[U-Boot] [PATCH 01/10] Use common function to set GPIOs for MX3 and MX5
The patch adds support for setting gpios to the MX51 processor and change name to the corresponding functions for MX31. In this way, it is possible to get rid of nasty #ifdef switches related to the processor type.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx31/mx31-regs.h | 14 +++- arch/arm/include/asm/arch-mx31/mx31.h | 25 ------- arch/arm/include/asm/arch-mx51/imx-regs.h | 6 ++ board/davedenx/qong/qong.c | 29 ++++---- drivers/gpio/Makefile | 2 +- drivers/gpio/mx31_gpio.c | 88 ----------------------- drivers/gpio/mxc_gpio.c | 107 ++++++++++++++++++++++++++++ drivers/spi/mxc_spi.c | 15 ++-- include/configs/imx31_phycore.h | 2 +- include/configs/qong.h | 2 +- include/mxc_gpio.h | 52 +++++++++++++ 11 files changed, 201 insertions(+), 141 deletions(-) delete mode 100644 drivers/gpio/mx31_gpio.c create mode 100644 drivers/gpio/mxc_gpio.c create mode 100644 include/mxc_gpio.h
diff --git a/arch/arm/include/asm/arch-mx31/mx31-regs.h b/arch/arm/include/asm/arch-mx31/mx31-regs.h index d72585c..f05e743 100644 --- a/arch/arm/include/asm/arch-mx31/mx31-regs.h +++ b/arch/arm/include/asm/arch-mx31/mx31-regs.h @@ -57,6 +57,14 @@ struct clock_control_regs { u32 pdr2; };
+/* GPIO Registers */ +struct gpio_regs { + u32 gpio_dr; + u32 gpio_dir; + u32 gpio_psr; +}; + + /* Bit definitions for RCSR register in CCM */ #define CCM_RCSR_NF16B (1 << 31) #define CCM_RCSR_NFMS (1 << 30) @@ -153,9 +161,9 @@ struct clock_control_regs { /* * GPIO */ -#define GPIO1_BASE 0x53FCC000 -#define GPIO2_BASE 0x53FD0000 -#define GPIO3_BASE 0x53FA4000 +#define GPIO1_BASE_ADDR 0x53FCC000 +#define GPIO2_BASE_ADDR 0x53FD0000 +#define GPIO3_BASE_ADDR 0x53FA4000 #define GPIO_DR 0x00000000 /* data register */ #define GPIO_GDIR 0x00000004 /* direction register */ #define GPIO_PSR 0x00000008 /* pad status register */ diff --git a/arch/arm/include/asm/arch-mx31/mx31.h b/arch/arm/include/asm/arch-mx31/mx31.h index f702d26..5a5aa11 100644 --- a/arch/arm/include/asm/arch-mx31/mx31.h +++ b/arch/arm/include/asm/arch-mx31/mx31.h @@ -28,31 +28,6 @@ extern u32 mx31_get_ipg_clk(void); #define imx_get_uartclk mx31_get_ipg_clk extern void mx31_gpio_mux(unsigned long mode);
-enum mx31_gpio_direction { - MX31_GPIO_DIRECTION_IN, - MX31_GPIO_DIRECTION_OUT, -}; - -#ifdef CONFIG_MX31_GPIO -extern int mx31_gpio_direction(unsigned int gpio, - enum mx31_gpio_direction direction); -extern void mx31_gpio_set(unsigned int gpio, unsigned int value); -extern int mx31_gpio_get(unsigned int gpio); -#else -static inline int mx31_gpio_direction(unsigned int gpio, - enum mx31_gpio_direction direction) -{ - return 1; -} -static inline int mx31_gpio_get(unsigned int gpio) -{ - return 1; -} -static inline void mx31_gpio_set(unsigned int gpio, unsigned int value) -{ -} -#endif - void mx31_uart1_hw_init(void); void mx31_spi2_hw_init(void);
diff --git a/arch/arm/include/asm/arch-mx51/imx-regs.h b/arch/arm/include/asm/arch-mx51/imx-regs.h index 3887d3c..0e3bc2a 100644 --- a/arch/arm/include/asm/arch-mx51/imx-regs.h +++ b/arch/arm/include/asm/arch-mx51/imx-regs.h @@ -256,6 +256,12 @@ struct weim { u32 cswcr2; };
+/* GPIO Registers */ +struct gpio_regs { + u32 gpio_dr; + u32 gpio_dir; + u32 gpio_psr; +}; #endif /* __ASSEMBLER__*/
#endif /* __ASM_ARCH_MXC_MX51_H__ */ diff --git a/board/davedenx/qong/qong.c b/board/davedenx/qong/qong.c index e509383..9abc29c 100644 --- a/board/davedenx/qong/qong.c +++ b/board/davedenx/qong/qong.c @@ -27,6 +27,7 @@ #include <asm/arch/mx31-regs.h> #include <nand.h> #include <fsl_pmic.h> +#include <mxc_gpio.h> #include "qong_fpga.h"
DECLARE_GLOBAL_DATA_PTR; @@ -41,9 +42,9 @@ int dram_init (void)
static void qong_fpga_reset(void) { - mx31_gpio_set(QONG_FPGA_RST_PIN, 0); + mxc_gpio_set(QONG_FPGA_RST_PIN, 0); udelay(30); - mx31_gpio_set(QONG_FPGA_RST_PIN, 1); + mxc_gpio_set(QONG_FPGA_RST_PIN, 1);
udelay(300); } @@ -66,11 +67,11 @@ int board_early_init_f (void)
/* FPGA reset Pin */ /* rstn = 0 */ - mx31_gpio_set(QONG_FPGA_RST_PIN, 0); - mx31_gpio_direction(QONG_FPGA_RST_PIN, MX31_GPIO_DIRECTION_OUT); + mxc_gpio_set(QONG_FPGA_RST_PIN, 0); + mxc_gpio_direction(QONG_FPGA_RST_PIN, MXC_GPIO_DIRECTION_OUT);
/* set interrupt pin as input */ - mx31_gpio_direction(QONG_FPGA_IRQ_PIN, MX31_GPIO_DIRECTION_IN); + mxc_gpio_direction(QONG_FPGA_IRQ_PIN, MXC_GPIO_DIRECTION_IN);
#endif
@@ -206,27 +207,27 @@ static void board_nand_setup(void) qong_fpga_reset();
/* Enable NAND flash */ - mx31_gpio_set(15, 1); - mx31_gpio_set(14, 1); - mx31_gpio_direction(15, MX31_GPIO_DIRECTION_OUT); - mx31_gpio_direction(16, MX31_GPIO_DIRECTION_IN); - mx31_gpio_direction(14, MX31_GPIO_DIRECTION_IN); - mx31_gpio_set(15, 0); + mxc_gpio_set(15, 1); + mxc_gpio_set(14, 1); + mxc_gpio_direction(15, MXC_GPIO_DIRECTION_OUT); + mxc_gpio_direction(16, MXC_GPIO_DIRECTION_IN); + mxc_gpio_direction(14, MXC_GPIO_DIRECTION_IN); + mxc_gpio_set(15, 0);
int qong_nand_rdy(void *chip) { udelay(1); - return mx31_gpio_get(16); + return mxc_gpio_get(16); }
void qong_nand_select_chip(struct mtd_info *mtd, int chip) { if (chip >= 0) - mx31_gpio_set(15, 0); + mxc_gpio_set(15, 0); else - mx31_gpio_set(15, 1); + mxc_gpio_set(15, 1);
diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 07d395d..a0f4552 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -27,7 +27,7 @@ LIB := $(obj)libgpio.a
COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o -COBJS-$(CONFIG_MX31_GPIO) += mx31_gpio.o +COBJS-$(CONFIG_MXC_GPIO) += mxc_gpio.o COBJS-$(CONFIG_PCA953X) += pca953x.o COBJS-$(CONFIG_S5P) += s5p_gpio.o
diff --git a/drivers/gpio/mx31_gpio.c b/drivers/gpio/mx31_gpio.c deleted file mode 100644 index b07f038..0000000 --- a/drivers/gpio/mx31_gpio.c +++ /dev/null @@ -1,88 +0,0 @@ -/* - * Copyright (C) 2009 - * Guennadi Liakhovetski, DENX Software Engineering, lg@denx.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <asm/arch/mx31.h> -#include <asm/arch/mx31-regs.h> - -/* GPIO port description */ -static unsigned long gpio_ports[] = { - [0] = GPIO1_BASE, - [1] = GPIO2_BASE, - [2] = GPIO3_BASE, -}; - -int mx31_gpio_direction(unsigned int gpio, enum mx31_gpio_direction direction) -{ - unsigned int port = gpio >> 5; - u32 l; - - if (port >= ARRAY_SIZE(gpio_ports)) - return 1; - - gpio &= 0x1f; - - l = __REG(gpio_ports[port] + GPIO_GDIR); - switch (direction) { - case MX31_GPIO_DIRECTION_OUT: - l |= 1 << gpio; - break; - case MX31_GPIO_DIRECTION_IN: - l &= ~(1 << gpio); - } - __REG(gpio_ports[port] + GPIO_GDIR) = l; - - return 0; -} - -void mx31_gpio_set(unsigned int gpio, unsigned int value) -{ - unsigned int port = gpio >> 5; - u32 l; - - if (port >= ARRAY_SIZE(gpio_ports)) - return; - - gpio &= 0x1f; - - l = __REG(gpio_ports[port] + GPIO_DR); - if (value) - l |= 1 << gpio; - else - l &= ~(1 << gpio); - __REG(gpio_ports[port] + GPIO_DR) = l; -} - -int mx31_gpio_get(unsigned int gpio) -{ - unsigned int port = gpio >> 5; - u32 l; - - if (port >= ARRAY_SIZE(gpio_ports)) - return -1; - - gpio &= 0x1f; - - l = (__REG(gpio_ports[port] + GPIO_DR) >> gpio) & 0x01; - - return l; -} diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c new file mode 100644 index 0000000..663141f --- /dev/null +++ b/drivers/gpio/mxc_gpio.c @@ -0,0 +1,107 @@ +/* + * Copyright (C) 2009 + * Guennadi Liakhovetski, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#ifdef CONFIG_MX31 +#include <asm/arch/mx31-regs.h> +#endif +#ifdef CONFIG_MX51 +#include <asm/arch/imx-regs.h> +#endif +#include <asm/io.h> +#include <mxc_gpio.h> + +/* GPIO port description */ +static unsigned long gpio_ports[] = { + [0] = GPIO1_BASE_ADDR, + [1] = GPIO2_BASE_ADDR, + [2] = GPIO3_BASE_ADDR, +#ifdef CONFIG_MX51 + [3] = GPIO4_BASE_ADDR, +#endif +}; + +int mxc_gpio_direction(unsigned int gpio, enum mxc_gpio_direction direction) +{ + unsigned int port = gpio >> 5; + struct gpio_regs *regs; + u32 l; + + if (port >= ARRAY_SIZE(gpio_ports)) + return 1; + + gpio &= 0x1f; + + regs = (struct gpio_regs *)gpio_ports[port]; + + l = readl(®s->gpio_dir); + + switch (direction) { + case MXC_GPIO_DIRECTION_OUT: + l |= 1 << gpio; + break; + case MXC_GPIO_DIRECTION_IN: + l &= ~(1 << gpio); + } + writel(l, ®s->gpio_dir); + + return 0; +} + +void mxc_gpio_set(unsigned int gpio, unsigned int value) +{ + unsigned int port = gpio >> 5; + struct gpio_regs *regs; + u32 l; + + if (port >= ARRAY_SIZE(gpio_ports)) + return; + + gpio &= 0x1f; + + regs = (struct gpio_regs *)gpio_ports[port]; + + l = readl(®s->gpio_dr); + if (value) + l |= 1 << gpio; + else + l &= ~(1 << gpio); + writel(l, ®s->gpio_dr); +} + +int mxc_gpio_get(unsigned int gpio) +{ + unsigned int port = gpio >> 5; + struct gpio_regs *regs; + u32 l; + + if (port >= ARRAY_SIZE(gpio_ports)) + return -1; + + gpio &= 0x1f; + + regs = (struct gpio_regs *)gpio_ports[port]; + + l = (readl(®s->gpio_dr) >> gpio) & 0x01; + + return l; +} diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index e15a63c..802cd2e 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -23,6 +23,7 @@ #include <spi.h> #include <asm/errno.h> #include <asm/io.h> +#include <mxc_gpio.h>
#ifdef CONFIG_MX27 /* i.MX27 has a completely wrong register layout and register definitions in the @@ -68,9 +69,6 @@ static unsigned long spi_bases[] = { 0x53f84000, };
-#define OUT MX31_GPIO_DIRECTION_OUT -#define mxc_gpio_direction mx31_gpio_direction -#define mxc_gpio_set mx31_gpio_set #elif defined(CONFIG_MX51) #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> @@ -111,13 +109,12 @@ static unsigned long spi_bases[] = { CSPI2_BASE_ADDR, CSPI3_BASE_ADDR, }; -#define mxc_gpio_direction(gpio, dir) (0) -#define mxc_gpio_set(gpio, value) {} -#define OUT 1 #else #error "Unsupported architecture" #endif
+#define OUT MXC_GPIO_DIRECTION_OUT + struct mxc_spi_slave { struct spi_slave slave; unsigned long base; @@ -126,6 +123,7 @@ struct mxc_spi_slave { u32 cfg_reg; #endif int gpio; + int ss_pol; };
static inline struct mxc_spi_slave *to_mxc_spi_slave(struct spi_slave *slave) @@ -147,7 +145,7 @@ void spi_cs_activate(struct spi_slave *slave) { struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); if (mxcs->gpio > 0) - mxc_gpio_set(mxcs->gpio, mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL); + mxc_gpio_set(mxcs->gpio, mxcs->ss_pol); }
void spi_cs_deactivate(struct spi_slave *slave) @@ -155,7 +153,7 @@ void spi_cs_deactivate(struct spi_slave *slave) struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); if (mxcs->gpio > 0) mxc_gpio_set(mxcs->gpio, - !(mxcs->ctrl_reg & MXC_CSPICTRL_SSPOL)); + !(mxcs->ss_pol)); }
#ifdef CONFIG_MX51 @@ -394,6 +392,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, mxcs->slave.bus = bus; mxcs->slave.cs = cs; mxcs->base = spi_bases[bus]; + mxcs->ss_pol = (mode & SPI_CS_HIGH) ? 1 : 0;
#ifdef CONFIG_MX51 /* Can be used for i.MX31 too ? */ diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 1dbafa0..62944a9 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -183,7 +183,7 @@ #ifdef CONFIG_IMX31_PHYCORE_EET #define BOARD_LATE_INIT
-#define CONFIG_MX31_GPIO 1 +#define CONFIG_MXC_GPIO
#define CONFIG_HARD_SPI 1 #define CONFIG_MXC_SPI 1 diff --git a/include/configs/qong.h b/include/configs/qong.h index 7a68b7b..7cd9558 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -52,7 +52,7 @@ #define CONFIG_MXC_UART 1 #define CONFIG_SYS_MX31_UART1 1
-#define CONFIG_MX31_GPIO +#define CONFIG_MXC_GPIO
#define CONFIG_MXC_SPI #define CONFIG_DEFAULT_SPI_BUS 1 diff --git a/include/mxc_gpio.h b/include/mxc_gpio.h new file mode 100644 index 0000000..002ba61 --- /dev/null +++ b/include/mxc_gpio.h @@ -0,0 +1,52 @@ +/* + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MXC_GPIO_H +#define __MXC_GPIO_H + +enum mxc_gpio_direction { + MXC_GPIO_DIRECTION_IN, + MXC_GPIO_DIRECTION_OUT, +}; + +#ifdef CONFIG_MXC_GPIO +extern int mxc_gpio_direction(unsigned int gpio, + enum mxc_gpio_direction direction); +extern void mxc_gpio_set(unsigned int gpio, unsigned int value); +extern int mxc_gpio_get(unsigned int gpio); +#else +static inline int mxc_gpio_direction(unsigned int gpio, + enum mxc_gpio_direction direction) +{ + return 1; +} +static inline int mxc_gpio_get(unsigned int gpio) +{ + return 1; +} +static inline void mxc_gpio_set(unsigned int gpio, unsigned int value) +{ +} +#endif + +#endif
The OMAP3 cpu directory contains a syslib file with some utilities that can be shared by all targets using arm cortexa8 processors, not only OMAP.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/Makefile | 3 +- arch/arm/cpu/armv7/omap-common/Makefile | 1 - arch/arm/cpu/armv7/omap-common/syslib.c | 70 ---------------------------- arch/arm/cpu/armv7/syslib.c | 70 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx51/sys_proto.h | 1 + 5 files changed, 73 insertions(+), 72 deletions(-) delete mode 100644 arch/arm/cpu/armv7/omap-common/syslib.c create mode 100644 arch/arm/cpu/armv7/syslib.c
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index ae20299..7743fef 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -27,6 +27,7 @@ LIB = $(obj)lib$(CPU).a
START := start.o COBJS := cpu.o +COBJS += syslib.o
SRCS := $(START:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) @@ -44,4 +45,4 @@ include $(SRCTREE)/rules.mk
sinclude $(obj).depend
-######################################################################### \ No newline at end of file +######################################################################### diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index caee726..aedea7b 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -28,7 +28,6 @@ LIB = $(obj)libomap-common.a SOBJS := reset.o
COBJS := timer.o -COBJS += syslib.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/armv7/omap-common/syslib.c b/arch/arm/cpu/armv7/omap-common/syslib.c deleted file mode 100644 index f9ed9a3..0000000 --- a/arch/arm/cpu/armv7/omap-common/syslib.c +++ /dev/null @@ -1,70 +0,0 @@ -/* - * (C) Copyright 2008 - * Texas Instruments, <www.ti.com> - * - * Richard Woodruff r-woodruff2@ti.com - * Syed Mohammed Khasim khasim@ti.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/sys_proto.h> - -/************************************************************ - * sdelay() - simple spin loop. Will be constant time as - * its generally used in bypass conditions only. This - * is necessary until timers are accessible. - * - * not inline to increase chances its in cache when called - *************************************************************/ -void sdelay(unsigned long loops) -{ - __asm__ volatile ("1:\n" "subs %0, %1, #1\n" - "bne 1b":"=r" (loops):"0"(loops)); -} - -/***************************************************************** - * sr32 - clear & set a value in a bit range for a 32 bit address - *****************************************************************/ -void sr32(void *addr, u32 start_bit, u32 num_bits, u32 value) -{ - u32 tmp, msk = 0; - msk = 1 << num_bits; - --msk; - tmp = readl((u32)addr) & ~(msk << start_bit); - tmp |= value << start_bit; - writel(tmp, (u32)addr); -} - -/********************************************************************* - * wait_on_value() - common routine to allow waiting for changes in - * volatile regs. - *********************************************************************/ -u32 wait_on_value(u32 read_bit_mask, u32 match_value, void *read_addr, - u32 bound) -{ - u32 i = 0, val; - do { - ++i; - val = readl((u32)read_addr) & read_bit_mask; - if (val == match_value) - return 1; - if (i == bound) - return 0; - } while (1); -} diff --git a/arch/arm/cpu/armv7/syslib.c b/arch/arm/cpu/armv7/syslib.c new file mode 100644 index 0000000..f9ed9a3 --- /dev/null +++ b/arch/arm/cpu/armv7/syslib.c @@ -0,0 +1,70 @@ +/* + * (C) Copyright 2008 + * Texas Instruments, <www.ti.com> + * + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> + +/************************************************************ + * sdelay() - simple spin loop. Will be constant time as + * its generally used in bypass conditions only. This + * is necessary until timers are accessible. + * + * not inline to increase chances its in cache when called + *************************************************************/ +void sdelay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + +/***************************************************************** + * sr32 - clear & set a value in a bit range for a 32 bit address + *****************************************************************/ +void sr32(void *addr, u32 start_bit, u32 num_bits, u32 value) +{ + u32 tmp, msk = 0; + msk = 1 << num_bits; + --msk; + tmp = readl((u32)addr) & ~(msk << start_bit); + tmp |= value << start_bit; + writel(tmp, (u32)addr); +} + +/********************************************************************* + * wait_on_value() - common routine to allow waiting for changes in + * volatile regs. + *********************************************************************/ +u32 wait_on_value(u32 read_bit_mask, u32 match_value, void *read_addr, + u32 bound) +{ + u32 i = 0, val; + do { + ++i; + val = readl((u32)read_addr) & read_bit_mask; + if (val == match_value) + return 1; + if (i == bound) + return 0; + } while (1); +} diff --git a/arch/arm/include/asm/arch-mx51/sys_proto.h b/arch/arm/include/asm/arch-mx51/sys_proto.h index bf500a8..f687503 100644 --- a/arch/arm/include/asm/arch-mx51/sys_proto.h +++ b/arch/arm/include/asm/arch-mx51/sys_proto.h @@ -26,5 +26,6 @@
u32 get_cpu_rev(void); #define is_soc_rev(rev) ((get_cpu_rev() & 0xFF) - rev) +void sdelay(unsigned long);
#endif
Add pins definitions to set up RAM pads. Pins have only a pad, there is no entry in the multiplexer.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx51/mx51_pins.h | 44 ++++++++++++++++++++++++++++ 1 files changed, 44 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx51/mx51_pins.h b/arch/arm/include/asm/arch-mx51/mx51_pins.h index ca26f41..b44ff25 100644 --- a/arch/arm/include/asm/arch-mx51/mx51_pins.h +++ b/arch/arm/include/asm/arch-mx51/mx51_pins.h @@ -368,6 +368,50 @@ enum iomux_pins { MX51_PIN_GPIO1_7 = _MXC_BUILD_GPIO_PIN(0, 7, 0, 0x3E4, 0x810), MX51_PIN_GPIO1_8 = _MXC_BUILD_GPIO_PIN(0, 8, 0, 0x3E8, 0x814), MX51_PIN_GPIO1_9 = _MXC_BUILD_GPIO_PIN(0, 9, 0, 0x3EC, 0x818), + + /* The following are PADS used for drive strength */ + + MX51_PIN_CTL_GRP_DDRPKS = _MXC_BUILD_NON_GPIO_PIN(0, 0x820), + MX51_PIN_CTL_GRP_PKEDDR = _MXC_BUILD_NON_GPIO_PIN(0, 0x838), + MX51_PIN_CTL_GRP_PKEADDR = _MXC_BUILD_NON_GPIO_PIN(0, 0x890), + MX51_PIN_CTL_GRP_DDRAPKS = _MXC_BUILD_NON_GPIO_PIN(0, 0x87C), + MX51_PIN_CTL_GRP_DDRAPUS = _MXC_BUILD_NON_GPIO_PIN(0, 0x84C), + MX51_PIN_CTL_GRP_DDRPUS = _MXC_BUILD_NON_GPIO_PIN(0, 0x884), + MX51_PIN_CTL_GRP_HYSDDR0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x85C), + MX51_PIN_CTL_GRP_HYSDDR1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x864), + MX51_PIN_CTL_GRP_HYSDDR2 = _MXC_BUILD_NON_GPIO_PIN(0, 0x86C), + MX51_PIN_CTL_GRP_HYSDDR3 = _MXC_BUILD_NON_GPIO_PIN(0, 0x874), + MX51_PIN_CTL_GRP_DDR_SR_B0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x878), + MX51_PIN_CTL_GRP_DDR_SR_B1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x880), + MX51_PIN_CTL_GRP_DDR_SR_B2 = _MXC_BUILD_NON_GPIO_PIN(0, 0x88C), + MX51_PIN_CTL_GRP_DDR_SR_B4 = _MXC_BUILD_NON_GPIO_PIN(0, 0x89C), + MX51_PIN_CTL_GRP_DRAM_B0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8A4), + MX51_PIN_CTL_GRP_DRAM_B1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8AC), + MX51_PIN_CTL_GRP_DRAM_B2 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8B8), + MX51_PIN_CTL_GRP_DRAM_B4 = _MXC_BUILD_NON_GPIO_PIN(0, 0x82C), + MX51_PIN_CTL_GRP_INMODE1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8A0), + MX51_PIN_CTL_GRP_DDR_SR_A0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8B0), + MX51_PIN_CTL_GRP_EMI_DS5 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8B4), + MX51_PIN_CTL_GRP_DDR_SR_A1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x8BC), + MX51_PIN_CTL_GRP_DDR_A0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x83C), + MX51_PIN_CTL_GRP_DDR_A1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x848), + MX51_PIN_CTL_GRP_DISP_PKE0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x868), + MX51_PIN_CTL_DRAM_RAS = _MXC_BUILD_NON_GPIO_PIN(0, 0x4A4), + MX51_PIN_CTL_DRAM_CAS = _MXC_BUILD_NON_GPIO_PIN(0, 0x4A8), + MX51_PIN_CTL_DRAM_SDWE = _MXC_BUILD_NON_GPIO_PIN(0, 0x4Ac), + MX51_PIN_CTL_DRAM_SDCKE0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4B0), + MX51_PIN_CTL_DRAM_SDCKE1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4B4), + MX51_PIN_CTL_DRAM_SDCLK = _MXC_BUILD_NON_GPIO_PIN(0, 0x4B8), + MX51_PIN_CTL_DRAM_SDQS0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4BC), + MX51_PIN_CTL_DRAM_SDQS1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4C0), + MX51_PIN_CTL_DRAM_SDQS2 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4C4), + MX51_PIN_CTL_DRAM_SDQS3 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4C8), + MX51_PIN_CTL_DRAM_CS0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4CC), + MX51_PIN_CTL_DRAM_CS1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4D0), + MX51_PIN_CTL_DRAM_DQM0 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4D4), + MX51_PIN_CTL_DRAM_DQM1 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4D8), + MX51_PIN_CTL_DRAM_DQM2 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4DC), + MX51_PIN_CTL_DRAM_DQM3 = _MXC_BUILD_NON_GPIO_PIN(0, 0x4E0), };
#endif /* __ASSEMBLY__ */
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx51/imx-regs.h | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx51/imx-regs.h b/arch/arm/include/asm/arch-mx51/imx-regs.h index 0e3bc2a..072ad0f 100644 --- a/arch/arm/include/asm/arch-mx51/imx-regs.h +++ b/arch/arm/include/asm/arch-mx51/imx-regs.h @@ -262,6 +262,16 @@ struct gpio_regs { u32 gpio_dir; u32 gpio_psr; }; + +/* System Reset Controller (SRC) */ +struct src { + u32 scr; + u32 sbmr; + u32 srsr; + u32 reserved1[2]; + u32 sisr; + u32 simr; +}; #endif /* __ASSEMBLER__*/
Calls WATCHDOG_RESET() inside serial driver for boards enabling watchdog.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/serial/serial_mxc.c | 7 +++++-- 1 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index 4b93e7b..f96b21f 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -18,6 +18,7 @@ */
#include <common.h> +#include <watchdog.h> #ifdef CONFIG_MX31 #include <asm/arch/mx31.h> #else @@ -189,7 +190,8 @@ void serial_setbrg (void)
int serial_getc (void) { - while (__REG(UART_PHYS + UTS) & UTS_RXEMPTY); + while (__REG(UART_PHYS + UTS) & UTS_RXEMPTY) + WATCHDOG_RESET(); return (__REG(UART_PHYS + URXD) & URXD_RX_DATA); /* mask out status from upper word */ }
@@ -198,7 +200,8 @@ void serial_putc (const char c) __REG(UART_PHYS + UTXD) = c;
/* wait for transmitter to be ready */ - while(!(__REG(UART_PHYS + UTS) & UTS_TXEMPTY)); + while (!(__REG(UART_PHYS + UTS) & UTS_TXEMPTY)) + WATCHDOG_RESET();
/* If \n, also do \r */ if (c == '\n')
As stated in 272017853339f5b9685f9488bdaf5405812d12a4, the mx51evk has not CPLD and all references must be removed. This patch drop a .h file that still remains in board directory.
Signed-off-by: Stefano Babic sbabic@denx.de --- board/freescale/mx51evk/mx51evk.c | 2 - board/freescale/mx51evk/mx51evk.h | 50 ------------------------------------- 2 files changed, 0 insertions(+), 52 deletions(-) delete mode 100644 board/freescale/mx51evk/mx51evk.h
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 75d642b..84386e6 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -33,12 +33,10 @@ #include <fsl_esdhc.h> #include <fsl_pmic.h> #include <mc13892.h> -#include "mx51evk.h"
static u32 system_rev; -struct io_board_ctrl *mx51_io_board;
#ifdef CONFIG_FSL_ESDHC struct fsl_esdhc_cfg esdhc_cfg[2] = { diff --git a/board/freescale/mx51evk/mx51evk.h b/board/freescale/mx51evk/mx51evk.h deleted file mode 100644 index 2854e71..0000000 --- a/board/freescale/mx51evk/mx51evk.h +++ /dev/null @@ -1,50 +0,0 @@ -/* - * (C) Copyright 2009 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __BOARD_FREESCALE_MX51_EVK_H__ -#define __BOARD_FREESCALE_MX51_EVK_H__ - -#ifndef __ASSEMBLY__ -struct io_board_ctrl { - u16 led_ctrl; /* 0x00 */ - u16 resv1[0x03]; - u16 sb_stat; /* 0x08 */ - u16 resv2[0x03]; - u16 int_stat; /* 0x10 */ - u16 resv3[0x07]; - u16 int_rest; /* 0x20 */ - u16 resv4[0x0B]; - u16 int_mask; /* 0x38 */ - u16 resv5[0x03]; - u16 id1; /* 0x40 */ - u16 resv6[0x03]; - u16 id2; /* 0x48 */ - u16 resv7[0x03]; - u16 version; /* 0x50 */ - u16 resv8[0x03]; - u16 id3; /* 0x58 */ - u16 resv9[0x03]; - u16 sw_reset; /* 0x60 */ -}; -#endif - -#endif
The handling of the SPI_CPOL bit inside the SPI driver was wrong. As reported by the manual, the meaning of the SSPOL inside the configuration register is the same as reported by SPI specification (0 if low in idle, 1 is high on idle). The driver inverts this logic.
Because this patch sets the logic as specified, it is required to clear the CPOL bit in the configuration file to adapt to the correct logic.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: David Jander david.jander@protonic.nl --- drivers/spi/mxc_spi.c | 4 ++-- include/configs/imx31_litekit.h | 4 ++-- include/configs/mx31ads.h | 4 ++-- include/configs/mx31pdk.h | 4 ++-- include/configs/mx51evk.h | 2 +- include/configs/qong.h | 4 ++-- 6 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index 802cd2e..c6c8f60 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -215,7 +215,7 @@ static s32 spi_cfg(struct mxc_spi_slave *mxcs, unsigned int cs, if (mode & SPI_CS_HIGH) ss_pol = 1;
- if (!(mode & SPI_CPOL)) + if (mode & SPI_CPOL) sclkpol = 1;
if (mode & SPI_CPHA) @@ -412,7 +412,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs,
if (mode & SPI_CPHA) ctrl_reg |= MXC_CSPICTRL_PHA; - if (!(mode & SPI_CPOL)) + if (mode & SPI_CPOL) ctrl_reg |= MXC_CSPICTRL_POL; if (mode & SPI_CS_HIGH) ctrl_reg |= MXC_CSPICTRL_SSPOL; diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 4904856..88c62d1 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -66,13 +66,13 @@ #define CONFIG_HARD_SPI 1 #define CONFIG_MXC_SPI 1 #define CONFIG_DEFAULT_SPI_BUS 1 -#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
#define CONFIG_FSL_PMIC #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 1000000 -#define CONFIG_FSL_PMIC_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH)
#define CONFIG_RTC_MC13783 1
diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index dedecd7..57955df 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -63,13 +63,13 @@ #define CONFIG_HARD_SPI 1 #define CONFIG_MXC_SPI 1 #define CONFIG_DEFAULT_SPI_BUS 1 -#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
#define CONFIG_FSL_PMIC #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 1000000 -#define CONFIG_FSL_PMIC_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH) #define CONFIG_RTC_MC13783 1
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 0414cc3..4b4fb1a 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -67,13 +67,13 @@ #define CONFIG_HARD_SPI 1 #define CONFIG_MXC_SPI 1 #define CONFIG_DEFAULT_SPI_BUS 1 -#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
#define CONFIG_FSL_PMIC #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 2 #define CONFIG_FSL_PMIC_CLK 1000000 -#define CONFIG_FSL_PMIC_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH) #define CONFIG_RTC_MC13783 1
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 86a4731..8864f3a 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -73,7 +73,7 @@ #define CONFIG_FSL_PMIC_BUS 0 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 2500000 -#define CONFIG_FSL_PMIC_MODE (SPI_CPOL | SPI_CS_HIGH) +#define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH)
/* * MMC Configs diff --git a/include/configs/qong.h b/include/configs/qong.h index 7cd9558..cbb53dd 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -56,14 +56,14 @@
#define CONFIG_MXC_SPI #define CONFIG_DEFAULT_SPI_BUS 1 -#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) #define CONFIG_RTC_MC13783
#define CONFIG_FSL_PMIC #define CONFIG_FSL_PMIC_BUS 1 #define CONFIG_FSL_PMIC_CS 0 #define CONFIG_FSL_PMIC_CLK 100000 -#define CONFIG_FSL_PMIC_MODE (SPI_MODE_2 | SPI_CS_HIGH) +#define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH)
/* FPGA */ #define CONFIG_QONG_FPGA 1
The actual SPI driver for i.MX31 and i.MX51 controller use a wrong byte ordering, because it is supposed to work only with Freescale's devices, as the Power Controllers (PMIC). The driver is not suitable for general purposes, because the buffers passed to spi_xfer must be 32-bit aligned, as it is used mainly to send integer to PMIC devices.
The patch drops any kind of limitation and makes the driver useful with devices controlled sending commands composed by single bytes (or by a odd number of bytes), such as spi flash, sensor, etc.
Because the byte ordering is changed, any current driver using this controller must be adapted, too.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/misc/fsl_pmic.c | 10 ++- drivers/spi/mxc_spi.c | 149 +++++++++++++++++++++++++++++++++++------------ 2 files changed, 118 insertions(+), 41 deletions(-)
diff --git a/drivers/misc/fsl_pmic.c b/drivers/misc/fsl_pmic.c index dca0a1d..5ee1de1 100644 --- a/drivers/misc/fsl_pmic.c +++ b/drivers/misc/fsl_pmic.c @@ -46,6 +46,7 @@ void pmic_spi_free(struct spi_slave *slave) u32 pmic_reg(u32 reg, u32 val, u32 write) { u32 pmic_tx, pmic_rx; + u32 tmp;
if (!slave) { slave = pmic_spi_probe(); @@ -65,7 +66,9 @@ u32 pmic_reg(u32 reg, u32 val, u32 write)
pmic_tx = (write << 31) | (reg << 25) | (val & 0x00FFFFFF);
- if (spi_xfer(slave, 4 << 3, &pmic_tx, &pmic_rx, + tmp = cpu_to_be32(pmic_tx); + + if (spi_xfer(slave, 4 << 3, &tmp, &pmic_rx, SPI_XFER_BEGIN | SPI_XFER_END)) { spi_release_bus(slave); return -1; @@ -73,7 +76,8 @@ u32 pmic_reg(u32 reg, u32 val, u32 write)
if (write) { pmic_tx &= ~(1 << 31); - if (spi_xfer(slave, 4 << 3, &pmic_tx, &pmic_rx, + tmp = cpu_to_be32(pmic_tx); + if (spi_xfer(slave, 4 << 3, &tmp, &pmic_rx, SPI_XFER_BEGIN | SPI_XFER_END)) { spi_release_bus(slave); return -1; @@ -81,7 +85,7 @@ u32 pmic_reg(u32 reg, u32 val, u32 write) }
spi_release_bus(slave); - return pmic_rx; + return cpu_to_be32(pmic_rx); }
void pmic_reg_write(u32 reg, u32 value) diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index c6c8f60..d558137 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -62,6 +62,7 @@ #define MXC_CSPICTRL_MAXBITS 0x1f
#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 4
static unsigned long spi_bases[] = { 0x43fa4000, @@ -95,6 +96,7 @@ static unsigned long spi_bases[] = { #define MXC_CSPICTRL_RXOVF (1 << 6)
#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 32
/* Bit position inside CTRL register to be associated with SS */ #define MXC_CSPICTRL_CHAN 18 @@ -252,13 +254,15 @@ static s32 spi_cfg(struct mxc_spi_slave *mxcs, unsigned int cs, } #endif
-static u32 spi_xchg_single(struct spi_slave *slave, u32 data, int bitlen, - unsigned long flags) +int spi_xchg_single(struct spi_slave *slave, unsigned int bitlen, + const u8 *dout, u8 *din, unsigned long flags) { struct mxc_spi_slave *mxcs = to_mxc_spi_slave(slave); + int nbytes = (bitlen + 7) / 8; + u32 data, cnt, i;
- if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); + debug("%s: bitlen %d dout 0x%x din 0x%x\n", + __func__, bitlen, (u32)dout, (u32)din);
mxcs->ctrl_reg = (mxcs->ctrl_reg & ~MXC_CSPICTRL_BITCOUNT(MXC_CSPICTRL_MAXBITS)) | @@ -273,8 +277,46 @@ static u32 spi_xchg_single(struct spi_slave *slave, u32 data, int bitlen, reg_write(mxcs->base + MXC_CSPISTAT, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF);
- debug("Sending SPI 0x%x\n", data); - reg_write(mxcs->base + MXC_CSPITXDATA, data); + /* + * The SPI controller works only with words, + * check if less than a word is sent. + * Access to the FIFO is only 32 bit + */ + if (bitlen % 32) { + data = 0; + cnt = (bitlen % 32) / 8; + if (dout) { + for (i = 0; i < cnt; i++) { + data = (data << 8) | (*dout++ & 0xFF); + } + } + debug("Sending SPI 0x%x\n", data); + + reg_write(mxcs->base + MXC_CSPITXDATA, data); + nbytes -= cnt; + } + + data = 0; + + while (nbytes > 0) { + data = 0; + if (dout) { + /* Buffer is not 32-bit aligned */ + if ((unsigned long)dout & 0x03) { + data = 0; + for (i = 0; i < 4; i++, data <<= 8) { + data = (data << 8) | (*dout++ & 0xFF); + } + } else { + data = *(u32 *)dout; + data = cpu_to_be32(data); + } + dout += 4; + } + debug("Sending SPI 0x%x\n", data); + reg_write(mxcs->base + MXC_CSPITXDATA, data); + nbytes -= 4; + }
/* FIFO is written, now starts the transfer setting the XCH bit */ reg_write(mxcs->base + MXC_CSPICTRL, mxcs->ctrl_reg | @@ -288,49 +330,78 @@ static u32 spi_xchg_single(struct spi_slave *slave, u32 data, int bitlen, reg_write(mxcs->base + MXC_CSPISTAT, MXC_CSPICTRL_TC | MXC_CSPICTRL_RXOVF);
- data = reg_read(mxcs->base + MXC_CSPIRXDATA); - debug("SPI Rx: 0x%x\n", data); + nbytes = (bitlen + 7) / 8;
- if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); + cnt = nbytes % 32;
- return data; + if (bitlen % 32) { + data = reg_read(mxcs->base + MXC_CSPIRXDATA); + cnt = (bitlen % 32) / 8; + debug("SPI Rx unaligned: 0x%x\n", data); + if (din) { + for (i = 0; i < cnt; i++, data >>= 8) { + *din++ = data & 0xFF; + } + } + nbytes -= cnt; + } + + while (nbytes > 0) { + u32 tmp; + tmp = reg_read(mxcs->base + MXC_CSPIRXDATA); + data = cpu_to_be32(tmp); + debug("SPI Rx: 0x%x 0x%x\n", tmp, data); + cnt = min(nbytes, sizeof(data)); + if (din) { + memcpy(din, &data, cnt); + din += cnt; + } + nbytes -= cnt; + } + + return 0;
+ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { - int n_blks = (bitlen + 31) / 32; - u32 *out_l, *in_l; - int i; + int n_bytes = (bitlen + 7) / 8; + int n_bits; + int ret; + u32 blk_size; + u8 *p_outbuf = (u8 *)dout; + u8 *p_inbuf = (u8 *)din;
- if ((int)dout & 3 || (int)din & 3) { - printf("Error: unaligned buffers in: %p, out: %p\n", din, dout); - return 1; - } + if (!slave) + return -1;
- /* This driver is currently partly broken, alert the user */ - if (bitlen > 16 && (bitlen % 32)) { - printf("Error: SPI transfer with bitlen=%d is broken.\n", - bitlen); - return 1; + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + while (n_bytes > 0) { + + if (n_bytes < MAX_SPI_BYTES) + blk_size = n_bytes; + else + blk_size = MAX_SPI_BYTES; + + n_bits = blk_size * 8; + + ret = spi_xchg_single(slave, n_bits, p_outbuf, p_inbuf, 0); + + if (ret) + return ret; + if (dout) + p_outbuf += blk_size; + if (din) + p_inbuf += blk_size; + n_bytes -= blk_size; }
- for (i = 0, in_l = (u32 *)din, out_l = (u32 *)dout; - i < n_blks; - i++, in_l++, out_l++, bitlen -= 32) { - u32 data = spi_xchg_single(slave, *out_l, bitlen, flags); - - /* Check if we're only transfering 8 or 16 bits */ - if (!i) { - if (bitlen < 9) - *(u8 *)din = data; - else if (bitlen < 17) - *(u16 *)din = data; - else - *in_l = data; - } + if (flags & SPI_XFER_END) { + spi_cs_deactivate(slave); }
return 0; @@ -378,8 +449,10 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, return NULL;
mxcs = malloc(sizeof(struct mxc_spi_slave)); - if (!mxcs) + if (!mxcs) { + puts("mxc_spi: SPI Slave not allocated !\n"); return NULL; + }
ret = decode_cs(mxcs, cs); if (ret < 0) {
Due to wrong dependencies, it is not possible to include imx_regs.h inside the board configuration file.
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx51/imx-regs.h | 10 ++++++---- 1 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx51/imx-regs.h b/arch/arm/include/asm/arch-mx51/imx-regs.h index 072ad0f..3ddda40 100644 --- a/arch/arm/include/asm/arch-mx51/imx-regs.h +++ b/arch/arm/include/asm/arch-mx51/imx-regs.h @@ -23,9 +23,6 @@ #ifndef __ASM_ARCH_MXC_MX51_H__ #define __ASM_ARCH_MXC_MX51_H__
-#define __REG(x) (*((volatile u32 *)(x))) -#define __REG16(x) (*((volatile u16 *)(x))) -#define __REG8(x) (*((volatile u8 *)(x))) /* * IRAM */ @@ -207,7 +204,12 @@ #define BOARD_REV_1_0 0x0 #define BOARD_REV_2_0 0x1
-#ifndef __ASSEMBLY__ +#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +#include <asm/types.h> + +#define __REG(x) (*((volatile u32 *)(x))) +#define __REG16(x) (*((volatile u16 *)(x))) +#define __REG8(x) (*((volatile u8 *)(x)))
struct clkctl { u32 ccr;
The patch adds support for TTECH vision2 board. The board has 512MB RAM, SDHC slot and 4MB SPI device from StMicron.
Signed-off-by: Stefano Babic sbabic@denx.de --- MAINTAINERS | 1 + board/ttcontrol/vision2/Makefile | 48 ++ board/ttcontrol/vision2/config.mk | 25 + board/ttcontrol/vision2/imximage_hynix.cfg | 209 ++++++++ board/ttcontrol/vision2/vision2.c | 712 ++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/vision2.h | 214 +++++++++ include/mc13892.h | 3 + 8 files changed, 1213 insertions(+), 0 deletions(-) create mode 100644 board/ttcontrol/vision2/Makefile create mode 100644 board/ttcontrol/vision2/config.mk create mode 100644 board/ttcontrol/vision2/imximage_hynix.cfg create mode 100644 board/ttcontrol/vision2/vision2.c create mode 100644 include/configs/vision2.h
diff --git a/MAINTAINERS b/MAINTAINERS index 2cf29dd..b348559 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -547,6 +547,7 @@ Stefano Babic sbabic@denx.de polaris xscale trizepsiv xscale mx51evk i.MX51 + vision2 i.MX51
Dirk Behme dirk.behme@gmail.com
diff --git a/board/ttcontrol/vision2/Makefile b/board/ttcontrol/vision2/Makefile new file mode 100644 index 0000000..309e3a3 --- /dev/null +++ b/board/ttcontrol/vision2/Makefile @@ -0,0 +1,48 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2009 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := vision2.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/ttcontrol/vision2/config.mk b/board/ttcontrol/vision2/config.mk new file mode 100644 index 0000000..59f3367 --- /dev/null +++ b/board/ttcontrol/vision2/config.mk @@ -0,0 +1,25 @@ +# +# Copyright 2009 Freescale Semiconductor, Inc. All Rights Reserved. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +LDSCRIPT = $(CPUDIR)/$(SOC)/u-boot.lds +TEXT_BASE = 0x97800000 +IMX_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/imximage_hynix.cfg diff --git a/board/ttcontrol/vision2/imximage_hynix.cfg b/board/ttcontrol/vision2/imximage_hynix.cfg new file mode 100644 index 0000000..ed531db --- /dev/null +++ b/board/ttcontrol/vision2/imximage_hynix.cfg @@ -0,0 +1,209 @@ +# +# (C) Copyright 2009 +# Stefano Babic DENX Software Engineering sbabic@denx.de. +# +# (C) Copyright 2010 +# Klaus Steinhammer TTECH Control Gmbh kst@tttech.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# Boot Device : one of +# spi, nand, onenand, sd + +BOOT_FROM spi + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register + +####################### +### Disable WDOG ### +####################### +DATA 2 0x73f98000 0x30 + +####################### +### SET DDR Clk ### +####################### + +# CCM: CBMCR - ddr_clk_sel: axi_b (133MHz) +DATA 4 0x73FD4018 0x000024C0 + +# DOUBLE SPI CLK (13MHz->26 MHz Clock) +DATA 4 0x73FD4038 0x2010241 + +#IOMUXC_SW_PAD_CTL_PAD_CSPI1_MOSI HYS_ENABLE | DRV_MAX | SRE_FAST +DATA 4 0x73fa8600 0x00000107 +#IOMUXC_SW_PAD_CTL_PAD_CSPI1_MISO HYS_ENABLE | DRV_MAX | SRE_FAST +DATA 4 0x73fa8604 0x00000107 +#IOMUXC_SW_PAD_CTL_PAD_CSPI1_SS0 HYS_ENABLE | PKE_ENABLE | DRV_MAX | SRE_FAST +DATA 4 0x73fa8608 0x00000187 +#IOMUXC_SW_PAD_CTL_PAD_CSPI1_SS1 HYS_ENABLE | PKE_ENABLE | DRV_MAX | SRE_FAST +DATA 4 0x73fa860c 0x00000187 +#IOMUXC_SW_PAD_CTL_PAD_CSPI1_SCLK HYS_ENABLE | DRV_MAX | SRE_FAST +DATA 4 0x73fa8614 0x00000107 +#IOMUXC_SW_PAD_CTL_PAD_DI1_PIN11 HYS_ENABLE | DRV_MAX | SRE_FAST (CSPI1_SS2) +DATA 4 0x73fa86a8 0x00000187 + +####################### +### Settings IOMUXC ### +####################### + +# DDR IOMUX configuration +# Control, Data, Address pads are in their default state: HIGH DS, FAST SR. +# IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK MAX DS +DATA 4 0x73fa84b8 0x000000e7 +# PVTC MAX (at GPC, PGR reg) +#DATA 4 0x73FD8004 0x1fc00000 + +#DQM0 DS high slew rate slow +DATA 4 0x73fa84d4 0x000000e4 +#DQM1 DS high slew rate slow +DATA 4 0x73fa84d8 0x000000e4 +#DQM2 DS high slew rate slow +DATA 4 0x73fa84dc 0x000000e4 +#DQM3 DS high slew rate slow +DATA 4 0x73fa84e0 0x000000e4 + +#IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0 DS high & SLEW slow +DATA 4 0x73fa84bc 0x000000c4 +#IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1 DS high & SLEW slow +DATA 4 0x73fa84c0 0x000000c4 +#IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2 DS high & SLEW slow +DATA 4 0x73fa84c4 0x000000c4 +#IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3 DS high & SLEW slow +DATA 4 0x73fa84c8 0x000000c4 + +#DRAM_DATA B0 +DATA 4 0x73fa88a4 0x00000004 +#DRAM_DATA B1 +DATA 4 0x73fa88ac 0x00000004 +#DRAM_DATA B2 +DATA 4 0x73fa88b8 0x00000004 +#DRAM_DATA B3 +DATA 4 0x73fa882c 0x00000004 + +#DRAM_DATA B0 slew rate +DATA 4 0x73fa8878 0x00000000 +#DRAM_DATA B1 slew rate +DATA 4 0x73fa8880 0x00000000 +#DRAM_DATA B2 slew rate +DATA 4 0x73fa888c 0x00000000 +#DRAM_DATA B3 slew rate +DATA 4 0x73fa889c 0x00000000 + +####################### +### Configure SDRAM ### +####################### + +# Configure CS0 +####################### + +# ESDCTL0: Enable controller +DATA 4 0x83fd9000 0x83220000 + +# Init DRAM on CS0 +# ESDSCR: Precharge command +DATA 4 0x83fd9014 0x04008008 +# ESDSCR: Refresh command +DATA 4 0x83fd9014 0x00008010 +# ESDSCR: Refresh command +DATA 4 0x83fd9014 0x00008010 +# ESDSCR: LMR with CAS=3 and BL=3 (Burst Length = 8) +DATA 4 0x83fd9014 0x00338018 +# ESDSCR: EMR with half Drive strength (= medium strength @ i.MX51) +DATA 4 0x83fd9014 0x0020801a +# ESDSCR +DATA 4 0x83fd9014 0x00008000 + +# ESDSCR: EMR with full Drive strength +#DATA 4 0x83fd9014 0x0000801a + +# ESDCTL0: 14 ROW, 10 COL, 32Bit, SREF=8 +DATA 4 0x83fd9000 0xC3220000 + +# ESDCFG0: tRFC:22clks, tXSR:28clks, tXP:2clks, tWTR:2clk, tRP:3clks, tMRD:2clks +# tRAS:8clks, tRRD:2clks, tWR:3clks, tRCD:3clks, tRC:11clks +#DATA 4 0x83fd9004 0xC33574AA + +#micron mDDR +# ESDCFG0: tRFC:11clks, tXSR:19clks, tXP:1clks, tWTR:2clk, tRP:3clks, tMRD:2clks +# tRAS:7clks, tRRD:2clks, tWR:3clks, tRCD:3clks, tRC:9clks +#DATA 4 0x83FD9004 0x101564a8 + +#hynix mDDR +# ESDCFG0: tRFC:17clks, tXSR:21clks, tXP:3clks, tWTR:1clk, tRP:3clks, tMRD:2clks +# tRAS:7clks, tRRD:2clks, tWR:3clks, tRCD:3clks, tRC:9clks +DATA 4 0x83FD9004 0x704564a8 + +# ESDMISC: AP=10, Bank interleaving on, MIF3 en, RALAT=2 +DATA 4 0x83fd9010 0x000a1700 + +# Configure CS1 +####################### + +# ESDCTL1: Enable controller +DATA 4 0x83fd9008 0x83220000 + +# Init DRAM on CS1 +# ESDSCR: Precharge command +DATA 4 0x83fd9014 0x0400800c +# ESDSCR: Refresh command +DATA 4 0x83fd9014 0x00008014 +# ESDSCR: Refresh command +DATA 4 0x83fd9014 0x00008014 +# ESDSCR: LMR with CAS=3 and BL=3 (Burst Length = 8) +DATA 4 0x83fd9014 0x0033801c +# ESDSCR: EMR with half Drive strength (= medium strength @ i.MX51) +DATA 4 0x83fd9014 0x0020801e +# ESDSCR +DATA 4 0x83fd9014 0x00008004 + +# ESDCTL1: 14 ROW, 10 COL, 32Bit, SREF=8 +DATA 4 0x83fd9008 0xC3220000 + +# ESDCFG1: tRFC:22clks, tXSR:28clks, tXP:2clks, tWTR:2clk, tRP:3clks, tMRD:2clks +# tRAS:8clks, tRRD:2clks, tWR:3clks, tRCD:3clks, tRC:11clks +#DATA 4 0x83fd900c 0xC33574AA + +#micron mDDR +# ESDCFG1: tRFC:11clks, tXSR:19clks, tXP:1clks, tWTR:2clk, tRP:3clks, tMRD:2clks +# tRAS:7clks, tRRD:2clks, tWR:3clks, tRCD:3clks, tRC:9clks +#DATA 4 0x83FD900C 0x101564a8 + +#hynix mDDR +# ESDCFG0: tRFC:17clks, tXSR:21clks, tXP:3clks, tWTR:1clk, tRP:3clks, tMRD:2clks +# tRAS:7clks, tRRD:2clks, tWR:3clks, tRCD:3clks, tRC:9clks +DATA 4 0x83FD900C 0x704564a8 + +# ESDSCR (mDRAM configuration finished) +DATA 4 0x83FD9014 0x00000004 + +# ESDSCR - clear "configuration request" bit +DATA 4 0x83fd9014 0x00000000 diff --git a/board/ttcontrol/vision2/vision2.c b/board/ttcontrol/vision2/vision2.c new file mode 100644 index 0000000..7118b7f --- /dev/null +++ b/board/ttcontrol/vision2/vision2.c @@ -0,0 +1,712 @@ +/* + * (C) Copyright 2010 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx51_pins.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <mxc_gpio.h> +#include <asm/arch/sys_proto.h> +#include <asm/errno.h> +#include <i2c.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <fsl_pmic.h> +#include <mc13892.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u32 system_rev; + +#ifdef CONFIG_HW_WATCHDOG +#include <watchdog.h> + +void hw_watchdog_reset(void) +{ + int val; + + /* toggle watchdog trigger pin */ + val = mxc_gpio_get(66); + val = val ? 0 : 1; + mxc_gpio_set(66, val); +} +#endif + +static void init_drive_strength(void) +{ + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_PKEDDR, PAD_CTL_DDR_INPUT_CMOS); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_PKEADDR, PAD_CTL_PKE_ENABLE); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDRAPKS, PAD_CTL_PUE_KEEPER); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDRAPUS, PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_SR_A1, PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_A0, PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_A1, PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_RAS, + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_CAS, + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_PKEDDR, PAD_CTL_PKE_ENABLE); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDRPKS, PAD_CTL_PUE_KEEPER); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_HYSDDR0, PAD_CTL_HYS_NONE); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_HYSDDR1, PAD_CTL_HYS_NONE); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_HYSDDR2, PAD_CTL_HYS_NONE); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_HYSDDR3, PAD_CTL_HYS_NONE); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_SR_B0, PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_SR_B1, PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_SR_B2, PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDR_SR_B4, PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DDRPUS, PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_INMODE1, PAD_CTL_DDR_INPUT_CMOS); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DRAM_B0, PAD_CTL_DRV_MEDIUM); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DRAM_B1, PAD_CTL_DRV_MEDIUM); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DRAM_B2, PAD_CTL_DRV_MEDIUM); + mxc_iomux_set_pad(MX51_PIN_CTL_GRP_DRAM_B4, PAD_CTL_DRV_MEDIUM); + + /* Setting pad options */ + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDWE, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDCKE0, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDCKE1, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDCLK, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDQS0, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDQS1, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDQS2, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_SDQS3, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_CS0, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_CS1, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_DQM0, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_DQM1, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_DQM2, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_CTL_DRAM_DQM3, + PAD_CTL_PKE_ENABLE | PAD_CTL_PUE_KEEPER | + PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST); +} + +u32 get_board_rev(void) +{ + system_rev = get_cpu_rev(); + + return system_rev; +} + +int dram_init(void) +{ +#ifdef CONFIG_SYS_ARM_WITHOUT_RELOC + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); +#if (CONFIG_NR_DRAM_BANKS > 1) + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = get_ram_size((long *)PHYS_SDRAM_2, + PHYS_SDRAM_2_SIZE); +#endif +#else + gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, + PHYS_SDRAM_1_SIZE); +#endif + + return 0; +} + +static void setup_weim(void) +{ + struct weim *pweim = (struct weim *)WEIM_BASE_ADDR; + + pweim->csgcr1 = 0x004100b9; + pweim->csgcr2 = 0x00000001; + pweim->csrcr1 = 0x0a018000; + pweim->csrcr2 = 0; + pweim->cswcr1 = 0x0704a240; +} + +static void setup_uart(void) +{ + unsigned int pad = PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | + PAD_CTL_PUE_PULL | PAD_CTL_DRV_HIGH | PAD_CTL_SRE_FAST; + /* console RX on Pin EIM_D25 */ + mxc_request_iomux(MX51_PIN_EIM_D25, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_D25, pad); + /* console TX on Pin EIM_D26 */ + mxc_request_iomux(MX51_PIN_EIM_D26, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_D26, pad); +} + +#ifdef CONFIG_MXC_SPI +void spi_io_init(void) +{ + /* 000: Select mux mode: ALT0 mux port: MOSI of instance: ecspi1 */ + mxc_request_iomux(MX51_PIN_CSPI1_MOSI, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_MOSI, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); + + /* 000: Select mux mode: ALT0 mux port: MISO of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_CSPI1_MISO, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_MISO, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); + + /* 000: Select mux mode: ALT0 mux port: SS0 of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_CSPI1_SS0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_SS0, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | + PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); + + /* + * SS1 will be used as GPIO because of uninterrupted + * long SPI transmissions (GPIO4_25) + */ + mxc_request_iomux(MX51_PIN_CSPI1_SS1, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_CSPI1_SS1, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | + PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); + + /* 000: Select mux mode: ALT0 mux port: SS2 of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_DI1_PIN11, IOMUX_CONFIG_ALT7); + mxc_iomux_set_pad(MX51_PIN_DI1_PIN11, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE | + PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); + + /* 000: Select mux mode: ALT0 mux port: SCLK of instance: ecspi1. */ + mxc_request_iomux(MX51_PIN_CSPI1_SCLK, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_CSPI1_SCLK, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); +} + +static void reset_peripherals(int reset) +{ + u32 val; + if (reset) { + + /* reset_n is on NANDF_D15 */ + mxc_gpio_set(89, 0); + mxc_gpio_direction(89, MXC_GPIO_DIRECTION_OUT); + +#ifdef CONFIG_VISION2_HW_1_0 + /* + * set FEC Configuration lines + * set levels of FEC config lines + */ + mxc_gpio_set(75, 0); + mxc_gpio_set(74, 1); + mxc_gpio_set(95, 1); + mxc_gpio_direction(75, MXC_GPIO_DIRECTION_OUT); + mxc_gpio_direction(74, MXC_GPIO_DIRECTION_OUT); + mxc_gpio_direction(95, MXC_GPIO_DIRECTION_OUT); + + /* set direction of FEC config lines */ + mxc_gpio_set(59, 0); + mxc_gpio_set(60, 0); + mxc_gpio_set(61, 0); + mxc_gpio_set(55, 1); + mxc_gpio_direction(59, MXC_GPIO_DIRECTION_OUT); + mxc_gpio_direction(60, MXC_GPIO_DIRECTION_OUT); + mxc_gpio_direction(61, MXC_GPIO_DIRECTION_OUT); + mxc_gpio_direction(55, MXC_GPIO_DIRECTION_OUT); + + /* FEC_RXD1 - sel GPIO (2-23) for configuration -> 1 */ + mxc_request_iomux(MX51_PIN_EIM_EB3, IOMUX_CONFIG_ALT1); + /* FEC_RXD2 - sel GPIO (2-27) for configuration -> 0 */ + mxc_request_iomux(MX51_PIN_EIM_CS2, IOMUX_CONFIG_ALT1); + /* FEC_RXD3 - sel GPIO (2-28) for configuration -> 0 */ + mxc_request_iomux(MX51_PIN_EIM_CS3, IOMUX_CONFIG_ALT1); + /* FEC_RXER - sel GPIO (2-29) for configuration -> 0 */ + mxc_request_iomux(MX51_PIN_EIM_CS4, IOMUX_CONFIG_ALT1); + /* FEC_COL - sel GPIO (3-10) for configuration -> 1 */ + mxc_request_iomux(MX51_PIN_NANDF_RB2, IOMUX_CONFIG_ALT3); + /* FEC_RCLK - sel GPIO (3-11) for configuration -> 0 */ + mxc_request_iomux(MX51_PIN_NANDF_RB3, IOMUX_CONFIG_ALT3); + /* FEC_RXD0 - sel GPIO (3-31) for configuration -> 1 */ + mxc_request_iomux(MX51_PIN_NANDF_D9, IOMUX_CONFIG_ALT3); +#endif + + /* + * activate reset_n pin + * Select mux mode: ALT3 mux port: NAND D15 + */ + mxc_request_iomux(MX51_PIN_NANDF_D15, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_NANDF_D15, + PAD_CTL_DRV_VOT_HIGH | PAD_CTL_DRV_MAX); + } else { + /* set FEC Control lines */ + mxc_gpio_direction(89, MXC_GPIO_DIRECTION_IN); + udelay(500); + +#ifdef CONFIG_VISION2_HW_1_0 + /* FEC RDATA[3] */ + mxc_request_iomux(MX51_PIN_EIM_CS3, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS3, 0x180); + + /* FEC RDATA[2] */ + mxc_request_iomux(MX51_PIN_EIM_CS2, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS2, 0x180); + + /* FEC RDATA[1] */ + mxc_request_iomux(MX51_PIN_EIM_EB3, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_EB3, 0x180); + + /* FEC RDATA[0] */ + mxc_request_iomux(MX51_PIN_NANDF_D9, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D9, 0x2180); + + /* FEC RX_CLK */ + mxc_request_iomux(MX51_PIN_NANDF_RB3, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RB3, 0x2180); + + /* FEC RX_ER */ + mxc_request_iomux(MX51_PIN_EIM_CS4, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS4, 0x180); + + /* FEC COL */ + mxc_request_iomux(MX51_PIN_NANDF_RB2, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RB2, 0x2180); +#endif + } +} + +static void power_init_mx51(void) +{ + unsigned int val; + + /* Write needed to Power Gate 2 register */ + val = pmic_reg_read(REG_POWER_MISC); + + /* enable VCAM with 2.775V to enable read from PMIC */ + val = VCAMCONFIG | VCAMEN; + pmic_reg_write(REG_MODE_1, val); + + /* + * Set switchers in Auto in NORMAL mode & STANDBY mode + * Setup the switcher mode for SW1 & SW2 + */ + val = pmic_reg_read(REG_SW_4); + val = (val & ~((SWMODE_MASK << SWMODE1_SHIFT) | + (SWMODE_MASK << SWMODE2_SHIFT))); + val |= (SWMODE_AUTO_AUTO << SWMODE1_SHIFT) | + (SWMODE_AUTO_AUTO << SWMODE2_SHIFT); + pmic_reg_write(REG_SW_4, val); + + /* Setup the switcher mode for SW3 & SW4 */ + val = pmic_reg_read(REG_SW_5); + val &= ~((SWMODE_MASK << SWMODE4_SHIFT) | + (SWMODE_MASK << SWMODE3_SHIFT)); + val |= (SWMODE_AUTO_AUTO << SWMODE4_SHIFT) | + (SWMODE_AUTO_AUTO << SWMODE3_SHIFT); + pmic_reg_write(REG_SW_5, val); + + + /* Set VGEN3 to 1.8V, VCAM to 3.0V */ + val = pmic_reg_read(REG_SETTING_0); + val &= ~(VCAM_MASK | VGEN3_MASK); + val |= VCAM_3_0; + pmic_reg_write(REG_SETTING_0, val); + + /* Set VVIDEO to 2.775V, VAUDIO to 3V0, VSD to 1.8V */ + val = pmic_reg_read(REG_SETTING_1); + val &= ~(VVIDEO_MASK | VSD_MASK | VAUDIO_MASK); + val |= VVIDEO_2_775 | VAUDIO_3_0 | VSD_1_8; + pmic_reg_write(REG_SETTING_1, val); + + /* Configure VGEN3 and VCAM regulators to use external PNP */ + val = VGEN3CONFIG | VCAMCONFIG; + pmic_reg_write(REG_MODE_1, val); + udelay(200); + + /* Enable VGEN3, VCAM, VAUDIO, VVIDEO, VSD regulators */ + val = VGEN3EN | VGEN3CONFIG | VCAMEN | VCAMCONFIG | + VVIDEOEN | VAUDIOEN | VSDEN; + pmic_reg_write(REG_MODE_1, val); + + val = pmic_reg_read(REG_POWER_CTL2); + val |= WDIRESET; + pmic_reg_write(REG_POWER_CTL2, val); + + udelay(2500); + +} +#endif + +static void setup_gpios(void) +{ + unsigned int i; + + /* CAM_SUP_DISn, GPIO1_7 */ + mxc_request_iomux(MX51_PIN_GPIO1_7, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_GPIO1_7, 0x82); + + /* DAB Display EN, GPIO3_1 */ + mxc_request_iomux(MX51_PIN_DI1_PIN12, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DI1_PIN12, 0x82); + + /* WDOG_TRIGGER, GPIO3_2 */ + mxc_request_iomux(MX51_PIN_DI1_PIN13, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DI1_PIN13, 0x82); + + /* Now we need to trigger the watchdog */ + WATCHDOG_RESET(); + + /* Display2 TxEN, GPIO3_3 */ + mxc_request_iomux(MX51_PIN_DI1_D0_CS, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DI1_D0_CS, 0x82); + + /* DAB Light EN, GPIO3_4 */ + mxc_request_iomux(MX51_PIN_DI1_D1_CS, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DI1_D1_CS, 0x82); + + /* AUDIO_MUTE, GPIO3_5 */ + mxc_request_iomux(MX51_PIN_DISPB2_SER_DIN, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DISPB2_SER_DIN, 0x82); + + /* SPARE_OUT, GPIO3_6 */ + mxc_request_iomux(MX51_PIN_DISPB2_SER_DIO, IOMUX_CONFIG_ALT4); + mxc_iomux_set_pad(MX51_PIN_DISPB2_SER_DIO, 0x82); + + /* BEEPER_EN, GPIO3_26 */ + mxc_request_iomux(MX51_PIN_NANDF_D14, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_NANDF_D14, 0x82); + + /* POWER_OFF, GPIO3_27 */ + mxc_request_iomux(MX51_PIN_NANDF_D13, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_NANDF_D13, 0x82); + + /* FRAM_WE, GPIO3_30 */ + mxc_request_iomux(MX51_PIN_NANDF_D10, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_NANDF_D10, 0x82); + + /* EXPANSION_EN, GPIO4_26 */ + mxc_request_iomux(MX51_PIN_CSPI1_RDY, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_CSPI1_RDY, 0x82); + + /* + * Set GPIO1_4 to high and output; it is used to reset + * the system on reboot + */ + mxc_gpio_set(4, 1); + mxc_gpio_direction(4, MXC_GPIO_DIRECTION_OUT); + + mxc_gpio_set(7, 0); + mxc_gpio_direction(7, MXC_GPIO_DIRECTION_OUT); + for (i = 65; i < 71; i++) { + mxc_gpio_set(i, 0); + mxc_gpio_direction(i, MXC_GPIO_DIRECTION_OUT); + } + + mxc_gpio_set(94, 0); + mxc_gpio_direction(94, MXC_GPIO_DIRECTION_OUT); + + /* Set POWER_OFF high */ + mxc_gpio_set(91, 1); + mxc_gpio_direction(91, MXC_GPIO_DIRECTION_OUT); + + mxc_gpio_set(90, 0); + mxc_gpio_direction(90, MXC_GPIO_DIRECTION_OUT); + + mxc_gpio_set(122, 0); + mxc_gpio_direction(122, MXC_GPIO_DIRECTION_OUT); + + mxc_gpio_set(121, 1); + mxc_gpio_direction(121, MXC_GPIO_DIRECTION_OUT); + + WATCHDOG_RESET(); +} + +static void setup_fec(void) +{ + /*FEC_MDIO*/ + mxc_request_iomux(MX51_PIN_EIM_EB2, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_EB2, 0x1FD); + + /*FEC_MDC*/ + mxc_request_iomux(MX51_PIN_NANDF_CS3, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS3, 0x2004); + + /* FEC RDATA[3] */ + mxc_request_iomux(MX51_PIN_EIM_CS3, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS3, 0x180); + + /* FEC RDATA[2] */ + mxc_request_iomux(MX51_PIN_EIM_CS2, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS2, 0x180); + + /* FEC RDATA[1] */ + mxc_request_iomux(MX51_PIN_EIM_EB3, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_EB3, 0x180); + + /* FEC RDATA[0] */ + mxc_request_iomux(MX51_PIN_NANDF_D9, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D9, 0x2180); + + /* FEC TDATA[3] */ + mxc_request_iomux(MX51_PIN_NANDF_CS6, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS6, 0x2004); + + /* FEC TDATA[2] */ + mxc_request_iomux(MX51_PIN_NANDF_CS5, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS5, 0x2004); + + /* FEC TDATA[1] */ + mxc_request_iomux(MX51_PIN_NANDF_CS4, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS4, 0x2004); + + /* FEC TDATA[0] */ + mxc_request_iomux(MX51_PIN_NANDF_D8, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D8, 0x2004); + + /* FEC TX_EN */ + mxc_request_iomux(MX51_PIN_NANDF_CS7, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS7, 0x2004); + + /* FEC TX_ER */ + mxc_request_iomux(MX51_PIN_NANDF_CS2, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_CS2, 0x2004); + + /* FEC TX_CLK */ + mxc_request_iomux(MX51_PIN_NANDF_RDY_INT, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RDY_INT, 0x2180); + + /* FEC TX_COL */ + mxc_request_iomux(MX51_PIN_NANDF_RB2, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RB2, 0x2180); + + /* FEC RX_CLK */ + mxc_request_iomux(MX51_PIN_NANDF_RB3, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX51_PIN_NANDF_RB3, 0x2180); + + /* FEC RX_CRS */ + mxc_request_iomux(MX51_PIN_EIM_CS5, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS5, 0x180); + + /* FEC RX_ER */ + mxc_request_iomux(MX51_PIN_EIM_CS4, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX51_PIN_EIM_CS4, 0x180); + + /* FEC RX_DV */ + mxc_request_iomux(MX51_PIN_NANDF_D11, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX51_PIN_NANDF_D11, 0x2180); +} + +struct fsl_esdhc_cfg esdhc_cfg[1] = { + {MMC_SDHC1_BASE_ADDR, 1}, +}; + +int get_mmc_getcd(u8 *cd, struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) + *cd = mxc_gpio_get(0); + else + *cd = 0; + + return 0; +} + +#ifdef CONFIG_FSL_ESDHC +int board_mmc_init(bd_t *bis) +{ + mxc_request_iomux(MX51_PIN_SD1_CMD, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_CLK, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA0, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA1, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA2, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_request_iomux(MX51_PIN_SD1_DATA3, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_SD1_CMD, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_CLK, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_NONE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA0, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA1, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA2, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_iomux_set_pad(MX51_PIN_SD1_DATA3, + PAD_CTL_DRV_MAX | PAD_CTL_DRV_VOT_HIGH | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PD | + PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_SRE_FAST); + mxc_request_iomux(MX51_PIN_GPIO1_0, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_0, + PAD_CTL_HYS_ENABLE); + mxc_request_iomux(MX51_PIN_GPIO1_1, + IOMUX_CONFIG_ALT0 | IOMUX_CONFIG_SION); + mxc_iomux_set_pad(MX51_PIN_GPIO1_1, + PAD_CTL_HYS_ENABLE); + + return fsl_esdhc_initialize(bis, &esdhc_cfg[0]); +} +#endif + +int board_early_init_f(void) +{ + + + init_drive_strength(); + + /* Setup debug led */ + mxc_gpio_set(6, 0); + mxc_gpio_direction(6, MXC_GPIO_DIRECTION_OUT); + mxc_request_iomux(MX51_PIN_GPIO1_6, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX51_PIN_GPIO1_6, PAD_CTL_DRV_MAX | PAD_CTL_SRE_FAST); + + /* wait a little while to give the pll time to settle */ + sdelay(100000); + + setup_weim(); + setup_uart(); + setup_fec(); + setup_gpios(); + + spi_io_init(); + + return 0; +} + +int board_init(void) +{ +#ifdef CONFIG_SYS_ARM_WITHOUT_RELOC + board_early_init_f(); +#endif + gd->bd->bi_arch_number = MACH_TYPE_TTC_VISION2; /* board id for linux */ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +int board_late_init(void) +{ + power_init_mx51(); + + reset_peripherals(1); + udelay(2000); + reset_peripherals(0); + udelay(2000); + + /* Early revisions require a second reset */ +#ifdef CONFIG_VISION2_HW_1_0 + reset_peripherals(1); + udelay(2000); + reset_peripherals(0); + udelay(2000); +#endif + + return 0; +} + +int checkboard(void) +{ + u32 system_rev = get_cpu_rev(); + u32 cause; + struct src *src_regs = (struct src *)SRC_BASE_ADDR; + + puts("Board: TTControl Vision II CPU V"); + + switch (system_rev & 0xff) { + case CHIP_REV_3_0: + puts("3.0 ["); + break; + case CHIP_REV_2_5: + puts("2.5 ["); + break; + case CHIP_REV_2_0: + puts("2.0 ["); + break; + case CHIP_REV_1_1: + puts("1.1 ["); + break; + case CHIP_REV_1_0: + default: + puts("1.0 ["); + break; + } + + cause = src_regs->srsr; + switch (cause) { + case 0x0001: + puts("POR"); + break; + case 0x0009: + puts("RST"); + break; + case 0x0010: + case 0x0011: + puts("WDOG"); + break; + default: + printf("unknown 0x%x", cause); + } + puts("]\n"); + + return 0; +} + diff --git a/boards.cfg b/boards.cfg index 02eb153..88c4060 100644 --- a/boards.cfg +++ b/boards.cfg @@ -47,6 +47,7 @@ jadecpu arm arm926ejs jadecpu syteco mb86r0x suen3 arm arm926ejs km_arm keymile kirkwood rd6281a arm arm926ejs - Marvell kirkwood mx51evk arm armv7 mx51evk freescale mx51 +vision2 arm armv7 vision2 ttcontrol mx51 actux1 arm ixp actux2 arm ixp actux3 arm ixp diff --git a/include/configs/vision2.h b/include/configs/vision2.h new file mode 100644 index 0000000..44a6f8b --- /dev/null +++ b/include/configs/vision2.h @@ -0,0 +1,214 @@ +/* + * Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de + * + * (C) Copyright 2009 Freescale Semiconductor, Inc. + * + * Configuration settings for the MX51-3Stack Freescale board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> + +#define CONFIG_MX51 /* in a mx51 */ +#define CONFIG_L2_OFF + +#define CONFIG_MX51_HCLK_FREQ 24000000 +#define CONFIG_MX51_CLK32 32768 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_REVISION_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define BOARD_LATE_INIT + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (2048 * 1024) + +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * Hardware drivers + */ +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX51_UART3 +#define CONFIG_MXC_GPIO +#define CONFIG_MXC_SPI +#define CONFIG_HW_WATCHDOG + + /* + * SPI Configs + * */ +#define CONFIG_FSL_SF +#define CONFIG_CMD_SF + +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO + +/* + * Use gpio 4 pin 25 as chip select for SPI flash + * This corresponds to gpio 121 + */ +#define CONFIG_SPI_FLASH_CS (1 | (121 << 8)) +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 25000000 + +#define CONFIG_ENV_SPI_CS (1 | (121 << 8)) +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_MAX_HZ 25000000 +#define CONFIG_ENV_SPI_MODE SPI_MODE_0 + +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_ENV_SECT_SIZE (1 * 64 * 1024) +#define CONFIG_ENV_SIZE (4 * 1024) + +#define CONFIG_FSL_ENV_IN_SF +#define CONFIG_ENV_IS_IN_SPI_FLASH + +/* PMIC Controller */ +#define CONFIG_FSL_PMIC +#define CONFIG_FSL_PMIC_BUS 0 +#define CONFIG_FSL_PMIC_CS 0 +#define CONFIG_FSL_PMIC_CLK 2500000 +#define CONFIG_FSL_PMIC_MODE SPI_MODE_0 +#define CONFIG_RTC_MC13783 + +/* + * MMC Configs + */ +#define CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR (0x70004000) +#define CONFIG_SYS_FSL_ESDHC_NUM 1 + +#define CONFIG_MMC + +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_CMD_DATE + +/* + * Eth Configs + */ +#define CONFIG_HAS_ETH1 +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY + +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE FEC_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1F + +#define CONFIG_CMD_PING +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 3 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/*********************************************************** + * Command definition + ***********************************************************/ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_SPI +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x90800000 /* loadaddr env var */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "loadaddr=0x90800000\0" + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "Vision II U-boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 64 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x90000000 +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "Vision II U-boot > " + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (256 * 1024 * 1024) +#define PHYS_SDRAM_2 CSD1_BASE_ADDR +#define PHYS_SDRAM_2_SIZE (256 * 1024 * 1024) +#define CONFIG_SYS_SDRAM_BASE 0x90000000 +#define CONFIG_SYS_INIT_RAM_ADDR 0x1FFE8000 + +#ifndef CONFIG_SYS_ARM_WITHOUT_RELOC +#define CONFIG_SYS_INIT_RAM_END (64 * 1024) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ + CONFIG_SYS_GBL_DATA_OFFSET) +#undef CONFIG_SKIP_RELOCATE_UBOOT +#else +#define CONFIG_SKIP_RELOCATE_UBOOT +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + 0x2000) +#endif + +#define CONFIG_BOARD_EARLY_INIT_F + +/* 166 MHz DDR RAM */ +#define CONFIG_SYS_DDR_CLKSEL 0 +#define CONFIG_SYS_CLKTL_CBCDR 0x19239100 + +#define CONFIG_SYS_NO_FLASH + +#endif /* __CONFIG_H */ diff --git a/include/mc13892.h b/include/mc13892.h index b291757..791e3ec 100644 --- a/include/mc13892.h +++ b/include/mc13892.h @@ -157,4 +157,7 @@ #define VSDSTBY (1 << 19) #define VSDMODE (1 << 20)
+/* Reg Power Control 2*/ +#define WDIRESET (1 << 12) + #endif
Stefano Babic
