is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_CACHE=y # CONFIG_CMD_TIME is not set CONFIG_CMD_MTDPARTS=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 075c09b62629..df02489b3b6e 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_SPL_WRITE_SIZE=0x40000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:256k(NAND.SPL),256k(NAND.SPL.backup1),256k(NAND.SPL.backup2),256k(NAND.SPL.backup3),512k(NAND.u-boot-spl-os),1m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup1),7m(NAND.kernel),-(NAND.file-system)" diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 39facf132e5f..459096db4f55 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am437x-sk-evm" diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index a0a6661e40d1..66fe74407f12 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SPL_WRITE_SIZE=0x40000 # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:256k(NAND.SPL),256k(NAND.SPL.backup1),256k(NAND.SPL.backup2),256k(NAND.SPL.backup3),512k(NAND.u-boot-spl-os),1m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup1),7m(NAND.kernel),-(NAND.file-system)" diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index db48785f9117..d1a6fbe75387 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 523ce00585f8..deaa19007fae 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_USB_ETHER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:256k(NAND.SPL),256k(NAND.SPL.backup1),256k(NAND.SPL.backup2),256k(NAND.SPL.backup3),512k(NAND.u-boot-spl-os),1m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup1),7m(NAND.kernel),-(NAND.file-system)" diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 42942e9ed4bb..f0418bd0ffa5 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_BCB=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_AB_SELECT=y +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_PMIC is not set CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index f80ec38004bc..c5a62fbbca6b 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_BCB=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_AB_SELECT=y +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_PMIC is not set CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 3b155cc2026d..c21a8755c128 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_BCB=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_AB_SELECT=y +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_PMIC is not set CONFIG_CMD_AVB=y CONFIG_OF_CONTROL=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 73a53047244d..88f1b5443503 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_NAND_LOCK_UNLOCK=y CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DNS=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 87dae5950b9b..2eb03ff67cc3 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 5ee9878a5508..851d6fddafa5 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index afc73dc89c52..01c114352131 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=8000000.nand" diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 51351669fee5..983aaf388d6e 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand" diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index ee49ed29e64a..1a6a97ed161a 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_DM=y CONFIG_CMD_MTD=y # CONFIG_CMD_SF is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_TIME is not set # CONFIG_CMD_EXT4 is not set CONFIG_CMD_FS_UUID=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index ab86108d664b..36ef122ba3ae 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_MTD=y # CONFIG_CMD_SF is not set # CONFIG_CMD_SPI is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_TIME is not set CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.2" diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index bc2c0a2c2542..e805f2c10eda 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_DM=y # CONFIG_CMD_GPT is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_TIME is not set # CONFIG_CMD_EXT4 is not set CONFIG_CMD_MTDPARTS=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 1d642c095f48..53a43ed0ae5b 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_LOCK_UNLOCK=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_BOOTP_NTPSERVER=y CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 4c326211d768..7050482a9803 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 16202c848c59..ee31e26c8016 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 644b6e54644e..c4758ef4e14f 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_MMC is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index d4b5a5fddd6f..34b5baa0edf9 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_MMC is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 5bc7f7f8656e..d16e8f48bd83 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_GPT is not set CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index a530ba035775..f089be4f563a 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_GPT is not set CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index eb5916c2c65d..6060a3e8bdf8 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_MMC is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 96cab5168725..ef1e4cc1da41 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_MMC is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 71a35e349616..39777d87f1b5 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_MMC is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 3fad15f121fd..26d071636ebf 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MX_CYCLIC=y # CONFIG_CMD_MMC is not set CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 50cf09c7f182..378465bf631b 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_DM=y CONFIG_CMD_NAND=y # CONFIG_CMD_PINMUX is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index ea7a0769f290..455ca32f53d6 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 43e64630ab62..b51a30e98192 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 3d0fcf3ea095..63fa72c13386 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_WOL=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 6585ac05fd09..5d79d4774c3c 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 864e2ff59ba2..d19271652691 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_PING=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 67de086c0b26..3603f0b18cbf 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_BMP=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index c4a4e137379d..b237d5237664 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 40c9de25c698..20b5f981ba09 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_BMP=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index a3f049e124e1..6cb3aa41fb60 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_READ=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 5b7569319b73..20a81a0350d2 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -56,6 +56,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_AXI=y CONFIG_CMD_AB_SELECT=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_PCAP=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 21f9047046a3..22f4b159fac7 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index fc8b26e88cfe..d499ac1727eb 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -51,6 +51,7 @@ CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y CONFIG_CMD_RARP=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index d81981a827e7..59b99cdace24 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 71c9119c7d06..60d9ccded8f1 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_BOOTP_DNS2=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 21d152aea9d1..98322b80084d 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set +CONFIG_BOOTP_DNS2=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=nand.0" diff --git a/configs/tools-only_defconfig b/configs/tools-only_defconfig index 70e62bf9d9da..1ae10236d2c9 100644 --- a/configs/tools-only_defconfig +++ b/configs/tools-only_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_SIGNATURE=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_ELF is not set +CONFIG_BOOTP_DNS2=y # CONFIG_CMD_DATE is not set CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index cf964373f0c6..c881ac621114 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -240,7 +240,6 @@ #endif
#define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index cc5e8314c71b..7cd9ec96593a 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -37,7 +37,6 @@ /* Ethernet */ #define CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 4a2c39c44d46..b7cc1a137ba7 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -193,7 +193,6 @@ #ifndef CONFIG_SPL_BUILD /* CPSW Ethernet */ #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index e94b7c8d216a..adcd9a12e2e5 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -54,7 +54,6 @@ #define CONFIG_HSMMC2_8BIT
/* CPSW Ethernet */ -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #define PHY_ANEG_TIMEOUT 8000 /* PHY needs longer aneg time at 1G */ diff --git a/include/configs/apf27.h b/include/configs/apf27.h index cecd485e2055..aaf22acdb51e 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -40,7 +40,6 @@ * BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_DNS2
#define CONFIG_HOSTNAME "apf27" #define CONFIG_ROOTPATH "/tftpboot/" __stringify(CONFIG_BOARD_NAME) "-root" diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 4d651264dd2e..2bb4e47496b4 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -166,7 +166,6 @@ * Network & Ethernet Configuration */ #ifdef CONFIG_DRIVER_TI_EMAC -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 21af126c4bde..f90c1c5a18a6 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -65,7 +65,6 @@ /* BOOTP/DHCP options */ #define CONFIG_BOOTP_NISDOMAIN #define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_TIMEOFFSET #undef CONFIG_BOOTP_VENDOREX diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 58fa5ccfa3ef..58fc10d31f46 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -157,7 +157,6 @@ #ifdef CONFIG_DRIVER_TI_EMAC #undef CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index 5c6692c1999c..e207ca45fdb6 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -151,11 +151,6 @@ #define CONFIG_SYS_MALLOC_BASE (DDR_BASE_ADDR) #endif
-#if 0 -/* Configure PXE */ -#define CONFIG_BOOTP_PXE_CLIENTARCH 0x100 -#endif - /* Physical memory map */ /* EVB board has 2x256 MB DDR chips, DDR0 and DDR1, u-boot is using just one */ #define PHYS_SDRAM (DDR_BASE_ADDR) diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 2a81f3a9bc02..273a15a41a62 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -67,7 +67,6 @@ #define CONFIG_KEEP_SERVERADDR #define CONFIG_UDP_CHECKSUM #define CONFIG_TIMESTAMP -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_SERVERIP
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index ed931176504a..d146ba51dedb 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -171,7 +171,6 @@ */
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index c13e9979219a..060030b83859 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -120,7 +120,6 @@ * */ #define CONFIG_DRIVER_TI_EMAC_USE_RMII -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 99ddc3e923c7..264b1f1a4cda 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -145,7 +145,6 @@ #endif
/* Ethernet */ -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #define CONFIG_PHY_ET1011C_TX_CLK_FIX diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index d16d61e5cdb2..01a174b29f24 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -88,7 +88,6 @@ #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 19e1e2249ed4..4b3981b9b0d6 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -27,7 +27,6 @@
#ifndef CONFIG_SPL_BUILD /* Network defines. */ -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 10 #endif diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 1b014c1022be..750a69fa7750 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -84,7 +84,6 @@
/* Network Configuration */ #define CONFIG_BOOTP_DEFAULT -#define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_NET_RETRY_COUNT 32 #define CONFIG_SYS_SGMII_REFCLK_MHZ 312
This converts the following to Kconfig: CONFIG_BOUNCE_BUFFER
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/px30_common.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/px30_common.h b/include/configs/px30_common.h index d6c70601dd01..76d6ab1c8b4e 100644 --- a/include/configs/px30_common.h +++ b/include/configs/px30_common.h @@ -32,9 +32,6 @@
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
-/* MMC/SD IP block */ -//#define CONFIG_BOUNCE_BUFFER - #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000 #define SDRAM_BANK_SIZE (2UL << 30)
This converts the following to Kconfig: CONFIG_BUILD_TARGET
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/db-88f6281-bp.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/db-88f6281-bp.h b/include/configs/db-88f6281-bp.h index cc51e6646ee3..e234b0bf9826 100644 --- a/include/configs/db-88f6281-bp.h +++ b/include/configs/db-88f6281-bp.h @@ -11,7 +11,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_TCLK 166666667 #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg -#define CONFIG_BUILD_TARGET "u-boot.kwb"
/* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000
This converts the following to Kconfig: CONFIG_CMDLINE_EDITING
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/ls1028a_common.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index 44f2dc8f9b41..c191f74a3a61 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -87,10 +87,6 @@ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */
-#ifndef CONFIG_CMDLINE_EDITING -#define CONFIG_CMDLINE_EDITING 1 -#endif - #define CONFIG_SYS_MAXARGS 64 /* max command args */
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
This converts the following to Kconfig: CONFIG_CONS_INDEX
Signed-off-by: Tom Rini trini@konsulko.com --- configs/am43xx_evm_defconfig | 1 - configs/am43xx_evm_qspiboot_defconfig | 2 +- configs/am43xx_evm_rtconly_defconfig | 1 - configs/am43xx_evm_usbhost_boot_defconfig | 1 - configs/am43xx_hs_evm_defconfig | 1 - configs/birdland_bav335a_defconfig | 1 - configs/birdland_bav335b_defconfig | 1 - configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/linkit-smart-7688_defconfig | 2 ++ configs/ls1028aqds_tfa_lpuart_defconfig | 1 + configs/mscc_jr2_defconfig | 1 + configs/mscc_luton_defconfig | 1 + configs/mscc_ocelot_defconfig | 1 + configs/mscc_serval_defconfig | 1 + configs/mscc_servalt_defconfig | 1 + configs/mt7628_rfb_defconfig | 1 - configs/x530_defconfig | 1 + include/configs/SBx81LIFKW.h | 2 -- include/configs/SBx81LIFXCAT.h | 2 -- include/configs/brsmarc1.h | 2 -- include/configs/db-88f6281-bp.h | 7 ------- include/configs/gardena-smart-gateway-mt7688.h | 1 - include/configs/linkit-smart-7688.h | 1 - include/configs/ls1021atsn.h | 1 - include/configs/ls1028a_common.h | 1 - include/configs/mt7628.h | 1 - include/configs/vcoreiii.h | 2 -- include/configs/vocore2.h | 1 - include/configs/x530.h | 2 -- 29 files changed, 11 insertions(+), 31 deletions(-)
diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index df02489b3b6e..be88f28e9e3d 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 459096db4f55..fea5aa01745a 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -10,7 +10,7 @@ CONFIG_DM_GPIO=y CONFIG_AM43XX=y CONFIG_ENV_OFFSET_REDUND=0x120000 CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,QSPI,QSPI_BOOT" +CONFIG_SYS_EXTRA_OPTIONS="QSPI,QSPI_BOOT" CONFIG_QSPI_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 66fe74407f12..8f1e60fd3e5d 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -10,7 +10,6 @@ CONFIG_SPL_RTC_DDR_SUPPORT=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index d1a6fbe75387..7afd328a4983 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -9,7 +9,6 @@ CONFIG_AM43XX=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index deaa19007fae..79a0466b5ac2 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -19,7 +19,6 @@ CONFIG_FIT_IMAGE_POST_PROCESS=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 2eb03ff67cc3..a20798be5443 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=1 CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 851d6fddafa5..f5d7e3f50a11 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_BAV_VERSION=2 CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 41496f739bda..610609091910 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -74,6 +74,7 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_BEB_LIMIT=22 CONFIG_MT7628_ETH=y CONFIG_PHY=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_WDT=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 8ec66938cdce..9115bb9d885f 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -60,6 +60,8 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_CONS_INDEX=3 CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_USB=y diff --git a/configs/ls1028aqds_tfa_lpuart_defconfig b/configs/ls1028aqds_tfa_lpuart_defconfig index e0348279d9f9..f3475b558a50 100644 --- a/configs/ls1028aqds_tfa_lpuart_defconfig +++ b/configs/ls1028aqds_tfa_lpuart_defconfig @@ -75,6 +75,7 @@ CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y CONFIG_SCSI=y CONFIG_DM_SCSI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_SPI=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index d9173f408666..aaede4a70b93 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -68,6 +68,7 @@ CONFIG_DM_ETH=y CONFIG_MSCC_JR2_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_ANNOUNCE=y diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index d5639016958d..0846ee84741b 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -72,6 +72,7 @@ CONFIG_DM_ETH=y CONFIG_MSCC_LUTON_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index a0e04bd4c749..36ca158715ba 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -72,6 +72,7 @@ CONFIG_DM_ETH=y CONFIG_MSCC_OCELOT_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_ANNOUNCE=y diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index 1c86c0dca39b..66d9e1d315aa 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -66,6 +66,7 @@ CONFIG_DM_ETH=y CONFIG_MSCC_SERVAL_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index 91347682eef3..1f56875b5feb 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -63,6 +63,7 @@ CONFIG_DM_ETH=y CONFIG_MSCC_SERVALT_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index f444cf98c6ce..ba3b06263f22 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -40,7 +40,6 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_XMC=y CONFIG_MT7628_ETH=y -# CONFIG_SPECIFY_CONSOLE_INDEX is not set CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_LZMA=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index de077cb71fde..2f1fd755fb36 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -70,6 +70,7 @@ CONFIG_DM_PCI_COMPAT=y CONFIG_PCI_MVEBU=y CONFIG_DM_RTC=y CONFIG_RTC_DS1307=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 8f31fc4c7456..ec0c531c4623 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -38,8 +38,6 @@ * for your console driver. */
-#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index f4440e576466..90480520ab3f 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -38,8 +38,6 @@ * for your console driver. */
-#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h index acf13b830a2e..d0cc08baa635 100644 --- a/include/configs/brsmarc1.h +++ b/include/configs/brsmarc1.h @@ -69,6 +69,4 @@ BUR_COMMON_ENV \ /* SPI Flash */
/* Environment */ - -#define CONFIG_CONS_INDEX 1 #endif /* __CONFIG_BRSMARC1_H__ */ diff --git a/include/configs/db-88f6281-bp.h b/include/configs/db-88f6281-bp.h index e234b0bf9826..06a7091be208 100644 --- a/include/configs/db-88f6281-bp.h +++ b/include/configs/db-88f6281-bp.h @@ -29,13 +29,6 @@ #define CONFIG_SYS_NS16550_COM1 KW_UART0_BASE
#define CONFIG_SYS_MAX_NAND_DEVICE 1 -/* - * Serial Port configuration - * The following definitions let you select what serial you want to use - * for your console driver. - */ - -#define CONFIG_CONS_INDEX 1 /* Console on UART0 */
/* * Environment variables configurations diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 261749db8d34..1b26466eda30 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_NS16550_CLK 40000000 #define CONFIG_SYS_NS16550_REG_SIZE -4 #define CONFIG_SYS_NS16550_COM1 0xb0000c00 -#define CONFIG_CONS_INDEX 1 #endif
/* UART */ diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index d7ebfeda4c56..e7a7ae319897 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -36,7 +36,6 @@ #define CONFIG_SYS_NS16550_CLK 40000000 #define CONFIG_SYS_NS16550_REG_SIZE -4 #define CONFIG_SYS_NS16550_COM3 0xb0000e00 -#define CONFIG_CONS_INDEX 3
#endif
diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index ec2ed7c60969..e76e54e97fc9 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -97,7 +97,6 @@ #define CONFIG_CHIP_SELECTS_PER_CTRL 4
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index c191f74a3a61..d184673a71b5 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -43,7 +43,6 @@ #endif
/* Serial Port */ -#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2) diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index 9b9218d29676..c6752f4acb72 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_NS16550_CLK 40000000 #define CONFIG_SYS_NS16550_REG_SIZE -4 #define CONFIG_SYS_NS16550_COM1 0xb0000c00 -#define CONFIG_CONS_INDEX 1 #endif
/* Serial common */ diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 460433cb00bf..82a8fa7354ee 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -34,8 +34,6 @@ #error Unknown DDR size - please add! #endif
-#define CONFIG_CONS_INDEX 1 - #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#if defined(CONFIG_MTDIDS_DEFAULT) && defined(CONFIG_MTDPARTS_DEFAULT) diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h index 5aa3ad8ddf21..40467b737ceb 100644 --- a/include/configs/vocore2.h +++ b/include/configs/vocore2.h @@ -34,7 +34,6 @@ #define CONFIG_SYS_NS16550_CLK 40000000 #define CONFIG_SYS_NS16550_REG_SIZE -4 #define CONFIG_SYS_NS16550_COM3 0xb0000e00 -#define CONFIG_CONS_INDEX 3
/* RAM */
diff --git a/include/configs/x530.h b/include/configs/x530.h index 7e0f2c24d943..4446510df4e0 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -30,8 +30,6 @@ * for your console driver. */
-#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ - /* NAND */ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_MAX_NAND_DEVICE 1
This converts the following to Kconfig: CONFIG_CONSOLE_MUX
Cc: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Tom Rini trini@konsulko.com --- configs/apalis_imx6_defconfig | 2 -- configs/colibri_imx6_defconfig | 2 -- include/configs/apalis_imx6.h | 1 - include/configs/colibri_imx6.h | 1 - 4 files changed, 6 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 6b0f0e463896..e9d9b3f30239 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -19,8 +19,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=1 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 44a3ff859c2d..8bdae00129c3 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -18,8 +18,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6DL" CONFIG_BOOTDELAY=1 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index d5a0625e0282..b2d87019c8e7 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -74,7 +74,6 @@ #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 6beef250942b..a0ee4d48ad06 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -62,7 +62,6 @@ #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
Hi Tom,
-- 2.17.1
Thanks for the patch.
Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/evb_px5.h | 1 - include/configs/evb_rk3308.h | 2 -- include/configs/evb_rk3328.h | 2 -- include/configs/firefly_rk3308.h | 2 -- include/configs/geekbox.h | 2 -- include/configs/sheep_rk3368.h | 2 -- 6 files changed, 11 deletions(-)
diff --git a/include/configs/evb_px5.h b/include/configs/evb_px5.h index e9304206bb12..ed801dd84556 100644 --- a/include/configs/evb_px5.h +++ b/include/configs/evb_px5.h @@ -8,7 +8,6 @@
#include <configs/rk3368_common.h>
-#define CONFIG_CONSOLE_SCROLL_LINES 10 #define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/evb_rk3308.h b/include/configs/evb_rk3308.h index 4d40606e4bd3..0d2cb21ac679 100644 --- a/include/configs/evb_rk3308.h +++ b/include/configs/evb_rk3308.h @@ -14,7 +14,5 @@ #define ROCKCHIP_DEVICE_SETTINGS \ "stdout=serial,vidconsole\0" \ "stderr=serial,vidconsole\0" -#undef CONFIG_CONSOLE_SCROLL_LINES -#define CONFIG_CONSOLE_SCROLL_LINES 10
#endif diff --git a/include/configs/evb_rk3328.h b/include/configs/evb_rk3328.h index ed5888bfd3e9..26687e638616 100644 --- a/include/configs/evb_rk3328.h +++ b/include/configs/evb_rk3328.h @@ -12,6 +12,4 @@
-#define CONFIG_CONSOLE_SCROLL_LINES 10 - #endif diff --git a/include/configs/firefly_rk3308.h b/include/configs/firefly_rk3308.h index 2cc7b4a153f8..7b8b62fbcb15 100644 --- a/include/configs/firefly_rk3308.h +++ b/include/configs/firefly_rk3308.h @@ -14,7 +14,5 @@ #define ROCKCHIP_DEVICE_SETTINGS \ "stdout=serial,vidconsole\0" \ "stderr=serial,vidconsole\0" -#undef CONFIG_CONSOLE_SCROLL_LINES -#define CONFIG_CONSOLE_SCROLL_LINES 10
#endif diff --git a/include/configs/geekbox.h b/include/configs/geekbox.h index 91f4feb73708..4b12eb7af9a8 100644 --- a/include/configs/geekbox.h +++ b/include/configs/geekbox.h @@ -8,6 +8,4 @@
-#define CONFIG_CONSOLE_SCROLL_LINES 10 - #endif diff --git a/include/configs/sheep_rk3368.h b/include/configs/sheep_rk3368.h index 238838fd7d05..550597c957d0 100644 --- a/include/configs/sheep_rk3368.h +++ b/include/configs/sheep_rk3368.h @@ -13,6 +13,4 @@ #define DTB_LOAD_ADDR 0x5600000 #define INITRD_LOAD_ADDR 0x5bf0000
While the normal case of CSF_SIZE is handled via Kconfig we have entries in config headers related to CONFIG_SECURE_BOOT. However in commit d714a75fd4dc ("imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HAB") this was renamed to CONFIG_IMX_HAB. Update the CSF_SIZE entry to have the correct default value if we have IMX_HAB enabled.
Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Fixes: d714a75fd4dc ("imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HAB") Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-imx/Kconfig | 1 + include/configs/imx8mm_beacon.h | 4 ---- include/configs/imx8mm_evk.h | 4 ---- include/configs/imx8mn_evk.h | 4 ---- include/configs/imx8mp_evk.h | 4 ---- include/configs/verdin-imx8mm.h | 4 ---- 6 files changed, 1 insertion(+), 20 deletions(-)
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index 6c3fedf665d6..0648c2725bf8 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -52,6 +52,7 @@ config IMX_HAB
config CSF_SIZE hex "Maximum size for Command Sequence File (CSF) binary" + default 0x2000 if IMX_HAB default 0x2060 help Define the maximum size for Command Sequence File (CSF) binary diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 21102d3c14d2..ce3ba7492435 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -9,10 +9,6 @@ #include <linux/sizes.h> #include <asm/arch/imx-regs.h>
-#ifdef CONFIG_SECURE_BOOT -#define CONFIG_CSF_SIZE SZ_8K -#endif - #define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 901a1bed6dd1..382ba620ccf4 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -10,10 +10,6 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
-#ifdef CONFIG_SECURE_BOOT -#define CONFIG_CSF_SIZE SZ_8K -#endif - #define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index a07440c73ba8..4350b5a62aff 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -10,10 +10,6 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
-#ifdef CONFIG_SECURE_BOOT -#define CONFIG_CSF_SIZE SZ_8K -#endif - #define CONFIG_SPL_MAX_SIZE (148 * 1024) #define CONFIG_SYS_MONITOR_LEN SZ_512K #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 7f38f21c09c5..9c13235982c6 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -10,10 +10,6 @@ #include <linux/stringify.h> #include <asm/arch/imx-regs.h>
-#ifdef CONFIG_SECURE_BOOT -#define CONFIG_CSF_SIZE 0x2000 /* 8K region */ -#endif - #define CONFIG_SPL_MAX_SIZE (152 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index ca528598f2f1..878c4996df42 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -9,10 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
Hi Tom,
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: 2020年6月11日 4:16 To: u-boot@lists.denx.de Cc: Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; dl-uboot-imx uboot-imx@nxp.com Subject: [EXT] [PATCH 24/30] arm: imx: Finish migration of CONFIG_CSF_SIZE to Kconfig
Caution: EXT Email
I suggest using "default 0x2000 if ARCH_IMX8M", because i.MX6/7 may also enable IMX_HAB.
Best regards, Ye Li
#define CONFIG_SPL_MAX_SIZE (152 * 1024) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin- imx8mm.h index ca528598f2f1..878c4996df42 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -9,10 +9,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
2.17.1
On Thu, Jun 11, 2020 at 05:28:45AM +0000, Ye Li wrote:
Hi Tom,
Caution: EXT Email
So ARCH_IMX8M && IMX_HAB? I would have expected the CSF size to be limited in all cases from the default value due to something security related eating up that 0x60 in overhead. Is that not the case? Thanks!
Hi Tom,
Caution: EXT Email
Ah, looking at the actual usage now, I get it. I'll make a v2 that has the right ddefault for ARCH_IMX8M and make CSF_SIZE itself depend on IMX_HAB.
There are a few remaining places where we say CONFIG_SECURE_BOOT rather than CONFIG_IMX HAB. Update these instances.
Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Eddy Petrișor eddy.petrisor@gmail.com Cc: Shawn Guo shawnguo@kernel.org Cc: Vladimir Oltean olteanv@gmail.com Cc: Priyanka Jain priyanka.jain@nxp.com Fixes: d714a75fd4dc ("imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HAB") Signed-off-by: Tom Rini trini@konsulko.com --- Note that we have one place left for CONFIG_SECURE_BOOT being in use but I think that is shared with PowerPC so I don't think IMX_HAB is the right name. But perhaps I'm wrong about it being used for PowerPC? --- arch/arm/mach-imx/spl_qspi.cfg | 2 +- board/ea/mx7ulp_com/imximage.cfg | 2 +- board/freescale/s32v234evb/s32v234evb.cfg | 2 +- board/novtech/meerkat96/imximage.cfg | 2 +- include/configs/ls1021atsn.h | 4 ++-- 5 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-imx/spl_qspi.cfg b/arch/arm/mach-imx/spl_qspi.cfg index 88956e626ffd..1e39ae2f01f7 100644 --- a/arch/arm/mach-imx/spl_qspi.cfg +++ b/arch/arm/mach-imx/spl_qspi.cfg @@ -12,6 +12,6 @@ BOOT_FROM qspi /* * Secure boot support */ -#ifdef CONFIG_SECURE_BOOT +#ifdef CONFIG_IMX_HAB CSF CONFIG_CSF_SIZE #endif diff --git a/board/ea/mx7ulp_com/imximage.cfg b/board/ea/mx7ulp_com/imximage.cfg index d298d17c1e92..1b218996aea9 100644 --- a/board/ea/mx7ulp_com/imximage.cfg +++ b/board/ea/mx7ulp_com/imximage.cfg @@ -28,7 +28,7 @@ BOOT_FROM sd PLUGIN board/freescale/mx7ulp_evk/plugin.bin 0x2F020000 #else
-#ifdef CONFIG_SECURE_BOOT +#ifdef CONFIG_IMX_HAB CSF CONFIG_CSF_SIZE #endif /* diff --git a/board/freescale/s32v234evb/s32v234evb.cfg b/board/freescale/s32v234evb/s32v234evb.cfg index 7881512139d0..d7f722006312 100644 --- a/board/freescale/s32v234evb/s32v234evb.cfg +++ b/board/freescale/s32v234evb/s32v234evb.cfg @@ -23,6 +23,6 @@ BOOT_FROM sd */
-#ifdef CONFIG_SECURE_BOOT +#ifdef CONFIG_IMX_HAB SECURE_BOOT #endif diff --git a/board/novtech/meerkat96/imximage.cfg b/board/novtech/meerkat96/imximage.cfg index 3bd8cc55e53c..86275b84d9c8 100644 --- a/board/novtech/meerkat96/imximage.cfg +++ b/board/novtech/meerkat96/imximage.cfg @@ -25,7 +25,7 @@ BOOT_FROM sd /* * Secure boot support */ -#ifdef CONFIG_SECURE_BOOT +#ifdef CONFIG_IMX_HAB CSF CONFIG_CSF_SIZE #endif
diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index e76e54e97fc9..efa708a239ea 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -60,9 +60,9 @@ #define CONFIG_SYS_FSL_PBL_RCW \ "board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg"
-#ifdef CONFIG_SECURE_BOOT +#ifdef CONFIG_IMX_HAB #define CONFIG_U_BOOT_HDR_SIZE (16 << 10) -#endif /* ifdef CONFIG_SECURE_BOOT */ +#endif /* ifdef CONFIG_IMX_HAB */
#define CONFIG_SPL_MAX_SIZE 0x1a000 #define CONFIG_SPL_STACK 0x1001d000
Hi Tom,
NACK on this patch. I'm not actually sure what were the cross-architecture problems with the CONFIG_SECURE_BOOT name that mandated Stefano to write this patch:
commit d714a75fd4dcfb0eb8b7e1dd29f43e07113cec0b Author: Stefano Babic sbabic@denx.de Date: Fri Sep 20 08:47:53 2019 +0200
CONFIG_SECURE_BOOT is too generic and forbids to use it for cross architecture purposes. If Secure Boot is required for imx, this means to enable and use the HAB processor in the soc.
Signed-off-by: Stefano Babic sbabic@denx.de
but going the full way and grouping Layerscape, QorIQ and S32V secure boot implementations together with a boot ROM feature available only on i.MX 50, 53, 6, 7, 8M and 8MM is demonstrably incorrect.
I think the correct solution (beside leaving the CONFIG_SECURE_BOOT name alone) would be to merge it, for the Layerscape (ls*) and PowerPC instances, with CONFIG_CHAIN_OF_TRUST (defined under board/freescale/common/Kconfig). But you or Stefano might argue that CHAIN_OF_TRUST is still too generic for a name, and in that case, maybe the whole thing can be renamed to CONFIG_FSL_ESBC (ESBC == "External Secure Boot Code", aka image validation code executed by the bootloader as opposed to the [internal] boot ROM).
By the way, I have no idea what is the correct solution for S32V.
- Secure boot support
2.17.1
Thanks, -Vladimir
On Thu, Jun 11, 2020 at 10:31:32PM +0300, Vladimir Oltean wrote:
Hi Tom,
NACK on this patch.
Note that today CONFIG_SECURE_BOOT is not defined anywhere and the commit you mention next replaced the only places that set CONFIG_SECURE_BOOT with CONFIG_IMX_HAB.
imx: replace CONFIG_SECURE_BOOT with CONFIG_IMX_HAB CONFIG_SECURE_BOOT is too generic and forbids to use it for cross architecture purposes. If Secure Boot is required for imx, this means to enable and use the HAB processor in the soc. Signed-off-by: Stefano Babic <sbabic@denx.de>
The problem is that SECURE_BOOT is very generic. We have quite a few different "secure boot" implementations in the tree and another pointed out what a bad name this one is. And just to be clear, I'm the only one (intentionally) touching non-i.MX spots here.
OK. I (and others on the thread at the time) were asking for someone to group things right and provide a new symbol. What's in there is what we got, but more details are always better as there were a few cases that didn't get updated.
So for this patch here it's a few instances of CONFIG_CSF_SIZE on i.MX files, a change to S32V that looks quite a lot like i.MX (the file notes as much) and a layerscape change to CONFIG_U_BOOT_HDR_SIZE. I'm quite happy to spin v2 dropping the layerscape part out and waiting to see what Eddy says for S32V. We have a CONFIG_NXP_ESBC symbol today, would that make sense to use in the check on include/configs/ls1021atsn.h and top-level Makefile for not making u-boot.pbl sometimes? Thanks again!
Hi Tom,
NACK on this patch.
Actually looks like the ls1021atsn_sdcard_SECURE_BOOT_defconfig that defined it (via CONFIG_SYS_EXTRA_OPTIONS) hasn't made it upstream yet, so it's a bit unfair to say it, but things under CONFIG_SECURE_BOOT are not dead code as you want to imply.
Ok, agree that it's a bad name for something that lives under board/freescale/.
Yes, yes, for ls1021atsn.h and for the top-level Makefile, CONFIG_NXP_ESBC is exactly what is needed! For the top-level Makefile in particular, I believe it was missed during this conversion:
commit 5536c3c9d0d10c1a4e440e71eac389df3a3dbfa7 Author: Udit Agarwal udit.agarwal@nxp.com Date: Thu Nov 7 16:11:32 2019 +0000
freescale/layerscape: Rename the config CONFIG_SECURE_BOOT name
Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot.
Signed-off-by: Udit Agarwal udit.agarwal@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com
I'm not sure how I missed it during my previous reply.
-- Tom
Thanks, -Vladimir
Hi Tom,
NACK on this patch.
Ah, sorry, I was trying to fix inadvertently broken code.
freescale/layerscape: Rename the config CONFIG_SECURE_BOOT name Rename CONFIG_SECURE_BOOT to CONFIG_NXP_ESBC to avoid conflict with UEFI secure boot. Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Ah-ha! I'll catch this in v2, thanks!
This converts the following to Kconfig: CONFIG_BOOTM_NETBSD
Signed-off-by: Tom Rini trini@konsulko.com --- configs/deneb_defconfig | 1 + configs/giedi_defconfig | 1 + configs/imx8qm_rom7720_a1_4G_defconfig | 1 + include/configs/capricorn-common.h | 4 ---- include/configs/imx8qm_rom7720.h | 2 -- 5 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/configs/deneb_defconfig b/configs/deneb_defconfig index 5377b4fed513..c0e7725f64e5 100644 --- a/configs/deneb_defconfig +++ b/configs/deneb_defconfig @@ -37,6 +37,7 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" CONFIG_AUTOBOOT_KEYED_CTRLC=y CONFIG_CMD_CPU=y +# CONFIG_BOOTM_NETBSD is not set # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_CRC32 is not set diff --git a/configs/giedi_defconfig b/configs/giedi_defconfig index dfac924bbb08..d2b0f13f61f1 100644 --- a/configs/giedi_defconfig +++ b/configs/giedi_defconfig @@ -37,6 +37,7 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" CONFIG_AUTOBOOT_KEYED_CTRLC=y CONFIG_CMD_CPU=y +# CONFIG_BOOTM_NETBSD is not set # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set # CONFIG_CMD_CRC32 is not set diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index 305c4e827c66..8af2b239d6e8 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -27,6 +27,7 @@ CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y +# CONFIG_BOOTM_NETBSD is not set # CONFIG_CMD_IMPORTENV is not set CONFIG_CMD_CLK=y CONFIG_CMD_DM=y diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index b107e0ce3f96..38a56e897e82 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -42,10 +42,6 @@
#define CONFIG_REMAKE_ELF
-/* Commands */ - -#undef CONFIG_BOOTM_NETBSD - /* ENET Config */ #define CONFIG_FEC_XCV_TYPE RMII #define FEC_QUIRK_ENET_MAC diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h index 9808e72474f0..5621ba8232da 100644 --- a/include/configs/imx8qm_rom7720.h +++ b/include/configs/imx8qm_rom7720.h @@ -15,8 +15,6 @@ #define CONFIG_SPL_BSS_START_ADDR 0x00128000 #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */
-#undef CONFIG_BOOTM_NETBSD - #define CONFIG_FSL_USDHC #define CONFIG_SYS_BOOTMAPSZ (256 << 20) #define CONFIG_SYS_FSL_ESDHC_ADDR 0
This variable is unset anywhere and only unset on a number of platforms. Remove all relevant code.
Signed-off-by: Tom Rini trini@konsulko.com --- README | 13 ------------- include/configs/MPC8536DS.h | 2 -- include/configs/MPC8540ADS.h | 2 -- include/configs/MPC8541CDS.h | 2 -- include/configs/MPC8544DS.h | 2 -- include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 2 -- include/configs/MPC8560ADS.h | 2 -- include/configs/MPC8568MDS.h | 2 -- include/configs/MPC8569MDS.h | 2 -- include/configs/MPC8572DS.h | 2 -- include/configs/MPC8610HPCD.h | 2 -- include/configs/MPC8641HPCN.h | 2 -- include/configs/UCP1020.h | 2 -- include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/sbc8548.h | 2 -- include/configs/sbc8641d.h | 2 -- include/env_default.h | 3 --- 18 files changed, 47 deletions(-)
diff --git a/README b/README index a0f54645fc26..11273726d323 100644 --- a/README +++ b/README @@ -559,19 +559,6 @@ The following options need to be configured: such as ARM architectural timer initialization.
- Linux Kernel Interface: - CONFIG_CLOCKS_IN_MHZ - - U-Boot stores all clock information in Hz - internally. For binary compatibility with older Linux - kernels (which expect the clocks passed in the - bd_info data to be in MHz) the environment variable - "clocks_in_mhz" can be defined so that U-Boot - converts clock data to MHZ before passing it to the - Linux kernel. - When CONFIG_CLOCKS_IN_MHZ is defined, a definition of - "clocks_in_mhz=1" is automatically included in the - default environment. - CONFIG_MEMSIZE_IN_BYTES [relevant for MIPS only]
When transferring memsize parameter to Linux, some versions diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 340574a98526..3956bdd2512c 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -124,8 +124,6 @@ #error ("CONFIG_SPD_EEPROM is required") #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Memory map -- xxx -this is wrong, needs updating * diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index f78782a1c140..f15af931483c 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -112,8 +112,6 @@
#define CONFIG_SYS_FLASH_EMPTY_INFO
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Local Bus Definitions */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index b2a320107203..9c77dcecd99a 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -57,8 +57,6 @@ extern unsigned long get_clock_freq(void); #error ("CONFIG_SPD_EEPROM is required by MPC85555CDS") #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Local Bus Definitions */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index c9f193fc4672..49c2a4acca27 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -63,8 +63,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #error ("CONFIG_SPD_EEPROM is required") #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Memory map * diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index de2bfd8f2f4a..933417483483 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -73,7 +73,6 @@ extern unsigned long get_clock_freq(void); #error ("CONFIG_SPD_EEPROM is required") #endif
-#undef CONFIG_CLOCKS_IN_MHZ /* * Physical Address Map * diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index d964b4e12173..9a14323b52ef 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -55,8 +55,6 @@ extern unsigned long get_clock_freq(void); #error ("CONFIG_SPD_EEPROM is required by MPC85555CDS") #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Local Bus Definitions */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 97d8cc48edf7..250f2de86060 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -113,8 +113,6 @@
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Local Bus Definitions */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index a0bd5f4d40f6..46d6b16d34d2 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -59,8 +59,6 @@ extern unsigned long get_clock_freq(void); #error ("CONFIG_SPD_EEPROM is required") #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Local Bus Definitions */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index beba848214e7..bbc75e35a7f8 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -109,8 +109,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_DDR_ERR_DIS 0x00000000 #define CONFIG_SYS_DDR_SBE 0x00010000
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Local Bus Definitions */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 3243f39df4b5..d924b2ba6117 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -118,8 +118,6 @@ #error ("CONFIG_SPD_EEPROM is required") #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Memory map * diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index b2acc7297361..c0407bbc16b2 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -176,8 +176,6 @@ #define CONFIG_SYS_SDRAM_SIZE 256 #endif
-#undef CONFIG_CLOCKS_IN_MHZ - #define CONFIG_SYS_INIT_RAM_LOCK 1 #ifndef CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index edbeeefdd4a9..ad8d261b3b4b 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -221,8 +221,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_SDRAM_SIZE 256 #endif
-#undef CONFIG_CLOCKS_IN_MHZ - #define CONFIG_SYS_INIT_RAM_LOCK 1 #ifndef CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x0fd00000 /* Initial RAM address */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index cfc9567332e9..2590a28867d3 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -227,8 +227,6 @@ #define CONFIG_SYS_DDR_MODE_2 0x8000c000 #define CONFIG_SYS_DDR_INTERVAL 0x0C300000
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Memory map * diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 219e5d216bbc..6b57be912ac5 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -300,8 +300,6 @@ #define CONFIG_SYS_DDR_INTERVAL 0x0C300000 #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * Memory map * diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 55c4bff28ae4..4cdfd1b099e7 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -118,8 +118,6 @@ #define CONFIG_SYS_DDR_CONTROL 0xc300c000 #endif
-#undef CONFIG_CLOCKS_IN_MHZ - /* * FLASH on the Local Bus * Two banks, one 8MB the other 64MB, using the CFI driver. diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 4ab364ae9a2f..662160701440 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -206,8 +206,6 @@ #define CONFIG_SYS_WRITE_SWAPPED_DATA #define CONFIG_SYS_FLASH_EMPTY_INFO
-#undef CONFIG_CLOCKS_IN_MHZ - #define CONFIG_SYS_INIT_RAM_LOCK 1 #ifndef CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x0fd00000 /* Initial RAM address */ diff --git a/include/env_default.h b/include/env_default.h index a657927e06f5..8a0c3057f0aa 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -83,9 +83,6 @@ const uchar default_environment[] = { #ifdef CONFIG_LOADADDR "loadaddr=" __stringify(CONFIG_LOADADDR) "\0" #endif -#ifdef CONFIG_CLOCKS_IN_MHZ - "clocks_in_mhz=1\0" -#endif #if defined(CONFIG_PCI_BOOTDELAY) && (CONFIG_PCI_BOOTDELAY > 0) "pcidelay=" __stringify(CONFIG_PCI_BOOTDELAY)"\0" #endif
Due to how the Makefile logic is we currently get DM_SPI support in SPL enabled by having DM_SPI enabled for full U-Boot but not having CONFIG_SPL_DM_SPI set. Add this missing option to boards that were inadvertently making use of it.
Cc: Adam Ford aford173@gmail.com Cc: Akash Gajjar akash@openedev.com Cc: Anatolij Gustschin agust@denx.de Cc: Andy Yan andy.yan@rock-chips.com Cc: Anup Patel anup.patel@wdc.com Cc: Atish Patra atish.patra@wdc.com Cc: Bin Meng bmeng.cn@gmail.com Cc: Chee Hong Ang chee.hong.ang@intel.com Cc: Chin-Liang See clsee@altera.com Cc: Dalon Westergreen dwesterg@gmail.com Cc: Dinh Nguyen dinguyen@kernel.org Cc: Eugen Hristev eugen.hristev@microchip.com Cc: Hannes Schmelzer hannes.schmelzer@br-automation.com Cc: Heiko Schocher hs@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Klaus Goger klaus.goger@theobroma-systems.com Cc: Levin Du djw@t-chip.com.cn Cc: Ley Foon Tan ley.foon.tan@intel.com Cc: Lokesh Vutla lokeshvutla@ti.com Cc: Luca Ceresoli luca@lucaceresoli.net Cc: Marek Vasut marex@denx.de Cc: Michal Simek monstr@monstr.eu Cc: Mike Looijmans mike.looijmans@topic.nl Cc: Nicolas Ferre nicolas.ferre@microchip.com Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Palmer Dabbelt palmer@dabbelt.com Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Paul Walmsley paul.walmsley@sifive.com Cc: Pavel Machek pavel@denx.de Cc: Peter Robinson pbrobinson@gmail.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Suniel Mahesh sunil@amarulasolutions.com Cc: Wolfgang Grandegger wg@aries-embedded.de Signed-off-by: Tom Rini trini@konsulko.com --- configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/am57xx_hs_evm_usb_defconfig | 1 + configs/am65x_evm_a53_defconfig | 1 + configs/am65x_evm_r5_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 1 + configs/am65x_hs_evm_r5_defconfig | 1 + configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 + configs/axm_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brsmarc1_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_coral_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link64_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_samus_tpl_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_nand_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + configs/dra7xx_hs_evm_usb_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/j721e_evm_a72_defconfig | 1 + configs/j721e_evm_r5_defconfig | 1 + configs/j721e_hs_evm_a72_defconfig | 1 + configs/j721e_hs_evm_r5_defconfig | 1 + configs/lion-rk3368_defconfig | 1 + configs/pinebook-pro-rk3399_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/roc-pc-mezzanine-rk3399_defconfig | 1 + configs/roc-pc-rk3399_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 1 + configs/sama5d27_wlsom1_ek_qspiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sifive_fu540_defconfig | 1 + configs/socfpga_agilex_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_dhcom_basic_defconfig | 1 + configs/stm32mp15_dhcor_basic_defconfig | 1 + configs/taurus_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + 68 files changed, 68 insertions(+)
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index f0418bd0ffa5..7c907fd3f496 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -4,6 +4,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_OMAP54XX=y CONFIG_TARGET_AM57XX_EVM=y CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index c5a62fbbca6b..81bac5592eb6 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -5,6 +5,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_OMAP54XX=y CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index c21a8755c128..ea5215e8cf3a 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -6,6 +6,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_OMAP54XX=y CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index d74a2d09309b..cc4da7dd15d4 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 4fc199e80911..1e7a7d1e6eec 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_AM654_R5_EVM=y CONFIG_ENV_SIZE=0x20000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index 117953817d82..5b504ad6deb6 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index b2d638672e33..9977e97f2b05 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -11,6 +11,7 @@ CONFIG_TARGET_AM654_R5_EVM=y CONFIG_ENV_SIZE=0x20000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 227a5416c63f..7592033dbb18 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 1615d8af0eba..6a3336c256b6 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_OFFSET=0x100000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 964b22b10093..aea67c25dc20 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x20000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_AM33XX=y CONFIG_TARGET_BRPPT1=y CONFIG_SPL_SERIAL_SUPPORT=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 8333038c61b7..aac8d17876bd 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x20000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=600 CONFIG_TARGET_BRSMARC1=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 23efafb0d2d5..22719fc5355c 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -3,6 +3,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3288=y # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_TARGET_CHROMEBIT_MICKEY=y diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 4f606e7ec9fc..b8093ca8fcce 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0 CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index d7cab2334baa..6cc3a8469feb 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -1,6 +1,7 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0x1110000 CONFIG_SYS_MALLOC_F_LEN=0x3d00 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SYS_MALLOC_F_LEN=0xf000 CONFIG_NR_DRAM_BANKS=8 CONFIG_BOOTSTAGE_STASH_ADDR=0xfef00000 diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 443e3cdace8d..6523921aee13 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -3,6 +3,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3288=y # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_SPL_STACK_R_ADDR=0x80000 diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 75f3d2c4116d..a80225a11f3a 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_DM_SPI=y CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 99ac0e067438..f33ab19998ff 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -3,6 +3,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3288=y # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_TARGET_CHROMEBOOK_MINNIE=y diff --git a/configs/chromebook_samus_tpl_defconfig b/configs/chromebook_samus_tpl_defconfig index 82172ba810ca..95c9b6e6af53 100644 --- a/configs/chromebook_samus_tpl_defconfig +++ b/configs/chromebook_samus_tpl_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x1a00 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_DM_SPI=y CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 5a5152541bf3..f930ba6179f3 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -3,6 +3,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00100000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3288=y # CONFIG_SPL_MMC_SUPPORT is not set CONFIG_TARGET_CHROMEBOOK_SPEEDY=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 94b051ad4f95..4232aaca002e 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_OFFSET=0xC0000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_AM43XX=y CONFIG_TARGET_CM_T43=y CONFIG_SPL_MMC_SUPPORT=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 1a6a97ed161a..12768065f3ab 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x80000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index e805f2c10eda..13026fd1ea2c 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x0 CONFIG_SYS_SPI_U_BOOT_OFFS=0x8000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index e4547d9dcc8c..afbc4383a6b0 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -4,6 +4,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_OMAP54XX=y CONFIG_TARGET_DRA7XX_EVM=y CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index c08bcce90381..d813040f93cf 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -5,6 +5,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_OMAP54XX=y CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 879c2b650be3..9d837e54460e 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -6,6 +6,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_OMAP54XX=y CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index d1323738e02b..039af2ddf076 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3368=y CONFIG_TPL_LDSCRIPT="arch/arm/mach-rockchip/u-boot-tpl-v8.lds" CONFIG_TPL_LIBCOMMON_SUPPORT=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 4deb4e219fe7..2d0b40719ddc 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index ee9217aee238..c597f8309238 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_J721E_R5_EVM=y CONFIG_ENV_SIZE=0x20000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/j721e_hs_evm_a72_defconfig b/configs/j721e_hs_evm_a72_defconfig index ae540a26a401..bd933eb8d795 100644 --- a/configs/j721e_hs_evm_a72_defconfig +++ b/configs/j721e_hs_evm_a72_defconfig @@ -9,6 +9,7 @@ CONFIG_TARGET_J721E_A72_EVM=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/j721e_hs_evm_r5_defconfig b/configs/j721e_hs_evm_r5_defconfig index 51d5a3bb98fa..7bdf3401a1a5 100644 --- a/configs/j721e_hs_evm_r5_defconfig +++ b/configs/j721e_hs_evm_r5_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index b6504b71238c..45ff1714791b 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3368=y CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 CONFIG_TPL_LIBCOMMON_SUPPORT=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index 0c129b9aebb4..754cf5e5b401 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_PINEBOOK_PRO_RK3399=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 6b7d2ee6b8af..8a0ae32c655a 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ENV_OFFSET=0x3F8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 CONFIG_TARGET_PUMA_RK3399=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 90d287b7b063..a5be09b2ba1c 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_TEXT_BASE=0x1110000 CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_ENV_SIZE=0x40000 CONFIG_MAX_CPUS=2 +CONFIG_SPL_DM_SPI=y CONFIG_NR_DRAM_BANKS=8 CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index fd1b85c1e4ba..b3c8f19e43d0 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_SIZE=0x6000 CONFIG_ENV_OFFSET=0x460000 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROC_PC_RK3399=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 80e700148181..edb327b46b8f 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_SIZE=0x6000 CONFIG_ENV_OFFSET=0x460000 CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROC_PC_RK3399=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 807747485a36..2bbded008361 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROCKPRO64_RK3399=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index eea86f935708..58b906ad5923 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 9f90aa1328c9..e5227b11f50b 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x6000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 4ff41161183b..b3bc4b4fe593 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x6000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 6eaebea82ddf..2799b69a5d2f 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x6000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index f225e9ea390b..4b7e825ce022 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x6000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x10000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index 8d412f8d6ae2..904f6cd03911 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -2,6 +2,7 @@ CONFIG_RISCV=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SIZE=0x20000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_agilex_defconfig index 60397a8ccea6..755541dc2266 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_agilex_defconfig @@ -6,6 +6,7 @@ CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x200 CONFIG_SYS_SPI_U_BOOT_OFFS=0x3c00000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SOCFPGA_AGILEX_SOCDK=y CONFIG_IDENT_STRING="socfpga_agilex" diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 35ae18fac003..5d1b7657723d 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SOCFPGA=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_TARGET_SOCFPGA_ARRIA10_SOCDK=y CONFIG_IDENT_STRING="socfpga_arria10" diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index ce230110e453..2ff9e8bc81cc 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 1633ca1deb57..0ef320ce6ee0 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index 3e1a06d94248..960d80dbca91 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_DEVBOARDS_DBM_SOC1=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_FIT=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index dafb5e83d09a..3fc0b04269be 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 64ee602b742f..18d914e15b13 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_TERASIC_DE10_NANO=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 095fc84c4b1e..8301bc3987f3 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SOCFPGA=y CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_TERASIC_DE1_SOC=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index a60df9b5d985..1128826dbc4d 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -5,6 +5,7 @@ CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SYS_BOOTCOUNT_ADDR=0xfffffff8 CONFIG_TARGET_SOCFPGA_IS1=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 157efea52209..979d76fda87b 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_ARIES_MCVEVK=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 247f3abda1c8..d814fd7baa76 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index a9ec97f2f4bb..f8dfec613f25 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -4,6 +4,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x4400 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_EBV_SOCRATES=y CONFIG_SPL_TEXT_BASE=0xFFFF0000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index c95a7fc5e073..328100f70eba 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -5,6 +5,7 @@ CONFIG_ENV_OFFSET=0xE0000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SYS_BOOTCOUNT_ADDR=0xfffffff8 CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_ENV_OFFSET_REDUND=0xF0000 diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 16ae0feb6807..96112062340a 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -6,6 +6,7 @@ CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x200 CONFIG_SYS_SPI_U_BOOT_OFFS=0x3C00000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SOCFPGA_STRATIX10_SOCDK=y CONFIG_IDENT_STRING="socfpga_stratix10" diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 61b569eb3cf6..37190ba04580 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -5,6 +5,7 @@ CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_TARGET_SOCFPGA_SOFTING_VINING_FPGA=y CONFIG_ENV_OFFSET_REDUND=0x110000 CONFIG_SPL_TEXT_BASE=0xFFFF0000 diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index c7dd2926c944..668cd434f1e1 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_OFFSET=0x280000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL=y CONFIG_TARGET_ST_STM32MP15x=y diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index 610657267351..1ac07c5865b8 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_STM32MP=y CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL=y CONFIG_TARGET_DH_STM32MP1_PDK2=y diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index 249646c4494b..225d04497948 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_STM32MP=y CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_ENV_SIZE=0x4000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL=y CONFIG_TARGET_DH_STM32MP1_PDK2=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 16a804b879f0..953f7784be42 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ENV_OFFSET=0x100000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index 721ed3f8a6a0..f816788fe946 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_ENV_SIZE=0x8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index 56981bb73654..8c61ae694419 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_ENV_SIZE=0x8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 129c8f657dfd..c714374771e9 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_ENV_SIZE=0x8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 5da7440af287..4dbf10119dc9 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index fe60d10c991d..e0c6e7ab24f9 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 462dff8942e5..8fbf5ec46619 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_TEXT_BASE=0xFFFC0000 CONFIG_ENV_SIZE=0x190 CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_SPL_DM_SPI=y CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x0
On 6/10/20 10:16 PM, Tom Rini wrote: [...]
I don't think those de*_soc boards have a SPI NOR at all. And I'm also afraid that enabling this will make those boards overflow SPL size limits.
There is zero size change from this patch on any platform included in this patch.
Today each of the boards you mention enables CONFIG_SPL_SPI_SUPPORT, CONFIG_SPL_SPI_FLASH_SUPPORT and then CONFIG_SPL_SPI_FLASH_TINY.
That said, that means you aren't using SPL_DM_SPI for real, so I'll go take a look at what to change instead in the previous patch, thanks!
Nope, check your platforms again. Based on looking over socfpga_de1_soc/spl/u-boot-spl.map it's not discarding a bunch of the DM SPI stuff as we're in fact building it today, and using the few functions that spi-mem-nodm.c provides from spi-mem.c instead. So this is correct for what's happening today.
With Jagan's removal patches that I believe allow us to nuke drivers/spi/spi.c (and so the unconditional building of it) as it nukes the only platform that uses the only video driver that calls spi_set_wordlen() (spi_do_alloc_slave() is unused globally) we could then go ahead and do non-DM_SPI here, fully.
Are you _sure_ the board has a SPI NOR on it at all ? I doubt all of them do, so it seems some of those SPL DM SPI are copy-paste errors.
I'm only as sure as what the board maintainer enabled. As they're on CC and see the answer is "Oh, I don't even have flash!" then they should go and fix that. My point is that it's not changing any platform sizes and is being explicit about what is implicit today based on the build logic in use.
Dear Tom
From: Tom Rini trini@konsulko.com Sent: mercredi 10 juin 2020 22:17
For configs/stm32mp15*defconfig
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
Thanks
Patrick
Not knowing exactly which patches to apply to see the Makefile changes in question, I'm just doing a code review instead of the test.
[snip]
Acked-by: Adam Ford aford173@gmail.com #da850evm
The da850evm_defconfig is setup to boot from SPI Flash, so that board will need it. Thank you.
The da850evm_nand_defconfig is set to boot from NAND via the NAND controller and not SPI, so it's probably not necessary, but I don't think it hurts anything. I may go through later and remove the CONFIG_SPL_DM_SPI from the nand version later.
[snip]
Thank you, we'll need this.
If you do a V2 for some reason and don't want to add this here in the future, I wouldn't object. If not, I'll do some testing later with this removed.
[snip]
-- 2.17.1
[snip]
[snip]
This is similar to the socfpga case Marek pointed out. Today, the platforms are building with SPI support enabled and are implicitly getting SPL_DM_SPI enabled too http://patchwork.ozlabs.org/project/uboot/patch/20200610201634.8457-30-trini... is the Makefile patch but it's just dropping in to the DM or not-DM side based on SPL/TPL_DM and not just DM in main U-Boot.
[snip]
Tested-by: Adam Ford aford173@gmail.com #da850evm
[snip]
-- Tom
[snip]
[snip]
I just sent a separate patch removing SPI from SPL from the nand defconfig since the system is booting from NAND to free up some space. I don't know how that plays into this patch for the nand version. If you need to apply your patch first, I can always rebase mine and re-submit later.
adam
-- Tom
Hi Tom,
For the Avnet Ultrazed:
Reviewed-by: Luca Ceresoli luca@lucaceresoli.net
We need to ensure that in the cases where SPL / TPL do not use DM we do not try and build the core nor drivers that require DM.
Cc: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Tom Rini trini@konsulko.com --- drivers/spi/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 342776404a50..f05ab0f6c8c2 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -4,7 +4,7 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
# There are many options which enable SPI, so make this library available -ifdef CONFIG_DM_SPI +ifdef CONFIG_$(SPL_TPL_)DM_SPI obj-y += spi-uclass.o obj-$(CONFIG_SANDBOX) += spi-emul-uclass.o obj-$(CONFIG_SOFT_SPI) += soft_spi.o
This converts the following to Kconfig: CONFIG_CADENCE_QSPI
Signed-off-by: Tom Rini trini@konsulko.com --- configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + drivers/spi/Makefile | 2 +- include/configs/k2g_evm.h | 1 - 4 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index d16e8f48bd83..b137238b9046 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -71,6 +71,7 @@ CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index f089be4f563a..adedfddf4f50 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -62,6 +62,7 @@ CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index f05ab0f6c8c2..534e702b0c3b 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -6,6 +6,7 @@ # There are many options which enable SPI, so make this library available ifdef CONFIG_$(SPL_TPL_)DM_SPI obj-y += spi-uclass.o +obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_SANDBOX) += spi-emul-uclass.o obj-$(CONFIG_SOFT_SPI) += soft_spi.o obj-$(CONFIG_SPI_MEM) += spi-mem.o @@ -23,7 +24,6 @@ obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o obj-$(CONFIG_BCM63XX_HSSPI) += bcm63xx_hsspi.o obj-$(CONFIG_BCM63XX_SPI) += bcm63xx_spi.o obj-$(CONFIG_BCMSTB_SPI) += bcmstb_spi.o -obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CF_SPI) += cf_spi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 25f3959533c6..83466b9e0cfa 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -82,7 +82,6 @@ #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */
#ifndef CONFIG_SPL_BUILD -#define CONFIG_CADENCE_QSPI #define CONFIG_CQSPI_REF_CLK 384000000 #endif
participants (9)
Adam Ford
Holger Brunck
Igor Opaniuk
Luca Ceresoli
Patrick DELAUNAY
Vladimir Oltean
Ye Li
