[U-Boot] [PATCH 0/3] board:tricorder: late fixups for 2014.04
These fixups are required for tricorder board to run with 2014.04.
One big change is a different ecc layout which came in by Pekon Gupta's changes to the omap_gpmc driver. Another point was changed behaviour of omap_gpio driver, we need to switch the clocks now explicitely.
Thomas, could you please chack the patches and send your ACK ASAP?
Best regards
Andreas Bießmann
Andreas Bießmann (3): board:tricorder: always work with valid eeprom data board:tricorder: enable omap_gpio clocks board:tricorder: fixup SPL OOB layout
board/corscience/tricorder/tricorder.c | 2 ++ include/configs/tricorder.h | 14 +++++++++----- 2 files changed, 11 insertions(+), 5 deletions(-)
From: Andreas Bießmann andreas.biessmann@corscience.de
Commit 890880583d84607e36b52a785a96b167728bbf73 introduced EEPROM parsing and board detection but faild to return a valid tricorder_eeprom struct for backup case. When pressing S200 while reading EEPROM we ignore the value. We returned falsely a tricorder_eeprom struct with uninitialized data which is just garbage. Initialize it by zeroing the whole structure.
Signed-off-by: Andreas Bießmann andreas.biessmann@corscience.de Cc: Thomas Weber thomas.weber@corscience.de Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com ---
board/corscience/tricorder/tricorder.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/corscience/tricorder/tricorder.c b/board/corscience/tricorder/tricorder.c index 2dfcb27..9e81bf3 100644 --- a/board/corscience/tricorder/tricorder.c +++ b/board/corscience/tricorder/tricorder.c @@ -79,6 +79,8 @@ static void get_eeprom(struct tricorder_eeprom *eeprom) } else { panic("Could not get board revision\n"); } + } else { + memset(eeprom, 0, TRICORDER_EEPROM_SIZE); } }
include/configs/tricorder.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 62f97d2..a609861 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -63,6 +63,9 @@ /* GPIO support */ #define CONFIG_OMAP_GPIO
+/* GPIO banks */ +#define CONFIG_OMAP3_GPIO_2 /* GPIO32..63 are in GPIO bank 2 */ + /* LED support */ #define CONFIG_STATUS_LED #define CONFIG_BOARD_SPECIFIC_LED
Commit d016dc42cedbf6102e100fa9ecb58462edfb14f8 changed the layout of BCH8 SW on omap3 boards. We need to adopt the ecc layout for the nand_spl_simle driver to avoid wrong ecc errors.
include/configs/tricorder.h | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index a609861..80985a2 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -368,11 +368,12 @@ #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS -#define CONFIG_SYS_NAND_ECCPOS {12, 13, 14, 15, 16, 17, 18, 19, 20,\ - 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33,\ - 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46,\ - 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59,\ - 60, 61, 62, 63} +#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, \ + 13, 14, 16, 17, 18, 19, 20, 21, 22, \ + 23, 24, 25, 26, 27, 28, 30, 31, 32, \ + 33, 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 44, 45, 46, 47, 48, 49, 50, 51, \ + 52, 53, 54, 55, 56}
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 13
Andreas Bießmann
