[U-Boot] [RFC 00/11] SYSFW Loader for TI K3 family SoCs using FS Loader
This series provides an alternative solution to the previously posted series titled "System Firmware Loader for TI K3 family SoCs" [1] using the existing FS loader driver rather than extending the SPL loader framework like the original patch series. Unlike the original series, it does not support eMMC/SD partition/sector based RAW loading, and it is larger in size.
It is only provided to support the discussion around to the initial series posted as "System Firmware Loader for TI K3 family SoCs" and is not intended to supersede this series, hence it is labeled as "RFC".
The interesting pieces are really in patches 04/11 (extension of FS loader to allow using platform data so one does not have to use either ENV or DTS), and 05/11 which implementes the usage of FS loader, including the required sequence of MMC initialization steps inspired by how SPL does it.
[1] https://lists.denx.de/pipermail/u-boot/2019-May/thread.html#368461
Regards, Andreas
Andreas Dannenberg (10): mmc: k3_arasan: Allow driver to probe without PDs specified spl: Allow skipping clearing BSS during relocation spl: mmc: Export function to get device index misc: fs_loader: Allow initializing blkdev using platform data arm: K3: Introduce System Firmware loader framework armV7R: K3: am654: Allow using SPL BSS pre-relocation armv7R: K3: am654: Use full malloc implementation in SPL armV7R: K3: am654: Load SYSFW binary and config from boot media configs: am65x_evm_r5: All sysfw to be loaded via MMC configs: am65x_hs_evm_r5: All sysfw to be loaded via MMC
Lokesh Vutla (1): armv7R: dts: k3: am654: Update for loading SYSFW from MMC
arch/arm/dts/k3-am654-r5-base-board.dts | 24 ++ arch/arm/lib/crt0.S | 3 + arch/arm/mach-k3/Kconfig | 22 ++ arch/arm/mach-k3/Makefile | 3 + arch/arm/mach-k3/am6_init.c | 34 ++- arch/arm/mach-k3/include/mach/sysfw-loader.h | 12 + arch/arm/mach-k3/sysfw-loader.c | 296 +++++++++++++++++++ board/ti/am65x/Kconfig | 1 + common/spl/Kconfig | 13 + common/spl/spl_mmc.c | 2 +- configs/am65x_evm_r5_defconfig | 6 +- configs/am65x_hs_evm_r5_defconfig | 6 +- drivers/misc/fs_loader.c | 17 +- drivers/mmc/k3_arsan_sdhci.c | 16 +- include/configs/am65x_evm.h | 28 +- include/fs_loader.h | 4 + include/spl.h | 2 + 17 files changed, 472 insertions(+), 17 deletions(-) create mode 100644 arch/arm/mach-k3/include/mach/sysfw-loader.h create mode 100644 arch/arm/mach-k3/sysfw-loader.c
We would like to use the driver even without power domains being specified for cases such as during early boot when the required power domains have already gotten enabled by the SoC's boot ROM and such explicit initialization is not needed and possible.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- drivers/mmc/k3_arsan_sdhci.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/k3_arsan_sdhci.c b/drivers/mmc/k3_arsan_sdhci.c index d5f2857382..785ba135c7 100644 --- a/drivers/mmc/k3_arsan_sdhci.c +++ b/drivers/mmc/k3_arsan_sdhci.c @@ -31,14 +31,14 @@ static int k3_arasan_sdhci_probe(struct udevice *dev) int ret;
ret = power_domain_get_by_index(dev, &sdhci_pwrdmn, 0); - if (ret) { - dev_err(dev, "failed to get power domain\n"); - return ret; - } - - ret = power_domain_on(&sdhci_pwrdmn); - if (ret) { - dev_err(dev, "Power domain on failed\n"); + if (!ret) { + ret = power_domain_on(&sdhci_pwrdmn); + if (ret) { + dev_err(dev, "Power domain on failed\n"); + return ret; + } + } else if (ret != -ENOENT && ret != -ENODEV && ret != -ENOSYS) { + dev_err(dev, "power_domain_get() failed: %d\n", ret); return ret; }
On some platform we have sufficient memory available early on to allow setting up and using a basic BSS prior to relocation. In order to be able to preserve data written to BSS during early startup add a Kconfig option allowing to skip the clearing of the BSS section during setting up of the final environment / relocation.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- arch/arm/lib/crt0.S | 3 +++ common/spl/Kconfig | 13 +++++++++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/arm/lib/crt0.S b/arch/arm/lib/crt0.S index 30fba20e1b..e24833a6f8 100644 --- a/arch/arm/lib/crt0.S +++ b/arch/arm/lib/crt0.S @@ -126,6 +126,8 @@ here: movne sp, r0 movne r9, r0 # endif + +#if !CONFIG_IS_ENABLED(SKIP_CLEAR_BSS) ldr r0, =__bss_start /* this is auto-relocated! */
#ifdef CONFIG_USE_ARCH_MEMSET @@ -143,6 +145,7 @@ clbss_l:cmp r0, r1 /* while not at end of BSS */ addlo r0, r0, #4 /* move to next */ blo clbss_l #endif +#endif
#if ! defined(CONFIG_SPL_BUILD) bl coloured_LED_init diff --git a/common/spl/Kconfig b/common/spl/Kconfig index c7cd34449a..098cbb2f7f 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -188,6 +188,19 @@ config TPL_BANNER_PRINT info. Disabling this option could be useful to reduce SPL boot time (e.g. approx. 6 ms faster, when output on i.MX6 with 115200 baud).
+ +config SPL_SKIP_CLEAR_BSS + depends on ARM && !ARM64 + bool "Skips clearing BSS section during environment setup / relocation" + help + On some platform we have sufficient memory available early on to + allow setting up and using a basic BSS prior to relocation. In order + to preserve data written to BSS during early startup use use this + option to skip the clearing of the BSS section. Note that activating + this option implies that you are responsible for clearing the BSS + section yourself, otherwise you will most likely end up with an + invalid post-relocation environment. + config SPL_DISPLAY_PRINT bool "Display a board-specific message in SPL" help
To better support use cases where we want to side-load additional files during SPL execution from MMC media export the SPL MMC framework function for determining the MMC boot device index.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- common/spl/spl_mmc.c | 2 +- include/spl.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 324d91c884..6bdc348e94 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -94,7 +94,7 @@ end: return 0; }
-static int spl_mmc_get_device_index(u32 boot_device) +int spl_mmc_get_device_index(u32 boot_device) { switch (boot_device) { case BOOT_DEVICE_MMC1: diff --git a/include/spl.h b/include/spl.h index f09909e189..98e8d1e951 100644 --- a/include/spl.h +++ b/include/spl.h @@ -327,6 +327,8 @@ bool spl_was_boot_source(void); */ int spl_dfu_cmd(int usbctrl, char *dfu_alt_info, char *interface, char *devstr);
+int spl_mmc_get_device_index(u32 boot_device); + int spl_mmc_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev);
To give us more flexibility using the FS loader eliminate the need of always having to use the ENV to configure the block device but rather allow the respective block device and partition to be setup through platform data.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- drivers/misc/fs_loader.c | 17 ++++++++++++++++- include/fs_loader.h | 4 ++++ 2 files changed, 20 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index f42eeff8f6..69f474da99 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -81,6 +81,15 @@ static int select_fs_dev(struct device_platdata *plat) return -ENODEV; } } + } else if (plat->blkdev) { + struct blk_desc *desc = blk_get_by_device(plat->blkdev); + + if (desc) { + ret = fs_set_blk_dev_with_part(desc, plat->blkpart); + } else { + debug("%s: No device found\n", __func__); + return -ENODEV; + } } else if (plat->mtdpart && plat->ubivol) { ret = mount_ubifs(plat->mtdpart, plat->ubivol); if (ret) @@ -138,13 +147,18 @@ static int _request_firmware_prepare(struct udevice *dev, static int fw_get_filesystem_firmware(struct udevice *dev) { loff_t actread; - char *storage_interface, *dev_part, *ubi_mtdpart, *ubi_volume; + char *storage_interface = NULL; + char *dev_part = NULL; + char *ubi_mtdpart = NULL; + char *ubi_volume = NULL; int ret;
+#if CONFIG_IS_ENABLED(ENV_SUPPORT) storage_interface = env_get("storage_interface"); dev_part = env_get("fw_dev_part"); ubi_mtdpart = env_get("fw_ubi_mtdpart"); ubi_volume = env_get("fw_ubi_volume"); +#endif
if (storage_interface && dev_part) { ret = fs_set_blk_dev(storage_interface, dev_part, FS_TYPE_ANY); @@ -159,6 +173,7 @@ static int fw_get_filesystem_firmware(struct udevice *dev) else ret = -ENODEV; } else { + debug("%s: init via platdata\n", __func__); ret = select_fs_dev(dev->platdata); }
diff --git a/include/fs_loader.h b/include/fs_loader.h index b728c06fcf..adaa2b5db8 100644 --- a/include/fs_loader.h +++ b/include/fs_loader.h @@ -28,11 +28,15 @@ struct phandle_part { * This holds information about all supported storage devices for driver use. * * @phandlepart: Attribute data for block device. + * @blkdev: Block device (alternative to using phandlepart) + * @blkpart: Partition number of block device (alternative to using phandlepart) * @mtdpart: MTD partition for ubi partition. * @ubivol: UBI volume-name for ubifsmount. */ struct device_platdata { struct phandle_part phandlepart; + struct udevice *blkdev; + u32 blkpart; char *mtdpart; char *ubivol; };
Why not using DT method?
- } else if (plat->blkdev) {
blkdev);
if (desc) {
blkpart);
} else {
return -ENODEV;
*ubi_volume;
- char *storage_interface = NULL;
- char *dev_part = NULL;
- char *ubi_mtdpart = NULL;
- char *ubi_volume = NULL;
int ret; +#if CONFIG_IS_ENABLED(ENV_SUPPORT) storage_interface = env_get("storage_interface"); dev_part = env_get("fw_dev_part"); ubi_mtdpart = env_get("fw_ubi_mtdpart"); ubi_volume = env_get("fw_ubi_volume"); +#endif if (storage_interface && dev_part) { ret = fs_set_blk_dev(storage_interface, dev_part, FS_TYPE_ANY); @@ -159,6 +173,7 @@ static int fw_get_filesystem_firmware(struct udevice *dev) else ret = -ENODEV; } else {
ret = select_fs_dev(dev->platdata); } diff --git a/include/fs_loader.h b/include/fs_loader.h index b728c06fcf..adaa2b5db8 100644 --- a/include/fs_loader.h +++ b/include/fs_loader.h @@ -28,11 +28,15 @@ struct phandle_part { * This holds information about all supported storage devices for driver use. * * @phandlepart: Attribute data for block device.
- @blkdev: Block device (alternative to using phandlepart)
- @blkpart: Partition number of block device (alternative to using
- struct udevice *blkdev;
- u32 blkpart;
Hi TF, first, thanks for taking time to continue having the discussion around this patch series.
We would like to use a single U-Boot build to support all of the different boot modes (boot media) a given device supports. In case of this RFC series this is really distilled down to only mmc0 and mmc1 but this already illustrates the point. The patch 05/11 shows how spl_boot_device() is used to make the MMC probing dependent on the boot device mmc0 vs mmc1. So hard-coding in DT will lose this flexibility. Of course there would be ways out such as dynamically updating DTS or to extend the FS loader probe function to select from multiple DTS nodes based on boot device, but all would come at a cost of additional memory consumption.
-- Andreas Dannenberg Texas Instruments Inc
Introduce a framework that allows loading the System Firmware (SYSFW) binary as well as the associated configuration data from an image tree blob named "sysfw.itb" from an FS-based boot media using the FS loader framework.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/Kconfig | 22 ++ arch/arm/mach-k3/Makefile | 3 + arch/arm/mach-k3/include/mach/sysfw-loader.h | 12 + arch/arm/mach-k3/sysfw-loader.c | 296 +++++++++++++++++++ 4 files changed, 333 insertions(+) create mode 100644 arch/arm/mach-k3/include/mach/sysfw-loader.h create mode 100644 arch/arm/mach-k3/sysfw-loader.c
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index e677a2e01b..fd28593cec 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -58,6 +58,28 @@ config SYS_K3_BOOT_CORE_ID int default 16
+config K3_LOAD_SYSFW + bool + depends on SPL + +config K3_SYSFW_IMAGE_NAME + string "File name of SYSFW firmware and configuration blob" + depends on K3_LOAD_SYSFW + default "sysfw.itb" + help + Filename of the combined System Firmware and configuration image tree + blob to be loaded when booting from a filesystem. + +config K3_SYSFW_IMAGE_SIZE_MAX + int "Amount of memory dynamically allocated for loading SYSFW blob" + depends on K3_LOAD_SYSFW + default 269000 + help + Amount of memory (in bytes) reserved through dynamic allocation at + runtime for loading the combined System Firmware and configuration image + tree blob. Keep it as tight as possible, as this directly affects the + overall SPL memory footprint. + config SYS_K3_SPL_ATF bool "Start Cortex-A from SPL" depends on SPL && CPU_V7R diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 0c3a4f7db1..3af7f2ec96 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -7,4 +7,7 @@ obj-$(CONFIG_SOC_K3_AM6) += am6_init.o obj-$(CONFIG_ARM64) += arm64-mmu.o obj-$(CONFIG_CPU_V7R) += r5_mpu.o lowlevel_init.o obj-$(CONFIG_TI_SECURE_DEVICE) += security.o +ifeq ($(CONFIG_SPL_BUILD),y) +obj-$(CONFIG_K3_LOAD_SYSFW) += sysfw-loader.o +endif obj-y += common.o diff --git a/arch/arm/mach-k3/include/mach/sysfw-loader.h b/arch/arm/mach-k3/include/mach/sysfw-loader.h new file mode 100644 index 0000000000..c335c7ed92 --- /dev/null +++ b/arch/arm/mach-k3/include/mach/sysfw-loader.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * Andreas Dannenberg dannenberg@ti.com + */ + +#ifndef _SYSFW_LOADER_H_ +#define _SYSFW_LOADER_H_ + +void k3_sysfw_loader(void (*config_pm_done_callback)(void)); + +#endif diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/sysfw-loader.c new file mode 100644 index 0000000000..1191640acd --- /dev/null +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * K3: System Firmware Loader + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + * Andreas Dannenberg dannenberg@ti.com + */ + +#include <common.h> +#include <spl.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <dm/pinctrl.h> +#include <remoteproc.h> +#include <linux/libfdt.h> +#include <linux/soc/ti/ti_sci_protocol.h> +#include <image.h> +#include <malloc.h> +#include <fs_loader.h> +#include <mmc.h> + +#include <asm/io.h> +#include <asm/spl.h> +#include <asm/sections.h> +#include <asm/armv7_mpu.h> +#include <asm/arch/hardware.h> + +/* Name of the FIT image nodes for SYSFW and its config data */ +#define SYSFW_FIRMWARE "sysfw.bin" +#define SYSFW_CFG_BOARD "board-cfg.bin" +#define SYSFW_CFG_PM "pm-cfg.bin" +#define SYSFW_CFG_RM "rm-cfg.bin" +#define SYSFW_CFG_SEC "sec-cfg.bin" + +static int fit_get_data_by_name(const void *fit, int images, const char *name, + const void **addr, size_t *size) +{ + int node_offset; + + node_offset = fdt_subnode_offset(fit, images, name); + if (node_offset < 0) + return -ENOENT; + + return fit_image_get_data(fit, node_offset, addr, size); +} + +static void k3_sysfw_load_using_fit(void *fit, struct ti_sci_handle **ti_sci) +{ + int images; + const void *sysfw_addr; + size_t sysfw_size; + struct udevice *dev; + int ret; + + /* Find the node holding the images information */ + images = fdt_path_offset(fit, FIT_IMAGES_PATH); + if (images < 0) + panic("Cannot find /images node (%d)\n", images); + + /* Extract System Firmware (SYSFW) image from FIT */ + ret = fit_get_data_by_name(fit, images, SYSFW_FIRMWARE, + &sysfw_addr, &sysfw_size); + if (ret < 0) + panic("Error accessing %s node in FIT (%d)\n", SYSFW_FIRMWARE, + ret); + + /* + * Start up system controller firmware + * + * It is assumed that remoteproc device 0 is the corresponding + * system-controller that runs SYSFW. Make sure DT reflects the same. + */ + ret = rproc_dev_init(0); + if (ret) + panic("rproc failed to be initialized (%d)\n", ret); + + ret = rproc_load(0, (ulong)sysfw_addr, (ulong)sysfw_size); + if (ret) + panic("Firmware failed to start on rproc (%d)\n", ret); + + ret = rproc_start(0); + if (ret) + panic("Firmware init failed on rproc (%d)\n", ret); + + /* Bring up the Device Management and Security Controller (SYSFW) */ + ret = uclass_get_device_by_name(UCLASS_FIRMWARE, "dmsc", &dev); + if (ret) + panic("Failed to initialize SYSFW (%d)\n", ret); + + /* Establish handle for easier access */ + *ti_sci = (struct ti_sci_handle *)(ti_sci_get_handle_from_sysfw(dev)); +} + +static void k3_sysfw_configure_using_fit(void *fit, + struct ti_sci_handle *ti_sci, + void (*config_pm_done_callback)(void)) +{ + struct ti_sci_board_ops *board_ops = &ti_sci->ops.board_ops; + int images; + const void *cfg_fragment_addr; + size_t cfg_fragment_size; + int ret; + + /* Find the node holding the images information */ + images = fdt_path_offset(fit, FIT_IMAGES_PATH); + if (images < 0) + panic("Cannot find /images node (%d)\n", images); + + /* Extract board configuration from FIT */ + ret = fit_get_data_by_name(fit, images, SYSFW_CFG_BOARD, + &cfg_fragment_addr, &cfg_fragment_size); + if (ret < 0) + panic("Error accessing %s node in FIT (%d)\n", SYSFW_CFG_BOARD, + ret); + + /* Apply board configuration to SYSFW */ + ret = board_ops->board_config(ti_sci, + (u64)(u32)cfg_fragment_addr, + (u32)cfg_fragment_size); + if (ret) + panic("Failed to set board configuration (%d)\n", ret); + + /* Extract power/clock (PM) specific configuration from FIT */ + ret = fit_get_data_by_name(fit, images, SYSFW_CFG_PM, + &cfg_fragment_addr, &cfg_fragment_size); + if (ret < 0) + panic("Error accessing %s node in FIT (%d)\n", SYSFW_CFG_PM, + ret); + + /* Apply power/clock (PM) specific configuration to SYSFW */ + ret = board_ops->board_config_pm(ti_sci, + (u64)(u32)cfg_fragment_addr, + (u32)cfg_fragment_size); + if (ret) + panic("Failed to set board PM configuration (%d)\n", ret); + + /* Extract resource management (RM) specific configuration from FIT */ + ret = fit_get_data_by_name(fit, images, SYSFW_CFG_RM, + &cfg_fragment_addr, &cfg_fragment_size); + if (ret < 0) + panic("Error accessing %s node in FIT (%d)\n", SYSFW_CFG_RM, + ret); + + /* Apply resource management (RM) configuration to SYSFW */ + ret = board_ops->board_config_rm(ti_sci, + (u64)(u32)cfg_fragment_addr, + (u32)cfg_fragment_size); + if (ret) + panic("Failed to set board RM configuration (%d)\n", ret); + + /* Extract security specific configuration from FIT */ + ret = fit_get_data_by_name(fit, images, SYSFW_CFG_SEC, + &cfg_fragment_addr, &cfg_fragment_size); + if (ret < 0) + panic("Error accessing %s node in FIT (%d)\n", SYSFW_CFG_SEC, + ret); + + /* Apply security configuration to SYSFW */ + ret = board_ops->board_config_security(ti_sci, + (u64)(u32)cfg_fragment_addr, + (u32)cfg_fragment_size); + if (ret) + panic("Failed to set board security configuration (%d)\n", + ret); + + /* + * Now that all clocks and PM aspects are setup, invoke a user- + * provided callback function. Usually this callback would be used + * to setup or re-configure the U-Boot console UART. + */ + if (config_pm_done_callback) + config_pm_done_callback(); +} + +static int k3_sysfw_load_mmc_fs(const char *filename, void *buf, size_t max_size) +{ + int mmc_dev; + struct udevice *mmcdev; + struct mmc *mmc; + struct udevice *fsdev; + struct device_platdata *plat; + int ret; + + /* Bring up the MMC boot device */ + + mmc_dev = spl_mmc_get_device_index(spl_boot_device()); + if (mmc_dev < 0) { + pr_err("%s: Getting MMC device index failed (%d)\n", __func__, + mmc_dev); + return mmc_dev; + } + + ret = uclass_get_device(UCLASS_MMC, mmc_dev, &mmcdev); + if (ret < 0) { + pr_err("%s: Getting MMC device failed (%d)\n", __func__, ret); + return ret; + } + + ret = mmc_initialize(NULL); + if (ret < 0) { + pr_err("%s: Initializing MMC device failed (%d)\n", __func__, + ret); + return ret; + } + + mmc = mmc_get_mmc_dev(mmcdev); + if (!mmc) { + pr_err("%s: Getting underlying MMC device failed\n", __func__); + return -ENODEV; + } + + ret = mmc_init(mmc); + if (ret) { + printf("%s: mmc init failed with error: %d\n", __func__, ret); + return ret; + } + + /* Use the FS loader framework to perform the actual FW loading */ + + ret = uclass_get_device(UCLASS_FS_FIRMWARE_LOADER, 0, &fsdev); + if (ret < 0) { + pr_err("%s: Getting FW loader device failed (%d)\n", __func__, + ret); + return ret; + } + + plat = fsdev->platdata; + plat->blkdev = mmcdev; + plat->blkpart = CONFIG_SYS_MMCSD_FS_BOOT_PARTITION; + + return request_firmware_into_buf(fsdev, filename, buf, max_size, 0); +} + +void k3_sysfw_loader(void (*config_pm_done_callback)(void)) +{ + void *addr; + struct spl_boot_device bootdev = { 0 }; + struct ti_sci_handle *ti_sci; + u32 boot_mode; + int ret; + + addr = memalign(ARCH_DMA_MINALIGN, CONFIG_K3_SYSFW_IMAGE_SIZE_MAX); + if (!addr) + panic("Error allocating %u bytes of memory for SYSFW image\n", + CONFIG_K3_SYSFW_IMAGE_SIZE_MAX); + + debug("%s: allocated %u bytes at 0x%p\n", __func__, + CONFIG_K3_SYSFW_IMAGE_SIZE_MAX, addr); + + bootdev.boot_device = spl_boot_device(); + boot_mode = spl_boot_mode(bootdev.boot_device); + + /* Load combined System Controller firmware and config data image */ + switch (bootdev.boot_device) { +#if CONFIG_IS_ENABLED(MMC_SUPPORT) + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + case BOOT_DEVICE_MMC2_2: +#ifdef CONFIG_K3_SYSFW_IMAGE_NAME + if (boot_mode == MMCSD_MODE_FS) { + ret = k3_sysfw_load_mmc_fs(CONFIG_K3_SYSFW_IMAGE_NAME, + addr, + CONFIG_K3_SYSFW_IMAGE_SIZE_MAX); + } else +#endif + { + panic("Non-FS load of SYSFW image from device %u not supported!\n", + bootdev.boot_device); + } + break; +#endif + default: + panic("Loading SYSFW image from device %u not supported!\n", + bootdev.boot_device); + } + + if (ret < 0) + panic("Error %d occurred during loading SYSFW image!\n", ret); + + /* Ensure the SYSFW image is in FIT format */ + if (image_get_magic((const image_header_t *)addr) != FDT_MAGIC) + panic("SYSFW image not in FIT format!\n"); + + /* Extract and start SYSFW */ + k3_sysfw_load_using_fit(addr, &ti_sci); + + /* Parse and apply the different SYSFW configuration fragments */ + k3_sysfw_configure_using_fit(addr, ti_sci, config_pm_done_callback); + + /* Output System Firmware version info */ + printf("SYSFW ABI: %d.%d (firmware rev 0x%04x '%.*s')\n", + ti_sci->version.abi_major, ti_sci->version.abi_minor, + ti_sci->version.firmware_revision, + sizeof(ti_sci->version.firmware_description), + ti_sci->version.firmware_description); +}
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index e677a2e01b..fd28593cec 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -58,6 +58,28 @@ config SYS_K3_BOOT_CORE_ID int default 16 +config K3_LOAD_SYSFW
- bool
- depends on SPL
- string "File name of SYSFW firmware and configuration blob"
- depends on K3_LOAD_SYSFW
- default "sysfw.itb"
- help
- Filename of the combined System Firmware and configuration
image tree
- blob to be loaded when booting from a filesystem.
- int "Amount of memory dynamically allocated for loading
SYSFW blob"
- default 269000
- help
- Amount of memory (in bytes) reserved through dynamic
allocation at
- runtime for loading the combined System Firmware and
configuration image
- tree blob. Keep it as tight as possible, as this directly
affects the
- overall SPL memory footprint.
- Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti
.com/
- Andreas Dannenberg dannenberg@ti.com
+#endif diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach- k3/sysfw-loader.c new file mode 100644 index 0000000000..1191640acd --- /dev/null +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- K3: System Firmware Loader
.com/
- int node_offset;
- node_offset = fdt_subnode_offset(fit, images, name);
- if (node_offset < 0)
return -ENOENT;
- return fit_image_get_data(fit, node_offset, addr, size);
- int images;
- const void *sysfw_addr;
- size_t sysfw_size;
- struct udevice *dev;
- int ret;
- /* Find the node holding the images information */
- images = fdt_path_offset(fit, FIT_IMAGES_PATH);
- if (images < 0)
- /* Extract System Firmware (SYSFW) image from FIT */
- ret = fit_get_data_by_name(fit, images, SYSFW_FIRMWARE,
- if (ret < 0)
SYSFW_FIRMWARE,
ret);
- * Start up system controller firmware
- * It is assumed that remoteproc device 0 is the
corresponding
- * system-controller that runs SYSFW. Make sure DT reflects
the same.
- ret = rproc_dev_init(0);
- if (ret)
- ret = rproc_load(0, (ulong)sysfw_addr, (ulong)sysfw_size);
- if (ret)
ret);
- ret = rproc_start(0);
- if (ret)
- /* Bring up the Device Management and Security Controller
(SYSFW) */
- ret = uclass_get_device_by_name(UCLASS_FIRMWARE, "dmsc",
&dev);
- if (ret)
- /* Establish handle for easier access */
- *ti_sci = (struct ti_sci_handle
*ti_sci,
void
- struct ti_sci_board_ops *board_ops = &ti_sci->ops.board_ops;
- int images;
- const void *cfg_fragment_addr;
- size_t cfg_fragment_size;
- int ret;
- if (images < 0)
- /* Extract board configuration from FIT */
- ret = fit_get_data_by_name(fit, images, SYSFW_CFG_BOARD,
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_BOARD,
ret);
- /* Apply board configuration to SYSFW */
- ret = board_ops->board_config(ti_sci,
- if (ret)
ret);
- /* Extract power/clock (PM) specific configuration from FIT
- ret = fit_get_data_by_name(fit, images, SYSFW_CFG_PM,
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_PM,
ret);
- /* Apply power/clock (PM) specific configuration to SYSFW */
- ret = board_ops->board_config_pm(ti_sci,
- if (ret)
ret);
- /* Extract resource management (RM) specific configuration
from FIT */
- ret = fit_get_data_by_name(fit, images, SYSFW_CFG_RM,
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_RM,
ret);
- /* Apply resource management (RM) configuration to SYSFW */
- ret = board_ops->board_config_rm(ti_sci,
- if (ret)
ret);
- /* Extract security specific configuration from FIT */
- ret = fit_get_data_by_name(fit, images, SYSFW_CFG_SEC,
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_SEC,
ret);
- /* Apply security configuration to SYSFW */
- ret = board_ops->board_config_security(ti_sci,
t_addr,
e);
- if (ret)
(%d)\n",
ret);
- * Now that all clocks and PM aspects are setup, invoke a
user-
- * provided callback function. Usually this callback would
be used
- * to setup or re-configure the U-Boot console UART.
- if (config_pm_done_callback)
- int mmc_dev;
- struct udevice *mmcdev;
- struct mmc *mmc;
- struct udevice *fsdev;
- struct device_platdata *plat;
- int ret;
- /* Bring up the MMC boot device */
- mmc_dev = spl_mmc_get_device_index(spl_boot_device());
- if (mmc_dev < 0) {
__func__,
mmc_dev);
return mmc_dev;
- ret = uclass_get_device(UCLASS_MMC, mmc_dev, &mmcdev);
- if (ret < 0) {
__func__, ret);
return ret;
- ret = mmc_initialize(NULL);
- if (ret < 0) {
__func__,
ret);
return ret;
- mmc = mmc_get_mmc_dev(mmcdev);
- if (!mmc) {
__func__);
return -ENODEV;
- ret = mmc_init(mmc);
- if (ret) {
__func__, ret);
return ret;
The probe function in fs loader already support the block init, and the block init would init the mmc.
- /* Use the FS loader framework to perform the actual FW
loading */
- ret = uclass_get_device(UCLASS_FS_FIRMWARE_LOADER, 0,
&fsdev);
- if (ret < 0) {
__func__,
ret);
return ret;
- plat = fsdev->platdata;
- plat->blkdev = mmcdev;
- plat->blkpart = CONFIG_SYS_MMCSD_FS_BOOT_PARTITION;
- return request_firmware_into_buf(fsdev, filename, buf,
max_size, 0); +}
- void *addr;
- struct spl_boot_device bootdev = { 0 };
- struct ti_sci_handle *ti_sci;
- u32 boot_mode;
- int ret;
- addr = memalign(ARCH_DMA_MINALIGN,
- if (!addr)
image\n",
- debug("%s: allocated %u bytes at 0x%p\n", __func__,
- CONFIG_K3_SYSFW_IMAGE_SIZE_MAX, addr);
- bootdev.boot_device = spl_boot_device();
- boot_mode = spl_boot_mode(bootdev.boot_device);
- /* Load combined System Controller firmware and config data
image */
- switch (bootdev.boot_device) {
- case BOOT_DEVICE_MMC1:
- case BOOT_DEVICE_MMC2:
- case BOOT_DEVICE_MMC2_2:
ret =
addr,
CONFIG_K3_SYSFW_I
MAGE_SIZE_MAX);
} else
break;
- default:
supported!\n",
- if (ret < 0)
image!\n", ret);
- /* Ensure the SYSFW image is in FIT format */
- if (image_get_magic((const image_header_t *)addr) !=
FDT_MAGIC)
- /* Extract and start SYSFW */
- k3_sysfw_load_using_fit(addr, &ti_sci);
- /* Parse and apply the different SYSFW configuration
fragments */
- k3_sysfw_configure_using_fit(addr, ti_sci,
- /* Output System Firmware version info */
- printf("SYSFW ABI: %d.%d (firmware rev 0x%04x '%.*s')\n",
- ti_sci->version.abi_major, ti_sci->version.abi_minor,
- ti_sci->version.firmware_revision,
- sizeof(ti_sci->version.firmware_description),
- ti_sci->version.firmware_description);
Hi TF,
__func__,
mmc_dev);
return mmc_dev;
- if (ret < 0) {
__func__, ret);
return ret;
- if (ret < 0) {
__func__,
ret);
return ret;
- if (!mmc) {
__func__);
return -ENODEV;
- if (ret) {
__func__, ret);
return ret;
Yes I'm sure this could have gotten simplified if I were to use the DTS to describe the boot device. But as explained earlier I was exploring a way to make it work without DTS for added flexibility so I can pick the boot device at runtime.
- bool
- depends on SPL
- help
image tree
SYSFW blob"
- default 269000
- help
allocation at
configuration image
affects the
.com/
.com/
- int node_offset;
return -ENOENT;
- int images;
- int ret;
- if (images < 0)
- if (ret < 0)
SYSFW_FIRMWARE,
ret);
corresponding
the same.
- if (ret)
- if (ret)
ret);
- if (ret)
(SYSFW) */
&dev);
- if (ret)
*ti_sci,
void
- int images;
- int ret;
- if (images < 0)
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_BOARD,
ret);
- if (ret)
ret);
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_PM,
ret);
- if (ret)
ret);
from FIT */
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_RM,
ret);
- if (ret)
ret);
&cfg_fragment_addr,
- if (ret < 0)
SYSFW_CFG_SEC,
ret);
t_addr,
e);
- if (ret)
(%d)\n",
ret);
user-
be used
- int mmc_dev;
- struct mmc *mmc;
- int ret;
__func__,
mmc_dev);
return mmc_dev;
- if (ret < 0) {
__func__, ret);
return ret;
- if (ret < 0) {
__func__,
ret);
return ret;
- if (!mmc) {
__func__);
return -ENODEV;
- if (ret) {
__func__, ret);
return ret;
Can use the fs loader probe for mmc init.
loading */
&fsdev);
- if (ret < 0) {
__func__,
ret);
return ret;
max_size, 0); +}
- void *addr;
- u32 boot_mode;
- int ret;
- if (!addr)
image\n",
image */
ret =
addr,
CONFIG_K3_SYSFW_I
MAGE_SIZE_MAX);
} else
break;
- default:
supported!\n",
- if (ret < 0)
image!\n", ret);
FDT_MAGIC)
fragments */
In order to be able to use more advanced driver functionality which often relies on having BSS initialized during early boot prior to relocation several things need to be in place:
1) Memory needs to be available for BSS to use. For this, we locate BSS at the top of the MCU SRAM area, with the stack starting right below it, 2) We need to zero-initialize BSS ourselves which will we do during board_init_f(), 3) We would also like to skip the implicit zero-initialization as part of SPL relocation, so that already initialized variables will carry over post-relocation. We will do this with a separate commit by turning on the respective CONFIG option.
In this commit we also clean up the assignment of the initial SP address as part of the refactoring, taking into account the pre-decrement post- increment nature in which the SP is used on ARM.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/am6_init.c | 7 +++++++ include/configs/am65x_evm.h | 25 +++++++++++++++++++++++-- 2 files changed, 30 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 60a580305d..22477efa5b 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -78,6 +78,13 @@ void board_init_f(ulong dummy)
#ifdef CONFIG_CPU_V7R setup_k3_mpu_regions(); + + /* + * When running SPL on R5 we are using SRAM for BSS to have global + * data etc. working prior to relocation. Since this means we need + * to self-manage BSS, clear that section now. + */ + memset(__bss_start, 0, __bss_end - __bss_start); #endif
/* Init DM early in-order to invoke system controller */ diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index b043bf886b..cff60a8444 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -19,6 +19,29 @@ #define CONFIG_SYS_SDRAM_BASE1 0x880000000
/* SPL Loader Configuration */ +#ifdef CONFIG_TARGET_AM654_A53_EVM +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ + CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE) +#else +/* + * Maximum size in memory allocated to the SPL BSS. Keep it as tight as + * possible (to allow the build to go through), as this directly affects + * our memory footprint. The less we use for BSS the more we have available + * for everything else. + */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x5000 +/* + * Link BSS to be within SPL in a dedicated region located near the top of + * the MCU SRAM, this way making it available also before relocation. Note + * that we are not using the actual top of the MCU SRAM as there is a memory + * location filled in by the boot ROM that we want to read out without any + * interference from the C context. + */ +#define CONFIG_SPL_BSS_START_ADDR (CONFIG_SYS_K3_BOOT_PARAM_TABLE_INDEX -\ + CONFIG_SPL_BSS_MAX_SIZE) +/* Set the stack right below the SPL BSS section */ +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SPL_BSS_START_ADDR +#endif
#ifdef CONFIG_SYS_K3_SPL_ATF #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "tispl.bin" @@ -29,8 +52,6 @@ #endif
#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ - CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE - 4)
#define CONFIG_SYS_BOOTM_LEN SZ_64M
Switch to using the full malloc scheme in post-relocation SPL to allow better utilization of available memory for example by allowing memory to get freed. Initially allocate a 16MB-sized region in DDR starting at address 0x84000000 for this purpose.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- configs/am65x_evm_r5_defconfig | 1 - configs/am65x_hs_evm_r5_defconfig | 1 - include/configs/am65x_evm.h | 3 +++ 3 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 3814872ec7..73f614944f 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 0b12f15782..49eca7de64 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -20,7 +20,6 @@ CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y CONFIG_USE_BOOTCOMMAND=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_I2C_SUPPORT=y diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index cff60a8444..a90f38edc9 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -41,6 +41,9 @@ CONFIG_SPL_BSS_MAX_SIZE) /* Set the stack right below the SPL BSS section */ #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SPL_BSS_START_ADDR +/* Configure R5 SPL post-relocation malloc pool in DDR */ +#define CONFIG_SYS_SPL_MALLOC_START 0x84000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_16M #endif
Use the System Firmware (SYSFW) loader framework to load and start the SYSFW as part of the AM654 early initialization sequence. While at it also initialize the WKUP_UART0 pinmux as it is used by SYSFW to print diagnostic messages.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/am6_init.c | 27 ++++++++++++++++++++++++++- board/ti/am65x/Kconfig | 1 + 2 files changed, 27 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 22477efa5b..f50eded03f 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -10,8 +10,11 @@ #include <asm/io.h> #include <spl.h> #include <asm/arch/hardware.h> +#include <asm/arch/sysfw-loader.h> #include "common.h" #include <dm.h> +#include <dm/uclass-internal.h> +#include <dm/pinctrl.h>
#ifdef CONFIG_SPL_BUILD static void mmr_unlock(u32 base, u32 partition) @@ -63,7 +66,7 @@ static void store_boot_index_from_rom(void)
void board_init_f(ulong dummy) { -#if defined(CONFIG_K3_AM654_DDRSS) +#if defined(CONFIG_K3_LOAD_SYSFW) || defined(CONFIG_K3_AM654_DDRSS) struct udevice *dev; int ret; #endif @@ -90,8 +93,30 @@ void board_init_f(ulong dummy) /* Init DM early in-order to invoke system controller */ spl_early_init();
+#ifdef CONFIG_K3_LOAD_SYSFW + /* + * Process pinctrl for the serial0 a.k.a. WKUP_UART0 module and continue + * regardless of the result of pinctrl. Do this without probing the + * device, but instead by searching the device that would request the + * given sequence number if probed. The UART will be used by the system + * firmware (SYSFW) image for various purposes and SYSFW depends on us + * to initialize its pin settings. + */ + ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, true, &dev); + if (!ret) + pinctrl_select_state(dev, "default"); + + /* + * Load, start up, and configure system controller firmware. Provide + * the U-Boot console init function to the SYSFW post-PM configuration + * callback hook, effectively switching on (or over) the console + * output. + */ + k3_sysfw_loader(preloader_console_init); +#else /* Prepare console output */ preloader_console_init(); +#endif
#ifdef CONFIG_K3_AM654_DDRSS ret = uclass_get_device(UCLASS_RAM, 0, &dev); diff --git a/board/ti/am65x/Kconfig b/board/ti/am65x/Kconfig index 98172c28f5..60bb834aca 100644 --- a/board/ti/am65x/Kconfig +++ b/board/ti/am65x/Kconfig @@ -18,6 +18,7 @@ config TARGET_AM654_R5_EVM select CPU_V7R select SYS_THUMB_BUILD select SOC_K3_AM6 + select K3_LOAD_SYSFW select K3_AM654_DDRSS imply SYS_K3_SPL_ATF
In order to load the sysfw.itb from an MMC device, clocks should be hard coded to the same value as ROM configured frequency. Clock updates cannot happen at this point as SYSFW is not yet available. So updating the clock properties for MMC nodes.
Furthermore, create a new node for the FS loader framework which we want to use to load the actual firmware file from the boot media.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/dts/k3-am654-r5-base-board.dts | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/arch/arm/dts/k3-am654-r5-base-board.dts b/arch/arm/dts/k3-am654-r5-base-board.dts index a07038be70..75880158a2 100644 --- a/arch/arm/dts/k3-am654-r5-base-board.dts +++ b/arch/arm/dts/k3-am654-r5-base-board.dts @@ -22,6 +22,12 @@ chosen { stdout-path = "serial2:115200n8"; tick-timer = &timer1; + firmware-loader = &fs_loader0; + }; + + fs_loader0: fs_loader@0 { + u-boot,dm-pre-reloc; + compatible = "u-boot,fs-loader"; };
aliases { @@ -96,6 +102,12 @@ u-boot,dm-spl; };
+ clk_200mhz: dummy_clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + u-boot,dm-spl; + }; };
&dmsc { @@ -137,3 +149,15 @@ pinctrl-names = "default"; pinctrl-0 = <&wkup_vtt_pins_default>; }; + +&sdhci0 { + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + /delete-property/ power-domains; +}; + +&sdhci1 { + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + /delete-property/ power-domains; +};
- fs_loader0: fs_loader@0 {
Why not using phandlepart = <&mmc 1>, this would help to avoid mmc init duplication in a few places such as patch [05/11].
}; aliases { @@ -96,6 +102,12 @@ u-boot,dm-spl; };
- clk_200mhz: dummy_clock {
#clock-cells = <0>;
u-boot,dm-spl;
}; &dmsc { @@ -137,3 +149,15 @@ pinctrl-names = "default"; pinctrl-0 = <&wkup_vtt_pins_default>; };
+&sdhci0 {
- clock-names = "clk_xin";
- clocks = <&clk_200mhz>;
- /delete-property/ power-domains;
+&sdhci1 {
Hi TF,
See comment on earlier patch, this path was chosen to allow for flexibility during runtime. When using FS loader as you intended it to get used it works very well (we are actually using it for other purposes on another device).
Hence my argument that the approach I chose with the original [1] SYSFW loader series of opening up the SPL loader framework in a "lean & mean" fashion and the FS loader driver as it is today are really things that are complementary and can co-exist when one starts looking under the hood.
Enable all the relevant configs that enables support for loading sysfw via MMC.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- configs/am65x_evm_r5_defconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 73f614944f..7633e42065 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_K3=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SOC_K3_AM6=y CONFIG_TARGET_AM654_R5_EVM=y CONFIG_SPL_MMC_SUPPORT=y @@ -20,6 +20,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_SPL_TEXT_BASE=0x41c00000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_SKIP_CLEAR_BSS=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_RESET=y @@ -60,6 +61,7 @@ CONFIG_DA8XX_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_MISC=y +CONFIG_FS_LOADER=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_K3_ARASAN=y @@ -87,3 +89,4 @@ CONFIG_SYSRESET_TI_SCI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- configs/am65x_hs_evm_r5_defconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig index 49eca7de64..4c3bf54e27 100644 --- a/configs/am65x_hs_evm_r5_defconfig +++ b/configs/am65x_hs_evm_r5_defconfig @@ -4,7 +4,7 @@ CONFIG_TI_SECURE_DEVICE=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SOC_K3_AM6=y CONFIG_TARGET_AM654_R5_EVM=y CONFIG_SPL_MMC_SUPPORT=y @@ -22,6 +22,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_SPL_TEXT_BASE=0x41c00000 CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_SKIP_CLEAR_BSS=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_RESET=y @@ -62,6 +63,7 @@ CONFIG_DA8XX_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_MISC=y +CONFIG_FS_LOADER=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_K3_ARASAN=y @@ -89,3 +91,4 @@ CONFIG_SYSRESET_TI_SCI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384
Andreas, thanks for posting this.
TF, do you see some way, given this series, to make changes such that "fs_loader" can be made smaller? And support more of Andreas' use cases than it does here? Thanks!
Hi Tom,
I'm not sure FS loader can be made much smaller but I'm more concerned how it would scale if I were to add support for the other boot modes we need such as eMMC/SD raw mode, QSPI/OSPI, Y-Modem, and others to come.
For all of those we have a solution in production similar to what was proposed here [1] tapping into the SPL loader framework at (almost) zero cost. Growing FS loader beyond what it is today plus adding in the support for runtime-selection of firmware load media all added up may quickly become prohibitive for very space constrained scenarios like on our AM654x devices.
Andreas Dannenberg
Chee, Tien Fong
dannenberg@ti.com
