[U-Boot] [PATCH 1/2] core: ofnode: Fix ofnode_get_addr_size_index function
Currently the else part of ofnode_get_addr_size_index function does not fetch addresses based on the index but rather just returns the base address. Fix that.
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/core/ofnode.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index b7b7ad3..c80e1cb 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -253,12 +253,12 @@ int ofnode_read_size(ofnode node, const char *propname)
fdt_addr_t ofnode_get_addr_index(ofnode node, int index) { + int na, ns; + u64 size; + if (ofnode_is_np(node)) { const __be32 *prop_val; uint flags; - u64 size; - int na; - int ns;
prop_val = of_get_address(ofnode_to_np(node), index, &size, &flags); @@ -274,8 +274,11 @@ fdt_addr_t ofnode_get_addr_index(ofnode node, int index) return of_read_number(prop_val, na); } } else { - return fdt_get_base_address(gd->fdt_blob, - ofnode_to_offset(node)); + na = ofnode_read_simple_addr_cells(ofnode_get_parent(node)); + ns = ofnode_read_simple_size_cells(ofnode_get_parent(node)); + return fdtdec_get_addr_size_fixed(gd->fdt_blob, + ofnode_to_offset(node), "reg", + index, na, ns, &size, true); }
return FDT_ADDR_T_NONE;
Add ofnode_get_addr_size_index function to fetch the address and size of the reg space based on index.
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/core/ofnode.c | 14 ++++++++++---- include/dm/ofnode.h | 13 +++++++++++++ 2 files changed, 23 insertions(+), 4 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index c80e1cb..b98b0b9 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -251,16 +251,15 @@ int ofnode_read_size(ofnode node, const char *propname) return -EINVAL; }
-fdt_addr_t ofnode_get_addr_index(ofnode node, int index) +fdt_addr_t ofnode_get_addr_size_index(ofnode node, int index, u64 *size) { int na, ns; - u64 size;
- prop_val = of_get_address(ofnode_to_np(node), index, &size, + prop_val = of_get_address(ofnode_to_np(node), index, size, &flags); if (!prop_val) return FDT_ADDR_T_NONE; @@ -278,12 +277,19 @@ fdt_addr_t ofnode_get_addr_index(ofnode node, int index) ns = ofnode_read_simple_size_cells(ofnode_get_parent(node)); return fdtdec_get_addr_size_fixed(gd->fdt_blob, ofnode_to_offset(node), "reg", - index, na, ns, &size, true); + index, na, ns, size, true); }
return FDT_ADDR_T_NONE; }
+fdt_addr_t ofnode_get_addr_index(ofnode node, int index) +{ + u64 size; + + return ofnode_get_addr_size_index(node, index, &size); +} + fdt_addr_t ofnode_get_addr(ofnode node) { return ofnode_get_addr_index(node, 0); diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 2fc9fa3..149acaa 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -356,6 +356,19 @@ int ofnode_read_size(ofnode node, const char *propname); phys_addr_t ofnode_get_addr_index(ofnode node, int index);
/** + * ofnode_get_addr_size_index() - get an address/size from a node + * based on index + * + * This reads the register address from a node + * + * @node: node to read from + * @index: Index of address to read (0 for first) + * @size: Pointer to size of the address + * @return address, or FDT_ADDR_T_NONE if not present or invalid + */ +phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, u64 *size); + +/** * ofnode_get_addr() - get an address from a node * * This reads the register address from a node
Keerthy
