[U-Boot-Users] [PATCH 1/4] ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of i2c_init()
ARM DaVinci: Remove duplicate definitions of MACH_TYPE and prototype of i2c_init().
Signed-off-by: Hugo Villeneuve hugo.villeneuve@lyrtech.com
board/davinci/dv-evm/dv_board.c | 3 --- board/davinci/schmoogie/dv_board.c | 3 --- board/davinci/sonata/dv_board.c | 3 --- 3 files changed, 0 insertions(+), 9 deletions(-)
diff --git a/board/davinci/dv-evm/dv_board.c b/board/davinci/dv-evm/dv_board.c index 88b1e57..454ac21 100644 --- a/board/davinci/dv-evm/dv_board.c +++ b/board/davinci/dv-evm/dv_board.c @@ -29,11 +29,8 @@ #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h>
-#define MACH_TYPE_DAVINCI_EVM 901 - DECLARE_GLOBAL_DATA_PTR;
-extern void i2c_init(int speed, int slaveaddr); extern void timer_init(void); extern int eth_hw_init(void); extern phy_t phy; diff --git a/board/davinci/schmoogie/dv_board.c b/board/davinci/schmoogie/dv_board.c index 13d2195..529a437 100644 --- a/board/davinci/schmoogie/dv_board.c +++ b/board/davinci/schmoogie/dv_board.c @@ -29,11 +29,8 @@ #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h>
-#define MACH_TYPE_SCHMOOGIE 1255 - DECLARE_GLOBAL_DATA_PTR;
-extern void i2c_init(int speed, int slaveaddr); extern void timer_init(void); extern int eth_hw_init(void); extern phy_t phy; diff --git a/board/davinci/sonata/dv_board.c b/board/davinci/sonata/dv_board.c index e8665e5..2db40c8 100644 --- a/board/davinci/sonata/dv_board.c +++ b/board/davinci/sonata/dv_board.c @@ -29,11 +29,8 @@ #include <asm/arch/hardware.h> #include <asm/arch/emac_defs.h>
-#define MACH_TYPE_SONATA 1254 - DECLARE_GLOBAL_DATA_PTR;
Applied. Thanks.
Best regards, J.
Hugo Villeneuve
Jean-Christophe PLAGNIOL-VILLARD
