[U-Boot] [PATCH v3] spi: Add error checking for invalid bus widths
At present an invalid bus width prints a message but does not return an error. This is the opposite of the correct behaviour. Adjust it to avoid code bloat in the common case, and avoid hard-to-debug failure in the uncommon case.
Changes in v3: - Display an error in U-Boot proper, but then continue - Drop patches previously applied
drivers/spi/spi-uclass.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index f59a701..1ab5b75 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -418,7 +418,7 @@ int spi_slave_ofdata_to_platdata(const void *blob, int node, mode |= SPI_TX_QUAD; break; default: - error("spi-tx-bus-width %d not supported\n", value); + warn_non_spl("spi-tx-bus-width %d not supported\n", value); break; }
@@ -433,7 +433,7 @@ int spi_slave_ofdata_to_platdata(const void *blob, int node, mode |= SPI_RX_QUAD; break; default: - error("spi-rx-bus-width %d not supported\n", value); + warn_non_spl("spi-rx-bus-width %d not supported\n", value); break; }
Changes in v3:
I thought in SPL it will reverse like debug and return by error, make sense?
thanks!
Hi Jagan,
Changes in v3:
Sorry I don't understand this comment. The intent here is to:
- do nothing in SPL - warn in U-Boot proper with printf()
Are you saying that it should use debug() in SPL?
On Mon, Dec 5, 2016 at 7:24 AM, Simon Glass sjg@chromium.org wrote:
Hi Jagan,
Changes in v3:
- do nothing in SPL
I though SPL should return error, unlike U-Boot. So-that SPL should use proper bus-width that will eventually fix the dt.
thanks!
Jagan Teki
