[U-Boot] [PATCH] ARM: socfpga: Put stack at the end of SRAM
The global data are in the .data section, so there's no point in reserving any space for it above stack. Put stack at the end of SRAM.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org --- include/configs/socfpga_common.h | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 4de2aa7929..cb67d539b1 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -35,10 +35,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 #define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ #endif -#define CONFIG_SYS_INIT_SP_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE)
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE)
I think this interferes with the bootcount being stored at the end of SRAM. See the defconfigs of 'is1' and 'sr1500' boards - or my local defconfig here :-)
I'd really like to keep some room here for bootcounter and some related things I store here.
Simon
So if I understand it correctly, before this patch, the boards overwrote the global data ?
Anyway, if you need some extra space, look at board_init_f_alloc_reserve() .
Ehrm, reading up on the init code path in the S and C files, it seems like that, yes. I just used the two boards as an example. Are they actively maintained? get_maintainer.pl shows the boards are maintained by denx, so maybe you could clarify this?
Chances are high that these bytes just fit into the 16-byte alignment allocated by GENERATED_GBL_DATA_SIZE (and on my board it *is* like that).
OK, but that function does not seem to be overridable? How can I reserve my own memory here?
And reading this function, I guess your commit message is a bit misleading. It seems that the purpose of CONFIG_SYS_INIT_SP_OFFSET like it was was to reserve memory for the initial gd (before relocation), which is now done in board_init_f_alloc_reserve().
Simon
+CC Stefan.
Add a __weak there I guess ?
The code is confusing as hell, I give you that.
+CC Stefan.
Thanks. At the time I added the bootcounter support on this platform, it used to work. I might have missed something though. Right now, I don't have access to such a platform, so its hard for me to test something. If you have some patches to fix any potential overlapping memory usages, I'll gladly review them.
Thanks, Stefan
+CC Stefan.
I just checked out ae996c80 and from what I can tell, the RAM layout was the same at that time: include/generated/generated-asm-offsets.h contains: - #define GENERATED_GBL_DATA_SIZE 208 - #define GD_SIZE 200
That leaves us with an 8 byte alignment gap at the end of the SRAM and that's where the boot counter is located. So the global data is not overwritten, but this is more or less by chance, any change to the struct definition might change this.
Looking at just another example: the x600 board defines its SRAM_SIZE 8 bytes smaller than what it really is. That seems like a good idea for socfpga, too. I'll see if I can provide a patch.
Slightly off-topic: I have a constellation where the boot-counter is not reset although the power has been pulled. This device has big capacitors and the SRAM content seems to survive although the processor is reset. To me it seems as if looking at the boot reason might be safer than checking for a magic word... Any ideas?
Thanks, Simon
Thanks, Stefan
On 12.05.2018 22:27, Marek Vasut wrote: > The global data are in the .data section, so there's no point in > reserving any space for it above stack. Put stack at the end of > SRAM. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Chin Liang See chin.liang.see@intel.com > Cc: Dinh Nguyen dinguyen@kernel.org > --- > include/configs/socfpga_common.h | 4 +--- > 1 file changed, 1 insertion(+), 3 deletions(-) > > diff --git a/include/configs/socfpga_common.h > b/include/configs/socfpga_common.h > index 4de2aa7929..cb67d539b1 100644 > --- a/include/configs/socfpga_common.h > +++ b/include/configs/socfpga_common.h > @@ -35,10 +35,8 @@ > #define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 > #define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ > #endif > -#define CONFIG_SYS_INIT_SP_OFFSET \ > - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) > #define CONFIG_SYS_INIT_SP_ADDR \ > - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) > + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE)
Anyway, after reading up on this in the code and the resulting binaries, I do think this patch is correct, so:
Reviewed-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com
Sorry for the confusion, but this really helped to clarify my understanding of the initial memory allocation ;-)
Thanks, Simon
+CC Stefan.
Thanks, Simon
Thanks, Stefan
+CC Stefan.
This looks like a hack and a bogus one. Lying about RAM size is never a good idea.
What boot reason options do you get ?
On 05/14/2018 10:03 AM, Simon Goldschmidt wrote: > On 12.05.2018 22:27, Marek Vasut wrote: >> The global data are in the .data section, so there's no point in >> reserving any space for it above stack. Put stack at the end of >> SRAM. >> >> Signed-off-by: Marek Vasut marex@denx.de >> Cc: Chin Liang See chin.liang.see@intel.com >> Cc: Dinh Nguyen dinguyen@kernel.org >> --- >> include/configs/socfpga_common.h | 4 +--- >> 1 file changed, 1 insertion(+), 3 deletions(-) >> >> diff --git a/include/configs/socfpga_common.h >> b/include/configs/socfpga_common.h >> index 4de2aa7929..cb67d539b1 100644 >> --- a/include/configs/socfpga_common.h >> +++ b/include/configs/socfpga_common.h >> @@ -35,10 +35,8 @@ >> #define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 >> #define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ >> #endif >> -#define CONFIG_SYS_INIT_SP_OFFSET \ >> - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) >> #define CONFIG_SYS_INIT_SP_ADDR \ >> - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) >> + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) > > I think this interferes with the bootcount being stored at the end of > SRAM. See the defconfigs of 'is1' and 'sr1500' boards - or my local > defconfig here :-) > > I'd really like to keep some room here for bootcounter and some > related > things I store here.
+CC Stefan.
The reset manager has a status register [1] that has various bits for different reasons of warm or cold reset. I'm just not sure if it's worth going through the hassle or if I'm alone with that problem of the bootcounter surviving a pull-and-replug.
[1] https://www.altera.com/hps/cyclone-v/topic/sfo1410067763568.html
Simon
On 14.05.2018 10:17, Marek Vasut wrote: > On 05/14/2018 10:03 AM, Simon Goldschmidt wrote: >> On 12.05.2018 22:27, Marek Vasut wrote: >>> The global data are in the .data section, so there's no point in >>> reserving any space for it above stack. Put stack at the end of >>> SRAM. >>> >>> Signed-off-by: Marek Vasut marex@denx.de >>> Cc: Chin Liang See chin.liang.see@intel.com >>> Cc: Dinh Nguyen dinguyen@kernel.org >>> --- >>> include/configs/socfpga_common.h | 4 +--- >>> 1 file changed, 1 insertion(+), 3 deletions(-) >>> >>> diff --git a/include/configs/socfpga_common.h >>> b/include/configs/socfpga_common.h >>> index 4de2aa7929..cb67d539b1 100644 >>> --- a/include/configs/socfpga_common.h >>> +++ b/include/configs/socfpga_common.h >>> @@ -35,10 +35,8 @@ >>> #define CONFIG_SYS_INIT_RAM_ADDR 0xFFE00000 >>> #define CONFIG_SYS_INIT_RAM_SIZE 0x40000 /* 256KB */ >>> #endif >>> -#define CONFIG_SYS_INIT_SP_OFFSET \ >>> - (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) >>> #define CONFIG_SYS_INIT_SP_ADDR \ >>> - (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) >>> + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) >> >> I think this interferes with the bootcount being stored at the >> end of >> SRAM. See the defconfigs of 'is1' and 'sr1500' boards - or my local >> defconfig here :-) >> >> I'd really like to keep some room here for bootcounter and some >> related >> things I store here. > > So if I understand it correctly, before this patch, the boards > overwrote > the global data ?
+CC Stefan.
Do you get warm or cold reset indication during plug-and-replug ?
Simon Goldschmidt
Stefan Roese
