[U-Boot] [PATCH] imx: mx6quq7: add sd card detection
Add board_mmc_getcd function and declare CD_GPIO for SDCard.
Signed-off-by: Julien Corjon corjon.j@ecagroup.com --- board/seco/mx6quq7/mx6quq7.c | 27 ++++++++++++++++++++++----- 1 file changed, 22 insertions(+), 5 deletions(-)
diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index ea1d4b8..d70c6bc 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -91,11 +91,30 @@ int board_eth_init(bd_t *bis) return ret; }
+#define USDHC4_CD_GPIO IMX_GPIO_NR(2, 6) + static struct fsl_esdhc_cfg usdhc_cfg[2] = { - {USDHC3_BASE_ADDR}, - {USDHC2_BASE_ADDR}, + {USDHC3_BASE_ADDR, 0, 4}, + {USDHC4_BASE_ADDR, 0, 4}, };
+int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC3_BASE_ADDR: + ret = 1; /* Assume eMMC is always present */ + break; + case USDHC4_BASE_ADDR: + ret = !gpio_get_value(USDHC4_CD_GPIO); + break; + } + + return ret; +} + int board_mmc_init(bd_t *bis) { u32 index = 0; @@ -112,14 +131,12 @@ int board_mmc_init(bd_t *bis) case 0: seco_mx6_setup_usdhc_iomux(3); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[0].max_bus_width = 4; break; case 1: seco_mx6_setup_usdhc_iomux(4); + gpio_direction_input(USDHC4_CD_GPIO); usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); - usdhc_cfg[1].max_bus_width = 4; break; - default: printf("Warning: %d exceed maximum number of SD ports %d\n", index + 1, CONFIG_SYS_FSL_USDHC_NUM);
Hi Julien,
This looks good to me, but can you split the changes in 3 different patches: 1/ remove USDHC2 2/ specify max_bus_width directly in usdhc_cfg static definition instead of tweaking it in the board_mmc_init() function. 3/ add USDHC4 + MMC detect
- {USDHC3_BASE_ADDR, 0, 4},
- {USDHC4_BASE_ADDR, 0, 4},
int ret = 0;
- case USDHC3_BASE_ADDR:
break;
break;
Please use tabs instead of spaces (scripts/checkpatch.sh should complain about that).
return ret;
case 1: seco_mx6_setup_usdhc_iomux(4);usdhc_cfg[0].max_bus_width = 4; break;
Thanks,
Boris
USDHC2 does not exist on mx6quq7 board, as USDHC4 was already been declared this is probably a typo.
Signed-off-by: Julien Corjon corjon.j@ecagroup.com --- v1 -> v2 - Split patch (suggested by Boris) - Replace spaces with tab (suggested by Boris)
board/seco/mx6quq7/mx6quq7.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index ea1d4b8..3743a9e 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -93,7 +93,7 @@ int board_eth_init(bd_t *bis)
static struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR}, - {USDHC2_BASE_ADDR}, + {USDHC4_BASE_ADDR}, };
Specify max_bus_width directly in usdhc_cfg static definition instead of tweaking it in the board_mmc_init() function.
board/seco/mx6quq7/mx6quq7.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index 3743a9e..89ae70d 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -92,8 +92,8 @@ int board_eth_init(bd_t *bis) }
static struct fsl_esdhc_cfg usdhc_cfg[2] = { - {USDHC3_BASE_ADDR}, - {USDHC4_BASE_ADDR}, + {USDHC3_BASE_ADDR, 0, 4}, + {USDHC4_BASE_ADDR, 0, 4}, };
int board_mmc_init(bd_t *bis) @@ -112,12 +112,10 @@ int board_mmc_init(bd_t *bis) case 0: seco_mx6_setup_usdhc_iomux(3); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[0].max_bus_width = 4; break; case 1: seco_mx6_setup_usdhc_iomux(4); usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); - usdhc_cfg[1].max_bus_width = 4; break;
default:
board/seco/mx6quq7/mx6quq7.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index 89ae70d..6be0b98 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -91,11 +91,30 @@ int board_eth_init(bd_t *bis) return ret; }
+#define USDHC4_CD_GPIO IMX_GPIO_NR(2, 6) + static struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR, 0, 4}, {USDHC4_BASE_ADDR, 0, 4}, };
For the whole series:
Acked-by: Boris Brezillon boris.brezillon@free-electrons.com
Thanks,
Boris
v1 -> v2
v1 -> v2
Applied (whole series) to u-boot-imx, thanks !
Best regards, Stefano Babic
Boris Brezillon
Julien Corjon
Stefano Babic
