[U-Boot-Users] [PATCH] Add sata sil3114 support
Add support for Silicon Images sil3114 sata chip using libata
Signed-off-by: Tor Krill tor@excito.com --- drivers/block/Makefile | 1 + drivers/block/sata_sil3114.c | 845 ++++++++++++++++++++++++++++++++++++++++++ drivers/block/sata_sil3114.h | 148 ++++++++ 3 files changed, 994 insertions(+), 0 deletions(-) create mode 100644 drivers/block/sata_sil3114.c create mode 100644 drivers/block/sata_sil3114.h
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 5f1298d..a09cd2a 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -29,6 +29,7 @@ COBJS-y += ahci.o COBJS-y += ata_piix.o COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o COBJS-$(CONFIG_LIBATA) += libata.o +COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o COBJS-y += sil680.o COBJS-y += sym53c8xx.o COBJS-y += systemace.o diff --git a/drivers/block/sata_sil3114.c b/drivers/block/sata_sil3114.c new file mode 100644 index 0000000..bdc22d3 --- /dev/null +++ b/drivers/block/sata_sil3114.c @@ -0,0 +1,845 @@ +/* + * Copyright (C) Excito Elektronik i Skåne AB, All rights reserved. + * Author: Tor Krill tor@excito.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * This is a driver for Silicon Image sil3114 sata chip modelled on + * the ata_piix driver + */ + + +#include <common.h> +#include <pci.h> +#include <command.h> +#include <config.h> +#include <asm/byteorder.h> +#include <asm/io.h> +#include <ide.h> +#include <libata.h> +#include "sata_sil3114.h" + +/* Convert sectorsize to wordsize */ +#define ATA_SECTOR_WORDS (ATA_SECT_SIZE/2) + +/* Excerpts from sata.h and cmd_sata.c */ +#define DEBUG_SATA 0 /*For debug prints set DEBUG_SATA to 1 */ + +#if (DEBUG_SATA) +#define PRINTF(fmt,args...) printf (fmt ,##args) +#else +#define PRINTF(fmt,args...) +#endif + +/* Forwards */ +u8 sil3114_spin_up(int num); +u8 sil3114_spin_down(int num); +static int sata_bus_softreset(int num); +static void sata_identify(int num, int dev); +static u8 check_power_mode(int num); +static void sata_port(struct sata_ioports *ioport); +static void set_Feature_cmd(int num, int dev); +static u8 sata_busy_wait(struct sata_ioports *ioaddr, int bits, unsigned int max, u8 usealtstatus); +static u8 sata_chk_status(struct sata_ioports * ioaddr, u8 usealtstatus); +static void msleep(int count); + +static u32 iobase[6]={0,0,0,0,0,0}; /* PCI BAR registers for our device */ +extern block_dev_desc_t sata_dev_desc[CFG_SATA_MAX_DEVICE]; + +static struct sata_port port[CFG_SATA_MAX_DEVICE]; + +static void output_data(struct sata_ioports *ioaddr, u16 * sect_buf, int words) +{ + while(words--){ + __raw_writew(*sect_buf++,(void *)ioaddr->data_addr); + } +} + +static int input_data(struct sata_ioports *ioaddr, u16 * sect_buf, int words) +{ + while(words--){ + *sect_buf++=__raw_readw((void *)ioaddr->data_addr); + } + return 0; +} + +static int sata_bus_softreset(int num) +{ + u8 status = 0; + + port[num].dev_mask = 1; + + port[num].ctl_reg = 0x08; /*Default value of control reg */ + writeb(port[num].ctl_reg, port[num].ioaddr.ctl_addr); + udelay(10); + writeb(port[num].ctl_reg | ATA_SRST, port[num].ioaddr.ctl_addr); + udelay(10); + writeb(port[num].ctl_reg, port[num].ioaddr.ctl_addr); + + /* spec mandates ">= 2ms" before checking status. + * We wait 150ms, because that was the magic delay used for + * ATAPI devices in Hale Landis's ATADRVR, for the period of time + * between when the ATA command register is written, and then + * status is checked. Because waiting for "a while" before + * checking status is fine, post SRST, we perform this magic + * delay here as well. + */ + msleep(150); + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 300, 0); + while((status & ATA_BUSY)) { + msleep(100); + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 3, 0); + } + + if(status & ATA_BUSY){ + printf ("ata%u is slow to respond,plz be patient\n", port); + } + + while((status & ATA_BUSY)) { + msleep(100); + status = sata_chk_status(&port[num].ioaddr,0); + } + + if (status & ATA_BUSY) { + printf ("ata%u failed to respond : ", port); + printf ("bus reset failed\n"); + port[num].dev_mask = 0; + return 1; + } + return 0; +} + +static void sata_identify(int num, int dev) +{ + u8 cmd = 0, status = 0, devno = num; + u16 iobuf[ATA_SECTOR_WORDS]; + u64 n_sectors = 0; + + memset(iobuf, 0, sizeof (iobuf)); + + if(!(port[num].dev_mask & 0x01)){ + printf("dev%d is not present on port#%d\n", dev, num); + return; + } + + PRINTF("port=%d dev=%d\n", num, dev); + + status = 0; + cmd = ATA_CMD_ID_ATA; /*Device Identify Command */ + writeb(cmd, port[num].ioaddr.command_addr); + readb(port[num].ioaddr.altstatus_addr); + udelay(10); + + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 1000, 0); + if(status & ATA_ERR){ + printf("\ndevice not responding\n"); + port[num].dev_mask &= ~0x01; + return; + } + + input_data(&port[num].ioaddr, iobuf, ATA_SECTOR_WORDS); + + ata_swap_buf_le16(iobuf,ATA_SECTOR_WORDS); + + PRINTF("Specific config: %x\n",iobuf[2]); + + /* we require LBA and DMA support (bits 8 & 9 of word 49) */ + if(!ata_id_has_dma(iobuf) || !ata_id_has_lba(iobuf)) { + PRINTF("ata%u: no dma/lba\n", num); + } +#ifdef DEBUG + ata_dump_id(iobuf); +#endif + n_sectors = ata_id_n_sectors(iobuf); + + if(n_sectors == 0) { + port[num].dev_mask &= ~0x01; + return; + } + ata_id_c_string(iobuf,(unsigned char *)sata_dev_desc[devno].revision, + ATA_ID_FW_REV,sizeof (sata_dev_desc[devno].revision)); + ata_id_c_string(iobuf,(unsigned char *)sata_dev_desc[devno].vendor, + ATA_ID_PROD,sizeof (sata_dev_desc[devno].vendor)); + ata_id_c_string(iobuf,(unsigned char *)sata_dev_desc[devno].product, + ATA_ID_SERNO,sizeof (sata_dev_desc[devno].product)); + + /* TODO - atm we asume harddisk ie not removable */ + sata_dev_desc[devno].removable = 0; + + sata_dev_desc[devno].lba = (u32)n_sectors; + PRINTF("lba=0x%x\n", sata_dev_desc[devno].lba); + +#ifdef CONFIG_LBA48 + if(iobuf[83] & (1<<10)) { + sata_dev_desc[devno].lba48 = 1; + }else{ + sata_dev_desc[devno].lba48 = 0; + } +#endif + + /* assuming HD */ + sata_dev_desc[devno].type = DEV_TYPE_HARDDISK; + sata_dev_desc[devno].blksz = ATA_SECT_SIZE; + sata_dev_desc[devno].lun = 0; /* just to fill something in... */ +} + +static void set_Feature_cmd(int num, int dev) +{ + u8 status = 0; + + if(!(port[num].dev_mask & 0x01)) { + PRINTF("dev%d is not present on port#%d\n", dev, num); + return; + } + + writeb(SETFEATURES_XFER, port[num].ioaddr.feature_addr); + writeb(XFER_PIO_4, port[num].ioaddr.nsect_addr); + writeb(0, port[num].ioaddr.lbal_addr); + writeb(0, port[num].ioaddr.lbam_addr); + writeb(0, port[num].ioaddr.lbah_addr); + + writeb(ATA_DEVICE_OBS, port[num].ioaddr.device_addr); + writeb(ATA_CMD_SET_FEATURES, port[num].ioaddr.command_addr); + + udelay(50); + msleep(150); + + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 5000, 0); + if((status & (ATA_BUSY | ATA_ERR))) { + printf("Error : status 0x%02x\n", status); + port[num].dev_mask &= ~0x01; + } +} + +u8 sil3114_spin_down(int num){ + u8 status = 0; + + PRINTF("Spin down disk\n"); + + if(!(port[num].dev_mask & 0x01)) { + PRINTF ("Device ata%d is not present\n", num); + return 1; + } + + if((status=check_power_mode(num))==0x00){ + PRINTF("Already in standby\n"); + return 0; + } + + if(status==0x01){ + printf("Failed to check power mode on ata%d\n",num); + return 1; + } + + if(!((status=sata_chk_status(&port[num].ioaddr,0))&ATA_DRDY)){ + printf("Device ata%d not ready\n",num); + return 1; + } + + writeb(0x00, port[num].ioaddr.feature_addr); + + writeb(0x00, port[num].ioaddr.nsect_addr); + writeb(0x00, port[num].ioaddr.lbal_addr); + writeb(0x00, port[num].ioaddr.lbam_addr); + writeb(0x00, port[num].ioaddr.lbah_addr); + + writeb(ATA_DEVICE_OBS, port[num].ioaddr.device_addr); + writeb(ATA_CMD_STANDBY, port[num].ioaddr.command_addr); + + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 30000,0); + if((status & (ATA_BUSY | ATA_ERR))) { + printf("Error waiting for disk spin down: status 0x%02x\n", status); + port[num].dev_mask &= ~0x01; + return 1; + } + return 0; +} + +u8 sil3114_spin_up(int num){ + u8 status = 0; + + PRINTF("Spin up disk\n"); + + if (!(port[num].dev_mask & 0x01)) { + PRINTF("Device ata%d is not present\n", num); + return 1; + } + + if((status=check_power_mode(num))!=0x00){ + if(status==0x01){ + printf("Failed to check power mode on ata%d\n",num); + return 1; + }else{ + /* should be up and running already */ + return 0; + } + } + + if(!((status=sata_chk_status(&port[num].ioaddr,0))&ATA_DRDY)){ + printf("Device ata%d not ready\n",num); + return 1; + } + + PRINTF("Stautus of device check: %d\n",status); + + writeb(0x00, port[num].ioaddr.feature_addr); + + writeb(0x00, port[num].ioaddr.nsect_addr); + writeb(0x00, port[num].ioaddr.lbal_addr); + writeb(0x00, port[num].ioaddr.lbam_addr); + writeb(0x00, port[num].ioaddr.lbah_addr); + + writeb(ATA_DEVICE_OBS, port[num].ioaddr.device_addr); + writeb(ATA_CMD_IDLE, port[num].ioaddr.command_addr); + + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 30000,0); + if((status & (ATA_BUSY | ATA_ERR))) { + printf("Error waiting for disk spin up: status 0x%02x\n", status); + port[num].dev_mask &= ~0x01; + return 1; + } + + /* Wait for disk to enter Active state */ + do{ + msleep(10); + status=check_power_mode(num); + }while((status==0x00) ||(status==0x80)); + + if(status==0x01){ + printf("Falied waiting for disk to spin up\n"); + return 1; + } + + return 0; +} + +/* Return value is not the usual here + * 0x00 - Device stand by + * 0x01 - Operation failed + * 0x80 - Device idle + * 0xff - Device active +*/ +static u8 check_power_mode(int num){ + u8 status = 0; + u8 res=0; + if(!(port[num].dev_mask & 0x01)) { + PRINTF ("Device ata%d is not present\n", num); + return 1; + } + + if(!(sata_chk_status(&port[num].ioaddr,0)&ATA_DRDY)){ + printf("Device ata%d not ready\n",num); + return 1; + } + + writeb(0, port[num].ioaddr.feature_addr); + writeb(0, port[num].ioaddr.nsect_addr); + writeb(0, port[num].ioaddr.lbal_addr); + writeb(0, port[num].ioaddr.lbam_addr); + writeb(0, port[num].ioaddr.lbah_addr); + + writeb(ATA_DEVICE_OBS, port[num].ioaddr.device_addr); + writeb(ATA_CMD_CHK_POWER, port[num].ioaddr.command_addr); + + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 5000,0); + if((status & (ATA_BUSY | ATA_ERR))) { + printf("Error waiting for check power mode complete : status 0x%02x\n", status); + port[num].dev_mask &= ~0x01; + return 1; + } + res=readb(port[num].ioaddr.nsect_addr); + PRINTF("Check powermode: %d\n",res); + return res; + +} + +static void sata_port(struct sata_ioports *ioport) +{ + ioport->data_addr = ioport->cmd_addr + ATA_REG_DATA; + ioport->error_addr = ioport->cmd_addr + ATA_REG_ERR; + ioport->feature_addr = ioport->cmd_addr + ATA_REG_FEATURE; + ioport->nsect_addr = ioport->cmd_addr + ATA_REG_NSECT; + ioport->lbal_addr = ioport->cmd_addr + ATA_REG_LBAL; + ioport->lbam_addr = ioport->cmd_addr + ATA_REG_LBAM; + ioport->lbah_addr = ioport->cmd_addr + ATA_REG_LBAH; + ioport->device_addr = ioport->cmd_addr + ATA_REG_DEVICE; + ioport->status_addr = ioport->cmd_addr + ATA_REG_STATUS; + ioport->command_addr = ioport->cmd_addr + ATA_REG_CMD; +} + +static u8 wait_for_irq(int num, unsigned int max){ + + u32 port=iobase[5]; + switch(num){ + case 0: + port+=VND_TF_CNST_CH0; + break; + case 1: + port+=VND_TF_CNST_CH1; + break; + case 2: + port+=VND_TF_CNST_CH2; + break; + case 3: + port+=VND_TF_CNST_CH3; + break; + default: + return 1; + } + + do{ + if(readl(port)&VND_TF_CNST_INTST){ + break; + } + udelay(1000); + max--; + } while( (max > 0)); + + return (max==0); +} + +static u8 sata_busy_wait(struct sata_ioports *ioaddr, int bits, unsigned int max, u8 usealtstatus) +{ + u8 status; + + do{ + if( !( (status = sata_chk_status (ioaddr,usealtstatus)) & bits) ){ + break; + } + udelay(1000); + max--; + } while((status & bits) && (max > 0)); + + return status; +} + +static u8 sata_chk_status(struct sata_ioports * ioaddr, u8 usealtstatus) +{ + if(!usealtstatus){ + return readb (ioaddr->status_addr); + }else{ + return readb (ioaddr->altstatus_addr); + } +} + +static void msleep(int count) +{ + int i; + + for (i = 0; i < count; i++) + udelay (1000); +} + +/* Read up to 255 sectors + * + * Returns sectors read +*/ +static u8 do_one_read(int device, ulong block, u8 blkcnt, u16* buff, uchar lba48){ + + u8 sr = 0; + u8 status; + u64 blknr = (u64)block; + + if(!(sata_chk_status(&port[device].ioaddr,0)&ATA_DRDY)){ + printf("Device ata%d not ready\n",device); + return 0; + } + + /* Set up transfer */ +#ifdef CONFIG_LBA48 + if(lba48) { + /* write high bits */ + writeb(0, port[device].ioaddr.nsect_addr); + writeb((blknr >> 24) & 0xFF, + port[device].ioaddr.lbal_addr); + writeb((blknr >> 32) & 0xFF, + port[device].ioaddr.lbam_addr); + writeb((blknr >> 40) & 0xFF, + port[device].ioaddr.lbah_addr); + } +#endif + writeb(blkcnt, port[device].ioaddr.nsect_addr); + writeb(((blknr) >> 0) & 0xFF, + port[device].ioaddr.lbal_addr); + writeb((blknr >> 8) & 0xFF, port[device].ioaddr.lbam_addr); + writeb((blknr >> 16) & 0xFF, port[device].ioaddr.lbah_addr); + +#ifdef CONFIG_LBA48 + if(lba48) { + writeb(ATA_LBA, port[device].ioaddr.device_addr); + writeb(ATA_CMD_PIO_READ_EXT, + port[device].ioaddr.command_addr); + } else +#endif + { + writeb(ATA_LBA | ((blknr >> 24) & 0xF), + port[device].ioaddr.device_addr); + writeb(ATA_CMD_PIO_READ, + port[device].ioaddr.command_addr); + } + + status = sata_busy_wait(&port[device].ioaddr, ATA_BUSY, 10000, 1); + + if(status & ATA_BUSY) { + u8 err = 0; + + printf("Device %d not responding status %d\n",device, status); + err = readb(port[device].ioaddr.error_addr); + printf("Error reg = 0x%x\n", err); + + return (sr); + } + while(blkcnt--){ + + if(wait_for_irq(device,500)){ + printf("ata%u irq failed\n",device); + return sr; + } + + status = sata_chk_status(&port[device].ioaddr,0); + if(status & ATA_ERR){ + printf("ata%u error %d\n",device,readb(port[device].ioaddr.error_addr)); + return sr; + } + /* Read one sector */ + input_data (&port[device].ioaddr, buff, ATA_SECTOR_WORDS); + buff+=ATA_SECTOR_WORDS; + sr++; + + } + return sr; +} + + +ulong sata_read(int device, ulong block,lbaint_t blkcnt, void * buff) +{ + ulong n = 0,sread; + u16 *buffer = (u16 *)buff; + u8 status = 0; + u64 blknr=(u64)block; + unsigned char lba48 = 0; + +#ifdef CONFIG_LBA48 + if(blknr > 0xfffffff) { + if(!sata_dev_desc[device].lba48) { + printf("Drive doesn't support 48-bit addressing\n"); + return 0; + } + /* more than 28 bits used, use 48bit mode */ + lba48 = 1; + } +#endif + + while(blkcnt> 0) { + + if(blkcnt>255){ + sread=255; + }else{ + sread=blkcnt; + } + + status=do_one_read(device,blknr,sread,buffer,lba48); + if(status!=sread){ + printf("Read failed\n"); + return n; + } + + blkcnt-=sread; + blknr+=sread; + n+=sread; + buffer += sread*ATA_SECTOR_WORDS; + } + return n; +} + +ulong sata_write(int device, ulong block,lbaint_t blkcnt, const void * buff) +{ + ulong n = 0; + u16 *buffer=(u16 *)buff; + unsigned char status = 0, num = 0; + u64 blknr=(u64)block; +#ifdef CONFIG_LBA48 + unsigned char lba48 = 0; + + if (blknr >0xfffffff) { + if (!sata_dev_desc[device].lba48) { + printf("Drive doesn't support 48-bit addressing\n"); + return 0; + } + /* more than 28 bits used, use 48bit mode */ + lba48 = 1; + } +#endif + /*Port Number */ + num = device; + + while(blkcnt-- > 0) { + status = sata_busy_wait (&port[num].ioaddr, ATA_BUSY, 500, 0); + if(status & ATA_BUSY) { + printf ("ata%u failed to respond\n", + port[num].port_no); + return n; + } +#ifdef CONFIG_LBA48 + if(lba48) { + /* write high bits */ + writeb(0, port[num].ioaddr.nsect_addr); + writeb((blknr >> 24) & 0xFF, + port[num].ioaddr.lbal_addr); + writeb((blknr >> 32) & 0xFF, + port[num].ioaddr.lbam_addr); + writeb((blknr >> 40) & 0xFF, + port[num].ioaddr.lbah_addr); + } +#endif + writeb(1, port[num].ioaddr.nsect_addr); + writeb((blknr >> 0) & 0xFF, port[num].ioaddr.lbal_addr); + writeb((blknr >> 8) & 0xFF, port[num].ioaddr.lbam_addr); + writeb((blknr >> 16) & 0xFF, port[num].ioaddr.lbah_addr); +#ifdef CONFIG_LBA48 + if(lba48) { + writeb(ATA_LBA, port[num].ioaddr.device_addr); + writeb(ATA_CMD_PIO_WRITE_EXT, + port[num].ioaddr.command_addr); + } else +#endif + { + writeb(ATA_LBA | ((blknr >> 24) & 0xF), + port[num].ioaddr.device_addr); + writeb(ATA_CMD_PIO_WRITE, + port[num].ioaddr.command_addr); + } + + msleep(50); + /*may take up to 4 sec */ + status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 4000, 0); + if((status & (ATA_DRQ | ATA_BUSY | ATA_ERR)) + != ATA_DRQ) { + printf("Error no DRQ dev %d blk %ld: sts 0x%02x\n", + device, (ulong) blknr, status); + return (n); + } + + output_data(&port[num].ioaddr, buffer, ATA_SECTOR_WORDS); + readb(port[num].ioaddr.altstatus_addr); + udelay(50); + + ++n; + ++blknr; + buffer += ATA_SECTOR_WORDS; + } + return n; +} + +/* Driver implementation */ +static u8 sil_get_device_cache_line(pci_dev_t pdev) +{ + u8 cache_line = 0; + pci_read_config_byte(pdev, PCI_CACHE_LINE_SIZE, &cache_line); + return cache_line; +} + +int init_sata(int dev) +{ + static u8 init_done=0; + static int res=1; + pci_dev_t devno; + u8 cls = 0; + u16 cmd = 0; + u32 sconf = 0; + + if(init_done){ + return res; + } + + init_done=1; + + if((devno=pci_find_device(SIL_VEND_ID,SIL3114_DEVICE_ID,0))==-1){ + res=1; + return res; + } + + /* Read out all BARs, even though we only use MMIO from BAR5 */ + pci_read_config_dword(devno, PCI_BASE_ADDRESS_0, &iobase[0]); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_1, &iobase[1]); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_2, &iobase[2]); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_3, &iobase[3]); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_4, &iobase[4]); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_5, &iobase[5]); + + if ((iobase[0] == 0xFFFFFFFF) || (iobase[1] == 0xFFFFFFFF) || + (iobase[2] == 0xFFFFFFFF) || (iobase[3] == 0xFFFFFFFF) || + (iobase[4] == 0xFFFFFFFF) || (iobase[5] == 0xFFFFFFFF)) { + printf ("Error no base addr for SATA controller\n"); + res=1; + return res; + } + + /* mask off unused bits */ + iobase[0]&=0xfffffffc; + iobase[1]&=0xfffffff8; + iobase[2]&=0xfffffffc; + iobase[3]&=0xfffffff8; + iobase[4]&=0xfffffff0; + iobase[5]&=0xfffffc00; + + /* from sata_sil in Linux kernel */ + cls=sil_get_device_cache_line(devno); + if(cls){ + cls >>= 3; + cls++; /* cls = (line_size/8)+1 */ + writel(cls<<8|cls,iobase[5]+VND_FIFOCFG_CH0); + writel(cls<<8|cls,iobase[5]+VND_FIFOCFG_CH1); + writel(cls<<8|cls,iobase[5]+VND_FIFOCFG_CH2); + writel(cls<<8|cls,iobase[5]+VND_FIFOCFG_CH3); + }else{ + printf("Cache line not set. Driver may not function\n"); + } + + /* Enable operation */ + pci_read_config_word(devno, PCI_COMMAND, &cmd); + cmd |= PCI_COMMAND_MASTER | PCI_COMMAND_IO | PCI_COMMAND_MEMORY; + pci_write_config_word(devno, PCI_COMMAND, cmd); + + /* Disable interrupt usage */ + pci_read_config_dword(devno, VND_SYSCONFSTAT ,&sconf); + sconf |= (VND_SYSCONFSTAT_CHN_0_INTBLOCK | VND_SYSCONFSTAT_CHN_1_INTBLOCK); + pci_write_config_dword(devno, VND_SYSCONFSTAT, sconf); + + res=0; + return res; +} + +/* Check if device is connected to port */ +int sata_bus_probe(int portno){ + u32 port=iobase[5]; + u32 val; + switch(portno){ + case 0: + port+=VND_SSTATUS_CH0; + break; + case 1: + port+=VND_SSTATUS_CH1; + break; + case 2: + port+=VND_SSTATUS_CH2; + break; + case 3: + port+=VND_SSTATUS_CH3; + break; + default: + return 0; + } + val=readl(port); + if((val&SATA_DET_PRES)==SATA_DET_PRES){ + return 1; + }else{ + return 0; + } +} + +int sata_phy_reset(int portno){ + u32 port=iobase[5]; + u32 val; + switch(portno){ + case 0: + port+=VND_SCONTROL_CH0; + break; + case 1: + port+=VND_SCONTROL_CH1; + break; + case 2: + port+=VND_SCONTROL_CH2; + break; + case 3: + port+=VND_SCONTROL_CH3; + break; + default: + return 0; + } + val=readl(port); + writel(val|SATA_SC_DET_RST,port); + msleep(150); + writel(val&~SATA_SC_DET_RST,port); + return 0; +} + +int scan_sata(int dev) +{ + /* A bit brain dead, but the code has a legacy */ + switch(dev){ + case 0: + port[0].port_no = 0; + port[0].ioaddr.cmd_addr = iobase[5]+VND_TF0_CH0; + port[0].ioaddr.altstatus_addr = port[0].ioaddr.ctl_addr = + (iobase[5]+VND_TF2_CH0)|ATA_PCI_CTL_OFS; + port[0].ioaddr.bmdma_addr = iobase[5]+VND_BMDMA_CH0; + break; + case 1: + port[1].port_no = 0; + port[1].ioaddr.cmd_addr = iobase[5]+VND_TF0_CH1; + port[1].ioaddr.altstatus_addr = port[1].ioaddr.ctl_addr = + (iobase[5]+VND_TF2_CH1)|ATA_PCI_CTL_OFS; + port[1].ioaddr.bmdma_addr = iobase[5]+VND_BMDMA_CH1; + break; + case 2: + port[2].port_no = 0; + port[2].ioaddr.cmd_addr = iobase[5]+VND_TF0_CH2; + port[2].ioaddr.altstatus_addr = port[2].ioaddr.ctl_addr = + (iobase[5]+VND_TF2_CH2)|ATA_PCI_CTL_OFS; + port[2].ioaddr.bmdma_addr = iobase[5]+VND_BMDMA_CH2; + break; + case 3: + port[3].port_no = 0; + port[3].ioaddr.cmd_addr = iobase[5]+VND_TF0_CH3; + port[3].ioaddr.altstatus_addr = port[3].ioaddr.ctl_addr = + (iobase[5]+VND_TF2_CH3)|ATA_PCI_CTL_OFS; + port[3].ioaddr.bmdma_addr = iobase[5]+VND_BMDMA_CH3; + break; + default: + printf("Tried to scan unknown port: ata%d\n",dev); + return 1; + } + + /* Initialize other registers */ + sata_port(&port[dev].ioaddr); + + /* Check for attached device */ + if(!sata_bus_probe(dev)){ + port[dev].port_state=0; + PRINTF("SATA#%d port is not present\n",dev); + }else{ + PRINTF("SATA#%d port is present\n",dev); + if (sata_bus_softreset (dev)) { + /* soft reset failed, try a hard one */ + sata_phy_reset(dev); + if(sata_bus_softreset(dev)){ + port[dev].port_state = 0; + }else{ + port[dev].port_state = 1; + } + }else{ + port[dev].port_state = 1; + } + } + if(port[dev].port_state==1){ + /* Probe device and set xfer mode */ + sata_identify(dev,0); + set_Feature_cmd(dev,0); + } + + return 0; +} diff --git a/drivers/block/sata_sil3114.h b/drivers/block/sata_sil3114.h new file mode 100644 index 0000000..8360ad6 --- /dev/null +++ b/drivers/block/sata_sil3114.h @@ -0,0 +1,148 @@ +/* + * Copyright (C) Excito Elektronik i Skåne AB, All rights reserved. + * Author: Tor Krill tor@excito.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef SATA_SIL3114_H +#define SATA_SIL3114_H + +struct sata_ioports { + unsigned long cmd_addr; + unsigned long data_addr; + unsigned long error_addr; + unsigned long feature_addr; + unsigned long nsect_addr; + unsigned long lbal_addr; + unsigned long lbam_addr; + unsigned long lbah_addr; + unsigned long device_addr; + unsigned long status_addr; + unsigned long command_addr; + unsigned long altstatus_addr; + unsigned long ctl_addr; + unsigned long bmdma_addr; + unsigned long scr_addr; +}; + +struct sata_port { + unsigned char port_no; /* primary=0, secondary=1 */ + struct sata_ioports ioaddr; /* ATA cmd/ctl/dma reg blks */ + unsigned char ctl_reg; + unsigned char last_ctl; + unsigned char port_state; /* 1-port is available and */ + /* 0-port is not available */ + unsigned char dev_mask; +}; + +/* Missing ata defines */ +#define ATA_CMD_STANDBY 0xE2 +#define ATA_CMD_STANDBYNOW1 0xE0 +#define ATA_CMD_IDLE 0xE3 +#define ATA_CMD_IDLEIMMEDIATE 0xE1 + + +/* Defines for SIL3114 chip */ + +/* PCI defines */ +#define SIL_VEND_ID 0x1095 +#define SIL3114_DEVICE_ID 0x3114 + +/* some vendor specific registers */ +#define VND_SYSCONFSTAT 0x88 /* System Configuration Status and Command */ +#define VND_SYSCONFSTAT_CHN_0_INTBLOCK (1<<22) +#define VND_SYSCONFSTAT_CHN_1_INTBLOCK (1<<23) +#define VND_SYSCONFSTAT_CHN_2_INTBLOCK (1<<24) +#define VND_SYSCONFSTAT_CHN_3_INTBLOCK (1<<25) + +/* internal registers mapped by BAR5 */ +/* SATA Control*/ +#define VND_SCONTROL_CH0 0x100 +#define VND_SCONTROL_CH1 0x180 +#define VND_SCONTROL_CH2 0x300 +#define VND_SCONTROL_CH3 0x380 + +#define SATA_SC_IPM_T2P (1<<16) +#define SATA_SC_IPM_T2S (2<<16) +#define SATA_SC_SPD_1_5 (1<<4) +#define SATA_SC_SPD_3_0 (2<<4) +#define SATA_SC_DET_RST (1) /* ATA Reset sequence */ +#define SATA_SC_DET_PDIS (4) /* PHY Disable */ + +/* SATA Status */ +#define VND_SSTATUS_CH0 0x104 +#define VND_SSTATUS_CH1 0x184 +#define VND_SSTATUS_CH2 0x304 +#define VND_SSTATUS_CH3 0x384 + +#define SATA_SS_IPM_ACTIVE (1<<8) +#define SATA_SS_IPM_PARTIAL (2<<8) +#define SATA_SS_IPM_SLUMBER (6<<8) +#define SATA_SS_SPD_1_5 (1<<4) +#define SATA_SS_SPD_3_0 (2<<4) +#define SATA_DET_P_NOPHY (1) /* Device presence but no PHY connection established */ +#define SATA_DET_PRES (3) /* Device presence and active PHY */ +#define SATA_DET_OFFLINE (4) /* Device offline or in loopback mode */ + +/* Task file registers in BAR5 mapping */ +#define VND_TF0_CH0 0x80 +#define VND_TF0_CH1 0xc0 +#define VND_TF0_CH2 0x280 +#define VND_TF0_CH3 0x2c0 +#define VND_TF1_CH0 0x88 +#define VND_TF1_CH1 0xc8 +#define VND_TF1_CH2 0x288 +#define VND_TF1_CH3 0x2c8 +#define VND_TF2_CH0 0x88 +#define VND_TF2_CH1 0xc8 +#define VND_TF2_CH2 0x288 +#define VND_TF2_CH3 0x2c8 + +#define VND_BMDMA_CH0 0x00 +#define VND_BMDMA_CH1 0x08 +#define VND_BMDMA_CH2 0x200 +#define VND_BMDMA_CH3 0x208 +#define VND_BMDMA2_CH0 0x10 +#define VND_BMDMA2_CH1 0x18 +#define VND_BMDMA2_CH2 0x210 +#define VND_BMDMA2_CH3 0x218 + +/* FIFO control */ +#define VND_FIFOCFG_CH0 0x40 +#define VND_FIFOCFG_CH1 0x44 +#define VND_FIFOCFG_CH2 0x240 +#define VND_FIFOCFG_CH3 0x244 + +/* Task File configuration and status */ +#define VND_TF_CNST_CH0 0xa0 +#define VND_TF_CNST_CH1 0xe0 +#define VND_TF_CNST_CH2 0x2a0 +#define VND_TF_CNST_CH3 0x2e0 + +#define VND_TF_CNST_BFCMD (1<<1) +#define VND_TF_CNST_CHNRST (1<<2) +#define VND_TF_CNST_VDMA (1<<10) +#define VND_TF_CNST_INTST (1<<11) +#define VND_TF_CNST_WDTO (1<<12) +#define VND_TF_CNST_WDEN (1<<13) +#define VND_TF_CNST_WDIEN (1<<14) + +/* for testing */ +#define VND_SSDR 0x04c /* System Software Data Register */ +#define VND_FMACS 0x050 /* Flash Memory Address control and status */ + +#endif
- Copyright (C) Excito Elektronik i Sk�ne AB, All rights reserved.
- Author: Tor Krill tor@excito.com
- MA 02111-1307 USA
- This is a driver for Silicon Image sil3114 sata chip modelled on
- the ata_piix driver
Is it possible to use debug() instead of PRINTF?
please replace with static u32 iobase[6] = {0, 0, 0, 0, 0, 0}; /* PCI BAR registers for our device */
- while(words--){
^ please add a space
^ same
- while(words--){
- u8 status = 0;
- port[num].dev_mask = 1;
- port[num].ctl_reg = 0x08; /*Default value of control reg */
- writeb(port[num].ctl_reg, port[num].ioaddr.ctl_addr);
- udelay(10);
- writeb(port[num].ctl_reg | ATA_SRST, port[num].ioaddr.ctl_addr);
- udelay(10);
- /* spec mandates ">= 2ms" before checking status.
- msleep(150);
- status = sata_busy_wait(&port[num].ioaddr, ATA_BUSY, 300, 0);
- while((status & ATA_BUSY)) {
msleep(100);
Could you check the coding style, there is also some whitespace issue
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Tor Krill
