[U-Boot] [PATCH 0/2] i.MX6 (DQ/DLS): use macros for mux and pad declarations
Updates i.MX6DQ and i.MXDLS mux/pad declarations to be declared using macros to allow their use in a binary supporting all four variants of the pin-compatible processors.
This patch set was broken into two parts to allow validation using "git show --word-diff".
The patches apply to u-boot-imx/master with commit a31d3efa (a previous and superfluous white-space change) reverted.
Compile-tested against all mx6 boards. Run-time tested against nitrogen6q.
Eric Nelson (2): i.MX6 (DQ/DLS): use macros for mux and pad declarations i.MX6DQ/DLS: whitespace: Align MX6_PAD_DECL columns
arch/arm/include/asm/arch-mx6/mx6-pins.h | 33 +- arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 2145 ++++++++++++------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 2054 ++++++++++++----------- board/barco/titanium/titanium.c | 2 +- board/freescale/mx6qarm2/mx6qarm2.c | 2 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 2 +- 6 files changed, 2127 insertions(+), 2111 deletions(-)
This allows the use of either or both declarations from the files mx6q_pins.h and mx6dl_pins.h.
All board files should include <asm/arch/mx6-pins.h> with one of the following defined in boards.cfg MX6Q - for boards targeting i.MX6Q or i.MX6D MX6DL - for boards targeting i.MX6DL MX6S - for boards targeting i.MX6S MX6QDL - for boards that support any of the above with run-time detection
Pad declarations will be MX6_PAD_x for single-variant boards and MX6Q_PAD_x and MX6DL_PAD_x for boards supporting both processor classes.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/include/asm/arch-mx6/mx6-pins.h | 33 +- arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 2143 ++++++++++++------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 2051 ++++++++++++----------- board/barco/titanium/titanium.c | 2 +- board/freescale/mx6qarm2/mx6qarm2.c | 2 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 2 +- 6 files changed, 2121 insertions(+), 2112 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index 1c9e3fe..dcd7f8f 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -6,18 +6,37 @@ #ifndef __ASM_ARCH_MX6_PINS_H__ #define __ASM_ARCH_MX6_PINS_H__
-#ifdef CONFIG_MX6Q +#include <asm/imx-common/iomux-v3.h> + +#define MX6_PAD_DECLARE(prefix, name, pco, mc, mm, sio, si, pc) \ + prefix##name = IOMUX_PAD(pco, mc, mm, sio, si, pc) + +#ifdef CONFIG_MX6QDL +enum { +#define MX6_PAD_DECL(name, pco, mc, mm, sio, si, pc) \ + MX6_PAD_DECLARE(MX6Q_PAD_,name, pco, mc, mm, sio, si, pc), #include "mx6q_pins.h" -#else -#if defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) +#undef MX6_PAD_DECL +#define MX6_PAD_DECL(name, pco, mc, mm, sio, si, pc) \ + MX6_PAD_DECLARE(MX6DL_PAD_,name, pco, mc, mm, sio, si, pc), #include "mx6dl_pins.h" -#else -#if defined(CONFIG_MX6SL) +}; +#elif defined(CONFIG_MX6Q) +enum { +#define MX6_PAD_DECL(name, pco, mc, mm, sio, si, pc) \ + MX6_PAD_DECLARE(MX6_PAD_,name, pco, mc, mm, sio, si, pc), +#include "mx6q_pins.h" +}; +#elif defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) +enum { +#define MX6_PAD_DECL(name, pco, mc, mm, sio, si, pc) \ + MX6_PAD_DECLARE(MX6_PAD_,name, pco, mc, mm, sio, si, pc), +#include "mx6dl_pins.h" +}; +#elif defined(CONFIG_MX6SL) #include "mx6sl_pins.h" #else #error "Please select cpu" -#endif /* CONFIG_MX6SL */ -#endif /* CONFIG_MX6DL or CONFIG_MX6S */ #endif /* CONFIG_MX6Q */
#endif /*__ASM_ARCH_MX6_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 47d704b..9b132a2 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -6,1078 +6,1073 @@
#ifndef __ASM_ARCH_MX6_MX6DL_PINS_H__ #define __ASM_ARCH_MX6_MX6DL_PINS_H__ - -#include <asm/imx-common/iomux-v3.h> - -enum { - MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0360, 0x004C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0360, 0x004C, 2, 0x07F8, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), - MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0364, 0x0050, 2, 0x0800, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), - MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), - MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), - MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), - MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), - MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0378, 0x0064, 3, 0x0910, 0, 0), - MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x037C, 0x0068, 3, 0x0910, 1, 0), - MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0380, 0x006C, 3, 0x0918, 0, 0), - MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0384, 0x0070, 3, 0x0918, 1, 0), - MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0388, 0x0074, 2, 0x07D8, 0, 0), - MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0388, 0x0074, 3, 0x08C0, 0, 0), - MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x038C, 0x0078, 2, 0x07E0, 0, 0), - MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x038C, 0x0078, 3, 0x08CC, 0, 0), - MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0390, 0x007C, 2, 0x07DC, 0, 0), - MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0390, 0x007C, 3, 0x08C4, 0, 0), - MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0394, 0x0080, 2, 0x07E4, 0, 0), - MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0394, 0x0080, 3, 0x08D0, 0, 0), - MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0398, 0x0084, 2, 0x07F4, 0, 0), - MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0398, 0x0084, 3, 0x08C8, 0, 0), - MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0), - MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x039C, 0x0088, 2, 0x07FC, 0, 0), - MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x039C, 0x0088, 3, 0x08D4, 0, 0), - MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0), - MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_DISP_CLK__LCD_CLK = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__LCD_WR_RWN = IOMUX_PAD(0x03B0, 0x009C, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN15__LCD_ENABLE = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__LCD_RD_E = IOMUX_PAD(0x03B4, 0x00A0, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN2__LCD_HSYNC = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x08D8, 0, 0), - MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__LCD_RS = IOMUX_PAD(0x03B8, 0x00A4, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN3__LCD_VSYNC = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__LCD_CS = IOMUX_PAD(0x03BC, 0x00A8, 8, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN4__LCD_BUSY = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x08D8, 1, 0), - MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x092C, 0, 0), - MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__LCD_RESET = IOMUX_PAD(0x03C0, 0x00AC, 8, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT0__LCD_DATA00 = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT1__LCD_DATA01 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__LCD_DATA10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT11__LCD_DATA11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT12__LCD_DATA12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT13__LCD_DATA13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), - MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT14__LCD_DATA14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), - MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT15__LCD_DATA15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x07E8, 0, 0), - MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0804, 0, 0), - MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT16__LCD_DATA16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x07FC, 1, 0), - MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), - MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x08E8, 0, 0), - MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT17__LCD_DATA17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x07F8, 1, 0), - MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), - MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x08EC, 0, 0), - MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT18__LCD_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x0800, 1, 0), - MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), - MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), - MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT19__LCD_DATA19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x07F4, 1, 0), - MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), - MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), - MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__LCD_DATA02 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT20__LCD_DATA20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x07D8, 1, 0), - MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), - MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT21__LCD_DATA21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x07E0, 1, 0), - MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), - MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT22__LCD_DATA22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x0400, 0x00EC, 2, 0x07DC, 1, 0), - MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), - MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT23__LCD_DATA23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x07E4, 1, 0), - MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), - MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT3__LCD_DATA03 = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0408, 0x00F4, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__GPIO4_IO24 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT4__LCD_DATA04 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__GPIO4_IO25 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT5__LCD_DATA05 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT6__LCD_DATA06 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x0414, 0x0100, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT7__LCD_DATA07 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x0418, 0x0104, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__GPIO4_IO28 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT8__LCD_DATA08 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x041C, 0x0108, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT9__LCD_DATA09 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x0420, 0x010C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x04E0, 0x0110, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x04E0, 0x0110, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A16__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x04E0, 0x0110, 2, 0x08B8, 0, 0), - MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x04E0, 0x0110, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x04E0, 0x0110, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A16__EPDC_DATA00 = IOMUX_PAD(0x04E0, 0x0110, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x04E4, 0x0114, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_CSI1_DATA12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), - MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x04E4, 0x0114, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x04E4, 0x0114, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A17__EPDC_PWR_STAT = IOMUX_PAD(0x04E4, 0x0114, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x04E8, 0x0118, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_CSI1_DATA13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), - MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x04E8, 0x0118, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x04E8, 0x0118, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A18__EPDC_PWR_CTRL0 = IOMUX_PAD(0x04E8, 0x0118, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x04EC, 0x011C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_CSI1_DATA14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), - MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x04EC, 0x011C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x04EC, 0x011C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A19__EPDC_PWR_CTRL1 = IOMUX_PAD(0x04EC, 0x011C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x04F0, 0x0120, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), - MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x04F0, 0x0120, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x04F0, 0x0120, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A20__EPDC_PWR_CTRL2 = IOMUX_PAD(0x04F0, 0x0120, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x04F4, 0x0124, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_CSI1_DATA16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), - MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x04F4, 0x0124, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x04F4, 0x0124, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A21__EPDC_GDCLK = IOMUX_PAD(0x04F4, 0x0124, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x04F8, 0x0128, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_CSI1_DATA17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), - MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x04F8, 0x0128, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x04F8, 0x0128, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A22__EPDC_GDSP = IOMUX_PAD(0x04F8, 0x0128, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x04FC, 0x012C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_CSI1_DATA18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), - MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x04FC, 0x012C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x04FC, 0x012C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x04FC, 0x012C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A23__EPDC_GDOE = IOMUX_PAD(0x04FC, 0x012C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x0500, 0x0130, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_CSI1_DATA19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), - MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x0500, 0x0130, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x0500, 0x0130, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x0500, 0x0130, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A24__EPDC_GDRL = IOMUX_PAD(0x0500, 0x0130, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x0504, 0x0134, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x0504, 0x0134, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x0504, 0x0134, 2, 0x0000, 0, 0), - MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x0504, 0x0134, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x0504, 0x0134, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x0504, 0x0134, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0504, 0x0134, 6, 0x085C, 0, 0), - MX6_PAD_EIM_A25__EPDC_DATA15 = IOMUX_PAD(0x0504, 0x0134, 8, 0x0000, 0, 0), - MX6_PAD_EIM_A25__EIM_ACLK_FREERUN = IOMUX_PAD(0x0504, 0x0134, 9, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x0508, 0x0138, 1, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x0508, 0x0138, 5, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__EPDC_SDCE9 = IOMUX_PAD(0x0508, 0x0138, 8, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x050C, 0x013C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x050C, 0x013C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x050C, 0x013C, 2, 0x07F4, 2, 0), - MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x050C, 0x013C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__EPDC_DATA06 = IOMUX_PAD(0x050C, 0x013C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0510, 0x0140, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0510, 0x0140, 1, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0510, 0x0140, 2, 0x07FC, 2, 0), - MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0510, 0x0140, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__EPDC_DATA08 = IOMUX_PAD(0x0510, 0x0140, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x0514, 0x0144, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x0514, 0x0144, 1, 0x07D8, 2, 0), - MX6_PAD_EIM_D16__IPU1_DI0_PIN05 = IOMUX_PAD(0x0514, 0x0144, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D16__IPU1_CSI1_DATA18 = IOMUX_PAD(0x0514, 0x0144, 3, 0x08A8, 1, 0), - MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x0514, 0x0144, 4, 0x0864, 0, 0), - MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x0514, 0x0144, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0), - MX6_PAD_EIM_D16__EPDC_DATA10 = IOMUX_PAD(0x0514, 0x0144, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x0518, 0x0148, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x0518, 0x0148, 1, 0x07DC, 2, 0), - MX6_PAD_EIM_D17__IPU1_DI0_PIN06 = IOMUX_PAD(0x0518, 0x0148, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D17__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x0518, 0x0148, 3, 0x08B8, 1, 0), - MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x0518, 0x0148, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x0518, 0x0148, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0), - MX6_PAD_EIM_D17__EPDC_VCOM0 = IOMUX_PAD(0x0518, 0x0148, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x051C, 0x014C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x051C, 0x014C, 1, 0x07E0, 2, 0), - MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x051C, 0x014C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D18__IPU1_CSI1_DATA17 = IOMUX_PAD(0x051C, 0x014C, 3, 0x08A4, 1, 0), - MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x051C, 0x014C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x051C, 0x014C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0), - MX6_PAD_EIM_D18__EPDC_VCOM1 = IOMUX_PAD(0x051C, 0x014C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x0520, 0x0150, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x0520, 0x0150, 1, 0x07E8, 1, 0), - MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x0520, 0x0150, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D19__IPU1_CSI1_DATA16 = IOMUX_PAD(0x0520, 0x0150, 3, 0x08A0, 1, 0), - MX6_PAD_EIM_D19__UART1_CTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x0520, 0x0150, 4, 0x08F8, 0, 0), - MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x0520, 0x0150, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x0520, 0x0150, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EPDC_DATA12 = IOMUX_PAD(0x0520, 0x0150, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x0524, 0x0154, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x0524, 0x0154, 1, 0x0808, 0, 0), - MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x0524, 0x0154, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D20__IPU1_CSI1_DATA15 = IOMUX_PAD(0x0524, 0x0154, 3, 0x089C, 1, 0), - MX6_PAD_EIM_D20__UART1_CTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x0524, 0x0154, 4, 0x08F8, 1, 0), - MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x0524, 0x0154, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EPIT2_OUT = IOMUX_PAD(0x0524, 0x0154, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x0528, 0x0158, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x0528, 0x0158, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x0528, 0x0158, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0528, 0x0158, 3, 0x088C, 0, 0), - MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x0528, 0x0158, 4, 0x0920, 0, 0), - MX6_PAD_EIM_D21__GPIO3_IO21 = IOMUX_PAD(0x0528, 0x0158, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0), - MX6_PAD_EIM_D21__SPDIF_IN = IOMUX_PAD(0x0528, 0x0158, 7, 0x08F0, 0, 0), - MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x052C, 0x015C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x052C, 0x015C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_DI0_PIN01 = IOMUX_PAD(0x052C, 0x015C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_CSI1_DATA10 = IOMUX_PAD(0x052C, 0x015C, 3, 0x0888, 0, 0), - MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x052C, 0x015C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x052C, 0x015C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D22__EPDC_SDCE6 = IOMUX_PAD(0x052C, 0x015C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x0530, 0x0160, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x0530, 0x0160, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_CTS_B = IOMUX_PAD(0x0530, 0x0160, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_RTS_B = IOMUX_PAD(0x0530, 0x0160, 2, 0x0908, 0, 0), - MX6_PAD_EIM_D23__UART1_DCD_B = IOMUX_PAD(0x0530, 0x0160, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x0530, 0x0160, 4, 0x08B0, 0, 0), - MX6_PAD_EIM_D23__GPIO3_IO23 = IOMUX_PAD(0x0530, 0x0160, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN02 = IOMUX_PAD(0x0530, 0x0160, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x0530, 0x0160, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D23__EPDC_DATA11 = IOMUX_PAD(0x0530, 0x0160, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D24__EIM_DATA24 = IOMUX_PAD(0x0534, 0x0164, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D24__ECSPI4_SS2 = IOMUX_PAD(0x0534, 0x0164, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_TX_DATA = IOMUX_PAD(0x0534, 0x0164, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_RX_DATA = IOMUX_PAD(0x0534, 0x0164, 2, 0x090C, 0, 0), - MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x0534, 0x0164, 3, 0x07EC, 0, 0), - MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x0534, 0x0164, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D24__GPIO3_IO24 = IOMUX_PAD(0x0534, 0x0164, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x0534, 0x0164, 6, 0x07BC, 1, 0), - MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x0534, 0x0164, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D24__EPDC_SDCE7 = IOMUX_PAD(0x0534, 0x0164, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x0538, 0x0168, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x0538, 0x0168, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_TX_DATA = IOMUX_PAD(0x0538, 0x0168, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_RX_DATA = IOMUX_PAD(0x0538, 0x0168, 2, 0x090C, 1, 0), - MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x0538, 0x0168, 3, 0x07F0, 0, 0), - MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x0538, 0x0168, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D25__GPIO3_IO25 = IOMUX_PAD(0x0538, 0x0168, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x0538, 0x0168, 6, 0x07B8, 1, 0), - MX6_PAD_EIM_D25__UART1_DSR_B = IOMUX_PAD(0x0538, 0x0168, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D25__EPDC_SDCE8 = IOMUX_PAD(0x0538, 0x0168, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x053C, 0x016C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x053C, 0x016C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x053C, 0x016C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI1_DATA14 = IOMUX_PAD(0x053C, 0x016C, 3, 0x0898, 1, 0), - MX6_PAD_EIM_D26__UART2_TX_DATA = IOMUX_PAD(0x053C, 0x016C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D26__UART2_RX_DATA = IOMUX_PAD(0x053C, 0x016C, 4, 0x0904, 0, 0), - MX6_PAD_EIM_D26__GPIO3_IO26 = IOMUX_PAD(0x053C, 0x016C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_SISG2 = IOMUX_PAD(0x053C, 0x016C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DISP1_DATA22 = IOMUX_PAD(0x053C, 0x016C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D26__EPDC_SDOED = IOMUX_PAD(0x053C, 0x016C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x0540, 0x0170, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x0540, 0x0170, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x0540, 0x0170, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI1_DATA13 = IOMUX_PAD(0x0540, 0x0170, 3, 0x0894, 1, 0), - MX6_PAD_EIM_D27__UART2_TX_DATA = IOMUX_PAD(0x0540, 0x0170, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x0540, 0x0170, 4, 0x0904, 1, 0), - MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x0540, 0x0170, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_SISG3 = IOMUX_PAD(0x0540, 0x0170, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DISP1_DATA23 = IOMUX_PAD(0x0540, 0x0170, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D27__EPDC_SDOE = IOMUX_PAD(0x0540, 0x0170, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x0544, 0x0174, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0), - MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x0544, 0x0174, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_CSI1_DATA12 = IOMUX_PAD(0x0544, 0x0174, 3, 0x0890, 1, 0), - MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x0544, 0x0174, 4, 0x0900, 0, 0), - MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x0544, 0x0174, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x0544, 0x0174, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D28__EPDC_PWR_CTRL3 = IOMUX_PAD(0x0544, 0x0174, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D29__EIM_DATA29 = IOMUX_PAD(0x0548, 0x0178, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x0548, 0x0178, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D29__ECSPI4_SS0 = IOMUX_PAD(0x0548, 0x0178, 2, 0x0808, 1, 0), - MX6_PAD_EIM_D29__UART2_CTS_B = IOMUX_PAD(0x0548, 0x0178, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D29__UART2_RTS_B = IOMUX_PAD(0x0548, 0x0178, 4, 0x0900, 1, 0), - MX6_PAD_EIM_D29__GPIO3_IO29 = IOMUX_PAD(0x0548, 0x0178, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D29__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0548, 0x0178, 6, 0x08BC, 0, 0), - MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x0548, 0x0178, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D29__EPDC_PWR_WAKE = IOMUX_PAD(0x0548, 0x0178, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x054C, 0x017C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x054C, 0x017C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x054C, 0x017C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x054C, 0x017C, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_CTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x054C, 0x017C, 4, 0x0908, 1, 0), - MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x054C, 0x017C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), - MX6_PAD_EIM_D30__EPDC_SDOEZ = IOMUX_PAD(0x054C, 0x017C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x0550, 0x0180, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x0550, 0x0180, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x0550, 0x0180, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x0550, 0x0180, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_CTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x0550, 0x0180, 4, 0x0908, 2, 0), - MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x0550, 0x0180, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D31__EPDC_SDCLK_P = IOMUX_PAD(0x0550, 0x0180, 8, 0x0000, 0, 0), - MX6_PAD_EIM_D31__EIM_ACLK_FREERUN = IOMUX_PAD(0x0550, 0x0180, 9, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_CSI1_DATA09 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0554, 0x0184, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0554, 0x0184, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__EPDC_SDCLK_N = IOMUX_PAD(0x0554, 0x0184, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_CSI1_DATA08 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x0558, 0x0188, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x0558, 0x0188, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__EPDC_SDLE = IOMUX_PAD(0x0558, 0x0188, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x055C, 0x018C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x055C, 0x018C, 2, 0x08B0, 1, 0), - MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x055C, 0x018C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__EPDC_DATA01 = IOMUX_PAD(0x055C, 0x018C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU1_CSI1_HSYNC = IOMUX_PAD(0x0560, 0x0190, 2, 0x08B4, 0, 0), - MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0560, 0x0190, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__EPDC_DATA03 = IOMUX_PAD(0x0560, 0x0190, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0564, 0x0194, 2, 0x08BC, 1, 0), - MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0564, 0x0194, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__EPDC_DATA02 = IOMUX_PAD(0x0564, 0x0194, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x0568, 0x0198, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x0568, 0x0198, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__EPDC_DATA13 = IOMUX_PAD(0x0568, 0x0198, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x056C, 0x019C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x056C, 0x019C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__EPDC_DATA14 = IOMUX_PAD(0x056C, 0x019C, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0570, 0x01A0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__EPDC_DATA09 = IOMUX_PAD(0x0570, 0x01A0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_CSI1_DATA07 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0574, 0x01A4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0574, 0x01A4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__EPDC_BDR0 = IOMUX_PAD(0x0574, 0x01A4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_CSI1_DATA06 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0578, 0x01A8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0578, 0x01A8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__EPDC_BDR1 = IOMUX_PAD(0x0578, 0x01A8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_CSI1_DATA05 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x057C, 0x01AC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x057C, 0x01AC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__EPDC_SDCE0 = IOMUX_PAD(0x057C, 0x01AC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_CSI1_DATA04 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x0580, 0x01B0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x0580, 0x01B0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__EPDC_SDCE1 = IOMUX_PAD(0x0580, 0x01B0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_CSI1_DATA03 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0584, 0x01B4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0584, 0x01B4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__EPDC_SDCE2 = IOMUX_PAD(0x0584, 0x01B4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_CSI1_DATA02 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0588, 0x01B8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0588, 0x01B8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__EPDC_SDCE3 = IOMUX_PAD(0x0588, 0x01B8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_CSI1_DATA01 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x058C, 0x01BC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x058C, 0x01BC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__EPDC_SDCE4 = IOMUX_PAD(0x058C, 0x01BC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_CSI1_DATA00 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x0590, 0x01C0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__EPDC_SDCE5 = IOMUX_PAD(0x0590, 0x01C0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0594, 0x01C4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_CSI1_DATA11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), - MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0594, 0x01C4, 4, 0x07D4, 0, 0), - MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0594, 0x01C4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0594, 0x01C4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__EPDC_PWR_COM = IOMUX_PAD(0x0594, 0x01C4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0598, 0x01C8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_CSI1_DATA10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), - MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0598, 0x01C8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0598, 0x01C8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__EPDC_SDSHR = IOMUX_PAD(0x0598, 0x01C8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x059C, 0x01CC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x059C, 0x01CC, 1, 0x07E4, 2, 0), - MX6_PAD_EIM_EB2__IPU1_CSI1_DATA19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), - MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x059C, 0x01CC, 4, 0x0860, 0, 0), - MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x059C, 0x01CC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0), - MX6_PAD_EIM_EB2__SRC_BOOT_CFG30 = IOMUX_PAD(0x059C, 0x01CC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__EPDC_DATA05 = IOMUX_PAD(0x059C, 0x01CC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__EIM_EB3_B = IOMUX_PAD(0x05A0, 0x01D0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__ECSPI4_RDY = IOMUX_PAD(0x05A0, 0x01D0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_CTS_B = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_RTS_B = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0908, 3, 0), - MX6_PAD_EIM_EB3__UART1_RI_B = IOMUX_PAD(0x05A0, 0x01D0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__IPU1_CSI1_HSYNC = IOMUX_PAD(0x05A0, 0x01D0, 4, 0x08B4, 1, 0), - MX6_PAD_EIM_EB3__GPIO2_IO31 = IOMUX_PAD(0x05A0, 0x01D0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__IPU1_DI1_PIN03 = IOMUX_PAD(0x05A0, 0x01D0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__SRC_BOOT_CFG31 = IOMUX_PAD(0x05A0, 0x01D0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__EPDC_SDCE0 = IOMUX_PAD(0x05A0, 0x01D0, 8, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__EIM_ACLK_FREERUN = IOMUX_PAD(0x05A0, 0x01D0, 9, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__EIM_LBA_B = IOMUX_PAD(0x05A4, 0x01D4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x05A4, 0x01D4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x05A4, 0x01D4, 2, 0x0804, 1, 0), - MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x05A4, 0x01D4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x05A4, 0x01D4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__EPDC_DATA04 = IOMUX_PAD(0x05A4, 0x01D4, 8, 0x0000, 0, 0), - MX6_PAD_EIM_OE__EIM_OE_B = IOMUX_PAD(0x05A8, 0x01D8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x05A8, 0x01D8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x05A8, 0x01D8, 2, 0x07F8, 2, 0), - MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x05A8, 0x01D8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_OE__EPDC_PWR_IRQ = IOMUX_PAD(0x05A8, 0x01D8, 8, 0x0000, 0, 0), - MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x05AC, 0x01DC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x05AC, 0x01DC, 2, 0x0800, 2, 0), - MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x05AC, 0x01DC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x05AC, 0x01DC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_RW__EPDC_DATA07 = IOMUX_PAD(0x05AC, 0x01DC, 8, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x05B0, 0x01E0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x05B4, 0x01E4, 1, 0x0828, 0, 0), - MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), - MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x05B4, 0x01E4, 3, 0x08F4, 0, 0), - MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x05B4, 0x01E4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x05B8, 0x01E8, 0, 0x08E0, 0, 0), - MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x05B8, 0x01E8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x05B8, 0x01E8, 2, 0x0858, 0, 0), - MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x05B8, 0x01E8, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x05B8, 0x01E8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x05BC, 0x01EC, 1, 0x0810, 0, 0), - MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x05BC, 0x01EC, 2, 0x083C, 0, 0), - MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x05BC, 0x01EC, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x05BC, 0x01EC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x05BC, 0x01EC, 6, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), - MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x05C0, 0x01F0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), - MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x05C4, 0x01F4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), - MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x05C4, 0x01F4, 3, 0x08F0, 1, 0), - MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x05C4, 0x01F4, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x05C4, 0x01F4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), - MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), - MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x08E4, 0, 0), - MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), - MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x0830, 0, 0), - MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x05D0, 0x0200, 2, 0x0850, 0, 0), - MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__I2C4_SCL = IOMUX_PAD(0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0), - MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), - MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x05D8, 0x0208, 0, 0x08DC, 0, 0), - MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), - MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__I2C4_SDA = IOMUX_PAD(0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0), - MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0000, 0, 0), - MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05DC, 0x020C, 2, 0x08C0, 1, 0), - MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0794, 0, 0), - MX6_PAD_GPIO_0__EPIT1_OUT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_0__GPIO1_IO00 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05DC, 0x020C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_1__ESAI_RX_CLK = IOMUX_PAD(0x05E0, 0x0210, 0, 0x083C, 1, 0), - MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_1__KEY_ROW5 = IOMUX_PAD(0x05E0, 0x0210, 2, 0x08CC, 1, 0), - MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0790, 1, 0), - MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05E0, 0x0210, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0850, 1, 0), - MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x05E4, 0x0214, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), - MX6_PAD_GPIO_16__SD1_LCTL = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_16__SPDIF_IN = IOMUX_PAD(0x05E4, 0x0214, 4, 0x08F0, 2, 0), - MX6_PAD_GPIO_16__GPIO7_IO11 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_16__I2C3_SDA = IOMUX_PAD(0x05E4, 0x0214, 6 | IOMUX_CONFIG_SION, 0x087C, 1, 0), - MX6_PAD_GPIO_16__JTAG_DE_B = IOMUX_PAD(0x05E4, 0x0214, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_17__ESAI_TX0 = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0844, 0, 0), - MX6_PAD_GPIO_17__ENET_1588_EVENT3_IN = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_17__CCM_PMIC_READY = IOMUX_PAD(0x05E8, 0x0218, 2, 0x07D4, 1, 0), - MX6_PAD_GPIO_17__SDMA_EXT_EVENT0 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x08E8, 1, 0), - MX6_PAD_GPIO_17__SPDIF_OUT = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x05EC, 0x021C, 0, 0x0848, 0, 0), - MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0814, 0, 0), - MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x08EC, 1, 0), - MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), - MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x08C0, 2, 0), - MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x05F0, 0x0220, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x05F0, 0x0220, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_19__CCM_CLKO1 = IOMUX_PAD(0x05F0, 0x0220, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_19__GPIO4_IO05 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x05F4, 0x0224, 0, 0x0830, 1, 0), - MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08D0, 1, 0), - MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x05F4, 0x0224, 7, 0x08E0, 1, 0), - MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05F8, 0x0228, 0, 0x0834, 1, 0), - MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0), - MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_3__GPIO1_IO03 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05F8, 0x0228, 6, 0x0924, 1, 0), - MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), - MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0838, 1, 0), - MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x05FC, 0x022C, 2, 0x08C8, 1, 0), - MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_4__SD2_CD_B = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_5__ESAI_TX2_RX3 = IOMUX_PAD(0x0600, 0x0230, 0, 0x084C, 1, 0), - MX6_PAD_GPIO_5__KEY_ROW7 = IOMUX_PAD(0x0600, 0x0230, 2, 0x08D4, 1, 0), - MX6_PAD_GPIO_5__CCM_CLKO1 = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_5__GPIO1_IO05 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0), - MX6_PAD_GPIO_5__ARM_EVENTI = IOMUX_PAD(0x0600, 0x0230, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0604, 0x0234, 0, 0x0840, 1, 0), - MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0), - MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), - MX6_PAD_GPIO_7__ESAI_TX4_RX1 = IOMUX_PAD(0x0608, 0x0238, 0, 0x0854, 1, 0), - MX6_PAD_GPIO_7__EPIT1_OUT = IOMUX_PAD(0x0608, 0x0238, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_7__FLEXCAN1_TX = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_TX_DATA = IOMUX_PAD(0x0608, 0x0238, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_RX_DATA = IOMUX_PAD(0x0608, 0x0238, 4, 0x0904, 2, 0), - MX6_PAD_GPIO_7__GPIO1_IO07 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_7__SPDIF_LOCK = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_7__USB_OTG_HOST_MODE = IOMUX_PAD(0x0608, 0x0238, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_7__I2C4_SCL = IOMUX_PAD(0x0608, 0x0238, 8 | IOMUX_CONFIG_SION, 0x0880, 1, 0), - MX6_PAD_GPIO_8__ESAI_TX5_RX0 = IOMUX_PAD(0x060C, 0x023C, 0, 0x0858, 1, 0), - MX6_PAD_GPIO_8__XTALOSC_REF_CLK_32K = IOMUX_PAD(0x060C, 0x023C, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_8__EPIT2_OUT = IOMUX_PAD(0x060C, 0x023C, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_8__FLEXCAN1_RX = IOMUX_PAD(0x060C, 0x023C, 3, 0x07C8, 0, 0), - MX6_PAD_GPIO_8__UART2_TX_DATA = IOMUX_PAD(0x060C, 0x023C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_8__UART2_RX_DATA = IOMUX_PAD(0x060C, 0x023C, 4, 0x0904, 3, 0), - MX6_PAD_GPIO_8__GPIO1_IO08 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_8__SPDIF_SR_CLK = IOMUX_PAD(0x060C, 0x023C, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_8__I2C4_SDA = IOMUX_PAD(0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0), - MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x0610, 0x0240, 0, 0x082C, 1, 0), - MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x0610, 0x0240, 2, 0x08C4, 1, 0), - MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), - MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x062C, 0x0244, 0, 0x07D8, 3, 0), - MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x062C, 0x0244, 1, 0x0824, 0, 0), - MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), - MX6_PAD_KEY_COL0__KEY_COL0 = IOMUX_PAD(0x062C, 0x0244, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_TX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x062C, 0x0244, 4, 0x0914, 2, 0), - MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x062C, 0x0244, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x0630, 0x0248, 0, 0x07DC, 3, 0), - MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x0630, 0x0248, 1, 0x0810, 1, 0), - MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), - MX6_PAD_KEY_COL1__KEY_COL1 = IOMUX_PAD(0x0630, 0x0248, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_TX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x0630, 0x0248, 4, 0x091C, 2, 0), - MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x0630, 0x0248, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x0634, 0x024C, 0, 0x07E8, 2, 0), - MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x0634, 0x024C, 1, 0x0820, 0, 0), - MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x0634, 0x024C, 2, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__KEY_COL2 = IOMUX_PAD(0x0634, 0x024C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x0634, 0x024C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x0634, 0x024C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x0634, 0x024C, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x0638, 0x0250, 0, 0x07F0, 1, 0), - MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x0638, 0x0250, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x0638, 0x0250, 2, 0x0860, 1, 0), - MX6_PAD_KEY_COL3__KEY_COL3 = IOMUX_PAD(0x0638, 0x0250, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0), - MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x0638, 0x0250, 6, 0x08F0, 3, 0), - MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x063C, 0x0254, 0, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x063C, 0x0254, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), - MX6_PAD_KEY_COL4__KEY_COL4 = IOMUX_PAD(0x063C, 0x0254, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x063C, 0x0254, 4, 0x0918, 2, 0), - MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x063C, 0x0254, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0640, 0x0258, 0, 0x07E0, 3, 0), - MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x0640, 0x0258, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), - MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x0640, 0x0258, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_TX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x0640, 0x0258, 4, 0x0914, 3, 0), - MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x0640, 0x0258, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x025C, 0, 0x07E4, 3, 0), - MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x0644, 0x025C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), - MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x0644, 0x025C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_TX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x0644, 0x025C, 4, 0x091C, 3, 0), - MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x0644, 0x025C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x0648, 0x0260, 0, 0x07EC, 1, 0), - MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x0648, 0x0260, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x0648, 0x0260, 2, 0x07C8, 1, 0), - MX6_PAD_KEY_ROW2__KEY_ROW2 = IOMUX_PAD(0x0648, 0x0260, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x0648, 0x0260, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0648, 0x0260, 6, 0x085C, 1, 0), - MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), - MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x064C, 0x0264, 2, 0x0864, 1, 0), - MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x064C, 0x0264, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), - MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x0650, 0x0268, 0, 0x07CC, 0, 0), - MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x0650, 0x0268, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x0650, 0x0268, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x0650, 0x0268, 4, 0x0918, 3, 0), - MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x0650, 0x0268, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x0654, 0x026C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x0654, 0x026C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x0654, 0x026C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__NAND_CLE = IOMUX_PAD(0x0658, 0x0270, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__GPIO6_IO07 = IOMUX_PAD(0x0658, 0x0270, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x065C, 0x0274, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x065C, 0x0274, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x0660, 0x0278, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x0664, 0x027C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x0664, 0x027C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x0664, 0x027C, 2, 0x0844, 1, 0), - MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x0664, 0x027C, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x0668, 0x0280, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x0668, 0x0280, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x0668, 0x0280, 2, 0x0848, 1, 0), - MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__I2C4_SDA = IOMUX_PAD(0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0), - MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x066C, 0x0284, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__SD1_DATA4 = IOMUX_PAD(0x066C, 0x0284, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__GPIO2_IO00 = IOMUX_PAD(0x066C, 0x0284, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__NAND_DATA01 = IOMUX_PAD(0x0670, 0x0288, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__SD1_DATA5 = IOMUX_PAD(0x0670, 0x0288, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__GPIO2_IO01 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__NAND_DATA02 = IOMUX_PAD(0x0674, 0x028C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__SD1_DATA6 = IOMUX_PAD(0x0674, 0x028C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__GPIO2_IO02 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__NAND_DATA03 = IOMUX_PAD(0x0678, 0x0290, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__SD1_DATA7 = IOMUX_PAD(0x0678, 0x0290, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__GPIO2_IO03 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__NAND_DATA04 = IOMUX_PAD(0x067C, 0x0294, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__SD2_DATA4 = IOMUX_PAD(0x067C, 0x0294, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__GPIO2_IO04 = IOMUX_PAD(0x067C, 0x0294, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__NAND_DATA05 = IOMUX_PAD(0x0680, 0x0298, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__SD2_DATA5 = IOMUX_PAD(0x0680, 0x0298, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__GPIO2_IO05 = IOMUX_PAD(0x0680, 0x0298, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__NAND_DATA06 = IOMUX_PAD(0x0684, 0x029C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__SD2_DATA6 = IOMUX_PAD(0x0684, 0x029C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__GPIO2_IO06 = IOMUX_PAD(0x0684, 0x029C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0688, 0x02A0, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0688, 0x02A0, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0688, 0x02A0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x068C, 0x02A4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__I2C4_SCL = IOMUX_PAD(0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0), - MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), - MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), - MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), - MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), - MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0828, 1, 0), - MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), - MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), - MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), - MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x080C, 1, 0), - MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x08F4, 1, 0), - MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0928, 1, 0), - MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x06C4, 0x02DC, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__GPIO1_IO20 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__PWM4_OUT = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPIO1_IO18 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__SD1_DATA0 = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPT_CAPTURE1 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPIO1_IO16 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__PWM3_OUT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPT_CAPTURE2 = IOMUX_PAD(0x06D0, 0x02E8, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPIO1_IO17 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__SD1_DATA2 = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__GPT_COMPARE2 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__PWM2_OUT = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_B = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__GPIO1_IO19 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_RESET_B_DEB = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__SD1_DATA3 = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPT_COMPARE3 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__PWM1_OUT = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_B = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPIO1_IO21 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x06DC, 0x02F4, 0, 0x0930, 1, 0), - MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x08C0, 3, 0), - MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), - MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x08CC, 2, 0), - MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), - MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), - MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x08D4, 2, 0), - MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), - MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x08C8, 2, 0), - MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), - MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x08D0, 2, 0), - MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x08C4, 2, 0), - MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), - MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), - MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__UART2_RTS_B = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0900, 2, 0), - MX6_PAD_SD3_CLK__FLEXCAN1_RX = IOMUX_PAD(0x06F4, 0x030C, 2, 0x07C8, 2, 0), - MX6_PAD_SD3_CLK__GPIO7_IO03 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_CTS_B = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0900, 3, 0), - MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__GPIO7_IO02 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_CTS_B = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06FC, 0x0314, 1, 0x08F8, 2, 0), - MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__GPIO7_IO04 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__SD3_DATA1 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_CTS_B = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_RTS_B = IOMUX_PAD(0x0700, 0x0318, 1, 0x08F8, 3, 0), - MX6_PAD_SD3_DAT1__FLEXCAN2_RX = IOMUX_PAD(0x0700, 0x0318, 2, 0x07CC, 1, 0), - MX6_PAD_SD3_DAT1__GPIO7_IO05 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__SD3_DATA2 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__GPIO7_IO06 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_CTS_B = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x0708, 0x0320, 1, 0x0908, 4, 0), - MX6_PAD_SD3_DAT3__GPIO7_IO07 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x070C, 0x0324, 1, 0x0904, 4, 0), - MX6_PAD_SD3_DAT4__GPIO7_IO01 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0710, 0x0328, 1, 0x0904, 5, 0), - MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 1, 0x08FC, 2, 0), - MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0718, 0x0330, 1, 0x08FC, 3, 0), - MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), - MX6_PAD_SD3_RST__SD3_RESET = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_CTS_B = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_RTS_B = IOMUX_PAD(0x071C, 0x0334, 1, 0x0908, 5, 0), - MX6_PAD_SD3_RST__GPIO7_IO08 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x0720, 0x0338, 0, 0x0938, 1, 0), - MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x090C, 2, 0), - MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__NAND_RE_B = IOMUX_PAD(0x0724, 0x033C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_TX_DATA = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_RX_DATA = IOMUX_PAD(0x0724, 0x033C, 2, 0x090C, 3, 0), - MX6_PAD_SD4_CMD__GPIO7_IO09 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__SD4_DATA0 = IOMUX_PAD(0x0728, 0x0340, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__NAND_DQS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__GPIO2_IO08 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__SD4_DATA1 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__PWM3_OUT = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__GPIO2_IO09 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__SD4_DATA2 = IOMUX_PAD(0x0730, 0x0348, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__PWM4_OUT = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__GPIO2_IO10 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__SD4_DATA3 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__GPIO2_IO11 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0738, 0x0350, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_TX_DATA = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0738, 0x0350, 2, 0x0904, 6, 0), - MX6_PAD_SD4_DAT4__GPIO2_IO12 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__SD4_DATA5 = IOMUX_PAD(0x073C, 0x0354, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_CTS_B = IOMUX_PAD(0x073C, 0x0354, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_RTS_B = IOMUX_PAD(0x073C, 0x0354, 2, 0x0900, 4, 0), - MX6_PAD_SD4_DAT5__GPIO2_IO13 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x0740, 0x0358, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_CTS_B = IOMUX_PAD(0x0740, 0x0358, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x0740, 0x0358, 2, 0x0900, 5, 0), - MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0744, 0x035C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0744, 0x035C, 2, 0x0904, 7, 0), - MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), -}; +MX6_PAD_DECL(CSI0_DAT10__IPU1_CSI0_DATA10, 0x0360, 0x004C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__AUD3_RXC, 0x0360, 0x004C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ECSPI2_MISO, 0x0360, 0x004C, 2, 0x07F8, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_TX_DATA, 0x0360, 0x004C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_RX_DATA, 0x0360, 0x004C, 3, 0x08FC, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__GPIO5_IO28, 0x0360, 0x004C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ARM_TRACE07, 0x0360, 0x004C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__IPU1_CSI0_DATA11, 0x0364, 0x0050, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__AUD3_RXFS, 0x0364, 0x0050, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ECSPI2_SS0, 0x0364, 0x0050, 2, 0x0800, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_TX_DATA, 0x0364, 0x0050, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_RX_DATA, 0x0364, 0x0050, 3, 0x08FC, 1, 0) +MX6_PAD_DECL(CSI0_DAT11__GPIO5_IO29, 0x0364, 0x0050, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ARM_TRACE08, 0x0364, 0x0050, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__IPU1_CSI0_DATA12, 0x0368, 0x0054, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__EIM_DATA08, 0x0368, 0x0054, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_TX_DATA, 0x0368, 0x0054, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_RX_DATA, 0x0368, 0x0054, 3, 0x0914, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__GPIO5_IO30, 0x0368, 0x0054, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__ARM_TRACE09, 0x0368, 0x0054, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__IPU1_CSI0_DATA13, 0x036C, 0x0058, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__EIM_DATA09, 0x036C, 0x0058, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_TX_DATA, 0x036C, 0x0058, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_RX_DATA, 0x036C, 0x0058, 3, 0x0914, 1, 0) +MX6_PAD_DECL(CSI0_DAT13__GPIO5_IO31, 0x036C, 0x0058, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__ARM_TRACE10, 0x036C, 0x0058, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__IPU1_CSI0_DATA14, 0x0370, 0x005C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__EIM_DATA10, 0x0370, 0x005C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_TX_DATA, 0x0370, 0x005C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_RX_DATA, 0x0370, 0x005C, 3, 0x091C, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__GPIO6_IO00, 0x0370, 0x005C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__ARM_TRACE11, 0x0370, 0x005C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__IPU1_CSI0_DATA15, 0x0374, 0x0060, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__EIM_DATA11, 0x0374, 0x0060, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_TX_DATA, 0x0374, 0x0060, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_RX_DATA, 0x0374, 0x0060, 3, 0x091C, 1, 0) +MX6_PAD_DECL(CSI0_DAT15__GPIO6_IO01, 0x0374, 0x0060, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__ARM_TRACE12, 0x0374, 0x0060, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__IPU1_CSI0_DATA16, 0x0378, 0x0064, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__EIM_DATA12, 0x0378, 0x0064, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_CTS_B, 0x0378, 0x0064, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_RTS_B, 0x0378, 0x0064, 3, 0x0910, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__GPIO6_IO02, 0x0378, 0x0064, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__ARM_TRACE13, 0x0378, 0x0064, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__IPU1_CSI0_DATA17, 0x037C, 0x0068, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__EIM_DATA13, 0x037C, 0x0068, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_CTS_B, 0x037C, 0x0068, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_RTS_B, 0x037C, 0x0068, 3, 0x0910, 1, 0) +MX6_PAD_DECL(CSI0_DAT17__GPIO6_IO03, 0x037C, 0x0068, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__ARM_TRACE14, 0x037C, 0x0068, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__IPU1_CSI0_DATA18, 0x0380, 0x006C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__EIM_DATA14, 0x0380, 0x006C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_CTS_B, 0x0380, 0x006C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_RTS_B, 0x0380, 0x006C, 3, 0x0918, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__GPIO6_IO04, 0x0380, 0x006C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__ARM_TRACE15, 0x0380, 0x006C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__IPU1_CSI0_DATA19, 0x0384, 0x0070, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__EIM_DATA15, 0x0384, 0x0070, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_CTS_B, 0x0384, 0x0070, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_RTS_B, 0x0384, 0x0070, 3, 0x0918, 1, 0) +MX6_PAD_DECL(CSI0_DAT19__GPIO6_IO05, 0x0384, 0x0070, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__IPU1_CSI0_DATA04, 0x0388, 0x0074, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__EIM_DATA02, 0x0388, 0x0074, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ECSPI1_SCLK, 0x0388, 0x0074, 2, 0x07D8, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__KEY_COL5, 0x0388, 0x0074, 3, 0x08C0, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__AUD3_TXC, 0x0388, 0x0074, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__GPIO5_IO22, 0x0388, 0x0074, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ARM_TRACE01, 0x0388, 0x0074, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__IPU1_CSI0_DATA05, 0x038C, 0x0078, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__EIM_DATA03, 0x038C, 0x0078, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ECSPI1_MOSI, 0x038C, 0x0078, 2, 0x07E0, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__KEY_ROW5, 0x038C, 0x0078, 3, 0x08CC, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__AUD3_TXD, 0x038C, 0x0078, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__GPIO5_IO23, 0x038C, 0x0078, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ARM_TRACE02, 0x038C, 0x0078, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__IPU1_CSI0_DATA06, 0x0390, 0x007C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__EIM_DATA04, 0x0390, 0x007C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ECSPI1_MISO, 0x0390, 0x007C, 2, 0x07DC, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__KEY_COL6, 0x0390, 0x007C, 3, 0x08C4, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__AUD3_TXFS, 0x0390, 0x007C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__GPIO5_IO24, 0x0390, 0x007C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ARM_TRACE03, 0x0390, 0x007C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__IPU1_CSI0_DATA07, 0x0394, 0x0080, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__EIM_DATA05, 0x0394, 0x0080, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ECSPI1_SS0, 0x0394, 0x0080, 2, 0x07E4, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__KEY_ROW6, 0x0394, 0x0080, 3, 0x08D0, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__AUD3_RXD, 0x0394, 0x0080, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__GPIO5_IO25, 0x0394, 0x0080, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ARM_TRACE04, 0x0394, 0x0080, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__IPU1_CSI0_DATA08, 0x0398, 0x0084, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__EIM_DATA06, 0x0398, 0x0084, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ECSPI2_SCLK, 0x0398, 0x0084, 2, 0x07F4, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__KEY_COL7, 0x0398, 0x0084, 3, 0x08C8, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__I2C1_SDA, 0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__GPIO5_IO26, 0x0398, 0x0084, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ARM_TRACE05, 0x0398, 0x0084, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__IPU1_CSI0_DATA09, 0x039C, 0x0088, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__EIM_DATA07, 0x039C, 0x0088, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ECSPI2_MOSI, 0x039C, 0x0088, 2, 0x07FC, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__KEY_ROW7, 0x039C, 0x0088, 3, 0x08D4, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__I2C1_SCL, 0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__GPIO5_IO27, 0x039C, 0x0088, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ARM_TRACE06, 0x039C, 0x0088, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__IPU1_CSI0_DATA_EN, 0x03A0, 0x008C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__EIM_DATA00, 0x03A0, 0x008C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__GPIO5_IO20, 0x03A0, 0x008C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__ARM_TRACE_CLK, 0x03A0, 0x008C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__IPU1_CSI0_HSYNC, 0x03A4, 0x0090, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__CCM_CLKO1, 0x03A4, 0x0090, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__GPIO5_IO19, 0x03A4, 0x0090, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__ARM_TRACE_CTL, 0x03A4, 0x0090, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__IPU1_CSI0_PIXCLK, 0x03A8, 0x0094, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__GPIO5_IO18, 0x03A8, 0x0094, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__ARM_EVENTO, 0x03A8, 0x0094, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__IPU1_CSI0_VSYNC, 0x03AC, 0x0098, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__EIM_DATA01, 0x03AC, 0x0098, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__GPIO5_IO21, 0x03AC, 0x0098, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__ARM_TRACE00, 0x03AC, 0x0098, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__IPU1_DI0_DISP_CLK, 0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_DISP_CLK__LCD_CLK, 0x03B0, 0x009C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__GPIO4_IO16, 0x03B0, 0x009C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__LCD_WR_RWN, 0x03B0, 0x009C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__IPU1_DI0_PIN15, 0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN15__LCD_ENABLE, 0x03B4, 0x00A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__AUD6_TXC, 0x03B4, 0x00A0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__GPIO4_IO17, 0x03B4, 0x00A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__LCD_RD_E, 0x03B4, 0x00A0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__IPU1_DI0_PIN02, 0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN2__LCD_HSYNC, 0x03B8, 0x00A4, 1, 0x08D8, 0, 0) +MX6_PAD_DECL(DI0_PIN2__AUD6_TXD, 0x03B8, 0x00A4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__GPIO4_IO18, 0x03B8, 0x00A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__LCD_RS, 0x03B8, 0x00A4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__IPU1_DI0_PIN03, 0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN3__LCD_VSYNC, 0x03BC, 0x00A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__AUD6_TXFS, 0x03BC, 0x00A8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__GPIO4_IO19, 0x03BC, 0x00A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__LCD_CS, 0x03BC, 0x00A8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__IPU1_DI0_PIN04, 0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN4__LCD_BUSY, 0x03C0, 0x00AC, 1, 0x08D8, 1, 0) +MX6_PAD_DECL(DI0_PIN4__AUD6_RXD, 0x03C0, 0x00AC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__SD1_WP, 0x03C0, 0x00AC, 3, 0x092C, 0, 0) +MX6_PAD_DECL(DI0_PIN4__GPIO4_IO20, 0x03C0, 0x00AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__LCD_RESET, 0x03C0, 0x00AC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__IPU1_DISP0_DATA00, 0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT0__LCD_DATA00, 0x03C4, 0x00B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__ECSPI3_SCLK, 0x03C4, 0x00B0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__GPIO4_IO21, 0x03C4, 0x00B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__IPU1_DISP0_DATA01, 0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT1__LCD_DATA01, 0x03C8, 0x00B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__ECSPI3_MOSI, 0x03C8, 0x00B4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__GPIO4_IO22, 0x03C8, 0x00B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT10__IPU1_DISP0_DATA10, 0x03CC, 0x00B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT10__LCD_DATA10, 0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT10__GPIO4_IO31, 0x03CC, 0x00B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__IPU1_DISP0_DATA11, 0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT11__LCD_DATA11, 0x03D0, 0x00BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__GPIO5_IO05, 0x03D0, 0x00BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__IPU1_DISP0_DATA12, 0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT12__LCD_DATA12, 0x03D4, 0x00C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__GPIO5_IO06, 0x03D4, 0x00C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__IPU1_DISP0_DATA13, 0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT13__LCD_DATA13, 0x03D8, 0x00C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__AUD5_RXFS, 0x03D8, 0x00C4, 3, 0x07BC, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__GPIO5_IO07, 0x03D8, 0x00C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__IPU1_DISP0_DATA14, 0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT14__LCD_DATA14, 0x03DC, 0x00C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__AUD5_RXC, 0x03DC, 0x00C8, 3, 0x07B8, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__GPIO5_IO08, 0x03DC, 0x00C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__IPU1_DISP0_DATA15, 0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT15__LCD_DATA15, 0x03E0, 0x00CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI1_SS1, 0x03E0, 0x00CC, 2, 0x07E8, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI2_SS1, 0x03E0, 0x00CC, 3, 0x0804, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__GPIO5_IO09, 0x03E0, 0x00CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__IPU1_DISP0_DATA16, 0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT16__LCD_DATA16, 0x03E4, 0x00D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__ECSPI2_MOSI, 0x03E4, 0x00D0, 2, 0x07FC, 1, 0) +MX6_PAD_DECL(DISP0_DAT16__AUD5_TXC, 0x03E4, 0x00D0, 3, 0x07C0, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__SDMA_EXT_EVENT0, 0x03E4, 0x00D0, 4, 0x08E8, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__GPIO5_IO10, 0x03E4, 0x00D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__IPU1_DISP0_DATA17, 0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT17__LCD_DATA17, 0x03E8, 0x00D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__ECSPI2_MISO, 0x03E8, 0x00D4, 2, 0x07F8, 1, 0) +MX6_PAD_DECL(DISP0_DAT17__AUD5_TXD, 0x03E8, 0x00D4, 3, 0x07B4, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__SDMA_EXT_EVENT1, 0x03E8, 0x00D4, 4, 0x08EC, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__GPIO5_IO11, 0x03E8, 0x00D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__IPU1_DISP0_DATA18, 0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT18__LCD_DATA18, 0x03EC, 0x00D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__ECSPI2_SS0, 0x03EC, 0x00D8, 2, 0x0800, 1, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD5_TXFS, 0x03EC, 0x00D8, 3, 0x07C4, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD4_RXFS, 0x03EC, 0x00D8, 4, 0x07A4, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__GPIO5_IO12, 0x03EC, 0x00D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__EIM_CS2_B, 0x03EC, 0x00D8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__IPU1_DISP0_DATA19, 0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT19__LCD_DATA19, 0x03F0, 0x00DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__ECSPI2_SCLK, 0x03F0, 0x00DC, 2, 0x07F4, 1, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD5_RXD, 0x03F0, 0x00DC, 3, 0x07B0, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD4_RXC, 0x03F0, 0x00DC, 4, 0x07A0, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__GPIO5_IO13, 0x03F0, 0x00DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__EIM_CS3_B, 0x03F0, 0x00DC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__IPU1_DISP0_DATA02, 0x03F4, 0x00E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__LCD_DATA02, 0x03F4, 0x00E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__ECSPI3_MISO, 0x03F4, 0x00E0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__GPIO4_IO23, 0x03F4, 0x00E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__IPU1_DISP0_DATA20, 0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT20__LCD_DATA20, 0x03F8, 0x00E4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__ECSPI1_SCLK, 0x03F8, 0x00E4, 2, 0x07D8, 1, 0) +MX6_PAD_DECL(DISP0_DAT20__AUD4_TXC, 0x03F8, 0x00E4, 3, 0x07A8, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__GPIO5_IO14, 0x03F8, 0x00E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__IPU1_DISP0_DATA21, 0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT21__LCD_DATA21, 0x03FC, 0x00E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__ECSPI1_MOSI, 0x03FC, 0x00E8, 2, 0x07E0, 1, 0) +MX6_PAD_DECL(DISP0_DAT21__AUD4_TXD, 0x03FC, 0x00E8, 3, 0x079C, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__GPIO5_IO15, 0x03FC, 0x00E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__IPU1_DISP0_DATA22, 0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT22__LCD_DATA22, 0x0400, 0x00EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__ECSPI1_MISO, 0x0400, 0x00EC, 2, 0x07DC, 1, 0) +MX6_PAD_DECL(DISP0_DAT22__AUD4_TXFS, 0x0400, 0x00EC, 3, 0x07AC, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__GPIO5_IO16, 0x0400, 0x00EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__IPU1_DISP0_DATA23, 0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT23__LCD_DATA23, 0x0404, 0x00F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__ECSPI1_SS0, 0x0404, 0x00F0, 2, 0x07E4, 1, 0) +MX6_PAD_DECL(DISP0_DAT23__AUD4_RXD, 0x0404, 0x00F0, 3, 0x0798, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__GPIO5_IO17, 0x0404, 0x00F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__IPU1_DISP0_DATA03, 0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT3__LCD_DATA03, 0x0408, 0x00F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__ECSPI3_SS0, 0x0408, 0x00F4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__GPIO4_IO24, 0x0408, 0x00F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__IPU1_DISP0_DATA04, 0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT4__LCD_DATA04, 0x040C, 0x00F8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__ECSPI3_SS1, 0x040C, 0x00F8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__GPIO4_IO25, 0x040C, 0x00F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__IPU1_DISP0_DATA05, 0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT5__LCD_DATA05, 0x0410, 0x00FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__ECSPI3_SS2, 0x0410, 0x00FC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__AUD6_RXFS, 0x0410, 0x00FC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__GPIO4_IO26, 0x0410, 0x00FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__IPU1_DISP0_DATA06, 0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT6__LCD_DATA06, 0x0414, 0x0100, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__ECSPI3_SS3, 0x0414, 0x0100, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__AUD6_RXC, 0x0414, 0x0100, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__GPIO4_IO27, 0x0414, 0x0100, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__IPU1_DISP0_DATA07, 0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT7__LCD_DATA07, 0x0418, 0x0104, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__ECSPI3_RDY, 0x0418, 0x0104, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__GPIO4_IO28, 0x0418, 0x0104, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__IPU1_DISP0_DATA08, 0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT8__LCD_DATA08, 0x041C, 0x0108, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__PWM1_OUT, 0x041C, 0x0108, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__WDOG1_B, 0x041C, 0x0108, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__GPIO4_IO29, 0x041C, 0x0108, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__IPU1_DISP0_DATA09, 0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT9__LCD_DATA09, 0x0420, 0x010C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__PWM2_OUT, 0x0420, 0x010C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__WDOG2_B, 0x0420, 0x010C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__GPIO4_IO30, 0x0420, 0x010C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__EIM_ADDR16, 0x04E0, 0x0110, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__IPU1_DI1_DISP_CLK, 0x04E0, 0x0110, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__IPU1_CSI1_PIXCLK, 0x04E0, 0x0110, 2, 0x08B8, 0, 0) +MX6_PAD_DECL(EIM_A16__GPIO2_IO22, 0x04E0, 0x0110, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__SRC_BOOT_CFG16, 0x04E0, 0x0110, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__EPDC_DATA00, 0x04E0, 0x0110, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__EIM_ADDR17, 0x04E4, 0x0114, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__IPU1_DISP1_DATA12, 0x04E4, 0x0114, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__IPU1_CSI1_DATA12, 0x04E4, 0x0114, 2, 0x0890, 0, 0) +MX6_PAD_DECL(EIM_A17__GPIO2_IO21, 0x04E4, 0x0114, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__SRC_BOOT_CFG17, 0x04E4, 0x0114, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__EPDC_PWR_STAT, 0x04E4, 0x0114, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__EIM_ADDR18, 0x04E8, 0x0118, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__IPU1_DISP1_DATA13, 0x04E8, 0x0118, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__IPU1_CSI1_DATA13, 0x04E8, 0x0118, 2, 0x0894, 0, 0) +MX6_PAD_DECL(EIM_A18__GPIO2_IO20, 0x04E8, 0x0118, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__SRC_BOOT_CFG18, 0x04E8, 0x0118, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__EPDC_PWR_CTRL0, 0x04E8, 0x0118, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__EIM_ADDR19, 0x04EC, 0x011C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__IPU1_DISP1_DATA14, 0x04EC, 0x011C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__IPU1_CSI1_DATA14, 0x04EC, 0x011C, 2, 0x0898, 0, 0) +MX6_PAD_DECL(EIM_A19__GPIO2_IO19, 0x04EC, 0x011C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__SRC_BOOT_CFG19, 0x04EC, 0x011C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__EPDC_PWR_CTRL1, 0x04EC, 0x011C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__EIM_ADDR20, 0x04F0, 0x0120, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__IPU1_DISP1_DATA15, 0x04F0, 0x0120, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__IPU1_CSI1_DATA15, 0x04F0, 0x0120, 2, 0x089C, 0, 0) +MX6_PAD_DECL(EIM_A20__GPIO2_IO18, 0x04F0, 0x0120, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__SRC_BOOT_CFG20, 0x04F0, 0x0120, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__EPDC_PWR_CTRL2, 0x04F0, 0x0120, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__EIM_ADDR21, 0x04F4, 0x0124, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__IPU1_DISP1_DATA16, 0x04F4, 0x0124, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__IPU1_CSI1_DATA16, 0x04F4, 0x0124, 2, 0x08A0, 0, 0) +MX6_PAD_DECL(EIM_A21__GPIO2_IO17, 0x04F4, 0x0124, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__SRC_BOOT_CFG21, 0x04F4, 0x0124, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__EPDC_GDCLK, 0x04F4, 0x0124, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__EIM_ADDR22, 0x04F8, 0x0128, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__IPU1_DISP1_DATA17, 0x04F8, 0x0128, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__IPU1_CSI1_DATA17, 0x04F8, 0x0128, 2, 0x08A4, 0, 0) +MX6_PAD_DECL(EIM_A22__GPIO2_IO16, 0x04F8, 0x0128, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__SRC_BOOT_CFG22, 0x04F8, 0x0128, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__EPDC_GDSP, 0x04F8, 0x0128, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__EIM_ADDR23, 0x04FC, 0x012C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_DISP1_DATA18, 0x04FC, 0x012C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_CSI1_DATA18, 0x04FC, 0x012C, 2, 0x08A8, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_SISG3, 0x04FC, 0x012C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__GPIO6_IO06, 0x04FC, 0x012C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__SRC_BOOT_CFG23, 0x04FC, 0x012C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__EPDC_GDOE, 0x04FC, 0x012C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__EIM_ADDR24, 0x0500, 0x0130, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_DISP1_DATA19, 0x0500, 0x0130, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_CSI1_DATA19, 0x0500, 0x0130, 2, 0x08AC, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_SISG2, 0x0500, 0x0130, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__GPIO5_IO04, 0x0500, 0x0130, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__SRC_BOOT_CFG24, 0x0500, 0x0130, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__EPDC_GDRL, 0x0500, 0x0130, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__EIM_ADDR25, 0x0504, 0x0134, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI4_SS1, 0x0504, 0x0134, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI2_RDY, 0x0504, 0x0134, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI1_PIN12, 0x0504, 0x0134, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI0_D1_CS, 0x0504, 0x0134, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__GPIO5_IO02, 0x0504, 0x0134, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__HDMI_TX_CEC_LINE, 0x0504, 0x0134, 6, 0x085C, 0, 0) +MX6_PAD_DECL(EIM_A25__EPDC_DATA15, 0x0504, 0x0134, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__EIM_ACLK_FREERUN, 0x0504, 0x0134, 9, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__EIM_BCLK, 0x0508, 0x0138, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__IPU1_DI1_PIN16, 0x0508, 0x0138, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__GPIO6_IO31, 0x0508, 0x0138, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__EPDC_SDCE9, 0x0508, 0x0138, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__EIM_CS0_B, 0x050C, 0x013C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__IPU1_DI1_PIN05, 0x050C, 0x013C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__ECSPI2_SCLK, 0x050C, 0x013C, 2, 0x07F4, 2, 0) +MX6_PAD_DECL(EIM_CS0__GPIO2_IO23, 0x050C, 0x013C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__EPDC_DATA06, 0x050C, 0x013C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__EIM_CS1_B, 0x0510, 0x0140, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__IPU1_DI1_PIN06, 0x0510, 0x0140, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__ECSPI2_MOSI, 0x0510, 0x0140, 2, 0x07FC, 2, 0) +MX6_PAD_DECL(EIM_CS1__GPIO2_IO24, 0x0510, 0x0140, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__EPDC_DATA08, 0x0510, 0x0140, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__EIM_DATA16, 0x0514, 0x0144, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__ECSPI1_SCLK, 0x0514, 0x0144, 1, 0x07D8, 2, 0) +MX6_PAD_DECL(EIM_D16__IPU1_DI0_PIN05, 0x0514, 0x0144, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__IPU1_CSI1_DATA18, 0x0514, 0x0144, 3, 0x08A8, 1, 0) +MX6_PAD_DECL(EIM_D16__HDMI_TX_DDC_SDA, 0x0514, 0x0144, 4, 0x0864, 0, 0) +MX6_PAD_DECL(EIM_D16__GPIO3_IO16, 0x0514, 0x0144, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__I2C2_SDA, 0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0) +MX6_PAD_DECL(EIM_D16__EPDC_DATA10, 0x0514, 0x0144, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__EIM_DATA17, 0x0518, 0x0148, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__ECSPI1_MISO, 0x0518, 0x0148, 1, 0x07DC, 2, 0) +MX6_PAD_DECL(EIM_D17__IPU1_DI0_PIN06, 0x0518, 0x0148, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__IPU1_CSI1_PIXCLK, 0x0518, 0x0148, 3, 0x08B8, 1, 0) +MX6_PAD_DECL(EIM_D17__DCIC1_OUT, 0x0518, 0x0148, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__GPIO3_IO17, 0x0518, 0x0148, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__I2C3_SCL, 0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0) +MX6_PAD_DECL(EIM_D17__EPDC_VCOM0, 0x0518, 0x0148, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__EIM_DATA18, 0x051C, 0x014C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__ECSPI1_MOSI, 0x051C, 0x014C, 1, 0x07E0, 2, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI0_PIN07, 0x051C, 0x014C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU1_CSI1_DATA17, 0x051C, 0x014C, 3, 0x08A4, 1, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI1_D0_CS, 0x051C, 0x014C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__GPIO3_IO18, 0x051C, 0x014C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__I2C3_SDA, 0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0) +MX6_PAD_DECL(EIM_D18__EPDC_VCOM1, 0x051C, 0x014C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EIM_DATA19, 0x0520, 0x0150, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__ECSPI1_SS1, 0x0520, 0x0150, 1, 0x07E8, 1, 0) +MX6_PAD_DECL(EIM_D19__IPU1_DI0_PIN08, 0x0520, 0x0150, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__IPU1_CSI1_DATA16, 0x0520, 0x0150, 3, 0x08A0, 1, 0) +MX6_PAD_DECL(EIM_D19__UART1_CTS_B, 0x0520, 0x0150, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__UART1_RTS_B, 0x0520, 0x0150, 4, 0x08F8, 0, 0) +MX6_PAD_DECL(EIM_D19__GPIO3_IO19, 0x0520, 0x0150, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EPIT1_OUT, 0x0520, 0x0150, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EPDC_DATA12, 0x0520, 0x0150, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EIM_DATA20, 0x0524, 0x0154, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__ECSPI4_SS0, 0x0524, 0x0154, 1, 0x0808, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU1_DI0_PIN16, 0x0524, 0x0154, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU1_CSI1_DATA15, 0x0524, 0x0154, 3, 0x089C, 1, 0) +MX6_PAD_DECL(EIM_D20__UART1_CTS_B, 0x0524, 0x0154, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__UART1_RTS_B, 0x0524, 0x0154, 4, 0x08F8, 1, 0) +MX6_PAD_DECL(EIM_D20__GPIO3_IO20, 0x0524, 0x0154, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EPIT2_OUT, 0x0524, 0x0154, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__EIM_DATA21, 0x0528, 0x0158, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__ECSPI4_SCLK, 0x0528, 0x0158, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU1_DI0_PIN17, 0x0528, 0x0158, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU1_CSI1_DATA11, 0x0528, 0x0158, 3, 0x088C, 0, 0) +MX6_PAD_DECL(EIM_D21__USB_OTG_OC, 0x0528, 0x0158, 4, 0x0920, 0, 0) +MX6_PAD_DECL(EIM_D21__GPIO3_IO21, 0x0528, 0x0158, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__I2C1_SCL, 0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0) +MX6_PAD_DECL(EIM_D21__SPDIF_IN, 0x0528, 0x0158, 7, 0x08F0, 0, 0) +MX6_PAD_DECL(EIM_D22__EIM_DATA22, 0x052C, 0x015C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__ECSPI4_MISO, 0x052C, 0x015C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU1_DI0_PIN01, 0x052C, 0x015C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU1_CSI1_DATA10, 0x052C, 0x015C, 3, 0x0888, 0, 0) +MX6_PAD_DECL(EIM_D22__USB_OTG_PWR, 0x052C, 0x015C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__GPIO3_IO22, 0x052C, 0x015C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__SPDIF_OUT, 0x052C, 0x015C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__EPDC_SDCE6, 0x052C, 0x015C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__EIM_DATA23, 0x0530, 0x0160, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI0_D0_CS, 0x0530, 0x0160, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_CTS_B, 0x0530, 0x0160, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_RTS_B, 0x0530, 0x0160, 2, 0x0908, 0, 0) +MX6_PAD_DECL(EIM_D23__UART1_DCD_B, 0x0530, 0x0160, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_CSI1_DATA_EN, 0x0530, 0x0160, 4, 0x08B0, 0, 0) +MX6_PAD_DECL(EIM_D23__GPIO3_IO23, 0x0530, 0x0160, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN02, 0x0530, 0x0160, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN14, 0x0530, 0x0160, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__EPDC_DATA11, 0x0530, 0x0160, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__EIM_DATA24, 0x0534, 0x0164, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI4_SS2, 0x0534, 0x0164, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_TX_DATA, 0x0534, 0x0164, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_RX_DATA, 0x0534, 0x0164, 2, 0x090C, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI1_SS2, 0x0534, 0x0164, 3, 0x07EC, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI2_SS2, 0x0534, 0x0164, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__GPIO3_IO24, 0x0534, 0x0164, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__AUD5_RXFS, 0x0534, 0x0164, 6, 0x07BC, 1, 0) +MX6_PAD_DECL(EIM_D24__UART1_DTR_B, 0x0534, 0x0164, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__EPDC_SDCE7, 0x0534, 0x0164, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__EIM_DATA25, 0x0538, 0x0168, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI4_SS3, 0x0538, 0x0168, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_TX_DATA, 0x0538, 0x0168, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_RX_DATA, 0x0538, 0x0168, 2, 0x090C, 1, 0) +MX6_PAD_DECL(EIM_D25__ECSPI1_SS3, 0x0538, 0x0168, 3, 0x07F0, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI2_SS3, 0x0538, 0x0168, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__GPIO3_IO25, 0x0538, 0x0168, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__AUD5_RXC, 0x0538, 0x0168, 6, 0x07B8, 1, 0) +MX6_PAD_DECL(EIM_D25__UART1_DSR_B, 0x0538, 0x0168, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__EPDC_SDCE8, 0x0538, 0x0168, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__EIM_DATA26, 0x053C, 0x016C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_DI1_PIN11, 0x053C, 0x016C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_CSI0_DATA01, 0x053C, 0x016C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_CSI1_DATA14, 0x053C, 0x016C, 3, 0x0898, 1, 0) +MX6_PAD_DECL(EIM_D26__UART2_TX_DATA, 0x053C, 0x016C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__UART2_RX_DATA, 0x053C, 0x016C, 4, 0x0904, 0, 0) +MX6_PAD_DECL(EIM_D26__GPIO3_IO26, 0x053C, 0x016C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_SISG2, 0x053C, 0x016C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_DISP1_DATA22, 0x053C, 0x016C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__EPDC_SDOED, 0x053C, 0x016C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__EIM_DATA27, 0x0540, 0x0170, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_DI1_PIN13, 0x0540, 0x0170, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_CSI0_DATA00, 0x0540, 0x0170, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_CSI1_DATA13, 0x0540, 0x0170, 3, 0x0894, 1, 0) +MX6_PAD_DECL(EIM_D27__UART2_TX_DATA, 0x0540, 0x0170, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__UART2_RX_DATA, 0x0540, 0x0170, 4, 0x0904, 1, 0) +MX6_PAD_DECL(EIM_D27__GPIO3_IO27, 0x0540, 0x0170, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_SISG3, 0x0540, 0x0170, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_DISP1_DATA23, 0x0540, 0x0170, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__EPDC_SDOE, 0x0540, 0x0170, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__EIM_DATA28, 0x0544, 0x0174, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__I2C1_SDA, 0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0) +MX6_PAD_DECL(EIM_D28__ECSPI4_MOSI, 0x0544, 0x0174, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_CSI1_DATA12, 0x0544, 0x0174, 3, 0x0890, 1, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_RTS_B, 0x0544, 0x0174, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_CTS_B, 0x0544, 0x0174, 4, 0x0900, 0, 0) +MX6_PAD_DECL(EIM_D28__GPIO3_IO28, 0x0544, 0x0174, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_EXT_TRIG, 0x0544, 0x0174, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_DI0_PIN13, 0x0544, 0x0174, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__EPDC_PWR_CTRL3, 0x0544, 0x0174, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__EIM_DATA29, 0x0548, 0x0178, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI1_PIN15, 0x0548, 0x0178, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__ECSPI4_SS0, 0x0548, 0x0178, 2, 0x0808, 1, 0) +MX6_PAD_DECL(EIM_D29__UART2_CTS_B, 0x0548, 0x0178, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__UART2_RTS_B, 0x0548, 0x0178, 4, 0x0900, 1, 0) +MX6_PAD_DECL(EIM_D29__GPIO3_IO29, 0x0548, 0x0178, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_CSI1_VSYNC, 0x0548, 0x0178, 6, 0x08BC, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI0_PIN14, 0x0548, 0x0178, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__EPDC_PWR_WAKE, 0x0548, 0x0178, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__EIM_DATA30, 0x054C, 0x017C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_DISP1_DATA21, 0x054C, 0x017C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_DI0_PIN11, 0x054C, 0x017C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_CSI0_DATA03, 0x054C, 0x017C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_CTS_B, 0x054C, 0x017C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_RTS_B, 0x054C, 0x017C, 4, 0x0908, 1, 0) +MX6_PAD_DECL(EIM_D30__GPIO3_IO30, 0x054C, 0x017C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__USB_H1_OC, 0x054C, 0x017C, 6, 0x0924, 0, 0) +MX6_PAD_DECL(EIM_D30__EPDC_SDOEZ, 0x054C, 0x017C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__EIM_DATA31, 0x0550, 0x0180, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_DISP1_DATA20, 0x0550, 0x0180, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_DI0_PIN12, 0x0550, 0x0180, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_CSI0_DATA02, 0x0550, 0x0180, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_CTS_B, 0x0550, 0x0180, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_RTS_B, 0x0550, 0x0180, 4, 0x0908, 2, 0) +MX6_PAD_DECL(EIM_D31__GPIO3_IO31, 0x0550, 0x0180, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__USB_H1_PWR, 0x0550, 0x0180, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__EPDC_SDCLK_P, 0x0550, 0x0180, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__EIM_ACLK_FREERUN, 0x0550, 0x0180, 9, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__EIM_AD00, 0x0554, 0x0184, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__IPU1_DISP1_DATA09, 0x0554, 0x0184, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__IPU1_CSI1_DATA09, 0x0554, 0x0184, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__GPIO3_IO00, 0x0554, 0x0184, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__SRC_BOOT_CFG00, 0x0554, 0x0184, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__EPDC_SDCLK_N, 0x0554, 0x0184, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__EIM_AD01, 0x0558, 0x0188, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__IPU1_DISP1_DATA08, 0x0558, 0x0188, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__IPU1_CSI1_DATA08, 0x0558, 0x0188, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__GPIO3_IO01, 0x0558, 0x0188, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__SRC_BOOT_CFG01, 0x0558, 0x0188, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__EPDC_SDLE, 0x0558, 0x0188, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__EIM_AD10, 0x055C, 0x018C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__IPU1_DI1_PIN15, 0x055C, 0x018C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__IPU1_CSI1_DATA_EN, 0x055C, 0x018C, 2, 0x08B0, 1, 0) +MX6_PAD_DECL(EIM_DA10__GPIO3_IO10, 0x055C, 0x018C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__SRC_BOOT_CFG10, 0x055C, 0x018C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__EPDC_DATA01, 0x055C, 0x018C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__EIM_AD11, 0x0560, 0x0190, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU1_DI1_PIN02, 0x0560, 0x0190, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU1_CSI1_HSYNC, 0x0560, 0x0190, 2, 0x08B4, 0, 0) +MX6_PAD_DECL(EIM_DA11__GPIO3_IO11, 0x0560, 0x0190, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__SRC_BOOT_CFG11, 0x0560, 0x0190, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__EPDC_DATA03, 0x0560, 0x0190, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__EIM_AD12, 0x0564, 0x0194, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU1_DI1_PIN03, 0x0564, 0x0194, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU1_CSI1_VSYNC, 0x0564, 0x0194, 2, 0x08BC, 1, 0) +MX6_PAD_DECL(EIM_DA12__GPIO3_IO12, 0x0564, 0x0194, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__SRC_BOOT_CFG12, 0x0564, 0x0194, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__EPDC_DATA02, 0x0564, 0x0194, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__EIM_AD13, 0x0568, 0x0198, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__IPU1_DI1_D0_CS, 0x0568, 0x0198, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__GPIO3_IO13, 0x0568, 0x0198, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__SRC_BOOT_CFG13, 0x0568, 0x0198, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__EPDC_DATA13, 0x0568, 0x0198, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__EIM_AD14, 0x056C, 0x019C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__IPU1_DI1_D1_CS, 0x056C, 0x019C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__GPIO3_IO14, 0x056C, 0x019C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__SRC_BOOT_CFG14, 0x056C, 0x019C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__EPDC_DATA14, 0x056C, 0x019C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__EIM_AD15, 0x0570, 0x01A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN01, 0x0570, 0x01A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN04, 0x0570, 0x01A0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__GPIO3_IO15, 0x0570, 0x01A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__SRC_BOOT_CFG15, 0x0570, 0x01A0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__EPDC_DATA09, 0x0570, 0x01A0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__EIM_AD02, 0x0574, 0x01A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__IPU1_DISP1_DATA07, 0x0574, 0x01A4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__IPU1_CSI1_DATA07, 0x0574, 0x01A4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__GPIO3_IO02, 0x0574, 0x01A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__SRC_BOOT_CFG02, 0x0574, 0x01A4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__EPDC_BDR0, 0x0574, 0x01A4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__EIM_AD03, 0x0578, 0x01A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__IPU1_DISP1_DATA06, 0x0578, 0x01A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__IPU1_CSI1_DATA06, 0x0578, 0x01A8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__GPIO3_IO03, 0x0578, 0x01A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__SRC_BOOT_CFG03, 0x0578, 0x01A8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__EPDC_BDR1, 0x0578, 0x01A8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__EIM_AD04, 0x057C, 0x01AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__IPU1_DISP1_DATA05, 0x057C, 0x01AC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__IPU1_CSI1_DATA05, 0x057C, 0x01AC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__GPIO3_IO04, 0x057C, 0x01AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__SRC_BOOT_CFG04, 0x057C, 0x01AC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__EPDC_SDCE0, 0x057C, 0x01AC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__EIM_AD05, 0x0580, 0x01B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__IPU1_DISP1_DATA04, 0x0580, 0x01B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__IPU1_CSI1_DATA04, 0x0580, 0x01B0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__GPIO3_IO05, 0x0580, 0x01B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__SRC_BOOT_CFG05, 0x0580, 0x01B0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__EPDC_SDCE1, 0x0580, 0x01B0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__EIM_AD06, 0x0584, 0x01B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__IPU1_DISP1_DATA03, 0x0584, 0x01B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__IPU1_CSI1_DATA03, 0x0584, 0x01B4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__GPIO3_IO06, 0x0584, 0x01B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__SRC_BOOT_CFG06, 0x0584, 0x01B4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__EPDC_SDCE2, 0x0584, 0x01B4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__EIM_AD07, 0x0588, 0x01B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__IPU1_DISP1_DATA02, 0x0588, 0x01B8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__IPU1_CSI1_DATA02, 0x0588, 0x01B8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__GPIO3_IO07, 0x0588, 0x01B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__SRC_BOOT_CFG07, 0x0588, 0x01B8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__EPDC_SDCE3, 0x0588, 0x01B8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__EIM_AD08, 0x058C, 0x01BC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__IPU1_DISP1_DATA01, 0x058C, 0x01BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__IPU1_CSI1_DATA01, 0x058C, 0x01BC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__GPIO3_IO08, 0x058C, 0x01BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__SRC_BOOT_CFG08, 0x058C, 0x01BC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__EPDC_SDCE4, 0x058C, 0x01BC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__EIM_AD09, 0x0590, 0x01C0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__IPU1_DISP1_DATA00, 0x0590, 0x01C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__IPU1_CSI1_DATA00, 0x0590, 0x01C0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__GPIO3_IO09, 0x0590, 0x01C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__SRC_BOOT_CFG09, 0x0590, 0x01C0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__EPDC_SDCE5, 0x0590, 0x01C0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__EIM_EB0_B, 0x0594, 0x01C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__IPU1_DISP1_DATA11, 0x0594, 0x01C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__IPU1_CSI1_DATA11, 0x0594, 0x01C4, 2, 0x088C, 1, 0) +MX6_PAD_DECL(EIM_EB0__CCM_PMIC_READY, 0x0594, 0x01C4, 4, 0x07D4, 0, 0) +MX6_PAD_DECL(EIM_EB0__GPIO2_IO28, 0x0594, 0x01C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__SRC_BOOT_CFG27, 0x0594, 0x01C4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__EPDC_PWR_COM, 0x0594, 0x01C4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__EIM_EB1_B, 0x0598, 0x01C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__IPU1_DISP1_DATA10, 0x0598, 0x01C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__IPU1_CSI1_DATA10, 0x0598, 0x01C8, 2, 0x0888, 1, 0) +MX6_PAD_DECL(EIM_EB1__GPIO2_IO29, 0x0598, 0x01C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__SRC_BOOT_CFG28, 0x0598, 0x01C8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__EPDC_SDSHR, 0x0598, 0x01C8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__EIM_EB2_B, 0x059C, 0x01CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__ECSPI1_SS0, 0x059C, 0x01CC, 1, 0x07E4, 2, 0) +MX6_PAD_DECL(EIM_EB2__IPU1_CSI1_DATA19, 0x059C, 0x01CC, 3, 0x08AC, 1, 0) +MX6_PAD_DECL(EIM_EB2__HDMI_TX_DDC_SCL, 0x059C, 0x01CC, 4, 0x0860, 0, 0) +MX6_PAD_DECL(EIM_EB2__GPIO2_IO30, 0x059C, 0x01CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__I2C2_SCL, 0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0) +MX6_PAD_DECL(EIM_EB2__SRC_BOOT_CFG30, 0x059C, 0x01CC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__EPDC_DATA05, 0x059C, 0x01CC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EIM_EB3_B, 0x05A0, 0x01D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__ECSPI4_RDY, 0x05A0, 0x01D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_CTS_B, 0x05A0, 0x01D0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_RTS_B, 0x05A0, 0x01D0, 2, 0x0908, 3, 0) +MX6_PAD_DECL(EIM_EB3__UART1_RI_B, 0x05A0, 0x01D0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU1_CSI1_HSYNC, 0x05A0, 0x01D0, 4, 0x08B4, 1, 0) +MX6_PAD_DECL(EIM_EB3__GPIO2_IO31, 0x05A0, 0x01D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU1_DI1_PIN03, 0x05A0, 0x01D0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__SRC_BOOT_CFG31, 0x05A0, 0x01D0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EPDC_SDCE0, 0x05A0, 0x01D0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EIM_ACLK_FREERUN, 0x05A0, 0x01D0, 9, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__EIM_LBA_B, 0x05A4, 0x01D4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__IPU1_DI1_PIN17, 0x05A4, 0x01D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__ECSPI2_SS1, 0x05A4, 0x01D4, 2, 0x0804, 1, 0) +MX6_PAD_DECL(EIM_LBA__GPIO2_IO27, 0x05A4, 0x01D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__SRC_BOOT_CFG26, 0x05A4, 0x01D4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__EPDC_DATA04, 0x05A4, 0x01D4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__EIM_OE_B, 0x05A8, 0x01D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__IPU1_DI1_PIN07, 0x05A8, 0x01D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__ECSPI2_MISO, 0x05A8, 0x01D8, 2, 0x07F8, 2, 0) +MX6_PAD_DECL(EIM_OE__GPIO2_IO25, 0x05A8, 0x01D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__EPDC_PWR_IRQ, 0x05A8, 0x01D8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__EIM_RW, 0x05AC, 0x01DC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__IPU1_DI1_PIN08, 0x05AC, 0x01DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__ECSPI2_SS0, 0x05AC, 0x01DC, 2, 0x0800, 2, 0) +MX6_PAD_DECL(EIM_RW__GPIO2_IO26, 0x05AC, 0x01DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__SRC_BOOT_CFG29, 0x05AC, 0x01DC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__EPDC_DATA07, 0x05AC, 0x01DC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_WAIT_B, 0x05B0, 0x01E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_DTACK_B, 0x05B0, 0x01E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__GPIO5_IO00, 0x05B0, 0x01E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__SRC_BOOT_CFG25, 0x05B0, 0x01E0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__ENET_RX_EN, 0x05B4, 0x01E4, 1, 0x0828, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__ESAI_TX_CLK, 0x05B4, 0x01E4, 2, 0x0840, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__SPDIF_EXT_CLK, 0x05B4, 0x01E4, 3, 0x08F4, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__GPIO1_IO25, 0x05B4, 0x01E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__MLB_DATA, 0x05B8, 0x01E8, 0, 0x08E0, 0, 0) +MX6_PAD_DECL(ENET_MDC__ENET_MDC, 0x05B8, 0x01E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__ESAI_TX5_RX0, 0x05B8, 0x01E8, 2, 0x0858, 0, 0) +MX6_PAD_DECL(ENET_MDC__ENET_1588_EVENT1_IN, 0x05B8, 0x01E8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__GPIO1_IO31, 0x05B8, 0x01E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ENET_MDIO, 0x05BC, 0x01EC, 1, 0x0810, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ESAI_RX_CLK, 0x05BC, 0x01EC, 2, 0x083C, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ENET_1588_EVENT1_OUT, 0x05BC, 0x01EC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__GPIO1_IO22, 0x05BC, 0x01EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__SPDIF_LOCK, 0x05BC, 0x01EC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ENET_TX_CLK, 0x05C0, 0x01F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ESAI_RX_FS, 0x05C0, 0x01F0, 2, 0x082C, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__GPIO1_IO23, 0x05C0, 0x01F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__SPDIF_SR_CLK, 0x05C0, 0x01F0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__USB_OTG_ID, 0x05C4, 0x01F4, 0, 0x0790, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__ENET_RX_ER, 0x05C4, 0x01F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__ESAI_RX_HF_CLK, 0x05C4, 0x01F4, 2, 0x0834, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__SPDIF_IN, 0x05C4, 0x01F4, 3, 0x08F0, 1, 0) +MX6_PAD_DECL(ENET_RX_ER__ENET_1588_EVENT2_OUT, 0x05C4, 0x01F4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__GPIO1_IO24, 0x05C4, 0x01F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__ENET_RX_DATA0, 0x05C8, 0x01F8, 1, 0x0818, 0, 0) +MX6_PAD_DECL(ENET_RXD0__ESAI_TX_HF_CLK, 0x05C8, 0x01F8, 2, 0x0838, 0, 0) +MX6_PAD_DECL(ENET_RXD0__SPDIF_OUT, 0x05C8, 0x01F8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__GPIO1_IO27, 0x05C8, 0x01F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD1__MLB_SIG, 0x05CC, 0x01FC, 0, 0x08E4, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ENET_RX_DATA1, 0x05CC, 0x01FC, 1, 0x081C, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ESAI_TX_FS, 0x05CC, 0x01FC, 2, 0x0830, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ENET_1588_EVENT3_OUT, 0x05CC, 0x01FC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD1__GPIO1_IO26, 0x05CC, 0x01FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ENET_TX_EN, 0x05D0, 0x0200, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ESAI_TX3_RX2, 0x05D0, 0x0200, 2, 0x0850, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__GPIO1_IO28, 0x05D0, 0x0200, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__I2C4_SCL, 0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ENET_TX_DATA0, 0x05D4, 0x0204, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ESAI_TX4_RX1, 0x05D4, 0x0204, 2, 0x0854, 0, 0) +MX6_PAD_DECL(ENET_TXD0__GPIO1_IO30, 0x05D4, 0x0204, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__MLB_CLK, 0x05D8, 0x0208, 0, 0x08DC, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ENET_TX_DATA1, 0x05D8, 0x0208, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ESAI_TX2_RX3, 0x05D8, 0x0208, 2, 0x084C, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ENET_1588_EVENT0_IN, 0x05D8, 0x0208, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__GPIO1_IO29, 0x05D8, 0x0208, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__I2C4_SDA, 0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0) +MX6_PAD_DECL(GPIO_0__CCM_CLKO1, 0x05DC, 0x020C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__KEY_COL5, 0x05DC, 0x020C, 2, 0x08C0, 1, 0) +MX6_PAD_DECL(GPIO_0__ASRC_EXT_CLK, 0x05DC, 0x020C, 3, 0x0794, 0, 0) +MX6_PAD_DECL(GPIO_0__EPIT1_OUT, 0x05DC, 0x020C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__GPIO1_IO00, 0x05DC, 0x020C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__USB_H1_PWR, 0x05DC, 0x020C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__SNVS_VIO_5, 0x05DC, 0x020C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__ESAI_RX_CLK, 0x05E0, 0x0210, 0, 0x083C, 1, 0) +MX6_PAD_DECL(GPIO_1__WDOG2_B, 0x05E0, 0x0210, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__KEY_ROW5, 0x05E0, 0x0210, 2, 0x08CC, 1, 0) +MX6_PAD_DECL(GPIO_1__USB_OTG_ID, 0x05E0, 0x0210, 3, 0x0790, 1, 0) +MX6_PAD_DECL(GPIO_1__PWM2_OUT, 0x05E0, 0x0210, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__GPIO1_IO01, 0x05E0, 0x0210, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__SD1_CD_B, 0x05E0, 0x0210, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__ESAI_TX3_RX2, 0x05E4, 0x0214, 0, 0x0850, 1, 0) +MX6_PAD_DECL(GPIO_16__ENET_1588_EVENT2_IN, 0x05E4, 0x0214, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__ENET_REF_CLK, 0x05E4, 0x0214, 2, 0x080C, 0, 0) +MX6_PAD_DECL(GPIO_16__SD1_LCTL, 0x05E4, 0x0214, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__SPDIF_IN, 0x05E4, 0x0214, 4, 0x08F0, 2, 0) +MX6_PAD_DECL(GPIO_16__GPIO7_IO11, 0x05E4, 0x0214, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__I2C3_SDA, 0x05E4, 0x0214, 6 | IOMUX_CONFIG_SION, 0x087C, 1, 0) +MX6_PAD_DECL(GPIO_16__JTAG_DE_B, 0x05E4, 0x0214, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__ESAI_TX0, 0x05E8, 0x0218, 0, 0x0844, 0, 0) +MX6_PAD_DECL(GPIO_17__ENET_1588_EVENT3_IN, 0x05E8, 0x0218, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__CCM_PMIC_READY, 0x05E8, 0x0218, 2, 0x07D4, 1, 0) +MX6_PAD_DECL(GPIO_17__SDMA_EXT_EVENT0, 0x05E8, 0x0218, 3, 0x08E8, 1, 0) +MX6_PAD_DECL(GPIO_17__SPDIF_OUT, 0x05E8, 0x0218, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__GPIO7_IO12, 0x05E8, 0x0218, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__ESAI_TX1, 0x05EC, 0x021C, 0, 0x0848, 0, 0) +MX6_PAD_DECL(GPIO_18__ENET_RX_CLK, 0x05EC, 0x021C, 1, 0x0814, 0, 0) +MX6_PAD_DECL(GPIO_18__SD3_VSELECT, 0x05EC, 0x021C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SDMA_EXT_EVENT1, 0x05EC, 0x021C, 3, 0x08EC, 1, 0) +MX6_PAD_DECL(GPIO_18__ASRC_EXT_CLK, 0x05EC, 0x021C, 4, 0x0794, 1, 0) +MX6_PAD_DECL(GPIO_18__GPIO7_IO13, 0x05EC, 0x021C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SNVS_VIO_5_CTL, 0x05EC, 0x021C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__KEY_COL5, 0x05F0, 0x0220, 0, 0x08C0, 2, 0) +MX6_PAD_DECL(GPIO_19__ENET_1588_EVENT0_OUT, 0x05F0, 0x0220, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__SPDIF_OUT, 0x05F0, 0x0220, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__CCM_CLKO1, 0x05F0, 0x0220, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ECSPI1_RDY, 0x05F0, 0x0220, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__GPIO4_IO05, 0x05F0, 0x0220, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ENET_TX_ER, 0x05F0, 0x0220, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__ESAI_TX_FS, 0x05F4, 0x0224, 0, 0x0830, 1, 0) +MX6_PAD_DECL(GPIO_2__KEY_ROW6, 0x05F4, 0x0224, 2, 0x08D0, 1, 0) +MX6_PAD_DECL(GPIO_2__GPIO1_IO02, 0x05F4, 0x0224, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__SD2_WP, 0x05F4, 0x0224, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__MLB_DATA, 0x05F4, 0x0224, 7, 0x08E0, 1, 0) +MX6_PAD_DECL(GPIO_3__ESAI_RX_HF_CLK, 0x05F8, 0x0228, 0, 0x0834, 1, 0) +MX6_PAD_DECL(GPIO_3__I2C3_SCL, 0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0) +MX6_PAD_DECL(GPIO_3__XTALOSC_REF_CLK_24M, 0x05F8, 0x0228, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__CCM_CLKO2, 0x05F8, 0x0228, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__GPIO1_IO03, 0x05F8, 0x0228, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__USB_H1_OC, 0x05F8, 0x0228, 6, 0x0924, 1, 0) +MX6_PAD_DECL(GPIO_3__MLB_CLK, 0x05F8, 0x0228, 7, 0x08DC, 1, 0) +MX6_PAD_DECL(GPIO_4__ESAI_TX_HF_CLK, 0x05FC, 0x022C, 0, 0x0838, 1, 0) +MX6_PAD_DECL(GPIO_4__KEY_COL7, 0x05FC, 0x022C, 2, 0x08C8, 1, 0) +MX6_PAD_DECL(GPIO_4__GPIO1_IO04, 0x05FC, 0x022C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_4__SD2_CD_B, 0x05FC, 0x022C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__ESAI_TX2_RX3, 0x0600, 0x0230, 0, 0x084C, 1, 0) +MX6_PAD_DECL(GPIO_5__KEY_ROW7, 0x0600, 0x0230, 2, 0x08D4, 1, 0) +MX6_PAD_DECL(GPIO_5__CCM_CLKO1, 0x0600, 0x0230, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__GPIO1_IO05, 0x0600, 0x0230, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__I2C3_SCL, 0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0) +MX6_PAD_DECL(GPIO_5__ARM_EVENTI, 0x0600, 0x0230, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__ESAI_TX_CLK, 0x0604, 0x0234, 0, 0x0840, 1, 0) +MX6_PAD_DECL(GPIO_6__I2C3_SDA, 0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0) +MX6_PAD_DECL(GPIO_6__GPIO1_IO06, 0x0604, 0x0234, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__SD2_LCTL, 0x0604, 0x0234, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__MLB_SIG, 0x0604, 0x0234, 7, 0x08E4, 1, 0) +MX6_PAD_DECL(GPIO_7__ESAI_TX4_RX1, 0x0608, 0x0238, 0, 0x0854, 1, 0) +MX6_PAD_DECL(GPIO_7__EPIT1_OUT, 0x0608, 0x0238, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__FLEXCAN1_TX, 0x0608, 0x0238, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_TX_DATA, 0x0608, 0x0238, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_RX_DATA, 0x0608, 0x0238, 4, 0x0904, 2, 0) +MX6_PAD_DECL(GPIO_7__GPIO1_IO07, 0x0608, 0x0238, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__SPDIF_LOCK, 0x0608, 0x0238, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__USB_OTG_HOST_MODE, 0x0608, 0x0238, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__I2C4_SCL, 0x0608, 0x0238, 8 | IOMUX_CONFIG_SION, 0x0880, 1, 0) +MX6_PAD_DECL(GPIO_8__ESAI_TX5_RX0, 0x060C, 0x023C, 0, 0x0858, 1, 0) +MX6_PAD_DECL(GPIO_8__XTALOSC_REF_CLK_32K, 0x060C, 0x023C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__EPIT2_OUT, 0x060C, 0x023C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__FLEXCAN1_RX, 0x060C, 0x023C, 3, 0x07C8, 0, 0) +MX6_PAD_DECL(GPIO_8__UART2_TX_DATA, 0x060C, 0x023C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__UART2_RX_DATA, 0x060C, 0x023C, 4, 0x0904, 3, 0) +MX6_PAD_DECL(GPIO_8__GPIO1_IO08, 0x060C, 0x023C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__SPDIF_SR_CLK, 0x060C, 0x023C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__USB_OTG_PWR_CTL_WAKE, 0x060C, 0x023C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__I2C4_SDA, 0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0) +MX6_PAD_DECL(GPIO_9__ESAI_RX_FS, 0x0610, 0x0240, 0, 0x082C, 1, 0) +MX6_PAD_DECL(GPIO_9__WDOG1_B, 0x0610, 0x0240, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__KEY_COL6, 0x0610, 0x0240, 2, 0x08C4, 1, 0) +MX6_PAD_DECL(GPIO_9__CCM_REF_EN_B, 0x0610, 0x0240, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__PWM1_OUT, 0x0610, 0x0240, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__GPIO1_IO09, 0x0610, 0x0240, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__SD1_WP, 0x0610, 0x0240, 6, 0x092C, 1, 0) +MX6_PAD_DECL(KEY_COL0__ECSPI1_SCLK, 0x062C, 0x0244, 0, 0x07D8, 3, 0) +MX6_PAD_DECL(KEY_COL0__ENET_RX_DATA3, 0x062C, 0x0244, 1, 0x0824, 0, 0) +MX6_PAD_DECL(KEY_COL0__AUD5_TXC, 0x062C, 0x0244, 2, 0x07C0, 1, 0) +MX6_PAD_DECL(KEY_COL0__KEY_COL0, 0x062C, 0x0244, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_TX_DATA, 0x062C, 0x0244, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_RX_DATA, 0x062C, 0x0244, 4, 0x0914, 2, 0) +MX6_PAD_DECL(KEY_COL0__GPIO4_IO06, 0x062C, 0x0244, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__DCIC1_OUT, 0x062C, 0x0244, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__ECSPI1_MISO, 0x0630, 0x0248, 0, 0x07DC, 3, 0) +MX6_PAD_DECL(KEY_COL1__ENET_MDIO, 0x0630, 0x0248, 1, 0x0810, 1, 0) +MX6_PAD_DECL(KEY_COL1__AUD5_TXFS, 0x0630, 0x0248, 2, 0x07C4, 1, 0) +MX6_PAD_DECL(KEY_COL1__KEY_COL1, 0x0630, 0x0248, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_TX_DATA, 0x0630, 0x0248, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_RX_DATA, 0x0630, 0x0248, 4, 0x091C, 2, 0) +MX6_PAD_DECL(KEY_COL1__GPIO4_IO08, 0x0630, 0x0248, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__SD1_VSELECT, 0x0630, 0x0248, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ECSPI1_SS1, 0x0634, 0x024C, 0, 0x07E8, 2, 0) +MX6_PAD_DECL(KEY_COL2__ENET_RX_DATA2, 0x0634, 0x024C, 1, 0x0820, 0, 0) +MX6_PAD_DECL(KEY_COL2__FLEXCAN1_TX, 0x0634, 0x024C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__KEY_COL2, 0x0634, 0x024C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ENET_MDC, 0x0634, 0x024C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__GPIO4_IO10, 0x0634, 0x024C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__USB_H1_PWR_CTL_WAKE, 0x0634, 0x024C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__ECSPI1_SS3, 0x0638, 0x0250, 0, 0x07F0, 1, 0) +MX6_PAD_DECL(KEY_COL3__ENET_CRS, 0x0638, 0x0250, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__HDMI_TX_DDC_SCL, 0x0638, 0x0250, 2, 0x0860, 1, 0) +MX6_PAD_DECL(KEY_COL3__KEY_COL3, 0x0638, 0x0250, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__I2C2_SCL, 0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0) +MX6_PAD_DECL(KEY_COL3__GPIO4_IO12, 0x0638, 0x0250, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__SPDIF_IN, 0x0638, 0x0250, 6, 0x08F0, 3, 0) +MX6_PAD_DECL(KEY_COL4__FLEXCAN2_TX, 0x063C, 0x0254, 0, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__IPU1_SISG4, 0x063C, 0x0254, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__USB_OTG_OC, 0x063C, 0x0254, 2, 0x0920, 1, 0) +MX6_PAD_DECL(KEY_COL4__KEY_COL4, 0x063C, 0x0254, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_CTS_B, 0x063C, 0x0254, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_RTS_B, 0x063C, 0x0254, 4, 0x0918, 2, 0) +MX6_PAD_DECL(KEY_COL4__GPIO4_IO14, 0x063C, 0x0254, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__ECSPI1_MOSI, 0x0640, 0x0258, 0, 0x07E0, 3, 0) +MX6_PAD_DECL(KEY_ROW0__ENET_TX_DATA3, 0x0640, 0x0258, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__AUD5_TXD, 0x0640, 0x0258, 2, 0x07B4, 1, 0) +MX6_PAD_DECL(KEY_ROW0__KEY_ROW0, 0x0640, 0x0258, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_TX_DATA, 0x0640, 0x0258, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_RX_DATA, 0x0640, 0x0258, 4, 0x0914, 3, 0) +MX6_PAD_DECL(KEY_ROW0__GPIO4_IO07, 0x0640, 0x0258, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__DCIC2_OUT, 0x0640, 0x0258, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__ECSPI1_SS0, 0x0644, 0x025C, 0, 0x07E4, 3, 0) +MX6_PAD_DECL(KEY_ROW1__ENET_COL, 0x0644, 0x025C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__AUD5_RXD, 0x0644, 0x025C, 2, 0x07B0, 1, 0) +MX6_PAD_DECL(KEY_ROW1__KEY_ROW1, 0x0644, 0x025C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_TX_DATA, 0x0644, 0x025C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_RX_DATA, 0x0644, 0x025C, 4, 0x091C, 3, 0) +MX6_PAD_DECL(KEY_ROW1__GPIO4_IO09, 0x0644, 0x025C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__SD2_VSELECT, 0x0644, 0x025C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__ECSPI1_SS2, 0x0648, 0x0260, 0, 0x07EC, 1, 0) +MX6_PAD_DECL(KEY_ROW2__ENET_TX_DATA2, 0x0648, 0x0260, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__FLEXCAN1_RX, 0x0648, 0x0260, 2, 0x07C8, 1, 0) +MX6_PAD_DECL(KEY_ROW2__KEY_ROW2, 0x0648, 0x0260, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__SD2_VSELECT, 0x0648, 0x0260, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__GPIO4_IO11, 0x0648, 0x0260, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__HDMI_TX_CEC_LINE, 0x0648, 0x0260, 6, 0x085C, 1, 0) +MX6_PAD_DECL(KEY_ROW3__ASRC_EXT_CLK, 0x064C, 0x0264, 1, 0x0794, 2, 0) +MX6_PAD_DECL(KEY_ROW3__HDMI_TX_DDC_SDA, 0x064C, 0x0264, 2, 0x0864, 1, 0) +MX6_PAD_DECL(KEY_ROW3__KEY_ROW3, 0x064C, 0x0264, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__I2C2_SDA, 0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0) +MX6_PAD_DECL(KEY_ROW3__GPIO4_IO13, 0x064C, 0x0264, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__SD1_VSELECT, 0x064C, 0x0264, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__FLEXCAN2_RX, 0x0650, 0x0268, 0, 0x07CC, 0, 0) +MX6_PAD_DECL(KEY_ROW4__IPU1_SISG5, 0x0650, 0x0268, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__USB_OTG_PWR, 0x0650, 0x0268, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__KEY_ROW4, 0x0650, 0x0268, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_CTS_B, 0x0650, 0x0268, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_RTS_B, 0x0650, 0x0268, 4, 0x0918, 3, 0) +MX6_PAD_DECL(KEY_ROW4__GPIO4_IO15, 0x0650, 0x0268, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__NAND_ALE, 0x0654, 0x026C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__SD4_RESET, 0x0654, 0x026C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__GPIO6_IO08, 0x0654, 0x026C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__NAND_CLE, 0x0658, 0x0270, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__GPIO6_IO07, 0x0658, 0x0270, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__NAND_CE0_B, 0x065C, 0x0274, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__GPIO6_IO11, 0x065C, 0x0274, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__NAND_CE1_B, 0x0660, 0x0278, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD4_VSELECT, 0x0660, 0x0278, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD3_VSELECT, 0x0660, 0x0278, 2, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__GPIO6_IO14, 0x0660, 0x0278, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__NAND_CE2_B, 0x0664, 0x027C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__IPU1_SISG0, 0x0664, 0x027C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__ESAI_TX0, 0x0664, 0x027C, 2, 0x0844, 1, 0) +MX6_PAD_DECL(NANDF_CS2__EIM_CRE, 0x0664, 0x027C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__CCM_CLKO2, 0x0664, 0x027C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__GPIO6_IO15, 0x0664, 0x027C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__NAND_CE3_B, 0x0668, 0x0280, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__IPU1_SISG1, 0x0668, 0x0280, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__ESAI_TX1, 0x0668, 0x0280, 2, 0x0848, 1, 0) +MX6_PAD_DECL(NANDF_CS3__EIM_ADDR26, 0x0668, 0x0280, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__GPIO6_IO16, 0x0668, 0x0280, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__I2C4_SDA, 0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0) +MX6_PAD_DECL(NANDF_D0__NAND_DATA00, 0x066C, 0x0284, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__SD1_DATA4, 0x066C, 0x0284, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__GPIO2_IO00, 0x066C, 0x0284, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__NAND_DATA01, 0x0670, 0x0288, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__SD1_DATA5, 0x0670, 0x0288, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__GPIO2_IO01, 0x0670, 0x0288, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__NAND_DATA02, 0x0674, 0x028C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__SD1_DATA6, 0x0674, 0x028C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__GPIO2_IO02, 0x0674, 0x028C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__NAND_DATA03, 0x0678, 0x0290, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__SD1_DATA7, 0x0678, 0x0290, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__GPIO2_IO03, 0x0678, 0x0290, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__NAND_DATA04, 0x067C, 0x0294, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__SD2_DATA4, 0x067C, 0x0294, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__GPIO2_IO04, 0x067C, 0x0294, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__NAND_DATA05, 0x0680, 0x0298, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__SD2_DATA5, 0x0680, 0x0298, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__GPIO2_IO05, 0x0680, 0x0298, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__NAND_DATA06, 0x0684, 0x029C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__SD2_DATA6, 0x0684, 0x029C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__GPIO2_IO06, 0x0684, 0x029C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__NAND_DATA07, 0x0688, 0x02A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__SD2_DATA7, 0x0688, 0x02A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__GPIO2_IO07, 0x0688, 0x02A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__NAND_READY_B, 0x068C, 0x02A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__GPIO6_IO10, 0x068C, 0x02A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__NAND_WP_B, 0x0690, 0x02A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__GPIO6_IO09, 0x0690, 0x02A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__I2C4_SCL, 0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0) +MX6_PAD_DECL(RGMII_RD0__HSI_RX_READY, 0x0694, 0x02AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD0__RGMII_RD0, 0x0694, 0x02AC, 1, 0x0818, 1, 0) +MX6_PAD_DECL(RGMII_RD0__GPIO6_IO25, 0x0694, 0x02AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__HSI_TX_FLAG, 0x0698, 0x02B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__RGMII_RD1, 0x0698, 0x02B0, 1, 0x081C, 1, 0) +MX6_PAD_DECL(RGMII_RD1__GPIO6_IO27, 0x0698, 0x02B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__HSI_TX_DATA, 0x069C, 0x02B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__RGMII_RD2, 0x069C, 0x02B4, 1, 0x0820, 1, 0) +MX6_PAD_DECL(RGMII_RD2__GPIO6_IO28, 0x069C, 0x02B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__HSI_TX_WAKE, 0x06A0, 0x02B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__RGMII_RD3, 0x06A0, 0x02B8, 1, 0x0824, 1, 0) +MX6_PAD_DECL(RGMII_RD3__GPIO6_IO29, 0x06A0, 0x02B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__USB_H3_DATA, 0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__RGMII_RX_CTL, 0x06A4, 0x02BC, 1, 0x0828, 1, 0) +MX6_PAD_DECL(RGMII_RX_CTL__GPIO6_IO24, 0x06A4, 0x02BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__USBOH3_H3_STROBE, 0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__USB_H3_STROBE, 0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP) +MX6_PAD_DECL(RGMII_RXC__RGMII_RXC, 0x06A8, 0x02C0, 1, 0x0814, 1, 0) +MX6_PAD_DECL(RGMII_RXC__GPIO6_IO30, 0x06A8, 0x02C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__HSI_TX_READY, 0x06AC, 0x02C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__RGMII_TD0, 0x06AC, 0x02C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__GPIO6_IO20, 0x06AC, 0x02C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__HSI_RX_FLAG, 0x06B0, 0x02C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__RGMII_TD1, 0x06B0, 0x02C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__GPIO6_IO21, 0x06B0, 0x02C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__HSI_RX_DATA, 0x06B4, 0x02CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__RGMII_TD2, 0x06B4, 0x02CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__GPIO6_IO22, 0x06B4, 0x02CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__HSI_RX_WAKE, 0x06B8, 0x02D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__RGMII_TD3, 0x06B8, 0x02D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__GPIO6_IO23, 0x06B8, 0x02D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__USBOH3_H2_STROBE, 0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__USB_H2_STROBE, 0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP) +MX6_PAD_DECL(RGMII_TX_CTL__RGMII_TX_CTL, 0x06BC, 0x02D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__GPIO6_IO26, 0x06BC, 0x02D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__ENET_REF_CLK, 0x06BC, 0x02D4, 7, 0x080C, 1, 0) +MX6_PAD_DECL(RGMII_TXC__USB_H2_DATA, 0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__RGMII_TXC, 0x06C0, 0x02D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__SPDIF_EXT_CLK, 0x06C0, 0x02D8, 2, 0x08F4, 1, 0) +MX6_PAD_DECL(RGMII_TXC__GPIO6_IO19, 0x06C0, 0x02D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__XTALOSC_REF_CLK_24M, 0x06C0, 0x02D8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__SD1_CLK, 0x06C4, 0x02DC, 0, 0x0928, 1, 0) +MX6_PAD_DECL(SD1_CLK__GPT_CLKIN, 0x06C4, 0x02DC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__GPIO1_IO20, 0x06C4, 0x02DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__SD1_CMD, 0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__PWM4_OUT, 0x06C8, 0x02E0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPT_COMPARE1, 0x06C8, 0x02E0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPIO1_IO18, 0x06C8, 0x02E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__SD1_DATA0, 0x06CC, 0x02E4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__GPT_CAPTURE1, 0x06CC, 0x02E4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__GPIO1_IO16, 0x06CC, 0x02E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__SD1_DATA1, 0x06D0, 0x02E8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__PWM3_OUT, 0x06D0, 0x02E8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPT_CAPTURE2, 0x06D0, 0x02E8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPIO1_IO17, 0x06D0, 0x02E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__SD1_DATA2, 0x06D4, 0x02EC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__GPT_COMPARE2, 0x06D4, 0x02EC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__PWM2_OUT, 0x06D4, 0x02EC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__WDOG1_B, 0x06D4, 0x02EC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__GPIO1_IO19, 0x06D4, 0x02EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__WDOG1_RESET_B_DEB, 0x06D4, 0x02EC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__SD1_DATA3, 0x06D8, 0x02F0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPT_COMPARE3, 0x06D8, 0x02F0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__PWM1_OUT, 0x06D8, 0x02F0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__WDOG2_B, 0x06D8, 0x02F0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPIO1_IO21, 0x06D8, 0x02F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__WDOG2_RESET_B_DEB, 0x06D8, 0x02F0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CLK__SD2_CLK, 0x06DC, 0x02F4, 0, 0x0930, 1, 0) +MX6_PAD_DECL(SD2_CLK__KEY_COL5, 0x06DC, 0x02F4, 2, 0x08C0, 3, 0) +MX6_PAD_DECL(SD2_CLK__AUD4_RXFS, 0x06DC, 0x02F4, 3, 0x07A4, 1, 0) +MX6_PAD_DECL(SD2_CLK__GPIO1_IO10, 0x06DC, 0x02F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__SD2_CMD, 0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__KEY_ROW5, 0x06E0, 0x02F8, 2, 0x08CC, 2, 0) +MX6_PAD_DECL(SD2_CMD__AUD4_RXC, 0x06E0, 0x02F8, 3, 0x07A0, 1, 0) +MX6_PAD_DECL(SD2_CMD__GPIO1_IO11, 0x06E0, 0x02F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__SD2_DATA0, 0x06E4, 0x02FC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__AUD4_RXD, 0x06E4, 0x02FC, 3, 0x0798, 1, 0) +MX6_PAD_DECL(SD2_DAT0__KEY_ROW7, 0x06E4, 0x02FC, 4, 0x08D4, 2, 0) +MX6_PAD_DECL(SD2_DAT0__GPIO1_IO15, 0x06E4, 0x02FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__DCIC2_OUT, 0x06E4, 0x02FC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__SD2_DATA1, 0x06E8, 0x0300, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__EIM_CS2_B, 0x06E8, 0x0300, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__AUD4_TXFS, 0x06E8, 0x0300, 3, 0x07AC, 1, 0) +MX6_PAD_DECL(SD2_DAT1__KEY_COL7, 0x06E8, 0x0300, 4, 0x08C8, 2, 0) +MX6_PAD_DECL(SD2_DAT1__GPIO1_IO14, 0x06E8, 0x0300, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__SD2_DATA2, 0x06EC, 0x0304, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__EIM_CS3_B, 0x06EC, 0x0304, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__AUD4_TXD, 0x06EC, 0x0304, 3, 0x079C, 1, 0) +MX6_PAD_DECL(SD2_DAT2__KEY_ROW6, 0x06EC, 0x0304, 4, 0x08D0, 2, 0) +MX6_PAD_DECL(SD2_DAT2__GPIO1_IO13, 0x06EC, 0x0304, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__SD2_DATA3, 0x06F0, 0x0308, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__KEY_COL6, 0x06F0, 0x0308, 2, 0x08C4, 2, 0) +MX6_PAD_DECL(SD2_DAT3__AUD4_TXC, 0x06F0, 0x0308, 3, 0x07A8, 1, 0) +MX6_PAD_DECL(SD2_DAT3__GPIO1_IO12, 0x06F0, 0x0308, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__SD3_CLK, 0x06F4, 0x030C, 0, 0x0934, 1, 0) +MX6_PAD_DECL(SD3_CLK__UART2_CTS_B, 0x06F4, 0x030C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__UART2_RTS_B, 0x06F4, 0x030C, 1, 0x0900, 2, 0) +MX6_PAD_DECL(SD3_CLK__FLEXCAN1_RX, 0x06F4, 0x030C, 2, 0x07C8, 2, 0) +MX6_PAD_DECL(SD3_CLK__GPIO7_IO03, 0x06F4, 0x030C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__SD3_CMD, 0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_CTS_B, 0x06F8, 0x0310, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_RTS_B, 0x06F8, 0x0310, 1, 0x0900, 3, 0) +MX6_PAD_DECL(SD3_CMD__FLEXCAN1_TX, 0x06F8, 0x0310, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__GPIO7_IO02, 0x06F8, 0x0310, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__SD3_DATA0, 0x06FC, 0x0314, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_CTS_B, 0x06FC, 0x0314, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_RTS_B, 0x06FC, 0x0314, 1, 0x08F8, 2, 0) +MX6_PAD_DECL(SD3_DAT0__FLEXCAN2_TX, 0x06FC, 0x0314, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__GPIO7_IO04, 0x06FC, 0x0314, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__SD3_DATA1, 0x0700, 0x0318, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_CTS_B, 0x0700, 0x0318, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_RTS_B, 0x0700, 0x0318, 1, 0x08F8, 3, 0) +MX6_PAD_DECL(SD3_DAT1__FLEXCAN2_RX, 0x0700, 0x0318, 2, 0x07CC, 1, 0) +MX6_PAD_DECL(SD3_DAT1__GPIO7_IO05, 0x0700, 0x0318, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__SD3_DATA2, 0x0704, 0x031C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__GPIO7_IO06, 0x0704, 0x031C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__SD3_DATA3, 0x0708, 0x0320, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_CTS_B, 0x0708, 0x0320, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_RTS_B, 0x0708, 0x0320, 1, 0x0908, 4, 0) +MX6_PAD_DECL(SD3_DAT3__GPIO7_IO07, 0x0708, 0x0320, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__SD3_DATA4, 0x070C, 0x0324, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_TX_DATA, 0x070C, 0x0324, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_RX_DATA, 0x070C, 0x0324, 1, 0x0904, 4, 0) +MX6_PAD_DECL(SD3_DAT4__GPIO7_IO01, 0x070C, 0x0324, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__SD3_DATA5, 0x0710, 0x0328, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_TX_DATA, 0x0710, 0x0328, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_RX_DATA, 0x0710, 0x0328, 1, 0x0904, 5, 0) +MX6_PAD_DECL(SD3_DAT5__GPIO7_IO00, 0x0710, 0x0328, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__SD3_DATA6, 0x0714, 0x032C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_TX_DATA, 0x0714, 0x032C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_RX_DATA, 0x0714, 0x032C, 1, 0x08FC, 2, 0) +MX6_PAD_DECL(SD3_DAT6__GPIO6_IO18, 0x0714, 0x032C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__SD3_DATA7, 0x0718, 0x0330, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_TX_DATA, 0x0718, 0x0330, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_RX_DATA, 0x0718, 0x0330, 1, 0x08FC, 3, 0) +MX6_PAD_DECL(SD3_DAT7__GPIO6_IO17, 0x0718, 0x0330, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__SD3_RESET, 0x071C, 0x0334, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_CTS_B, 0x071C, 0x0334, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_RTS_B, 0x071C, 0x0334, 1, 0x0908, 5, 0) +MX6_PAD_DECL(SD3_RST__GPIO7_IO08, 0x071C, 0x0334, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__SD4_CLK, 0x0720, 0x0338, 0, 0x0938, 1, 0) +MX6_PAD_DECL(SD4_CLK__NAND_WE_B, 0x0720, 0x0338, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_TX_DATA, 0x0720, 0x0338, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_RX_DATA, 0x0720, 0x0338, 2, 0x090C, 2, 0) +MX6_PAD_DECL(SD4_CLK__GPIO7_IO10, 0x0720, 0x0338, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__SD4_CMD, 0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__NAND_RE_B, 0x0724, 0x033C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_TX_DATA, 0x0724, 0x033C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_RX_DATA, 0x0724, 0x033C, 2, 0x090C, 3, 0) +MX6_PAD_DECL(SD4_CMD__GPIO7_IO09, 0x0724, 0x033C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__SD4_DATA0, 0x0728, 0x0340, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__NAND_DQS, 0x0728, 0x0340, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__GPIO2_IO08, 0x0728, 0x0340, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__SD4_DATA1, 0x072C, 0x0344, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__PWM3_OUT, 0x072C, 0x0344, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__GPIO2_IO09, 0x072C, 0x0344, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__SD4_DATA2, 0x0730, 0x0348, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__PWM4_OUT, 0x0730, 0x0348, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__GPIO2_IO10, 0x0730, 0x0348, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__SD4_DATA3, 0x0734, 0x034C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__GPIO2_IO11, 0x0734, 0x034C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__SD4_DATA4, 0x0738, 0x0350, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_TX_DATA, 0x0738, 0x0350, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_RX_DATA, 0x0738, 0x0350, 2, 0x0904, 6, 0) +MX6_PAD_DECL(SD4_DAT4__GPIO2_IO12, 0x0738, 0x0350, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__SD4_DATA5, 0x073C, 0x0354, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_CTS_B, 0x073C, 0x0354, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_RTS_B, 0x073C, 0x0354, 2, 0x0900, 4, 0) +MX6_PAD_DECL(SD4_DAT5__GPIO2_IO13, 0x073C, 0x0354, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__SD4_DATA6, 0x0740, 0x0358, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_CTS_B, 0x0740, 0x0358, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_RTS_B, 0x0740, 0x0358, 2, 0x0900, 5, 0) +MX6_PAD_DECL(SD4_DAT6__GPIO2_IO14, 0x0740, 0x0358, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__SD4_DATA7, 0x0744, 0x035C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_TX_DATA, 0x0744, 0x035C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_RX_DATA, 0x0744, 0x035C, 2, 0x0904, 7, 0) +MX6_PAD_DECL(SD4_DAT7__GPIO2_IO15, 0x0744, 0x035C, 5, 0x0000, 0, 0) #endif /* __ASM_ARCH_MX6_MX6DL_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index 5e38556..5e33753 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -9,1032 +9,1027 @@ #ifndef __ASM_ARCH_MX6_MX6Q_PINS_H__ #define __ASM_ARCH_MX6_MX6Q_PINS_H__
-#include <asm/imx-common/iomux-v3.h> - -enum { - MX6_PAD_SD2_DAT1__SD2_DATA1 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0360, 0x004C, 1, 0x0834, 0, 0), - MX6_PAD_SD2_DAT1__EIM_CS2_B = IOMUX_PAD(0x0360, 0x004C, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT1__AUD4_TXFS = IOMUX_PAD(0x0360, 0x004C, 3, 0x07C8, 0, 0), - MX6_PAD_SD2_DAT1__KEY_COL7 = IOMUX_PAD(0x0360, 0x004C, 4, 0x08F0, 0, 0), - MX6_PAD_SD2_DAT1__GPIO1_IO14 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__SD2_DATA2 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0364, 0x0050, 1, 0x0838, 0, 0), - MX6_PAD_SD2_DAT2__EIM_CS3_B = IOMUX_PAD(0x0364, 0x0050, 2, 0x0000, 0, 0), - MX6_PAD_SD2_DAT2__AUD4_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x07B8, 0, 0), - MX6_PAD_SD2_DAT2__KEY_ROW6 = IOMUX_PAD(0x0364, 0x0050, 4, 0x08F8, 0, 0), - MX6_PAD_SD2_DAT2__GPIO1_IO13 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__SD2_DATA0 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0368, 0x0054, 1, 0x082C, 0, 0), - MX6_PAD_SD2_DAT0__AUD4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x07B4, 0, 0), - MX6_PAD_SD2_DAT0__KEY_ROW7 = IOMUX_PAD(0x0368, 0x0054, 4, 0x08FC, 0, 0), - MX6_PAD_SD2_DAT0__GPIO1_IO15 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT0__DCIC2_OUT = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__USB_H2_DATA = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__RGMII_TXC = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__SPDIF_EXT_CLK = IOMUX_PAD(0x036C, 0x0058, 2, 0x0918, 0, 0), - MX6_PAD_RGMII_TXC__GPIO6_IO19 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TXC__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__HSI_TX_READY = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__RGMII_TD0 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD0__GPIO6_IO20 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__HSI_RX_FLAG = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__RGMII_TD1 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD1__GPIO6_IO21 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__HSI_RX_DATA = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__RGMII_TD2 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD2__GPIO6_IO22 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__HSI_RX_WAKE = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__RGMII_TD3 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TD3__GPIO6_IO23 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__USB_H3_DATA = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x0380, 0x006C, 1, 0x0858, 0, 0), - MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__HSI_RX_READY = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__RGMII_RD0 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0848, 0, 0), - MX6_PAD_RGMII_RD0__GPIO6_IO25 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__USB_H2_STROBE = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__GPIO6_IO26 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_TX_CTL__ENET_REF_CLK = IOMUX_PAD(0x0388, 0x0074, 7, 0x083C, 0, 0), - MX6_PAD_RGMII_RD1__HSI_TX_FLAG = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD1__RGMII_RD1 = IOMUX_PAD(0x038C, 0x0078, 1, 0x084C, 0, 0), - MX6_PAD_RGMII_RD1__GPIO6_IO27 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__HSI_TX_DATA = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD2__RGMII_RD2 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0850, 0, 0), - MX6_PAD_RGMII_RD2__GPIO6_IO28 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__HSI_TX_WAKE = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RD3__RGMII_RD3 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0854, 0, 0), - MX6_PAD_RGMII_RD3__GPIO6_IO29 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__USB_H3_STROBE = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), - MX6_PAD_RGMII_RXC__RGMII_RXC = IOMUX_PAD(0x0398, 0x0084, 1, 0x0844, 0, 0), - MX6_PAD_RGMII_RXC__GPIO6_IO30 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A25__EIM_ADDR25 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x039C, 0x0088, 2, 0x0000, 0, 0), - MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x039C, 0x0088, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x039C, 0x0088, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A25__GPIO5_IO02 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x039C, 0x0088, 6, 0x088C, 0, 0), - MX6_PAD_EIM_EB2__EIM_EB2_B = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0800, 0, 0), - MX6_PAD_EIM_EB2__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03A0, 0x008C, 3, 0x08D4, 0, 0), - MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0890, 0, 0), - MX6_PAD_EIM_EB2__GPIO2_IO30 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x03A0, 0x008C, 22, 0x08A0, 0, 0), - MX6_PAD_EIM_EB2__SRC_BOOT_CFG30 = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D16__EIM_DATA16 = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x03A4, 0x0090, 1, 0x07F4, 0, 0), - MX6_PAD_EIM_D16__IPU1_DI0_PIN05 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D16__IPU2_CSI1_DATA18 = IOMUX_PAD(0x03A4, 0x0090, 3, 0x08D0, 0, 0), - MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x03A4, 0x0090, 4, 0x0894, 0, 0), - MX6_PAD_EIM_D16__GPIO3_IO16 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x03A4, 0x0090, 22, 0x08A4, 0, 0), - MX6_PAD_EIM_D17__EIM_DATA17 = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x03A8, 0x0094, 1, 0x07F8, 0, 0), - MX6_PAD_EIM_D17__IPU1_DI0_PIN06 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D17__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 3, 0x08E0, 0, 0), - MX6_PAD_EIM_D17__DCIC1_OUT = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D17__GPIO3_IO17 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x03A8, 0x0094, 22, 0x08A8, 0, 0), - MX6_PAD_EIM_D18__EIM_DATA18 = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x03AC, 0x0098, 1, 0x07FC, 0, 0), - MX6_PAD_EIM_D18__IPU1_DI0_PIN07 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D18__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03AC, 0x0098, 3, 0x08CC, 0, 0), - MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D18__GPIO3_IO18 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x03AC, 0x0098, 22, 0x08AC, 0, 0), - MX6_PAD_EIM_D19__EIM_DATA19 = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0804, 0, 0), - MX6_PAD_EIM_D19__IPU1_DI0_PIN08 = IOMUX_PAD(0x03B0, 0x009C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D19__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x08C8, 0, 0), - MX6_PAD_EIM_D19__UART1_CTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D19__UART1_RTS_B = IOMUX_PAD(0x03B0, 0x009C, 4, 0x091C, 0, 0), - MX6_PAD_EIM_D19__GPIO3_IO19 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D19__EPIT1_OUT = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EIM_DATA20 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0824, 0, 0), - MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x08C4, 0, 0), - MX6_PAD_EIM_D20__UART1_CTS_B = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D20__UART1_RTS_B = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x091C, 1, 0), - MX6_PAD_EIM_D20__GPIO3_IO20 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D20__EPIT2_OUT = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D21__EIM_DATA21 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D21__IPU2_CSI1_DATA11 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x08B4, 0, 0), - MX6_PAD_EIM_D21__USB_OTG_OC = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0944, 0, 0), - MX6_PAD_EIM_D21__GPIO3_IO21 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x03B8, 0x00A4, 22, 0x0898, 0, 0), - MX6_PAD_EIM_D21__SPDIF_IN = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0914, 0, 0), - MX6_PAD_EIM_D22__EIM_DATA22 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU1_DI0_PIN01 = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D22__IPU2_CSI1_DATA10 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x08B0, 0, 0), - MX6_PAD_EIM_D22__USB_OTG_PWR = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D22__GPIO3_IO22 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D22__SPDIF_OUT = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D23__EIM_DATA23 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_CTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D23__UART3_RTS_B = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x092C, 0, 0), - MX6_PAD_EIM_D23__UART1_DCD_B = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x08D8, 0, 0), - MX6_PAD_EIM_D23__GPIO3_IO23 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN02 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__EIM_EB3_B = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__ECSPI4_RDY = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_CTS_B = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__UART3_RTS_B = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x092C, 1, 0), - MX6_PAD_EIM_EB3__UART1_RI_B = IOMUX_PAD(0x03C4, 0x00B0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__IPU2_CSI1_HSYNC = IOMUX_PAD(0x03C4, 0x00B0, 4, 0x08DC, 0, 0), - MX6_PAD_EIM_EB3__GPIO2_IO31 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__IPU1_DI1_PIN03 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_EB3__SRC_BOOT_CFG31 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D24__EIM_DATA24 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D24__ECSPI4_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_TX_DATA = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D24__UART3_RX_DATA = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0930, 0, 0), - MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 3, 0x0808, 0, 0), - MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x03C8, 0x00B4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D24__GPIO3_IO24 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D24__AUD5_RXFS = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x07D8, 0, 0), - MX6_PAD_EIM_D24__UART1_DTR_B = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D25__EIM_DATA25 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_TX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D25__UART3_RX_DATA = IOMUX_PAD(0x03CC, 0x00B8, 2, 0x0930, 1, 0), - MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x080C, 0, 0), - MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D25__GPIO3_IO25 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D25__AUD5_RXC = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x07D4, 0, 0), - MX6_PAD_EIM_D25__UART1_DSR_B = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D26__EIM_DATA26 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_CSI0_DATA01 = IOMUX_PAD(0x03D0, 0x00BC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x08C0, 0, 0), - MX6_PAD_EIM_D26__UART2_TX_DATA = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D26__UART2_RX_DATA = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0928, 0, 0), - MX6_PAD_EIM_D26__GPIO3_IO26 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_SISG2 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D26__IPU1_DISP1_DATA22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D27__EIM_DATA27 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_CSI0_DATA00 = IOMUX_PAD(0x03D4, 0x00C0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU2_CSI1_DATA13 = IOMUX_PAD(0x03D4, 0x00C0, 3, 0x08BC, 0, 0), - MX6_PAD_EIM_D27__UART2_TX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D27__UART2_RX_DATA = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0928, 1, 0), - MX6_PAD_EIM_D27__GPIO3_IO27 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_SISG3 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D27__IPU1_DISP1_DATA23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D28__EIM_DATA28 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x03D8, 0x00C4, 17, 0x089C, 0, 0), - MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x03D8, 0x00C4, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU2_CSI1_DATA12 = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x08B8, 0, 0), - MX6_PAD_EIM_D28__UART2_DTE_CTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0924, 0, 0), - MX6_PAD_EIM_D28__UART2_DTE_RTS_B = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D28__GPIO3_IO28 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), - MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D29__EIM_DATA29 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D29__ECSPI4_SS0 = IOMUX_PAD(0x03DC, 0x00C8, 2, 0x0824, 1, 0), - MX6_PAD_EIM_D29__UART2_CTS_B = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D29__UART2_RTS_B = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0924, 1, 0), - MX6_PAD_EIM_D29__GPIO3_IO29 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D29__IPU2_CSI1_VSYNC = IOMUX_PAD(0x03DC, 0x00C8, 6, 0x08E4, 0, 0), - MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_D30__EIM_DATA30 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DISP1_DATA21 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D30__IPU1_CSI0_DATA03 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_CTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D30__UART3_RTS_B = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x092C, 2, 0), - MX6_PAD_EIM_D30__GPIO3_IO30 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D30__USB_H1_OC = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0948, 0, 0), - MX6_PAD_EIM_D31__EIM_DATA31 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DISP1_DATA20 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x0000, 0, 0), - MX6_PAD_EIM_D31__IPU1_CSI0_DATA02 = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_CTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x0000, 0, 0), - MX6_PAD_EIM_D31__UART3_RTS_B = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x092C, 3, 0), - MX6_PAD_EIM_D31__GPIO3_IO31 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_D31__USB_H1_PWR = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), - MX6_PAD_EIM_A24__EIM_ADDR24 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_DISP1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU2_CSI1_DATA19 = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x08D4, 1, 0), - MX6_PAD_EIM_A24__IPU2_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A24__IPU1_SISG2 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A24__GPIO5_IO04 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A24__SRC_BOOT_CFG24 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A23__EIM_ADDR23 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_DISP1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU2_CSI1_DATA18 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x08D0, 1, 0), - MX6_PAD_EIM_A23__IPU2_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x0000, 0, 0), - MX6_PAD_EIM_A23__IPU1_SISG3 = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x0000, 0, 0), - MX6_PAD_EIM_A23__GPIO6_IO06 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A23__SRC_BOOT_CFG23 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A22__EIM_ADDR22 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU1_DISP1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A22__IPU2_CSI1_DATA17 = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x08CC, 1, 0), - MX6_PAD_EIM_A22__GPIO2_IO16 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A22__SRC_BOOT_CFG22 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A21__EIM_ADDR21 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU1_DISP1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A21__IPU2_CSI1_DATA16 = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x08C8, 1, 0), - MX6_PAD_EIM_A21__GPIO2_IO17 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A21__SRC_BOOT_CFG21 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A20__EIM_ADDR20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU1_DISP1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A20__IPU2_CSI1_DATA15 = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x08C4, 1, 0), - MX6_PAD_EIM_A20__GPIO2_IO18 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A20__SRC_BOOT_CFG20 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A19__EIM_ADDR19 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU1_DISP1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A19__IPU2_CSI1_DATA14 = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x08C0, 1, 0), - MX6_PAD_EIM_A19__GPIO2_IO19 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A19__SRC_BOOT_CFG19 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A18__EIM_ADDR18 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU1_DISP1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A18__IPU2_CSI1_DATA13 = IOMUX_PAD(0x0400, 0x00EC, 2, 0x08BC, 1, 0), - MX6_PAD_EIM_A18__GPIO2_IO20 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A18__SRC_BOOT_CFG18 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A17__EIM_ADDR17 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU1_DISP1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A17__IPU2_CSI1_DATA12 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x08B8, 1, 0), - MX6_PAD_EIM_A17__GPIO2_IO21 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A17__SRC_BOOT_CFG17 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), - MX6_PAD_EIM_A16__EIM_ADDR16 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, 0), - MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), - MX6_PAD_EIM_A16__IPU2_CSI1_PIXCLK = IOMUX_PAD(0x0408, 0x00F4, 2, 0x08E0, 1, 0), - MX6_PAD_EIM_A16__GPIO2_IO22 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), - MX6_PAD_EIM_A16__SRC_BOOT_CFG16 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__EIM_CS0_B = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__IPU1_DI1_PIN05 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), - MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0810, 0, 0), - MX6_PAD_EIM_CS0__GPIO2_IO23 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__EIM_CS1_B = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__IPU1_DI1_PIN06 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), - MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0818, 0, 0), - MX6_PAD_EIM_CS1__GPIO2_IO24 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), - MX6_PAD_EIM_OE__EIM_OE_B = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, 0), - MX6_PAD_EIM_OE__IPU1_DI1_PIN07 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), - MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x0414, 0x0100, 2, 0x0814, 0, 0), - MX6_PAD_EIM_OE__GPIO2_IO25 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), - MX6_PAD_EIM_RW__EIM_RW = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, 0), - MX6_PAD_EIM_RW__IPU1_DI1_PIN08 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), - MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x0418, 0x0104, 2, 0x081C, 0, 0), - MX6_PAD_EIM_RW__GPIO2_IO26 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), - MX6_PAD_EIM_RW__SRC_BOOT_CFG29 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__EIM_LBA_B = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x041C, 0x0108, 2, 0x0820, 0, 0), - MX6_PAD_EIM_LBA__GPIO2_IO27 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), - MX6_PAD_EIM_LBA__SRC_BOOT_CFG26 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__EIM_EB0_B = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU1_DISP1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__IPU2_CSI1_DATA11 = IOMUX_PAD(0x0420, 0x010C, 2, 0x08B4, 1, 0), - MX6_PAD_EIM_EB0__CCM_PMIC_READY = IOMUX_PAD(0x0420, 0x010C, 4, 0x07F0, 0, 0), - MX6_PAD_EIM_EB0__GPIO2_IO28 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB0__SRC_BOOT_CFG27 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__EIM_EB1_B = IOMUX_PAD(0x0424, 0x0110, 0, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU1_DISP1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 1, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__IPU2_CSI1_DATA10 = IOMUX_PAD(0x0424, 0x0110, 2, 0x08B0, 1, 0), - MX6_PAD_EIM_EB1__GPIO2_IO29 = IOMUX_PAD(0x0424, 0x0110, 5, 0x0000, 0, 0), - MX6_PAD_EIM_EB1__SRC_BOOT_CFG28 = IOMUX_PAD(0x0424, 0x0110, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__EIM_AD00 = IOMUX_PAD(0x0428, 0x0114, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU1_DISP1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__IPU2_CSI1_DATA09 = IOMUX_PAD(0x0428, 0x0114, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__GPIO3_IO00 = IOMUX_PAD(0x0428, 0x0114, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA0__SRC_BOOT_CFG00 = IOMUX_PAD(0x0428, 0x0114, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__EIM_AD01 = IOMUX_PAD(0x042C, 0x0118, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU1_DISP1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__IPU2_CSI1_DATA08 = IOMUX_PAD(0x042C, 0x0118, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__GPIO3_IO01 = IOMUX_PAD(0x042C, 0x0118, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA1__SRC_BOOT_CFG01 = IOMUX_PAD(0x042C, 0x0118, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__EIM_AD02 = IOMUX_PAD(0x0430, 0x011C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU1_DISP1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__IPU2_CSI1_DATA07 = IOMUX_PAD(0x0430, 0x011C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__GPIO3_IO02 = IOMUX_PAD(0x0430, 0x011C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA2__SRC_BOOT_CFG02 = IOMUX_PAD(0x0430, 0x011C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__EIM_AD03 = IOMUX_PAD(0x0434, 0x0120, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU1_DISP1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__IPU2_CSI1_DATA06 = IOMUX_PAD(0x0434, 0x0120, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__GPIO3_IO03 = IOMUX_PAD(0x0434, 0x0120, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA3__SRC_BOOT_CFG03 = IOMUX_PAD(0x0434, 0x0120, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__EIM_AD04 = IOMUX_PAD(0x0438, 0x0124, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU1_DISP1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__IPU2_CSI1_DATA05 = IOMUX_PAD(0x0438, 0x0124, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__GPIO3_IO04 = IOMUX_PAD(0x0438, 0x0124, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA4__SRC_BOOT_CFG04 = IOMUX_PAD(0x0438, 0x0124, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__EIM_AD05 = IOMUX_PAD(0x043C, 0x0128, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU1_DISP1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__IPU2_CSI1_DATA04 = IOMUX_PAD(0x043C, 0x0128, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__GPIO3_IO05 = IOMUX_PAD(0x043C, 0x0128, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA5__SRC_BOOT_CFG05 = IOMUX_PAD(0x043C, 0x0128, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__EIM_AD06 = IOMUX_PAD(0x0440, 0x012C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU1_DISP1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__IPU2_CSI1_DATA03 = IOMUX_PAD(0x0440, 0x012C, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__GPIO3_IO06 = IOMUX_PAD(0x0440, 0x012C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA6__SRC_BOOT_CFG06 = IOMUX_PAD(0x0440, 0x012C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__EIM_AD07 = IOMUX_PAD(0x0444, 0x0130, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU1_DISP1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__IPU2_CSI1_DATA02 = IOMUX_PAD(0x0444, 0x0130, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__GPIO3_IO07 = IOMUX_PAD(0x0444, 0x0130, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA7__SRC_BOOT_CFG07 = IOMUX_PAD(0x0444, 0x0130, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__EIM_AD08 = IOMUX_PAD(0x0448, 0x0134, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU1_DISP1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__IPU2_CSI1_DATA01 = IOMUX_PAD(0x0448, 0x0134, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__GPIO3_IO08 = IOMUX_PAD(0x0448, 0x0134, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA8__SRC_BOOT_CFG08 = IOMUX_PAD(0x0448, 0x0134, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__EIM_AD09 = IOMUX_PAD(0x044C, 0x0138, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU1_DISP1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__IPU2_CSI1_DATA00 = IOMUX_PAD(0x044C, 0x0138, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__GPIO3_IO09 = IOMUX_PAD(0x044C, 0x0138, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA9__SRC_BOOT_CFG09 = IOMUX_PAD(0x044C, 0x0138, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__EIM_AD10 = IOMUX_PAD(0x0450, 0x013C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x0450, 0x013C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__IPU2_CSI1_DATA_EN = IOMUX_PAD(0x0450, 0x013C, 2, 0x08D8, 1, 0), - MX6_PAD_EIM_DA10__GPIO3_IO10 = IOMUX_PAD(0x0450, 0x013C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA10__SRC_BOOT_CFG10 = IOMUX_PAD(0x0450, 0x013C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__EIM_AD11 = IOMUX_PAD(0x0454, 0x0140, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU1_DI1_PIN02 = IOMUX_PAD(0x0454, 0x0140, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__IPU2_CSI1_HSYNC = IOMUX_PAD(0x0454, 0x0140, 2, 0x08DC, 1, 0), - MX6_PAD_EIM_DA11__GPIO3_IO11 = IOMUX_PAD(0x0454, 0x0140, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA11__SRC_BOOT_CFG11 = IOMUX_PAD(0x0454, 0x0140, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__EIM_AD12 = IOMUX_PAD(0x0458, 0x0144, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU1_DI1_PIN03 = IOMUX_PAD(0x0458, 0x0144, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__IPU2_CSI1_VSYNC = IOMUX_PAD(0x0458, 0x0144, 2, 0x08E4, 1, 0), - MX6_PAD_EIM_DA12__GPIO3_IO12 = IOMUX_PAD(0x0458, 0x0144, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA12__SRC_BOOT_CFG12 = IOMUX_PAD(0x0458, 0x0144, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__EIM_AD13 = IOMUX_PAD(0x045C, 0x0148, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x045C, 0x0148, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__GPIO3_IO13 = IOMUX_PAD(0x045C, 0x0148, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA13__SRC_BOOT_CFG13 = IOMUX_PAD(0x045C, 0x0148, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__EIM_AD14 = IOMUX_PAD(0x0460, 0x014C, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x0460, 0x014C, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__GPIO3_IO14 = IOMUX_PAD(0x0460, 0x014C, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA14__SRC_BOOT_CFG14 = IOMUX_PAD(0x0460, 0x014C, 7, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__EIM_AD15 = IOMUX_PAD(0x0464, 0x0150, 0, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN01 = IOMUX_PAD(0x0464, 0x0150, 1, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__IPU1_DI1_PIN04 = IOMUX_PAD(0x0464, 0x0150, 2, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__GPIO3_IO15 = IOMUX_PAD(0x0464, 0x0150, 5, 0x0000, 0, 0), - MX6_PAD_EIM_DA15__SRC_BOOT_CFG15 = IOMUX_PAD(0x0464, 0x0150, 7, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_WAIT_B = IOMUX_PAD(0x0468, 0x0154, 0, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__EIM_DTACK_B = IOMUX_PAD(0x0468, 0x0154, 1, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__GPIO5_IO00 = IOMUX_PAD(0x0468, 0x0154, 5, 0x0000, 0, 0), - MX6_PAD_EIM_WAIT__SRC_BOOT_CFG25 = IOMUX_PAD(0x0468, 0x0154, 7, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__EIM_BCLK = IOMUX_PAD(0x046C, 0x0158, 0, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x046C, 0x0158, 1, 0x0000, 0, 0), - MX6_PAD_EIM_BCLK__GPIO6_IO31 = IOMUX_PAD(0x046C, 0x0158, 5, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK = IOMUX_PAD(0x0470, 0x015C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_DISP_CLK__GPIO4_IO16 = IOMUX_PAD(0x0470, 0x015C, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN15__IPU2_DI0_PIN15 = IOMUX_PAD(0x0474, 0x0160, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__AUD6_TXC = IOMUX_PAD(0x0474, 0x0160, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN15__GPIO4_IO17 = IOMUX_PAD(0x0474, 0x0160, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN2__IPU2_DI0_PIN02 = IOMUX_PAD(0x0478, 0x0164, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__AUD6_TXD = IOMUX_PAD(0x0478, 0x0164, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN2__GPIO4_IO18 = IOMUX_PAD(0x0478, 0x0164, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN3__IPU2_DI0_PIN03 = IOMUX_PAD(0x047C, 0x0168, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__AUD6_TXFS = IOMUX_PAD(0x047C, 0x0168, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN3__GPIO4_IO19 = IOMUX_PAD(0x047C, 0x0168, 5, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 0, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__IPU2_DI0_PIN04 = IOMUX_PAD(0x0480, 0x016C, 1, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__AUD6_RXD = IOMUX_PAD(0x0480, 0x016C, 2, 0x0000, 0, 0), - MX6_PAD_DI0_PIN4__SD1_WP = IOMUX_PAD(0x0480, 0x016C, 3, 0x094C, 0, 0), - MX6_PAD_DI0_PIN4__GPIO4_IO20 = IOMUX_PAD(0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 = IOMUX_PAD(0x0484, 0x0170, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x0484, 0x0170, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT0__GPIO4_IO21 = IOMUX_PAD(0x0484, 0x0170, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 = IOMUX_PAD(0x0488, 0x0174, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x0488, 0x0174, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT1__GPIO4_IO22 = IOMUX_PAD(0x0488, 0x0174, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 = IOMUX_PAD(0x048C, 0x0178, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x048C, 0x0178, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT2__GPIO4_IO23 = IOMUX_PAD(0x048C, 0x0178, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 = IOMUX_PAD(0x0490, 0x017C, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0490, 0x017C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT3__GPIO4_IO24 = IOMUX_PAD(0x0490, 0x017C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04 = IOMUX_PAD(0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 = IOMUX_PAD(0x0494, 0x0180, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x0494, 0x0180, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT4__GPIO4_IO25 = IOMUX_PAD(0x0494, 0x0180, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 = IOMUX_PAD(0x0498, 0x0184, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0498, 0x0184, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__AUD6_RXFS = IOMUX_PAD(0x0498, 0x0184, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT5__GPIO4_IO26 = IOMUX_PAD(0x0498, 0x0184, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 = IOMUX_PAD(0x049C, 0x0188, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x049C, 0x0188, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__AUD6_RXC = IOMUX_PAD(0x049C, 0x0188, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT6__GPIO4_IO27 = IOMUX_PAD(0x049C, 0x0188, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 = IOMUX_PAD(0x04A0, 0x018C, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x04A0, 0x018C, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT7__GPIO4_IO28 = IOMUX_PAD(0x04A0, 0x018C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 = IOMUX_PAD(0x04A4, 0x0190, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__PWM1_OUT = IOMUX_PAD(0x04A4, 0x0190, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__WDOG1_B = IOMUX_PAD(0x04A4, 0x0190, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT8__GPIO4_IO29 = IOMUX_PAD(0x04A4, 0x0190, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 = IOMUX_PAD(0x04A8, 0x0194, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__PWM2_OUT = IOMUX_PAD(0x04A8, 0x0194, 2, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__WDOG2_B = IOMUX_PAD(0x04A8, 0x0194, 3, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT9__GPIO4_IO30 = IOMUX_PAD(0x04A8, 0x0194, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 = IOMUX_PAD(0x04AC, 0x0198, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT10__GPIO4_IO31 = IOMUX_PAD(0x04AC, 0x0198, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 = IOMUX_PAD(0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 = IOMUX_PAD(0x04B0, 0x019C, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT11__GPIO5_IO05 = IOMUX_PAD(0x04B0, 0x019C, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 = IOMUX_PAD(0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 = IOMUX_PAD(0x04B4, 0x01A0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT12__GPIO5_IO06 = IOMUX_PAD(0x04B4, 0x01A0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 = IOMUX_PAD(0x04B8, 0x01A4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT13__AUD5_RXFS = IOMUX_PAD(0x04B8, 0x01A4, 3, 0x07D8, 1, 0), - MX6_PAD_DISP0_DAT13__GPIO5_IO07 = IOMUX_PAD(0x04B8, 0x01A4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 = IOMUX_PAD(0x04BC, 0x01A8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT14__AUD5_RXC = IOMUX_PAD(0x04BC, 0x01A8, 3, 0x07D4, 1, 0), - MX6_PAD_DISP0_DAT14__GPIO5_IO08 = IOMUX_PAD(0x04BC, 0x01A8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 = IOMUX_PAD(0x04C0, 0x01AC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 2, 0x0804, 1, 0), - MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x04C0, 0x01AC, 3, 0x0820, 1, 0), - MX6_PAD_DISP0_DAT15__GPIO5_IO09 = IOMUX_PAD(0x04C0, 0x01AC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT16__IPU2_DISP0_DATA16 = IOMUX_PAD(0x04C4, 0x01B0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x04C4, 0x01B0, 2, 0x0818, 1, 0), - MX6_PAD_DISP0_DAT16__AUD5_TXC = IOMUX_PAD(0x04C4, 0x01B0, 3, 0x07DC, 0, 0), - MX6_PAD_DISP0_DAT16__SDMA_EXT_EVENT0 = IOMUX_PAD(0x04C4, 0x01B0, 4, 0x090C, 0, 0), - MX6_PAD_DISP0_DAT16__GPIO5_IO10 = IOMUX_PAD(0x04C4, 0x01B0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT17__IPU2_DISP0_DATA17 = IOMUX_PAD(0x04C8, 0x01B4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x04C8, 0x01B4, 2, 0x0814, 1, 0), - MX6_PAD_DISP0_DAT17__AUD5_TXD = IOMUX_PAD(0x04C8, 0x01B4, 3, 0x07D0, 0, 0), - MX6_PAD_DISP0_DAT17__SDMA_EXT_EVENT1 = IOMUX_PAD(0x04C8, 0x01B4, 4, 0x0910, 0, 0), - MX6_PAD_DISP0_DAT17__GPIO5_IO11 = IOMUX_PAD(0x04C8, 0x01B4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT18__IPU2_DISP0_DATA18 = IOMUX_PAD(0x04CC, 0x01B8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x04CC, 0x01B8, 2, 0x081C, 1, 0), - MX6_PAD_DISP0_DAT18__AUD5_TXFS = IOMUX_PAD(0x04CC, 0x01B8, 3, 0x07E0, 0, 0), - MX6_PAD_DISP0_DAT18__AUD4_RXFS = IOMUX_PAD(0x04CC, 0x01B8, 4, 0x07C0, 0, 0), - MX6_PAD_DISP0_DAT18__GPIO5_IO12 = IOMUX_PAD(0x04CC, 0x01B8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT18__EIM_CS2_B = IOMUX_PAD(0x04CC, 0x01B8, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT19__IPU2_DISP0_DATA19 = IOMUX_PAD(0x04D0, 0x01BC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x04D0, 0x01BC, 2, 0x0810, 1, 0), - MX6_PAD_DISP0_DAT19__AUD5_RXD = IOMUX_PAD(0x04D0, 0x01BC, 3, 0x07CC, 0, 0), - MX6_PAD_DISP0_DAT19__AUD4_RXC = IOMUX_PAD(0x04D0, 0x01BC, 4, 0x07BC, 0, 0), - MX6_PAD_DISP0_DAT19__GPIO5_IO13 = IOMUX_PAD(0x04D0, 0x01BC, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT19__EIM_CS3_B = IOMUX_PAD(0x04D0, 0x01BC, 7, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT20__IPU2_DISP0_DATA20 = IOMUX_PAD(0x04D4, 0x01C0, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x04D4, 0x01C0, 2, 0x07F4, 1, 0), - MX6_PAD_DISP0_DAT20__AUD4_TXC = IOMUX_PAD(0x04D4, 0x01C0, 3, 0x07C4, 0, 0), - MX6_PAD_DISP0_DAT20__GPIO5_IO14 = IOMUX_PAD(0x04D4, 0x01C0, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT21__IPU2_DISP0_DATA21 = IOMUX_PAD(0x04D8, 0x01C4, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x04D8, 0x01C4, 2, 0x07FC, 1, 0), - MX6_PAD_DISP0_DAT21__AUD4_TXD = IOMUX_PAD(0x04D8, 0x01C4, 3, 0x07B8, 1, 0), - MX6_PAD_DISP0_DAT21__GPIO5_IO15 = IOMUX_PAD(0x04D8, 0x01C4, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT22__IPU2_DISP0_DATA22 = IOMUX_PAD(0x04DC, 0x01C8, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x04DC, 0x01C8, 2, 0x07F8, 1, 0), - MX6_PAD_DISP0_DAT22__AUD4_TXFS = IOMUX_PAD(0x04DC, 0x01C8, 3, 0x07C8, 1, 0), - MX6_PAD_DISP0_DAT22__GPIO5_IO16 = IOMUX_PAD(0x04DC, 0x01C8, 5, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT23__IPU2_DISP0_DATA23 = IOMUX_PAD(0x04E0, 0x01CC, 1, 0x0000, 0, 0), - MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x04E0, 0x01CC, 2, 0x0800, 1, 0), - MX6_PAD_DISP0_DAT23__AUD4_RXD = IOMUX_PAD(0x04E0, 0x01CC, 3, 0x07B4, 1, 0), - MX6_PAD_DISP0_DAT23__GPIO5_IO17 = IOMUX_PAD(0x04E0, 0x01CC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x04E4, 0x01D0, 1, 0x0840, 0, 0), - MX6_PAD_ENET_MDIO__ESAI_RX_CLK = IOMUX_PAD(0x04E4, 0x01D0, 2, 0x086C, 0, 0), - MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x04E4, 0x01D0, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__GPIO1_IO22 = IOMUX_PAD(0x04E4, 0x01D0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDIO__SPDIF_LOCK = IOMUX_PAD(0x04E4, 0x01D0, 6, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x04E8, 0x01D4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__ESAI_RX_FS = IOMUX_PAD(0x04E8, 0x01D4, 2, 0x085C, 0, 0), - MX6_PAD_ENET_REF_CLK__GPIO1_IO23 = IOMUX_PAD(0x04E8, 0x01D4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_REF_CLK__SPDIF_SR_CLK = IOMUX_PAD(0x04E8, 0x01D4, 6, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__USB_OTG_ID = IOMUX_PAD(0x04EC, 0x01D8, 0, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x04EC, 0x01D8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__ESAI_RX_HF_CLK = IOMUX_PAD(0x04EC, 0x01D8, 2, 0x0864, 0, 0), - MX6_PAD_ENET_RX_ER__SPDIF_IN = IOMUX_PAD(0x04EC, 0x01D8, 3, 0x0914, 1, 0), - MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x04EC, 0x01D8, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RX_ER__GPIO1_IO24 = IOMUX_PAD(0x04EC, 0x01D8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x04F0, 0x01DC, 1, 0x0858, 1, 0), - MX6_PAD_ENET_CRS_DV__ESAI_TX_CLK = IOMUX_PAD(0x04F0, 0x01DC, 2, 0x0870, 0, 0), - MX6_PAD_ENET_CRS_DV__SPDIF_EXT_CLK = IOMUX_PAD(0x04F0, 0x01DC, 3, 0x0918, 1, 0), - MX6_PAD_ENET_CRS_DV__GPIO1_IO25 = IOMUX_PAD(0x04F0, 0x01DC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__MLB_SIG = IOMUX_PAD(0x04F4, 0x01E0, 0, 0x0908, 0, 0), - MX6_PAD_ENET_RXD1__ENET_RX_DATA1 = IOMUX_PAD(0x04F4, 0x01E0, 1, 0x084C, 1, 0), - MX6_PAD_ENET_RXD1__ESAI_TX_FS = IOMUX_PAD(0x04F4, 0x01E0, 2, 0x0860, 0, 0), - MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x04F4, 0x01E0, 4, 0x0000, 0, 0), - MX6_PAD_ENET_RXD1__GPIO1_IO26 = IOMUX_PAD(0x04F4, 0x01E0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__ENET_RX_DATA0 = IOMUX_PAD(0x04F8, 0x01E4, 1, 0x0848, 1, 0), - MX6_PAD_ENET_RXD0__ESAI_TX_HF_CLK = IOMUX_PAD(0x04F8, 0x01E4, 2, 0x0868, 0, 0), - MX6_PAD_ENET_RXD0__SPDIF_OUT = IOMUX_PAD(0x04F8, 0x01E4, 3, 0x0000, 0, 0), - MX6_PAD_ENET_RXD0__GPIO1_IO27 = IOMUX_PAD(0x04F8, 0x01E4, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x04FC, 0x01E8, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TX_EN__ESAI_TX3_RX2 = IOMUX_PAD(0x04FC, 0x01E8, 2, 0x0880, 0, 0), - MX6_PAD_ENET_TX_EN__GPIO1_IO28 = IOMUX_PAD(0x04FC, 0x01E8, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__MLB_CLK = IOMUX_PAD(0x0500, 0x01EC, 0, 0x0900, 0, 0), - MX6_PAD_ENET_TXD1__ENET_TX_DATA1 = IOMUX_PAD(0x0500, 0x01EC, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__ESAI_TX2_RX3 = IOMUX_PAD(0x0500, 0x01EC, 2, 0x087C, 0, 0), - MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x0500, 0x01EC, 4, 0x0000, 0, 0), - MX6_PAD_ENET_TXD1__GPIO1_IO29 = IOMUX_PAD(0x0500, 0x01EC, 5, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ENET_TX_DATA0 = IOMUX_PAD(0x0504, 0x01F0, 1, 0x0000, 0, 0), - MX6_PAD_ENET_TXD0__ESAI_TX4_RX1 = IOMUX_PAD(0x0504, 0x01F0, 2, 0x0884, 0, 0), - MX6_PAD_ENET_TXD0__GPIO1_IO30 = IOMUX_PAD(0x0504, 0x01F0, 5, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__MLB_DATA = IOMUX_PAD(0x0508, 0x01F4, 0, 0x0904, 0, 0), - MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x0508, 0x01F4, 1, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__ESAI_TX5_RX0 = IOMUX_PAD(0x0508, 0x01F4, 2, 0x0888, 0, 0), - MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x0508, 0x01F4, 4, 0x0000, 0, 0), - MX6_PAD_ENET_MDC__GPIO1_IO31 = IOMUX_PAD(0x0508, 0x01F4, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x07F4, 2, 0), - MX6_PAD_KEY_COL0__ENET_RX_DATA3 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0854, 1, 0), - MX6_PAD_KEY_COL0__AUD5_TXC = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x07DC, 1, 0), - MX6_PAD_KEY_COL0__KEY_COL0 = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_TX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__UART4_RX_DATA = IOMUX_PAD(0x05C8, 0x01F8, 4, 0x0938, 0, 0), - MX6_PAD_KEY_COL0__GPIO4_IO06 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL0__DCIC1_OUT = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x07FC, 2, 0), - MX6_PAD_KEY_ROW0__ENET_TX_DATA3 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__AUD5_TXD = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x07D0, 1, 0), - MX6_PAD_KEY_ROW0__KEY_ROW0 = IOMUX_PAD(0x05CC, 0x01FC, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_TX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__UART4_RX_DATA = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0938, 1, 0), - MX6_PAD_KEY_ROW0__GPIO4_IO07 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW0__DCIC2_OUT = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x05D0, 0x0200, 0, 0x07F8, 2, 0), - MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0840, 1, 0), - MX6_PAD_KEY_COL1__AUD5_TXFS = IOMUX_PAD(0x05D0, 0x0200, 2, 0x07E0, 1, 0), - MX6_PAD_KEY_COL1__KEY_COL1 = IOMUX_PAD(0x05D0, 0x0200, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_TX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__UART5_RX_DATA = IOMUX_PAD(0x05D0, 0x0200, 4, 0x0940, 0, 0), - MX6_PAD_KEY_COL1__GPIO4_IO08 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL1__SD1_VSELECT = IOMUX_PAD(0x05D0, 0x0200, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x05D4, 0x0204, 0, 0x0800, 2, 0), - MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__AUD5_RXD = IOMUX_PAD(0x05D4, 0x0204, 2, 0x07CC, 1, 0), - MX6_PAD_KEY_ROW1__KEY_ROW1 = IOMUX_PAD(0x05D4, 0x0204, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_TX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__UART5_RX_DATA = IOMUX_PAD(0x05D4, 0x0204, 4, 0x0940, 1, 0), - MX6_PAD_KEY_ROW1__GPIO4_IO09 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW1__SD2_VSELECT = IOMUX_PAD(0x05D4, 0x0204, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x05D8, 0x0208, 0, 0x0804, 2, 0), - MX6_PAD_KEY_COL2__ENET_RX_DATA2 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0850, 1, 0), - MX6_PAD_KEY_COL2__FLEXCAN1_TX = IOMUX_PAD(0x05D8, 0x0208, 2, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__KEY_COL2 = IOMUX_PAD(0x05D8, 0x0208, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__GPIO4_IO10 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL2__USB_H1_PWR_CTL_WAKE = IOMUX_PAD(0x05D8, 0x0208, 6, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0808, 1, 0), - MX6_PAD_KEY_ROW2__ENET_TX_DATA2 = IOMUX_PAD(0x05DC, 0x020C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__FLEXCAN1_RX = IOMUX_PAD(0x05DC, 0x020C, 2, 0x07E4, 0, 0), - MX6_PAD_KEY_ROW2__KEY_ROW2 = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__SD2_VSELECT = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__GPIO4_IO11 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x05DC, 0x020C, 6, 0x088C, 1, 0), - MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x05E0, 0x0210, 0, 0x080C, 1, 0), - MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x05E0, 0x0210, 2, 0x0890, 1, 0), - MX6_PAD_KEY_COL3__KEY_COL3 = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x05E0, 0x0210, 20, 0x08A0, 1, 0), - MX6_PAD_KEY_COL3__GPIO4_IO12 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), - MX6_PAD_KEY_COL3__SPDIF_IN = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0914, 2, 0), - MX6_PAD_KEY_ROW3__ASRC_EXT_CLK = IOMUX_PAD(0x05E4, 0x0214, 1, 0x07B0, 0, 0), - MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x05E4, 0x0214, 2, 0x0894, 1, 0), - MX6_PAD_KEY_ROW3__KEY_ROW3 = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x05E4, 0x0214, 20, 0x08A4, 1, 0), - MX6_PAD_KEY_ROW3__GPIO4_IO13 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW3__SD1_VSELECT = IOMUX_PAD(0x05E4, 0x0214, 6, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__FLEXCAN2_TX = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__IPU1_SISG4 = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__USB_OTG_OC = IOMUX_PAD(0x05E8, 0x0218, 2, 0x0944, 1, 0), - MX6_PAD_KEY_COL4__KEY_COL4 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_CTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), - MX6_PAD_KEY_COL4__UART5_RTS_B = IOMUX_PAD(0x05E8, 0x0218, 4, 0x093C, 0, 0), - MX6_PAD_KEY_COL4__GPIO4_IO14 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__FLEXCAN2_RX = IOMUX_PAD(0x05EC, 0x021C, 0, 0x07E8, 0, 0), - MX6_PAD_KEY_ROW4__IPU1_SISG5 = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__USB_OTG_PWR = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__KEY_ROW4 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_CTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0000, 0, 0), - MX6_PAD_KEY_ROW4__UART5_RTS_B = IOMUX_PAD(0x05EC, 0x021C, 4, 0x093C, 1, 0), - MX6_PAD_KEY_ROW4__GPIO4_IO15 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__CCM_CLKO1 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x0000, 0, 0), - MX6_PAD_GPIO_0__KEY_COL5 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x08E8, 0, 0), - MX6_PAD_GPIO_0__ASRC_EXT_CLK = IOMUX_PAD(0x05F0, 0x0220, 3, 0x07B0, 1, 0), - MX6_PAD_GPIO_0__EPIT1_OUT = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_0__GPIO1_IO00 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_0__USB_H1_PWR = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_0__SNVS_VIO_5 = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_1__ESAI_RX_CLK = IOMUX_PAD(0x05F4, 0x0224, 0, 0x086C, 1, 0), - MX6_PAD_GPIO_1__WDOG2_B = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_1__KEY_ROW5 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08F4, 0, 0), - MX6_PAD_GPIO_1__USB_OTG_ID = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_1__PWM2_OUT = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_1__GPIO1_IO01 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_1__SD1_CD_B = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_9__ESAI_RX_FS = IOMUX_PAD(0x05F8, 0x0228, 0, 0x085C, 1, 0), - MX6_PAD_GPIO_9__WDOG1_B = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_9__KEY_COL6 = IOMUX_PAD(0x05F8, 0x0228, 2, 0x08EC, 0, 0), - MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_9__PWM1_OUT = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_9__GPIO1_IO09 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_9__SD1_WP = IOMUX_PAD(0x05F8, 0x0228, 6, 0x094C, 1, 0), - MX6_PAD_GPIO_3__ESAI_RX_HF_CLK = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0864, 1, 0), - MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05FC, 0x022C, 18, 0x08A8, 1, 0), - MX6_PAD_GPIO_3__XTALOSC_REF_CLK_24M = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_3__GPIO1_IO03 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_3__USB_H1_OC = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0948, 1, 0), - MX6_PAD_GPIO_3__MLB_CLK = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0900, 1, 0), - MX6_PAD_GPIO_6__ESAI_TX_CLK = IOMUX_PAD(0x0600, 0x0230, 0, 0x0870, 1, 0), - MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0600, 0x0230, 18, 0x08AC, 1, 0), - MX6_PAD_GPIO_6__GPIO1_IO06 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_6__SD2_LCTL = IOMUX_PAD(0x0600, 0x0230, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_6__MLB_SIG = IOMUX_PAD(0x0600, 0x0230, 7, 0x0908, 1, 0), - MX6_PAD_GPIO_2__ESAI_TX_FS = IOMUX_PAD(0x0604, 0x0234, 0, 0x0860, 1, 0), - MX6_PAD_GPIO_2__KEY_ROW6 = IOMUX_PAD(0x0604, 0x0234, 2, 0x08F8, 1, 0), - MX6_PAD_GPIO_2__GPIO1_IO02 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_2__SD2_WP = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_2__MLB_DATA = IOMUX_PAD(0x0604, 0x0234, 7, 0x0904, 1, 0), - MX6_PAD_GPIO_4__ESAI_TX_HF_CLK = IOMUX_PAD(0x0608, 0x0238, 0, 0x0868, 1, 0), - MX6_PAD_GPIO_4__KEY_COL7 = IOMUX_PAD(0x0608, 0x0238, 2, 0x08F0, 1, 0), - MX6_PAD_GPIO_4__GPIO1_IO04 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_4__SD2_CD_B = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_5__ESAI_TX2_RX3 = IOMUX_PAD(0x060C, 0x023C, 0, 0x087C, 1, 0), - MX6_PAD_GPIO_5__KEY_ROW7 = IOMUX_PAD(0x060C, 0x023C, 2, 0x08FC, 1, 0), - MX6_PAD_GPIO_5__CCM_CLKO1 = IOMUX_PAD(0x060C, 0x023C, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_5__GPIO1_IO05 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x060C, 0x023C, 22, 0x08A8, 2, 0), - MX6_PAD_GPIO_5__ARM_EVENTI = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_7__ESAI_TX4_RX1 = IOMUX_PAD(0x0610, 0x0240, 0, 0x0884, 1, 0), - MX6_PAD_GPIO_7__ECSPI5_RDY = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_7__EPIT1_OUT = IOMUX_PAD(0x0610, 0x0240, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_7__FLEXCAN1_TX = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_TX_DATA = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_7__UART2_RX_DATA = IOMUX_PAD(0x0610, 0x0240, 4, 0x0928, 2, 0), - MX6_PAD_GPIO_7__GPIO1_IO07 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_7__SPDIF_LOCK = IOMUX_PAD(0x0610, 0x0240, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_7__USB_OTG_HOST_MODE = IOMUX_PAD(0x0610, 0x0240, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_8__ESAI_TX5_RX0 = IOMUX_PAD(0x0614, 0x0244, 0, 0x0888, 1, 0), - MX6_PAD_GPIO_8__XTALOSC_REF_CLK_32K = IOMUX_PAD(0x0614, 0x0244, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_8__EPIT2_OUT = IOMUX_PAD(0x0614, 0x0244, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_8__FLEXCAN1_RX = IOMUX_PAD(0x0614, 0x0244, 3, 0x07E4, 1, 0), - MX6_PAD_GPIO_8__UART2_TX_DATA = IOMUX_PAD(0x0614, 0x0244, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_8__UART2_RX_DATA = IOMUX_PAD(0x0614, 0x0244, 4, 0x0928, 3, 0), - MX6_PAD_GPIO_8__GPIO1_IO08 = IOMUX_PAD(0x0614, 0x0244, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_8__SPDIF_SR_CLK = IOMUX_PAD(0x0614, 0x0244, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_8__USB_OTG_PWR_CTL_WAKE = IOMUX_PAD(0x0614, 0x0244, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ESAI_TX3_RX2 = IOMUX_PAD(0x0618, 0x0248, 0, 0x0880, 1, 0), - MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x0618, 0x0248, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_16__ENET_REF_CLK = IOMUX_PAD(0x0618, 0x0248, 2, 0x083C, 1, 0), - MX6_PAD_GPIO_16__SD1_LCTL = IOMUX_PAD(0x0618, 0x0248, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_16__SPDIF_IN = IOMUX_PAD(0x0618, 0x0248, 4, 0x0914, 3, 0), - MX6_PAD_GPIO_16__GPIO7_IO11 = IOMUX_PAD(0x0618, 0x0248, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_16__I2C3_SDA = IOMUX_PAD(0x0618, 0x0248, 22, 0x08AC, 2, 0), - MX6_PAD_GPIO_16__JTAG_DE_B = IOMUX_PAD(0x0618, 0x0248, 7, 0x0000, 0, 0), - MX6_PAD_GPIO_17__ESAI_TX0 = IOMUX_PAD(0x061C, 0x024C, 0, 0x0874, 0, 0), - MX6_PAD_GPIO_17__ENET_1588_EVENT3_IN = IOMUX_PAD(0x061C, 0x024C, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_17__CCM_PMIC_READY = IOMUX_PAD(0x061C, 0x024C, 2, 0x07F0, 1, 0), - MX6_PAD_GPIO_17__SDMA_EXT_EVENT0 = IOMUX_PAD(0x061C, 0x024C, 3, 0x090C, 1, 0), - MX6_PAD_GPIO_17__SPDIF_OUT = IOMUX_PAD(0x061C, 0x024C, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_17__GPIO7_IO12 = IOMUX_PAD(0x061C, 0x024C, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__ESAI_TX1 = IOMUX_PAD(0x0620, 0x0250, 0, 0x0878, 0, 0), - MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x0620, 0x0250, 1, 0x0844, 1, 0), - MX6_PAD_GPIO_18__SD3_VSELECT = IOMUX_PAD(0x0620, 0x0250, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SDMA_EXT_EVENT1 = IOMUX_PAD(0x0620, 0x0250, 3, 0x0910, 1, 0), - MX6_PAD_GPIO_18__ASRC_EXT_CLK = IOMUX_PAD(0x0620, 0x0250, 4, 0x07B0, 2, 0), - MX6_PAD_GPIO_18__GPIO7_IO13 = IOMUX_PAD(0x0620, 0x0250, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_18__SNVS_VIO_5_CTL = IOMUX_PAD(0x0620, 0x0250, 6, 0x0000, 0, 0), - MX6_PAD_GPIO_19__KEY_COL5 = IOMUX_PAD(0x0624, 0x0254, 0, 0x08E8, 1, 0), - MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x0624, 0x0254, 1, 0x0000, 0, 0), - MX6_PAD_GPIO_19__SPDIF_OUT = IOMUX_PAD(0x0624, 0x0254, 2, 0x0000, 0, 0), - MX6_PAD_GPIO_19__CCM_CLKO1 = IOMUX_PAD(0x0624, 0x0254, 3, 0x0000, 0, 0), - MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x0624, 0x0254, 4, 0x0000, 0, 0), - MX6_PAD_GPIO_19__GPIO4_IO05 = IOMUX_PAD(0x0624, 0x0254, 5, 0x0000, 0, 0), - MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x0624, 0x0254, 6, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x0628, 0x0258, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__GPIO5_IO18 = IOMUX_PAD(0x0628, 0x0258, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_PIXCLK__ARM_EVENTO = IOMUX_PAD(0x0628, 0x0258, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x062C, 0x025C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__CCM_CLKO1 = IOMUX_PAD(0x062C, 0x025C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__GPIO5_IO19 = IOMUX_PAD(0x062C, 0x025C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_MCLK__ARM_TRACE_CTL = IOMUX_PAD(0x062C, 0x025C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x0630, 0x0260, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__EIM_DATA00 = IOMUX_PAD(0x0630, 0x0260, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__GPIO5_IO20 = IOMUX_PAD(0x0630, 0x0260, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DATA_EN__ARM_TRACE_CLK = IOMUX_PAD(0x0630, 0x0260, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x0634, 0x0264, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__EIM_DATA01 = IOMUX_PAD(0x0634, 0x0264, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__GPIO5_IO21 = IOMUX_PAD(0x0634, 0x0264, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_VSYNC__ARM_TRACE00 = IOMUX_PAD(0x0634, 0x0264, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__IPU1_CSI0_DATA04 = IOMUX_PAD(0x0638, 0x0268, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__EIM_DATA02 = IOMUX_PAD(0x0638, 0x0268, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0638, 0x0268, 2, 0x07F4, 3, 0), - MX6_PAD_CSI0_DAT4__KEY_COL5 = IOMUX_PAD(0x0638, 0x0268, 3, 0x08E8, 2, 0), - MX6_PAD_CSI0_DAT4__AUD3_TXC = IOMUX_PAD(0x0638, 0x0268, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__GPIO5_IO22 = IOMUX_PAD(0x0638, 0x0268, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT4__ARM_TRACE01 = IOMUX_PAD(0x0638, 0x0268, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__IPU1_CSI0_DATA05 = IOMUX_PAD(0x063C, 0x026C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__EIM_DATA03 = IOMUX_PAD(0x063C, 0x026C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x063C, 0x026C, 2, 0x07FC, 3, 0), - MX6_PAD_CSI0_DAT5__KEY_ROW5 = IOMUX_PAD(0x063C, 0x026C, 3, 0x08F4, 1, 0), - MX6_PAD_CSI0_DAT5__AUD3_TXD = IOMUX_PAD(0x063C, 0x026C, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__GPIO5_IO23 = IOMUX_PAD(0x063C, 0x026C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT5__ARM_TRACE02 = IOMUX_PAD(0x063C, 0x026C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__IPU1_CSI0_DATA06 = IOMUX_PAD(0x0640, 0x0270, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__EIM_DATA04 = IOMUX_PAD(0x0640, 0x0270, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0640, 0x0270, 2, 0x07F8, 3, 0), - MX6_PAD_CSI0_DAT6__KEY_COL6 = IOMUX_PAD(0x0640, 0x0270, 3, 0x08EC, 1, 0), - MX6_PAD_CSI0_DAT6__AUD3_TXFS = IOMUX_PAD(0x0640, 0x0270, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__GPIO5_IO24 = IOMUX_PAD(0x0640, 0x0270, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT6__ARM_TRACE03 = IOMUX_PAD(0x0640, 0x0270, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__IPU1_CSI0_DATA07 = IOMUX_PAD(0x0644, 0x0274, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__EIM_DATA05 = IOMUX_PAD(0x0644, 0x0274, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x0274, 2, 0x0800, 3, 0), - MX6_PAD_CSI0_DAT7__KEY_ROW6 = IOMUX_PAD(0x0644, 0x0274, 3, 0x08F8, 2, 0), - MX6_PAD_CSI0_DAT7__AUD3_RXD = IOMUX_PAD(0x0644, 0x0274, 4, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__GPIO5_IO25 = IOMUX_PAD(0x0644, 0x0274, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT7__ARM_TRACE04 = IOMUX_PAD(0x0644, 0x0274, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__IPU1_CSI0_DATA08 = IOMUX_PAD(0x0648, 0x0278, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__EIM_DATA06 = IOMUX_PAD(0x0648, 0x0278, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0648, 0x0278, 2, 0x0810, 2, 0), - MX6_PAD_CSI0_DAT8__KEY_COL7 = IOMUX_PAD(0x0648, 0x0278, 3, 0x08F0, 2, 0), - MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0648, 0x0278, 20, 0x089C, 1, 0), - MX6_PAD_CSI0_DAT8__GPIO5_IO26 = IOMUX_PAD(0x0648, 0x0278, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT8__ARM_TRACE05 = IOMUX_PAD(0x0648, 0x0278, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__IPU1_CSI0_DATA09 = IOMUX_PAD(0x064C, 0x027C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__EIM_DATA07 = IOMUX_PAD(0x064C, 0x027C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x064C, 0x027C, 2, 0x0818, 2, 0), - MX6_PAD_CSI0_DAT9__KEY_ROW7 = IOMUX_PAD(0x064C, 0x027C, 3, 0x08FC, 2, 0), - MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x064C, 0x027C, 20, 0x0898, 1, 0), - MX6_PAD_CSI0_DAT9__GPIO5_IO27 = IOMUX_PAD(0x064C, 0x027C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT9__ARM_TRACE06 = IOMUX_PAD(0x064C, 0x027C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__IPU1_CSI0_DATA10 = IOMUX_PAD(0x0650, 0x0280, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__AUD3_RXC = IOMUX_PAD(0x0650, 0x0280, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0650, 0x0280, 2, 0x0814, 2, 0), - MX6_PAD_CSI0_DAT10__UART1_TX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__UART1_RX_DATA = IOMUX_PAD(0x0650, 0x0280, 3, 0x0920, 0, 0), - MX6_PAD_CSI0_DAT10__GPIO5_IO28 = IOMUX_PAD(0x0650, 0x0280, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT10__ARM_TRACE07 = IOMUX_PAD(0x0650, 0x0280, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__IPU1_CSI0_DATA11 = IOMUX_PAD(0x0654, 0x0284, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__AUD3_RXFS = IOMUX_PAD(0x0654, 0x0284, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0654, 0x0284, 2, 0x081C, 2, 0), - MX6_PAD_CSI0_DAT11__UART1_TX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__UART1_RX_DATA = IOMUX_PAD(0x0654, 0x0284, 3, 0x0920, 1, 0), - MX6_PAD_CSI0_DAT11__GPIO5_IO29 = IOMUX_PAD(0x0654, 0x0284, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT11__ARM_TRACE08 = IOMUX_PAD(0x0654, 0x0284, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__IPU1_CSI0_DATA12 = IOMUX_PAD(0x0658, 0x0288, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__EIM_DATA08 = IOMUX_PAD(0x0658, 0x0288, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_TX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__UART4_RX_DATA = IOMUX_PAD(0x0658, 0x0288, 3, 0x0938, 2, 0), - MX6_PAD_CSI0_DAT12__GPIO5_IO30 = IOMUX_PAD(0x0658, 0x0288, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT12__ARM_TRACE09 = IOMUX_PAD(0x0658, 0x0288, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__IPU1_CSI0_DATA13 = IOMUX_PAD(0x065C, 0x028C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__EIM_DATA09 = IOMUX_PAD(0x065C, 0x028C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_TX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__UART4_RX_DATA = IOMUX_PAD(0x065C, 0x028C, 3, 0x0938, 3, 0), - MX6_PAD_CSI0_DAT13__GPIO5_IO31 = IOMUX_PAD(0x065C, 0x028C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT13__ARM_TRACE10 = IOMUX_PAD(0x065C, 0x028C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__IPU1_CSI0_DATA14 = IOMUX_PAD(0x0660, 0x0290, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__EIM_DATA10 = IOMUX_PAD(0x0660, 0x0290, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_TX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__UART5_RX_DATA = IOMUX_PAD(0x0660, 0x0290, 3, 0x0940, 2, 0), - MX6_PAD_CSI0_DAT14__GPIO6_IO00 = IOMUX_PAD(0x0660, 0x0290, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT14__ARM_TRACE11 = IOMUX_PAD(0x0660, 0x0290, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__IPU1_CSI0_DATA15 = IOMUX_PAD(0x0664, 0x0294, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__EIM_DATA11 = IOMUX_PAD(0x0664, 0x0294, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_TX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__UART5_RX_DATA = IOMUX_PAD(0x0664, 0x0294, 3, 0x0940, 3, 0), - MX6_PAD_CSI0_DAT15__GPIO6_IO01 = IOMUX_PAD(0x0664, 0x0294, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT15__ARM_TRACE12 = IOMUX_PAD(0x0664, 0x0294, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__IPU1_CSI0_DATA16 = IOMUX_PAD(0x0668, 0x0298, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__EIM_DATA12 = IOMUX_PAD(0x0668, 0x0298, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_CTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__UART4_RTS_B = IOMUX_PAD(0x0668, 0x0298, 3, 0x0934, 0, 0), - MX6_PAD_CSI0_DAT16__GPIO6_IO02 = IOMUX_PAD(0x0668, 0x0298, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT16__ARM_TRACE13 = IOMUX_PAD(0x0668, 0x0298, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__IPU1_CSI0_DATA17 = IOMUX_PAD(0x066C, 0x029C, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__EIM_DATA13 = IOMUX_PAD(0x066C, 0x029C, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_CTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__UART4_RTS_B = IOMUX_PAD(0x066C, 0x029C, 3, 0x0934, 1, 0), - MX6_PAD_CSI0_DAT17__GPIO6_IO03 = IOMUX_PAD(0x066C, 0x029C, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT17__ARM_TRACE14 = IOMUX_PAD(0x066C, 0x029C, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__IPU1_CSI0_DATA18 = IOMUX_PAD(0x0670, 0x02A0, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__EIM_DATA14 = IOMUX_PAD(0x0670, 0x02A0, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_CTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__UART5_RTS_B = IOMUX_PAD(0x0670, 0x02A0, 3, 0x093C, 2, 0), - MX6_PAD_CSI0_DAT18__GPIO6_IO04 = IOMUX_PAD(0x0670, 0x02A0, 5, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT18__ARM_TRACE15 = IOMUX_PAD(0x0670, 0x02A0, 7, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__IPU1_CSI0_DATA19 = IOMUX_PAD(0x0674, 0x02A4, 0, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__EIM_DATA15 = IOMUX_PAD(0x0674, 0x02A4, 1, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_CTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x0000, 0, 0), - MX6_PAD_CSI0_DAT19__UART5_RTS_B = IOMUX_PAD(0x0674, 0x02A4, 3, 0x093C, 3, 0), - MX6_PAD_CSI0_DAT19__GPIO6_IO05 = IOMUX_PAD(0x0674, 0x02A4, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__SD3_DATA7 = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_TX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT7__UART1_RX_DATA = IOMUX_PAD(0x0690, 0x02A8, 1, 0x0920, 2, 0), - MX6_PAD_SD3_DAT7__GPIO6_IO17 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__SD3_DATA6 = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_TX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT6__UART1_RX_DATA = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0920, 3, 0), - MX6_PAD_SD3_DAT6__GPIO6_IO18 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__SD3_DATA5 = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_TX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT5__UART2_RX_DATA = IOMUX_PAD(0x0698, 0x02B0, 1, 0x0928, 4, 0), - MX6_PAD_SD3_DAT5__GPIO7_IO00 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__SD3_DATA4 = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT4__UART2_RX_DATA = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0928, 5, 0), - MX6_PAD_SD3_DAT4__GPIO7_IO01 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__SD3_CMD = IOMUX_PAD(0x06A0, 0x02B8, 16, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_CTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__UART2_RTS_B = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0924, 2, 0), - MX6_PAD_SD3_CMD__FLEXCAN1_TX = IOMUX_PAD(0x06A0, 0x02B8, 2, 0x0000, 0, 0), - MX6_PAD_SD3_CMD__GPIO7_IO02 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__SD3_CLK = IOMUX_PAD(0x06A4, 0x02BC, 0, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__UART2_CTS_B = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0000, 0, 0), - MX6_PAD_SD3_CLK__UART2_RTS_B = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0924, 3, 0), - MX6_PAD_SD3_CLK__FLEXCAN1_RX = IOMUX_PAD(0x06A4, 0x02BC, 2, 0x07E4, 2, 0), - MX6_PAD_SD3_CLK__GPIO7_IO03 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__SD3_DATA0 = IOMUX_PAD(0x06A8, 0x02C0, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_CTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__UART1_RTS_B = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x091C, 2, 0), - MX6_PAD_SD3_DAT0__FLEXCAN2_TX = IOMUX_PAD(0x06A8, 0x02C0, 2, 0x0000, 0, 0), - MX6_PAD_SD3_DAT0__GPIO7_IO04 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__SD3_DATA1 = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_CTS_B = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT1__UART1_RTS_B = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x091C, 3, 0), - MX6_PAD_SD3_DAT1__FLEXCAN2_RX = IOMUX_PAD(0x06AC, 0x02C4, 2, 0x07E8, 1, 0), - MX6_PAD_SD3_DAT1__GPIO7_IO05 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__SD3_DATA2 = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT2__GPIO7_IO06 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__SD3_DATA3 = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_CTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), - MX6_PAD_SD3_DAT3__UART3_RTS_B = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x092C, 4, 0), - MX6_PAD_SD3_DAT3__GPIO7_IO07 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), - MX6_PAD_SD3_RST__SD3_RESET = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_CTS_B = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), - MX6_PAD_SD3_RST__UART3_RTS_B = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x092C, 5, 0), - MX6_PAD_SD3_RST__GPIO7_IO08 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__NAND_CLE = IOMUX_PAD(0x06BC, 0x02D4, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__IPU2_SISG4 = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CLE__GPIO6_IO07 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__NAND_ALE = IOMUX_PAD(0x06C0, 0x02D8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__SD4_RESET = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_ALE__GPIO6_IO08 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__NAND_WP_B = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__IPU2_SISG5 = IOMUX_PAD(0x06C4, 0x02DC, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_WP_B__GPIO6_IO09 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__NAND_READY_B = IOMUX_PAD(0x06C8, 0x02E0, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__IPU2_DI0_PIN01 = IOMUX_PAD(0x06C8, 0x02E0, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_RB0__GPIO6_IO10 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__NAND_CE0_B = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS0__GPIO6_IO11 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__NAND_CE1_B = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD4_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__SD3_VSELECT = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), - MX6_PAD_NANDF_CS1__GPIO6_IO14 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__NAND_CE2_B = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__IPU1_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__ESAI_TX0 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0874, 1, 0), - MX6_PAD_NANDF_CS2__EIM_CRE = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__GPIO6_IO15 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS2__IPU2_SISG0 = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__NAND_CE3_B = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__IPU1_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__ESAI_TX1 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0878, 1, 0), - MX6_PAD_NANDF_CS3__EIM_ADDR26 = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__GPIO6_IO16 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_CS3__IPU2_SISG1 = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__SD4_CMD = IOMUX_PAD(0x06DC, 0x02F4, 16, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__NAND_RE_B = IOMUX_PAD(0x06DC, 0x02F4, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_TX_DATA = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CMD__UART3_RX_DATA = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x0930, 2, 0), - MX6_PAD_SD4_CMD__GPIO7_IO09 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__SD4_CLK = IOMUX_PAD(0x06E0, 0x02F8, 0, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__NAND_WE_B = IOMUX_PAD(0x06E0, 0x02F8, 1, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_TX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0000, 0, 0), - MX6_PAD_SD4_CLK__UART3_RX_DATA = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x0930, 3, 0), - MX6_PAD_SD4_CLK__GPIO7_IO10 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__NAND_DATA00 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__SD1_DATA4 = IOMUX_PAD(0x06E4, 0x02FC, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D0__GPIO2_IO00 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__NAND_DATA01 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__SD1_DATA5 = IOMUX_PAD(0x06E8, 0x0300, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D1__GPIO2_IO01 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__NAND_DATA02 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__SD1_DATA6 = IOMUX_PAD(0x06EC, 0x0304, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D2__GPIO2_IO02 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__NAND_DATA03 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__SD1_DATA7 = IOMUX_PAD(0x06F0, 0x0308, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D3__GPIO2_IO03 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__NAND_DATA04 = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__SD2_DATA4 = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D4__GPIO2_IO04 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__NAND_DATA05 = IOMUX_PAD(0x06F8, 0x0310, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__SD2_DATA5 = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D5__GPIO2_IO05 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__NAND_DATA06 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__SD2_DATA6 = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D6__GPIO2_IO06 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__NAND_DATA07 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__SD2_DATA7 = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), - MX6_PAD_NANDF_D7__GPIO2_IO07 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__SD4_DATA0 = IOMUX_PAD(0x0704, 0x031C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__NAND_DQS = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT0__GPIO2_IO08 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__SD4_DATA1 = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__PWM3_OUT = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT1__GPIO2_IO09 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__SD4_DATA2 = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__PWM4_OUT = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT2__GPIO2_IO10 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__SD4_DATA3 = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT3__GPIO2_IO11 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__SD4_DATA4 = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_TX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT4__UART2_RX_DATA = IOMUX_PAD(0x0714, 0x032C, 2, 0x0928, 6, 0), - MX6_PAD_SD4_DAT4__GPIO2_IO12 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__SD4_DATA5 = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_CTS_B = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT5__UART2_RTS_B = IOMUX_PAD(0x0718, 0x0330, 2, 0x0924, 4, 0), - MX6_PAD_SD4_DAT5__GPIO2_IO13 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__SD4_DATA6 = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_CTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT6__UART2_RTS_B = IOMUX_PAD(0x071C, 0x0334, 2, 0x0924, 5, 0), - MX6_PAD_SD4_DAT6__GPIO2_IO14 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__SD4_DATA7 = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_TX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), - MX6_PAD_SD4_DAT7__UART2_RX_DATA = IOMUX_PAD(0x0720, 0x0338, 2, 0x0928, 7, 0), - MX6_PAD_SD4_DAT7__GPIO2_IO15 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__SD1_DATA1 = IOMUX_PAD(0x0724, 0x033C, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0724, 0x033C, 1, 0x0834, 1, 0), - MX6_PAD_SD1_DAT1__PWM3_OUT = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPT_CAPTURE2 = IOMUX_PAD(0x0724, 0x033C, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT1__GPIO1_IO17 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__SD1_DATA0 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__ECSPI5_MISO = IOMUX_PAD(0x0728, 0x0340, 1, 0x082C, 1, 0), - MX6_PAD_SD1_DAT0__GPT_CAPTURE1 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT0__GPIO1_IO16 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__SD1_DATA3 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__ECSPI5_SS2 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPT_COMPARE3 = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__PWM1_OUT = IOMUX_PAD(0x072C, 0x0344, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_B = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__GPIO1_IO21 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT3__WDOG2_RESET_B_DEB = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x0730, 0x0348, 16, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0730, 0x0348, 1, 0x0830, 0, 0), - MX6_PAD_SD1_CMD__PWM4_OUT = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPT_COMPARE1 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CMD__GPIO1_IO18 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__SD1_DATA2 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__ECSPI5_SS1 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0838, 1, 0), - MX6_PAD_SD1_DAT2__GPT_COMPARE2 = IOMUX_PAD(0x0734, 0x034C, 2, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__PWM2_OUT = IOMUX_PAD(0x0734, 0x034C, 3, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_B = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__GPIO1_IO19 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), - MX6_PAD_SD1_DAT2__WDOG1_RESET_B_DEB = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__ECSPI5_SCLK = IOMUX_PAD(0x0738, 0x0350, 1, 0x0828, 0, 0), - MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x0738, 0x0350, 3, 0x0000, 0, 0), - MX6_PAD_SD1_CLK__GPIO1_IO20 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), - MX6_PAD_SD2_CLK__ECSPI5_SCLK = IOMUX_PAD(0x073C, 0x0354, 1, 0x0828, 1, 0), - MX6_PAD_SD2_CLK__KEY_COL5 = IOMUX_PAD(0x073C, 0x0354, 2, 0x08E8, 3, 0), - MX6_PAD_SD2_CLK__AUD4_RXFS = IOMUX_PAD(0x073C, 0x0354, 3, 0x07C0, 1, 0), - MX6_PAD_SD2_CLK__GPIO1_IO10 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x0740, 0x0358, 16, 0x0000, 0, 0), - MX6_PAD_SD2_CMD__ECSPI5_MOSI = IOMUX_PAD(0x0740, 0x0358, 1, 0x0830, 1, 0), - MX6_PAD_SD2_CMD__KEY_ROW5 = IOMUX_PAD(0x0740, 0x0358, 2, 0x08F4, 2, 0), - MX6_PAD_SD2_CMD__AUD4_RXC = IOMUX_PAD(0x0740, 0x0358, 3, 0x07BC, 1, 0), - MX6_PAD_SD2_CMD__GPIO1_IO11 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__SD2_DATA3 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__ECSPI5_SS3 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), - MX6_PAD_SD2_DAT3__KEY_COL6 = IOMUX_PAD(0x0744, 0x035C, 2, 0x08EC, 2, 0), - MX6_PAD_SD2_DAT3__AUD4_TXC = IOMUX_PAD(0x0744, 0x035C, 3, 0x07C4, 1, 0), - MX6_PAD_SD2_DAT3__GPIO1_IO12 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), -}; - +MX6_PAD_DECL(SD2_DAT1__SD2_DATA1, 0x0360, 0x004C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__ECSPI5_SS0, 0x0360, 0x004C, 1, 0x0834, 0, 0) +MX6_PAD_DECL(SD2_DAT1__EIM_CS2_B, 0x0360, 0x004C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__AUD4_TXFS, 0x0360, 0x004C, 3, 0x07C8, 0, 0) +MX6_PAD_DECL(SD2_DAT1__KEY_COL7, 0x0360, 0x004C, 4, 0x08F0, 0, 0) +MX6_PAD_DECL(SD2_DAT1__GPIO1_IO14, 0x0360, 0x004C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__SD2_DATA2, 0x0364, 0x0050, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__ECSPI5_SS1, 0x0364, 0x0050, 1, 0x0838, 0, 0) +MX6_PAD_DECL(SD2_DAT2__EIM_CS3_B, 0x0364, 0x0050, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__AUD4_TXD, 0x0364, 0x0050, 3, 0x07B8, 0, 0) +MX6_PAD_DECL(SD2_DAT2__KEY_ROW6, 0x0364, 0x0050, 4, 0x08F8, 0, 0) +MX6_PAD_DECL(SD2_DAT2__GPIO1_IO13, 0x0364, 0x0050, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__SD2_DATA0, 0x0368, 0x0054, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__ECSPI5_MISO, 0x0368, 0x0054, 1, 0x082C, 0, 0) +MX6_PAD_DECL(SD2_DAT0__AUD4_RXD, 0x0368, 0x0054, 3, 0x07B4, 0, 0) +MX6_PAD_DECL(SD2_DAT0__KEY_ROW7, 0x0368, 0x0054, 4, 0x08FC, 0, 0) +MX6_PAD_DECL(SD2_DAT0__GPIO1_IO15, 0x0368, 0x0054, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__DCIC2_OUT, 0x0368, 0x0054, 6, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__USB_H2_DATA, 0x036C, 0x0058, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__RGMII_TXC, 0x036C, 0x0058, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__SPDIF_EXT_CLK, 0x036C, 0x0058, 2, 0x0918, 0, 0) +MX6_PAD_DECL(RGMII_TXC__GPIO6_IO19, 0x036C, 0x0058, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__XTALOSC_REF_CLK_24M, 0x036C, 0x0058, 7, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__HSI_TX_READY, 0x0370, 0x005C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__RGMII_TD0, 0x0370, 0x005C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__GPIO6_IO20, 0x0370, 0x005C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__HSI_RX_FLAG, 0x0374, 0x0060, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__RGMII_TD1, 0x0374, 0x0060, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__GPIO6_IO21, 0x0374, 0x0060, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__HSI_RX_DATA, 0x0378, 0x0064, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__RGMII_TD2, 0x0378, 0x0064, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__GPIO6_IO22, 0x0378, 0x0064, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__HSI_RX_WAKE, 0x037C, 0x0068, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__RGMII_TD3, 0x037C, 0x0068, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__GPIO6_IO23, 0x037C, 0x0068, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__USB_H3_DATA, 0x0380, 0x006C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__RGMII_RX_CTL, 0x0380, 0x006C, 1, 0x0858, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__GPIO6_IO24, 0x0380, 0x006C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD0__HSI_RX_READY, 0x0384, 0x0070, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD0__RGMII_RD0, 0x0384, 0x0070, 1, 0x0848, 0, 0) +MX6_PAD_DECL(RGMII_RD0__GPIO6_IO25, 0x0384, 0x0070, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__USB_H2_STROBE, 0x0388, 0x0074, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__RGMII_TX_CTL, 0x0388, 0x0074, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__GPIO6_IO26, 0x0388, 0x0074, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__ENET_REF_CLK, 0x0388, 0x0074, 7, 0x083C, 0, 0) +MX6_PAD_DECL(RGMII_RD1__HSI_TX_FLAG, 0x038C, 0x0078, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__RGMII_RD1, 0x038C, 0x0078, 1, 0x084C, 0, 0) +MX6_PAD_DECL(RGMII_RD1__GPIO6_IO27, 0x038C, 0x0078, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__HSI_TX_DATA, 0x0390, 0x007C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__RGMII_RD2, 0x0390, 0x007C, 1, 0x0850, 0, 0) +MX6_PAD_DECL(RGMII_RD2__GPIO6_IO28, 0x0390, 0x007C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__HSI_TX_WAKE, 0x0394, 0x0080, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__RGMII_RD3, 0x0394, 0x0080, 1, 0x0854, 0, 0) +MX6_PAD_DECL(RGMII_RD3__GPIO6_IO29, 0x0394, 0x0080, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__USB_H3_STROBE, 0x0398, 0x0084, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__RGMII_RXC, 0x0398, 0x0084, 1, 0x0844, 0, 0) +MX6_PAD_DECL(RGMII_RXC__GPIO6_IO30, 0x0398, 0x0084, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__EIM_ADDR25, 0x039C, 0x0088, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI4_SS1, 0x039C, 0x0088, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI2_RDY, 0x039C, 0x0088, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI1_PIN12, 0x039C, 0x0088, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI0_D1_CS, 0x039C, 0x0088, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__GPIO5_IO02, 0x039C, 0x0088, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__HDMI_TX_CEC_LINE, 0x039C, 0x0088, 6, 0x088C, 0, 0) +MX6_PAD_DECL(EIM_EB2__EIM_EB2_B, 0x03A0, 0x008C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__ECSPI1_SS0, 0x03A0, 0x008C, 1, 0x0800, 0, 0) +MX6_PAD_DECL(EIM_EB2__IPU2_CSI1_DATA19, 0x03A0, 0x008C, 3, 0x08D4, 0, 0) +MX6_PAD_DECL(EIM_EB2__HDMI_TX_DDC_SCL, 0x03A0, 0x008C, 4, 0x0890, 0, 0) +MX6_PAD_DECL(EIM_EB2__GPIO2_IO30, 0x03A0, 0x008C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__I2C2_SCL, 0x03A0, 0x008C, 22, 0x08A0, 0, 0) +MX6_PAD_DECL(EIM_EB2__SRC_BOOT_CFG30, 0x03A0, 0x008C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__EIM_DATA16, 0x03A4, 0x0090, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__ECSPI1_SCLK, 0x03A4, 0x0090, 1, 0x07F4, 0, 0) +MX6_PAD_DECL(EIM_D16__IPU1_DI0_PIN05, 0x03A4, 0x0090, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__IPU2_CSI1_DATA18, 0x03A4, 0x0090, 3, 0x08D0, 0, 0) +MX6_PAD_DECL(EIM_D16__HDMI_TX_DDC_SDA, 0x03A4, 0x0090, 4, 0x0894, 0, 0) +MX6_PAD_DECL(EIM_D16__GPIO3_IO16, 0x03A4, 0x0090, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__I2C2_SDA, 0x03A4, 0x0090, 22, 0x08A4, 0, 0) +MX6_PAD_DECL(EIM_D17__EIM_DATA17, 0x03A8, 0x0094, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__ECSPI1_MISO, 0x03A8, 0x0094, 1, 0x07F8, 0, 0) +MX6_PAD_DECL(EIM_D17__IPU1_DI0_PIN06, 0x03A8, 0x0094, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__IPU2_CSI1_PIXCLK, 0x03A8, 0x0094, 3, 0x08E0, 0, 0) +MX6_PAD_DECL(EIM_D17__DCIC1_OUT, 0x03A8, 0x0094, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__GPIO3_IO17, 0x03A8, 0x0094, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__I2C3_SCL, 0x03A8, 0x0094, 22, 0x08A8, 0, 0) +MX6_PAD_DECL(EIM_D18__EIM_DATA18, 0x03AC, 0x0098, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__ECSPI1_MOSI, 0x03AC, 0x0098, 1, 0x07FC, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI0_PIN07, 0x03AC, 0x0098, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU2_CSI1_DATA17, 0x03AC, 0x0098, 3, 0x08CC, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI1_D0_CS, 0x03AC, 0x0098, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__GPIO3_IO18, 0x03AC, 0x0098, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__I2C3_SDA, 0x03AC, 0x0098, 22, 0x08AC, 0, 0) +MX6_PAD_DECL(EIM_D19__EIM_DATA19, 0x03B0, 0x009C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__ECSPI1_SS1, 0x03B0, 0x009C, 1, 0x0804, 0, 0) +MX6_PAD_DECL(EIM_D19__IPU1_DI0_PIN08, 0x03B0, 0x009C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__IPU2_CSI1_DATA16, 0x03B0, 0x009C, 3, 0x08C8, 0, 0) +MX6_PAD_DECL(EIM_D19__UART1_CTS_B, 0x03B0, 0x009C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__UART1_RTS_B, 0x03B0, 0x009C, 4, 0x091C, 0, 0) +MX6_PAD_DECL(EIM_D19__GPIO3_IO19, 0x03B0, 0x009C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EPIT1_OUT, 0x03B0, 0x009C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EIM_DATA20, 0x03B4, 0x00A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__ECSPI4_SS0, 0x03B4, 0x00A0, 1, 0x0824, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU1_DI0_PIN16, 0x03B4, 0x00A0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU2_CSI1_DATA15, 0x03B4, 0x00A0, 3, 0x08C4, 0, 0) +MX6_PAD_DECL(EIM_D20__UART1_CTS_B, 0x03B4, 0x00A0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__UART1_RTS_B, 0x03B4, 0x00A0, 4, 0x091C, 1, 0) +MX6_PAD_DECL(EIM_D20__GPIO3_IO20, 0x03B4, 0x00A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EPIT2_OUT, 0x03B4, 0x00A0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__EIM_DATA21, 0x03B8, 0x00A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__ECSPI4_SCLK, 0x03B8, 0x00A4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU1_DI0_PIN17, 0x03B8, 0x00A4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU2_CSI1_DATA11, 0x03B8, 0x00A4, 3, 0x08B4, 0, 0) +MX6_PAD_DECL(EIM_D21__USB_OTG_OC, 0x03B8, 0x00A4, 4, 0x0944, 0, 0) +MX6_PAD_DECL(EIM_D21__GPIO3_IO21, 0x03B8, 0x00A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__I2C1_SCL, 0x03B8, 0x00A4, 22, 0x0898, 0, 0) +MX6_PAD_DECL(EIM_D21__SPDIF_IN, 0x03B8, 0x00A4, 7, 0x0914, 0, 0) +MX6_PAD_DECL(EIM_D22__EIM_DATA22, 0x03BC, 0x00A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__ECSPI4_MISO, 0x03BC, 0x00A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU1_DI0_PIN01, 0x03BC, 0x00A8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU2_CSI1_DATA10, 0x03BC, 0x00A8, 3, 0x08B0, 0, 0) +MX6_PAD_DECL(EIM_D22__USB_OTG_PWR, 0x03BC, 0x00A8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__GPIO3_IO22, 0x03BC, 0x00A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__SPDIF_OUT, 0x03BC, 0x00A8, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__EIM_DATA23, 0x03C0, 0x00AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI0_D0_CS, 0x03C0, 0x00AC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_CTS_B, 0x03C0, 0x00AC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_RTS_B, 0x03C0, 0x00AC, 2, 0x092C, 0, 0) +MX6_PAD_DECL(EIM_D23__UART1_DCD_B, 0x03C0, 0x00AC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU2_CSI1_DATA_EN, 0x03C0, 0x00AC, 4, 0x08D8, 0, 0) +MX6_PAD_DECL(EIM_D23__GPIO3_IO23, 0x03C0, 0x00AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN02, 0x03C0, 0x00AC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN14, 0x03C0, 0x00AC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EIM_EB3_B, 0x03C4, 0x00B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__ECSPI4_RDY, 0x03C4, 0x00B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_CTS_B, 0x03C4, 0x00B0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_RTS_B, 0x03C4, 0x00B0, 2, 0x092C, 1, 0) +MX6_PAD_DECL(EIM_EB3__UART1_RI_B, 0x03C4, 0x00B0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU2_CSI1_HSYNC, 0x03C4, 0x00B0, 4, 0x08DC, 0, 0) +MX6_PAD_DECL(EIM_EB3__GPIO2_IO31, 0x03C4, 0x00B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU1_DI1_PIN03, 0x03C4, 0x00B0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__SRC_BOOT_CFG31, 0x03C4, 0x00B0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__EIM_DATA24, 0x03C8, 0x00B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI4_SS2, 0x03C8, 0x00B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_TX_DATA, 0x03C8, 0x00B4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_RX_DATA, 0x03C8, 0x00B4, 2, 0x0930, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI1_SS2, 0x03C8, 0x00B4, 3, 0x0808, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI2_SS2, 0x03C8, 0x00B4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__GPIO3_IO24, 0x03C8, 0x00B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__AUD5_RXFS, 0x03C8, 0x00B4, 6, 0x07D8, 0, 0) +MX6_PAD_DECL(EIM_D24__UART1_DTR_B, 0x03C8, 0x00B4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__EIM_DATA25, 0x03CC, 0x00B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI4_SS3, 0x03CC, 0x00B8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_TX_DATA, 0x03CC, 0x00B8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_RX_DATA, 0x03CC, 0x00B8, 2, 0x0930, 1, 0) +MX6_PAD_DECL(EIM_D25__ECSPI1_SS3, 0x03CC, 0x00B8, 3, 0x080C, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI2_SS3, 0x03CC, 0x00B8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__GPIO3_IO25, 0x03CC, 0x00B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__AUD5_RXC, 0x03CC, 0x00B8, 6, 0x07D4, 0, 0) +MX6_PAD_DECL(EIM_D25__UART1_DSR_B, 0x03CC, 0x00B8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__EIM_DATA26, 0x03D0, 0x00BC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_DI1_PIN11, 0x03D0, 0x00BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_CSI0_DATA01, 0x03D0, 0x00BC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU2_CSI1_DATA14, 0x03D0, 0x00BC, 3, 0x08C0, 0, 0) +MX6_PAD_DECL(EIM_D26__UART2_TX_DATA, 0x03D0, 0x00BC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__UART2_RX_DATA, 0x03D0, 0x00BC, 4, 0x0928, 0, 0) +MX6_PAD_DECL(EIM_D26__GPIO3_IO26, 0x03D0, 0x00BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_SISG2, 0x03D0, 0x00BC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_DISP1_DATA22, 0x03D0, 0x00BC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__EIM_DATA27, 0x03D4, 0x00C0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_DI1_PIN13, 0x03D4, 0x00C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_CSI0_DATA00, 0x03D4, 0x00C0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU2_CSI1_DATA13, 0x03D4, 0x00C0, 3, 0x08BC, 0, 0) +MX6_PAD_DECL(EIM_D27__UART2_TX_DATA, 0x03D4, 0x00C0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__UART2_RX_DATA, 0x03D4, 0x00C0, 4, 0x0928, 1, 0) +MX6_PAD_DECL(EIM_D27__GPIO3_IO27, 0x03D4, 0x00C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_SISG3, 0x03D4, 0x00C0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_DISP1_DATA23, 0x03D4, 0x00C0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__EIM_DATA28, 0x03D8, 0x00C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__I2C1_SDA, 0x03D8, 0x00C4, 17, 0x089C, 0, 0) +MX6_PAD_DECL(EIM_D28__ECSPI4_MOSI, 0x03D8, 0x00C4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU2_CSI1_DATA12, 0x03D8, 0x00C4, 3, 0x08B8, 0, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_CTS_B, 0x03D8, 0x00C4, 4, 0x0924, 0, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_RTS_B, 0x03D8, 0x00C4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__GPIO3_IO28, 0x03D8, 0x00C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_EXT_TRIG, 0x03D8, 0x00C4, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_DI0_PIN13, 0x03D8, 0x00C4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__EIM_DATA29, 0x03DC, 0x00C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI1_PIN15, 0x03DC, 0x00C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__ECSPI4_SS0, 0x03DC, 0x00C8, 2, 0x0824, 1, 0) +MX6_PAD_DECL(EIM_D29__UART2_CTS_B, 0x03DC, 0x00C8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__UART2_RTS_B, 0x03DC, 0x00C8, 4, 0x0924, 1, 0) +MX6_PAD_DECL(EIM_D29__GPIO3_IO29, 0x03DC, 0x00C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU2_CSI1_VSYNC, 0x03DC, 0x00C8, 6, 0x08E4, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI0_PIN14, 0x03DC, 0x00C8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__EIM_DATA30, 0x03E0, 0x00CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_DISP1_DATA21, 0x03E0, 0x00CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_DI0_PIN11, 0x03E0, 0x00CC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_CSI0_DATA03, 0x03E0, 0x00CC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_CTS_B, 0x03E0, 0x00CC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_RTS_B, 0x03E0, 0x00CC, 4, 0x092C, 2, 0) +MX6_PAD_DECL(EIM_D30__GPIO3_IO30, 0x03E0, 0x00CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__USB_H1_OC, 0x03E0, 0x00CC, 6, 0x0948, 0, 0) +MX6_PAD_DECL(EIM_D31__EIM_DATA31, 0x03E4, 0x00D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_DISP1_DATA20, 0x03E4, 0x00D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_DI0_PIN12, 0x03E4, 0x00D0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_CSI0_DATA02, 0x03E4, 0x00D0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_CTS_B, 0x03E4, 0x00D0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_RTS_B, 0x03E4, 0x00D0, 4, 0x092C, 3, 0) +MX6_PAD_DECL(EIM_D31__GPIO3_IO31, 0x03E4, 0x00D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__USB_H1_PWR, 0x03E4, 0x00D0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__EIM_ADDR24, 0x03E8, 0x00D4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_DISP1_DATA19, 0x03E8, 0x00D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU2_CSI1_DATA19, 0x03E8, 0x00D4, 2, 0x08D4, 1, 0) +MX6_PAD_DECL(EIM_A24__IPU2_SISG2, 0x03E8, 0x00D4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_SISG2, 0x03E8, 0x00D4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__GPIO5_IO04, 0x03E8, 0x00D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__SRC_BOOT_CFG24, 0x03E8, 0x00D4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__EIM_ADDR23, 0x03EC, 0x00D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_DISP1_DATA18, 0x03EC, 0x00D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU2_CSI1_DATA18, 0x03EC, 0x00D8, 2, 0x08D0, 1, 0) +MX6_PAD_DECL(EIM_A23__IPU2_SISG3, 0x03EC, 0x00D8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_SISG3, 0x03EC, 0x00D8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__GPIO6_IO06, 0x03EC, 0x00D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__SRC_BOOT_CFG23, 0x03EC, 0x00D8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__EIM_ADDR22, 0x03F0, 0x00DC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__IPU1_DISP1_DATA17, 0x03F0, 0x00DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__IPU2_CSI1_DATA17, 0x03F0, 0x00DC, 2, 0x08CC, 1, 0) +MX6_PAD_DECL(EIM_A22__GPIO2_IO16, 0x03F0, 0x00DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__SRC_BOOT_CFG22, 0x03F0, 0x00DC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__EIM_ADDR21, 0x03F4, 0x00E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__IPU1_DISP1_DATA16, 0x03F4, 0x00E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__IPU2_CSI1_DATA16, 0x03F4, 0x00E0, 2, 0x08C8, 1, 0) +MX6_PAD_DECL(EIM_A21__GPIO2_IO17, 0x03F4, 0x00E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__SRC_BOOT_CFG21, 0x03F4, 0x00E0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__EIM_ADDR20, 0x03F8, 0x00E4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__IPU1_DISP1_DATA15, 0x03F8, 0x00E4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__IPU2_CSI1_DATA15, 0x03F8, 0x00E4, 2, 0x08C4, 1, 0) +MX6_PAD_DECL(EIM_A20__GPIO2_IO18, 0x03F8, 0x00E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__SRC_BOOT_CFG20, 0x03F8, 0x00E4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__EIM_ADDR19, 0x03FC, 0x00E8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__IPU1_DISP1_DATA14, 0x03FC, 0x00E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__IPU2_CSI1_DATA14, 0x03FC, 0x00E8, 2, 0x08C0, 1, 0) +MX6_PAD_DECL(EIM_A19__GPIO2_IO19, 0x03FC, 0x00E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__SRC_BOOT_CFG19, 0x03FC, 0x00E8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__EIM_ADDR18, 0x0400, 0x00EC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__IPU1_DISP1_DATA13, 0x0400, 0x00EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__IPU2_CSI1_DATA13, 0x0400, 0x00EC, 2, 0x08BC, 1, 0) +MX6_PAD_DECL(EIM_A18__GPIO2_IO20, 0x0400, 0x00EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__SRC_BOOT_CFG18, 0x0400, 0x00EC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__EIM_ADDR17, 0x0404, 0x00F0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__IPU1_DISP1_DATA12, 0x0404, 0x00F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__IPU2_CSI1_DATA12, 0x0404, 0x00F0, 2, 0x08B8, 1, 0) +MX6_PAD_DECL(EIM_A17__GPIO2_IO21, 0x0404, 0x00F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__SRC_BOOT_CFG17, 0x0404, 0x00F0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__EIM_ADDR16, 0x0408, 0x00F4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__IPU1_DI1_DISP_CLK, 0x0408, 0x00F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__IPU2_CSI1_PIXCLK, 0x0408, 0x00F4, 2, 0x08E0, 1, 0) +MX6_PAD_DECL(EIM_A16__GPIO2_IO22, 0x0408, 0x00F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__SRC_BOOT_CFG16, 0x0408, 0x00F4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__EIM_CS0_B, 0x040C, 0x00F8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__IPU1_DI1_PIN05, 0x040C, 0x00F8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__ECSPI2_SCLK, 0x040C, 0x00F8, 2, 0x0810, 0, 0) +MX6_PAD_DECL(EIM_CS0__GPIO2_IO23, 0x040C, 0x00F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__EIM_CS1_B, 0x0410, 0x00FC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__IPU1_DI1_PIN06, 0x0410, 0x00FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__ECSPI2_MOSI, 0x0410, 0x00FC, 2, 0x0818, 0, 0) +MX6_PAD_DECL(EIM_CS1__GPIO2_IO24, 0x0410, 0x00FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__EIM_OE_B, 0x0414, 0x0100, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__IPU1_DI1_PIN07, 0x0414, 0x0100, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__ECSPI2_MISO, 0x0414, 0x0100, 2, 0x0814, 0, 0) +MX6_PAD_DECL(EIM_OE__GPIO2_IO25, 0x0414, 0x0100, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__EIM_RW, 0x0418, 0x0104, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__IPU1_DI1_PIN08, 0x0418, 0x0104, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__ECSPI2_SS0, 0x0418, 0x0104, 2, 0x081C, 0, 0) +MX6_PAD_DECL(EIM_RW__GPIO2_IO26, 0x0418, 0x0104, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__SRC_BOOT_CFG29, 0x0418, 0x0104, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__EIM_LBA_B, 0x041C, 0x0108, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__IPU1_DI1_PIN17, 0x041C, 0x0108, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__ECSPI2_SS1, 0x041C, 0x0108, 2, 0x0820, 0, 0) +MX6_PAD_DECL(EIM_LBA__GPIO2_IO27, 0x041C, 0x0108, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__SRC_BOOT_CFG26, 0x041C, 0x0108, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__EIM_EB0_B, 0x0420, 0x010C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__IPU1_DISP1_DATA11, 0x0420, 0x010C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__IPU2_CSI1_DATA11, 0x0420, 0x010C, 2, 0x08B4, 1, 0) +MX6_PAD_DECL(EIM_EB0__CCM_PMIC_READY, 0x0420, 0x010C, 4, 0x07F0, 0, 0) +MX6_PAD_DECL(EIM_EB0__GPIO2_IO28, 0x0420, 0x010C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__SRC_BOOT_CFG27, 0x0420, 0x010C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__EIM_EB1_B, 0x0424, 0x0110, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__IPU1_DISP1_DATA10, 0x0424, 0x0110, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__IPU2_CSI1_DATA10, 0x0424, 0x0110, 2, 0x08B0, 1, 0) +MX6_PAD_DECL(EIM_EB1__GPIO2_IO29, 0x0424, 0x0110, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__SRC_BOOT_CFG28, 0x0424, 0x0110, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__EIM_AD00, 0x0428, 0x0114, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__IPU1_DISP1_DATA09, 0x0428, 0x0114, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__IPU2_CSI1_DATA09, 0x0428, 0x0114, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__GPIO3_IO00, 0x0428, 0x0114, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__SRC_BOOT_CFG00, 0x0428, 0x0114, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__EIM_AD01, 0x042C, 0x0118, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__IPU1_DISP1_DATA08, 0x042C, 0x0118, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__IPU2_CSI1_DATA08, 0x042C, 0x0118, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__GPIO3_IO01, 0x042C, 0x0118, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__SRC_BOOT_CFG01, 0x042C, 0x0118, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__EIM_AD02, 0x0430, 0x011C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__IPU1_DISP1_DATA07, 0x0430, 0x011C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__IPU2_CSI1_DATA07, 0x0430, 0x011C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__GPIO3_IO02, 0x0430, 0x011C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__SRC_BOOT_CFG02, 0x0430, 0x011C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__EIM_AD03, 0x0434, 0x0120, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__IPU1_DISP1_DATA06, 0x0434, 0x0120, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__IPU2_CSI1_DATA06, 0x0434, 0x0120, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__GPIO3_IO03, 0x0434, 0x0120, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__SRC_BOOT_CFG03, 0x0434, 0x0120, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__EIM_AD04, 0x0438, 0x0124, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__IPU1_DISP1_DATA05, 0x0438, 0x0124, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__IPU2_CSI1_DATA05, 0x0438, 0x0124, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__GPIO3_IO04, 0x0438, 0x0124, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__SRC_BOOT_CFG04, 0x0438, 0x0124, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__EIM_AD05, 0x043C, 0x0128, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__IPU1_DISP1_DATA04, 0x043C, 0x0128, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__IPU2_CSI1_DATA04, 0x043C, 0x0128, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__GPIO3_IO05, 0x043C, 0x0128, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__SRC_BOOT_CFG05, 0x043C, 0x0128, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__EIM_AD06, 0x0440, 0x012C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__IPU1_DISP1_DATA03, 0x0440, 0x012C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__IPU2_CSI1_DATA03, 0x0440, 0x012C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__GPIO3_IO06, 0x0440, 0x012C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__SRC_BOOT_CFG06, 0x0440, 0x012C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__EIM_AD07, 0x0444, 0x0130, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__IPU1_DISP1_DATA02, 0x0444, 0x0130, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__IPU2_CSI1_DATA02, 0x0444, 0x0130, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__GPIO3_IO07, 0x0444, 0x0130, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__SRC_BOOT_CFG07, 0x0444, 0x0130, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__EIM_AD08, 0x0448, 0x0134, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__IPU1_DISP1_DATA01, 0x0448, 0x0134, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__IPU2_CSI1_DATA01, 0x0448, 0x0134, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__GPIO3_IO08, 0x0448, 0x0134, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__SRC_BOOT_CFG08, 0x0448, 0x0134, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__EIM_AD09, 0x044C, 0x0138, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__IPU1_DISP1_DATA00, 0x044C, 0x0138, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__IPU2_CSI1_DATA00, 0x044C, 0x0138, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__GPIO3_IO09, 0x044C, 0x0138, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__SRC_BOOT_CFG09, 0x044C, 0x0138, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__EIM_AD10, 0x0450, 0x013C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__IPU1_DI1_PIN15, 0x0450, 0x013C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__IPU2_CSI1_DATA_EN, 0x0450, 0x013C, 2, 0x08D8, 1, 0) +MX6_PAD_DECL(EIM_DA10__GPIO3_IO10, 0x0450, 0x013C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__SRC_BOOT_CFG10, 0x0450, 0x013C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__EIM_AD11, 0x0454, 0x0140, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU1_DI1_PIN02, 0x0454, 0x0140, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU2_CSI1_HSYNC, 0x0454, 0x0140, 2, 0x08DC, 1, 0) +MX6_PAD_DECL(EIM_DA11__GPIO3_IO11, 0x0454, 0x0140, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__SRC_BOOT_CFG11, 0x0454, 0x0140, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__EIM_AD12, 0x0458, 0x0144, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU1_DI1_PIN03, 0x0458, 0x0144, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU2_CSI1_VSYNC, 0x0458, 0x0144, 2, 0x08E4, 1, 0) +MX6_PAD_DECL(EIM_DA12__GPIO3_IO12, 0x0458, 0x0144, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__SRC_BOOT_CFG12, 0x0458, 0x0144, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__EIM_AD13, 0x045C, 0x0148, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__IPU1_DI1_D0_CS, 0x045C, 0x0148, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__GPIO3_IO13, 0x045C, 0x0148, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__SRC_BOOT_CFG13, 0x045C, 0x0148, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__EIM_AD14, 0x0460, 0x014C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__IPU1_DI1_D1_CS, 0x0460, 0x014C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__GPIO3_IO14, 0x0460, 0x014C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__SRC_BOOT_CFG14, 0x0460, 0x014C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__EIM_AD15, 0x0464, 0x0150, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN01, 0x0464, 0x0150, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN04, 0x0464, 0x0150, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__GPIO3_IO15, 0x0464, 0x0150, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__SRC_BOOT_CFG15, 0x0464, 0x0150, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_WAIT_B, 0x0468, 0x0154, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_DTACK_B, 0x0468, 0x0154, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__GPIO5_IO00, 0x0468, 0x0154, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__SRC_BOOT_CFG25, 0x0468, 0x0154, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__EIM_BCLK, 0x046C, 0x0158, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__IPU1_DI1_PIN16, 0x046C, 0x0158, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__GPIO6_IO31, 0x046C, 0x0158, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__IPU1_DI0_DISP_CLK, 0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_DISP_CLK__IPU2_DI0_DISP_CLK, 0x0470, 0x015C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__GPIO4_IO16, 0x0470, 0x015C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__IPU1_DI0_PIN15, 0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN15__IPU2_DI0_PIN15, 0x0474, 0x0160, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__AUD6_TXC, 0x0474, 0x0160, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__GPIO4_IO17, 0x0474, 0x0160, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__IPU1_DI0_PIN02, 0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN2__IPU2_DI0_PIN02, 0x0478, 0x0164, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__AUD6_TXD, 0x0478, 0x0164, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__GPIO4_IO18, 0x0478, 0x0164, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__IPU1_DI0_PIN03, 0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN3__IPU2_DI0_PIN03, 0x047C, 0x0168, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__AUD6_TXFS, 0x047C, 0x0168, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__GPIO4_IO19, 0x047C, 0x0168, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__IPU1_DI0_PIN04, 0x0480, 0x016C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__IPU2_DI0_PIN04, 0x0480, 0x016C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__AUD6_RXD, 0x0480, 0x016C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__SD1_WP, 0x0480, 0x016C, 3, 0x094C, 0, 0) +MX6_PAD_DECL(DI0_PIN4__GPIO4_IO20, 0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT0__IPU1_DISP0_DATA00, 0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT0__IPU2_DISP0_DATA00, 0x0484, 0x0170, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__ECSPI3_SCLK, 0x0484, 0x0170, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__GPIO4_IO21, 0x0484, 0x0170, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__IPU1_DISP0_DATA01, 0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT1__IPU2_DISP0_DATA01, 0x0488, 0x0174, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__ECSPI3_MOSI, 0x0488, 0x0174, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__GPIO4_IO22, 0x0488, 0x0174, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__IPU1_DISP0_DATA02, 0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT2__IPU2_DISP0_DATA02, 0x048C, 0x0178, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__ECSPI3_MISO, 0x048C, 0x0178, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__GPIO4_IO23, 0x048C, 0x0178, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__IPU1_DISP0_DATA03, 0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT3__IPU2_DISP0_DATA03, 0x0490, 0x017C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__ECSPI3_SS0, 0x0490, 0x017C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__GPIO4_IO24, 0x0490, 0x017C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__IPU1_DISP0_DATA04, 0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT4__IPU2_DISP0_DATA04, 0x0494, 0x0180, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__ECSPI3_SS1, 0x0494, 0x0180, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__GPIO4_IO25, 0x0494, 0x0180, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__IPU1_DISP0_DATA05, 0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT5__IPU2_DISP0_DATA05, 0x0498, 0x0184, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__ECSPI3_SS2, 0x0498, 0x0184, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__AUD6_RXFS, 0x0498, 0x0184, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__GPIO4_IO26, 0x0498, 0x0184, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__IPU1_DISP0_DATA06, 0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT6__IPU2_DISP0_DATA06, 0x049C, 0x0188, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__ECSPI3_SS3, 0x049C, 0x0188, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__AUD6_RXC, 0x049C, 0x0188, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__GPIO4_IO27, 0x049C, 0x0188, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__IPU1_DISP0_DATA07, 0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT7__IPU2_DISP0_DATA07, 0x04A0, 0x018C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__ECSPI3_RDY, 0x04A0, 0x018C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__GPIO4_IO28, 0x04A0, 0x018C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__IPU1_DISP0_DATA08, 0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT8__IPU2_DISP0_DATA08, 0x04A4, 0x0190, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__PWM1_OUT, 0x04A4, 0x0190, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__WDOG1_B, 0x04A4, 0x0190, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__GPIO4_IO29, 0x04A4, 0x0190, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__IPU1_DISP0_DATA09, 0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT9__IPU2_DISP0_DATA09, 0x04A8, 0x0194, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__PWM2_OUT, 0x04A8, 0x0194, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__WDOG2_B, 0x04A8, 0x0194, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__GPIO4_IO30, 0x04A8, 0x0194, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT10__IPU1_DISP0_DATA10, 0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT10__IPU2_DISP0_DATA10, 0x04AC, 0x0198, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT10__GPIO4_IO31, 0x04AC, 0x0198, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__IPU1_DISP0_DATA11, 0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT11__IPU2_DISP0_DATA11, 0x04B0, 0x019C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__GPIO5_IO05, 0x04B0, 0x019C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__IPU1_DISP0_DATA12, 0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT12__IPU2_DISP0_DATA12, 0x04B4, 0x01A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__GPIO5_IO06, 0x04B4, 0x01A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__IPU1_DISP0_DATA13, 0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT13__IPU2_DISP0_DATA13, 0x04B8, 0x01A4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__AUD5_RXFS, 0x04B8, 0x01A4, 3, 0x07D8, 1, 0) +MX6_PAD_DECL(DISP0_DAT13__GPIO5_IO07, 0x04B8, 0x01A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__IPU1_DISP0_DATA14, 0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT14__IPU2_DISP0_DATA14, 0x04BC, 0x01A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__AUD5_RXC, 0x04BC, 0x01A8, 3, 0x07D4, 1, 0) +MX6_PAD_DECL(DISP0_DAT14__GPIO5_IO08, 0x04BC, 0x01A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__IPU1_DISP0_DATA15, 0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT15__IPU2_DISP0_DATA15, 0x04C0, 0x01AC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI1_SS1, 0x04C0, 0x01AC, 2, 0x0804, 1, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI2_SS1, 0x04C0, 0x01AC, 3, 0x0820, 1, 0) +MX6_PAD_DECL(DISP0_DAT15__GPIO5_IO09, 0x04C0, 0x01AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__IPU1_DISP0_DATA16, 0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT16__IPU2_DISP0_DATA16, 0x04C4, 0x01B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__ECSPI2_MOSI, 0x04C4, 0x01B0, 2, 0x0818, 1, 0) +MX6_PAD_DECL(DISP0_DAT16__AUD5_TXC, 0x04C4, 0x01B0, 3, 0x07DC, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__SDMA_EXT_EVENT0, 0x04C4, 0x01B0, 4, 0x090C, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__GPIO5_IO10, 0x04C4, 0x01B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__IPU1_DISP0_DATA17, 0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT17__IPU2_DISP0_DATA17, 0x04C8, 0x01B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__ECSPI2_MISO, 0x04C8, 0x01B4, 2, 0x0814, 1, 0) +MX6_PAD_DECL(DISP0_DAT17__AUD5_TXD, 0x04C8, 0x01B4, 3, 0x07D0, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__SDMA_EXT_EVENT1, 0x04C8, 0x01B4, 4, 0x0910, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__GPIO5_IO11, 0x04C8, 0x01B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__IPU1_DISP0_DATA18, 0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT18__IPU2_DISP0_DATA18, 0x04CC, 0x01B8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__ECSPI2_SS0, 0x04CC, 0x01B8, 2, 0x081C, 1, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD5_TXFS, 0x04CC, 0x01B8, 3, 0x07E0, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD4_RXFS, 0x04CC, 0x01B8, 4, 0x07C0, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__GPIO5_IO12, 0x04CC, 0x01B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__EIM_CS2_B, 0x04CC, 0x01B8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__IPU1_DISP0_DATA19, 0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT19__IPU2_DISP0_DATA19, 0x04D0, 0x01BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__ECSPI2_SCLK, 0x04D0, 0x01BC, 2, 0x0810, 1, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD5_RXD, 0x04D0, 0x01BC, 3, 0x07CC, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD4_RXC, 0x04D0, 0x01BC, 4, 0x07BC, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__GPIO5_IO13, 0x04D0, 0x01BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__EIM_CS3_B, 0x04D0, 0x01BC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__IPU1_DISP0_DATA20, 0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT20__IPU2_DISP0_DATA20, 0x04D4, 0x01C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__ECSPI1_SCLK, 0x04D4, 0x01C0, 2, 0x07F4, 1, 0) +MX6_PAD_DECL(DISP0_DAT20__AUD4_TXC, 0x04D4, 0x01C0, 3, 0x07C4, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__GPIO5_IO14, 0x04D4, 0x01C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__IPU1_DISP0_DATA21, 0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT21__IPU2_DISP0_DATA21, 0x04D8, 0x01C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__ECSPI1_MOSI, 0x04D8, 0x01C4, 2, 0x07FC, 1, 0) +MX6_PAD_DECL(DISP0_DAT21__AUD4_TXD, 0x04D8, 0x01C4, 3, 0x07B8, 1, 0) +MX6_PAD_DECL(DISP0_DAT21__GPIO5_IO15, 0x04D8, 0x01C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__IPU1_DISP0_DATA22, 0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT22__IPU2_DISP0_DATA22, 0x04DC, 0x01C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__ECSPI1_MISO, 0x04DC, 0x01C8, 2, 0x07F8, 1, 0) +MX6_PAD_DECL(DISP0_DAT22__AUD4_TXFS, 0x04DC, 0x01C8, 3, 0x07C8, 1, 0) +MX6_PAD_DECL(DISP0_DAT22__GPIO5_IO16, 0x04DC, 0x01C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__IPU1_DISP0_DATA23, 0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT23__IPU2_DISP0_DATA23, 0x04E0, 0x01CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__ECSPI1_SS0, 0x04E0, 0x01CC, 2, 0x0800, 1, 0) +MX6_PAD_DECL(DISP0_DAT23__AUD4_RXD, 0x04E0, 0x01CC, 3, 0x07B4, 1, 0) +MX6_PAD_DECL(DISP0_DAT23__GPIO5_IO17, 0x04E0, 0x01CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ENET_MDIO, 0x04E4, 0x01D0, 1, 0x0840, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ESAI_RX_CLK, 0x04E4, 0x01D0, 2, 0x086C, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ENET_1588_EVENT1_OUT, 0x04E4, 0x01D0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__GPIO1_IO22, 0x04E4, 0x01D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__SPDIF_LOCK, 0x04E4, 0x01D0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ENET_TX_CLK, 0x04E8, 0x01D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ESAI_RX_FS, 0x04E8, 0x01D4, 2, 0x085C, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__GPIO1_IO23, 0x04E8, 0x01D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__SPDIF_SR_CLK, 0x04E8, 0x01D4, 6, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__USB_OTG_ID, 0x04EC, 0x01D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__ENET_RX_ER, 0x04EC, 0x01D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__ESAI_RX_HF_CLK, 0x04EC, 0x01D8, 2, 0x0864, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__SPDIF_IN, 0x04EC, 0x01D8, 3, 0x0914, 1, 0) +MX6_PAD_DECL(ENET_RX_ER__ENET_1588_EVENT2_OUT, 0x04EC, 0x01D8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__GPIO1_IO24, 0x04EC, 0x01D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__ENET_RX_EN, 0x04F0, 0x01DC, 1, 0x0858, 1, 0) +MX6_PAD_DECL(ENET_CRS_DV__ESAI_TX_CLK, 0x04F0, 0x01DC, 2, 0x0870, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__SPDIF_EXT_CLK, 0x04F0, 0x01DC, 3, 0x0918, 1, 0) +MX6_PAD_DECL(ENET_CRS_DV__GPIO1_IO25, 0x04F0, 0x01DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD1__MLB_SIG, 0x04F4, 0x01E0, 0, 0x0908, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ENET_RX_DATA1, 0x04F4, 0x01E0, 1, 0x084C, 1, 0) +MX6_PAD_DECL(ENET_RXD1__ESAI_TX_FS, 0x04F4, 0x01E0, 2, 0x0860, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ENET_1588_EVENT3_OUT, 0x04F4, 0x01E0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD1__GPIO1_IO26, 0x04F4, 0x01E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__ENET_RX_DATA0, 0x04F8, 0x01E4, 1, 0x0848, 1, 0) +MX6_PAD_DECL(ENET_RXD0__ESAI_TX_HF_CLK, 0x04F8, 0x01E4, 2, 0x0868, 0, 0) +MX6_PAD_DECL(ENET_RXD0__SPDIF_OUT, 0x04F8, 0x01E4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__GPIO1_IO27, 0x04F8, 0x01E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ENET_TX_EN, 0x04FC, 0x01E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ESAI_TX3_RX2, 0x04FC, 0x01E8, 2, 0x0880, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__GPIO1_IO28, 0x04FC, 0x01E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__MLB_CLK, 0x0500, 0x01EC, 0, 0x0900, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ENET_TX_DATA1, 0x0500, 0x01EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ESAI_TX2_RX3, 0x0500, 0x01EC, 2, 0x087C, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ENET_1588_EVENT0_IN, 0x0500, 0x01EC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__GPIO1_IO29, 0x0500, 0x01EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ENET_TX_DATA0, 0x0504, 0x01F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ESAI_TX4_RX1, 0x0504, 0x01F0, 2, 0x0884, 0, 0) +MX6_PAD_DECL(ENET_TXD0__GPIO1_IO30, 0x0504, 0x01F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__MLB_DATA, 0x0508, 0x01F4, 0, 0x0904, 0, 0) +MX6_PAD_DECL(ENET_MDC__ENET_MDC, 0x0508, 0x01F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__ESAI_TX5_RX0, 0x0508, 0x01F4, 2, 0x0888, 0, 0) +MX6_PAD_DECL(ENET_MDC__ENET_1588_EVENT1_IN, 0x0508, 0x01F4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__GPIO1_IO31, 0x0508, 0x01F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__ECSPI1_SCLK, 0x05C8, 0x01F8, 0, 0x07F4, 2, 0) +MX6_PAD_DECL(KEY_COL0__ENET_RX_DATA3, 0x05C8, 0x01F8, 1, 0x0854, 1, 0) +MX6_PAD_DECL(KEY_COL0__AUD5_TXC, 0x05C8, 0x01F8, 2, 0x07DC, 1, 0) +MX6_PAD_DECL(KEY_COL0__KEY_COL0, 0x05C8, 0x01F8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_TX_DATA, 0x05C8, 0x01F8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_RX_DATA, 0x05C8, 0x01F8, 4, 0x0938, 0, 0) +MX6_PAD_DECL(KEY_COL0__GPIO4_IO06, 0x05C8, 0x01F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__DCIC1_OUT, 0x05C8, 0x01F8, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__ECSPI1_MOSI, 0x05CC, 0x01FC, 0, 0x07FC, 2, 0) +MX6_PAD_DECL(KEY_ROW0__ENET_TX_DATA3, 0x05CC, 0x01FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__AUD5_TXD, 0x05CC, 0x01FC, 2, 0x07D0, 1, 0) +MX6_PAD_DECL(KEY_ROW0__KEY_ROW0, 0x05CC, 0x01FC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_TX_DATA, 0x05CC, 0x01FC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_RX_DATA, 0x05CC, 0x01FC, 4, 0x0938, 1, 0) +MX6_PAD_DECL(KEY_ROW0__GPIO4_IO07, 0x05CC, 0x01FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__DCIC2_OUT, 0x05CC, 0x01FC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__ECSPI1_MISO, 0x05D0, 0x0200, 0, 0x07F8, 2, 0) +MX6_PAD_DECL(KEY_COL1__ENET_MDIO, 0x05D0, 0x0200, 1, 0x0840, 1, 0) +MX6_PAD_DECL(KEY_COL1__AUD5_TXFS, 0x05D0, 0x0200, 2, 0x07E0, 1, 0) +MX6_PAD_DECL(KEY_COL1__KEY_COL1, 0x05D0, 0x0200, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_TX_DATA, 0x05D0, 0x0200, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_RX_DATA, 0x05D0, 0x0200, 4, 0x0940, 0, 0) +MX6_PAD_DECL(KEY_COL1__GPIO4_IO08, 0x05D0, 0x0200, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__SD1_VSELECT, 0x05D0, 0x0200, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__ECSPI1_SS0, 0x05D4, 0x0204, 0, 0x0800, 2, 0) +MX6_PAD_DECL(KEY_ROW1__ENET_COL, 0x05D4, 0x0204, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__AUD5_RXD, 0x05D4, 0x0204, 2, 0x07CC, 1, 0) +MX6_PAD_DECL(KEY_ROW1__KEY_ROW1, 0x05D4, 0x0204, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_TX_DATA, 0x05D4, 0x0204, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_RX_DATA, 0x05D4, 0x0204, 4, 0x0940, 1, 0) +MX6_PAD_DECL(KEY_ROW1__GPIO4_IO09, 0x05D4, 0x0204, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__SD2_VSELECT, 0x05D4, 0x0204, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ECSPI1_SS1, 0x05D8, 0x0208, 0, 0x0804, 2, 0) +MX6_PAD_DECL(KEY_COL2__ENET_RX_DATA2, 0x05D8, 0x0208, 1, 0x0850, 1, 0) +MX6_PAD_DECL(KEY_COL2__FLEXCAN1_TX, 0x05D8, 0x0208, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__KEY_COL2, 0x05D8, 0x0208, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ENET_MDC, 0x05D8, 0x0208, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__GPIO4_IO10, 0x05D8, 0x0208, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__USB_H1_PWR_CTL_WAKE, 0x05D8, 0x0208, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__ECSPI1_SS2, 0x05DC, 0x020C, 0, 0x0808, 1, 0) +MX6_PAD_DECL(KEY_ROW2__ENET_TX_DATA2, 0x05DC, 0x020C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__FLEXCAN1_RX, 0x05DC, 0x020C, 2, 0x07E4, 0, 0) +MX6_PAD_DECL(KEY_ROW2__KEY_ROW2, 0x05DC, 0x020C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__SD2_VSELECT, 0x05DC, 0x020C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__GPIO4_IO11, 0x05DC, 0x020C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__HDMI_TX_CEC_LINE, 0x05DC, 0x020C, 6, 0x088C, 1, 0) +MX6_PAD_DECL(KEY_COL3__ECSPI1_SS3, 0x05E0, 0x0210, 0, 0x080C, 1, 0) +MX6_PAD_DECL(KEY_COL3__ENET_CRS, 0x05E0, 0x0210, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__HDMI_TX_DDC_SCL, 0x05E0, 0x0210, 2, 0x0890, 1, 0) +MX6_PAD_DECL(KEY_COL3__KEY_COL3, 0x05E0, 0x0210, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__I2C2_SCL, 0x05E0, 0x0210, 20, 0x08A0, 1, 0) +MX6_PAD_DECL(KEY_COL3__GPIO4_IO12, 0x05E0, 0x0210, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__SPDIF_IN, 0x05E0, 0x0210, 6, 0x0914, 2, 0) +MX6_PAD_DECL(KEY_ROW3__ASRC_EXT_CLK, 0x05E4, 0x0214, 1, 0x07B0, 0, 0) +MX6_PAD_DECL(KEY_ROW3__HDMI_TX_DDC_SDA, 0x05E4, 0x0214, 2, 0x0894, 1, 0) +MX6_PAD_DECL(KEY_ROW3__KEY_ROW3, 0x05E4, 0x0214, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__I2C2_SDA, 0x05E4, 0x0214, 20, 0x08A4, 1, 0) +MX6_PAD_DECL(KEY_ROW3__GPIO4_IO13, 0x05E4, 0x0214, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__SD1_VSELECT, 0x05E4, 0x0214, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__FLEXCAN2_TX, 0x05E8, 0x0218, 0, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__IPU1_SISG4, 0x05E8, 0x0218, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__USB_OTG_OC, 0x05E8, 0x0218, 2, 0x0944, 1, 0) +MX6_PAD_DECL(KEY_COL4__KEY_COL4, 0x05E8, 0x0218, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_CTS_B, 0x05E8, 0x0218, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_RTS_B, 0x05E8, 0x0218, 4, 0x093C, 0, 0) +MX6_PAD_DECL(KEY_COL4__GPIO4_IO14, 0x05E8, 0x0218, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__FLEXCAN2_RX, 0x05EC, 0x021C, 0, 0x07E8, 0, 0) +MX6_PAD_DECL(KEY_ROW4__IPU1_SISG5, 0x05EC, 0x021C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__USB_OTG_PWR, 0x05EC, 0x021C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__KEY_ROW4, 0x05EC, 0x021C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_CTS_B, 0x05EC, 0x021C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_RTS_B, 0x05EC, 0x021C, 4, 0x093C, 1, 0) +MX6_PAD_DECL(KEY_ROW4__GPIO4_IO15, 0x05EC, 0x021C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__CCM_CLKO1, 0x05F0, 0x0220, 0, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__KEY_COL5, 0x05F0, 0x0220, 2, 0x08E8, 0, 0) +MX6_PAD_DECL(GPIO_0__ASRC_EXT_CLK, 0x05F0, 0x0220, 3, 0x07B0, 1, 0) +MX6_PAD_DECL(GPIO_0__EPIT1_OUT, 0x05F0, 0x0220, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__GPIO1_IO00, 0x05F0, 0x0220, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__USB_H1_PWR, 0x05F0, 0x0220, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__SNVS_VIO_5, 0x05F0, 0x0220, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__ESAI_RX_CLK, 0x05F4, 0x0224, 0, 0x086C, 1, 0) +MX6_PAD_DECL(GPIO_1__WDOG2_B, 0x05F4, 0x0224, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__KEY_ROW5, 0x05F4, 0x0224, 2, 0x08F4, 0, 0) +MX6_PAD_DECL(GPIO_1__USB_OTG_ID, 0x05F4, 0x0224, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__PWM2_OUT, 0x05F4, 0x0224, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__GPIO1_IO01, 0x05F4, 0x0224, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__SD1_CD_B, 0x05F4, 0x0224, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__ESAI_RX_FS, 0x05F8, 0x0228, 0, 0x085C, 1, 0) +MX6_PAD_DECL(GPIO_9__WDOG1_B, 0x05F8, 0x0228, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__KEY_COL6, 0x05F8, 0x0228, 2, 0x08EC, 0, 0) +MX6_PAD_DECL(GPIO_9__CCM_REF_EN_B, 0x05F8, 0x0228, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__PWM1_OUT, 0x05F8, 0x0228, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__GPIO1_IO09, 0x05F8, 0x0228, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__SD1_WP, 0x05F8, 0x0228, 6, 0x094C, 1, 0) +MX6_PAD_DECL(GPIO_3__ESAI_RX_HF_CLK, 0x05FC, 0x022C, 0, 0x0864, 1, 0) +MX6_PAD_DECL(GPIO_3__I2C3_SCL, 0x05FC, 0x022C, 18, 0x08A8, 1, 0) +MX6_PAD_DECL(GPIO_3__XTALOSC_REF_CLK_24M, 0x05FC, 0x022C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__CCM_CLKO2, 0x05FC, 0x022C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__GPIO1_IO03, 0x05FC, 0x022C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__USB_H1_OC, 0x05FC, 0x022C, 6, 0x0948, 1, 0) +MX6_PAD_DECL(GPIO_3__MLB_CLK, 0x05FC, 0x022C, 7, 0x0900, 1, 0) +MX6_PAD_DECL(GPIO_6__ESAI_TX_CLK, 0x0600, 0x0230, 0, 0x0870, 1, 0) +MX6_PAD_DECL(GPIO_6__I2C3_SDA, 0x0600, 0x0230, 18, 0x08AC, 1, 0) +MX6_PAD_DECL(GPIO_6__GPIO1_IO06, 0x0600, 0x0230, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__SD2_LCTL, 0x0600, 0x0230, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__MLB_SIG, 0x0600, 0x0230, 7, 0x0908, 1, 0) +MX6_PAD_DECL(GPIO_2__ESAI_TX_FS, 0x0604, 0x0234, 0, 0x0860, 1, 0) +MX6_PAD_DECL(GPIO_2__KEY_ROW6, 0x0604, 0x0234, 2, 0x08F8, 1, 0) +MX6_PAD_DECL(GPIO_2__GPIO1_IO02, 0x0604, 0x0234, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__SD2_WP, 0x0604, 0x0234, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__MLB_DATA, 0x0604, 0x0234, 7, 0x0904, 1, 0) +MX6_PAD_DECL(GPIO_4__ESAI_TX_HF_CLK, 0x0608, 0x0238, 0, 0x0868, 1, 0) +MX6_PAD_DECL(GPIO_4__KEY_COL7, 0x0608, 0x0238, 2, 0x08F0, 1, 0) +MX6_PAD_DECL(GPIO_4__GPIO1_IO04, 0x0608, 0x0238, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_4__SD2_CD_B, 0x0608, 0x0238, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__ESAI_TX2_RX3, 0x060C, 0x023C, 0, 0x087C, 1, 0) +MX6_PAD_DECL(GPIO_5__KEY_ROW7, 0x060C, 0x023C, 2, 0x08FC, 1, 0) +MX6_PAD_DECL(GPIO_5__CCM_CLKO1, 0x060C, 0x023C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__GPIO1_IO05, 0x060C, 0x023C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__I2C3_SCL, 0x060C, 0x023C, 22, 0x08A8, 2, 0) +MX6_PAD_DECL(GPIO_5__ARM_EVENTI, 0x060C, 0x023C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__ESAI_TX4_RX1, 0x0610, 0x0240, 0, 0x0884, 1, 0) +MX6_PAD_DECL(GPIO_7__ECSPI5_RDY, 0x0610, 0x0240, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__EPIT1_OUT, 0x0610, 0x0240, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__FLEXCAN1_TX, 0x0610, 0x0240, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_TX_DATA, 0x0610, 0x0240, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_RX_DATA, 0x0610, 0x0240, 4, 0x0928, 2, 0) +MX6_PAD_DECL(GPIO_7__GPIO1_IO07, 0x0610, 0x0240, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__SPDIF_LOCK, 0x0610, 0x0240, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__USB_OTG_HOST_MODE, 0x0610, 0x0240, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__ESAI_TX5_RX0, 0x0614, 0x0244, 0, 0x0888, 1, 0) +MX6_PAD_DECL(GPIO_8__XTALOSC_REF_CLK_32K, 0x0614, 0x0244, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__EPIT2_OUT, 0x0614, 0x0244, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__FLEXCAN1_RX, 0x0614, 0x0244, 3, 0x07E4, 1, 0) +MX6_PAD_DECL(GPIO_8__UART2_TX_DATA, 0x0614, 0x0244, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__UART2_RX_DATA, 0x0614, 0x0244, 4, 0x0928, 3, 0) +MX6_PAD_DECL(GPIO_8__GPIO1_IO08, 0x0614, 0x0244, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__SPDIF_SR_CLK, 0x0614, 0x0244, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__USB_OTG_PWR_CTL_WAKE, 0x0614, 0x0244, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__ESAI_TX3_RX2, 0x0618, 0x0248, 0, 0x0880, 1, 0) +MX6_PAD_DECL(GPIO_16__ENET_1588_EVENT2_IN, 0x0618, 0x0248, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__ENET_REF_CLK, 0x0618, 0x0248, 2, 0x083C, 1, 0) +MX6_PAD_DECL(GPIO_16__SD1_LCTL, 0x0618, 0x0248, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__SPDIF_IN, 0x0618, 0x0248, 4, 0x0914, 3, 0) +MX6_PAD_DECL(GPIO_16__GPIO7_IO11, 0x0618, 0x0248, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__I2C3_SDA, 0x0618, 0x0248, 22, 0x08AC, 2, 0) +MX6_PAD_DECL(GPIO_16__JTAG_DE_B, 0x0618, 0x0248, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__ESAI_TX0, 0x061C, 0x024C, 0, 0x0874, 0, 0) +MX6_PAD_DECL(GPIO_17__ENET_1588_EVENT3_IN, 0x061C, 0x024C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__CCM_PMIC_READY, 0x061C, 0x024C, 2, 0x07F0, 1, 0) +MX6_PAD_DECL(GPIO_17__SDMA_EXT_EVENT0, 0x061C, 0x024C, 3, 0x090C, 1, 0) +MX6_PAD_DECL(GPIO_17__SPDIF_OUT, 0x061C, 0x024C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__GPIO7_IO12, 0x061C, 0x024C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__ESAI_TX1, 0x0620, 0x0250, 0, 0x0878, 0, 0) +MX6_PAD_DECL(GPIO_18__ENET_RX_CLK, 0x0620, 0x0250, 1, 0x0844, 1, 0) +MX6_PAD_DECL(GPIO_18__SD3_VSELECT, 0x0620, 0x0250, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SDMA_EXT_EVENT1, 0x0620, 0x0250, 3, 0x0910, 1, 0) +MX6_PAD_DECL(GPIO_18__ASRC_EXT_CLK, 0x0620, 0x0250, 4, 0x07B0, 2, 0) +MX6_PAD_DECL(GPIO_18__GPIO7_IO13, 0x0620, 0x0250, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SNVS_VIO_5_CTL, 0x0620, 0x0250, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__KEY_COL5, 0x0624, 0x0254, 0, 0x08E8, 1, 0) +MX6_PAD_DECL(GPIO_19__ENET_1588_EVENT0_OUT, 0x0624, 0x0254, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__SPDIF_OUT, 0x0624, 0x0254, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__CCM_CLKO1, 0x0624, 0x0254, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ECSPI1_RDY, 0x0624, 0x0254, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__GPIO4_IO05, 0x0624, 0x0254, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ENET_TX_ER, 0x0624, 0x0254, 6, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__IPU1_CSI0_PIXCLK, 0x0628, 0x0258, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__GPIO5_IO18, 0x0628, 0x0258, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__ARM_EVENTO, 0x0628, 0x0258, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__IPU1_CSI0_HSYNC, 0x062C, 0x025C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__CCM_CLKO1, 0x062C, 0x025C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__GPIO5_IO19, 0x062C, 0x025C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__ARM_TRACE_CTL, 0x062C, 0x025C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__IPU1_CSI0_DATA_EN, 0x0630, 0x0260, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__EIM_DATA00, 0x0630, 0x0260, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__GPIO5_IO20, 0x0630, 0x0260, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__ARM_TRACE_CLK, 0x0630, 0x0260, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__IPU1_CSI0_VSYNC, 0x0634, 0x0264, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__EIM_DATA01, 0x0634, 0x0264, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__GPIO5_IO21, 0x0634, 0x0264, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__ARM_TRACE00, 0x0634, 0x0264, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__IPU1_CSI0_DATA04, 0x0638, 0x0268, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__EIM_DATA02, 0x0638, 0x0268, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ECSPI1_SCLK, 0x0638, 0x0268, 2, 0x07F4, 3, 0) +MX6_PAD_DECL(CSI0_DAT4__KEY_COL5, 0x0638, 0x0268, 3, 0x08E8, 2, 0) +MX6_PAD_DECL(CSI0_DAT4__AUD3_TXC, 0x0638, 0x0268, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__GPIO5_IO22, 0x0638, 0x0268, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ARM_TRACE01, 0x0638, 0x0268, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__IPU1_CSI0_DATA05, 0x063C, 0x026C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__EIM_DATA03, 0x063C, 0x026C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ECSPI1_MOSI, 0x063C, 0x026C, 2, 0x07FC, 3, 0) +MX6_PAD_DECL(CSI0_DAT5__KEY_ROW5, 0x063C, 0x026C, 3, 0x08F4, 1, 0) +MX6_PAD_DECL(CSI0_DAT5__AUD3_TXD, 0x063C, 0x026C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__GPIO5_IO23, 0x063C, 0x026C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ARM_TRACE02, 0x063C, 0x026C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__IPU1_CSI0_DATA06, 0x0640, 0x0270, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__EIM_DATA04, 0x0640, 0x0270, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ECSPI1_MISO, 0x0640, 0x0270, 2, 0x07F8, 3, 0) +MX6_PAD_DECL(CSI0_DAT6__KEY_COL6, 0x0640, 0x0270, 3, 0x08EC, 1, 0) +MX6_PAD_DECL(CSI0_DAT6__AUD3_TXFS, 0x0640, 0x0270, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__GPIO5_IO24, 0x0640, 0x0270, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ARM_TRACE03, 0x0640, 0x0270, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__IPU1_CSI0_DATA07, 0x0644, 0x0274, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__EIM_DATA05, 0x0644, 0x0274, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ECSPI1_SS0, 0x0644, 0x0274, 2, 0x0800, 3, 0) +MX6_PAD_DECL(CSI0_DAT7__KEY_ROW6, 0x0644, 0x0274, 3, 0x08F8, 2, 0) +MX6_PAD_DECL(CSI0_DAT7__AUD3_RXD, 0x0644, 0x0274, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__GPIO5_IO25, 0x0644, 0x0274, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ARM_TRACE04, 0x0644, 0x0274, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__IPU1_CSI0_DATA08, 0x0648, 0x0278, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__EIM_DATA06, 0x0648, 0x0278, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ECSPI2_SCLK, 0x0648, 0x0278, 2, 0x0810, 2, 0) +MX6_PAD_DECL(CSI0_DAT8__KEY_COL7, 0x0648, 0x0278, 3, 0x08F0, 2, 0) +MX6_PAD_DECL(CSI0_DAT8__I2C1_SDA, 0x0648, 0x0278, 20, 0x089C, 1, 0) +MX6_PAD_DECL(CSI0_DAT8__GPIO5_IO26, 0x0648, 0x0278, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ARM_TRACE05, 0x0648, 0x0278, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__IPU1_CSI0_DATA09, 0x064C, 0x027C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__EIM_DATA07, 0x064C, 0x027C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ECSPI2_MOSI, 0x064C, 0x027C, 2, 0x0818, 2, 0) +MX6_PAD_DECL(CSI0_DAT9__KEY_ROW7, 0x064C, 0x027C, 3, 0x08FC, 2, 0) +MX6_PAD_DECL(CSI0_DAT9__I2C1_SCL, 0x064C, 0x027C, 20, 0x0898, 1, 0) +MX6_PAD_DECL(CSI0_DAT9__GPIO5_IO27, 0x064C, 0x027C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ARM_TRACE06, 0x064C, 0x027C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__IPU1_CSI0_DATA10, 0x0650, 0x0280, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__AUD3_RXC, 0x0650, 0x0280, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ECSPI2_MISO, 0x0650, 0x0280, 2, 0x0814, 2, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_TX_DATA, 0x0650, 0x0280, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_RX_DATA, 0x0650, 0x0280, 3, 0x0920, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__GPIO5_IO28, 0x0650, 0x0280, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ARM_TRACE07, 0x0650, 0x0280, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__IPU1_CSI0_DATA11, 0x0654, 0x0284, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__AUD3_RXFS, 0x0654, 0x0284, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ECSPI2_SS0, 0x0654, 0x0284, 2, 0x081C, 2, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_TX_DATA, 0x0654, 0x0284, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_RX_DATA, 0x0654, 0x0284, 3, 0x0920, 1, 0) +MX6_PAD_DECL(CSI0_DAT11__GPIO5_IO29, 0x0654, 0x0284, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ARM_TRACE08, 0x0654, 0x0284, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__IPU1_CSI0_DATA12, 0x0658, 0x0288, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__EIM_DATA08, 0x0658, 0x0288, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_TX_DATA, 0x0658, 0x0288, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_RX_DATA, 0x0658, 0x0288, 3, 0x0938, 2, 0) +MX6_PAD_DECL(CSI0_DAT12__GPIO5_IO30, 0x0658, 0x0288, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__ARM_TRACE09, 0x0658, 0x0288, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__IPU1_CSI0_DATA13, 0x065C, 0x028C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__EIM_DATA09, 0x065C, 0x028C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_TX_DATA, 0x065C, 0x028C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_RX_DATA, 0x065C, 0x028C, 3, 0x0938, 3, 0) +MX6_PAD_DECL(CSI0_DAT13__GPIO5_IO31, 0x065C, 0x028C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__ARM_TRACE10, 0x065C, 0x028C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__IPU1_CSI0_DATA14, 0x0660, 0x0290, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__EIM_DATA10, 0x0660, 0x0290, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_TX_DATA, 0x0660, 0x0290, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_RX_DATA, 0x0660, 0x0290, 3, 0x0940, 2, 0) +MX6_PAD_DECL(CSI0_DAT14__GPIO6_IO00, 0x0660, 0x0290, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__ARM_TRACE11, 0x0660, 0x0290, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__IPU1_CSI0_DATA15, 0x0664, 0x0294, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__EIM_DATA11, 0x0664, 0x0294, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_TX_DATA, 0x0664, 0x0294, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_RX_DATA, 0x0664, 0x0294, 3, 0x0940, 3, 0) +MX6_PAD_DECL(CSI0_DAT15__GPIO6_IO01, 0x0664, 0x0294, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__ARM_TRACE12, 0x0664, 0x0294, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__IPU1_CSI0_DATA16, 0x0668, 0x0298, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__EIM_DATA12, 0x0668, 0x0298, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_CTS_B, 0x0668, 0x0298, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_RTS_B, 0x0668, 0x0298, 3, 0x0934, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__GPIO6_IO02, 0x0668, 0x0298, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__ARM_TRACE13, 0x0668, 0x0298, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__IPU1_CSI0_DATA17, 0x066C, 0x029C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__EIM_DATA13, 0x066C, 0x029C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_CTS_B, 0x066C, 0x029C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_RTS_B, 0x066C, 0x029C, 3, 0x0934, 1, 0) +MX6_PAD_DECL(CSI0_DAT17__GPIO6_IO03, 0x066C, 0x029C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__ARM_TRACE14, 0x066C, 0x029C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__IPU1_CSI0_DATA18, 0x0670, 0x02A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__EIM_DATA14, 0x0670, 0x02A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_CTS_B, 0x0670, 0x02A0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_RTS_B, 0x0670, 0x02A0, 3, 0x093C, 2, 0) +MX6_PAD_DECL(CSI0_DAT18__GPIO6_IO04, 0x0670, 0x02A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__ARM_TRACE15, 0x0670, 0x02A0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__IPU1_CSI0_DATA19, 0x0674, 0x02A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__EIM_DATA15, 0x0674, 0x02A4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_CTS_B, 0x0674, 0x02A4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_RTS_B, 0x0674, 0x02A4, 3, 0x093C, 3, 0) +MX6_PAD_DECL(CSI0_DAT19__GPIO6_IO05, 0x0674, 0x02A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__SD3_DATA7, 0x0690, 0x02A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_TX_DATA, 0x0690, 0x02A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_RX_DATA, 0x0690, 0x02A8, 1, 0x0920, 2, 0) +MX6_PAD_DECL(SD3_DAT7__GPIO6_IO17, 0x0690, 0x02A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__SD3_DATA6, 0x0694, 0x02AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_TX_DATA, 0x0694, 0x02AC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_RX_DATA, 0x0694, 0x02AC, 1, 0x0920, 3, 0) +MX6_PAD_DECL(SD3_DAT6__GPIO6_IO18, 0x0694, 0x02AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__SD3_DATA5, 0x0698, 0x02B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_TX_DATA, 0x0698, 0x02B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_RX_DATA, 0x0698, 0x02B0, 1, 0x0928, 4, 0) +MX6_PAD_DECL(SD3_DAT5__GPIO7_IO00, 0x0698, 0x02B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__SD3_DATA4, 0x069C, 0x02B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_TX_DATA, 0x069C, 0x02B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_RX_DATA, 0x069C, 0x02B4, 1, 0x0928, 5, 0) +MX6_PAD_DECL(SD3_DAT4__GPIO7_IO01, 0x069C, 0x02B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__SD3_CMD, 0x06A0, 0x02B8, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_CTS_B, 0x06A0, 0x02B8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_RTS_B, 0x06A0, 0x02B8, 1, 0x0924, 2, 0) +MX6_PAD_DECL(SD3_CMD__FLEXCAN1_TX, 0x06A0, 0x02B8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__GPIO7_IO02, 0x06A0, 0x02B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__SD3_CLK, 0x06A4, 0x02BC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__UART2_CTS_B, 0x06A4, 0x02BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__UART2_RTS_B, 0x06A4, 0x02BC, 1, 0x0924, 3, 0) +MX6_PAD_DECL(SD3_CLK__FLEXCAN1_RX, 0x06A4, 0x02BC, 2, 0x07E4, 2, 0) +MX6_PAD_DECL(SD3_CLK__GPIO7_IO03, 0x06A4, 0x02BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__SD3_DATA0, 0x06A8, 0x02C0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_CTS_B, 0x06A8, 0x02C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_RTS_B, 0x06A8, 0x02C0, 1, 0x091C, 2, 0) +MX6_PAD_DECL(SD3_DAT0__FLEXCAN2_TX, 0x06A8, 0x02C0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__GPIO7_IO04, 0x06A8, 0x02C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__SD3_DATA1, 0x06AC, 0x02C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_CTS_B, 0x06AC, 0x02C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_RTS_B, 0x06AC, 0x02C4, 1, 0x091C, 3, 0) +MX6_PAD_DECL(SD3_DAT1__FLEXCAN2_RX, 0x06AC, 0x02C4, 2, 0x07E8, 1, 0) +MX6_PAD_DECL(SD3_DAT1__GPIO7_IO05, 0x06AC, 0x02C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__SD3_DATA2, 0x06B0, 0x02C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__GPIO7_IO06, 0x06B0, 0x02C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__SD3_DATA3, 0x06B4, 0x02CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_CTS_B, 0x06B4, 0x02CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_RTS_B, 0x06B4, 0x02CC, 1, 0x092C, 4, 0) +MX6_PAD_DECL(SD3_DAT3__GPIO7_IO07, 0x06B4, 0x02CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__SD3_RESET, 0x06B8, 0x02D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_CTS_B, 0x06B8, 0x02D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_RTS_B, 0x06B8, 0x02D0, 1, 0x092C, 5, 0) +MX6_PAD_DECL(SD3_RST__GPIO7_IO08, 0x06B8, 0x02D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__NAND_CLE, 0x06BC, 0x02D4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__IPU2_SISG4, 0x06BC, 0x02D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__GPIO6_IO07, 0x06BC, 0x02D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__NAND_ALE, 0x06C0, 0x02D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__SD4_RESET, 0x06C0, 0x02D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__GPIO6_IO08, 0x06C0, 0x02D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__NAND_WP_B, 0x06C4, 0x02DC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__IPU2_SISG5, 0x06C4, 0x02DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__GPIO6_IO09, 0x06C4, 0x02DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__NAND_READY_B, 0x06C8, 0x02E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__IPU2_DI0_PIN01, 0x06C8, 0x02E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__GPIO6_IO10, 0x06C8, 0x02E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__NAND_CE0_B, 0x06CC, 0x02E4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__GPIO6_IO11, 0x06CC, 0x02E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__NAND_CE1_B, 0x06D0, 0x02E8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD4_VSELECT, 0x06D0, 0x02E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD3_VSELECT, 0x06D0, 0x02E8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__GPIO6_IO14, 0x06D0, 0x02E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__NAND_CE2_B, 0x06D4, 0x02EC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__IPU1_SISG0, 0x06D4, 0x02EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__ESAI_TX0, 0x06D4, 0x02EC, 2, 0x0874, 1, 0) +MX6_PAD_DECL(NANDF_CS2__EIM_CRE, 0x06D4, 0x02EC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__CCM_CLKO2, 0x06D4, 0x02EC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__GPIO6_IO15, 0x06D4, 0x02EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__IPU2_SISG0, 0x06D4, 0x02EC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__NAND_CE3_B, 0x06D8, 0x02F0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__IPU1_SISG1, 0x06D8, 0x02F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__ESAI_TX1, 0x06D8, 0x02F0, 2, 0x0878, 1, 0) +MX6_PAD_DECL(NANDF_CS3__EIM_ADDR26, 0x06D8, 0x02F0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__GPIO6_IO16, 0x06D8, 0x02F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__IPU2_SISG1, 0x06D8, 0x02F0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__SD4_CMD, 0x06DC, 0x02F4, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__NAND_RE_B, 0x06DC, 0x02F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_TX_DATA, 0x06DC, 0x02F4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_RX_DATA, 0x06DC, 0x02F4, 2, 0x0930, 2, 0) +MX6_PAD_DECL(SD4_CMD__GPIO7_IO09, 0x06DC, 0x02F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__SD4_CLK, 0x06E0, 0x02F8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__NAND_WE_B, 0x06E0, 0x02F8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_TX_DATA, 0x06E0, 0x02F8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_RX_DATA, 0x06E0, 0x02F8, 2, 0x0930, 3, 0) +MX6_PAD_DECL(SD4_CLK__GPIO7_IO10, 0x06E0, 0x02F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__NAND_DATA00, 0x06E4, 0x02FC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__SD1_DATA4, 0x06E4, 0x02FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__GPIO2_IO00, 0x06E4, 0x02FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__NAND_DATA01, 0x06E8, 0x0300, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__SD1_DATA5, 0x06E8, 0x0300, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__GPIO2_IO01, 0x06E8, 0x0300, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__NAND_DATA02, 0x06EC, 0x0304, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__SD1_DATA6, 0x06EC, 0x0304, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__GPIO2_IO02, 0x06EC, 0x0304, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__NAND_DATA03, 0x06F0, 0x0308, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__SD1_DATA7, 0x06F0, 0x0308, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__GPIO2_IO03, 0x06F0, 0x0308, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__NAND_DATA04, 0x06F4, 0x030C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__SD2_DATA4, 0x06F4, 0x030C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__GPIO2_IO04, 0x06F4, 0x030C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__NAND_DATA05, 0x06F8, 0x0310, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__SD2_DATA5, 0x06F8, 0x0310, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__GPIO2_IO05, 0x06F8, 0x0310, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__NAND_DATA06, 0x06FC, 0x0314, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__SD2_DATA6, 0x06FC, 0x0314, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__GPIO2_IO06, 0x06FC, 0x0314, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__NAND_DATA07, 0x0700, 0x0318, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__SD2_DATA7, 0x0700, 0x0318, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__GPIO2_IO07, 0x0700, 0x0318, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__SD4_DATA0, 0x0704, 0x031C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__NAND_DQS, 0x0704, 0x031C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__GPIO2_IO08, 0x0704, 0x031C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__SD4_DATA1, 0x0708, 0x0320, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__PWM3_OUT, 0x0708, 0x0320, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__GPIO2_IO09, 0x0708, 0x0320, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__SD4_DATA2, 0x070C, 0x0324, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__PWM4_OUT, 0x070C, 0x0324, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__GPIO2_IO10, 0x070C, 0x0324, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__SD4_DATA3, 0x0710, 0x0328, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__GPIO2_IO11, 0x0710, 0x0328, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__SD4_DATA4, 0x0714, 0x032C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_TX_DATA, 0x0714, 0x032C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_RX_DATA, 0x0714, 0x032C, 2, 0x0928, 6, 0) +MX6_PAD_DECL(SD4_DAT4__GPIO2_IO12, 0x0714, 0x032C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__SD4_DATA5, 0x0718, 0x0330, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_CTS_B, 0x0718, 0x0330, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_RTS_B, 0x0718, 0x0330, 2, 0x0924, 4, 0) +MX6_PAD_DECL(SD4_DAT5__GPIO2_IO13, 0x0718, 0x0330, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__SD4_DATA6, 0x071C, 0x0334, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_CTS_B, 0x071C, 0x0334, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_RTS_B, 0x071C, 0x0334, 2, 0x0924, 5, 0) +MX6_PAD_DECL(SD4_DAT6__GPIO2_IO14, 0x071C, 0x0334, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__SD4_DATA7, 0x0720, 0x0338, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_TX_DATA, 0x0720, 0x0338, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_RX_DATA, 0x0720, 0x0338, 2, 0x0928, 7, 0) +MX6_PAD_DECL(SD4_DAT7__GPIO2_IO15, 0x0720, 0x0338, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__SD1_DATA1, 0x0724, 0x033C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__ECSPI5_SS0, 0x0724, 0x033C, 1, 0x0834, 1, 0) +MX6_PAD_DECL(SD1_DAT1__PWM3_OUT, 0x0724, 0x033C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPT_CAPTURE2, 0x0724, 0x033C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPIO1_IO17, 0x0724, 0x033C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__SD1_DATA0, 0x0728, 0x0340, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__ECSPI5_MISO, 0x0728, 0x0340, 1, 0x082C, 1, 0) +MX6_PAD_DECL(SD1_DAT0__GPT_CAPTURE1, 0x0728, 0x0340, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__GPIO1_IO16, 0x0728, 0x0340, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__SD1_DATA3, 0x072C, 0x0344, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__ECSPI5_SS2, 0x072C, 0x0344, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPT_COMPARE3, 0x072C, 0x0344, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__PWM1_OUT, 0x072C, 0x0344, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__WDOG2_B, 0x072C, 0x0344, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPIO1_IO21, 0x072C, 0x0344, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__WDOG2_RESET_B_DEB, 0x072C, 0x0344, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__SD1_CMD, 0x0730, 0x0348, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__ECSPI5_MOSI, 0x0730, 0x0348, 1, 0x0830, 0, 0) +MX6_PAD_DECL(SD1_CMD__PWM4_OUT, 0x0730, 0x0348, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPT_COMPARE1, 0x0730, 0x0348, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPIO1_IO18, 0x0730, 0x0348, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__SD1_DATA2, 0x0734, 0x034C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__ECSPI5_SS1, 0x0734, 0x034C, 1, 0x0838, 1, 0) +MX6_PAD_DECL(SD1_DAT2__GPT_COMPARE2, 0x0734, 0x034C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__PWM2_OUT, 0x0734, 0x034C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__WDOG1_B, 0x0734, 0x034C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__GPIO1_IO19, 0x0734, 0x034C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__WDOG1_RESET_B_DEB, 0x0734, 0x034C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__SD1_CLK, 0x0738, 0x0350, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__ECSPI5_SCLK, 0x0738, 0x0350, 1, 0x0828, 0, 0) +MX6_PAD_DECL(SD1_CLK__GPT_CLKIN, 0x0738, 0x0350, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__GPIO1_IO20, 0x0738, 0x0350, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CLK__SD2_CLK, 0x073C, 0x0354, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CLK__ECSPI5_SCLK, 0x073C, 0x0354, 1, 0x0828, 1, 0) +MX6_PAD_DECL(SD2_CLK__KEY_COL5, 0x073C, 0x0354, 2, 0x08E8, 3, 0) +MX6_PAD_DECL(SD2_CLK__AUD4_RXFS, 0x073C, 0x0354, 3, 0x07C0, 1, 0) +MX6_PAD_DECL(SD2_CLK__GPIO1_IO10, 0x073C, 0x0354, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__SD2_CMD, 0x0740, 0x0358, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__ECSPI5_MOSI, 0x0740, 0x0358, 1, 0x0830, 1, 0) +MX6_PAD_DECL(SD2_CMD__KEY_ROW5, 0x0740, 0x0358, 2, 0x08F4, 2, 0) +MX6_PAD_DECL(SD2_CMD__AUD4_RXC, 0x0740, 0x0358, 3, 0x07BC, 1, 0) +MX6_PAD_DECL(SD2_CMD__GPIO1_IO11, 0x0740, 0x0358, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__SD2_DATA3, 0x0744, 0x035C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__ECSPI5_SS3, 0x0744, 0x035C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__KEY_COL6, 0x0744, 0x035C, 2, 0x08EC, 2, 0) +MX6_PAD_DECL(SD2_DAT3__AUD4_TXC, 0x0744, 0x035C, 3, 0x07C4, 1, 0) +MX6_PAD_DECL(SD2_DAT3__GPIO1_IO12, 0x0744, 0x035C, 5, 0x0000, 0, 0) #endif /* __ASM_ARCH_MX6_MX6Q_PINS_H__ */ diff --git a/board/barco/titanium/titanium.c b/board/barco/titanium/titanium.c index c3775ef..6db4488 100644 --- a/board/barco/titanium/titanium.c +++ b/board/barco/titanium/titanium.c @@ -9,7 +9,7 @@ #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> -#include <asm/arch/mx6q_pins.h> +#include <asm/arch/mx6-pins.h> #include <asm/arch/crm_regs.h> #include <asm/arch/sys_proto.h> #include <asm/gpio.h> diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index 1b4791c..e063407 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -7,7 +7,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> -#include <asm/arch/mx6q_pins.h> +#include <asm/arch/mx6-pins.h> #include <asm/arch/clock.h> #include <asm/errno.h> #include <asm/gpio.h> diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index 1cf649c..fc75eae 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -11,7 +11,7 @@ #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> -#include <asm/arch/mx6q_pins.h> +#include <asm/arch/mx6-pins.h> #include <asm/errno.h> #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h>
Hi Eric,
On 14/11/2013 00:36, Eric Nelson wrote:
This allows the use of either or both declarations from the files mx6q_pins.h and mx6dl_pins.h.
All board files should include <asm/arch/mx6-pins.h> with one of the following defined in boards.cfg MX6Q - for boards targeting i.MX6Q or i.MX6D MX6DL - for boards targeting i.MX6DL MX6S - for boards targeting i.MX6S MX6QDL - for boards that support any of the above with run-time detection
Pad declarations will be MX6_PAD_x for single-variant boards and MX6Q_PAD_x and MX6DL_PAD_x for boards supporting both processor classes.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com
Thanks Eric, this is the way we have already discussed how to set the pinmux at runtime.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Applied to u-boot-imx, sorry for delay.
Align columns and add column headers to improve readability.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 1942 ++++++++++++++-------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 1803 +++++++++++++------------- 2 files changed, 1876 insertions(+), 1869 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 9b132a2..09fd54f 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -6,1073 +6,1077 @@
#ifndef __ASM_ARCH_MX6_MX6DL_PINS_H__ #define __ASM_ARCH_MX6_MX6DL_PINS_H__ + +/* Pad name pad mux mux inp inp pad + * offs offs mode offs sel ctrl + */ MX6_PAD_DECL(CSI0_DAT10__IPU1_CSI0_DATA10, 0x0360, 0x004C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__AUD3_RXC, 0x0360, 0x004C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__ECSPI2_MISO, 0x0360, 0x004C, 2, 0x07F8, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__UART1_TX_DATA, 0x0360, 0x004C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__UART1_RX_DATA, 0x0360, 0x004C, 3, 0x08FC, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__GPIO5_IO28, 0x0360, 0x004C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__ARM_TRACE07, 0x0360, 0x004C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__AUD3_RXC, 0x0360, 0x004C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ECSPI2_MISO, 0x0360, 0x004C, 2, 0x07F8, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_TX_DATA, 0x0360, 0x004C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_RX_DATA, 0x0360, 0x004C, 3, 0x08FC, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__GPIO5_IO28, 0x0360, 0x004C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ARM_TRACE07, 0x0360, 0x004C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT11__IPU1_CSI0_DATA11, 0x0364, 0x0050, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__AUD3_RXFS, 0x0364, 0x0050, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__ECSPI2_SS0, 0x0364, 0x0050, 2, 0x0800, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__UART1_TX_DATA, 0x0364, 0x0050, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__UART1_RX_DATA, 0x0364, 0x0050, 3, 0x08FC, 1, 0) -MX6_PAD_DECL(CSI0_DAT11__GPIO5_IO29, 0x0364, 0x0050, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__ARM_TRACE08, 0x0364, 0x0050, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__AUD3_RXFS, 0x0364, 0x0050, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ECSPI2_SS0, 0x0364, 0x0050, 2, 0x0800, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_TX_DATA, 0x0364, 0x0050, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_RX_DATA, 0x0364, 0x0050, 3, 0x08FC, 1, 0) +MX6_PAD_DECL(CSI0_DAT11__GPIO5_IO29, 0x0364, 0x0050, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ARM_TRACE08, 0x0364, 0x0050, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT12__IPU1_CSI0_DATA12, 0x0368, 0x0054, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__EIM_DATA08, 0x0368, 0x0054, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__UART4_TX_DATA, 0x0368, 0x0054, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__UART4_RX_DATA, 0x0368, 0x0054, 3, 0x0914, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__GPIO5_IO30, 0x0368, 0x0054, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__ARM_TRACE09, 0x0368, 0x0054, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__EIM_DATA08, 0x0368, 0x0054, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_TX_DATA, 0x0368, 0x0054, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_RX_DATA, 0x0368, 0x0054, 3, 0x0914, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__GPIO5_IO30, 0x0368, 0x0054, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__ARM_TRACE09, 0x0368, 0x0054, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT13__IPU1_CSI0_DATA13, 0x036C, 0x0058, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__EIM_DATA09, 0x036C, 0x0058, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__UART4_TX_DATA, 0x036C, 0x0058, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__UART4_RX_DATA, 0x036C, 0x0058, 3, 0x0914, 1, 0) -MX6_PAD_DECL(CSI0_DAT13__GPIO5_IO31, 0x036C, 0x0058, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__ARM_TRACE10, 0x036C, 0x0058, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__EIM_DATA09, 0x036C, 0x0058, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_TX_DATA, 0x036C, 0x0058, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_RX_DATA, 0x036C, 0x0058, 3, 0x0914, 1, 0) +MX6_PAD_DECL(CSI0_DAT13__GPIO5_IO31, 0x036C, 0x0058, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__ARM_TRACE10, 0x036C, 0x0058, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT14__IPU1_CSI0_DATA14, 0x0370, 0x005C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__EIM_DATA10, 0x0370, 0x005C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__UART5_TX_DATA, 0x0370, 0x005C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__UART5_RX_DATA, 0x0370, 0x005C, 3, 0x091C, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__GPIO6_IO00, 0x0370, 0x005C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__ARM_TRACE11, 0x0370, 0x005C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__EIM_DATA10, 0x0370, 0x005C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_TX_DATA, 0x0370, 0x005C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_RX_DATA, 0x0370, 0x005C, 3, 0x091C, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__GPIO6_IO00, 0x0370, 0x005C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__ARM_TRACE11, 0x0370, 0x005C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT15__IPU1_CSI0_DATA15, 0x0374, 0x0060, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__EIM_DATA11, 0x0374, 0x0060, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__UART5_TX_DATA, 0x0374, 0x0060, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__UART5_RX_DATA, 0x0374, 0x0060, 3, 0x091C, 1, 0) -MX6_PAD_DECL(CSI0_DAT15__GPIO6_IO01, 0x0374, 0x0060, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__ARM_TRACE12, 0x0374, 0x0060, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__EIM_DATA11, 0x0374, 0x0060, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_TX_DATA, 0x0374, 0x0060, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_RX_DATA, 0x0374, 0x0060, 3, 0x091C, 1, 0) +MX6_PAD_DECL(CSI0_DAT15__GPIO6_IO01, 0x0374, 0x0060, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__ARM_TRACE12, 0x0374, 0x0060, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT16__IPU1_CSI0_DATA16, 0x0378, 0x0064, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__EIM_DATA12, 0x0378, 0x0064, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__UART4_CTS_B, 0x0378, 0x0064, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__UART4_RTS_B, 0x0378, 0x0064, 3, 0x0910, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__GPIO6_IO02, 0x0378, 0x0064, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__ARM_TRACE13, 0x0378, 0x0064, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__EIM_DATA12, 0x0378, 0x0064, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_CTS_B, 0x0378, 0x0064, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_RTS_B, 0x0378, 0x0064, 3, 0x0910, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__GPIO6_IO02, 0x0378, 0x0064, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__ARM_TRACE13, 0x0378, 0x0064, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT17__IPU1_CSI0_DATA17, 0x037C, 0x0068, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__EIM_DATA13, 0x037C, 0x0068, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__UART4_CTS_B, 0x037C, 0x0068, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__UART4_RTS_B, 0x037C, 0x0068, 3, 0x0910, 1, 0) -MX6_PAD_DECL(CSI0_DAT17__GPIO6_IO03, 0x037C, 0x0068, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__ARM_TRACE14, 0x037C, 0x0068, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__EIM_DATA13, 0x037C, 0x0068, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_CTS_B, 0x037C, 0x0068, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_RTS_B, 0x037C, 0x0068, 3, 0x0910, 1, 0) +MX6_PAD_DECL(CSI0_DAT17__GPIO6_IO03, 0x037C, 0x0068, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__ARM_TRACE14, 0x037C, 0x0068, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT18__IPU1_CSI0_DATA18, 0x0380, 0x006C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__EIM_DATA14, 0x0380, 0x006C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__UART5_CTS_B, 0x0380, 0x006C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__UART5_RTS_B, 0x0380, 0x006C, 3, 0x0918, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__GPIO6_IO04, 0x0380, 0x006C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__ARM_TRACE15, 0x0380, 0x006C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__EIM_DATA14, 0x0380, 0x006C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_CTS_B, 0x0380, 0x006C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_RTS_B, 0x0380, 0x006C, 3, 0x0918, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__GPIO6_IO04, 0x0380, 0x006C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__ARM_TRACE15, 0x0380, 0x006C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT19__IPU1_CSI0_DATA19, 0x0384, 0x0070, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT19__EIM_DATA15, 0x0384, 0x0070, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT19__UART5_CTS_B, 0x0384, 0x0070, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT19__UART5_RTS_B, 0x0384, 0x0070, 3, 0x0918, 1, 0) -MX6_PAD_DECL(CSI0_DAT19__GPIO6_IO05, 0x0384, 0x0070, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__EIM_DATA15, 0x0384, 0x0070, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_CTS_B, 0x0384, 0x0070, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_RTS_B, 0x0384, 0x0070, 3, 0x0918, 1, 0) +MX6_PAD_DECL(CSI0_DAT19__GPIO6_IO05, 0x0384, 0x0070, 5, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT4__IPU1_CSI0_DATA04, 0x0388, 0x0074, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__EIM_DATA02, 0x0388, 0x0074, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__ECSPI1_SCLK, 0x0388, 0x0074, 2, 0x07D8, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__KEY_COL5, 0x0388, 0x0074, 3, 0x08C0, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__AUD3_TXC, 0x0388, 0x0074, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__GPIO5_IO22, 0x0388, 0x0074, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__ARM_TRACE01, 0x0388, 0x0074, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__EIM_DATA02, 0x0388, 0x0074, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ECSPI1_SCLK, 0x0388, 0x0074, 2, 0x07D8, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__KEY_COL5, 0x0388, 0x0074, 3, 0x08C0, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__AUD3_TXC, 0x0388, 0x0074, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__GPIO5_IO22, 0x0388, 0x0074, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ARM_TRACE01, 0x0388, 0x0074, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT5__IPU1_CSI0_DATA05, 0x038C, 0x0078, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__EIM_DATA03, 0x038C, 0x0078, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__ECSPI1_MOSI, 0x038C, 0x0078, 2, 0x07E0, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__KEY_ROW5, 0x038C, 0x0078, 3, 0x08CC, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__AUD3_TXD, 0x038C, 0x0078, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__GPIO5_IO23, 0x038C, 0x0078, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__ARM_TRACE02, 0x038C, 0x0078, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__EIM_DATA03, 0x038C, 0x0078, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ECSPI1_MOSI, 0x038C, 0x0078, 2, 0x07E0, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__KEY_ROW5, 0x038C, 0x0078, 3, 0x08CC, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__AUD3_TXD, 0x038C, 0x0078, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__GPIO5_IO23, 0x038C, 0x0078, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ARM_TRACE02, 0x038C, 0x0078, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT6__IPU1_CSI0_DATA06, 0x0390, 0x007C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__EIM_DATA04, 0x0390, 0x007C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__ECSPI1_MISO, 0x0390, 0x007C, 2, 0x07DC, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__KEY_COL6, 0x0390, 0x007C, 3, 0x08C4, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__AUD3_TXFS, 0x0390, 0x007C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__GPIO5_IO24, 0x0390, 0x007C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__ARM_TRACE03, 0x0390, 0x007C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__EIM_DATA04, 0x0390, 0x007C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ECSPI1_MISO, 0x0390, 0x007C, 2, 0x07DC, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__KEY_COL6, 0x0390, 0x007C, 3, 0x08C4, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__AUD3_TXFS, 0x0390, 0x007C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__GPIO5_IO24, 0x0390, 0x007C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ARM_TRACE03, 0x0390, 0x007C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT7__IPU1_CSI0_DATA07, 0x0394, 0x0080, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__EIM_DATA05, 0x0394, 0x0080, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__ECSPI1_SS0, 0x0394, 0x0080, 2, 0x07E4, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__KEY_ROW6, 0x0394, 0x0080, 3, 0x08D0, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__AUD3_RXD, 0x0394, 0x0080, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__GPIO5_IO25, 0x0394, 0x0080, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__ARM_TRACE04, 0x0394, 0x0080, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__EIM_DATA05, 0x0394, 0x0080, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ECSPI1_SS0, 0x0394, 0x0080, 2, 0x07E4, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__KEY_ROW6, 0x0394, 0x0080, 3, 0x08D0, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__AUD3_RXD, 0x0394, 0x0080, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__GPIO5_IO25, 0x0394, 0x0080, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ARM_TRACE04, 0x0394, 0x0080, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT8__IPU1_CSI0_DATA08, 0x0398, 0x0084, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__EIM_DATA06, 0x0398, 0x0084, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__ECSPI2_SCLK, 0x0398, 0x0084, 2, 0x07F4, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__KEY_COL7, 0x0398, 0x0084, 3, 0x08C8, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__I2C1_SDA, 0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__GPIO5_IO26, 0x0398, 0x0084, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__ARM_TRACE05, 0x0398, 0x0084, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__EIM_DATA06, 0x0398, 0x0084, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ECSPI2_SCLK, 0x0398, 0x0084, 2, 0x07F4, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__KEY_COL7, 0x0398, 0x0084, 3, 0x08C8, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__I2C1_SDA, 0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__GPIO5_IO26, 0x0398, 0x0084, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ARM_TRACE05, 0x0398, 0x0084, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT9__IPU1_CSI0_DATA09, 0x039C, 0x0088, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__EIM_DATA07, 0x039C, 0x0088, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__ECSPI2_MOSI, 0x039C, 0x0088, 2, 0x07FC, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__KEY_ROW7, 0x039C, 0x0088, 3, 0x08D4, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__I2C1_SCL, 0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__GPIO5_IO27, 0x039C, 0x0088, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__ARM_TRACE06, 0x039C, 0x0088, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__EIM_DATA07, 0x039C, 0x0088, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ECSPI2_MOSI, 0x039C, 0x0088, 2, 0x07FC, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__KEY_ROW7, 0x039C, 0x0088, 3, 0x08D4, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__I2C1_SCL, 0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__GPIO5_IO27, 0x039C, 0x0088, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ARM_TRACE06, 0x039C, 0x0088, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DATA_EN__IPU1_CSI0_DATA_EN, 0x03A0, 0x008C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DATA_EN__EIM_DATA00, 0x03A0, 0x008C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DATA_EN__GPIO5_IO20, 0x03A0, 0x008C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__EIM_DATA00, 0x03A0, 0x008C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__GPIO5_IO20, 0x03A0, 0x008C, 5, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DATA_EN__ARM_TRACE_CLK, 0x03A0, 0x008C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_MCLK__IPU1_CSI0_HSYNC, 0x03A4, 0x0090, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_MCLK__CCM_CLKO1, 0x03A4, 0x0090, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_MCLK__GPIO5_IO19, 0x03A4, 0x0090, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_MCLK__ARM_TRACE_CTL, 0x03A4, 0x0090, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__CCM_CLKO1, 0x03A4, 0x0090, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__GPIO5_IO19, 0x03A4, 0x0090, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__ARM_TRACE_CTL, 0x03A4, 0x0090, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_PIXCLK__IPU1_CSI0_PIXCLK, 0x03A8, 0x0094, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_PIXCLK__GPIO5_IO18, 0x03A8, 0x0094, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_PIXCLK__ARM_EVENTO, 0x03A8, 0x0094, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__GPIO5_IO18, 0x03A8, 0x0094, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__ARM_EVENTO, 0x03A8, 0x0094, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_VSYNC__IPU1_CSI0_VSYNC, 0x03AC, 0x0098, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_VSYNC__EIM_DATA01, 0x03AC, 0x0098, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_VSYNC__GPIO5_IO21, 0x03AC, 0x0098, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_VSYNC__ARM_TRACE00, 0x03AC, 0x0098, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__EIM_DATA01, 0x03AC, 0x0098, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__GPIO5_IO21, 0x03AC, 0x0098, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__ARM_TRACE00, 0x03AC, 0x0098, 7, 0x0000, 0, 0) MX6_PAD_DECL(DI0_DISP_CLK__IPU1_DI0_DISP_CLK, 0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_DISP_CLK__LCD_CLK, 0x03B0, 0x009C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_DISP_CLK__GPIO4_IO16, 0x03B0, 0x009C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_DISP_CLK__LCD_WR_RWN, 0x03B0, 0x009C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__IPU1_DI0_PIN15, 0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN15__LCD_ENABLE, 0x03B4, 0x00A0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__AUD6_TXC, 0x03B4, 0x00A0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__GPIO4_IO17, 0x03B4, 0x00A0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__LCD_RD_E, 0x03B4, 0x00A0, 8, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN2__IPU1_DI0_PIN02, 0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN2__LCD_HSYNC, 0x03B8, 0x00A4, 1, 0x08D8, 0, 0) -MX6_PAD_DECL(DI0_PIN2__AUD6_TXD, 0x03B8, 0x00A4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN2__GPIO4_IO18, 0x03B8, 0x00A4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN2__LCD_RS, 0x03B8, 0x00A4, 8, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__IPU1_DI0_PIN03, 0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN3__LCD_VSYNC, 0x03BC, 0x00A8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__AUD6_TXFS, 0x03BC, 0x00A8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__GPIO4_IO19, 0x03BC, 0x00A8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__LCD_CS, 0x03BC, 0x00A8, 8, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__IPU1_DI0_PIN04, 0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN4__LCD_BUSY, 0x03C0, 0x00AC, 1, 0x08D8, 1, 0) -MX6_PAD_DECL(DI0_PIN4__AUD6_RXD, 0x03C0, 0x00AC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__SD1_WP, 0x03C0, 0x00AC, 3, 0x092C, 0, 0) -MX6_PAD_DECL(DI0_PIN4__GPIO4_IO20, 0x03C0, 0x00AC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__LCD_RESET, 0x03C0, 0x00AC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__LCD_CLK, 0x03B0, 0x009C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__GPIO4_IO16, 0x03B0, 0x009C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_DISP_CLK__LCD_WR_RWN, 0x03B0, 0x009C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__IPU1_DI0_PIN15, 0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN15__LCD_ENABLE, 0x03B4, 0x00A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__AUD6_TXC, 0x03B4, 0x00A0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__GPIO4_IO17, 0x03B4, 0x00A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__LCD_RD_E, 0x03B4, 0x00A0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__IPU1_DI0_PIN02, 0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN2__LCD_HSYNC, 0x03B8, 0x00A4, 1, 0x08D8, 0, 0) +MX6_PAD_DECL(DI0_PIN2__AUD6_TXD, 0x03B8, 0x00A4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__GPIO4_IO18, 0x03B8, 0x00A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__LCD_RS, 0x03B8, 0x00A4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__IPU1_DI0_PIN03, 0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN3__LCD_VSYNC, 0x03BC, 0x00A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__AUD6_TXFS, 0x03BC, 0x00A8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__GPIO4_IO19, 0x03BC, 0x00A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__LCD_CS, 0x03BC, 0x00A8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__IPU1_DI0_PIN04, 0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN4__LCD_BUSY, 0x03C0, 0x00AC, 1, 0x08D8, 1, 0) +MX6_PAD_DECL(DI0_PIN4__AUD6_RXD, 0x03C0, 0x00AC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__SD1_WP, 0x03C0, 0x00AC, 3, 0x092C, 0, 0) +MX6_PAD_DECL(DI0_PIN4__GPIO4_IO20, 0x03C0, 0x00AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__LCD_RESET, 0x03C0, 0x00AC, 8, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT0__IPU1_DISP0_DATA00, 0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT0__LCD_DATA00, 0x03C4, 0x00B0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT0__ECSPI3_SCLK, 0x03C4, 0x00B0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT0__GPIO4_IO21, 0x03C4, 0x00B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__LCD_DATA00, 0x03C4, 0x00B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__ECSPI3_SCLK, 0x03C4, 0x00B0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__GPIO4_IO21, 0x03C4, 0x00B0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT1__IPU1_DISP0_DATA01, 0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT1__LCD_DATA01, 0x03C8, 0x00B4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT1__ECSPI3_MOSI, 0x03C8, 0x00B4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT1__GPIO4_IO22, 0x03C8, 0x00B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__LCD_DATA01, 0x03C8, 0x00B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__ECSPI3_MOSI, 0x03C8, 0x00B4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__GPIO4_IO22, 0x03C8, 0x00B4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT10__IPU1_DISP0_DATA10, 0x03CC, 0x00B8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT10__LCD_DATA10, 0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT10__GPIO4_IO31, 0x03CC, 0x00B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT10__LCD_DATA10, 0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DISP0_DAT10__GPIO4_IO31, 0x03CC, 0x00B8, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT11__IPU1_DISP0_DATA11, 0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT11__LCD_DATA11, 0x03D0, 0x00BC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT11__GPIO5_IO05, 0x03D0, 0x00BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__LCD_DATA11, 0x03D0, 0x00BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__GPIO5_IO05, 0x03D0, 0x00BC, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT12__IPU1_DISP0_DATA12, 0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT12__LCD_DATA12, 0x03D4, 0x00C0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT12__GPIO5_IO06, 0x03D4, 0x00C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__LCD_DATA12, 0x03D4, 0x00C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__GPIO5_IO06, 0x03D4, 0x00C0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT13__IPU1_DISP0_DATA13, 0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT13__LCD_DATA13, 0x03D8, 0x00C4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT13__AUD5_RXFS, 0x03D8, 0x00C4, 3, 0x07BC, 0, 0) -MX6_PAD_DECL(DISP0_DAT13__GPIO5_IO07, 0x03D8, 0x00C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__LCD_DATA13, 0x03D8, 0x00C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__AUD5_RXFS, 0x03D8, 0x00C4, 3, 0x07BC, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__GPIO5_IO07, 0x03D8, 0x00C4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT14__IPU1_DISP0_DATA14, 0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT14__LCD_DATA14, 0x03DC, 0x00C8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT14__AUD5_RXC, 0x03DC, 0x00C8, 3, 0x07B8, 0, 0) -MX6_PAD_DECL(DISP0_DAT14__GPIO5_IO08, 0x03DC, 0x00C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__LCD_DATA14, 0x03DC, 0x00C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__AUD5_RXC, 0x03DC, 0x00C8, 3, 0x07B8, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__GPIO5_IO08, 0x03DC, 0x00C8, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT15__IPU1_DISP0_DATA15, 0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT15__LCD_DATA15, 0x03E0, 0x00CC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT15__ECSPI1_SS1, 0x03E0, 0x00CC, 2, 0x07E8, 0, 0) -MX6_PAD_DECL(DISP0_DAT15__ECSPI2_SS1, 0x03E0, 0x00CC, 3, 0x0804, 0, 0) -MX6_PAD_DECL(DISP0_DAT15__GPIO5_IO09, 0x03E0, 0x00CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__LCD_DATA15, 0x03E0, 0x00CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI1_SS1, 0x03E0, 0x00CC, 2, 0x07E8, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI2_SS1, 0x03E0, 0x00CC, 3, 0x0804, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__GPIO5_IO09, 0x03E0, 0x00CC, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT16__IPU1_DISP0_DATA16, 0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT16__LCD_DATA16, 0x03E4, 0x00D0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT16__ECSPI2_MOSI, 0x03E4, 0x00D0, 2, 0x07FC, 1, 0) -MX6_PAD_DECL(DISP0_DAT16__AUD5_TXC, 0x03E4, 0x00D0, 3, 0x07C0, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__LCD_DATA16, 0x03E4, 0x00D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__ECSPI2_MOSI, 0x03E4, 0x00D0, 2, 0x07FC, 1, 0) +MX6_PAD_DECL(DISP0_DAT16__AUD5_TXC, 0x03E4, 0x00D0, 3, 0x07C0, 0, 0) MX6_PAD_DECL(DISP0_DAT16__SDMA_EXT_EVENT0, 0x03E4, 0x00D0, 4, 0x08E8, 0, 0) -MX6_PAD_DECL(DISP0_DAT16__GPIO5_IO10, 0x03E4, 0x00D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__GPIO5_IO10, 0x03E4, 0x00D0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT17__IPU1_DISP0_DATA17, 0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT17__LCD_DATA17, 0x03E8, 0x00D4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT17__ECSPI2_MISO, 0x03E8, 0x00D4, 2, 0x07F8, 1, 0) -MX6_PAD_DECL(DISP0_DAT17__AUD5_TXD, 0x03E8, 0x00D4, 3, 0x07B4, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__LCD_DATA17, 0x03E8, 0x00D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__ECSPI2_MISO, 0x03E8, 0x00D4, 2, 0x07F8, 1, 0) +MX6_PAD_DECL(DISP0_DAT17__AUD5_TXD, 0x03E8, 0x00D4, 3, 0x07B4, 0, 0) MX6_PAD_DECL(DISP0_DAT17__SDMA_EXT_EVENT1, 0x03E8, 0x00D4, 4, 0x08EC, 0, 0) -MX6_PAD_DECL(DISP0_DAT17__GPIO5_IO11, 0x03E8, 0x00D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__GPIO5_IO11, 0x03E8, 0x00D4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT18__IPU1_DISP0_DATA18, 0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT18__LCD_DATA18, 0x03EC, 0x00D8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__ECSPI2_SS0, 0x03EC, 0x00D8, 2, 0x0800, 1, 0) -MX6_PAD_DECL(DISP0_DAT18__AUD5_TXFS, 0x03EC, 0x00D8, 3, 0x07C4, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__AUD4_RXFS, 0x03EC, 0x00D8, 4, 0x07A4, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__GPIO5_IO12, 0x03EC, 0x00D8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__EIM_CS2_B, 0x03EC, 0x00D8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__LCD_DATA18, 0x03EC, 0x00D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__ECSPI2_SS0, 0x03EC, 0x00D8, 2, 0x0800, 1, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD5_TXFS, 0x03EC, 0x00D8, 3, 0x07C4, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD4_RXFS, 0x03EC, 0x00D8, 4, 0x07A4, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__GPIO5_IO12, 0x03EC, 0x00D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__EIM_CS2_B, 0x03EC, 0x00D8, 7, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT19__IPU1_DISP0_DATA19, 0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT19__LCD_DATA19, 0x03F0, 0x00DC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__ECSPI2_SCLK, 0x03F0, 0x00DC, 2, 0x07F4, 1, 0) -MX6_PAD_DECL(DISP0_DAT19__AUD5_RXD, 0x03F0, 0x00DC, 3, 0x07B0, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__AUD4_RXC, 0x03F0, 0x00DC, 4, 0x07A0, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__GPIO5_IO13, 0x03F0, 0x00DC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__EIM_CS3_B, 0x03F0, 0x00DC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__LCD_DATA19, 0x03F0, 0x00DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__ECSPI2_SCLK, 0x03F0, 0x00DC, 2, 0x07F4, 1, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD5_RXD, 0x03F0, 0x00DC, 3, 0x07B0, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD4_RXC, 0x03F0, 0x00DC, 4, 0x07A0, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__GPIO5_IO13, 0x03F0, 0x00DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__EIM_CS3_B, 0x03F0, 0x00DC, 7, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT2__IPU1_DISP0_DATA02, 0x03F4, 0x00E0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT2__LCD_DATA02, 0x03F4, 0x00E0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT2__ECSPI3_MISO, 0x03F4, 0x00E0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT2__GPIO4_IO23, 0x03F4, 0x00E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__LCD_DATA02, 0x03F4, 0x00E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__ECSPI3_MISO, 0x03F4, 0x00E0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__GPIO4_IO23, 0x03F4, 0x00E0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT20__IPU1_DISP0_DATA20, 0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT20__LCD_DATA20, 0x03F8, 0x00E4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT20__ECSPI1_SCLK, 0x03F8, 0x00E4, 2, 0x07D8, 1, 0) -MX6_PAD_DECL(DISP0_DAT20__AUD4_TXC, 0x03F8, 0x00E4, 3, 0x07A8, 0, 0) -MX6_PAD_DECL(DISP0_DAT20__GPIO5_IO14, 0x03F8, 0x00E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__LCD_DATA20, 0x03F8, 0x00E4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__ECSPI1_SCLK, 0x03F8, 0x00E4, 2, 0x07D8, 1, 0) +MX6_PAD_DECL(DISP0_DAT20__AUD4_TXC, 0x03F8, 0x00E4, 3, 0x07A8, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__GPIO5_IO14, 0x03F8, 0x00E4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT21__IPU1_DISP0_DATA21, 0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT21__LCD_DATA21, 0x03FC, 0x00E8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT21__ECSPI1_MOSI, 0x03FC, 0x00E8, 2, 0x07E0, 1, 0) -MX6_PAD_DECL(DISP0_DAT21__AUD4_TXD, 0x03FC, 0x00E8, 3, 0x079C, 0, 0) -MX6_PAD_DECL(DISP0_DAT21__GPIO5_IO15, 0x03FC, 0x00E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__LCD_DATA21, 0x03FC, 0x00E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__ECSPI1_MOSI, 0x03FC, 0x00E8, 2, 0x07E0, 1, 0) +MX6_PAD_DECL(DISP0_DAT21__AUD4_TXD, 0x03FC, 0x00E8, 3, 0x079C, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__GPIO5_IO15, 0x03FC, 0x00E8, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT22__IPU1_DISP0_DATA22, 0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT22__LCD_DATA22, 0x0400, 0x00EC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT22__ECSPI1_MISO, 0x0400, 0x00EC, 2, 0x07DC, 1, 0) -MX6_PAD_DECL(DISP0_DAT22__AUD4_TXFS, 0x0400, 0x00EC, 3, 0x07AC, 0, 0) -MX6_PAD_DECL(DISP0_DAT22__GPIO5_IO16, 0x0400, 0x00EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__LCD_DATA22, 0x0400, 0x00EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__ECSPI1_MISO, 0x0400, 0x00EC, 2, 0x07DC, 1, 0) +MX6_PAD_DECL(DISP0_DAT22__AUD4_TXFS, 0x0400, 0x00EC, 3, 0x07AC, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__GPIO5_IO16, 0x0400, 0x00EC, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT23__IPU1_DISP0_DATA23, 0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT23__LCD_DATA23, 0x0404, 0x00F0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT23__ECSPI1_SS0, 0x0404, 0x00F0, 2, 0x07E4, 1, 0) -MX6_PAD_DECL(DISP0_DAT23__AUD4_RXD, 0x0404, 0x00F0, 3, 0x0798, 0, 0) -MX6_PAD_DECL(DISP0_DAT23__GPIO5_IO17, 0x0404, 0x00F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__LCD_DATA23, 0x0404, 0x00F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__ECSPI1_SS0, 0x0404, 0x00F0, 2, 0x07E4, 1, 0) +MX6_PAD_DECL(DISP0_DAT23__AUD4_RXD, 0x0404, 0x00F0, 3, 0x0798, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__GPIO5_IO17, 0x0404, 0x00F0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT3__IPU1_DISP0_DATA03, 0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT3__LCD_DATA03, 0x0408, 0x00F4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT3__ECSPI3_SS0, 0x0408, 0x00F4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT3__GPIO4_IO24, 0x0408, 0x00F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__LCD_DATA03, 0x0408, 0x00F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__ECSPI3_SS0, 0x0408, 0x00F4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__GPIO4_IO24, 0x0408, 0x00F4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT4__IPU1_DISP0_DATA04, 0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT4__LCD_DATA04, 0x040C, 0x00F8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT4__ECSPI3_SS1, 0x040C, 0x00F8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT4__GPIO4_IO25, 0x040C, 0x00F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__LCD_DATA04, 0x040C, 0x00F8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__ECSPI3_SS1, 0x040C, 0x00F8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__GPIO4_IO25, 0x040C, 0x00F8, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT5__IPU1_DISP0_DATA05, 0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT5__LCD_DATA05, 0x0410, 0x00FC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT5__ECSPI3_SS2, 0x0410, 0x00FC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT5__AUD6_RXFS, 0x0410, 0x00FC, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT5__GPIO4_IO26, 0x0410, 0x00FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__LCD_DATA05, 0x0410, 0x00FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__ECSPI3_SS2, 0x0410, 0x00FC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__AUD6_RXFS, 0x0410, 0x00FC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__GPIO4_IO26, 0x0410, 0x00FC, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT6__IPU1_DISP0_DATA06, 0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT6__LCD_DATA06, 0x0414, 0x0100, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT6__ECSPI3_SS3, 0x0414, 0x0100, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT6__AUD6_RXC, 0x0414, 0x0100, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT6__GPIO4_IO27, 0x0414, 0x0100, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__LCD_DATA06, 0x0414, 0x0100, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__ECSPI3_SS3, 0x0414, 0x0100, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__AUD6_RXC, 0x0414, 0x0100, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__GPIO4_IO27, 0x0414, 0x0100, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT7__IPU1_DISP0_DATA07, 0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT7__LCD_DATA07, 0x0418, 0x0104, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT7__ECSPI3_RDY, 0x0418, 0x0104, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT7__GPIO4_IO28, 0x0418, 0x0104, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__LCD_DATA07, 0x0418, 0x0104, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__ECSPI3_RDY, 0x0418, 0x0104, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__GPIO4_IO28, 0x0418, 0x0104, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT8__IPU1_DISP0_DATA08, 0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT8__LCD_DATA08, 0x041C, 0x0108, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT8__PWM1_OUT, 0x041C, 0x0108, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT8__WDOG1_B, 0x041C, 0x0108, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT8__GPIO4_IO29, 0x041C, 0x0108, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__LCD_DATA08, 0x041C, 0x0108, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__PWM1_OUT, 0x041C, 0x0108, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__WDOG1_B, 0x041C, 0x0108, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__GPIO4_IO29, 0x041C, 0x0108, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT9__IPU1_DISP0_DATA09, 0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DISP0_DAT9__LCD_DATA09, 0x0420, 0x010C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT9__PWM2_OUT, 0x0420, 0x010C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT9__WDOG2_B, 0x0420, 0x010C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT9__GPIO4_IO30, 0x0420, 0x010C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__EIM_ADDR16, 0x04E0, 0x0110, 0, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__LCD_DATA09, 0x0420, 0x010C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__PWM2_OUT, 0x0420, 0x010C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__WDOG2_B, 0x0420, 0x010C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__GPIO4_IO30, 0x0420, 0x010C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__EIM_ADDR16, 0x04E0, 0x0110, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A16__IPU1_DI1_DISP_CLK, 0x04E0, 0x0110, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__IPU1_CSI1_PIXCLK, 0x04E0, 0x0110, 2, 0x08B8, 0, 0) -MX6_PAD_DECL(EIM_A16__GPIO2_IO22, 0x04E0, 0x0110, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__SRC_BOOT_CFG16, 0x04E0, 0x0110, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__EPDC_DATA00, 0x04E0, 0x0110, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__EIM_ADDR17, 0x04E4, 0x0114, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__IPU1_CSI1_PIXCLK, 0x04E0, 0x0110, 2, 0x08B8, 0, 0) +MX6_PAD_DECL(EIM_A16__GPIO2_IO22, 0x04E0, 0x0110, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__SRC_BOOT_CFG16, 0x04E0, 0x0110, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__EPDC_DATA00, 0x04E0, 0x0110, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__EIM_ADDR17, 0x04E4, 0x0114, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A17__IPU1_DISP1_DATA12, 0x04E4, 0x0114, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__IPU1_CSI1_DATA12, 0x04E4, 0x0114, 2, 0x0890, 0, 0) -MX6_PAD_DECL(EIM_A17__GPIO2_IO21, 0x04E4, 0x0114, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__SRC_BOOT_CFG17, 0x04E4, 0x0114, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__EPDC_PWR_STAT, 0x04E4, 0x0114, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__EIM_ADDR18, 0x04E8, 0x0118, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__IPU1_CSI1_DATA12, 0x04E4, 0x0114, 2, 0x0890, 0, 0) +MX6_PAD_DECL(EIM_A17__GPIO2_IO21, 0x04E4, 0x0114, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__SRC_BOOT_CFG17, 0x04E4, 0x0114, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__EPDC_PWR_STAT, 0x04E4, 0x0114, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__EIM_ADDR18, 0x04E8, 0x0118, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A18__IPU1_DISP1_DATA13, 0x04E8, 0x0118, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__IPU1_CSI1_DATA13, 0x04E8, 0x0118, 2, 0x0894, 0, 0) -MX6_PAD_DECL(EIM_A18__GPIO2_IO20, 0x04E8, 0x0118, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__SRC_BOOT_CFG18, 0x04E8, 0x0118, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__EPDC_PWR_CTRL0, 0x04E8, 0x0118, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__EIM_ADDR19, 0x04EC, 0x011C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__IPU1_CSI1_DATA13, 0x04E8, 0x0118, 2, 0x0894, 0, 0) +MX6_PAD_DECL(EIM_A18__GPIO2_IO20, 0x04E8, 0x0118, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__SRC_BOOT_CFG18, 0x04E8, 0x0118, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__EPDC_PWR_CTRL0, 0x04E8, 0x0118, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__EIM_ADDR19, 0x04EC, 0x011C, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A19__IPU1_DISP1_DATA14, 0x04EC, 0x011C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__IPU1_CSI1_DATA14, 0x04EC, 0x011C, 2, 0x0898, 0, 0) -MX6_PAD_DECL(EIM_A19__GPIO2_IO19, 0x04EC, 0x011C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__SRC_BOOT_CFG19, 0x04EC, 0x011C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__EPDC_PWR_CTRL1, 0x04EC, 0x011C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__EIM_ADDR20, 0x04F0, 0x0120, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__IPU1_CSI1_DATA14, 0x04EC, 0x011C, 2, 0x0898, 0, 0) +MX6_PAD_DECL(EIM_A19__GPIO2_IO19, 0x04EC, 0x011C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__SRC_BOOT_CFG19, 0x04EC, 0x011C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__EPDC_PWR_CTRL1, 0x04EC, 0x011C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__EIM_ADDR20, 0x04F0, 0x0120, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A20__IPU1_DISP1_DATA15, 0x04F0, 0x0120, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__IPU1_CSI1_DATA15, 0x04F0, 0x0120, 2, 0x089C, 0, 0) -MX6_PAD_DECL(EIM_A20__GPIO2_IO18, 0x04F0, 0x0120, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__SRC_BOOT_CFG20, 0x04F0, 0x0120, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__EPDC_PWR_CTRL2, 0x04F0, 0x0120, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__EIM_ADDR21, 0x04F4, 0x0124, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__IPU1_CSI1_DATA15, 0x04F0, 0x0120, 2, 0x089C, 0, 0) +MX6_PAD_DECL(EIM_A20__GPIO2_IO18, 0x04F0, 0x0120, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__SRC_BOOT_CFG20, 0x04F0, 0x0120, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__EPDC_PWR_CTRL2, 0x04F0, 0x0120, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__EIM_ADDR21, 0x04F4, 0x0124, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A21__IPU1_DISP1_DATA16, 0x04F4, 0x0124, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__IPU1_CSI1_DATA16, 0x04F4, 0x0124, 2, 0x08A0, 0, 0) -MX6_PAD_DECL(EIM_A21__GPIO2_IO17, 0x04F4, 0x0124, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__SRC_BOOT_CFG21, 0x04F4, 0x0124, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__EPDC_GDCLK, 0x04F4, 0x0124, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__EIM_ADDR22, 0x04F8, 0x0128, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__IPU1_CSI1_DATA16, 0x04F4, 0x0124, 2, 0x08A0, 0, 0) +MX6_PAD_DECL(EIM_A21__GPIO2_IO17, 0x04F4, 0x0124, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__SRC_BOOT_CFG21, 0x04F4, 0x0124, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__EPDC_GDCLK, 0x04F4, 0x0124, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__EIM_ADDR22, 0x04F8, 0x0128, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A22__IPU1_DISP1_DATA17, 0x04F8, 0x0128, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__IPU1_CSI1_DATA17, 0x04F8, 0x0128, 2, 0x08A4, 0, 0) -MX6_PAD_DECL(EIM_A22__GPIO2_IO16, 0x04F8, 0x0128, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__SRC_BOOT_CFG22, 0x04F8, 0x0128, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__EPDC_GDSP, 0x04F8, 0x0128, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__EIM_ADDR23, 0x04FC, 0x012C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__IPU1_CSI1_DATA17, 0x04F8, 0x0128, 2, 0x08A4, 0, 0) +MX6_PAD_DECL(EIM_A22__GPIO2_IO16, 0x04F8, 0x0128, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__SRC_BOOT_CFG22, 0x04F8, 0x0128, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__EPDC_GDSP, 0x04F8, 0x0128, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__EIM_ADDR23, 0x04FC, 0x012C, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A23__IPU1_DISP1_DATA18, 0x04FC, 0x012C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__IPU1_CSI1_DATA18, 0x04FC, 0x012C, 2, 0x08A8, 0, 0) -MX6_PAD_DECL(EIM_A23__IPU1_SISG3, 0x04FC, 0x012C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__GPIO6_IO06, 0x04FC, 0x012C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__SRC_BOOT_CFG23, 0x04FC, 0x012C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__EPDC_GDOE, 0x04FC, 0x012C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__EIM_ADDR24, 0x0500, 0x0130, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_CSI1_DATA18, 0x04FC, 0x012C, 2, 0x08A8, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_SISG3, 0x04FC, 0x012C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__GPIO6_IO06, 0x04FC, 0x012C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__SRC_BOOT_CFG23, 0x04FC, 0x012C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__EPDC_GDOE, 0x04FC, 0x012C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__EIM_ADDR24, 0x0500, 0x0130, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A24__IPU1_DISP1_DATA19, 0x0500, 0x0130, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__IPU1_CSI1_DATA19, 0x0500, 0x0130, 2, 0x08AC, 0, 0) -MX6_PAD_DECL(EIM_A24__IPU1_SISG2, 0x0500, 0x0130, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__GPIO5_IO04, 0x0500, 0x0130, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__SRC_BOOT_CFG24, 0x0500, 0x0130, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__EPDC_GDRL, 0x0500, 0x0130, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__EIM_ADDR25, 0x0504, 0x0134, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__ECSPI4_SS1, 0x0504, 0x0134, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__ECSPI2_RDY, 0x0504, 0x0134, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__IPU1_DI1_PIN12, 0x0504, 0x0134, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__IPU1_DI0_D1_CS, 0x0504, 0x0134, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__GPIO5_IO02, 0x0504, 0x0134, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__HDMI_TX_CEC_LINE, 0x0504, 0x0134, 6, 0x085C, 0, 0) -MX6_PAD_DECL(EIM_A25__EPDC_DATA15, 0x0504, 0x0134, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__EIM_ACLK_FREERUN, 0x0504, 0x0134, 9, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__EIM_BCLK, 0x0508, 0x0138, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__IPU1_DI1_PIN16, 0x0508, 0x0138, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__GPIO6_IO31, 0x0508, 0x0138, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__EPDC_SDCE9, 0x0508, 0x0138, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__EIM_CS0_B, 0x050C, 0x013C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__IPU1_DI1_PIN05, 0x050C, 0x013C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__ECSPI2_SCLK, 0x050C, 0x013C, 2, 0x07F4, 2, 0) -MX6_PAD_DECL(EIM_CS0__GPIO2_IO23, 0x050C, 0x013C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__EPDC_DATA06, 0x050C, 0x013C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__EIM_CS1_B, 0x0510, 0x0140, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__IPU1_DI1_PIN06, 0x0510, 0x0140, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__ECSPI2_MOSI, 0x0510, 0x0140, 2, 0x07FC, 2, 0) -MX6_PAD_DECL(EIM_CS1__GPIO2_IO24, 0x0510, 0x0140, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__EPDC_DATA08, 0x0510, 0x0140, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__EIM_DATA16, 0x0514, 0x0144, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__ECSPI1_SCLK, 0x0514, 0x0144, 1, 0x07D8, 2, 0) -MX6_PAD_DECL(EIM_D16__IPU1_DI0_PIN05, 0x0514, 0x0144, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__IPU1_CSI1_DATA18, 0x0514, 0x0144, 3, 0x08A8, 1, 0) -MX6_PAD_DECL(EIM_D16__HDMI_TX_DDC_SDA, 0x0514, 0x0144, 4, 0x0864, 0, 0) -MX6_PAD_DECL(EIM_D16__GPIO3_IO16, 0x0514, 0x0144, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__I2C2_SDA, 0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0) -MX6_PAD_DECL(EIM_D16__EPDC_DATA10, 0x0514, 0x0144, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__EIM_DATA17, 0x0518, 0x0148, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__ECSPI1_MISO, 0x0518, 0x0148, 1, 0x07DC, 2, 0) -MX6_PAD_DECL(EIM_D17__IPU1_DI0_PIN06, 0x0518, 0x0148, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__IPU1_CSI1_PIXCLK, 0x0518, 0x0148, 3, 0x08B8, 1, 0) -MX6_PAD_DECL(EIM_D17__DCIC1_OUT, 0x0518, 0x0148, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__GPIO3_IO17, 0x0518, 0x0148, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__I2C3_SCL, 0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0) -MX6_PAD_DECL(EIM_D17__EPDC_VCOM0, 0x0518, 0x0148, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__EIM_DATA18, 0x051C, 0x014C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__ECSPI1_MOSI, 0x051C, 0x014C, 1, 0x07E0, 2, 0) -MX6_PAD_DECL(EIM_D18__IPU1_DI0_PIN07, 0x051C, 0x014C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__IPU1_CSI1_DATA17, 0x051C, 0x014C, 3, 0x08A4, 1, 0) -MX6_PAD_DECL(EIM_D18__IPU1_DI1_D0_CS, 0x051C, 0x014C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__GPIO3_IO18, 0x051C, 0x014C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__I2C3_SDA, 0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0) -MX6_PAD_DECL(EIM_D18__EPDC_VCOM1, 0x051C, 0x014C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__EIM_DATA19, 0x0520, 0x0150, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__ECSPI1_SS1, 0x0520, 0x0150, 1, 0x07E8, 1, 0) -MX6_PAD_DECL(EIM_D19__IPU1_DI0_PIN08, 0x0520, 0x0150, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__IPU1_CSI1_DATA16, 0x0520, 0x0150, 3, 0x08A0, 1, 0) -MX6_PAD_DECL(EIM_D19__UART1_CTS_B, 0x0520, 0x0150, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__UART1_RTS_B, 0x0520, 0x0150, 4, 0x08F8, 0, 0) -MX6_PAD_DECL(EIM_D19__GPIO3_IO19, 0x0520, 0x0150, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__EPIT1_OUT, 0x0520, 0x0150, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__EPDC_DATA12, 0x0520, 0x0150, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__EIM_DATA20, 0x0524, 0x0154, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__ECSPI4_SS0, 0x0524, 0x0154, 1, 0x0808, 0, 0) -MX6_PAD_DECL(EIM_D20__IPU1_DI0_PIN16, 0x0524, 0x0154, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__IPU1_CSI1_DATA15, 0x0524, 0x0154, 3, 0x089C, 1, 0) -MX6_PAD_DECL(EIM_D20__UART1_CTS_B, 0x0524, 0x0154, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__UART1_RTS_B, 0x0524, 0x0154, 4, 0x08F8, 1, 0) -MX6_PAD_DECL(EIM_D20__GPIO3_IO20, 0x0524, 0x0154, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__EPIT2_OUT, 0x0524, 0x0154, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__EIM_DATA21, 0x0528, 0x0158, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__ECSPI4_SCLK, 0x0528, 0x0158, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__IPU1_DI0_PIN17, 0x0528, 0x0158, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__IPU1_CSI1_DATA11, 0x0528, 0x0158, 3, 0x088C, 0, 0) -MX6_PAD_DECL(EIM_D21__USB_OTG_OC, 0x0528, 0x0158, 4, 0x0920, 0, 0) -MX6_PAD_DECL(EIM_D21__GPIO3_IO21, 0x0528, 0x0158, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__I2C1_SCL, 0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0) -MX6_PAD_DECL(EIM_D21__SPDIF_IN, 0x0528, 0x0158, 7, 0x08F0, 0, 0) -MX6_PAD_DECL(EIM_D22__EIM_DATA22, 0x052C, 0x015C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__ECSPI4_MISO, 0x052C, 0x015C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__IPU1_DI0_PIN01, 0x052C, 0x015C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__IPU1_CSI1_DATA10, 0x052C, 0x015C, 3, 0x0888, 0, 0) -MX6_PAD_DECL(EIM_D22__USB_OTG_PWR, 0x052C, 0x015C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__GPIO3_IO22, 0x052C, 0x015C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__SPDIF_OUT, 0x052C, 0x015C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__EPDC_SDCE6, 0x052C, 0x015C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__EIM_DATA23, 0x0530, 0x0160, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__IPU1_DI0_D0_CS, 0x0530, 0x0160, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__UART3_CTS_B, 0x0530, 0x0160, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__UART3_RTS_B, 0x0530, 0x0160, 2, 0x0908, 0, 0) -MX6_PAD_DECL(EIM_D23__UART1_DCD_B, 0x0530, 0x0160, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_CSI1_DATA19, 0x0500, 0x0130, 2, 0x08AC, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_SISG2, 0x0500, 0x0130, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__GPIO5_IO04, 0x0500, 0x0130, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__SRC_BOOT_CFG24, 0x0500, 0x0130, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__EPDC_GDRL, 0x0500, 0x0130, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__EIM_ADDR25, 0x0504, 0x0134, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI4_SS1, 0x0504, 0x0134, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI2_RDY, 0x0504, 0x0134, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI1_PIN12, 0x0504, 0x0134, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI0_D1_CS, 0x0504, 0x0134, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__GPIO5_IO02, 0x0504, 0x0134, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__HDMI_TX_CEC_LINE, 0x0504, 0x0134, 6, 0x085C, 0, 0) +MX6_PAD_DECL(EIM_A25__EPDC_DATA15, 0x0504, 0x0134, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__EIM_ACLK_FREERUN, 0x0504, 0x0134, 9, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__EIM_BCLK, 0x0508, 0x0138, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__IPU1_DI1_PIN16, 0x0508, 0x0138, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__GPIO6_IO31, 0x0508, 0x0138, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__EPDC_SDCE9, 0x0508, 0x0138, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__EIM_CS0_B, 0x050C, 0x013C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__IPU1_DI1_PIN05, 0x050C, 0x013C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__ECSPI2_SCLK, 0x050C, 0x013C, 2, 0x07F4, 2, 0) +MX6_PAD_DECL(EIM_CS0__GPIO2_IO23, 0x050C, 0x013C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__EPDC_DATA06, 0x050C, 0x013C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__EIM_CS1_B, 0x0510, 0x0140, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__IPU1_DI1_PIN06, 0x0510, 0x0140, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__ECSPI2_MOSI, 0x0510, 0x0140, 2, 0x07FC, 2, 0) +MX6_PAD_DECL(EIM_CS1__GPIO2_IO24, 0x0510, 0x0140, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__EPDC_DATA08, 0x0510, 0x0140, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__EIM_DATA16, 0x0514, 0x0144, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__ECSPI1_SCLK, 0x0514, 0x0144, 1, 0x07D8, 2, 0) +MX6_PAD_DECL(EIM_D16__IPU1_DI0_PIN05, 0x0514, 0x0144, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__IPU1_CSI1_DATA18, 0x0514, 0x0144, 3, 0x08A8, 1, 0) +MX6_PAD_DECL(EIM_D16__HDMI_TX_DDC_SDA, 0x0514, 0x0144, 4, 0x0864, 0, 0) +MX6_PAD_DECL(EIM_D16__GPIO3_IO16, 0x0514, 0x0144, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__I2C2_SDA, 0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0) +MX6_PAD_DECL(EIM_D16__EPDC_DATA10, 0x0514, 0x0144, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__EIM_DATA17, 0x0518, 0x0148, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__ECSPI1_MISO, 0x0518, 0x0148, 1, 0x07DC, 2, 0) +MX6_PAD_DECL(EIM_D17__IPU1_DI0_PIN06, 0x0518, 0x0148, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__IPU1_CSI1_PIXCLK, 0x0518, 0x0148, 3, 0x08B8, 1, 0) +MX6_PAD_DECL(EIM_D17__DCIC1_OUT, 0x0518, 0x0148, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__GPIO3_IO17, 0x0518, 0x0148, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__I2C3_SCL, 0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0) +MX6_PAD_DECL(EIM_D17__EPDC_VCOM0, 0x0518, 0x0148, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__EIM_DATA18, 0x051C, 0x014C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__ECSPI1_MOSI, 0x051C, 0x014C, 1, 0x07E0, 2, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI0_PIN07, 0x051C, 0x014C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU1_CSI1_DATA17, 0x051C, 0x014C, 3, 0x08A4, 1, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI1_D0_CS, 0x051C, 0x014C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__GPIO3_IO18, 0x051C, 0x014C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__I2C3_SDA, 0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0) +MX6_PAD_DECL(EIM_D18__EPDC_VCOM1, 0x051C, 0x014C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EIM_DATA19, 0x0520, 0x0150, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__ECSPI1_SS1, 0x0520, 0x0150, 1, 0x07E8, 1, 0) +MX6_PAD_DECL(EIM_D19__IPU1_DI0_PIN08, 0x0520, 0x0150, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__IPU1_CSI1_DATA16, 0x0520, 0x0150, 3, 0x08A0, 1, 0) +MX6_PAD_DECL(EIM_D19__UART1_CTS_B, 0x0520, 0x0150, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__UART1_RTS_B, 0x0520, 0x0150, 4, 0x08F8, 0, 0) +MX6_PAD_DECL(EIM_D19__GPIO3_IO19, 0x0520, 0x0150, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EPIT1_OUT, 0x0520, 0x0150, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EPDC_DATA12, 0x0520, 0x0150, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EIM_DATA20, 0x0524, 0x0154, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__ECSPI4_SS0, 0x0524, 0x0154, 1, 0x0808, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU1_DI0_PIN16, 0x0524, 0x0154, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU1_CSI1_DATA15, 0x0524, 0x0154, 3, 0x089C, 1, 0) +MX6_PAD_DECL(EIM_D20__UART1_CTS_B, 0x0524, 0x0154, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__UART1_RTS_B, 0x0524, 0x0154, 4, 0x08F8, 1, 0) +MX6_PAD_DECL(EIM_D20__GPIO3_IO20, 0x0524, 0x0154, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EPIT2_OUT, 0x0524, 0x0154, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__EIM_DATA21, 0x0528, 0x0158, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__ECSPI4_SCLK, 0x0528, 0x0158, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU1_DI0_PIN17, 0x0528, 0x0158, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU1_CSI1_DATA11, 0x0528, 0x0158, 3, 0x088C, 0, 0) +MX6_PAD_DECL(EIM_D21__USB_OTG_OC, 0x0528, 0x0158, 4, 0x0920, 0, 0) +MX6_PAD_DECL(EIM_D21__GPIO3_IO21, 0x0528, 0x0158, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__I2C1_SCL, 0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0) +MX6_PAD_DECL(EIM_D21__SPDIF_IN, 0x0528, 0x0158, 7, 0x08F0, 0, 0) +MX6_PAD_DECL(EIM_D22__EIM_DATA22, 0x052C, 0x015C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__ECSPI4_MISO, 0x052C, 0x015C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU1_DI0_PIN01, 0x052C, 0x015C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU1_CSI1_DATA10, 0x052C, 0x015C, 3, 0x0888, 0, 0) +MX6_PAD_DECL(EIM_D22__USB_OTG_PWR, 0x052C, 0x015C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__GPIO3_IO22, 0x052C, 0x015C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__SPDIF_OUT, 0x052C, 0x015C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__EPDC_SDCE6, 0x052C, 0x015C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__EIM_DATA23, 0x0530, 0x0160, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI0_D0_CS, 0x0530, 0x0160, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_CTS_B, 0x0530, 0x0160, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_RTS_B, 0x0530, 0x0160, 2, 0x0908, 0, 0) +MX6_PAD_DECL(EIM_D23__UART1_DCD_B, 0x0530, 0x0160, 3, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D23__IPU1_CSI1_DATA_EN, 0x0530, 0x0160, 4, 0x08B0, 0, 0) -MX6_PAD_DECL(EIM_D23__GPIO3_IO23, 0x0530, 0x0160, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN02, 0x0530, 0x0160, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN14, 0x0530, 0x0160, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__EPDC_DATA11, 0x0530, 0x0160, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__EIM_DATA24, 0x0534, 0x0164, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__ECSPI4_SS2, 0x0534, 0x0164, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__UART3_TX_DATA, 0x0534, 0x0164, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__UART3_RX_DATA, 0x0534, 0x0164, 2, 0x090C, 0, 0) -MX6_PAD_DECL(EIM_D24__ECSPI1_SS2, 0x0534, 0x0164, 3, 0x07EC, 0, 0) -MX6_PAD_DECL(EIM_D24__ECSPI2_SS2, 0x0534, 0x0164, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__GPIO3_IO24, 0x0534, 0x0164, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__AUD5_RXFS, 0x0534, 0x0164, 6, 0x07BC, 1, 0) -MX6_PAD_DECL(EIM_D24__UART1_DTR_B, 0x0534, 0x0164, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__EPDC_SDCE7, 0x0534, 0x0164, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__EIM_DATA25, 0x0538, 0x0168, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__ECSPI4_SS3, 0x0538, 0x0168, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__UART3_TX_DATA, 0x0538, 0x0168, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__UART3_RX_DATA, 0x0538, 0x0168, 2, 0x090C, 1, 0) -MX6_PAD_DECL(EIM_D25__ECSPI1_SS3, 0x0538, 0x0168, 3, 0x07F0, 0, 0) -MX6_PAD_DECL(EIM_D25__ECSPI2_SS3, 0x0538, 0x0168, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__GPIO3_IO25, 0x0538, 0x0168, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__AUD5_RXC, 0x0538, 0x0168, 6, 0x07B8, 1, 0) -MX6_PAD_DECL(EIM_D25__UART1_DSR_B, 0x0538, 0x0168, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__EPDC_SDCE8, 0x0538, 0x0168, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__EIM_DATA26, 0x053C, 0x016C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_DI1_PIN11, 0x053C, 0x016C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_CSI0_DATA01, 0x053C, 0x016C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_CSI1_DATA14, 0x053C, 0x016C, 3, 0x0898, 1, 0) -MX6_PAD_DECL(EIM_D26__UART2_TX_DATA, 0x053C, 0x016C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__UART2_RX_DATA, 0x053C, 0x016C, 4, 0x0904, 0, 0) -MX6_PAD_DECL(EIM_D26__GPIO3_IO26, 0x053C, 0x016C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_SISG2, 0x053C, 0x016C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__GPIO3_IO23, 0x0530, 0x0160, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN02, 0x0530, 0x0160, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN14, 0x0530, 0x0160, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__EPDC_DATA11, 0x0530, 0x0160, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__EIM_DATA24, 0x0534, 0x0164, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI4_SS2, 0x0534, 0x0164, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_TX_DATA, 0x0534, 0x0164, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_RX_DATA, 0x0534, 0x0164, 2, 0x090C, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI1_SS2, 0x0534, 0x0164, 3, 0x07EC, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI2_SS2, 0x0534, 0x0164, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__GPIO3_IO24, 0x0534, 0x0164, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__AUD5_RXFS, 0x0534, 0x0164, 6, 0x07BC, 1, 0) +MX6_PAD_DECL(EIM_D24__UART1_DTR_B, 0x0534, 0x0164, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__EPDC_SDCE7, 0x0534, 0x0164, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__EIM_DATA25, 0x0538, 0x0168, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI4_SS3, 0x0538, 0x0168, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_TX_DATA, 0x0538, 0x0168, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_RX_DATA, 0x0538, 0x0168, 2, 0x090C, 1, 0) +MX6_PAD_DECL(EIM_D25__ECSPI1_SS3, 0x0538, 0x0168, 3, 0x07F0, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI2_SS3, 0x0538, 0x0168, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__GPIO3_IO25, 0x0538, 0x0168, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__AUD5_RXC, 0x0538, 0x0168, 6, 0x07B8, 1, 0) +MX6_PAD_DECL(EIM_D25__UART1_DSR_B, 0x0538, 0x0168, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__EPDC_SDCE8, 0x0538, 0x0168, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__EIM_DATA26, 0x053C, 0x016C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_DI1_PIN11, 0x053C, 0x016C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_CSI0_DATA01, 0x053C, 0x016C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_CSI1_DATA14, 0x053C, 0x016C, 3, 0x0898, 1, 0) +MX6_PAD_DECL(EIM_D26__UART2_TX_DATA, 0x053C, 0x016C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__UART2_RX_DATA, 0x053C, 0x016C, 4, 0x0904, 0, 0) +MX6_PAD_DECL(EIM_D26__GPIO3_IO26, 0x053C, 0x016C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_SISG2, 0x053C, 0x016C, 6, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D26__IPU1_DISP1_DATA22, 0x053C, 0x016C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__EPDC_SDOED, 0x053C, 0x016C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__EIM_DATA27, 0x0540, 0x0170, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_DI1_PIN13, 0x0540, 0x0170, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_CSI0_DATA00, 0x0540, 0x0170, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_CSI1_DATA13, 0x0540, 0x0170, 3, 0x0894, 1, 0) -MX6_PAD_DECL(EIM_D27__UART2_TX_DATA, 0x0540, 0x0170, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__UART2_RX_DATA, 0x0540, 0x0170, 4, 0x0904, 1, 0) -MX6_PAD_DECL(EIM_D27__GPIO3_IO27, 0x0540, 0x0170, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_SISG3, 0x0540, 0x0170, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__EPDC_SDOED, 0x053C, 0x016C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__EIM_DATA27, 0x0540, 0x0170, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_DI1_PIN13, 0x0540, 0x0170, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_CSI0_DATA00, 0x0540, 0x0170, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_CSI1_DATA13, 0x0540, 0x0170, 3, 0x0894, 1, 0) +MX6_PAD_DECL(EIM_D27__UART2_TX_DATA, 0x0540, 0x0170, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__UART2_RX_DATA, 0x0540, 0x0170, 4, 0x0904, 1, 0) +MX6_PAD_DECL(EIM_D27__GPIO3_IO27, 0x0540, 0x0170, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_SISG3, 0x0540, 0x0170, 6, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D27__IPU1_DISP1_DATA23, 0x0540, 0x0170, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__EPDC_SDOE, 0x0540, 0x0170, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__EIM_DATA28, 0x0544, 0x0174, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__I2C1_SDA, 0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0) -MX6_PAD_DECL(EIM_D28__ECSPI4_MOSI, 0x0544, 0x0174, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__IPU1_CSI1_DATA12, 0x0544, 0x0174, 3, 0x0890, 1, 0) -MX6_PAD_DECL(EIM_D28__UART2_DTE_RTS_B, 0x0544, 0x0174, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__UART2_DTE_CTS_B, 0x0544, 0x0174, 4, 0x0900, 0, 0) -MX6_PAD_DECL(EIM_D28__GPIO3_IO28, 0x0544, 0x0174, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__IPU1_EXT_TRIG, 0x0544, 0x0174, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__IPU1_DI0_PIN13, 0x0544, 0x0174, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__EPDC_PWR_CTRL3, 0x0544, 0x0174, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__EIM_DATA29, 0x0548, 0x0178, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__IPU1_DI1_PIN15, 0x0548, 0x0178, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__ECSPI4_SS0, 0x0548, 0x0178, 2, 0x0808, 1, 0) -MX6_PAD_DECL(EIM_D29__UART2_CTS_B, 0x0548, 0x0178, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__UART2_RTS_B, 0x0548, 0x0178, 4, 0x0900, 1, 0) -MX6_PAD_DECL(EIM_D29__GPIO3_IO29, 0x0548, 0x0178, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__IPU1_CSI1_VSYNC, 0x0548, 0x0178, 6, 0x08BC, 0, 0) -MX6_PAD_DECL(EIM_D29__IPU1_DI0_PIN14, 0x0548, 0x0178, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__EPDC_PWR_WAKE, 0x0548, 0x0178, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__EIM_DATA30, 0x054C, 0x017C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__EPDC_SDOE, 0x0540, 0x0170, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__EIM_DATA28, 0x0544, 0x0174, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__I2C1_SDA, 0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0) +MX6_PAD_DECL(EIM_D28__ECSPI4_MOSI, 0x0544, 0x0174, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_CSI1_DATA12, 0x0544, 0x0174, 3, 0x0890, 1, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_RTS_B, 0x0544, 0x0174, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_CTS_B, 0x0544, 0x0174, 4, 0x0900, 0, 0) +MX6_PAD_DECL(EIM_D28__GPIO3_IO28, 0x0544, 0x0174, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_EXT_TRIG, 0x0544, 0x0174, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_DI0_PIN13, 0x0544, 0x0174, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__EPDC_PWR_CTRL3, 0x0544, 0x0174, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__EIM_DATA29, 0x0548, 0x0178, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI1_PIN15, 0x0548, 0x0178, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__ECSPI4_SS0, 0x0548, 0x0178, 2, 0x0808, 1, 0) +MX6_PAD_DECL(EIM_D29__UART2_CTS_B, 0x0548, 0x0178, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__UART2_RTS_B, 0x0548, 0x0178, 4, 0x0900, 1, 0) +MX6_PAD_DECL(EIM_D29__GPIO3_IO29, 0x0548, 0x0178, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_CSI1_VSYNC, 0x0548, 0x0178, 6, 0x08BC, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI0_PIN14, 0x0548, 0x0178, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__EPDC_PWR_WAKE, 0x0548, 0x0178, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__EIM_DATA30, 0x054C, 0x017C, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D30__IPU1_DISP1_DATA21, 0x054C, 0x017C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__IPU1_DI0_PIN11, 0x054C, 0x017C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__IPU1_CSI0_DATA03, 0x054C, 0x017C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__UART3_CTS_B, 0x054C, 0x017C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__UART3_RTS_B, 0x054C, 0x017C, 4, 0x0908, 1, 0) -MX6_PAD_DECL(EIM_D30__GPIO3_IO30, 0x054C, 0x017C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__USB_H1_OC, 0x054C, 0x017C, 6, 0x0924, 0, 0) -MX6_PAD_DECL(EIM_D30__EPDC_SDOEZ, 0x054C, 0x017C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__EIM_DATA31, 0x0550, 0x0180, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_DI0_PIN11, 0x054C, 0x017C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_CSI0_DATA03, 0x054C, 0x017C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_CTS_B, 0x054C, 0x017C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_RTS_B, 0x054C, 0x017C, 4, 0x0908, 1, 0) +MX6_PAD_DECL(EIM_D30__GPIO3_IO30, 0x054C, 0x017C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__USB_H1_OC, 0x054C, 0x017C, 6, 0x0924, 0, 0) +MX6_PAD_DECL(EIM_D30__EPDC_SDOEZ, 0x054C, 0x017C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__EIM_DATA31, 0x0550, 0x0180, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D31__IPU1_DISP1_DATA20, 0x0550, 0x0180, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__IPU1_DI0_PIN12, 0x0550, 0x0180, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__IPU1_CSI0_DATA02, 0x0550, 0x0180, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__UART3_CTS_B, 0x0550, 0x0180, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__UART3_RTS_B, 0x0550, 0x0180, 4, 0x0908, 2, 0) -MX6_PAD_DECL(EIM_D31__GPIO3_IO31, 0x0550, 0x0180, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__USB_H1_PWR, 0x0550, 0x0180, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__EPDC_SDCLK_P, 0x0550, 0x0180, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__EIM_ACLK_FREERUN, 0x0550, 0x0180, 9, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__EIM_AD00, 0x0554, 0x0184, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_DI0_PIN12, 0x0550, 0x0180, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_CSI0_DATA02, 0x0550, 0x0180, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_CTS_B, 0x0550, 0x0180, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_RTS_B, 0x0550, 0x0180, 4, 0x0908, 2, 0) +MX6_PAD_DECL(EIM_D31__GPIO3_IO31, 0x0550, 0x0180, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__USB_H1_PWR, 0x0550, 0x0180, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__EPDC_SDCLK_P, 0x0550, 0x0180, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__EIM_ACLK_FREERUN, 0x0550, 0x0180, 9, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__EIM_AD00, 0x0554, 0x0184, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA0__IPU1_DISP1_DATA09, 0x0554, 0x0184, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__IPU1_CSI1_DATA09, 0x0554, 0x0184, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__GPIO3_IO00, 0x0554, 0x0184, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__SRC_BOOT_CFG00, 0x0554, 0x0184, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__EPDC_SDCLK_N, 0x0554, 0x0184, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__EIM_AD01, 0x0558, 0x0188, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__IPU1_CSI1_DATA09, 0x0554, 0x0184, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__GPIO3_IO00, 0x0554, 0x0184, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__SRC_BOOT_CFG00, 0x0554, 0x0184, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__EPDC_SDCLK_N, 0x0554, 0x0184, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__EIM_AD01, 0x0558, 0x0188, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA1__IPU1_DISP1_DATA08, 0x0558, 0x0188, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__IPU1_CSI1_DATA08, 0x0558, 0x0188, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__GPIO3_IO01, 0x0558, 0x0188, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__SRC_BOOT_CFG01, 0x0558, 0x0188, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__EPDC_SDLE, 0x0558, 0x0188, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__EIM_AD10, 0x055C, 0x018C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__IPU1_DI1_PIN15, 0x055C, 0x018C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__IPU1_CSI1_DATA08, 0x0558, 0x0188, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__GPIO3_IO01, 0x0558, 0x0188, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__SRC_BOOT_CFG01, 0x0558, 0x0188, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__EPDC_SDLE, 0x0558, 0x0188, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__EIM_AD10, 0x055C, 0x018C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__IPU1_DI1_PIN15, 0x055C, 0x018C, 1, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA10__IPU1_CSI1_DATA_EN, 0x055C, 0x018C, 2, 0x08B0, 1, 0) -MX6_PAD_DECL(EIM_DA10__GPIO3_IO10, 0x055C, 0x018C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__SRC_BOOT_CFG10, 0x055C, 0x018C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__EPDC_DATA01, 0x055C, 0x018C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__EIM_AD11, 0x0560, 0x0190, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__IPU1_DI1_PIN02, 0x0560, 0x0190, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__IPU1_CSI1_HSYNC, 0x0560, 0x0190, 2, 0x08B4, 0, 0) -MX6_PAD_DECL(EIM_DA11__GPIO3_IO11, 0x0560, 0x0190, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__SRC_BOOT_CFG11, 0x0560, 0x0190, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__EPDC_DATA03, 0x0560, 0x0190, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__EIM_AD12, 0x0564, 0x0194, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__IPU1_DI1_PIN03, 0x0564, 0x0194, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__IPU1_CSI1_VSYNC, 0x0564, 0x0194, 2, 0x08BC, 1, 0) -MX6_PAD_DECL(EIM_DA12__GPIO3_IO12, 0x0564, 0x0194, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__SRC_BOOT_CFG12, 0x0564, 0x0194, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__EPDC_DATA02, 0x0564, 0x0194, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__EIM_AD13, 0x0568, 0x0198, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__IPU1_DI1_D0_CS, 0x0568, 0x0198, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__GPIO3_IO13, 0x0568, 0x0198, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__SRC_BOOT_CFG13, 0x0568, 0x0198, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__EPDC_DATA13, 0x0568, 0x0198, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__EIM_AD14, 0x056C, 0x019C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__IPU1_DI1_D1_CS, 0x056C, 0x019C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__GPIO3_IO14, 0x056C, 0x019C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__SRC_BOOT_CFG14, 0x056C, 0x019C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__EPDC_DATA14, 0x056C, 0x019C, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__EIM_AD15, 0x0570, 0x01A0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN01, 0x0570, 0x01A0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN04, 0x0570, 0x01A0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__GPIO3_IO15, 0x0570, 0x01A0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__SRC_BOOT_CFG15, 0x0570, 0x01A0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__EPDC_DATA09, 0x0570, 0x01A0, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__EIM_AD02, 0x0574, 0x01A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__GPIO3_IO10, 0x055C, 0x018C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__SRC_BOOT_CFG10, 0x055C, 0x018C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__EPDC_DATA01, 0x055C, 0x018C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__EIM_AD11, 0x0560, 0x0190, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU1_DI1_PIN02, 0x0560, 0x0190, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU1_CSI1_HSYNC, 0x0560, 0x0190, 2, 0x08B4, 0, 0) +MX6_PAD_DECL(EIM_DA11__GPIO3_IO11, 0x0560, 0x0190, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__SRC_BOOT_CFG11, 0x0560, 0x0190, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__EPDC_DATA03, 0x0560, 0x0190, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__EIM_AD12, 0x0564, 0x0194, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU1_DI1_PIN03, 0x0564, 0x0194, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU1_CSI1_VSYNC, 0x0564, 0x0194, 2, 0x08BC, 1, 0) +MX6_PAD_DECL(EIM_DA12__GPIO3_IO12, 0x0564, 0x0194, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__SRC_BOOT_CFG12, 0x0564, 0x0194, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__EPDC_DATA02, 0x0564, 0x0194, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__EIM_AD13, 0x0568, 0x0198, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__IPU1_DI1_D0_CS, 0x0568, 0x0198, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__GPIO3_IO13, 0x0568, 0x0198, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__SRC_BOOT_CFG13, 0x0568, 0x0198, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__EPDC_DATA13, 0x0568, 0x0198, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__EIM_AD14, 0x056C, 0x019C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__IPU1_DI1_D1_CS, 0x056C, 0x019C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__GPIO3_IO14, 0x056C, 0x019C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__SRC_BOOT_CFG14, 0x056C, 0x019C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__EPDC_DATA14, 0x056C, 0x019C, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__EIM_AD15, 0x0570, 0x01A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN01, 0x0570, 0x01A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN04, 0x0570, 0x01A0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__GPIO3_IO15, 0x0570, 0x01A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__SRC_BOOT_CFG15, 0x0570, 0x01A0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__EPDC_DATA09, 0x0570, 0x01A0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__EIM_AD02, 0x0574, 0x01A4, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA2__IPU1_DISP1_DATA07, 0x0574, 0x01A4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__IPU1_CSI1_DATA07, 0x0574, 0x01A4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__GPIO3_IO02, 0x0574, 0x01A4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__SRC_BOOT_CFG02, 0x0574, 0x01A4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__EPDC_BDR0, 0x0574, 0x01A4, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__EIM_AD03, 0x0578, 0x01A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__IPU1_CSI1_DATA07, 0x0574, 0x01A4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__GPIO3_IO02, 0x0574, 0x01A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__SRC_BOOT_CFG02, 0x0574, 0x01A4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__EPDC_BDR0, 0x0574, 0x01A4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__EIM_AD03, 0x0578, 0x01A8, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA3__IPU1_DISP1_DATA06, 0x0578, 0x01A8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__IPU1_CSI1_DATA06, 0x0578, 0x01A8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__GPIO3_IO03, 0x0578, 0x01A8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__SRC_BOOT_CFG03, 0x0578, 0x01A8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__EPDC_BDR1, 0x0578, 0x01A8, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__EIM_AD04, 0x057C, 0x01AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__IPU1_CSI1_DATA06, 0x0578, 0x01A8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__GPIO3_IO03, 0x0578, 0x01A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__SRC_BOOT_CFG03, 0x0578, 0x01A8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__EPDC_BDR1, 0x0578, 0x01A8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__EIM_AD04, 0x057C, 0x01AC, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA4__IPU1_DISP1_DATA05, 0x057C, 0x01AC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__IPU1_CSI1_DATA05, 0x057C, 0x01AC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__GPIO3_IO04, 0x057C, 0x01AC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__SRC_BOOT_CFG04, 0x057C, 0x01AC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__EPDC_SDCE0, 0x057C, 0x01AC, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__EIM_AD05, 0x0580, 0x01B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__IPU1_CSI1_DATA05, 0x057C, 0x01AC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__GPIO3_IO04, 0x057C, 0x01AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__SRC_BOOT_CFG04, 0x057C, 0x01AC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__EPDC_SDCE0, 0x057C, 0x01AC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__EIM_AD05, 0x0580, 0x01B0, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA5__IPU1_DISP1_DATA04, 0x0580, 0x01B0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__IPU1_CSI1_DATA04, 0x0580, 0x01B0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__GPIO3_IO05, 0x0580, 0x01B0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__SRC_BOOT_CFG05, 0x0580, 0x01B0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__EPDC_SDCE1, 0x0580, 0x01B0, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__EIM_AD06, 0x0584, 0x01B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__IPU1_CSI1_DATA04, 0x0580, 0x01B0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__GPIO3_IO05, 0x0580, 0x01B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__SRC_BOOT_CFG05, 0x0580, 0x01B0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__EPDC_SDCE1, 0x0580, 0x01B0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__EIM_AD06, 0x0584, 0x01B4, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA6__IPU1_DISP1_DATA03, 0x0584, 0x01B4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__IPU1_CSI1_DATA03, 0x0584, 0x01B4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__GPIO3_IO06, 0x0584, 0x01B4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__SRC_BOOT_CFG06, 0x0584, 0x01B4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__EPDC_SDCE2, 0x0584, 0x01B4, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__EIM_AD07, 0x0588, 0x01B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__IPU1_CSI1_DATA03, 0x0584, 0x01B4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__GPIO3_IO06, 0x0584, 0x01B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__SRC_BOOT_CFG06, 0x0584, 0x01B4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__EPDC_SDCE2, 0x0584, 0x01B4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__EIM_AD07, 0x0588, 0x01B8, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA7__IPU1_DISP1_DATA02, 0x0588, 0x01B8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__IPU1_CSI1_DATA02, 0x0588, 0x01B8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__GPIO3_IO07, 0x0588, 0x01B8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__SRC_BOOT_CFG07, 0x0588, 0x01B8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__EPDC_SDCE3, 0x0588, 0x01B8, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__EIM_AD08, 0x058C, 0x01BC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__IPU1_CSI1_DATA02, 0x0588, 0x01B8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__GPIO3_IO07, 0x0588, 0x01B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__SRC_BOOT_CFG07, 0x0588, 0x01B8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__EPDC_SDCE3, 0x0588, 0x01B8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__EIM_AD08, 0x058C, 0x01BC, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA8__IPU1_DISP1_DATA01, 0x058C, 0x01BC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__IPU1_CSI1_DATA01, 0x058C, 0x01BC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__GPIO3_IO08, 0x058C, 0x01BC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__SRC_BOOT_CFG08, 0x058C, 0x01BC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__EPDC_SDCE4, 0x058C, 0x01BC, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__EIM_AD09, 0x0590, 0x01C0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__IPU1_CSI1_DATA01, 0x058C, 0x01BC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__GPIO3_IO08, 0x058C, 0x01BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__SRC_BOOT_CFG08, 0x058C, 0x01BC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__EPDC_SDCE4, 0x058C, 0x01BC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__EIM_AD09, 0x0590, 0x01C0, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA9__IPU1_DISP1_DATA00, 0x0590, 0x01C0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__IPU1_CSI1_DATA00, 0x0590, 0x01C0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__GPIO3_IO09, 0x0590, 0x01C0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__SRC_BOOT_CFG09, 0x0590, 0x01C0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__EPDC_SDCE5, 0x0590, 0x01C0, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__EIM_EB0_B, 0x0594, 0x01C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__IPU1_CSI1_DATA00, 0x0590, 0x01C0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__GPIO3_IO09, 0x0590, 0x01C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__SRC_BOOT_CFG09, 0x0590, 0x01C0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__EPDC_SDCE5, 0x0590, 0x01C0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__EIM_EB0_B, 0x0594, 0x01C4, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_EB0__IPU1_DISP1_DATA11, 0x0594, 0x01C4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__IPU1_CSI1_DATA11, 0x0594, 0x01C4, 2, 0x088C, 1, 0) -MX6_PAD_DECL(EIM_EB0__CCM_PMIC_READY, 0x0594, 0x01C4, 4, 0x07D4, 0, 0) -MX6_PAD_DECL(EIM_EB0__GPIO2_IO28, 0x0594, 0x01C4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__SRC_BOOT_CFG27, 0x0594, 0x01C4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__EPDC_PWR_COM, 0x0594, 0x01C4, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__EIM_EB1_B, 0x0598, 0x01C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__IPU1_CSI1_DATA11, 0x0594, 0x01C4, 2, 0x088C, 1, 0) +MX6_PAD_DECL(EIM_EB0__CCM_PMIC_READY, 0x0594, 0x01C4, 4, 0x07D4, 0, 0) +MX6_PAD_DECL(EIM_EB0__GPIO2_IO28, 0x0594, 0x01C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__SRC_BOOT_CFG27, 0x0594, 0x01C4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__EPDC_PWR_COM, 0x0594, 0x01C4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__EIM_EB1_B, 0x0598, 0x01C8, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_EB1__IPU1_DISP1_DATA10, 0x0598, 0x01C8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__IPU1_CSI1_DATA10, 0x0598, 0x01C8, 2, 0x0888, 1, 0) -MX6_PAD_DECL(EIM_EB1__GPIO2_IO29, 0x0598, 0x01C8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__SRC_BOOT_CFG28, 0x0598, 0x01C8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__EPDC_SDSHR, 0x0598, 0x01C8, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB2__EIM_EB2_B, 0x059C, 0x01CC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB2__ECSPI1_SS0, 0x059C, 0x01CC, 1, 0x07E4, 2, 0) -MX6_PAD_DECL(EIM_EB2__IPU1_CSI1_DATA19, 0x059C, 0x01CC, 3, 0x08AC, 1, 0) -MX6_PAD_DECL(EIM_EB2__HDMI_TX_DDC_SCL, 0x059C, 0x01CC, 4, 0x0860, 0, 0) -MX6_PAD_DECL(EIM_EB2__GPIO2_IO30, 0x059C, 0x01CC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB2__I2C2_SCL, 0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0) -MX6_PAD_DECL(EIM_EB2__SRC_BOOT_CFG30, 0x059C, 0x01CC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB2__EPDC_DATA05, 0x059C, 0x01CC, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__EIM_EB3_B, 0x05A0, 0x01D0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__ECSPI4_RDY, 0x05A0, 0x01D0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__UART3_CTS_B, 0x05A0, 0x01D0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__UART3_RTS_B, 0x05A0, 0x01D0, 2, 0x0908, 3, 0) -MX6_PAD_DECL(EIM_EB3__UART1_RI_B, 0x05A0, 0x01D0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__IPU1_CSI1_HSYNC, 0x05A0, 0x01D0, 4, 0x08B4, 1, 0) -MX6_PAD_DECL(EIM_EB3__GPIO2_IO31, 0x05A0, 0x01D0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__IPU1_DI1_PIN03, 0x05A0, 0x01D0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__SRC_BOOT_CFG31, 0x05A0, 0x01D0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__EPDC_SDCE0, 0x05A0, 0x01D0, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__EIM_ACLK_FREERUN, 0x05A0, 0x01D0, 9, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__EIM_LBA_B, 0x05A4, 0x01D4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__IPU1_DI1_PIN17, 0x05A4, 0x01D4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__ECSPI2_SS1, 0x05A4, 0x01D4, 2, 0x0804, 1, 0) -MX6_PAD_DECL(EIM_LBA__GPIO2_IO27, 0x05A4, 0x01D4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__SRC_BOOT_CFG26, 0x05A4, 0x01D4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__EPDC_DATA04, 0x05A4, 0x01D4, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__EIM_OE_B, 0x05A8, 0x01D8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__IPU1_DI1_PIN07, 0x05A8, 0x01D8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__ECSPI2_MISO, 0x05A8, 0x01D8, 2, 0x07F8, 2, 0) -MX6_PAD_DECL(EIM_OE__GPIO2_IO25, 0x05A8, 0x01D8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__EPDC_PWR_IRQ, 0x05A8, 0x01D8, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__EIM_RW, 0x05AC, 0x01DC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__IPU1_DI1_PIN08, 0x05AC, 0x01DC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__ECSPI2_SS0, 0x05AC, 0x01DC, 2, 0x0800, 2, 0) -MX6_PAD_DECL(EIM_RW__GPIO2_IO26, 0x05AC, 0x01DC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__SRC_BOOT_CFG29, 0x05AC, 0x01DC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__EPDC_DATA07, 0x05AC, 0x01DC, 8, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__EIM_WAIT_B, 0x05B0, 0x01E0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__EIM_DTACK_B, 0x05B0, 0x01E0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__GPIO5_IO00, 0x05B0, 0x01E0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__SRC_BOOT_CFG25, 0x05B0, 0x01E0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_CRS_DV__ENET_RX_EN, 0x05B4, 0x01E4, 1, 0x0828, 0, 0) -MX6_PAD_DECL(ENET_CRS_DV__ESAI_TX_CLK, 0x05B4, 0x01E4, 2, 0x0840, 0, 0) +MX6_PAD_DECL(EIM_EB1__IPU1_CSI1_DATA10, 0x0598, 0x01C8, 2, 0x0888, 1, 0) +MX6_PAD_DECL(EIM_EB1__GPIO2_IO29, 0x0598, 0x01C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__SRC_BOOT_CFG28, 0x0598, 0x01C8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__EPDC_SDSHR, 0x0598, 0x01C8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__EIM_EB2_B, 0x059C, 0x01CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__ECSPI1_SS0, 0x059C, 0x01CC, 1, 0x07E4, 2, 0) +MX6_PAD_DECL(EIM_EB2__IPU1_CSI1_DATA19, 0x059C, 0x01CC, 3, 0x08AC, 1, 0) +MX6_PAD_DECL(EIM_EB2__HDMI_TX_DDC_SCL, 0x059C, 0x01CC, 4, 0x0860, 0, 0) +MX6_PAD_DECL(EIM_EB2__GPIO2_IO30, 0x059C, 0x01CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__I2C2_SCL, 0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0) +MX6_PAD_DECL(EIM_EB2__SRC_BOOT_CFG30, 0x059C, 0x01CC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__EPDC_DATA05, 0x059C, 0x01CC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EIM_EB3_B, 0x05A0, 0x01D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__ECSPI4_RDY, 0x05A0, 0x01D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_CTS_B, 0x05A0, 0x01D0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_RTS_B, 0x05A0, 0x01D0, 2, 0x0908, 3, 0) +MX6_PAD_DECL(EIM_EB3__UART1_RI_B, 0x05A0, 0x01D0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU1_CSI1_HSYNC, 0x05A0, 0x01D0, 4, 0x08B4, 1, 0) +MX6_PAD_DECL(EIM_EB3__GPIO2_IO31, 0x05A0, 0x01D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU1_DI1_PIN03, 0x05A0, 0x01D0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__SRC_BOOT_CFG31, 0x05A0, 0x01D0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EPDC_SDCE0, 0x05A0, 0x01D0, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EIM_ACLK_FREERUN, 0x05A0, 0x01D0, 9, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__EIM_LBA_B, 0x05A4, 0x01D4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__IPU1_DI1_PIN17, 0x05A4, 0x01D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__ECSPI2_SS1, 0x05A4, 0x01D4, 2, 0x0804, 1, 0) +MX6_PAD_DECL(EIM_LBA__GPIO2_IO27, 0x05A4, 0x01D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__SRC_BOOT_CFG26, 0x05A4, 0x01D4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__EPDC_DATA04, 0x05A4, 0x01D4, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__EIM_OE_B, 0x05A8, 0x01D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__IPU1_DI1_PIN07, 0x05A8, 0x01D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__ECSPI2_MISO, 0x05A8, 0x01D8, 2, 0x07F8, 2, 0) +MX6_PAD_DECL(EIM_OE__GPIO2_IO25, 0x05A8, 0x01D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__EPDC_PWR_IRQ, 0x05A8, 0x01D8, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__EIM_RW, 0x05AC, 0x01DC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__IPU1_DI1_PIN08, 0x05AC, 0x01DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__ECSPI2_SS0, 0x05AC, 0x01DC, 2, 0x0800, 2, 0) +MX6_PAD_DECL(EIM_RW__GPIO2_IO26, 0x05AC, 0x01DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__SRC_BOOT_CFG29, 0x05AC, 0x01DC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__EPDC_DATA07, 0x05AC, 0x01DC, 8, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_WAIT_B, 0x05B0, 0x01E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_DTACK_B, 0x05B0, 0x01E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__GPIO5_IO00, 0x05B0, 0x01E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__SRC_BOOT_CFG25, 0x05B0, 0x01E0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__ENET_RX_EN, 0x05B4, 0x01E4, 1, 0x0828, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__ESAI_TX_CLK, 0x05B4, 0x01E4, 2, 0x0840, 0, 0) MX6_PAD_DECL(ENET_CRS_DV__SPDIF_EXT_CLK, 0x05B4, 0x01E4, 3, 0x08F4, 0, 0) -MX6_PAD_DECL(ENET_CRS_DV__GPIO1_IO25, 0x05B4, 0x01E4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDC__MLB_DATA, 0x05B8, 0x01E8, 0, 0x08E0, 0, 0) -MX6_PAD_DECL(ENET_MDC__ENET_MDC, 0x05B8, 0x01E8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDC__ESAI_TX5_RX0, 0x05B8, 0x01E8, 2, 0x0858, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__GPIO1_IO25, 0x05B4, 0x01E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__MLB_DATA, 0x05B8, 0x01E8, 0, 0x08E0, 0, 0) +MX6_PAD_DECL(ENET_MDC__ENET_MDC, 0x05B8, 0x01E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__ESAI_TX5_RX0, 0x05B8, 0x01E8, 2, 0x0858, 0, 0) MX6_PAD_DECL(ENET_MDC__ENET_1588_EVENT1_IN, 0x05B8, 0x01E8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDC__GPIO1_IO31, 0x05B8, 0x01E8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDIO__ENET_MDIO, 0x05BC, 0x01EC, 1, 0x0810, 0, 0) -MX6_PAD_DECL(ENET_MDIO__ESAI_RX_CLK, 0x05BC, 0x01EC, 2, 0x083C, 0, 0) +MX6_PAD_DECL(ENET_MDC__GPIO1_IO31, 0x05B8, 0x01E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ENET_MDIO, 0x05BC, 0x01EC, 1, 0x0810, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ESAI_RX_CLK, 0x05BC, 0x01EC, 2, 0x083C, 0, 0) MX6_PAD_DECL(ENET_MDIO__ENET_1588_EVENT1_OUT, 0x05BC, 0x01EC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDIO__GPIO1_IO22, 0x05BC, 0x01EC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDIO__SPDIF_LOCK, 0x05BC, 0x01EC, 6, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_REF_CLK__ENET_TX_CLK, 0x05C0, 0x01F0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_REF_CLK__ESAI_RX_FS, 0x05C0, 0x01F0, 2, 0x082C, 0, 0) -MX6_PAD_DECL(ENET_REF_CLK__GPIO1_IO23, 0x05C0, 0x01F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__GPIO1_IO22, 0x05BC, 0x01EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__SPDIF_LOCK, 0x05BC, 0x01EC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ENET_TX_CLK, 0x05C0, 0x01F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ESAI_RX_FS, 0x05C0, 0x01F0, 2, 0x082C, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__GPIO1_IO23, 0x05C0, 0x01F0, 5, 0x0000, 0, 0) MX6_PAD_DECL(ENET_REF_CLK__SPDIF_SR_CLK, 0x05C0, 0x01F0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__USB_OTG_ID, 0x05C4, 0x01F4, 0, 0x0790, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__ENET_RX_ER, 0x05C4, 0x01F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__USB_OTG_ID, 0x05C4, 0x01F4, 0, 0x0790, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__ENET_RX_ER, 0x05C4, 0x01F4, 1, 0x0000, 0, 0) MX6_PAD_DECL(ENET_RX_ER__ESAI_RX_HF_CLK, 0x05C4, 0x01F4, 2, 0x0834, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__SPDIF_IN, 0x05C4, 0x01F4, 3, 0x08F0, 1, 0) +MX6_PAD_DECL(ENET_RX_ER__SPDIF_IN, 0x05C4, 0x01F4, 3, 0x08F0, 1, 0) MX6_PAD_DECL(ENET_RX_ER__ENET_1588_EVENT2_OUT, 0x05C4, 0x01F4, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__GPIO1_IO24, 0x05C4, 0x01F4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD0__ENET_RX_DATA0, 0x05C8, 0x01F8, 1, 0x0818, 0, 0) -MX6_PAD_DECL(ENET_RXD0__ESAI_TX_HF_CLK, 0x05C8, 0x01F8, 2, 0x0838, 0, 0) -MX6_PAD_DECL(ENET_RXD0__SPDIF_OUT, 0x05C8, 0x01F8, 3, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD0__GPIO1_IO27, 0x05C8, 0x01F8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD1__MLB_SIG, 0x05CC, 0x01FC, 0, 0x08E4, 0, 0) -MX6_PAD_DECL(ENET_RXD1__ENET_RX_DATA1, 0x05CC, 0x01FC, 1, 0x081C, 0, 0) -MX6_PAD_DECL(ENET_RXD1__ESAI_TX_FS, 0x05CC, 0x01FC, 2, 0x0830, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__GPIO1_IO24, 0x05C4, 0x01F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__ENET_RX_DATA0, 0x05C8, 0x01F8, 1, 0x0818, 0, 0) +MX6_PAD_DECL(ENET_RXD0__ESAI_TX_HF_CLK, 0x05C8, 0x01F8, 2, 0x0838, 0, 0) +MX6_PAD_DECL(ENET_RXD0__SPDIF_OUT, 0x05C8, 0x01F8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__GPIO1_IO27, 0x05C8, 0x01F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD1__MLB_SIG, 0x05CC, 0x01FC, 0, 0x08E4, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ENET_RX_DATA1, 0x05CC, 0x01FC, 1, 0x081C, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ESAI_TX_FS, 0x05CC, 0x01FC, 2, 0x0830, 0, 0) MX6_PAD_DECL(ENET_RXD1__ENET_1588_EVENT3_OUT, 0x05CC, 0x01FC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD1__GPIO1_IO26, 0x05CC, 0x01FC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__ENET_TX_EN, 0x05D0, 0x0200, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__ESAI_TX3_RX2, 0x05D0, 0x0200, 2, 0x0850, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__GPIO1_IO28, 0x05D0, 0x0200, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__I2C4_SCL, 0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0) -MX6_PAD_DECL(ENET_TXD0__ENET_TX_DATA0, 0x05D4, 0x0204, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD0__ESAI_TX4_RX1, 0x05D4, 0x0204, 2, 0x0854, 0, 0) -MX6_PAD_DECL(ENET_TXD0__GPIO1_IO30, 0x05D4, 0x0204, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__MLB_CLK, 0x05D8, 0x0208, 0, 0x08DC, 0, 0) -MX6_PAD_DECL(ENET_TXD1__ENET_TX_DATA1, 0x05D8, 0x0208, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__ESAI_TX2_RX3, 0x05D8, 0x0208, 2, 0x084C, 0, 0) +MX6_PAD_DECL(ENET_RXD1__GPIO1_IO26, 0x05CC, 0x01FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ENET_TX_EN, 0x05D0, 0x0200, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ESAI_TX3_RX2, 0x05D0, 0x0200, 2, 0x0850, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__GPIO1_IO28, 0x05D0, 0x0200, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__I2C4_SCL, 0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ENET_TX_DATA0, 0x05D4, 0x0204, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ESAI_TX4_RX1, 0x05D4, 0x0204, 2, 0x0854, 0, 0) +MX6_PAD_DECL(ENET_TXD0__GPIO1_IO30, 0x05D4, 0x0204, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__MLB_CLK, 0x05D8, 0x0208, 0, 0x08DC, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ENET_TX_DATA1, 0x05D8, 0x0208, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ESAI_TX2_RX3, 0x05D8, 0x0208, 2, 0x084C, 0, 0) MX6_PAD_DECL(ENET_TXD1__ENET_1588_EVENT0_IN, 0x05D8, 0x0208, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__GPIO1_IO29, 0x05D8, 0x0208, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__I2C4_SDA, 0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0) -MX6_PAD_DECL(GPIO_0__CCM_CLKO1, 0x05DC, 0x020C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__KEY_COL5, 0x05DC, 0x020C, 2, 0x08C0, 1, 0) -MX6_PAD_DECL(GPIO_0__ASRC_EXT_CLK, 0x05DC, 0x020C, 3, 0x0794, 0, 0) -MX6_PAD_DECL(GPIO_0__EPIT1_OUT, 0x05DC, 0x020C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__GPIO1_IO00, 0x05DC, 0x020C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__USB_H1_PWR, 0x05DC, 0x020C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__SNVS_VIO_5, 0x05DC, 0x020C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__ESAI_RX_CLK, 0x05E0, 0x0210, 0, 0x083C, 1, 0) -MX6_PAD_DECL(GPIO_1__WDOG2_B, 0x05E0, 0x0210, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__KEY_ROW5, 0x05E0, 0x0210, 2, 0x08CC, 1, 0) -MX6_PAD_DECL(GPIO_1__USB_OTG_ID, 0x05E0, 0x0210, 3, 0x0790, 1, 0) -MX6_PAD_DECL(GPIO_1__PWM2_OUT, 0x05E0, 0x0210, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__GPIO1_IO01, 0x05E0, 0x0210, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__SD1_CD_B, 0x05E0, 0x0210, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__ESAI_TX3_RX2, 0x05E4, 0x0214, 0, 0x0850, 1, 0) +MX6_PAD_DECL(ENET_TXD1__GPIO1_IO29, 0x05D8, 0x0208, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__I2C4_SDA, 0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0) +MX6_PAD_DECL(GPIO_0__CCM_CLKO1, 0x05DC, 0x020C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__KEY_COL5, 0x05DC, 0x020C, 2, 0x08C0, 1, 0) +MX6_PAD_DECL(GPIO_0__ASRC_EXT_CLK, 0x05DC, 0x020C, 3, 0x0794, 0, 0) +MX6_PAD_DECL(GPIO_0__EPIT1_OUT, 0x05DC, 0x020C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__GPIO1_IO00, 0x05DC, 0x020C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__USB_H1_PWR, 0x05DC, 0x020C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__SNVS_VIO_5, 0x05DC, 0x020C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__ESAI_RX_CLK, 0x05E0, 0x0210, 0, 0x083C, 1, 0) +MX6_PAD_DECL(GPIO_1__WDOG2_B, 0x05E0, 0x0210, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__KEY_ROW5, 0x05E0, 0x0210, 2, 0x08CC, 1, 0) +MX6_PAD_DECL(GPIO_1__USB_OTG_ID, 0x05E0, 0x0210, 3, 0x0790, 1, 0) +MX6_PAD_DECL(GPIO_1__PWM2_OUT, 0x05E0, 0x0210, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__GPIO1_IO01, 0x05E0, 0x0210, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__SD1_CD_B, 0x05E0, 0x0210, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__ESAI_TX3_RX2, 0x05E4, 0x0214, 0, 0x0850, 1, 0) MX6_PAD_DECL(GPIO_16__ENET_1588_EVENT2_IN, 0x05E4, 0x0214, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__ENET_REF_CLK, 0x05E4, 0x0214, 2, 0x080C, 0, 0) -MX6_PAD_DECL(GPIO_16__SD1_LCTL, 0x05E4, 0x0214, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__SPDIF_IN, 0x05E4, 0x0214, 4, 0x08F0, 2, 0) -MX6_PAD_DECL(GPIO_16__GPIO7_IO11, 0x05E4, 0x0214, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__I2C3_SDA, 0x05E4, 0x0214, 6 | IOMUX_CONFIG_SION, 0x087C, 1, 0) -MX6_PAD_DECL(GPIO_16__JTAG_DE_B, 0x05E4, 0x0214, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_17__ESAI_TX0, 0x05E8, 0x0218, 0, 0x0844, 0, 0) +MX6_PAD_DECL(GPIO_16__ENET_REF_CLK, 0x05E4, 0x0214, 2, 0x080C, 0, 0) +MX6_PAD_DECL(GPIO_16__SD1_LCTL, 0x05E4, 0x0214, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__SPDIF_IN, 0x05E4, 0x0214, 4, 0x08F0, 2, 0) +MX6_PAD_DECL(GPIO_16__GPIO7_IO11, 0x05E4, 0x0214, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__I2C3_SDA, 0x05E4, 0x0214, 6 | IOMUX_CONFIG_SION, 0x087C, 1, 0) +MX6_PAD_DECL(GPIO_16__JTAG_DE_B, 0x05E4, 0x0214, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__ESAI_TX0, 0x05E8, 0x0218, 0, 0x0844, 0, 0) MX6_PAD_DECL(GPIO_17__ENET_1588_EVENT3_IN, 0x05E8, 0x0218, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_17__CCM_PMIC_READY, 0x05E8, 0x0218, 2, 0x07D4, 1, 0) -MX6_PAD_DECL(GPIO_17__SDMA_EXT_EVENT0, 0x05E8, 0x0218, 3, 0x08E8, 1, 0) -MX6_PAD_DECL(GPIO_17__SPDIF_OUT, 0x05E8, 0x0218, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_17__GPIO7_IO12, 0x05E8, 0x0218, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_18__ESAI_TX1, 0x05EC, 0x021C, 0, 0x0848, 0, 0) -MX6_PAD_DECL(GPIO_18__ENET_RX_CLK, 0x05EC, 0x021C, 1, 0x0814, 0, 0) -MX6_PAD_DECL(GPIO_18__SD3_VSELECT, 0x05EC, 0x021C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_18__SDMA_EXT_EVENT1, 0x05EC, 0x021C, 3, 0x08EC, 1, 0) -MX6_PAD_DECL(GPIO_18__ASRC_EXT_CLK, 0x05EC, 0x021C, 4, 0x0794, 1, 0) -MX6_PAD_DECL(GPIO_18__GPIO7_IO13, 0x05EC, 0x021C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_18__SNVS_VIO_5_CTL, 0x05EC, 0x021C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__KEY_COL5, 0x05F0, 0x0220, 0, 0x08C0, 2, 0) +MX6_PAD_DECL(GPIO_17__CCM_PMIC_READY, 0x05E8, 0x0218, 2, 0x07D4, 1, 0) +MX6_PAD_DECL(GPIO_17__SDMA_EXT_EVENT0, 0x05E8, 0x0218, 3, 0x08E8, 1, 0) +MX6_PAD_DECL(GPIO_17__SPDIF_OUT, 0x05E8, 0x0218, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__GPIO7_IO12, 0x05E8, 0x0218, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__ESAI_TX1, 0x05EC, 0x021C, 0, 0x0848, 0, 0) +MX6_PAD_DECL(GPIO_18__ENET_RX_CLK, 0x05EC, 0x021C, 1, 0x0814, 0, 0) +MX6_PAD_DECL(GPIO_18__SD3_VSELECT, 0x05EC, 0x021C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SDMA_EXT_EVENT1, 0x05EC, 0x021C, 3, 0x08EC, 1, 0) +MX6_PAD_DECL(GPIO_18__ASRC_EXT_CLK, 0x05EC, 0x021C, 4, 0x0794, 1, 0) +MX6_PAD_DECL(GPIO_18__GPIO7_IO13, 0x05EC, 0x021C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SNVS_VIO_5_CTL, 0x05EC, 0x021C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__KEY_COL5, 0x05F0, 0x0220, 0, 0x08C0, 2, 0) MX6_PAD_DECL(GPIO_19__ENET_1588_EVENT0_OUT, 0x05F0, 0x0220, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__SPDIF_OUT, 0x05F0, 0x0220, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__CCM_CLKO1, 0x05F0, 0x0220, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__ECSPI1_RDY, 0x05F0, 0x0220, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__GPIO4_IO05, 0x05F0, 0x0220, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__ENET_TX_ER, 0x05F0, 0x0220, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_2__ESAI_TX_FS, 0x05F4, 0x0224, 0, 0x0830, 1, 0) -MX6_PAD_DECL(GPIO_2__KEY_ROW6, 0x05F4, 0x0224, 2, 0x08D0, 1, 0) -MX6_PAD_DECL(GPIO_2__GPIO1_IO02, 0x05F4, 0x0224, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_2__SD2_WP, 0x05F4, 0x0224, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_2__MLB_DATA, 0x05F4, 0x0224, 7, 0x08E0, 1, 0) -MX6_PAD_DECL(GPIO_3__ESAI_RX_HF_CLK, 0x05F8, 0x0228, 0, 0x0834, 1, 0) -MX6_PAD_DECL(GPIO_3__I2C3_SCL, 0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0) +MX6_PAD_DECL(GPIO_19__SPDIF_OUT, 0x05F0, 0x0220, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__CCM_CLKO1, 0x05F0, 0x0220, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ECSPI1_RDY, 0x05F0, 0x0220, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__GPIO4_IO05, 0x05F0, 0x0220, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ENET_TX_ER, 0x05F0, 0x0220, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__ESAI_TX_FS, 0x05F4, 0x0224, 0, 0x0830, 1, 0) +MX6_PAD_DECL(GPIO_2__KEY_ROW6, 0x05F4, 0x0224, 2, 0x08D0, 1, 0) +MX6_PAD_DECL(GPIO_2__GPIO1_IO02, 0x05F4, 0x0224, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__SD2_WP, 0x05F4, 0x0224, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__MLB_DATA, 0x05F4, 0x0224, 7, 0x08E0, 1, 0) +MX6_PAD_DECL(GPIO_3__ESAI_RX_HF_CLK, 0x05F8, 0x0228, 0, 0x0834, 1, 0) +MX6_PAD_DECL(GPIO_3__I2C3_SCL, 0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0) MX6_PAD_DECL(GPIO_3__XTALOSC_REF_CLK_24M, 0x05F8, 0x0228, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_3__CCM_CLKO2, 0x05F8, 0x0228, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_3__GPIO1_IO03, 0x05F8, 0x0228, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_3__USB_H1_OC, 0x05F8, 0x0228, 6, 0x0924, 1, 0) -MX6_PAD_DECL(GPIO_3__MLB_CLK, 0x05F8, 0x0228, 7, 0x08DC, 1, 0) -MX6_PAD_DECL(GPIO_4__ESAI_TX_HF_CLK, 0x05FC, 0x022C, 0, 0x0838, 1, 0) -MX6_PAD_DECL(GPIO_4__KEY_COL7, 0x05FC, 0x022C, 2, 0x08C8, 1, 0) -MX6_PAD_DECL(GPIO_4__GPIO1_IO04, 0x05FC, 0x022C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_4__SD2_CD_B, 0x05FC, 0x022C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_5__ESAI_TX2_RX3, 0x0600, 0x0230, 0, 0x084C, 1, 0) -MX6_PAD_DECL(GPIO_5__KEY_ROW7, 0x0600, 0x0230, 2, 0x08D4, 1, 0) -MX6_PAD_DECL(GPIO_5__CCM_CLKO1, 0x0600, 0x0230, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_5__GPIO1_IO05, 0x0600, 0x0230, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_5__I2C3_SCL, 0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0) -MX6_PAD_DECL(GPIO_5__ARM_EVENTI, 0x0600, 0x0230, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_6__ESAI_TX_CLK, 0x0604, 0x0234, 0, 0x0840, 1, 0) -MX6_PAD_DECL(GPIO_6__I2C3_SDA, 0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0) -MX6_PAD_DECL(GPIO_6__GPIO1_IO06, 0x0604, 0x0234, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_6__SD2_LCTL, 0x0604, 0x0234, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_6__MLB_SIG, 0x0604, 0x0234, 7, 0x08E4, 1, 0) -MX6_PAD_DECL(GPIO_7__ESAI_TX4_RX1, 0x0608, 0x0238, 0, 0x0854, 1, 0) -MX6_PAD_DECL(GPIO_7__EPIT1_OUT, 0x0608, 0x0238, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__FLEXCAN1_TX, 0x0608, 0x0238, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__UART2_TX_DATA, 0x0608, 0x0238, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__UART2_RX_DATA, 0x0608, 0x0238, 4, 0x0904, 2, 0) -MX6_PAD_DECL(GPIO_7__GPIO1_IO07, 0x0608, 0x0238, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__SPDIF_LOCK, 0x0608, 0x0238, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__USB_OTG_HOST_MODE, 0x0608, 0x0238, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__I2C4_SCL, 0x0608, 0x0238, 8 | IOMUX_CONFIG_SION, 0x0880, 1, 0) -MX6_PAD_DECL(GPIO_8__ESAI_TX5_RX0, 0x060C, 0x023C, 0, 0x0858, 1, 0) +MX6_PAD_DECL(GPIO_3__CCM_CLKO2, 0x05F8, 0x0228, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__GPIO1_IO03, 0x05F8, 0x0228, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__USB_H1_OC, 0x05F8, 0x0228, 6, 0x0924, 1, 0) +MX6_PAD_DECL(GPIO_3__MLB_CLK, 0x05F8, 0x0228, 7, 0x08DC, 1, 0) +MX6_PAD_DECL(GPIO_4__ESAI_TX_HF_CLK, 0x05FC, 0x022C, 0, 0x0838, 1, 0) +MX6_PAD_DECL(GPIO_4__KEY_COL7, 0x05FC, 0x022C, 2, 0x08C8, 1, 0) +MX6_PAD_DECL(GPIO_4__GPIO1_IO04, 0x05FC, 0x022C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_4__SD2_CD_B, 0x05FC, 0x022C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__ESAI_TX2_RX3, 0x0600, 0x0230, 0, 0x084C, 1, 0) +MX6_PAD_DECL(GPIO_5__KEY_ROW7, 0x0600, 0x0230, 2, 0x08D4, 1, 0) +MX6_PAD_DECL(GPIO_5__CCM_CLKO1, 0x0600, 0x0230, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__GPIO1_IO05, 0x0600, 0x0230, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__I2C3_SCL, 0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0) +MX6_PAD_DECL(GPIO_5__ARM_EVENTI, 0x0600, 0x0230, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__ESAI_TX_CLK, 0x0604, 0x0234, 0, 0x0840, 1, 0) +MX6_PAD_DECL(GPIO_6__I2C3_SDA, 0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0) +MX6_PAD_DECL(GPIO_6__GPIO1_IO06, 0x0604, 0x0234, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__SD2_LCTL, 0x0604, 0x0234, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__MLB_SIG, 0x0604, 0x0234, 7, 0x08E4, 1, 0) +MX6_PAD_DECL(GPIO_7__ESAI_TX4_RX1, 0x0608, 0x0238, 0, 0x0854, 1, 0) +MX6_PAD_DECL(GPIO_7__EPIT1_OUT, 0x0608, 0x0238, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__FLEXCAN1_TX, 0x0608, 0x0238, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_TX_DATA, 0x0608, 0x0238, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_RX_DATA, 0x0608, 0x0238, 4, 0x0904, 2, 0) +MX6_PAD_DECL(GPIO_7__GPIO1_IO07, 0x0608, 0x0238, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__SPDIF_LOCK, 0x0608, 0x0238, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__USB_OTG_HOST_MODE, 0x0608, 0x0238, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__I2C4_SCL, 0x0608, 0x0238, 8 | IOMUX_CONFIG_SION, 0x0880, 1, 0) +MX6_PAD_DECL(GPIO_8__ESAI_TX5_RX0, 0x060C, 0x023C, 0, 0x0858, 1, 0) MX6_PAD_DECL(GPIO_8__XTALOSC_REF_CLK_32K, 0x060C, 0x023C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__EPIT2_OUT, 0x060C, 0x023C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__FLEXCAN1_RX, 0x060C, 0x023C, 3, 0x07C8, 0, 0) -MX6_PAD_DECL(GPIO_8__UART2_TX_DATA, 0x060C, 0x023C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__UART2_RX_DATA, 0x060C, 0x023C, 4, 0x0904, 3, 0) -MX6_PAD_DECL(GPIO_8__GPIO1_IO08, 0x060C, 0x023C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__SPDIF_SR_CLK, 0x060C, 0x023C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__EPIT2_OUT, 0x060C, 0x023C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__FLEXCAN1_RX, 0x060C, 0x023C, 3, 0x07C8, 0, 0) +MX6_PAD_DECL(GPIO_8__UART2_TX_DATA, 0x060C, 0x023C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__UART2_RX_DATA, 0x060C, 0x023C, 4, 0x0904, 3, 0) +MX6_PAD_DECL(GPIO_8__GPIO1_IO08, 0x060C, 0x023C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__SPDIF_SR_CLK, 0x060C, 0x023C, 6, 0x0000, 0, 0) MX6_PAD_DECL(GPIO_8__USB_OTG_PWR_CTL_WAKE, 0x060C, 0x023C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__I2C4_SDA, 0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0) -MX6_PAD_DECL(GPIO_9__ESAI_RX_FS, 0x0610, 0x0240, 0, 0x082C, 1, 0) -MX6_PAD_DECL(GPIO_9__WDOG1_B, 0x0610, 0x0240, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__KEY_COL6, 0x0610, 0x0240, 2, 0x08C4, 1, 0) -MX6_PAD_DECL(GPIO_9__CCM_REF_EN_B, 0x0610, 0x0240, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__PWM1_OUT, 0x0610, 0x0240, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__GPIO1_IO09, 0x0610, 0x0240, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__SD1_WP, 0x0610, 0x0240, 6, 0x092C, 1, 0) -MX6_PAD_DECL(KEY_COL0__ECSPI1_SCLK, 0x062C, 0x0244, 0, 0x07D8, 3, 0) -MX6_PAD_DECL(KEY_COL0__ENET_RX_DATA3, 0x062C, 0x0244, 1, 0x0824, 0, 0) -MX6_PAD_DECL(KEY_COL0__AUD5_TXC, 0x062C, 0x0244, 2, 0x07C0, 1, 0) -MX6_PAD_DECL(KEY_COL0__KEY_COL0, 0x062C, 0x0244, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__UART4_TX_DATA, 0x062C, 0x0244, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__UART4_RX_DATA, 0x062C, 0x0244, 4, 0x0914, 2, 0) -MX6_PAD_DECL(KEY_COL0__GPIO4_IO06, 0x062C, 0x0244, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__DCIC1_OUT, 0x062C, 0x0244, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__ECSPI1_MISO, 0x0630, 0x0248, 0, 0x07DC, 3, 0) -MX6_PAD_DECL(KEY_COL1__ENET_MDIO, 0x0630, 0x0248, 1, 0x0810, 1, 0) -MX6_PAD_DECL(KEY_COL1__AUD5_TXFS, 0x0630, 0x0248, 2, 0x07C4, 1, 0) -MX6_PAD_DECL(KEY_COL1__KEY_COL1, 0x0630, 0x0248, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__UART5_TX_DATA, 0x0630, 0x0248, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__UART5_RX_DATA, 0x0630, 0x0248, 4, 0x091C, 2, 0) -MX6_PAD_DECL(KEY_COL1__GPIO4_IO08, 0x0630, 0x0248, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__SD1_VSELECT, 0x0630, 0x0248, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__ECSPI1_SS1, 0x0634, 0x024C, 0, 0x07E8, 2, 0) -MX6_PAD_DECL(KEY_COL2__ENET_RX_DATA2, 0x0634, 0x024C, 1, 0x0820, 0, 0) -MX6_PAD_DECL(KEY_COL2__FLEXCAN1_TX, 0x0634, 0x024C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__KEY_COL2, 0x0634, 0x024C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__ENET_MDC, 0x0634, 0x024C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__GPIO4_IO10, 0x0634, 0x024C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__I2C4_SDA, 0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0) +MX6_PAD_DECL(GPIO_9__ESAI_RX_FS, 0x0610, 0x0240, 0, 0x082C, 1, 0) +MX6_PAD_DECL(GPIO_9__WDOG1_B, 0x0610, 0x0240, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__KEY_COL6, 0x0610, 0x0240, 2, 0x08C4, 1, 0) +MX6_PAD_DECL(GPIO_9__CCM_REF_EN_B, 0x0610, 0x0240, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__PWM1_OUT, 0x0610, 0x0240, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__GPIO1_IO09, 0x0610, 0x0240, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__SD1_WP, 0x0610, 0x0240, 6, 0x092C, 1, 0) +MX6_PAD_DECL(KEY_COL0__ECSPI1_SCLK, 0x062C, 0x0244, 0, 0x07D8, 3, 0) +MX6_PAD_DECL(KEY_COL0__ENET_RX_DATA3, 0x062C, 0x0244, 1, 0x0824, 0, 0) +MX6_PAD_DECL(KEY_COL0__AUD5_TXC, 0x062C, 0x0244, 2, 0x07C0, 1, 0) +MX6_PAD_DECL(KEY_COL0__KEY_COL0, 0x062C, 0x0244, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_TX_DATA, 0x062C, 0x0244, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_RX_DATA, 0x062C, 0x0244, 4, 0x0914, 2, 0) +MX6_PAD_DECL(KEY_COL0__GPIO4_IO06, 0x062C, 0x0244, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__DCIC1_OUT, 0x062C, 0x0244, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__ECSPI1_MISO, 0x0630, 0x0248, 0, 0x07DC, 3, 0) +MX6_PAD_DECL(KEY_COL1__ENET_MDIO, 0x0630, 0x0248, 1, 0x0810, 1, 0) +MX6_PAD_DECL(KEY_COL1__AUD5_TXFS, 0x0630, 0x0248, 2, 0x07C4, 1, 0) +MX6_PAD_DECL(KEY_COL1__KEY_COL1, 0x0630, 0x0248, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_TX_DATA, 0x0630, 0x0248, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_RX_DATA, 0x0630, 0x0248, 4, 0x091C, 2, 0) +MX6_PAD_DECL(KEY_COL1__GPIO4_IO08, 0x0630, 0x0248, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__SD1_VSELECT, 0x0630, 0x0248, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ECSPI1_SS1, 0x0634, 0x024C, 0, 0x07E8, 2, 0) +MX6_PAD_DECL(KEY_COL2__ENET_RX_DATA2, 0x0634, 0x024C, 1, 0x0820, 0, 0) +MX6_PAD_DECL(KEY_COL2__FLEXCAN1_TX, 0x0634, 0x024C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__KEY_COL2, 0x0634, 0x024C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ENET_MDC, 0x0634, 0x024C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__GPIO4_IO10, 0x0634, 0x024C, 5, 0x0000, 0, 0) MX6_PAD_DECL(KEY_COL2__USB_H1_PWR_CTL_WAKE, 0x0634, 0x024C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__ECSPI1_SS3, 0x0638, 0x0250, 0, 0x07F0, 1, 0) -MX6_PAD_DECL(KEY_COL3__ENET_CRS, 0x0638, 0x0250, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__HDMI_TX_DDC_SCL, 0x0638, 0x0250, 2, 0x0860, 1, 0) -MX6_PAD_DECL(KEY_COL3__KEY_COL3, 0x0638, 0x0250, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__I2C2_SCL, 0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0) -MX6_PAD_DECL(KEY_COL3__GPIO4_IO12, 0x0638, 0x0250, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__SPDIF_IN, 0x0638, 0x0250, 6, 0x08F0, 3, 0) -MX6_PAD_DECL(KEY_COL4__FLEXCAN2_TX, 0x063C, 0x0254, 0, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__IPU1_SISG4, 0x063C, 0x0254, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__USB_OTG_OC, 0x063C, 0x0254, 2, 0x0920, 1, 0) -MX6_PAD_DECL(KEY_COL4__KEY_COL4, 0x063C, 0x0254, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__UART5_CTS_B, 0x063C, 0x0254, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__UART5_RTS_B, 0x063C, 0x0254, 4, 0x0918, 2, 0) -MX6_PAD_DECL(KEY_COL4__GPIO4_IO14, 0x063C, 0x0254, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__ECSPI1_MOSI, 0x0640, 0x0258, 0, 0x07E0, 3, 0) -MX6_PAD_DECL(KEY_ROW0__ENET_TX_DATA3, 0x0640, 0x0258, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__AUD5_TXD, 0x0640, 0x0258, 2, 0x07B4, 1, 0) -MX6_PAD_DECL(KEY_ROW0__KEY_ROW0, 0x0640, 0x0258, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__UART4_TX_DATA, 0x0640, 0x0258, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__UART4_RX_DATA, 0x0640, 0x0258, 4, 0x0914, 3, 0) -MX6_PAD_DECL(KEY_ROW0__GPIO4_IO07, 0x0640, 0x0258, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__DCIC2_OUT, 0x0640, 0x0258, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__ECSPI1_SS0, 0x0644, 0x025C, 0, 0x07E4, 3, 0) -MX6_PAD_DECL(KEY_ROW1__ENET_COL, 0x0644, 0x025C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__AUD5_RXD, 0x0644, 0x025C, 2, 0x07B0, 1, 0) -MX6_PAD_DECL(KEY_ROW1__KEY_ROW1, 0x0644, 0x025C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__UART5_TX_DATA, 0x0644, 0x025C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__UART5_RX_DATA, 0x0644, 0x025C, 4, 0x091C, 3, 0) -MX6_PAD_DECL(KEY_ROW1__GPIO4_IO09, 0x0644, 0x025C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__SD2_VSELECT, 0x0644, 0x025C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__ECSPI1_SS2, 0x0648, 0x0260, 0, 0x07EC, 1, 0) -MX6_PAD_DECL(KEY_ROW2__ENET_TX_DATA2, 0x0648, 0x0260, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__FLEXCAN1_RX, 0x0648, 0x0260, 2, 0x07C8, 1, 0) -MX6_PAD_DECL(KEY_ROW2__KEY_ROW2, 0x0648, 0x0260, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__SD2_VSELECT, 0x0648, 0x0260, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__GPIO4_IO11, 0x0648, 0x0260, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__ECSPI1_SS3, 0x0638, 0x0250, 0, 0x07F0, 1, 0) +MX6_PAD_DECL(KEY_COL3__ENET_CRS, 0x0638, 0x0250, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__HDMI_TX_DDC_SCL, 0x0638, 0x0250, 2, 0x0860, 1, 0) +MX6_PAD_DECL(KEY_COL3__KEY_COL3, 0x0638, 0x0250, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__I2C2_SCL, 0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0) +MX6_PAD_DECL(KEY_COL3__GPIO4_IO12, 0x0638, 0x0250, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__SPDIF_IN, 0x0638, 0x0250, 6, 0x08F0, 3, 0) +MX6_PAD_DECL(KEY_COL4__FLEXCAN2_TX, 0x063C, 0x0254, 0, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__IPU1_SISG4, 0x063C, 0x0254, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__USB_OTG_OC, 0x063C, 0x0254, 2, 0x0920, 1, 0) +MX6_PAD_DECL(KEY_COL4__KEY_COL4, 0x063C, 0x0254, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_CTS_B, 0x063C, 0x0254, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_RTS_B, 0x063C, 0x0254, 4, 0x0918, 2, 0) +MX6_PAD_DECL(KEY_COL4__GPIO4_IO14, 0x063C, 0x0254, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__ECSPI1_MOSI, 0x0640, 0x0258, 0, 0x07E0, 3, 0) +MX6_PAD_DECL(KEY_ROW0__ENET_TX_DATA3, 0x0640, 0x0258, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__AUD5_TXD, 0x0640, 0x0258, 2, 0x07B4, 1, 0) +MX6_PAD_DECL(KEY_ROW0__KEY_ROW0, 0x0640, 0x0258, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_TX_DATA, 0x0640, 0x0258, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_RX_DATA, 0x0640, 0x0258, 4, 0x0914, 3, 0) +MX6_PAD_DECL(KEY_ROW0__GPIO4_IO07, 0x0640, 0x0258, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__DCIC2_OUT, 0x0640, 0x0258, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__ECSPI1_SS0, 0x0644, 0x025C, 0, 0x07E4, 3, 0) +MX6_PAD_DECL(KEY_ROW1__ENET_COL, 0x0644, 0x025C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__AUD5_RXD, 0x0644, 0x025C, 2, 0x07B0, 1, 0) +MX6_PAD_DECL(KEY_ROW1__KEY_ROW1, 0x0644, 0x025C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_TX_DATA, 0x0644, 0x025C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_RX_DATA, 0x0644, 0x025C, 4, 0x091C, 3, 0) +MX6_PAD_DECL(KEY_ROW1__GPIO4_IO09, 0x0644, 0x025C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__SD2_VSELECT, 0x0644, 0x025C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__ECSPI1_SS2, 0x0648, 0x0260, 0, 0x07EC, 1, 0) +MX6_PAD_DECL(KEY_ROW2__ENET_TX_DATA2, 0x0648, 0x0260, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__FLEXCAN1_RX, 0x0648, 0x0260, 2, 0x07C8, 1, 0) +MX6_PAD_DECL(KEY_ROW2__KEY_ROW2, 0x0648, 0x0260, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__SD2_VSELECT, 0x0648, 0x0260, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__GPIO4_IO11, 0x0648, 0x0260, 5, 0x0000, 0, 0) MX6_PAD_DECL(KEY_ROW2__HDMI_TX_CEC_LINE, 0x0648, 0x0260, 6, 0x085C, 1, 0) -MX6_PAD_DECL(KEY_ROW3__ASRC_EXT_CLK, 0x064C, 0x0264, 1, 0x0794, 2, 0) -MX6_PAD_DECL(KEY_ROW3__HDMI_TX_DDC_SDA, 0x064C, 0x0264, 2, 0x0864, 1, 0) -MX6_PAD_DECL(KEY_ROW3__KEY_ROW3, 0x064C, 0x0264, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW3__I2C2_SDA, 0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0) -MX6_PAD_DECL(KEY_ROW3__GPIO4_IO13, 0x064C, 0x0264, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW3__SD1_VSELECT, 0x064C, 0x0264, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__FLEXCAN2_RX, 0x0650, 0x0268, 0, 0x07CC, 0, 0) -MX6_PAD_DECL(KEY_ROW4__IPU1_SISG5, 0x0650, 0x0268, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__USB_OTG_PWR, 0x0650, 0x0268, 2, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__KEY_ROW4, 0x0650, 0x0268, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__UART5_CTS_B, 0x0650, 0x0268, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__UART5_RTS_B, 0x0650, 0x0268, 4, 0x0918, 3, 0) -MX6_PAD_DECL(KEY_ROW4__GPIO4_IO15, 0x0650, 0x0268, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_ALE__NAND_ALE, 0x0654, 0x026C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_ALE__SD4_RESET, 0x0654, 0x026C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_ALE__GPIO6_IO08, 0x0654, 0x026C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CLE__NAND_CLE, 0x0658, 0x0270, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CLE__GPIO6_IO07, 0x0658, 0x0270, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS0__NAND_CE0_B, 0x065C, 0x0274, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS0__GPIO6_IO11, 0x065C, 0x0274, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__NAND_CE1_B, 0x0660, 0x0278, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__SD4_VSELECT, 0x0660, 0x0278, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__SD3_VSELECT, 0x0660, 0x0278, 2, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__GPIO6_IO14, 0x0660, 0x0278, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__NAND_CE2_B, 0x0664, 0x027C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__IPU1_SISG0, 0x0664, 0x027C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__ESAI_TX0, 0x0664, 0x027C, 2, 0x0844, 1, 0) -MX6_PAD_DECL(NANDF_CS2__EIM_CRE, 0x0664, 0x027C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__CCM_CLKO2, 0x0664, 0x027C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__GPIO6_IO15, 0x0664, 0x027C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__NAND_CE3_B, 0x0668, 0x0280, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__IPU1_SISG1, 0x0668, 0x0280, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__ESAI_TX1, 0x0668, 0x0280, 2, 0x0848, 1, 0) -MX6_PAD_DECL(NANDF_CS3__EIM_ADDR26, 0x0668, 0x0280, 3, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__GPIO6_IO16, 0x0668, 0x0280, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__I2C4_SDA, 0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0) -MX6_PAD_DECL(NANDF_D0__NAND_DATA00, 0x066C, 0x0284, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D0__SD1_DATA4, 0x066C, 0x0284, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D0__GPIO2_IO00, 0x066C, 0x0284, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D1__NAND_DATA01, 0x0670, 0x0288, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D1__SD1_DATA5, 0x0670, 0x0288, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D1__GPIO2_IO01, 0x0670, 0x0288, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D2__NAND_DATA02, 0x0674, 0x028C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D2__SD1_DATA6, 0x0674, 0x028C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D2__GPIO2_IO02, 0x0674, 0x028C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D3__NAND_DATA03, 0x0678, 0x0290, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D3__SD1_DATA7, 0x0678, 0x0290, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D3__GPIO2_IO03, 0x0678, 0x0290, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D4__NAND_DATA04, 0x067C, 0x0294, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D4__SD2_DATA4, 0x067C, 0x0294, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D4__GPIO2_IO04, 0x067C, 0x0294, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D5__NAND_DATA05, 0x0680, 0x0298, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D5__SD2_DATA5, 0x0680, 0x0298, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D5__GPIO2_IO05, 0x0680, 0x0298, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D6__NAND_DATA06, 0x0684, 0x029C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D6__SD2_DATA6, 0x0684, 0x029C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D6__GPIO2_IO06, 0x0684, 0x029C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D7__NAND_DATA07, 0x0688, 0x02A0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D7__SD2_DATA7, 0x0688, 0x02A0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D7__GPIO2_IO07, 0x0688, 0x02A0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_RB0__NAND_READY_B, 0x068C, 0x02A4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_RB0__GPIO6_IO10, 0x068C, 0x02A4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_WP_B__NAND_WP_B, 0x0690, 0x02A8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_WP_B__GPIO6_IO09, 0x0690, 0x02A8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_WP_B__I2C4_SCL, 0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0) -MX6_PAD_DECL(RGMII_RD0__HSI_RX_READY, 0x0694, 0x02AC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD0__RGMII_RD0, 0x0694, 0x02AC, 1, 0x0818, 1, 0) -MX6_PAD_DECL(RGMII_RD0__GPIO6_IO25, 0x0694, 0x02AC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD1__HSI_TX_FLAG, 0x0698, 0x02B0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD1__RGMII_RD1, 0x0698, 0x02B0, 1, 0x081C, 1, 0) -MX6_PAD_DECL(RGMII_RD1__GPIO6_IO27, 0x0698, 0x02B0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD2__HSI_TX_DATA, 0x069C, 0x02B4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD2__RGMII_RD2, 0x069C, 0x02B4, 1, 0x0820, 1, 0) -MX6_PAD_DECL(RGMII_RD2__GPIO6_IO28, 0x069C, 0x02B4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD3__HSI_TX_WAKE, 0x06A0, 0x02B8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD3__RGMII_RD3, 0x06A0, 0x02B8, 1, 0x0824, 1, 0) -MX6_PAD_DECL(RGMII_RD3__GPIO6_IO29, 0x06A0, 0x02B8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RX_CTL__USB_H3_DATA, 0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__ASRC_EXT_CLK, 0x064C, 0x0264, 1, 0x0794, 2, 0) +MX6_PAD_DECL(KEY_ROW3__HDMI_TX_DDC_SDA, 0x064C, 0x0264, 2, 0x0864, 1, 0) +MX6_PAD_DECL(KEY_ROW3__KEY_ROW3, 0x064C, 0x0264, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__I2C2_SDA, 0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0) +MX6_PAD_DECL(KEY_ROW3__GPIO4_IO13, 0x064C, 0x0264, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__SD1_VSELECT, 0x064C, 0x0264, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__FLEXCAN2_RX, 0x0650, 0x0268, 0, 0x07CC, 0, 0) +MX6_PAD_DECL(KEY_ROW4__IPU1_SISG5, 0x0650, 0x0268, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__USB_OTG_PWR, 0x0650, 0x0268, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__KEY_ROW4, 0x0650, 0x0268, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_CTS_B, 0x0650, 0x0268, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_RTS_B, 0x0650, 0x0268, 4, 0x0918, 3, 0) +MX6_PAD_DECL(KEY_ROW4__GPIO4_IO15, 0x0650, 0x0268, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__NAND_ALE, 0x0654, 0x026C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__SD4_RESET, 0x0654, 0x026C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__GPIO6_IO08, 0x0654, 0x026C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__NAND_CLE, 0x0658, 0x0270, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__GPIO6_IO07, 0x0658, 0x0270, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__NAND_CE0_B, 0x065C, 0x0274, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__GPIO6_IO11, 0x065C, 0x0274, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__NAND_CE1_B, 0x0660, 0x0278, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD4_VSELECT, 0x0660, 0x0278, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD3_VSELECT, 0x0660, 0x0278, 2, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__GPIO6_IO14, 0x0660, 0x0278, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__NAND_CE2_B, 0x0664, 0x027C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__IPU1_SISG0, 0x0664, 0x027C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__ESAI_TX0, 0x0664, 0x027C, 2, 0x0844, 1, 0) +MX6_PAD_DECL(NANDF_CS2__EIM_CRE, 0x0664, 0x027C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__CCM_CLKO2, 0x0664, 0x027C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__GPIO6_IO15, 0x0664, 0x027C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__NAND_CE3_B, 0x0668, 0x0280, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__IPU1_SISG1, 0x0668, 0x0280, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__ESAI_TX1, 0x0668, 0x0280, 2, 0x0848, 1, 0) +MX6_PAD_DECL(NANDF_CS3__EIM_ADDR26, 0x0668, 0x0280, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__GPIO6_IO16, 0x0668, 0x0280, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__I2C4_SDA, 0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0) +MX6_PAD_DECL(NANDF_D0__NAND_DATA00, 0x066C, 0x0284, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__SD1_DATA4, 0x066C, 0x0284, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__GPIO2_IO00, 0x066C, 0x0284, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__NAND_DATA01, 0x0670, 0x0288, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__SD1_DATA5, 0x0670, 0x0288, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__GPIO2_IO01, 0x0670, 0x0288, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__NAND_DATA02, 0x0674, 0x028C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__SD1_DATA6, 0x0674, 0x028C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__GPIO2_IO02, 0x0674, 0x028C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__NAND_DATA03, 0x0678, 0x0290, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__SD1_DATA7, 0x0678, 0x0290, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__GPIO2_IO03, 0x0678, 0x0290, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__NAND_DATA04, 0x067C, 0x0294, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__SD2_DATA4, 0x067C, 0x0294, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__GPIO2_IO04, 0x067C, 0x0294, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__NAND_DATA05, 0x0680, 0x0298, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__SD2_DATA5, 0x0680, 0x0298, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__GPIO2_IO05, 0x0680, 0x0298, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__NAND_DATA06, 0x0684, 0x029C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__SD2_DATA6, 0x0684, 0x029C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__GPIO2_IO06, 0x0684, 0x029C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__NAND_DATA07, 0x0688, 0x02A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__SD2_DATA7, 0x0688, 0x02A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__GPIO2_IO07, 0x0688, 0x02A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__NAND_READY_B, 0x068C, 0x02A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__GPIO6_IO10, 0x068C, 0x02A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__NAND_WP_B, 0x0690, 0x02A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__GPIO6_IO09, 0x0690, 0x02A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__I2C4_SCL, 0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0) +MX6_PAD_DECL(RGMII_RD0__HSI_RX_READY, 0x0694, 0x02AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD0__RGMII_RD0, 0x0694, 0x02AC, 1, 0x0818, 1, 0) +MX6_PAD_DECL(RGMII_RD0__GPIO6_IO25, 0x0694, 0x02AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__HSI_TX_FLAG, 0x0698, 0x02B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__RGMII_RD1, 0x0698, 0x02B0, 1, 0x081C, 1, 0) +MX6_PAD_DECL(RGMII_RD1__GPIO6_IO27, 0x0698, 0x02B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__HSI_TX_DATA, 0x069C, 0x02B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__RGMII_RD2, 0x069C, 0x02B4, 1, 0x0820, 1, 0) +MX6_PAD_DECL(RGMII_RD2__GPIO6_IO28, 0x069C, 0x02B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__HSI_TX_WAKE, 0x06A0, 0x02B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__RGMII_RD3, 0x06A0, 0x02B8, 1, 0x0824, 1, 0) +MX6_PAD_DECL(RGMII_RD3__GPIO6_IO29, 0x06A0, 0x02B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__USB_H3_DATA, 0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_RX_CTL__RGMII_RX_CTL, 0x06A4, 0x02BC, 1, 0x0828, 1, 0) -MX6_PAD_DECL(RGMII_RX_CTL__GPIO6_IO24, 0x06A4, 0x02BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__GPIO6_IO24, 0x06A4, 0x02BC, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_RXC__USBOH3_H3_STROBE, 0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RXC__USB_H3_STROBE, 0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP) -MX6_PAD_DECL(RGMII_RXC__RGMII_RXC, 0x06A8, 0x02C0, 1, 0x0814, 1, 0) -MX6_PAD_DECL(RGMII_RXC__GPIO6_IO30, 0x06A8, 0x02C0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD0__HSI_TX_READY, 0x06AC, 0x02C4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD0__RGMII_TD0, 0x06AC, 0x02C4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD0__GPIO6_IO20, 0x06AC, 0x02C4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD1__HSI_RX_FLAG, 0x06B0, 0x02C8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD1__RGMII_TD1, 0x06B0, 0x02C8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD1__GPIO6_IO21, 0x06B0, 0x02C8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD2__HSI_RX_DATA, 0x06B4, 0x02CC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD2__RGMII_TD2, 0x06B4, 0x02CC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD2__GPIO6_IO22, 0x06B4, 0x02CC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD3__HSI_RX_WAKE, 0x06B8, 0x02D0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD3__RGMII_TD3, 0x06B8, 0x02D0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD3__GPIO6_IO23, 0x06B8, 0x02D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__USB_H3_STROBE, 0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP) +MX6_PAD_DECL(RGMII_RXC__RGMII_RXC, 0x06A8, 0x02C0, 1, 0x0814, 1, 0) +MX6_PAD_DECL(RGMII_RXC__GPIO6_IO30, 0x06A8, 0x02C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__HSI_TX_READY, 0x06AC, 0x02C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__RGMII_TD0, 0x06AC, 0x02C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__GPIO6_IO20, 0x06AC, 0x02C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__HSI_RX_FLAG, 0x06B0, 0x02C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__RGMII_TD1, 0x06B0, 0x02C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__GPIO6_IO21, 0x06B0, 0x02C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__HSI_RX_DATA, 0x06B4, 0x02CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__RGMII_TD2, 0x06B4, 0x02CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__GPIO6_IO22, 0x06B4, 0x02CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__HSI_RX_WAKE, 0x06B8, 0x02D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__RGMII_TD3, 0x06B8, 0x02D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__GPIO6_IO23, 0x06B8, 0x02D0, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TX_CTL__USBOH3_H2_STROBE, 0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TX_CTL__USB_H2_STROBE, 0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP) MX6_PAD_DECL(RGMII_TX_CTL__RGMII_TX_CTL, 0x06BC, 0x02D4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TX_CTL__GPIO6_IO26, 0x06BC, 0x02D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__GPIO6_IO26, 0x06BC, 0x02D4, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TX_CTL__ENET_REF_CLK, 0x06BC, 0x02D4, 7, 0x080C, 1, 0) -MX6_PAD_DECL(RGMII_TXC__USB_H2_DATA, 0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TXC__RGMII_TXC, 0x06C0, 0x02D8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TXC__SPDIF_EXT_CLK, 0x06C0, 0x02D8, 2, 0x08F4, 1, 0) -MX6_PAD_DECL(RGMII_TXC__GPIO6_IO19, 0x06C0, 0x02D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__USB_H2_DATA, 0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__RGMII_TXC, 0x06C0, 0x02D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__SPDIF_EXT_CLK, 0x06C0, 0x02D8, 2, 0x08F4, 1, 0) +MX6_PAD_DECL(RGMII_TXC__GPIO6_IO19, 0x06C0, 0x02D8, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TXC__XTALOSC_REF_CLK_24M, 0x06C0, 0x02D8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CLK__SD1_CLK, 0x06C4, 0x02DC, 0, 0x0928, 1, 0) -MX6_PAD_DECL(SD1_CLK__GPT_CLKIN, 0x06C4, 0x02DC, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CLK__GPIO1_IO20, 0x06C4, 0x02DC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__SD1_CMD, 0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__PWM4_OUT, 0x06C8, 0x02E0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__GPT_COMPARE1, 0x06C8, 0x02E0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__GPIO1_IO18, 0x06C8, 0x02E0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT0__SD1_DATA0, 0x06CC, 0x02E4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT0__GPT_CAPTURE1, 0x06CC, 0x02E4, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT0__GPIO1_IO16, 0x06CC, 0x02E4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__SD1_DATA1, 0x06D0, 0x02E8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__PWM3_OUT, 0x06D0, 0x02E8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__GPT_CAPTURE2, 0x06D0, 0x02E8, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__GPIO1_IO17, 0x06D0, 0x02E8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__SD1_DATA2, 0x06D4, 0x02EC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__GPT_COMPARE2, 0x06D4, 0x02EC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__PWM2_OUT, 0x06D4, 0x02EC, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__WDOG1_B, 0x06D4, 0x02EC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__GPIO1_IO19, 0x06D4, 0x02EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__SD1_CLK, 0x06C4, 0x02DC, 0, 0x0928, 1, 0) +MX6_PAD_DECL(SD1_CLK__GPT_CLKIN, 0x06C4, 0x02DC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__GPIO1_IO20, 0x06C4, 0x02DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__SD1_CMD, 0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__PWM4_OUT, 0x06C8, 0x02E0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPT_COMPARE1, 0x06C8, 0x02E0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPIO1_IO18, 0x06C8, 0x02E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__SD1_DATA0, 0x06CC, 0x02E4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__GPT_CAPTURE1, 0x06CC, 0x02E4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__GPIO1_IO16, 0x06CC, 0x02E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__SD1_DATA1, 0x06D0, 0x02E8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__PWM3_OUT, 0x06D0, 0x02E8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPT_CAPTURE2, 0x06D0, 0x02E8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPIO1_IO17, 0x06D0, 0x02E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__SD1_DATA2, 0x06D4, 0x02EC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__GPT_COMPARE2, 0x06D4, 0x02EC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__PWM2_OUT, 0x06D4, 0x02EC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__WDOG1_B, 0x06D4, 0x02EC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__GPIO1_IO19, 0x06D4, 0x02EC, 5, 0x0000, 0, 0) MX6_PAD_DECL(SD1_DAT2__WDOG1_RESET_B_DEB, 0x06D4, 0x02EC, 6, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__SD1_DATA3, 0x06D8, 0x02F0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__GPT_COMPARE3, 0x06D8, 0x02F0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__PWM1_OUT, 0x06D8, 0x02F0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__WDOG2_B, 0x06D8, 0x02F0, 4, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__GPIO1_IO21, 0x06D8, 0x02F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__SD1_DATA3, 0x06D8, 0x02F0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPT_COMPARE3, 0x06D8, 0x02F0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__PWM1_OUT, 0x06D8, 0x02F0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__WDOG2_B, 0x06D8, 0x02F0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPIO1_IO21, 0x06D8, 0x02F0, 5, 0x0000, 0, 0) MX6_PAD_DECL(SD1_DAT3__WDOG2_RESET_B_DEB, 0x06D8, 0x02F0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CLK__SD2_CLK, 0x06DC, 0x02F4, 0, 0x0930, 1, 0) -MX6_PAD_DECL(SD2_CLK__KEY_COL5, 0x06DC, 0x02F4, 2, 0x08C0, 3, 0) -MX6_PAD_DECL(SD2_CLK__AUD4_RXFS, 0x06DC, 0x02F4, 3, 0x07A4, 1, 0) -MX6_PAD_DECL(SD2_CLK__GPIO1_IO10, 0x06DC, 0x02F4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CMD__SD2_CMD, 0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CMD__KEY_ROW5, 0x06E0, 0x02F8, 2, 0x08CC, 2, 0) -MX6_PAD_DECL(SD2_CMD__AUD4_RXC, 0x06E0, 0x02F8, 3, 0x07A0, 1, 0) -MX6_PAD_DECL(SD2_CMD__GPIO1_IO11, 0x06E0, 0x02F8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT0__SD2_DATA0, 0x06E4, 0x02FC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT0__AUD4_RXD, 0x06E4, 0x02FC, 3, 0x0798, 1, 0) -MX6_PAD_DECL(SD2_DAT0__KEY_ROW7, 0x06E4, 0x02FC, 4, 0x08D4, 2, 0) -MX6_PAD_DECL(SD2_DAT0__GPIO1_IO15, 0x06E4, 0x02FC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT0__DCIC2_OUT, 0x06E4, 0x02FC, 6, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT1__SD2_DATA1, 0x06E8, 0x0300, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT1__EIM_CS2_B, 0x06E8, 0x0300, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT1__AUD4_TXFS, 0x06E8, 0x0300, 3, 0x07AC, 1, 0) -MX6_PAD_DECL(SD2_DAT1__KEY_COL7, 0x06E8, 0x0300, 4, 0x08C8, 2, 0) -MX6_PAD_DECL(SD2_DAT1__GPIO1_IO14, 0x06E8, 0x0300, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT2__SD2_DATA2, 0x06EC, 0x0304, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT2__EIM_CS3_B, 0x06EC, 0x0304, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT2__AUD4_TXD, 0x06EC, 0x0304, 3, 0x079C, 1, 0) -MX6_PAD_DECL(SD2_DAT2__KEY_ROW6, 0x06EC, 0x0304, 4, 0x08D0, 2, 0) -MX6_PAD_DECL(SD2_DAT2__GPIO1_IO13, 0x06EC, 0x0304, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT3__SD2_DATA3, 0x06F0, 0x0308, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT3__KEY_COL6, 0x06F0, 0x0308, 2, 0x08C4, 2, 0) -MX6_PAD_DECL(SD2_DAT3__AUD4_TXC, 0x06F0, 0x0308, 3, 0x07A8, 1, 0) -MX6_PAD_DECL(SD2_DAT3__GPIO1_IO12, 0x06F0, 0x0308, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CLK__SD3_CLK, 0x06F4, 0x030C, 0, 0x0934, 1, 0) -MX6_PAD_DECL(SD3_CLK__UART2_CTS_B, 0x06F4, 0x030C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CLK__UART2_RTS_B, 0x06F4, 0x030C, 1, 0x0900, 2, 0) -MX6_PAD_DECL(SD3_CLK__FLEXCAN1_RX, 0x06F4, 0x030C, 2, 0x07C8, 2, 0) -MX6_PAD_DECL(SD3_CLK__GPIO7_IO03, 0x06F4, 0x030C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__SD3_CMD, 0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__UART2_CTS_B, 0x06F8, 0x0310, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__UART2_RTS_B, 0x06F8, 0x0310, 1, 0x0900, 3, 0) -MX6_PAD_DECL(SD3_CMD__FLEXCAN1_TX, 0x06F8, 0x0310, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__GPIO7_IO02, 0x06F8, 0x0310, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__SD3_DATA0, 0x06FC, 0x0314, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__UART1_CTS_B, 0x06FC, 0x0314, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__UART1_RTS_B, 0x06FC, 0x0314, 1, 0x08F8, 2, 0) -MX6_PAD_DECL(SD3_DAT0__FLEXCAN2_TX, 0x06FC, 0x0314, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__GPIO7_IO04, 0x06FC, 0x0314, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT1__SD3_DATA1, 0x0700, 0x0318, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT1__UART1_CTS_B, 0x0700, 0x0318, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT1__UART1_RTS_B, 0x0700, 0x0318, 1, 0x08F8, 3, 0) -MX6_PAD_DECL(SD3_DAT1__FLEXCAN2_RX, 0x0700, 0x0318, 2, 0x07CC, 1, 0) -MX6_PAD_DECL(SD3_DAT1__GPIO7_IO05, 0x0700, 0x0318, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT2__SD3_DATA2, 0x0704, 0x031C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT2__GPIO7_IO06, 0x0704, 0x031C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT3__SD3_DATA3, 0x0708, 0x0320, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT3__UART3_CTS_B, 0x0708, 0x0320, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT3__UART3_RTS_B, 0x0708, 0x0320, 1, 0x0908, 4, 0) -MX6_PAD_DECL(SD3_DAT3__GPIO7_IO07, 0x0708, 0x0320, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT4__SD3_DATA4, 0x070C, 0x0324, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT4__UART2_TX_DATA, 0x070C, 0x0324, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT4__UART2_RX_DATA, 0x070C, 0x0324, 1, 0x0904, 4, 0) -MX6_PAD_DECL(SD3_DAT4__GPIO7_IO01, 0x070C, 0x0324, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT5__SD3_DATA5, 0x0710, 0x0328, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT5__UART2_TX_DATA, 0x0710, 0x0328, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT5__UART2_RX_DATA, 0x0710, 0x0328, 1, 0x0904, 5, 0) -MX6_PAD_DECL(SD3_DAT5__GPIO7_IO00, 0x0710, 0x0328, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT6__SD3_DATA6, 0x0714, 0x032C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT6__UART1_TX_DATA, 0x0714, 0x032C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT6__UART1_RX_DATA, 0x0714, 0x032C, 1, 0x08FC, 2, 0) -MX6_PAD_DECL(SD3_DAT6__GPIO6_IO18, 0x0714, 0x032C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT7__SD3_DATA7, 0x0718, 0x0330, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT7__UART1_TX_DATA, 0x0718, 0x0330, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT7__UART1_RX_DATA, 0x0718, 0x0330, 1, 0x08FC, 3, 0) -MX6_PAD_DECL(SD3_DAT7__GPIO6_IO17, 0x0718, 0x0330, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_RST__SD3_RESET, 0x071C, 0x0334, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_RST__UART3_CTS_B, 0x071C, 0x0334, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_RST__UART3_RTS_B, 0x071C, 0x0334, 1, 0x0908, 5, 0) -MX6_PAD_DECL(SD3_RST__GPIO7_IO08, 0x071C, 0x0334, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__SD4_CLK, 0x0720, 0x0338, 0, 0x0938, 1, 0) -MX6_PAD_DECL(SD4_CLK__NAND_WE_B, 0x0720, 0x0338, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__UART3_TX_DATA, 0x0720, 0x0338, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__UART3_RX_DATA, 0x0720, 0x0338, 2, 0x090C, 2, 0) -MX6_PAD_DECL(SD4_CLK__GPIO7_IO10, 0x0720, 0x0338, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__SD4_CMD, 0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__NAND_RE_B, 0x0724, 0x033C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__UART3_TX_DATA, 0x0724, 0x033C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__UART3_RX_DATA, 0x0724, 0x033C, 2, 0x090C, 3, 0) -MX6_PAD_DECL(SD4_CMD__GPIO7_IO09, 0x0724, 0x033C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT0__SD4_DATA0, 0x0728, 0x0340, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT0__NAND_DQS, 0x0728, 0x0340, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT0__GPIO2_IO08, 0x0728, 0x0340, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT1__SD4_DATA1, 0x072C, 0x0344, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT1__PWM3_OUT, 0x072C, 0x0344, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT1__GPIO2_IO09, 0x072C, 0x0344, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT2__SD4_DATA2, 0x0730, 0x0348, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT2__PWM4_OUT, 0x0730, 0x0348, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT2__GPIO2_IO10, 0x0730, 0x0348, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT3__SD4_DATA3, 0x0734, 0x034C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT3__GPIO2_IO11, 0x0734, 0x034C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT4__SD4_DATA4, 0x0738, 0x0350, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT4__UART2_TX_DATA, 0x0738, 0x0350, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT4__UART2_RX_DATA, 0x0738, 0x0350, 2, 0x0904, 6, 0) -MX6_PAD_DECL(SD4_DAT4__GPIO2_IO12, 0x0738, 0x0350, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT5__SD4_DATA5, 0x073C, 0x0354, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT5__UART2_CTS_B, 0x073C, 0x0354, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT5__UART2_RTS_B, 0x073C, 0x0354, 2, 0x0900, 4, 0) -MX6_PAD_DECL(SD4_DAT5__GPIO2_IO13, 0x073C, 0x0354, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT6__SD4_DATA6, 0x0740, 0x0358, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT6__UART2_CTS_B, 0x0740, 0x0358, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT6__UART2_RTS_B, 0x0740, 0x0358, 2, 0x0900, 5, 0) -MX6_PAD_DECL(SD4_DAT6__GPIO2_IO14, 0x0740, 0x0358, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT7__SD4_DATA7, 0x0744, 0x035C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT7__UART2_TX_DATA, 0x0744, 0x035C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT7__UART2_RX_DATA, 0x0744, 0x035C, 2, 0x0904, 7, 0) -MX6_PAD_DECL(SD4_DAT7__GPIO2_IO15, 0x0744, 0x035C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CLK__SD2_CLK, 0x06DC, 0x02F4, 0, 0x0930, 1, 0) +MX6_PAD_DECL(SD2_CLK__KEY_COL5, 0x06DC, 0x02F4, 2, 0x08C0, 3, 0) +MX6_PAD_DECL(SD2_CLK__AUD4_RXFS, 0x06DC, 0x02F4, 3, 0x07A4, 1, 0) +MX6_PAD_DECL(SD2_CLK__GPIO1_IO10, 0x06DC, 0x02F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__SD2_CMD, 0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__KEY_ROW5, 0x06E0, 0x02F8, 2, 0x08CC, 2, 0) +MX6_PAD_DECL(SD2_CMD__AUD4_RXC, 0x06E0, 0x02F8, 3, 0x07A0, 1, 0) +MX6_PAD_DECL(SD2_CMD__GPIO1_IO11, 0x06E0, 0x02F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__SD2_DATA0, 0x06E4, 0x02FC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__AUD4_RXD, 0x06E4, 0x02FC, 3, 0x0798, 1, 0) +MX6_PAD_DECL(SD2_DAT0__KEY_ROW7, 0x06E4, 0x02FC, 4, 0x08D4, 2, 0) +MX6_PAD_DECL(SD2_DAT0__GPIO1_IO15, 0x06E4, 0x02FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__DCIC2_OUT, 0x06E4, 0x02FC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__SD2_DATA1, 0x06E8, 0x0300, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__EIM_CS2_B, 0x06E8, 0x0300, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__AUD4_TXFS, 0x06E8, 0x0300, 3, 0x07AC, 1, 0) +MX6_PAD_DECL(SD2_DAT1__KEY_COL7, 0x06E8, 0x0300, 4, 0x08C8, 2, 0) +MX6_PAD_DECL(SD2_DAT1__GPIO1_IO14, 0x06E8, 0x0300, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__SD2_DATA2, 0x06EC, 0x0304, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__EIM_CS3_B, 0x06EC, 0x0304, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__AUD4_TXD, 0x06EC, 0x0304, 3, 0x079C, 1, 0) +MX6_PAD_DECL(SD2_DAT2__KEY_ROW6, 0x06EC, 0x0304, 4, 0x08D0, 2, 0) +MX6_PAD_DECL(SD2_DAT2__GPIO1_IO13, 0x06EC, 0x0304, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__SD2_DATA3, 0x06F0, 0x0308, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__KEY_COL6, 0x06F0, 0x0308, 2, 0x08C4, 2, 0) +MX6_PAD_DECL(SD2_DAT3__AUD4_TXC, 0x06F0, 0x0308, 3, 0x07A8, 1, 0) +MX6_PAD_DECL(SD2_DAT3__GPIO1_IO12, 0x06F0, 0x0308, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__SD3_CLK, 0x06F4, 0x030C, 0, 0x0934, 1, 0) +MX6_PAD_DECL(SD3_CLK__UART2_CTS_B, 0x06F4, 0x030C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__UART2_RTS_B, 0x06F4, 0x030C, 1, 0x0900, 2, 0) +MX6_PAD_DECL(SD3_CLK__FLEXCAN1_RX, 0x06F4, 0x030C, 2, 0x07C8, 2, 0) +MX6_PAD_DECL(SD3_CLK__GPIO7_IO03, 0x06F4, 0x030C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__SD3_CMD, 0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_CTS_B, 0x06F8, 0x0310, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_RTS_B, 0x06F8, 0x0310, 1, 0x0900, 3, 0) +MX6_PAD_DECL(SD3_CMD__FLEXCAN1_TX, 0x06F8, 0x0310, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__GPIO7_IO02, 0x06F8, 0x0310, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__SD3_DATA0, 0x06FC, 0x0314, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_CTS_B, 0x06FC, 0x0314, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_RTS_B, 0x06FC, 0x0314, 1, 0x08F8, 2, 0) +MX6_PAD_DECL(SD3_DAT0__FLEXCAN2_TX, 0x06FC, 0x0314, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__GPIO7_IO04, 0x06FC, 0x0314, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__SD3_DATA1, 0x0700, 0x0318, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_CTS_B, 0x0700, 0x0318, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_RTS_B, 0x0700, 0x0318, 1, 0x08F8, 3, 0) +MX6_PAD_DECL(SD3_DAT1__FLEXCAN2_RX, 0x0700, 0x0318, 2, 0x07CC, 1, 0) +MX6_PAD_DECL(SD3_DAT1__GPIO7_IO05, 0x0700, 0x0318, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__SD3_DATA2, 0x0704, 0x031C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__GPIO7_IO06, 0x0704, 0x031C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__SD3_DATA3, 0x0708, 0x0320, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_CTS_B, 0x0708, 0x0320, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_RTS_B, 0x0708, 0x0320, 1, 0x0908, 4, 0) +MX6_PAD_DECL(SD3_DAT3__GPIO7_IO07, 0x0708, 0x0320, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__SD3_DATA4, 0x070C, 0x0324, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_TX_DATA, 0x070C, 0x0324, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_RX_DATA, 0x070C, 0x0324, 1, 0x0904, 4, 0) +MX6_PAD_DECL(SD3_DAT4__GPIO7_IO01, 0x070C, 0x0324, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__SD3_DATA5, 0x0710, 0x0328, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_TX_DATA, 0x0710, 0x0328, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_RX_DATA, 0x0710, 0x0328, 1, 0x0904, 5, 0) +MX6_PAD_DECL(SD3_DAT5__GPIO7_IO00, 0x0710, 0x0328, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__SD3_DATA6, 0x0714, 0x032C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_TX_DATA, 0x0714, 0x032C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_RX_DATA, 0x0714, 0x032C, 1, 0x08FC, 2, 0) +MX6_PAD_DECL(SD3_DAT6__GPIO6_IO18, 0x0714, 0x032C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__SD3_DATA7, 0x0718, 0x0330, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_TX_DATA, 0x0718, 0x0330, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_RX_DATA, 0x0718, 0x0330, 1, 0x08FC, 3, 0) +MX6_PAD_DECL(SD3_DAT7__GPIO6_IO17, 0x0718, 0x0330, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__SD3_RESET, 0x071C, 0x0334, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_CTS_B, 0x071C, 0x0334, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_RTS_B, 0x071C, 0x0334, 1, 0x0908, 5, 0) +MX6_PAD_DECL(SD3_RST__GPIO7_IO08, 0x071C, 0x0334, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__SD4_CLK, 0x0720, 0x0338, 0, 0x0938, 1, 0) +MX6_PAD_DECL(SD4_CLK__NAND_WE_B, 0x0720, 0x0338, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_TX_DATA, 0x0720, 0x0338, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_RX_DATA, 0x0720, 0x0338, 2, 0x090C, 2, 0) +MX6_PAD_DECL(SD4_CLK__GPIO7_IO10, 0x0720, 0x0338, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__SD4_CMD, 0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__NAND_RE_B, 0x0724, 0x033C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_TX_DATA, 0x0724, 0x033C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_RX_DATA, 0x0724, 0x033C, 2, 0x090C, 3, 0) +MX6_PAD_DECL(SD4_CMD__GPIO7_IO09, 0x0724, 0x033C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__SD4_DATA0, 0x0728, 0x0340, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__NAND_DQS, 0x0728, 0x0340, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__GPIO2_IO08, 0x0728, 0x0340, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__SD4_DATA1, 0x072C, 0x0344, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__PWM3_OUT, 0x072C, 0x0344, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__GPIO2_IO09, 0x072C, 0x0344, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__SD4_DATA2, 0x0730, 0x0348, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__PWM4_OUT, 0x0730, 0x0348, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__GPIO2_IO10, 0x0730, 0x0348, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__SD4_DATA3, 0x0734, 0x034C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__GPIO2_IO11, 0x0734, 0x034C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__SD4_DATA4, 0x0738, 0x0350, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_TX_DATA, 0x0738, 0x0350, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_RX_DATA, 0x0738, 0x0350, 2, 0x0904, 6, 0) +MX6_PAD_DECL(SD4_DAT4__GPIO2_IO12, 0x0738, 0x0350, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__SD4_DATA5, 0x073C, 0x0354, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_CTS_B, 0x073C, 0x0354, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_RTS_B, 0x073C, 0x0354, 2, 0x0900, 4, 0) +MX6_PAD_DECL(SD4_DAT5__GPIO2_IO13, 0x073C, 0x0354, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__SD4_DATA6, 0x0740, 0x0358, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_CTS_B, 0x0740, 0x0358, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_RTS_B, 0x0740, 0x0358, 2, 0x0900, 5, 0) +MX6_PAD_DECL(SD4_DAT6__GPIO2_IO14, 0x0740, 0x0358, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__SD4_DATA7, 0x0744, 0x035C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_TX_DATA, 0x0744, 0x035C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_RX_DATA, 0x0744, 0x035C, 2, 0x0904, 7, 0) +MX6_PAD_DECL(SD4_DAT7__GPIO2_IO15, 0x0744, 0x035C, 5, 0x0000, 0, 0) #endif /* __ASM_ARCH_MX6_MX6DL_PINS_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index 5e33753..015f014 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -9,1027 +9,1030 @@ #ifndef __ASM_ARCH_MX6_MX6Q_PINS_H__ #define __ASM_ARCH_MX6_MX6Q_PINS_H__
-MX6_PAD_DECL(SD2_DAT1__SD2_DATA1, 0x0360, 0x004C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT1__ECSPI5_SS0, 0x0360, 0x004C, 1, 0x0834, 0, 0) -MX6_PAD_DECL(SD2_DAT1__EIM_CS2_B, 0x0360, 0x004C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT1__AUD4_TXFS, 0x0360, 0x004C, 3, 0x07C8, 0, 0) -MX6_PAD_DECL(SD2_DAT1__KEY_COL7, 0x0360, 0x004C, 4, 0x08F0, 0, 0) -MX6_PAD_DECL(SD2_DAT1__GPIO1_IO14, 0x0360, 0x004C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT2__SD2_DATA2, 0x0364, 0x0050, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT2__ECSPI5_SS1, 0x0364, 0x0050, 1, 0x0838, 0, 0) -MX6_PAD_DECL(SD2_DAT2__EIM_CS3_B, 0x0364, 0x0050, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT2__AUD4_TXD, 0x0364, 0x0050, 3, 0x07B8, 0, 0) -MX6_PAD_DECL(SD2_DAT2__KEY_ROW6, 0x0364, 0x0050, 4, 0x08F8, 0, 0) -MX6_PAD_DECL(SD2_DAT2__GPIO1_IO13, 0x0364, 0x0050, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT0__SD2_DATA0, 0x0368, 0x0054, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT0__ECSPI5_MISO, 0x0368, 0x0054, 1, 0x082C, 0, 0) -MX6_PAD_DECL(SD2_DAT0__AUD4_RXD, 0x0368, 0x0054, 3, 0x07B4, 0, 0) -MX6_PAD_DECL(SD2_DAT0__KEY_ROW7, 0x0368, 0x0054, 4, 0x08FC, 0, 0) -MX6_PAD_DECL(SD2_DAT0__GPIO1_IO15, 0x0368, 0x0054, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT0__DCIC2_OUT, 0x0368, 0x0054, 6, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TXC__USB_H2_DATA, 0x036C, 0x0058, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TXC__RGMII_TXC, 0x036C, 0x0058, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TXC__SPDIF_EXT_CLK, 0x036C, 0x0058, 2, 0x0918, 0, 0) -MX6_PAD_DECL(RGMII_TXC__GPIO6_IO19, 0x036C, 0x0058, 5, 0x0000, 0, 0) +/* Pad name pad mux mux inp inp pad + * offs offs mode offs sel ctrl + */ +MX6_PAD_DECL(SD2_DAT1__SD2_DATA1, 0x0360, 0x004C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__ECSPI5_SS0, 0x0360, 0x004C, 1, 0x0834, 0, 0) +MX6_PAD_DECL(SD2_DAT1__EIM_CS2_B, 0x0360, 0x004C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT1__AUD4_TXFS, 0x0360, 0x004C, 3, 0x07C8, 0, 0) +MX6_PAD_DECL(SD2_DAT1__KEY_COL7, 0x0360, 0x004C, 4, 0x08F0, 0, 0) +MX6_PAD_DECL(SD2_DAT1__GPIO1_IO14, 0x0360, 0x004C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__SD2_DATA2, 0x0364, 0x0050, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__ECSPI5_SS1, 0x0364, 0x0050, 1, 0x0838, 0, 0) +MX6_PAD_DECL(SD2_DAT2__EIM_CS3_B, 0x0364, 0x0050, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT2__AUD4_TXD, 0x0364, 0x0050, 3, 0x07B8, 0, 0) +MX6_PAD_DECL(SD2_DAT2__KEY_ROW6, 0x0364, 0x0050, 4, 0x08F8, 0, 0) +MX6_PAD_DECL(SD2_DAT2__GPIO1_IO13, 0x0364, 0x0050, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__SD2_DATA0, 0x0368, 0x0054, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__ECSPI5_MISO, 0x0368, 0x0054, 1, 0x082C, 0, 0) +MX6_PAD_DECL(SD2_DAT0__AUD4_RXD, 0x0368, 0x0054, 3, 0x07B4, 0, 0) +MX6_PAD_DECL(SD2_DAT0__KEY_ROW7, 0x0368, 0x0054, 4, 0x08FC, 0, 0) +MX6_PAD_DECL(SD2_DAT0__GPIO1_IO15, 0x0368, 0x0054, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT0__DCIC2_OUT, 0x0368, 0x0054, 6, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__USB_H2_DATA, 0x036C, 0x0058, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__RGMII_TXC, 0x036C, 0x0058, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TXC__SPDIF_EXT_CLK, 0x036C, 0x0058, 2, 0x0918, 0, 0) +MX6_PAD_DECL(RGMII_TXC__GPIO6_IO19, 0x036C, 0x0058, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TXC__XTALOSC_REF_CLK_24M, 0x036C, 0x0058, 7, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD0__HSI_TX_READY, 0x0370, 0x005C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD0__RGMII_TD0, 0x0370, 0x005C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD0__GPIO6_IO20, 0x0370, 0x005C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD1__HSI_RX_FLAG, 0x0374, 0x0060, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD1__RGMII_TD1, 0x0374, 0x0060, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD1__GPIO6_IO21, 0x0374, 0x0060, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD2__HSI_RX_DATA, 0x0378, 0x0064, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD2__RGMII_TD2, 0x0378, 0x0064, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD2__GPIO6_IO22, 0x0378, 0x0064, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD3__HSI_RX_WAKE, 0x037C, 0x0068, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD3__RGMII_TD3, 0x037C, 0x0068, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TD3__GPIO6_IO23, 0x037C, 0x0068, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RX_CTL__USB_H3_DATA, 0x0380, 0x006C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__HSI_TX_READY, 0x0370, 0x005C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__RGMII_TD0, 0x0370, 0x005C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD0__GPIO6_IO20, 0x0370, 0x005C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__HSI_RX_FLAG, 0x0374, 0x0060, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__RGMII_TD1, 0x0374, 0x0060, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD1__GPIO6_IO21, 0x0374, 0x0060, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__HSI_RX_DATA, 0x0378, 0x0064, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__RGMII_TD2, 0x0378, 0x0064, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD2__GPIO6_IO22, 0x0378, 0x0064, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__HSI_RX_WAKE, 0x037C, 0x0068, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__RGMII_TD3, 0x037C, 0x0068, 1, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TD3__GPIO6_IO23, 0x037C, 0x0068, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__USB_H3_DATA, 0x0380, 0x006C, 0, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_RX_CTL__RGMII_RX_CTL, 0x0380, 0x006C, 1, 0x0858, 0, 0) -MX6_PAD_DECL(RGMII_RX_CTL__GPIO6_IO24, 0x0380, 0x006C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD0__HSI_RX_READY, 0x0384, 0x0070, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD0__RGMII_RD0, 0x0384, 0x0070, 1, 0x0848, 0, 0) -MX6_PAD_DECL(RGMII_RD0__GPIO6_IO25, 0x0384, 0x0070, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RX_CTL__GPIO6_IO24, 0x0380, 0x006C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD0__HSI_RX_READY, 0x0384, 0x0070, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD0__RGMII_RD0, 0x0384, 0x0070, 1, 0x0848, 0, 0) +MX6_PAD_DECL(RGMII_RD0__GPIO6_IO25, 0x0384, 0x0070, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TX_CTL__USB_H2_STROBE, 0x0388, 0x0074, 0, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TX_CTL__RGMII_TX_CTL, 0x0388, 0x0074, 1, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_TX_CTL__GPIO6_IO26, 0x0388, 0x0074, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_TX_CTL__GPIO6_IO26, 0x0388, 0x0074, 5, 0x0000, 0, 0) MX6_PAD_DECL(RGMII_TX_CTL__ENET_REF_CLK, 0x0388, 0x0074, 7, 0x083C, 0, 0) -MX6_PAD_DECL(RGMII_RD1__HSI_TX_FLAG, 0x038C, 0x0078, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD1__RGMII_RD1, 0x038C, 0x0078, 1, 0x084C, 0, 0) -MX6_PAD_DECL(RGMII_RD1__GPIO6_IO27, 0x038C, 0x0078, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD2__HSI_TX_DATA, 0x0390, 0x007C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD2__RGMII_RD2, 0x0390, 0x007C, 1, 0x0850, 0, 0) -MX6_PAD_DECL(RGMII_RD2__GPIO6_IO28, 0x0390, 0x007C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD3__HSI_TX_WAKE, 0x0394, 0x0080, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RD3__RGMII_RD3, 0x0394, 0x0080, 1, 0x0854, 0, 0) -MX6_PAD_DECL(RGMII_RD3__GPIO6_IO29, 0x0394, 0x0080, 5, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RXC__USB_H3_STROBE, 0x0398, 0x0084, 0, 0x0000, 0, 0) -MX6_PAD_DECL(RGMII_RXC__RGMII_RXC, 0x0398, 0x0084, 1, 0x0844, 0, 0) -MX6_PAD_DECL(RGMII_RXC__GPIO6_IO30, 0x0398, 0x0084, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__EIM_ADDR25, 0x039C, 0x0088, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__ECSPI4_SS1, 0x039C, 0x0088, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__ECSPI2_RDY, 0x039C, 0x0088, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__IPU1_DI1_PIN12, 0x039C, 0x0088, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__IPU1_DI0_D1_CS, 0x039C, 0x0088, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__GPIO5_IO02, 0x039C, 0x0088, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A25__HDMI_TX_CEC_LINE, 0x039C, 0x0088, 6, 0x088C, 0, 0) -MX6_PAD_DECL(EIM_EB2__EIM_EB2_B, 0x03A0, 0x008C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB2__ECSPI1_SS0, 0x03A0, 0x008C, 1, 0x0800, 0, 0) -MX6_PAD_DECL(EIM_EB2__IPU2_CSI1_DATA19, 0x03A0, 0x008C, 3, 0x08D4, 0, 0) -MX6_PAD_DECL(EIM_EB2__HDMI_TX_DDC_SCL, 0x03A0, 0x008C, 4, 0x0890, 0, 0) -MX6_PAD_DECL(EIM_EB2__GPIO2_IO30, 0x03A0, 0x008C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB2__I2C2_SCL, 0x03A0, 0x008C, 22, 0x08A0, 0, 0) -MX6_PAD_DECL(EIM_EB2__SRC_BOOT_CFG30, 0x03A0, 0x008C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__EIM_DATA16, 0x03A4, 0x0090, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__ECSPI1_SCLK, 0x03A4, 0x0090, 1, 0x07F4, 0, 0) -MX6_PAD_DECL(EIM_D16__IPU1_DI0_PIN05, 0x03A4, 0x0090, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__IPU2_CSI1_DATA18, 0x03A4, 0x0090, 3, 0x08D0, 0, 0) -MX6_PAD_DECL(EIM_D16__HDMI_TX_DDC_SDA, 0x03A4, 0x0090, 4, 0x0894, 0, 0) -MX6_PAD_DECL(EIM_D16__GPIO3_IO16, 0x03A4, 0x0090, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D16__I2C2_SDA, 0x03A4, 0x0090, 22, 0x08A4, 0, 0) -MX6_PAD_DECL(EIM_D17__EIM_DATA17, 0x03A8, 0x0094, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__ECSPI1_MISO, 0x03A8, 0x0094, 1, 0x07F8, 0, 0) -MX6_PAD_DECL(EIM_D17__IPU1_DI0_PIN06, 0x03A8, 0x0094, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__IPU2_CSI1_PIXCLK, 0x03A8, 0x0094, 3, 0x08E0, 0, 0) -MX6_PAD_DECL(EIM_D17__DCIC1_OUT, 0x03A8, 0x0094, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__GPIO3_IO17, 0x03A8, 0x0094, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D17__I2C3_SCL, 0x03A8, 0x0094, 22, 0x08A8, 0, 0) -MX6_PAD_DECL(EIM_D18__EIM_DATA18, 0x03AC, 0x0098, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__ECSPI1_MOSI, 0x03AC, 0x0098, 1, 0x07FC, 0, 0) -MX6_PAD_DECL(EIM_D18__IPU1_DI0_PIN07, 0x03AC, 0x0098, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__IPU2_CSI1_DATA17, 0x03AC, 0x0098, 3, 0x08CC, 0, 0) -MX6_PAD_DECL(EIM_D18__IPU1_DI1_D0_CS, 0x03AC, 0x0098, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__GPIO3_IO18, 0x03AC, 0x0098, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D18__I2C3_SDA, 0x03AC, 0x0098, 22, 0x08AC, 0, 0) -MX6_PAD_DECL(EIM_D19__EIM_DATA19, 0x03B0, 0x009C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__ECSPI1_SS1, 0x03B0, 0x009C, 1, 0x0804, 0, 0) -MX6_PAD_DECL(EIM_D19__IPU1_DI0_PIN08, 0x03B0, 0x009C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__IPU2_CSI1_DATA16, 0x03B0, 0x009C, 3, 0x08C8, 0, 0) -MX6_PAD_DECL(EIM_D19__UART1_CTS_B, 0x03B0, 0x009C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__UART1_RTS_B, 0x03B0, 0x009C, 4, 0x091C, 0, 0) -MX6_PAD_DECL(EIM_D19__GPIO3_IO19, 0x03B0, 0x009C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D19__EPIT1_OUT, 0x03B0, 0x009C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__EIM_DATA20, 0x03B4, 0x00A0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__ECSPI4_SS0, 0x03B4, 0x00A0, 1, 0x0824, 0, 0) -MX6_PAD_DECL(EIM_D20__IPU1_DI0_PIN16, 0x03B4, 0x00A0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__IPU2_CSI1_DATA15, 0x03B4, 0x00A0, 3, 0x08C4, 0, 0) -MX6_PAD_DECL(EIM_D20__UART1_CTS_B, 0x03B4, 0x00A0, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__UART1_RTS_B, 0x03B4, 0x00A0, 4, 0x091C, 1, 0) -MX6_PAD_DECL(EIM_D20__GPIO3_IO20, 0x03B4, 0x00A0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D20__EPIT2_OUT, 0x03B4, 0x00A0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__EIM_DATA21, 0x03B8, 0x00A4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__ECSPI4_SCLK, 0x03B8, 0x00A4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__IPU1_DI0_PIN17, 0x03B8, 0x00A4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__IPU2_CSI1_DATA11, 0x03B8, 0x00A4, 3, 0x08B4, 0, 0) -MX6_PAD_DECL(EIM_D21__USB_OTG_OC, 0x03B8, 0x00A4, 4, 0x0944, 0, 0) -MX6_PAD_DECL(EIM_D21__GPIO3_IO21, 0x03B8, 0x00A4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D21__I2C1_SCL, 0x03B8, 0x00A4, 22, 0x0898, 0, 0) -MX6_PAD_DECL(EIM_D21__SPDIF_IN, 0x03B8, 0x00A4, 7, 0x0914, 0, 0) -MX6_PAD_DECL(EIM_D22__EIM_DATA22, 0x03BC, 0x00A8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__ECSPI4_MISO, 0x03BC, 0x00A8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__IPU1_DI0_PIN01, 0x03BC, 0x00A8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__IPU2_CSI1_DATA10, 0x03BC, 0x00A8, 3, 0x08B0, 0, 0) -MX6_PAD_DECL(EIM_D22__USB_OTG_PWR, 0x03BC, 0x00A8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__GPIO3_IO22, 0x03BC, 0x00A8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D22__SPDIF_OUT, 0x03BC, 0x00A8, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__EIM_DATA23, 0x03C0, 0x00AC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__IPU1_DI0_D0_CS, 0x03C0, 0x00AC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__UART3_CTS_B, 0x03C0, 0x00AC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__UART3_RTS_B, 0x03C0, 0x00AC, 2, 0x092C, 0, 0) -MX6_PAD_DECL(EIM_D23__UART1_DCD_B, 0x03C0, 0x00AC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__HSI_TX_FLAG, 0x038C, 0x0078, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD1__RGMII_RD1, 0x038C, 0x0078, 1, 0x084C, 0, 0) +MX6_PAD_DECL(RGMII_RD1__GPIO6_IO27, 0x038C, 0x0078, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__HSI_TX_DATA, 0x0390, 0x007C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD2__RGMII_RD2, 0x0390, 0x007C, 1, 0x0850, 0, 0) +MX6_PAD_DECL(RGMII_RD2__GPIO6_IO28, 0x0390, 0x007C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__HSI_TX_WAKE, 0x0394, 0x0080, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RD3__RGMII_RD3, 0x0394, 0x0080, 1, 0x0854, 0, 0) +MX6_PAD_DECL(RGMII_RD3__GPIO6_IO29, 0x0394, 0x0080, 5, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__USB_H3_STROBE, 0x0398, 0x0084, 0, 0x0000, 0, 0) +MX6_PAD_DECL(RGMII_RXC__RGMII_RXC, 0x0398, 0x0084, 1, 0x0844, 0, 0) +MX6_PAD_DECL(RGMII_RXC__GPIO6_IO30, 0x0398, 0x0084, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__EIM_ADDR25, 0x039C, 0x0088, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI4_SS1, 0x039C, 0x0088, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__ECSPI2_RDY, 0x039C, 0x0088, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI1_PIN12, 0x039C, 0x0088, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__IPU1_DI0_D1_CS, 0x039C, 0x0088, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__GPIO5_IO02, 0x039C, 0x0088, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A25__HDMI_TX_CEC_LINE, 0x039C, 0x0088, 6, 0x088C, 0, 0) +MX6_PAD_DECL(EIM_EB2__EIM_EB2_B, 0x03A0, 0x008C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__ECSPI1_SS0, 0x03A0, 0x008C, 1, 0x0800, 0, 0) +MX6_PAD_DECL(EIM_EB2__IPU2_CSI1_DATA19, 0x03A0, 0x008C, 3, 0x08D4, 0, 0) +MX6_PAD_DECL(EIM_EB2__HDMI_TX_DDC_SCL, 0x03A0, 0x008C, 4, 0x0890, 0, 0) +MX6_PAD_DECL(EIM_EB2__GPIO2_IO30, 0x03A0, 0x008C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB2__I2C2_SCL, 0x03A0, 0x008C, 22, 0x08A0, 0, 0) +MX6_PAD_DECL(EIM_EB2__SRC_BOOT_CFG30, 0x03A0, 0x008C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__EIM_DATA16, 0x03A4, 0x0090, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__ECSPI1_SCLK, 0x03A4, 0x0090, 1, 0x07F4, 0, 0) +MX6_PAD_DECL(EIM_D16__IPU1_DI0_PIN05, 0x03A4, 0x0090, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__IPU2_CSI1_DATA18, 0x03A4, 0x0090, 3, 0x08D0, 0, 0) +MX6_PAD_DECL(EIM_D16__HDMI_TX_DDC_SDA, 0x03A4, 0x0090, 4, 0x0894, 0, 0) +MX6_PAD_DECL(EIM_D16__GPIO3_IO16, 0x03A4, 0x0090, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D16__I2C2_SDA, 0x03A4, 0x0090, 22, 0x08A4, 0, 0) +MX6_PAD_DECL(EIM_D17__EIM_DATA17, 0x03A8, 0x0094, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__ECSPI1_MISO, 0x03A8, 0x0094, 1, 0x07F8, 0, 0) +MX6_PAD_DECL(EIM_D17__IPU1_DI0_PIN06, 0x03A8, 0x0094, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__IPU2_CSI1_PIXCLK, 0x03A8, 0x0094, 3, 0x08E0, 0, 0) +MX6_PAD_DECL(EIM_D17__DCIC1_OUT, 0x03A8, 0x0094, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__GPIO3_IO17, 0x03A8, 0x0094, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D17__I2C3_SCL, 0x03A8, 0x0094, 22, 0x08A8, 0, 0) +MX6_PAD_DECL(EIM_D18__EIM_DATA18, 0x03AC, 0x0098, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__ECSPI1_MOSI, 0x03AC, 0x0098, 1, 0x07FC, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI0_PIN07, 0x03AC, 0x0098, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU2_CSI1_DATA17, 0x03AC, 0x0098, 3, 0x08CC, 0, 0) +MX6_PAD_DECL(EIM_D18__IPU1_DI1_D0_CS, 0x03AC, 0x0098, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__GPIO3_IO18, 0x03AC, 0x0098, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D18__I2C3_SDA, 0x03AC, 0x0098, 22, 0x08AC, 0, 0) +MX6_PAD_DECL(EIM_D19__EIM_DATA19, 0x03B0, 0x009C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__ECSPI1_SS1, 0x03B0, 0x009C, 1, 0x0804, 0, 0) +MX6_PAD_DECL(EIM_D19__IPU1_DI0_PIN08, 0x03B0, 0x009C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__IPU2_CSI1_DATA16, 0x03B0, 0x009C, 3, 0x08C8, 0, 0) +MX6_PAD_DECL(EIM_D19__UART1_CTS_B, 0x03B0, 0x009C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__UART1_RTS_B, 0x03B0, 0x009C, 4, 0x091C, 0, 0) +MX6_PAD_DECL(EIM_D19__GPIO3_IO19, 0x03B0, 0x009C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D19__EPIT1_OUT, 0x03B0, 0x009C, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EIM_DATA20, 0x03B4, 0x00A0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__ECSPI4_SS0, 0x03B4, 0x00A0, 1, 0x0824, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU1_DI0_PIN16, 0x03B4, 0x00A0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__IPU2_CSI1_DATA15, 0x03B4, 0x00A0, 3, 0x08C4, 0, 0) +MX6_PAD_DECL(EIM_D20__UART1_CTS_B, 0x03B4, 0x00A0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__UART1_RTS_B, 0x03B4, 0x00A0, 4, 0x091C, 1, 0) +MX6_PAD_DECL(EIM_D20__GPIO3_IO20, 0x03B4, 0x00A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D20__EPIT2_OUT, 0x03B4, 0x00A0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__EIM_DATA21, 0x03B8, 0x00A4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__ECSPI4_SCLK, 0x03B8, 0x00A4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU1_DI0_PIN17, 0x03B8, 0x00A4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__IPU2_CSI1_DATA11, 0x03B8, 0x00A4, 3, 0x08B4, 0, 0) +MX6_PAD_DECL(EIM_D21__USB_OTG_OC, 0x03B8, 0x00A4, 4, 0x0944, 0, 0) +MX6_PAD_DECL(EIM_D21__GPIO3_IO21, 0x03B8, 0x00A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D21__I2C1_SCL, 0x03B8, 0x00A4, 22, 0x0898, 0, 0) +MX6_PAD_DECL(EIM_D21__SPDIF_IN, 0x03B8, 0x00A4, 7, 0x0914, 0, 0) +MX6_PAD_DECL(EIM_D22__EIM_DATA22, 0x03BC, 0x00A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__ECSPI4_MISO, 0x03BC, 0x00A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU1_DI0_PIN01, 0x03BC, 0x00A8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__IPU2_CSI1_DATA10, 0x03BC, 0x00A8, 3, 0x08B0, 0, 0) +MX6_PAD_DECL(EIM_D22__USB_OTG_PWR, 0x03BC, 0x00A8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__GPIO3_IO22, 0x03BC, 0x00A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D22__SPDIF_OUT, 0x03BC, 0x00A8, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__EIM_DATA23, 0x03C0, 0x00AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI0_D0_CS, 0x03C0, 0x00AC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_CTS_B, 0x03C0, 0x00AC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__UART3_RTS_B, 0x03C0, 0x00AC, 2, 0x092C, 0, 0) +MX6_PAD_DECL(EIM_D23__UART1_DCD_B, 0x03C0, 0x00AC, 3, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D23__IPU2_CSI1_DATA_EN, 0x03C0, 0x00AC, 4, 0x08D8, 0, 0) -MX6_PAD_DECL(EIM_D23__GPIO3_IO23, 0x03C0, 0x00AC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN02, 0x03C0, 0x00AC, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN14, 0x03C0, 0x00AC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__EIM_EB3_B, 0x03C4, 0x00B0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__ECSPI4_RDY, 0x03C4, 0x00B0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__UART3_CTS_B, 0x03C4, 0x00B0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__UART3_RTS_B, 0x03C4, 0x00B0, 2, 0x092C, 1, 0) -MX6_PAD_DECL(EIM_EB3__UART1_RI_B, 0x03C4, 0x00B0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__IPU2_CSI1_HSYNC, 0x03C4, 0x00B0, 4, 0x08DC, 0, 0) -MX6_PAD_DECL(EIM_EB3__GPIO2_IO31, 0x03C4, 0x00B0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__IPU1_DI1_PIN03, 0x03C4, 0x00B0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB3__SRC_BOOT_CFG31, 0x03C4, 0x00B0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__EIM_DATA24, 0x03C8, 0x00B4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__ECSPI4_SS2, 0x03C8, 0x00B4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__UART3_TX_DATA, 0x03C8, 0x00B4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__UART3_RX_DATA, 0x03C8, 0x00B4, 2, 0x0930, 0, 0) -MX6_PAD_DECL(EIM_D24__ECSPI1_SS2, 0x03C8, 0x00B4, 3, 0x0808, 0, 0) -MX6_PAD_DECL(EIM_D24__ECSPI2_SS2, 0x03C8, 0x00B4, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__GPIO3_IO24, 0x03C8, 0x00B4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D24__AUD5_RXFS, 0x03C8, 0x00B4, 6, 0x07D8, 0, 0) -MX6_PAD_DECL(EIM_D24__UART1_DTR_B, 0x03C8, 0x00B4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__EIM_DATA25, 0x03CC, 0x00B8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__ECSPI4_SS3, 0x03CC, 0x00B8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__UART3_TX_DATA, 0x03CC, 0x00B8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__UART3_RX_DATA, 0x03CC, 0x00B8, 2, 0x0930, 1, 0) -MX6_PAD_DECL(EIM_D25__ECSPI1_SS3, 0x03CC, 0x00B8, 3, 0x080C, 0, 0) -MX6_PAD_DECL(EIM_D25__ECSPI2_SS3, 0x03CC, 0x00B8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__GPIO3_IO25, 0x03CC, 0x00B8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D25__AUD5_RXC, 0x03CC, 0x00B8, 6, 0x07D4, 0, 0) -MX6_PAD_DECL(EIM_D25__UART1_DSR_B, 0x03CC, 0x00B8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__EIM_DATA26, 0x03D0, 0x00BC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_DI1_PIN11, 0x03D0, 0x00BC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_CSI0_DATA01, 0x03D0, 0x00BC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU2_CSI1_DATA14, 0x03D0, 0x00BC, 3, 0x08C0, 0, 0) -MX6_PAD_DECL(EIM_D26__UART2_TX_DATA, 0x03D0, 0x00BC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__UART2_RX_DATA, 0x03D0, 0x00BC, 4, 0x0928, 0, 0) -MX6_PAD_DECL(EIM_D26__GPIO3_IO26, 0x03D0, 0x00BC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D26__IPU1_SISG2, 0x03D0, 0x00BC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__GPIO3_IO23, 0x03C0, 0x00AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN02, 0x03C0, 0x00AC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D23__IPU1_DI1_PIN14, 0x03C0, 0x00AC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__EIM_EB3_B, 0x03C4, 0x00B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__ECSPI4_RDY, 0x03C4, 0x00B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_CTS_B, 0x03C4, 0x00B0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__UART3_RTS_B, 0x03C4, 0x00B0, 2, 0x092C, 1, 0) +MX6_PAD_DECL(EIM_EB3__UART1_RI_B, 0x03C4, 0x00B0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU2_CSI1_HSYNC, 0x03C4, 0x00B0, 4, 0x08DC, 0, 0) +MX6_PAD_DECL(EIM_EB3__GPIO2_IO31, 0x03C4, 0x00B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__IPU1_DI1_PIN03, 0x03C4, 0x00B0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB3__SRC_BOOT_CFG31, 0x03C4, 0x00B0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__EIM_DATA24, 0x03C8, 0x00B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI4_SS2, 0x03C8, 0x00B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_TX_DATA, 0x03C8, 0x00B4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__UART3_RX_DATA, 0x03C8, 0x00B4, 2, 0x0930, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI1_SS2, 0x03C8, 0x00B4, 3, 0x0808, 0, 0) +MX6_PAD_DECL(EIM_D24__ECSPI2_SS2, 0x03C8, 0x00B4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__GPIO3_IO24, 0x03C8, 0x00B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D24__AUD5_RXFS, 0x03C8, 0x00B4, 6, 0x07D8, 0, 0) +MX6_PAD_DECL(EIM_D24__UART1_DTR_B, 0x03C8, 0x00B4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__EIM_DATA25, 0x03CC, 0x00B8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI4_SS3, 0x03CC, 0x00B8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_TX_DATA, 0x03CC, 0x00B8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__UART3_RX_DATA, 0x03CC, 0x00B8, 2, 0x0930, 1, 0) +MX6_PAD_DECL(EIM_D25__ECSPI1_SS3, 0x03CC, 0x00B8, 3, 0x080C, 0, 0) +MX6_PAD_DECL(EIM_D25__ECSPI2_SS3, 0x03CC, 0x00B8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__GPIO3_IO25, 0x03CC, 0x00B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D25__AUD5_RXC, 0x03CC, 0x00B8, 6, 0x07D4, 0, 0) +MX6_PAD_DECL(EIM_D25__UART1_DSR_B, 0x03CC, 0x00B8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__EIM_DATA26, 0x03D0, 0x00BC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_DI1_PIN11, 0x03D0, 0x00BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_CSI0_DATA01, 0x03D0, 0x00BC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU2_CSI1_DATA14, 0x03D0, 0x00BC, 3, 0x08C0, 0, 0) +MX6_PAD_DECL(EIM_D26__UART2_TX_DATA, 0x03D0, 0x00BC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__UART2_RX_DATA, 0x03D0, 0x00BC, 4, 0x0928, 0, 0) +MX6_PAD_DECL(EIM_D26__GPIO3_IO26, 0x03D0, 0x00BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D26__IPU1_SISG2, 0x03D0, 0x00BC, 6, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D26__IPU1_DISP1_DATA22, 0x03D0, 0x00BC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__EIM_DATA27, 0x03D4, 0x00C0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_DI1_PIN13, 0x03D4, 0x00C0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_CSI0_DATA00, 0x03D4, 0x00C0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU2_CSI1_DATA13, 0x03D4, 0x00C0, 3, 0x08BC, 0, 0) -MX6_PAD_DECL(EIM_D27__UART2_TX_DATA, 0x03D4, 0x00C0, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__UART2_RX_DATA, 0x03D4, 0x00C0, 4, 0x0928, 1, 0) -MX6_PAD_DECL(EIM_D27__GPIO3_IO27, 0x03D4, 0x00C0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D27__IPU1_SISG3, 0x03D4, 0x00C0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__EIM_DATA27, 0x03D4, 0x00C0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_DI1_PIN13, 0x03D4, 0x00C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_CSI0_DATA00, 0x03D4, 0x00C0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU2_CSI1_DATA13, 0x03D4, 0x00C0, 3, 0x08BC, 0, 0) +MX6_PAD_DECL(EIM_D27__UART2_TX_DATA, 0x03D4, 0x00C0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__UART2_RX_DATA, 0x03D4, 0x00C0, 4, 0x0928, 1, 0) +MX6_PAD_DECL(EIM_D27__GPIO3_IO27, 0x03D4, 0x00C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D27__IPU1_SISG3, 0x03D4, 0x00C0, 6, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D27__IPU1_DISP1_DATA23, 0x03D4, 0x00C0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__EIM_DATA28, 0x03D8, 0x00C4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__I2C1_SDA, 0x03D8, 0x00C4, 17, 0x089C, 0, 0) -MX6_PAD_DECL(EIM_D28__ECSPI4_MOSI, 0x03D8, 0x00C4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__IPU2_CSI1_DATA12, 0x03D8, 0x00C4, 3, 0x08B8, 0, 0) -MX6_PAD_DECL(EIM_D28__UART2_DTE_CTS_B, 0x03D8, 0x00C4, 4, 0x0924, 0, 0) -MX6_PAD_DECL(EIM_D28__UART2_DTE_RTS_B, 0x03D8, 0x00C4, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__GPIO3_IO28, 0x03D8, 0x00C4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__IPU1_EXT_TRIG, 0x03D8, 0x00C4, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D28__IPU1_DI0_PIN13, 0x03D8, 0x00C4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__EIM_DATA29, 0x03DC, 0x00C8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__IPU1_DI1_PIN15, 0x03DC, 0x00C8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__ECSPI4_SS0, 0x03DC, 0x00C8, 2, 0x0824, 1, 0) -MX6_PAD_DECL(EIM_D29__UART2_CTS_B, 0x03DC, 0x00C8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__UART2_RTS_B, 0x03DC, 0x00C8, 4, 0x0924, 1, 0) -MX6_PAD_DECL(EIM_D29__GPIO3_IO29, 0x03DC, 0x00C8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D29__IPU2_CSI1_VSYNC, 0x03DC, 0x00C8, 6, 0x08E4, 0, 0) -MX6_PAD_DECL(EIM_D29__IPU1_DI0_PIN14, 0x03DC, 0x00C8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__EIM_DATA30, 0x03E0, 0x00CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__EIM_DATA28, 0x03D8, 0x00C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__I2C1_SDA, 0x03D8, 0x00C4, 17, 0x089C, 0, 0) +MX6_PAD_DECL(EIM_D28__ECSPI4_MOSI, 0x03D8, 0x00C4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU2_CSI1_DATA12, 0x03D8, 0x00C4, 3, 0x08B8, 0, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_CTS_B, 0x03D8, 0x00C4, 4, 0x0924, 0, 0) +MX6_PAD_DECL(EIM_D28__UART2_DTE_RTS_B, 0x03D8, 0x00C4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__GPIO3_IO28, 0x03D8, 0x00C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_EXT_TRIG, 0x03D8, 0x00C4, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D28__IPU1_DI0_PIN13, 0x03D8, 0x00C4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__EIM_DATA29, 0x03DC, 0x00C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI1_PIN15, 0x03DC, 0x00C8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__ECSPI4_SS0, 0x03DC, 0x00C8, 2, 0x0824, 1, 0) +MX6_PAD_DECL(EIM_D29__UART2_CTS_B, 0x03DC, 0x00C8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__UART2_RTS_B, 0x03DC, 0x00C8, 4, 0x0924, 1, 0) +MX6_PAD_DECL(EIM_D29__GPIO3_IO29, 0x03DC, 0x00C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU2_CSI1_VSYNC, 0x03DC, 0x00C8, 6, 0x08E4, 0, 0) +MX6_PAD_DECL(EIM_D29__IPU1_DI0_PIN14, 0x03DC, 0x00C8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__EIM_DATA30, 0x03E0, 0x00CC, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D30__IPU1_DISP1_DATA21, 0x03E0, 0x00CC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__IPU1_DI0_PIN11, 0x03E0, 0x00CC, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__IPU1_CSI0_DATA03, 0x03E0, 0x00CC, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__UART3_CTS_B, 0x03E0, 0x00CC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__UART3_RTS_B, 0x03E0, 0x00CC, 4, 0x092C, 2, 0) -MX6_PAD_DECL(EIM_D30__GPIO3_IO30, 0x03E0, 0x00CC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D30__USB_H1_OC, 0x03E0, 0x00CC, 6, 0x0948, 0, 0) -MX6_PAD_DECL(EIM_D31__EIM_DATA31, 0x03E4, 0x00D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_DI0_PIN11, 0x03E0, 0x00CC, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__IPU1_CSI0_DATA03, 0x03E0, 0x00CC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_CTS_B, 0x03E0, 0x00CC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__UART3_RTS_B, 0x03E0, 0x00CC, 4, 0x092C, 2, 0) +MX6_PAD_DECL(EIM_D30__GPIO3_IO30, 0x03E0, 0x00CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D30__USB_H1_OC, 0x03E0, 0x00CC, 6, 0x0948, 0, 0) +MX6_PAD_DECL(EIM_D31__EIM_DATA31, 0x03E4, 0x00D0, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_D31__IPU1_DISP1_DATA20, 0x03E4, 0x00D0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__IPU1_DI0_PIN12, 0x03E4, 0x00D0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__IPU1_CSI0_DATA02, 0x03E4, 0x00D0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__UART3_CTS_B, 0x03E4, 0x00D0, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__UART3_RTS_B, 0x03E4, 0x00D0, 4, 0x092C, 3, 0) -MX6_PAD_DECL(EIM_D31__GPIO3_IO31, 0x03E4, 0x00D0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_D31__USB_H1_PWR, 0x03E4, 0x00D0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__EIM_ADDR24, 0x03E8, 0x00D4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_DI0_PIN12, 0x03E4, 0x00D0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__IPU1_CSI0_DATA02, 0x03E4, 0x00D0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_CTS_B, 0x03E4, 0x00D0, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__UART3_RTS_B, 0x03E4, 0x00D0, 4, 0x092C, 3, 0) +MX6_PAD_DECL(EIM_D31__GPIO3_IO31, 0x03E4, 0x00D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_D31__USB_H1_PWR, 0x03E4, 0x00D0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__EIM_ADDR24, 0x03E8, 0x00D4, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A24__IPU1_DISP1_DATA19, 0x03E8, 0x00D4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__IPU2_CSI1_DATA19, 0x03E8, 0x00D4, 2, 0x08D4, 1, 0) -MX6_PAD_DECL(EIM_A24__IPU2_SISG2, 0x03E8, 0x00D4, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__IPU1_SISG2, 0x03E8, 0x00D4, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__GPIO5_IO04, 0x03E8, 0x00D4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A24__SRC_BOOT_CFG24, 0x03E8, 0x00D4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__EIM_ADDR23, 0x03EC, 0x00D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU2_CSI1_DATA19, 0x03E8, 0x00D4, 2, 0x08D4, 1, 0) +MX6_PAD_DECL(EIM_A24__IPU2_SISG2, 0x03E8, 0x00D4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__IPU1_SISG2, 0x03E8, 0x00D4, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__GPIO5_IO04, 0x03E8, 0x00D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A24__SRC_BOOT_CFG24, 0x03E8, 0x00D4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__EIM_ADDR23, 0x03EC, 0x00D8, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A23__IPU1_DISP1_DATA18, 0x03EC, 0x00D8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__IPU2_CSI1_DATA18, 0x03EC, 0x00D8, 2, 0x08D0, 1, 0) -MX6_PAD_DECL(EIM_A23__IPU2_SISG3, 0x03EC, 0x00D8, 3, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__IPU1_SISG3, 0x03EC, 0x00D8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__GPIO6_IO06, 0x03EC, 0x00D8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A23__SRC_BOOT_CFG23, 0x03EC, 0x00D8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__EIM_ADDR22, 0x03F0, 0x00DC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU2_CSI1_DATA18, 0x03EC, 0x00D8, 2, 0x08D0, 1, 0) +MX6_PAD_DECL(EIM_A23__IPU2_SISG3, 0x03EC, 0x00D8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__IPU1_SISG3, 0x03EC, 0x00D8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__GPIO6_IO06, 0x03EC, 0x00D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A23__SRC_BOOT_CFG23, 0x03EC, 0x00D8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__EIM_ADDR22, 0x03F0, 0x00DC, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A22__IPU1_DISP1_DATA17, 0x03F0, 0x00DC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__IPU2_CSI1_DATA17, 0x03F0, 0x00DC, 2, 0x08CC, 1, 0) -MX6_PAD_DECL(EIM_A22__GPIO2_IO16, 0x03F0, 0x00DC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A22__SRC_BOOT_CFG22, 0x03F0, 0x00DC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__EIM_ADDR21, 0x03F4, 0x00E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__IPU2_CSI1_DATA17, 0x03F0, 0x00DC, 2, 0x08CC, 1, 0) +MX6_PAD_DECL(EIM_A22__GPIO2_IO16, 0x03F0, 0x00DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A22__SRC_BOOT_CFG22, 0x03F0, 0x00DC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__EIM_ADDR21, 0x03F4, 0x00E0, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A21__IPU1_DISP1_DATA16, 0x03F4, 0x00E0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__IPU2_CSI1_DATA16, 0x03F4, 0x00E0, 2, 0x08C8, 1, 0) -MX6_PAD_DECL(EIM_A21__GPIO2_IO17, 0x03F4, 0x00E0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A21__SRC_BOOT_CFG21, 0x03F4, 0x00E0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__EIM_ADDR20, 0x03F8, 0x00E4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__IPU2_CSI1_DATA16, 0x03F4, 0x00E0, 2, 0x08C8, 1, 0) +MX6_PAD_DECL(EIM_A21__GPIO2_IO17, 0x03F4, 0x00E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A21__SRC_BOOT_CFG21, 0x03F4, 0x00E0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__EIM_ADDR20, 0x03F8, 0x00E4, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A20__IPU1_DISP1_DATA15, 0x03F8, 0x00E4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__IPU2_CSI1_DATA15, 0x03F8, 0x00E4, 2, 0x08C4, 1, 0) -MX6_PAD_DECL(EIM_A20__GPIO2_IO18, 0x03F8, 0x00E4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A20__SRC_BOOT_CFG20, 0x03F8, 0x00E4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__EIM_ADDR19, 0x03FC, 0x00E8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__IPU2_CSI1_DATA15, 0x03F8, 0x00E4, 2, 0x08C4, 1, 0) +MX6_PAD_DECL(EIM_A20__GPIO2_IO18, 0x03F8, 0x00E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A20__SRC_BOOT_CFG20, 0x03F8, 0x00E4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__EIM_ADDR19, 0x03FC, 0x00E8, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A19__IPU1_DISP1_DATA14, 0x03FC, 0x00E8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__IPU2_CSI1_DATA14, 0x03FC, 0x00E8, 2, 0x08C0, 1, 0) -MX6_PAD_DECL(EIM_A19__GPIO2_IO19, 0x03FC, 0x00E8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A19__SRC_BOOT_CFG19, 0x03FC, 0x00E8, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__EIM_ADDR18, 0x0400, 0x00EC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__IPU2_CSI1_DATA14, 0x03FC, 0x00E8, 2, 0x08C0, 1, 0) +MX6_PAD_DECL(EIM_A19__GPIO2_IO19, 0x03FC, 0x00E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A19__SRC_BOOT_CFG19, 0x03FC, 0x00E8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__EIM_ADDR18, 0x0400, 0x00EC, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A18__IPU1_DISP1_DATA13, 0x0400, 0x00EC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__IPU2_CSI1_DATA13, 0x0400, 0x00EC, 2, 0x08BC, 1, 0) -MX6_PAD_DECL(EIM_A18__GPIO2_IO20, 0x0400, 0x00EC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A18__SRC_BOOT_CFG18, 0x0400, 0x00EC, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__EIM_ADDR17, 0x0404, 0x00F0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__IPU2_CSI1_DATA13, 0x0400, 0x00EC, 2, 0x08BC, 1, 0) +MX6_PAD_DECL(EIM_A18__GPIO2_IO20, 0x0400, 0x00EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A18__SRC_BOOT_CFG18, 0x0400, 0x00EC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__EIM_ADDR17, 0x0404, 0x00F0, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A17__IPU1_DISP1_DATA12, 0x0404, 0x00F0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__IPU2_CSI1_DATA12, 0x0404, 0x00F0, 2, 0x08B8, 1, 0) -MX6_PAD_DECL(EIM_A17__GPIO2_IO21, 0x0404, 0x00F0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A17__SRC_BOOT_CFG17, 0x0404, 0x00F0, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__EIM_ADDR16, 0x0408, 0x00F4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__IPU2_CSI1_DATA12, 0x0404, 0x00F0, 2, 0x08B8, 1, 0) +MX6_PAD_DECL(EIM_A17__GPIO2_IO21, 0x0404, 0x00F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A17__SRC_BOOT_CFG17, 0x0404, 0x00F0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__EIM_ADDR16, 0x0408, 0x00F4, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_A16__IPU1_DI1_DISP_CLK, 0x0408, 0x00F4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__IPU2_CSI1_PIXCLK, 0x0408, 0x00F4, 2, 0x08E0, 1, 0) -MX6_PAD_DECL(EIM_A16__GPIO2_IO22, 0x0408, 0x00F4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_A16__SRC_BOOT_CFG16, 0x0408, 0x00F4, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__EIM_CS0_B, 0x040C, 0x00F8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__IPU1_DI1_PIN05, 0x040C, 0x00F8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS0__ECSPI2_SCLK, 0x040C, 0x00F8, 2, 0x0810, 0, 0) -MX6_PAD_DECL(EIM_CS0__GPIO2_IO23, 0x040C, 0x00F8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__EIM_CS1_B, 0x0410, 0x00FC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__IPU1_DI1_PIN06, 0x0410, 0x00FC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_CS1__ECSPI2_MOSI, 0x0410, 0x00FC, 2, 0x0818, 0, 0) -MX6_PAD_DECL(EIM_CS1__GPIO2_IO24, 0x0410, 0x00FC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__EIM_OE_B, 0x0414, 0x0100, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__IPU1_DI1_PIN07, 0x0414, 0x0100, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_OE__ECSPI2_MISO, 0x0414, 0x0100, 2, 0x0814, 0, 0) -MX6_PAD_DECL(EIM_OE__GPIO2_IO25, 0x0414, 0x0100, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__EIM_RW, 0x0418, 0x0104, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__IPU1_DI1_PIN08, 0x0418, 0x0104, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__ECSPI2_SS0, 0x0418, 0x0104, 2, 0x081C, 0, 0) -MX6_PAD_DECL(EIM_RW__GPIO2_IO26, 0x0418, 0x0104, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_RW__SRC_BOOT_CFG29, 0x0418, 0x0104, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__EIM_LBA_B, 0x041C, 0x0108, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__IPU1_DI1_PIN17, 0x041C, 0x0108, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__ECSPI2_SS1, 0x041C, 0x0108, 2, 0x0820, 0, 0) -MX6_PAD_DECL(EIM_LBA__GPIO2_IO27, 0x041C, 0x0108, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_LBA__SRC_BOOT_CFG26, 0x041C, 0x0108, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__EIM_EB0_B, 0x0420, 0x010C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__IPU2_CSI1_PIXCLK, 0x0408, 0x00F4, 2, 0x08E0, 1, 0) +MX6_PAD_DECL(EIM_A16__GPIO2_IO22, 0x0408, 0x00F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_A16__SRC_BOOT_CFG16, 0x0408, 0x00F4, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__EIM_CS0_B, 0x040C, 0x00F8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__IPU1_DI1_PIN05, 0x040C, 0x00F8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS0__ECSPI2_SCLK, 0x040C, 0x00F8, 2, 0x0810, 0, 0) +MX6_PAD_DECL(EIM_CS0__GPIO2_IO23, 0x040C, 0x00F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__EIM_CS1_B, 0x0410, 0x00FC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__IPU1_DI1_PIN06, 0x0410, 0x00FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_CS1__ECSPI2_MOSI, 0x0410, 0x00FC, 2, 0x0818, 0, 0) +MX6_PAD_DECL(EIM_CS1__GPIO2_IO24, 0x0410, 0x00FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__EIM_OE_B, 0x0414, 0x0100, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__IPU1_DI1_PIN07, 0x0414, 0x0100, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_OE__ECSPI2_MISO, 0x0414, 0x0100, 2, 0x0814, 0, 0) +MX6_PAD_DECL(EIM_OE__GPIO2_IO25, 0x0414, 0x0100, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__EIM_RW, 0x0418, 0x0104, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__IPU1_DI1_PIN08, 0x0418, 0x0104, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__ECSPI2_SS0, 0x0418, 0x0104, 2, 0x081C, 0, 0) +MX6_PAD_DECL(EIM_RW__GPIO2_IO26, 0x0418, 0x0104, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_RW__SRC_BOOT_CFG29, 0x0418, 0x0104, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__EIM_LBA_B, 0x041C, 0x0108, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__IPU1_DI1_PIN17, 0x041C, 0x0108, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__ECSPI2_SS1, 0x041C, 0x0108, 2, 0x0820, 0, 0) +MX6_PAD_DECL(EIM_LBA__GPIO2_IO27, 0x041C, 0x0108, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_LBA__SRC_BOOT_CFG26, 0x041C, 0x0108, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__EIM_EB0_B, 0x0420, 0x010C, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_EB0__IPU1_DISP1_DATA11, 0x0420, 0x010C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__IPU2_CSI1_DATA11, 0x0420, 0x010C, 2, 0x08B4, 1, 0) -MX6_PAD_DECL(EIM_EB0__CCM_PMIC_READY, 0x0420, 0x010C, 4, 0x07F0, 0, 0) -MX6_PAD_DECL(EIM_EB0__GPIO2_IO28, 0x0420, 0x010C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB0__SRC_BOOT_CFG27, 0x0420, 0x010C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__EIM_EB1_B, 0x0424, 0x0110, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__IPU2_CSI1_DATA11, 0x0420, 0x010C, 2, 0x08B4, 1, 0) +MX6_PAD_DECL(EIM_EB0__CCM_PMIC_READY, 0x0420, 0x010C, 4, 0x07F0, 0, 0) +MX6_PAD_DECL(EIM_EB0__GPIO2_IO28, 0x0420, 0x010C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB0__SRC_BOOT_CFG27, 0x0420, 0x010C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__EIM_EB1_B, 0x0424, 0x0110, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_EB1__IPU1_DISP1_DATA10, 0x0424, 0x0110, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__IPU2_CSI1_DATA10, 0x0424, 0x0110, 2, 0x08B0, 1, 0) -MX6_PAD_DECL(EIM_EB1__GPIO2_IO29, 0x0424, 0x0110, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_EB1__SRC_BOOT_CFG28, 0x0424, 0x0110, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__EIM_AD00, 0x0428, 0x0114, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__IPU2_CSI1_DATA10, 0x0424, 0x0110, 2, 0x08B0, 1, 0) +MX6_PAD_DECL(EIM_EB1__GPIO2_IO29, 0x0424, 0x0110, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_EB1__SRC_BOOT_CFG28, 0x0424, 0x0110, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__EIM_AD00, 0x0428, 0x0114, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA0__IPU1_DISP1_DATA09, 0x0428, 0x0114, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__IPU2_CSI1_DATA09, 0x0428, 0x0114, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__GPIO3_IO00, 0x0428, 0x0114, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA0__SRC_BOOT_CFG00, 0x0428, 0x0114, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__EIM_AD01, 0x042C, 0x0118, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__IPU2_CSI1_DATA09, 0x0428, 0x0114, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__GPIO3_IO00, 0x0428, 0x0114, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA0__SRC_BOOT_CFG00, 0x0428, 0x0114, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__EIM_AD01, 0x042C, 0x0118, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA1__IPU1_DISP1_DATA08, 0x042C, 0x0118, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__IPU2_CSI1_DATA08, 0x042C, 0x0118, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__GPIO3_IO01, 0x042C, 0x0118, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA1__SRC_BOOT_CFG01, 0x042C, 0x0118, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__EIM_AD02, 0x0430, 0x011C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__IPU2_CSI1_DATA08, 0x042C, 0x0118, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__GPIO3_IO01, 0x042C, 0x0118, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA1__SRC_BOOT_CFG01, 0x042C, 0x0118, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__EIM_AD02, 0x0430, 0x011C, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA2__IPU1_DISP1_DATA07, 0x0430, 0x011C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__IPU2_CSI1_DATA07, 0x0430, 0x011C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__GPIO3_IO02, 0x0430, 0x011C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA2__SRC_BOOT_CFG02, 0x0430, 0x011C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__EIM_AD03, 0x0434, 0x0120, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__IPU2_CSI1_DATA07, 0x0430, 0x011C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__GPIO3_IO02, 0x0430, 0x011C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA2__SRC_BOOT_CFG02, 0x0430, 0x011C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__EIM_AD03, 0x0434, 0x0120, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA3__IPU1_DISP1_DATA06, 0x0434, 0x0120, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__IPU2_CSI1_DATA06, 0x0434, 0x0120, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__GPIO3_IO03, 0x0434, 0x0120, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA3__SRC_BOOT_CFG03, 0x0434, 0x0120, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__EIM_AD04, 0x0438, 0x0124, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__IPU2_CSI1_DATA06, 0x0434, 0x0120, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__GPIO3_IO03, 0x0434, 0x0120, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA3__SRC_BOOT_CFG03, 0x0434, 0x0120, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__EIM_AD04, 0x0438, 0x0124, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA4__IPU1_DISP1_DATA05, 0x0438, 0x0124, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__IPU2_CSI1_DATA05, 0x0438, 0x0124, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__GPIO3_IO04, 0x0438, 0x0124, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA4__SRC_BOOT_CFG04, 0x0438, 0x0124, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__EIM_AD05, 0x043C, 0x0128, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__IPU2_CSI1_DATA05, 0x0438, 0x0124, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__GPIO3_IO04, 0x0438, 0x0124, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA4__SRC_BOOT_CFG04, 0x0438, 0x0124, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__EIM_AD05, 0x043C, 0x0128, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA5__IPU1_DISP1_DATA04, 0x043C, 0x0128, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__IPU2_CSI1_DATA04, 0x043C, 0x0128, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__GPIO3_IO05, 0x043C, 0x0128, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA5__SRC_BOOT_CFG05, 0x043C, 0x0128, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__EIM_AD06, 0x0440, 0x012C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__IPU2_CSI1_DATA04, 0x043C, 0x0128, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__GPIO3_IO05, 0x043C, 0x0128, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA5__SRC_BOOT_CFG05, 0x043C, 0x0128, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__EIM_AD06, 0x0440, 0x012C, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA6__IPU1_DISP1_DATA03, 0x0440, 0x012C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__IPU2_CSI1_DATA03, 0x0440, 0x012C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__GPIO3_IO06, 0x0440, 0x012C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA6__SRC_BOOT_CFG06, 0x0440, 0x012C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__EIM_AD07, 0x0444, 0x0130, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__IPU2_CSI1_DATA03, 0x0440, 0x012C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__GPIO3_IO06, 0x0440, 0x012C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA6__SRC_BOOT_CFG06, 0x0440, 0x012C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__EIM_AD07, 0x0444, 0x0130, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA7__IPU1_DISP1_DATA02, 0x0444, 0x0130, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__IPU2_CSI1_DATA02, 0x0444, 0x0130, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__GPIO3_IO07, 0x0444, 0x0130, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA7__SRC_BOOT_CFG07, 0x0444, 0x0130, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__EIM_AD08, 0x0448, 0x0134, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__IPU2_CSI1_DATA02, 0x0444, 0x0130, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__GPIO3_IO07, 0x0444, 0x0130, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA7__SRC_BOOT_CFG07, 0x0444, 0x0130, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__EIM_AD08, 0x0448, 0x0134, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA8__IPU1_DISP1_DATA01, 0x0448, 0x0134, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__IPU2_CSI1_DATA01, 0x0448, 0x0134, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__GPIO3_IO08, 0x0448, 0x0134, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA8__SRC_BOOT_CFG08, 0x0448, 0x0134, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__EIM_AD09, 0x044C, 0x0138, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__IPU2_CSI1_DATA01, 0x0448, 0x0134, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__GPIO3_IO08, 0x0448, 0x0134, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA8__SRC_BOOT_CFG08, 0x0448, 0x0134, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__EIM_AD09, 0x044C, 0x0138, 0, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA9__IPU1_DISP1_DATA00, 0x044C, 0x0138, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__IPU2_CSI1_DATA00, 0x044C, 0x0138, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__GPIO3_IO09, 0x044C, 0x0138, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA9__SRC_BOOT_CFG09, 0x044C, 0x0138, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__EIM_AD10, 0x0450, 0x013C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__IPU1_DI1_PIN15, 0x0450, 0x013C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__IPU2_CSI1_DATA00, 0x044C, 0x0138, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__GPIO3_IO09, 0x044C, 0x0138, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA9__SRC_BOOT_CFG09, 0x044C, 0x0138, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__EIM_AD10, 0x0450, 0x013C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__IPU1_DI1_PIN15, 0x0450, 0x013C, 1, 0x0000, 0, 0) MX6_PAD_DECL(EIM_DA10__IPU2_CSI1_DATA_EN, 0x0450, 0x013C, 2, 0x08D8, 1, 0) -MX6_PAD_DECL(EIM_DA10__GPIO3_IO10, 0x0450, 0x013C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA10__SRC_BOOT_CFG10, 0x0450, 0x013C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__EIM_AD11, 0x0454, 0x0140, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__IPU1_DI1_PIN02, 0x0454, 0x0140, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__IPU2_CSI1_HSYNC, 0x0454, 0x0140, 2, 0x08DC, 1, 0) -MX6_PAD_DECL(EIM_DA11__GPIO3_IO11, 0x0454, 0x0140, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA11__SRC_BOOT_CFG11, 0x0454, 0x0140, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__EIM_AD12, 0x0458, 0x0144, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__IPU1_DI1_PIN03, 0x0458, 0x0144, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__IPU2_CSI1_VSYNC, 0x0458, 0x0144, 2, 0x08E4, 1, 0) -MX6_PAD_DECL(EIM_DA12__GPIO3_IO12, 0x0458, 0x0144, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA12__SRC_BOOT_CFG12, 0x0458, 0x0144, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__EIM_AD13, 0x045C, 0x0148, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__IPU1_DI1_D0_CS, 0x045C, 0x0148, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__GPIO3_IO13, 0x045C, 0x0148, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA13__SRC_BOOT_CFG13, 0x045C, 0x0148, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__EIM_AD14, 0x0460, 0x014C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__IPU1_DI1_D1_CS, 0x0460, 0x014C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__GPIO3_IO14, 0x0460, 0x014C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA14__SRC_BOOT_CFG14, 0x0460, 0x014C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__EIM_AD15, 0x0464, 0x0150, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN01, 0x0464, 0x0150, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN04, 0x0464, 0x0150, 2, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__GPIO3_IO15, 0x0464, 0x0150, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_DA15__SRC_BOOT_CFG15, 0x0464, 0x0150, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__EIM_WAIT_B, 0x0468, 0x0154, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__EIM_DTACK_B, 0x0468, 0x0154, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__GPIO5_IO00, 0x0468, 0x0154, 5, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_WAIT__SRC_BOOT_CFG25, 0x0468, 0x0154, 7, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__EIM_BCLK, 0x046C, 0x0158, 0, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__IPU1_DI1_PIN16, 0x046C, 0x0158, 1, 0x0000, 0, 0) -MX6_PAD_DECL(EIM_BCLK__GPIO6_IO31, 0x046C, 0x0158, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__GPIO3_IO10, 0x0450, 0x013C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA10__SRC_BOOT_CFG10, 0x0450, 0x013C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__EIM_AD11, 0x0454, 0x0140, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU1_DI1_PIN02, 0x0454, 0x0140, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__IPU2_CSI1_HSYNC, 0x0454, 0x0140, 2, 0x08DC, 1, 0) +MX6_PAD_DECL(EIM_DA11__GPIO3_IO11, 0x0454, 0x0140, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA11__SRC_BOOT_CFG11, 0x0454, 0x0140, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__EIM_AD12, 0x0458, 0x0144, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU1_DI1_PIN03, 0x0458, 0x0144, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__IPU2_CSI1_VSYNC, 0x0458, 0x0144, 2, 0x08E4, 1, 0) +MX6_PAD_DECL(EIM_DA12__GPIO3_IO12, 0x0458, 0x0144, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA12__SRC_BOOT_CFG12, 0x0458, 0x0144, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__EIM_AD13, 0x045C, 0x0148, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__IPU1_DI1_D0_CS, 0x045C, 0x0148, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__GPIO3_IO13, 0x045C, 0x0148, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA13__SRC_BOOT_CFG13, 0x045C, 0x0148, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__EIM_AD14, 0x0460, 0x014C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__IPU1_DI1_D1_CS, 0x0460, 0x014C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__GPIO3_IO14, 0x0460, 0x014C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA14__SRC_BOOT_CFG14, 0x0460, 0x014C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__EIM_AD15, 0x0464, 0x0150, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN01, 0x0464, 0x0150, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__IPU1_DI1_PIN04, 0x0464, 0x0150, 2, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__GPIO3_IO15, 0x0464, 0x0150, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_DA15__SRC_BOOT_CFG15, 0x0464, 0x0150, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_WAIT_B, 0x0468, 0x0154, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__EIM_DTACK_B, 0x0468, 0x0154, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__GPIO5_IO00, 0x0468, 0x0154, 5, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_WAIT__SRC_BOOT_CFG25, 0x0468, 0x0154, 7, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__EIM_BCLK, 0x046C, 0x0158, 0, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__IPU1_DI1_PIN16, 0x046C, 0x0158, 1, 0x0000, 0, 0) +MX6_PAD_DECL(EIM_BCLK__GPIO6_IO31, 0x046C, 0x0158, 5, 0x0000, 0, 0) MX6_PAD_DECL(DI0_DISP_CLK__IPU1_DI0_DISP_CLK, 0x0470, 0x015C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DI0_DISP_CLK__IPU2_DI0_DISP_CLK, 0x0470, 0x015C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_DISP_CLK__GPIO4_IO16, 0x0470, 0x015C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__IPU1_DI0_PIN15, 0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN15__IPU2_DI0_PIN15, 0x0474, 0x0160, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__AUD6_TXC, 0x0474, 0x0160, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN15__GPIO4_IO17, 0x0474, 0x0160, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN2__IPU1_DI0_PIN02, 0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN2__IPU2_DI0_PIN02, 0x0478, 0x0164, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN2__AUD6_TXD, 0x0478, 0x0164, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN2__GPIO4_IO18, 0x0478, 0x0164, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__IPU1_DI0_PIN03, 0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) -MX6_PAD_DECL(DI0_PIN3__IPU2_DI0_PIN03, 0x047C, 0x0168, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__AUD6_TXFS, 0x047C, 0x0168, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN3__GPIO4_IO19, 0x047C, 0x0168, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__IPU1_DI0_PIN04, 0x0480, 0x016C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__IPU2_DI0_PIN04, 0x0480, 0x016C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__AUD6_RXD, 0x0480, 0x016C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DI0_PIN4__SD1_WP, 0x0480, 0x016C, 3, 0x094C, 0, 0) -MX6_PAD_DECL(DI0_PIN4__GPIO4_IO20, 0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_DISP_CLK__GPIO4_IO16, 0x0470, 0x015C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__IPU1_DI0_PIN15, 0x0474, 0x0160, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN15__IPU2_DI0_PIN15, 0x0474, 0x0160, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__AUD6_TXC, 0x0474, 0x0160, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN15__GPIO4_IO17, 0x0474, 0x0160, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__IPU1_DI0_PIN02, 0x0478, 0x0164, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN2__IPU2_DI0_PIN02, 0x0478, 0x0164, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__AUD6_TXD, 0x0478, 0x0164, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN2__GPIO4_IO18, 0x0478, 0x0164, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__IPU1_DI0_PIN03, 0x047C, 0x0168, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) +MX6_PAD_DECL(DI0_PIN3__IPU2_DI0_PIN03, 0x047C, 0x0168, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__AUD6_TXFS, 0x047C, 0x0168, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN3__GPIO4_IO19, 0x047C, 0x0168, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__IPU1_DI0_PIN04, 0x0480, 0x016C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__IPU2_DI0_PIN04, 0x0480, 0x016C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__AUD6_RXD, 0x0480, 0x016C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DI0_PIN4__SD1_WP, 0x0480, 0x016C, 3, 0x094C, 0, 0) +MX6_PAD_DECL(DI0_PIN4__GPIO4_IO20, 0x0480, 0x016C, 5, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT0__IPU1_DISP0_DATA00, 0x0484, 0x0170, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT0__IPU2_DISP0_DATA00, 0x0484, 0x0170, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT0__ECSPI3_SCLK, 0x0484, 0x0170, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT0__GPIO4_IO21, 0x0484, 0x0170, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__ECSPI3_SCLK, 0x0484, 0x0170, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT0__GPIO4_IO21, 0x0484, 0x0170, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT1__IPU1_DISP0_DATA01, 0x0488, 0x0174, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT1__IPU2_DISP0_DATA01, 0x0488, 0x0174, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT1__ECSPI3_MOSI, 0x0488, 0x0174, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT1__GPIO4_IO22, 0x0488, 0x0174, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__ECSPI3_MOSI, 0x0488, 0x0174, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT1__GPIO4_IO22, 0x0488, 0x0174, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT2__IPU1_DISP0_DATA02, 0x048C, 0x0178, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT2__IPU2_DISP0_DATA02, 0x048C, 0x0178, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT2__ECSPI3_MISO, 0x048C, 0x0178, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT2__GPIO4_IO23, 0x048C, 0x0178, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__ECSPI3_MISO, 0x048C, 0x0178, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT2__GPIO4_IO23, 0x048C, 0x0178, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT3__IPU1_DISP0_DATA03, 0x0490, 0x017C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT3__IPU2_DISP0_DATA03, 0x0490, 0x017C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT3__ECSPI3_SS0, 0x0490, 0x017C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT3__GPIO4_IO24, 0x0490, 0x017C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__ECSPI3_SS0, 0x0490, 0x017C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT3__GPIO4_IO24, 0x0490, 0x017C, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT4__IPU1_DISP0_DATA04, 0x0494, 0x0180, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT4__IPU2_DISP0_DATA04, 0x0494, 0x0180, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT4__ECSPI3_SS1, 0x0494, 0x0180, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT4__GPIO4_IO25, 0x0494, 0x0180, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__ECSPI3_SS1, 0x0494, 0x0180, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT4__GPIO4_IO25, 0x0494, 0x0180, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT5__IPU1_DISP0_DATA05, 0x0498, 0x0184, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT5__IPU2_DISP0_DATA05, 0x0498, 0x0184, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT5__ECSPI3_SS2, 0x0498, 0x0184, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT5__AUD6_RXFS, 0x0498, 0x0184, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT5__GPIO4_IO26, 0x0498, 0x0184, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__ECSPI3_SS2, 0x0498, 0x0184, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__AUD6_RXFS, 0x0498, 0x0184, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT5__GPIO4_IO26, 0x0498, 0x0184, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT6__IPU1_DISP0_DATA06, 0x049C, 0x0188, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT6__IPU2_DISP0_DATA06, 0x049C, 0x0188, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT6__ECSPI3_SS3, 0x049C, 0x0188, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT6__AUD6_RXC, 0x049C, 0x0188, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT6__GPIO4_IO27, 0x049C, 0x0188, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__ECSPI3_SS3, 0x049C, 0x0188, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__AUD6_RXC, 0x049C, 0x0188, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT6__GPIO4_IO27, 0x049C, 0x0188, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT7__IPU1_DISP0_DATA07, 0x04A0, 0x018C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT7__IPU2_DISP0_DATA07, 0x04A0, 0x018C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT7__ECSPI3_RDY, 0x04A0, 0x018C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT7__GPIO4_IO28, 0x04A0, 0x018C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__ECSPI3_RDY, 0x04A0, 0x018C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT7__GPIO4_IO28, 0x04A0, 0x018C, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT8__IPU1_DISP0_DATA08, 0x04A4, 0x0190, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT8__IPU2_DISP0_DATA08, 0x04A4, 0x0190, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT8__PWM1_OUT, 0x04A4, 0x0190, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT8__WDOG1_B, 0x04A4, 0x0190, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT8__GPIO4_IO29, 0x04A4, 0x0190, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__PWM1_OUT, 0x04A4, 0x0190, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__WDOG1_B, 0x04A4, 0x0190, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT8__GPIO4_IO29, 0x04A4, 0x0190, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT9__IPU1_DISP0_DATA09, 0x04A8, 0x0194, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT9__IPU2_DISP0_DATA09, 0x04A8, 0x0194, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT9__PWM2_OUT, 0x04A8, 0x0194, 2, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT9__WDOG2_B, 0x04A8, 0x0194, 3, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT9__GPIO4_IO30, 0x04A8, 0x0194, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__PWM2_OUT, 0x04A8, 0x0194, 2, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__WDOG2_B, 0x04A8, 0x0194, 3, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT9__GPIO4_IO30, 0x04A8, 0x0194, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT10__IPU1_DISP0_DATA10, 0x04AC, 0x0198, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT10__IPU2_DISP0_DATA10, 0x04AC, 0x0198, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT10__GPIO4_IO31, 0x04AC, 0x0198, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT10__GPIO4_IO31, 0x04AC, 0x0198, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT11__IPU1_DISP0_DATA11, 0x04B0, 0x019C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT11__IPU2_DISP0_DATA11, 0x04B0, 0x019C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT11__GPIO5_IO05, 0x04B0, 0x019C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT11__GPIO5_IO05, 0x04B0, 0x019C, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT12__IPU1_DISP0_DATA12, 0x04B4, 0x01A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT12__IPU2_DISP0_DATA12, 0x04B4, 0x01A0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT12__GPIO5_IO06, 0x04B4, 0x01A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT12__GPIO5_IO06, 0x04B4, 0x01A0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT13__IPU1_DISP0_DATA13, 0x04B8, 0x01A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT13__IPU2_DISP0_DATA13, 0x04B8, 0x01A4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT13__AUD5_RXFS, 0x04B8, 0x01A4, 3, 0x07D8, 1, 0) -MX6_PAD_DECL(DISP0_DAT13__GPIO5_IO07, 0x04B8, 0x01A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT13__AUD5_RXFS, 0x04B8, 0x01A4, 3, 0x07D8, 1, 0) +MX6_PAD_DECL(DISP0_DAT13__GPIO5_IO07, 0x04B8, 0x01A4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT14__IPU1_DISP0_DATA14, 0x04BC, 0x01A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT14__IPU2_DISP0_DATA14, 0x04BC, 0x01A8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT14__AUD5_RXC, 0x04BC, 0x01A8, 3, 0x07D4, 1, 0) -MX6_PAD_DECL(DISP0_DAT14__GPIO5_IO08, 0x04BC, 0x01A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT14__AUD5_RXC, 0x04BC, 0x01A8, 3, 0x07D4, 1, 0) +MX6_PAD_DECL(DISP0_DAT14__GPIO5_IO08, 0x04BC, 0x01A8, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT15__IPU1_DISP0_DATA15, 0x04C0, 0x01AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT15__IPU2_DISP0_DATA15, 0x04C0, 0x01AC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT15__ECSPI1_SS1, 0x04C0, 0x01AC, 2, 0x0804, 1, 0) -MX6_PAD_DECL(DISP0_DAT15__ECSPI2_SS1, 0x04C0, 0x01AC, 3, 0x0820, 1, 0) -MX6_PAD_DECL(DISP0_DAT15__GPIO5_IO09, 0x04C0, 0x01AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI1_SS1, 0x04C0, 0x01AC, 2, 0x0804, 1, 0) +MX6_PAD_DECL(DISP0_DAT15__ECSPI2_SS1, 0x04C0, 0x01AC, 3, 0x0820, 1, 0) +MX6_PAD_DECL(DISP0_DAT15__GPIO5_IO09, 0x04C0, 0x01AC, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT16__IPU1_DISP0_DATA16, 0x04C4, 0x01B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT16__IPU2_DISP0_DATA16, 0x04C4, 0x01B0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT16__ECSPI2_MOSI, 0x04C4, 0x01B0, 2, 0x0818, 1, 0) -MX6_PAD_DECL(DISP0_DAT16__AUD5_TXC, 0x04C4, 0x01B0, 3, 0x07DC, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__ECSPI2_MOSI, 0x04C4, 0x01B0, 2, 0x0818, 1, 0) +MX6_PAD_DECL(DISP0_DAT16__AUD5_TXC, 0x04C4, 0x01B0, 3, 0x07DC, 0, 0) MX6_PAD_DECL(DISP0_DAT16__SDMA_EXT_EVENT0, 0x04C4, 0x01B0, 4, 0x090C, 0, 0) -MX6_PAD_DECL(DISP0_DAT16__GPIO5_IO10, 0x04C4, 0x01B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT16__GPIO5_IO10, 0x04C4, 0x01B0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT17__IPU1_DISP0_DATA17, 0x04C8, 0x01B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT17__IPU2_DISP0_DATA17, 0x04C8, 0x01B4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT17__ECSPI2_MISO, 0x04C8, 0x01B4, 2, 0x0814, 1, 0) -MX6_PAD_DECL(DISP0_DAT17__AUD5_TXD, 0x04C8, 0x01B4, 3, 0x07D0, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__ECSPI2_MISO, 0x04C8, 0x01B4, 2, 0x0814, 1, 0) +MX6_PAD_DECL(DISP0_DAT17__AUD5_TXD, 0x04C8, 0x01B4, 3, 0x07D0, 0, 0) MX6_PAD_DECL(DISP0_DAT17__SDMA_EXT_EVENT1, 0x04C8, 0x01B4, 4, 0x0910, 0, 0) -MX6_PAD_DECL(DISP0_DAT17__GPIO5_IO11, 0x04C8, 0x01B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT17__GPIO5_IO11, 0x04C8, 0x01B4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT18__IPU1_DISP0_DATA18, 0x04CC, 0x01B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT18__IPU2_DISP0_DATA18, 0x04CC, 0x01B8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__ECSPI2_SS0, 0x04CC, 0x01B8, 2, 0x081C, 1, 0) -MX6_PAD_DECL(DISP0_DAT18__AUD5_TXFS, 0x04CC, 0x01B8, 3, 0x07E0, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__AUD4_RXFS, 0x04CC, 0x01B8, 4, 0x07C0, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__GPIO5_IO12, 0x04CC, 0x01B8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT18__EIM_CS2_B, 0x04CC, 0x01B8, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__ECSPI2_SS0, 0x04CC, 0x01B8, 2, 0x081C, 1, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD5_TXFS, 0x04CC, 0x01B8, 3, 0x07E0, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__AUD4_RXFS, 0x04CC, 0x01B8, 4, 0x07C0, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__GPIO5_IO12, 0x04CC, 0x01B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT18__EIM_CS2_B, 0x04CC, 0x01B8, 7, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT19__IPU1_DISP0_DATA19, 0x04D0, 0x01BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT19__IPU2_DISP0_DATA19, 0x04D0, 0x01BC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__ECSPI2_SCLK, 0x04D0, 0x01BC, 2, 0x0810, 1, 0) -MX6_PAD_DECL(DISP0_DAT19__AUD5_RXD, 0x04D0, 0x01BC, 3, 0x07CC, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__AUD4_RXC, 0x04D0, 0x01BC, 4, 0x07BC, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__GPIO5_IO13, 0x04D0, 0x01BC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT19__EIM_CS3_B, 0x04D0, 0x01BC, 7, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__ECSPI2_SCLK, 0x04D0, 0x01BC, 2, 0x0810, 1, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD5_RXD, 0x04D0, 0x01BC, 3, 0x07CC, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__AUD4_RXC, 0x04D0, 0x01BC, 4, 0x07BC, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__GPIO5_IO13, 0x04D0, 0x01BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT19__EIM_CS3_B, 0x04D0, 0x01BC, 7, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT20__IPU1_DISP0_DATA20, 0x04D4, 0x01C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT20__IPU2_DISP0_DATA20, 0x04D4, 0x01C0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT20__ECSPI1_SCLK, 0x04D4, 0x01C0, 2, 0x07F4, 1, 0) -MX6_PAD_DECL(DISP0_DAT20__AUD4_TXC, 0x04D4, 0x01C0, 3, 0x07C4, 0, 0) -MX6_PAD_DECL(DISP0_DAT20__GPIO5_IO14, 0x04D4, 0x01C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__ECSPI1_SCLK, 0x04D4, 0x01C0, 2, 0x07F4, 1, 0) +MX6_PAD_DECL(DISP0_DAT20__AUD4_TXC, 0x04D4, 0x01C0, 3, 0x07C4, 0, 0) +MX6_PAD_DECL(DISP0_DAT20__GPIO5_IO14, 0x04D4, 0x01C0, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT21__IPU1_DISP0_DATA21, 0x04D8, 0x01C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT21__IPU2_DISP0_DATA21, 0x04D8, 0x01C4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT21__ECSPI1_MOSI, 0x04D8, 0x01C4, 2, 0x07FC, 1, 0) -MX6_PAD_DECL(DISP0_DAT21__AUD4_TXD, 0x04D8, 0x01C4, 3, 0x07B8, 1, 0) -MX6_PAD_DECL(DISP0_DAT21__GPIO5_IO15, 0x04D8, 0x01C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT21__ECSPI1_MOSI, 0x04D8, 0x01C4, 2, 0x07FC, 1, 0) +MX6_PAD_DECL(DISP0_DAT21__AUD4_TXD, 0x04D8, 0x01C4, 3, 0x07B8, 1, 0) +MX6_PAD_DECL(DISP0_DAT21__GPIO5_IO15, 0x04D8, 0x01C4, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT22__IPU1_DISP0_DATA22, 0x04DC, 0x01C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT22__IPU2_DISP0_DATA22, 0x04DC, 0x01C8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT22__ECSPI1_MISO, 0x04DC, 0x01C8, 2, 0x07F8, 1, 0) -MX6_PAD_DECL(DISP0_DAT22__AUD4_TXFS, 0x04DC, 0x01C8, 3, 0x07C8, 1, 0) -MX6_PAD_DECL(DISP0_DAT22__GPIO5_IO16, 0x04DC, 0x01C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(DISP0_DAT22__ECSPI1_MISO, 0x04DC, 0x01C8, 2, 0x07F8, 1, 0) +MX6_PAD_DECL(DISP0_DAT22__AUD4_TXFS, 0x04DC, 0x01C8, 3, 0x07C8, 1, 0) +MX6_PAD_DECL(DISP0_DAT22__GPIO5_IO16, 0x04DC, 0x01C8, 5, 0x0000, 0, 0) MX6_PAD_DECL(DISP0_DAT23__IPU1_DISP0_DATA23, 0x04E0, 0x01CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm) MX6_PAD_DECL(DISP0_DAT23__IPU2_DISP0_DATA23, 0x04E0, 0x01CC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(DISP0_DAT23__ECSPI1_SS0, 0x04E0, 0x01CC, 2, 0x0800, 1, 0) -MX6_PAD_DECL(DISP0_DAT23__AUD4_RXD, 0x04E0, 0x01CC, 3, 0x07B4, 1, 0) -MX6_PAD_DECL(DISP0_DAT23__GPIO5_IO17, 0x04E0, 0x01CC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDIO__ENET_MDIO, 0x04E4, 0x01D0, 1, 0x0840, 0, 0) -MX6_PAD_DECL(ENET_MDIO__ESAI_RX_CLK, 0x04E4, 0x01D0, 2, 0x086C, 0, 0) +MX6_PAD_DECL(DISP0_DAT23__ECSPI1_SS0, 0x04E0, 0x01CC, 2, 0x0800, 1, 0) +MX6_PAD_DECL(DISP0_DAT23__AUD4_RXD, 0x04E0, 0x01CC, 3, 0x07B4, 1, 0) +MX6_PAD_DECL(DISP0_DAT23__GPIO5_IO17, 0x04E0, 0x01CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ENET_MDIO, 0x04E4, 0x01D0, 1, 0x0840, 0, 0) +MX6_PAD_DECL(ENET_MDIO__ESAI_RX_CLK, 0x04E4, 0x01D0, 2, 0x086C, 0, 0) MX6_PAD_DECL(ENET_MDIO__ENET_1588_EVENT1_OUT, 0x04E4, 0x01D0, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDIO__GPIO1_IO22, 0x04E4, 0x01D0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDIO__SPDIF_LOCK, 0x04E4, 0x01D0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_REF_CLK__ENET_TX_CLK, 0x04E8, 0x01D4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_REF_CLK__ESAI_RX_FS, 0x04E8, 0x01D4, 2, 0x085C, 0, 0) -MX6_PAD_DECL(ENET_REF_CLK__GPIO1_IO23, 0x04E8, 0x01D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__GPIO1_IO22, 0x04E4, 0x01D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDIO__SPDIF_LOCK, 0x04E4, 0x01D0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ENET_TX_CLK, 0x04E8, 0x01D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__ESAI_RX_FS, 0x04E8, 0x01D4, 2, 0x085C, 0, 0) +MX6_PAD_DECL(ENET_REF_CLK__GPIO1_IO23, 0x04E8, 0x01D4, 5, 0x0000, 0, 0) MX6_PAD_DECL(ENET_REF_CLK__SPDIF_SR_CLK, 0x04E8, 0x01D4, 6, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__USB_OTG_ID, 0x04EC, 0x01D8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__ENET_RX_ER, 0x04EC, 0x01D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__USB_OTG_ID, 0x04EC, 0x01D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__ENET_RX_ER, 0x04EC, 0x01D8, 1, 0x0000, 0, 0) MX6_PAD_DECL(ENET_RX_ER__ESAI_RX_HF_CLK, 0x04EC, 0x01D8, 2, 0x0864, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__SPDIF_IN, 0x04EC, 0x01D8, 3, 0x0914, 1, 0) +MX6_PAD_DECL(ENET_RX_ER__SPDIF_IN, 0x04EC, 0x01D8, 3, 0x0914, 1, 0) MX6_PAD_DECL(ENET_RX_ER__ENET_1588_EVENT2_OUT, 0x04EC, 0x01D8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RX_ER__GPIO1_IO24, 0x04EC, 0x01D8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_CRS_DV__ENET_RX_EN, 0x04F0, 0x01DC, 1, 0x0858, 1, 0) -MX6_PAD_DECL(ENET_CRS_DV__ESAI_TX_CLK, 0x04F0, 0x01DC, 2, 0x0870, 0, 0) +MX6_PAD_DECL(ENET_RX_ER__GPIO1_IO24, 0x04EC, 0x01D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__ENET_RX_EN, 0x04F0, 0x01DC, 1, 0x0858, 1, 0) +MX6_PAD_DECL(ENET_CRS_DV__ESAI_TX_CLK, 0x04F0, 0x01DC, 2, 0x0870, 0, 0) MX6_PAD_DECL(ENET_CRS_DV__SPDIF_EXT_CLK, 0x04F0, 0x01DC, 3, 0x0918, 1, 0) -MX6_PAD_DECL(ENET_CRS_DV__GPIO1_IO25, 0x04F0, 0x01DC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD1__MLB_SIG, 0x04F4, 0x01E0, 0, 0x0908, 0, 0) -MX6_PAD_DECL(ENET_RXD1__ENET_RX_DATA1, 0x04F4, 0x01E0, 1, 0x084C, 1, 0) -MX6_PAD_DECL(ENET_RXD1__ESAI_TX_FS, 0x04F4, 0x01E0, 2, 0x0860, 0, 0) +MX6_PAD_DECL(ENET_CRS_DV__GPIO1_IO25, 0x04F0, 0x01DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD1__MLB_SIG, 0x04F4, 0x01E0, 0, 0x0908, 0, 0) +MX6_PAD_DECL(ENET_RXD1__ENET_RX_DATA1, 0x04F4, 0x01E0, 1, 0x084C, 1, 0) +MX6_PAD_DECL(ENET_RXD1__ESAI_TX_FS, 0x04F4, 0x01E0, 2, 0x0860, 0, 0) MX6_PAD_DECL(ENET_RXD1__ENET_1588_EVENT3_OUT, 0x04F4, 0x01E0, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD1__GPIO1_IO26, 0x04F4, 0x01E0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD0__ENET_RX_DATA0, 0x04F8, 0x01E4, 1, 0x0848, 1, 0) -MX6_PAD_DECL(ENET_RXD0__ESAI_TX_HF_CLK, 0x04F8, 0x01E4, 2, 0x0868, 0, 0) -MX6_PAD_DECL(ENET_RXD0__SPDIF_OUT, 0x04F8, 0x01E4, 3, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_RXD0__GPIO1_IO27, 0x04F8, 0x01E4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__ENET_TX_EN, 0x04FC, 0x01E8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__ESAI_TX3_RX2, 0x04FC, 0x01E8, 2, 0x0880, 0, 0) -MX6_PAD_DECL(ENET_TX_EN__GPIO1_IO28, 0x04FC, 0x01E8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__MLB_CLK, 0x0500, 0x01EC, 0, 0x0900, 0, 0) -MX6_PAD_DECL(ENET_TXD1__ENET_TX_DATA1, 0x0500, 0x01EC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__ESAI_TX2_RX3, 0x0500, 0x01EC, 2, 0x087C, 0, 0) +MX6_PAD_DECL(ENET_RXD1__GPIO1_IO26, 0x04F4, 0x01E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__ENET_RX_DATA0, 0x04F8, 0x01E4, 1, 0x0848, 1, 0) +MX6_PAD_DECL(ENET_RXD0__ESAI_TX_HF_CLK, 0x04F8, 0x01E4, 2, 0x0868, 0, 0) +MX6_PAD_DECL(ENET_RXD0__SPDIF_OUT, 0x04F8, 0x01E4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_RXD0__GPIO1_IO27, 0x04F8, 0x01E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ENET_TX_EN, 0x04FC, 0x01E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__ESAI_TX3_RX2, 0x04FC, 0x01E8, 2, 0x0880, 0, 0) +MX6_PAD_DECL(ENET_TX_EN__GPIO1_IO28, 0x04FC, 0x01E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__MLB_CLK, 0x0500, 0x01EC, 0, 0x0900, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ENET_TX_DATA1, 0x0500, 0x01EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD1__ESAI_TX2_RX3, 0x0500, 0x01EC, 2, 0x087C, 0, 0) MX6_PAD_DECL(ENET_TXD1__ENET_1588_EVENT0_IN, 0x0500, 0x01EC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD1__GPIO1_IO29, 0x0500, 0x01EC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD0__ENET_TX_DATA0, 0x0504, 0x01F0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_TXD0__ESAI_TX4_RX1, 0x0504, 0x01F0, 2, 0x0884, 0, 0) -MX6_PAD_DECL(ENET_TXD0__GPIO1_IO30, 0x0504, 0x01F0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDC__MLB_DATA, 0x0508, 0x01F4, 0, 0x0904, 0, 0) -MX6_PAD_DECL(ENET_MDC__ENET_MDC, 0x0508, 0x01F4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDC__ESAI_TX5_RX0, 0x0508, 0x01F4, 2, 0x0888, 0, 0) +MX6_PAD_DECL(ENET_TXD1__GPIO1_IO29, 0x0500, 0x01EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ENET_TX_DATA0, 0x0504, 0x01F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_TXD0__ESAI_TX4_RX1, 0x0504, 0x01F0, 2, 0x0884, 0, 0) +MX6_PAD_DECL(ENET_TXD0__GPIO1_IO30, 0x0504, 0x01F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__MLB_DATA, 0x0508, 0x01F4, 0, 0x0904, 0, 0) +MX6_PAD_DECL(ENET_MDC__ENET_MDC, 0x0508, 0x01F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__ESAI_TX5_RX0, 0x0508, 0x01F4, 2, 0x0888, 0, 0) MX6_PAD_DECL(ENET_MDC__ENET_1588_EVENT1_IN, 0x0508, 0x01F4, 4, 0x0000, 0, 0) -MX6_PAD_DECL(ENET_MDC__GPIO1_IO31, 0x0508, 0x01F4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__ECSPI1_SCLK, 0x05C8, 0x01F8, 0, 0x07F4, 2, 0) -MX6_PAD_DECL(KEY_COL0__ENET_RX_DATA3, 0x05C8, 0x01F8, 1, 0x0854, 1, 0) -MX6_PAD_DECL(KEY_COL0__AUD5_TXC, 0x05C8, 0x01F8, 2, 0x07DC, 1, 0) -MX6_PAD_DECL(KEY_COL0__KEY_COL0, 0x05C8, 0x01F8, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__UART4_TX_DATA, 0x05C8, 0x01F8, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__UART4_RX_DATA, 0x05C8, 0x01F8, 4, 0x0938, 0, 0) -MX6_PAD_DECL(KEY_COL0__GPIO4_IO06, 0x05C8, 0x01F8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL0__DCIC1_OUT, 0x05C8, 0x01F8, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__ECSPI1_MOSI, 0x05CC, 0x01FC, 0, 0x07FC, 2, 0) -MX6_PAD_DECL(KEY_ROW0__ENET_TX_DATA3, 0x05CC, 0x01FC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__AUD5_TXD, 0x05CC, 0x01FC, 2, 0x07D0, 1, 0) -MX6_PAD_DECL(KEY_ROW0__KEY_ROW0, 0x05CC, 0x01FC, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__UART4_TX_DATA, 0x05CC, 0x01FC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__UART4_RX_DATA, 0x05CC, 0x01FC, 4, 0x0938, 1, 0) -MX6_PAD_DECL(KEY_ROW0__GPIO4_IO07, 0x05CC, 0x01FC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW0__DCIC2_OUT, 0x05CC, 0x01FC, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__ECSPI1_MISO, 0x05D0, 0x0200, 0, 0x07F8, 2, 0) -MX6_PAD_DECL(KEY_COL1__ENET_MDIO, 0x05D0, 0x0200, 1, 0x0840, 1, 0) -MX6_PAD_DECL(KEY_COL1__AUD5_TXFS, 0x05D0, 0x0200, 2, 0x07E0, 1, 0) -MX6_PAD_DECL(KEY_COL1__KEY_COL1, 0x05D0, 0x0200, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__UART5_TX_DATA, 0x05D0, 0x0200, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__UART5_RX_DATA, 0x05D0, 0x0200, 4, 0x0940, 0, 0) -MX6_PAD_DECL(KEY_COL1__GPIO4_IO08, 0x05D0, 0x0200, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL1__SD1_VSELECT, 0x05D0, 0x0200, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__ECSPI1_SS0, 0x05D4, 0x0204, 0, 0x0800, 2, 0) -MX6_PAD_DECL(KEY_ROW1__ENET_COL, 0x05D4, 0x0204, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__AUD5_RXD, 0x05D4, 0x0204, 2, 0x07CC, 1, 0) -MX6_PAD_DECL(KEY_ROW1__KEY_ROW1, 0x05D4, 0x0204, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__UART5_TX_DATA, 0x05D4, 0x0204, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__UART5_RX_DATA, 0x05D4, 0x0204, 4, 0x0940, 1, 0) -MX6_PAD_DECL(KEY_ROW1__GPIO4_IO09, 0x05D4, 0x0204, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW1__SD2_VSELECT, 0x05D4, 0x0204, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__ECSPI1_SS1, 0x05D8, 0x0208, 0, 0x0804, 2, 0) -MX6_PAD_DECL(KEY_COL2__ENET_RX_DATA2, 0x05D8, 0x0208, 1, 0x0850, 1, 0) -MX6_PAD_DECL(KEY_COL2__FLEXCAN1_TX, 0x05D8, 0x0208, 2, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__KEY_COL2, 0x05D8, 0x0208, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__ENET_MDC, 0x05D8, 0x0208, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL2__GPIO4_IO10, 0x05D8, 0x0208, 5, 0x0000, 0, 0) +MX6_PAD_DECL(ENET_MDC__GPIO1_IO31, 0x0508, 0x01F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__ECSPI1_SCLK, 0x05C8, 0x01F8, 0, 0x07F4, 2, 0) +MX6_PAD_DECL(KEY_COL0__ENET_RX_DATA3, 0x05C8, 0x01F8, 1, 0x0854, 1, 0) +MX6_PAD_DECL(KEY_COL0__AUD5_TXC, 0x05C8, 0x01F8, 2, 0x07DC, 1, 0) +MX6_PAD_DECL(KEY_COL0__KEY_COL0, 0x05C8, 0x01F8, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_TX_DATA, 0x05C8, 0x01F8, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__UART4_RX_DATA, 0x05C8, 0x01F8, 4, 0x0938, 0, 0) +MX6_PAD_DECL(KEY_COL0__GPIO4_IO06, 0x05C8, 0x01F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL0__DCIC1_OUT, 0x05C8, 0x01F8, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__ECSPI1_MOSI, 0x05CC, 0x01FC, 0, 0x07FC, 2, 0) +MX6_PAD_DECL(KEY_ROW0__ENET_TX_DATA3, 0x05CC, 0x01FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__AUD5_TXD, 0x05CC, 0x01FC, 2, 0x07D0, 1, 0) +MX6_PAD_DECL(KEY_ROW0__KEY_ROW0, 0x05CC, 0x01FC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_TX_DATA, 0x05CC, 0x01FC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__UART4_RX_DATA, 0x05CC, 0x01FC, 4, 0x0938, 1, 0) +MX6_PAD_DECL(KEY_ROW0__GPIO4_IO07, 0x05CC, 0x01FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW0__DCIC2_OUT, 0x05CC, 0x01FC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__ECSPI1_MISO, 0x05D0, 0x0200, 0, 0x07F8, 2, 0) +MX6_PAD_DECL(KEY_COL1__ENET_MDIO, 0x05D0, 0x0200, 1, 0x0840, 1, 0) +MX6_PAD_DECL(KEY_COL1__AUD5_TXFS, 0x05D0, 0x0200, 2, 0x07E0, 1, 0) +MX6_PAD_DECL(KEY_COL1__KEY_COL1, 0x05D0, 0x0200, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_TX_DATA, 0x05D0, 0x0200, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__UART5_RX_DATA, 0x05D0, 0x0200, 4, 0x0940, 0, 0) +MX6_PAD_DECL(KEY_COL1__GPIO4_IO08, 0x05D0, 0x0200, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL1__SD1_VSELECT, 0x05D0, 0x0200, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__ECSPI1_SS0, 0x05D4, 0x0204, 0, 0x0800, 2, 0) +MX6_PAD_DECL(KEY_ROW1__ENET_COL, 0x05D4, 0x0204, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__AUD5_RXD, 0x05D4, 0x0204, 2, 0x07CC, 1, 0) +MX6_PAD_DECL(KEY_ROW1__KEY_ROW1, 0x05D4, 0x0204, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_TX_DATA, 0x05D4, 0x0204, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__UART5_RX_DATA, 0x05D4, 0x0204, 4, 0x0940, 1, 0) +MX6_PAD_DECL(KEY_ROW1__GPIO4_IO09, 0x05D4, 0x0204, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW1__SD2_VSELECT, 0x05D4, 0x0204, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ECSPI1_SS1, 0x05D8, 0x0208, 0, 0x0804, 2, 0) +MX6_PAD_DECL(KEY_COL2__ENET_RX_DATA2, 0x05D8, 0x0208, 1, 0x0850, 1, 0) +MX6_PAD_DECL(KEY_COL2__FLEXCAN1_TX, 0x05D8, 0x0208, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__KEY_COL2, 0x05D8, 0x0208, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__ENET_MDC, 0x05D8, 0x0208, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL2__GPIO4_IO10, 0x05D8, 0x0208, 5, 0x0000, 0, 0) MX6_PAD_DECL(KEY_COL2__USB_H1_PWR_CTL_WAKE, 0x05D8, 0x0208, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__ECSPI1_SS2, 0x05DC, 0x020C, 0, 0x0808, 1, 0) -MX6_PAD_DECL(KEY_ROW2__ENET_TX_DATA2, 0x05DC, 0x020C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__FLEXCAN1_RX, 0x05DC, 0x020C, 2, 0x07E4, 0, 0) -MX6_PAD_DECL(KEY_ROW2__KEY_ROW2, 0x05DC, 0x020C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__SD2_VSELECT, 0x05DC, 0x020C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW2__GPIO4_IO11, 0x05DC, 0x020C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__ECSPI1_SS2, 0x05DC, 0x020C, 0, 0x0808, 1, 0) +MX6_PAD_DECL(KEY_ROW2__ENET_TX_DATA2, 0x05DC, 0x020C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__FLEXCAN1_RX, 0x05DC, 0x020C, 2, 0x07E4, 0, 0) +MX6_PAD_DECL(KEY_ROW2__KEY_ROW2, 0x05DC, 0x020C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__SD2_VSELECT, 0x05DC, 0x020C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW2__GPIO4_IO11, 0x05DC, 0x020C, 5, 0x0000, 0, 0) MX6_PAD_DECL(KEY_ROW2__HDMI_TX_CEC_LINE, 0x05DC, 0x020C, 6, 0x088C, 1, 0) -MX6_PAD_DECL(KEY_COL3__ECSPI1_SS3, 0x05E0, 0x0210, 0, 0x080C, 1, 0) -MX6_PAD_DECL(KEY_COL3__ENET_CRS, 0x05E0, 0x0210, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__HDMI_TX_DDC_SCL, 0x05E0, 0x0210, 2, 0x0890, 1, 0) -MX6_PAD_DECL(KEY_COL3__KEY_COL3, 0x05E0, 0x0210, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__I2C2_SCL, 0x05E0, 0x0210, 20, 0x08A0, 1, 0) -MX6_PAD_DECL(KEY_COL3__GPIO4_IO12, 0x05E0, 0x0210, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL3__SPDIF_IN, 0x05E0, 0x0210, 6, 0x0914, 2, 0) -MX6_PAD_DECL(KEY_ROW3__ASRC_EXT_CLK, 0x05E4, 0x0214, 1, 0x07B0, 0, 0) -MX6_PAD_DECL(KEY_ROW3__HDMI_TX_DDC_SDA, 0x05E4, 0x0214, 2, 0x0894, 1, 0) -MX6_PAD_DECL(KEY_ROW3__KEY_ROW3, 0x05E4, 0x0214, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW3__I2C2_SDA, 0x05E4, 0x0214, 20, 0x08A4, 1, 0) -MX6_PAD_DECL(KEY_ROW3__GPIO4_IO13, 0x05E4, 0x0214, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW3__SD1_VSELECT, 0x05E4, 0x0214, 6, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__FLEXCAN2_TX, 0x05E8, 0x0218, 0, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__IPU1_SISG4, 0x05E8, 0x0218, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__USB_OTG_OC, 0x05E8, 0x0218, 2, 0x0944, 1, 0) -MX6_PAD_DECL(KEY_COL4__KEY_COL4, 0x05E8, 0x0218, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__UART5_CTS_B, 0x05E8, 0x0218, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_COL4__UART5_RTS_B, 0x05E8, 0x0218, 4, 0x093C, 0, 0) -MX6_PAD_DECL(KEY_COL4__GPIO4_IO14, 0x05E8, 0x0218, 5, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__FLEXCAN2_RX, 0x05EC, 0x021C, 0, 0x07E8, 0, 0) -MX6_PAD_DECL(KEY_ROW4__IPU1_SISG5, 0x05EC, 0x021C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__USB_OTG_PWR, 0x05EC, 0x021C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__KEY_ROW4, 0x05EC, 0x021C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__UART5_CTS_B, 0x05EC, 0x021C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(KEY_ROW4__UART5_RTS_B, 0x05EC, 0x021C, 4, 0x093C, 1, 0) -MX6_PAD_DECL(KEY_ROW4__GPIO4_IO15, 0x05EC, 0x021C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__CCM_CLKO1, 0x05F0, 0x0220, 0, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__KEY_COL5, 0x05F0, 0x0220, 2, 0x08E8, 0, 0) -MX6_PAD_DECL(GPIO_0__ASRC_EXT_CLK, 0x05F0, 0x0220, 3, 0x07B0, 1, 0) -MX6_PAD_DECL(GPIO_0__EPIT1_OUT, 0x05F0, 0x0220, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__GPIO1_IO00, 0x05F0, 0x0220, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__USB_H1_PWR, 0x05F0, 0x0220, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_0__SNVS_VIO_5, 0x05F0, 0x0220, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__ESAI_RX_CLK, 0x05F4, 0x0224, 0, 0x086C, 1, 0) -MX6_PAD_DECL(GPIO_1__WDOG2_B, 0x05F4, 0x0224, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__KEY_ROW5, 0x05F4, 0x0224, 2, 0x08F4, 0, 0) -MX6_PAD_DECL(GPIO_1__USB_OTG_ID, 0x05F4, 0x0224, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__PWM2_OUT, 0x05F4, 0x0224, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__GPIO1_IO01, 0x05F4, 0x0224, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_1__SD1_CD_B, 0x05F4, 0x0224, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__ESAI_RX_FS, 0x05F8, 0x0228, 0, 0x085C, 1, 0) -MX6_PAD_DECL(GPIO_9__WDOG1_B, 0x05F8, 0x0228, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__KEY_COL6, 0x05F8, 0x0228, 2, 0x08EC, 0, 0) -MX6_PAD_DECL(GPIO_9__CCM_REF_EN_B, 0x05F8, 0x0228, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__PWM1_OUT, 0x05F8, 0x0228, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__GPIO1_IO09, 0x05F8, 0x0228, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_9__SD1_WP, 0x05F8, 0x0228, 6, 0x094C, 1, 0) -MX6_PAD_DECL(GPIO_3__ESAI_RX_HF_CLK, 0x05FC, 0x022C, 0, 0x0864, 1, 0) -MX6_PAD_DECL(GPIO_3__I2C3_SCL, 0x05FC, 0x022C, 18, 0x08A8, 1, 0) +MX6_PAD_DECL(KEY_COL3__ECSPI1_SS3, 0x05E0, 0x0210, 0, 0x080C, 1, 0) +MX6_PAD_DECL(KEY_COL3__ENET_CRS, 0x05E0, 0x0210, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__HDMI_TX_DDC_SCL, 0x05E0, 0x0210, 2, 0x0890, 1, 0) +MX6_PAD_DECL(KEY_COL3__KEY_COL3, 0x05E0, 0x0210, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__I2C2_SCL, 0x05E0, 0x0210, 20, 0x08A0, 1, 0) +MX6_PAD_DECL(KEY_COL3__GPIO4_IO12, 0x05E0, 0x0210, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL3__SPDIF_IN, 0x05E0, 0x0210, 6, 0x0914, 2, 0) +MX6_PAD_DECL(KEY_ROW3__ASRC_EXT_CLK, 0x05E4, 0x0214, 1, 0x07B0, 0, 0) +MX6_PAD_DECL(KEY_ROW3__HDMI_TX_DDC_SDA, 0x05E4, 0x0214, 2, 0x0894, 1, 0) +MX6_PAD_DECL(KEY_ROW3__KEY_ROW3, 0x05E4, 0x0214, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__I2C2_SDA, 0x05E4, 0x0214, 20, 0x08A4, 1, 0) +MX6_PAD_DECL(KEY_ROW3__GPIO4_IO13, 0x05E4, 0x0214, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW3__SD1_VSELECT, 0x05E4, 0x0214, 6, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__FLEXCAN2_TX, 0x05E8, 0x0218, 0, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__IPU1_SISG4, 0x05E8, 0x0218, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__USB_OTG_OC, 0x05E8, 0x0218, 2, 0x0944, 1, 0) +MX6_PAD_DECL(KEY_COL4__KEY_COL4, 0x05E8, 0x0218, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_CTS_B, 0x05E8, 0x0218, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_COL4__UART5_RTS_B, 0x05E8, 0x0218, 4, 0x093C, 0, 0) +MX6_PAD_DECL(KEY_COL4__GPIO4_IO14, 0x05E8, 0x0218, 5, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__FLEXCAN2_RX, 0x05EC, 0x021C, 0, 0x07E8, 0, 0) +MX6_PAD_DECL(KEY_ROW4__IPU1_SISG5, 0x05EC, 0x021C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__USB_OTG_PWR, 0x05EC, 0x021C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__KEY_ROW4, 0x05EC, 0x021C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_CTS_B, 0x05EC, 0x021C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(KEY_ROW4__UART5_RTS_B, 0x05EC, 0x021C, 4, 0x093C, 1, 0) +MX6_PAD_DECL(KEY_ROW4__GPIO4_IO15, 0x05EC, 0x021C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__CCM_CLKO1, 0x05F0, 0x0220, 0, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__KEY_COL5, 0x05F0, 0x0220, 2, 0x08E8, 0, 0) +MX6_PAD_DECL(GPIO_0__ASRC_EXT_CLK, 0x05F0, 0x0220, 3, 0x07B0, 1, 0) +MX6_PAD_DECL(GPIO_0__EPIT1_OUT, 0x05F0, 0x0220, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__GPIO1_IO00, 0x05F0, 0x0220, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__USB_H1_PWR, 0x05F0, 0x0220, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_0__SNVS_VIO_5, 0x05F0, 0x0220, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__ESAI_RX_CLK, 0x05F4, 0x0224, 0, 0x086C, 1, 0) +MX6_PAD_DECL(GPIO_1__WDOG2_B, 0x05F4, 0x0224, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__KEY_ROW5, 0x05F4, 0x0224, 2, 0x08F4, 0, 0) +MX6_PAD_DECL(GPIO_1__USB_OTG_ID, 0x05F4, 0x0224, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__PWM2_OUT, 0x05F4, 0x0224, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__GPIO1_IO01, 0x05F4, 0x0224, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_1__SD1_CD_B, 0x05F4, 0x0224, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__ESAI_RX_FS, 0x05F8, 0x0228, 0, 0x085C, 1, 0) +MX6_PAD_DECL(GPIO_9__WDOG1_B, 0x05F8, 0x0228, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__KEY_COL6, 0x05F8, 0x0228, 2, 0x08EC, 0, 0) +MX6_PAD_DECL(GPIO_9__CCM_REF_EN_B, 0x05F8, 0x0228, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__PWM1_OUT, 0x05F8, 0x0228, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__GPIO1_IO09, 0x05F8, 0x0228, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_9__SD1_WP, 0x05F8, 0x0228, 6, 0x094C, 1, 0) +MX6_PAD_DECL(GPIO_3__ESAI_RX_HF_CLK, 0x05FC, 0x022C, 0, 0x0864, 1, 0) +MX6_PAD_DECL(GPIO_3__I2C3_SCL, 0x05FC, 0x022C, 18, 0x08A8, 1, 0) MX6_PAD_DECL(GPIO_3__XTALOSC_REF_CLK_24M, 0x05FC, 0x022C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_3__CCM_CLKO2, 0x05FC, 0x022C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_3__GPIO1_IO03, 0x05FC, 0x022C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_3__USB_H1_OC, 0x05FC, 0x022C, 6, 0x0948, 1, 0) -MX6_PAD_DECL(GPIO_3__MLB_CLK, 0x05FC, 0x022C, 7, 0x0900, 1, 0) -MX6_PAD_DECL(GPIO_6__ESAI_TX_CLK, 0x0600, 0x0230, 0, 0x0870, 1, 0) -MX6_PAD_DECL(GPIO_6__I2C3_SDA, 0x0600, 0x0230, 18, 0x08AC, 1, 0) -MX6_PAD_DECL(GPIO_6__GPIO1_IO06, 0x0600, 0x0230, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_6__SD2_LCTL, 0x0600, 0x0230, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_6__MLB_SIG, 0x0600, 0x0230, 7, 0x0908, 1, 0) -MX6_PAD_DECL(GPIO_2__ESAI_TX_FS, 0x0604, 0x0234, 0, 0x0860, 1, 0) -MX6_PAD_DECL(GPIO_2__KEY_ROW6, 0x0604, 0x0234, 2, 0x08F8, 1, 0) -MX6_PAD_DECL(GPIO_2__GPIO1_IO02, 0x0604, 0x0234, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_2__SD2_WP, 0x0604, 0x0234, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_2__MLB_DATA, 0x0604, 0x0234, 7, 0x0904, 1, 0) -MX6_PAD_DECL(GPIO_4__ESAI_TX_HF_CLK, 0x0608, 0x0238, 0, 0x0868, 1, 0) -MX6_PAD_DECL(GPIO_4__KEY_COL7, 0x0608, 0x0238, 2, 0x08F0, 1, 0) -MX6_PAD_DECL(GPIO_4__GPIO1_IO04, 0x0608, 0x0238, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_4__SD2_CD_B, 0x0608, 0x0238, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_5__ESAI_TX2_RX3, 0x060C, 0x023C, 0, 0x087C, 1, 0) -MX6_PAD_DECL(GPIO_5__KEY_ROW7, 0x060C, 0x023C, 2, 0x08FC, 1, 0) -MX6_PAD_DECL(GPIO_5__CCM_CLKO1, 0x060C, 0x023C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_5__GPIO1_IO05, 0x060C, 0x023C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_5__I2C3_SCL, 0x060C, 0x023C, 22, 0x08A8, 2, 0) -MX6_PAD_DECL(GPIO_5__ARM_EVENTI, 0x060C, 0x023C, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__ESAI_TX4_RX1, 0x0610, 0x0240, 0, 0x0884, 1, 0) -MX6_PAD_DECL(GPIO_7__ECSPI5_RDY, 0x0610, 0x0240, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__EPIT1_OUT, 0x0610, 0x0240, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__FLEXCAN1_TX, 0x0610, 0x0240, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__UART2_TX_DATA, 0x0610, 0x0240, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__UART2_RX_DATA, 0x0610, 0x0240, 4, 0x0928, 2, 0) -MX6_PAD_DECL(GPIO_7__GPIO1_IO07, 0x0610, 0x0240, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__SPDIF_LOCK, 0x0610, 0x0240, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_7__USB_OTG_HOST_MODE, 0x0610, 0x0240, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__ESAI_TX5_RX0, 0x0614, 0x0244, 0, 0x0888, 1, 0) +MX6_PAD_DECL(GPIO_3__CCM_CLKO2, 0x05FC, 0x022C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__GPIO1_IO03, 0x05FC, 0x022C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_3__USB_H1_OC, 0x05FC, 0x022C, 6, 0x0948, 1, 0) +MX6_PAD_DECL(GPIO_3__MLB_CLK, 0x05FC, 0x022C, 7, 0x0900, 1, 0) +MX6_PAD_DECL(GPIO_6__ESAI_TX_CLK, 0x0600, 0x0230, 0, 0x0870, 1, 0) +MX6_PAD_DECL(GPIO_6__I2C3_SDA, 0x0600, 0x0230, 18, 0x08AC, 1, 0) +MX6_PAD_DECL(GPIO_6__GPIO1_IO06, 0x0600, 0x0230, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__SD2_LCTL, 0x0600, 0x0230, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_6__MLB_SIG, 0x0600, 0x0230, 7, 0x0908, 1, 0) +MX6_PAD_DECL(GPIO_2__ESAI_TX_FS, 0x0604, 0x0234, 0, 0x0860, 1, 0) +MX6_PAD_DECL(GPIO_2__KEY_ROW6, 0x0604, 0x0234, 2, 0x08F8, 1, 0) +MX6_PAD_DECL(GPIO_2__GPIO1_IO02, 0x0604, 0x0234, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__SD2_WP, 0x0604, 0x0234, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_2__MLB_DATA, 0x0604, 0x0234, 7, 0x0904, 1, 0) +MX6_PAD_DECL(GPIO_4__ESAI_TX_HF_CLK, 0x0608, 0x0238, 0, 0x0868, 1, 0) +MX6_PAD_DECL(GPIO_4__KEY_COL7, 0x0608, 0x0238, 2, 0x08F0, 1, 0) +MX6_PAD_DECL(GPIO_4__GPIO1_IO04, 0x0608, 0x0238, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_4__SD2_CD_B, 0x0608, 0x0238, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__ESAI_TX2_RX3, 0x060C, 0x023C, 0, 0x087C, 1, 0) +MX6_PAD_DECL(GPIO_5__KEY_ROW7, 0x060C, 0x023C, 2, 0x08FC, 1, 0) +MX6_PAD_DECL(GPIO_5__CCM_CLKO1, 0x060C, 0x023C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__GPIO1_IO05, 0x060C, 0x023C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_5__I2C3_SCL, 0x060C, 0x023C, 22, 0x08A8, 2, 0) +MX6_PAD_DECL(GPIO_5__ARM_EVENTI, 0x060C, 0x023C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__ESAI_TX4_RX1, 0x0610, 0x0240, 0, 0x0884, 1, 0) +MX6_PAD_DECL(GPIO_7__ECSPI5_RDY, 0x0610, 0x0240, 1, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__EPIT1_OUT, 0x0610, 0x0240, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__FLEXCAN1_TX, 0x0610, 0x0240, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_TX_DATA, 0x0610, 0x0240, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__UART2_RX_DATA, 0x0610, 0x0240, 4, 0x0928, 2, 0) +MX6_PAD_DECL(GPIO_7__GPIO1_IO07, 0x0610, 0x0240, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__SPDIF_LOCK, 0x0610, 0x0240, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_7__USB_OTG_HOST_MODE, 0x0610, 0x0240, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__ESAI_TX5_RX0, 0x0614, 0x0244, 0, 0x0888, 1, 0) MX6_PAD_DECL(GPIO_8__XTALOSC_REF_CLK_32K, 0x0614, 0x0244, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__EPIT2_OUT, 0x0614, 0x0244, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__FLEXCAN1_RX, 0x0614, 0x0244, 3, 0x07E4, 1, 0) -MX6_PAD_DECL(GPIO_8__UART2_TX_DATA, 0x0614, 0x0244, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__UART2_RX_DATA, 0x0614, 0x0244, 4, 0x0928, 3, 0) -MX6_PAD_DECL(GPIO_8__GPIO1_IO08, 0x0614, 0x0244, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_8__SPDIF_SR_CLK, 0x0614, 0x0244, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__EPIT2_OUT, 0x0614, 0x0244, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__FLEXCAN1_RX, 0x0614, 0x0244, 3, 0x07E4, 1, 0) +MX6_PAD_DECL(GPIO_8__UART2_TX_DATA, 0x0614, 0x0244, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__UART2_RX_DATA, 0x0614, 0x0244, 4, 0x0928, 3, 0) +MX6_PAD_DECL(GPIO_8__GPIO1_IO08, 0x0614, 0x0244, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_8__SPDIF_SR_CLK, 0x0614, 0x0244, 6, 0x0000, 0, 0) MX6_PAD_DECL(GPIO_8__USB_OTG_PWR_CTL_WAKE, 0x0614, 0x0244, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__ESAI_TX3_RX2, 0x0618, 0x0248, 0, 0x0880, 1, 0) +MX6_PAD_DECL(GPIO_16__ESAI_TX3_RX2, 0x0618, 0x0248, 0, 0x0880, 1, 0) MX6_PAD_DECL(GPIO_16__ENET_1588_EVENT2_IN, 0x0618, 0x0248, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__ENET_REF_CLK, 0x0618, 0x0248, 2, 0x083C, 1, 0) -MX6_PAD_DECL(GPIO_16__SD1_LCTL, 0x0618, 0x0248, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__SPDIF_IN, 0x0618, 0x0248, 4, 0x0914, 3, 0) -MX6_PAD_DECL(GPIO_16__GPIO7_IO11, 0x0618, 0x0248, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_16__I2C3_SDA, 0x0618, 0x0248, 22, 0x08AC, 2, 0) -MX6_PAD_DECL(GPIO_16__JTAG_DE_B, 0x0618, 0x0248, 7, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_17__ESAI_TX0, 0x061C, 0x024C, 0, 0x0874, 0, 0) +MX6_PAD_DECL(GPIO_16__ENET_REF_CLK, 0x0618, 0x0248, 2, 0x083C, 1, 0) +MX6_PAD_DECL(GPIO_16__SD1_LCTL, 0x0618, 0x0248, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__SPDIF_IN, 0x0618, 0x0248, 4, 0x0914, 3, 0) +MX6_PAD_DECL(GPIO_16__GPIO7_IO11, 0x0618, 0x0248, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_16__I2C3_SDA, 0x0618, 0x0248, 22, 0x08AC, 2, 0) +MX6_PAD_DECL(GPIO_16__JTAG_DE_B, 0x0618, 0x0248, 7, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__ESAI_TX0, 0x061C, 0x024C, 0, 0x0874, 0, 0) MX6_PAD_DECL(GPIO_17__ENET_1588_EVENT3_IN, 0x061C, 0x024C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_17__CCM_PMIC_READY, 0x061C, 0x024C, 2, 0x07F0, 1, 0) -MX6_PAD_DECL(GPIO_17__SDMA_EXT_EVENT0, 0x061C, 0x024C, 3, 0x090C, 1, 0) -MX6_PAD_DECL(GPIO_17__SPDIF_OUT, 0x061C, 0x024C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_17__GPIO7_IO12, 0x061C, 0x024C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_18__ESAI_TX1, 0x0620, 0x0250, 0, 0x0878, 0, 0) -MX6_PAD_DECL(GPIO_18__ENET_RX_CLK, 0x0620, 0x0250, 1, 0x0844, 1, 0) -MX6_PAD_DECL(GPIO_18__SD3_VSELECT, 0x0620, 0x0250, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_18__SDMA_EXT_EVENT1, 0x0620, 0x0250, 3, 0x0910, 1, 0) -MX6_PAD_DECL(GPIO_18__ASRC_EXT_CLK, 0x0620, 0x0250, 4, 0x07B0, 2, 0) -MX6_PAD_DECL(GPIO_18__GPIO7_IO13, 0x0620, 0x0250, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_18__SNVS_VIO_5_CTL, 0x0620, 0x0250, 6, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__KEY_COL5, 0x0624, 0x0254, 0, 0x08E8, 1, 0) +MX6_PAD_DECL(GPIO_17__CCM_PMIC_READY, 0x061C, 0x024C, 2, 0x07F0, 1, 0) +MX6_PAD_DECL(GPIO_17__SDMA_EXT_EVENT0, 0x061C, 0x024C, 3, 0x090C, 1, 0) +MX6_PAD_DECL(GPIO_17__SPDIF_OUT, 0x061C, 0x024C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_17__GPIO7_IO12, 0x061C, 0x024C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__ESAI_TX1, 0x0620, 0x0250, 0, 0x0878, 0, 0) +MX6_PAD_DECL(GPIO_18__ENET_RX_CLK, 0x0620, 0x0250, 1, 0x0844, 1, 0) +MX6_PAD_DECL(GPIO_18__SD3_VSELECT, 0x0620, 0x0250, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SDMA_EXT_EVENT1, 0x0620, 0x0250, 3, 0x0910, 1, 0) +MX6_PAD_DECL(GPIO_18__ASRC_EXT_CLK, 0x0620, 0x0250, 4, 0x07B0, 2, 0) +MX6_PAD_DECL(GPIO_18__GPIO7_IO13, 0x0620, 0x0250, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_18__SNVS_VIO_5_CTL, 0x0620, 0x0250, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__KEY_COL5, 0x0624, 0x0254, 0, 0x08E8, 1, 0) MX6_PAD_DECL(GPIO_19__ENET_1588_EVENT0_OUT, 0x0624, 0x0254, 1, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__SPDIF_OUT, 0x0624, 0x0254, 2, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__CCM_CLKO1, 0x0624, 0x0254, 3, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__ECSPI1_RDY, 0x0624, 0x0254, 4, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__GPIO4_IO05, 0x0624, 0x0254, 5, 0x0000, 0, 0) -MX6_PAD_DECL(GPIO_19__ENET_TX_ER, 0x0624, 0x0254, 6, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__SPDIF_OUT, 0x0624, 0x0254, 2, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__CCM_CLKO1, 0x0624, 0x0254, 3, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ECSPI1_RDY, 0x0624, 0x0254, 4, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__GPIO4_IO05, 0x0624, 0x0254, 5, 0x0000, 0, 0) +MX6_PAD_DECL(GPIO_19__ENET_TX_ER, 0x0624, 0x0254, 6, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_PIXCLK__IPU1_CSI0_PIXCLK, 0x0628, 0x0258, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_PIXCLK__GPIO5_IO18, 0x0628, 0x0258, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_PIXCLK__ARM_EVENTO, 0x0628, 0x0258, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__GPIO5_IO18, 0x0628, 0x0258, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_PIXCLK__ARM_EVENTO, 0x0628, 0x0258, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_MCLK__IPU1_CSI0_HSYNC, 0x062C, 0x025C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_MCLK__CCM_CLKO1, 0x062C, 0x025C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_MCLK__GPIO5_IO19, 0x062C, 0x025C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_MCLK__ARM_TRACE_CTL, 0x062C, 0x025C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__CCM_CLKO1, 0x062C, 0x025C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__GPIO5_IO19, 0x062C, 0x025C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_MCLK__ARM_TRACE_CTL, 0x062C, 0x025C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DATA_EN__IPU1_CSI0_DATA_EN, 0x0630, 0x0260, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DATA_EN__EIM_DATA00, 0x0630, 0x0260, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DATA_EN__GPIO5_IO20, 0x0630, 0x0260, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__EIM_DATA00, 0x0630, 0x0260, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DATA_EN__GPIO5_IO20, 0x0630, 0x0260, 5, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DATA_EN__ARM_TRACE_CLK, 0x0630, 0x0260, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_VSYNC__IPU1_CSI0_VSYNC, 0x0634, 0x0264, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_VSYNC__EIM_DATA01, 0x0634, 0x0264, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_VSYNC__GPIO5_IO21, 0x0634, 0x0264, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_VSYNC__ARM_TRACE00, 0x0634, 0x0264, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__EIM_DATA01, 0x0634, 0x0264, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__GPIO5_IO21, 0x0634, 0x0264, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_VSYNC__ARM_TRACE00, 0x0634, 0x0264, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT4__IPU1_CSI0_DATA04, 0x0638, 0x0268, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__EIM_DATA02, 0x0638, 0x0268, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__ECSPI1_SCLK, 0x0638, 0x0268, 2, 0x07F4, 3, 0) -MX6_PAD_DECL(CSI0_DAT4__KEY_COL5, 0x0638, 0x0268, 3, 0x08E8, 2, 0) -MX6_PAD_DECL(CSI0_DAT4__AUD3_TXC, 0x0638, 0x0268, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__GPIO5_IO22, 0x0638, 0x0268, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT4__ARM_TRACE01, 0x0638, 0x0268, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__EIM_DATA02, 0x0638, 0x0268, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ECSPI1_SCLK, 0x0638, 0x0268, 2, 0x07F4, 3, 0) +MX6_PAD_DECL(CSI0_DAT4__KEY_COL5, 0x0638, 0x0268, 3, 0x08E8, 2, 0) +MX6_PAD_DECL(CSI0_DAT4__AUD3_TXC, 0x0638, 0x0268, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__GPIO5_IO22, 0x0638, 0x0268, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT4__ARM_TRACE01, 0x0638, 0x0268, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT5__IPU1_CSI0_DATA05, 0x063C, 0x026C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__EIM_DATA03, 0x063C, 0x026C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__ECSPI1_MOSI, 0x063C, 0x026C, 2, 0x07FC, 3, 0) -MX6_PAD_DECL(CSI0_DAT5__KEY_ROW5, 0x063C, 0x026C, 3, 0x08F4, 1, 0) -MX6_PAD_DECL(CSI0_DAT5__AUD3_TXD, 0x063C, 0x026C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__GPIO5_IO23, 0x063C, 0x026C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT5__ARM_TRACE02, 0x063C, 0x026C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__EIM_DATA03, 0x063C, 0x026C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ECSPI1_MOSI, 0x063C, 0x026C, 2, 0x07FC, 3, 0) +MX6_PAD_DECL(CSI0_DAT5__KEY_ROW5, 0x063C, 0x026C, 3, 0x08F4, 1, 0) +MX6_PAD_DECL(CSI0_DAT5__AUD3_TXD, 0x063C, 0x026C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__GPIO5_IO23, 0x063C, 0x026C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT5__ARM_TRACE02, 0x063C, 0x026C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT6__IPU1_CSI0_DATA06, 0x0640, 0x0270, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__EIM_DATA04, 0x0640, 0x0270, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__ECSPI1_MISO, 0x0640, 0x0270, 2, 0x07F8, 3, 0) -MX6_PAD_DECL(CSI0_DAT6__KEY_COL6, 0x0640, 0x0270, 3, 0x08EC, 1, 0) -MX6_PAD_DECL(CSI0_DAT6__AUD3_TXFS, 0x0640, 0x0270, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__GPIO5_IO24, 0x0640, 0x0270, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT6__ARM_TRACE03, 0x0640, 0x0270, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__EIM_DATA04, 0x0640, 0x0270, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ECSPI1_MISO, 0x0640, 0x0270, 2, 0x07F8, 3, 0) +MX6_PAD_DECL(CSI0_DAT6__KEY_COL6, 0x0640, 0x0270, 3, 0x08EC, 1, 0) +MX6_PAD_DECL(CSI0_DAT6__AUD3_TXFS, 0x0640, 0x0270, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__GPIO5_IO24, 0x0640, 0x0270, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT6__ARM_TRACE03, 0x0640, 0x0270, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT7__IPU1_CSI0_DATA07, 0x0644, 0x0274, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__EIM_DATA05, 0x0644, 0x0274, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__ECSPI1_SS0, 0x0644, 0x0274, 2, 0x0800, 3, 0) -MX6_PAD_DECL(CSI0_DAT7__KEY_ROW6, 0x0644, 0x0274, 3, 0x08F8, 2, 0) -MX6_PAD_DECL(CSI0_DAT7__AUD3_RXD, 0x0644, 0x0274, 4, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__GPIO5_IO25, 0x0644, 0x0274, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT7__ARM_TRACE04, 0x0644, 0x0274, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__EIM_DATA05, 0x0644, 0x0274, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ECSPI1_SS0, 0x0644, 0x0274, 2, 0x0800, 3, 0) +MX6_PAD_DECL(CSI0_DAT7__KEY_ROW6, 0x0644, 0x0274, 3, 0x08F8, 2, 0) +MX6_PAD_DECL(CSI0_DAT7__AUD3_RXD, 0x0644, 0x0274, 4, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__GPIO5_IO25, 0x0644, 0x0274, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT7__ARM_TRACE04, 0x0644, 0x0274, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT8__IPU1_CSI0_DATA08, 0x0648, 0x0278, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__EIM_DATA06, 0x0648, 0x0278, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__ECSPI2_SCLK, 0x0648, 0x0278, 2, 0x0810, 2, 0) -MX6_PAD_DECL(CSI0_DAT8__KEY_COL7, 0x0648, 0x0278, 3, 0x08F0, 2, 0) -MX6_PAD_DECL(CSI0_DAT8__I2C1_SDA, 0x0648, 0x0278, 20, 0x089C, 1, 0) -MX6_PAD_DECL(CSI0_DAT8__GPIO5_IO26, 0x0648, 0x0278, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT8__ARM_TRACE05, 0x0648, 0x0278, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__EIM_DATA06, 0x0648, 0x0278, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ECSPI2_SCLK, 0x0648, 0x0278, 2, 0x0810, 2, 0) +MX6_PAD_DECL(CSI0_DAT8__KEY_COL7, 0x0648, 0x0278, 3, 0x08F0, 2, 0) +MX6_PAD_DECL(CSI0_DAT8__I2C1_SDA, 0x0648, 0x0278, 20, 0x089C, 1, 0) +MX6_PAD_DECL(CSI0_DAT8__GPIO5_IO26, 0x0648, 0x0278, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT8__ARM_TRACE05, 0x0648, 0x0278, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT9__IPU1_CSI0_DATA09, 0x064C, 0x027C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__EIM_DATA07, 0x064C, 0x027C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__ECSPI2_MOSI, 0x064C, 0x027C, 2, 0x0818, 2, 0) -MX6_PAD_DECL(CSI0_DAT9__KEY_ROW7, 0x064C, 0x027C, 3, 0x08FC, 2, 0) -MX6_PAD_DECL(CSI0_DAT9__I2C1_SCL, 0x064C, 0x027C, 20, 0x0898, 1, 0) -MX6_PAD_DECL(CSI0_DAT9__GPIO5_IO27, 0x064C, 0x027C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT9__ARM_TRACE06, 0x064C, 0x027C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__EIM_DATA07, 0x064C, 0x027C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ECSPI2_MOSI, 0x064C, 0x027C, 2, 0x0818, 2, 0) +MX6_PAD_DECL(CSI0_DAT9__KEY_ROW7, 0x064C, 0x027C, 3, 0x08FC, 2, 0) +MX6_PAD_DECL(CSI0_DAT9__I2C1_SCL, 0x064C, 0x027C, 20, 0x0898, 1, 0) +MX6_PAD_DECL(CSI0_DAT9__GPIO5_IO27, 0x064C, 0x027C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT9__ARM_TRACE06, 0x064C, 0x027C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT10__IPU1_CSI0_DATA10, 0x0650, 0x0280, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__AUD3_RXC, 0x0650, 0x0280, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__ECSPI2_MISO, 0x0650, 0x0280, 2, 0x0814, 2, 0) -MX6_PAD_DECL(CSI0_DAT10__UART1_TX_DATA, 0x0650, 0x0280, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__UART1_RX_DATA, 0x0650, 0x0280, 3, 0x0920, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__GPIO5_IO28, 0x0650, 0x0280, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT10__ARM_TRACE07, 0x0650, 0x0280, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__AUD3_RXC, 0x0650, 0x0280, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ECSPI2_MISO, 0x0650, 0x0280, 2, 0x0814, 2, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_TX_DATA, 0x0650, 0x0280, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__UART1_RX_DATA, 0x0650, 0x0280, 3, 0x0920, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__GPIO5_IO28, 0x0650, 0x0280, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT10__ARM_TRACE07, 0x0650, 0x0280, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT11__IPU1_CSI0_DATA11, 0x0654, 0x0284, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__AUD3_RXFS, 0x0654, 0x0284, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__ECSPI2_SS0, 0x0654, 0x0284, 2, 0x081C, 2, 0) -MX6_PAD_DECL(CSI0_DAT11__UART1_TX_DATA, 0x0654, 0x0284, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__UART1_RX_DATA, 0x0654, 0x0284, 3, 0x0920, 1, 0) -MX6_PAD_DECL(CSI0_DAT11__GPIO5_IO29, 0x0654, 0x0284, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT11__ARM_TRACE08, 0x0654, 0x0284, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__AUD3_RXFS, 0x0654, 0x0284, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ECSPI2_SS0, 0x0654, 0x0284, 2, 0x081C, 2, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_TX_DATA, 0x0654, 0x0284, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__UART1_RX_DATA, 0x0654, 0x0284, 3, 0x0920, 1, 0) +MX6_PAD_DECL(CSI0_DAT11__GPIO5_IO29, 0x0654, 0x0284, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT11__ARM_TRACE08, 0x0654, 0x0284, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT12__IPU1_CSI0_DATA12, 0x0658, 0x0288, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__EIM_DATA08, 0x0658, 0x0288, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__UART4_TX_DATA, 0x0658, 0x0288, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__UART4_RX_DATA, 0x0658, 0x0288, 3, 0x0938, 2, 0) -MX6_PAD_DECL(CSI0_DAT12__GPIO5_IO30, 0x0658, 0x0288, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT12__ARM_TRACE09, 0x0658, 0x0288, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__EIM_DATA08, 0x0658, 0x0288, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_TX_DATA, 0x0658, 0x0288, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__UART4_RX_DATA, 0x0658, 0x0288, 3, 0x0938, 2, 0) +MX6_PAD_DECL(CSI0_DAT12__GPIO5_IO30, 0x0658, 0x0288, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT12__ARM_TRACE09, 0x0658, 0x0288, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT13__IPU1_CSI0_DATA13, 0x065C, 0x028C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__EIM_DATA09, 0x065C, 0x028C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__UART4_TX_DATA, 0x065C, 0x028C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__UART4_RX_DATA, 0x065C, 0x028C, 3, 0x0938, 3, 0) -MX6_PAD_DECL(CSI0_DAT13__GPIO5_IO31, 0x065C, 0x028C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT13__ARM_TRACE10, 0x065C, 0x028C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__EIM_DATA09, 0x065C, 0x028C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_TX_DATA, 0x065C, 0x028C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__UART4_RX_DATA, 0x065C, 0x028C, 3, 0x0938, 3, 0) +MX6_PAD_DECL(CSI0_DAT13__GPIO5_IO31, 0x065C, 0x028C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT13__ARM_TRACE10, 0x065C, 0x028C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT14__IPU1_CSI0_DATA14, 0x0660, 0x0290, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__EIM_DATA10, 0x0660, 0x0290, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__UART5_TX_DATA, 0x0660, 0x0290, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__UART5_RX_DATA, 0x0660, 0x0290, 3, 0x0940, 2, 0) -MX6_PAD_DECL(CSI0_DAT14__GPIO6_IO00, 0x0660, 0x0290, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT14__ARM_TRACE11, 0x0660, 0x0290, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__EIM_DATA10, 0x0660, 0x0290, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_TX_DATA, 0x0660, 0x0290, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__UART5_RX_DATA, 0x0660, 0x0290, 3, 0x0940, 2, 0) +MX6_PAD_DECL(CSI0_DAT14__GPIO6_IO00, 0x0660, 0x0290, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT14__ARM_TRACE11, 0x0660, 0x0290, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT15__IPU1_CSI0_DATA15, 0x0664, 0x0294, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__EIM_DATA11, 0x0664, 0x0294, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__UART5_TX_DATA, 0x0664, 0x0294, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__UART5_RX_DATA, 0x0664, 0x0294, 3, 0x0940, 3, 0) -MX6_PAD_DECL(CSI0_DAT15__GPIO6_IO01, 0x0664, 0x0294, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT15__ARM_TRACE12, 0x0664, 0x0294, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__EIM_DATA11, 0x0664, 0x0294, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_TX_DATA, 0x0664, 0x0294, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__UART5_RX_DATA, 0x0664, 0x0294, 3, 0x0940, 3, 0) +MX6_PAD_DECL(CSI0_DAT15__GPIO6_IO01, 0x0664, 0x0294, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT15__ARM_TRACE12, 0x0664, 0x0294, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT16__IPU1_CSI0_DATA16, 0x0668, 0x0298, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__EIM_DATA12, 0x0668, 0x0298, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__UART4_CTS_B, 0x0668, 0x0298, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__UART4_RTS_B, 0x0668, 0x0298, 3, 0x0934, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__GPIO6_IO02, 0x0668, 0x0298, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT16__ARM_TRACE13, 0x0668, 0x0298, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__EIM_DATA12, 0x0668, 0x0298, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_CTS_B, 0x0668, 0x0298, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__UART4_RTS_B, 0x0668, 0x0298, 3, 0x0934, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__GPIO6_IO02, 0x0668, 0x0298, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT16__ARM_TRACE13, 0x0668, 0x0298, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT17__IPU1_CSI0_DATA17, 0x066C, 0x029C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__EIM_DATA13, 0x066C, 0x029C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__UART4_CTS_B, 0x066C, 0x029C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__UART4_RTS_B, 0x066C, 0x029C, 3, 0x0934, 1, 0) -MX6_PAD_DECL(CSI0_DAT17__GPIO6_IO03, 0x066C, 0x029C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT17__ARM_TRACE14, 0x066C, 0x029C, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__EIM_DATA13, 0x066C, 0x029C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_CTS_B, 0x066C, 0x029C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__UART4_RTS_B, 0x066C, 0x029C, 3, 0x0934, 1, 0) +MX6_PAD_DECL(CSI0_DAT17__GPIO6_IO03, 0x066C, 0x029C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT17__ARM_TRACE14, 0x066C, 0x029C, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT18__IPU1_CSI0_DATA18, 0x0670, 0x02A0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__EIM_DATA14, 0x0670, 0x02A0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__UART5_CTS_B, 0x0670, 0x02A0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__UART5_RTS_B, 0x0670, 0x02A0, 3, 0x093C, 2, 0) -MX6_PAD_DECL(CSI0_DAT18__GPIO6_IO04, 0x0670, 0x02A0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT18__ARM_TRACE15, 0x0670, 0x02A0, 7, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__EIM_DATA14, 0x0670, 0x02A0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_CTS_B, 0x0670, 0x02A0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__UART5_RTS_B, 0x0670, 0x02A0, 3, 0x093C, 2, 0) +MX6_PAD_DECL(CSI0_DAT18__GPIO6_IO04, 0x0670, 0x02A0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT18__ARM_TRACE15, 0x0670, 0x02A0, 7, 0x0000, 0, 0) MX6_PAD_DECL(CSI0_DAT19__IPU1_CSI0_DATA19, 0x0674, 0x02A4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT19__EIM_DATA15, 0x0674, 0x02A4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT19__UART5_CTS_B, 0x0674, 0x02A4, 3, 0x0000, 0, 0) -MX6_PAD_DECL(CSI0_DAT19__UART5_RTS_B, 0x0674, 0x02A4, 3, 0x093C, 3, 0) -MX6_PAD_DECL(CSI0_DAT19__GPIO6_IO05, 0x0674, 0x02A4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT7__SD3_DATA7, 0x0690, 0x02A8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT7__UART1_TX_DATA, 0x0690, 0x02A8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT7__UART1_RX_DATA, 0x0690, 0x02A8, 1, 0x0920, 2, 0) -MX6_PAD_DECL(SD3_DAT7__GPIO6_IO17, 0x0690, 0x02A8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT6__SD3_DATA6, 0x0694, 0x02AC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT6__UART1_TX_DATA, 0x0694, 0x02AC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT6__UART1_RX_DATA, 0x0694, 0x02AC, 1, 0x0920, 3, 0) -MX6_PAD_DECL(SD3_DAT6__GPIO6_IO18, 0x0694, 0x02AC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT5__SD3_DATA5, 0x0698, 0x02B0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT5__UART2_TX_DATA, 0x0698, 0x02B0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT5__UART2_RX_DATA, 0x0698, 0x02B0, 1, 0x0928, 4, 0) -MX6_PAD_DECL(SD3_DAT5__GPIO7_IO00, 0x0698, 0x02B0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT4__SD3_DATA4, 0x069C, 0x02B4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT4__UART2_TX_DATA, 0x069C, 0x02B4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT4__UART2_RX_DATA, 0x069C, 0x02B4, 1, 0x0928, 5, 0) -MX6_PAD_DECL(SD3_DAT4__GPIO7_IO01, 0x069C, 0x02B4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__SD3_CMD, 0x06A0, 0x02B8, 16, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__UART2_CTS_B, 0x06A0, 0x02B8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__UART2_RTS_B, 0x06A0, 0x02B8, 1, 0x0924, 2, 0) -MX6_PAD_DECL(SD3_CMD__FLEXCAN1_TX, 0x06A0, 0x02B8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CMD__GPIO7_IO02, 0x06A0, 0x02B8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CLK__SD3_CLK, 0x06A4, 0x02BC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CLK__UART2_CTS_B, 0x06A4, 0x02BC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_CLK__UART2_RTS_B, 0x06A4, 0x02BC, 1, 0x0924, 3, 0) -MX6_PAD_DECL(SD3_CLK__FLEXCAN1_RX, 0x06A4, 0x02BC, 2, 0x07E4, 2, 0) -MX6_PAD_DECL(SD3_CLK__GPIO7_IO03, 0x06A4, 0x02BC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__SD3_DATA0, 0x06A8, 0x02C0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__UART1_CTS_B, 0x06A8, 0x02C0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__UART1_RTS_B, 0x06A8, 0x02C0, 1, 0x091C, 2, 0) -MX6_PAD_DECL(SD3_DAT0__FLEXCAN2_TX, 0x06A8, 0x02C0, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT0__GPIO7_IO04, 0x06A8, 0x02C0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT1__SD3_DATA1, 0x06AC, 0x02C4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT1__UART1_CTS_B, 0x06AC, 0x02C4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT1__UART1_RTS_B, 0x06AC, 0x02C4, 1, 0x091C, 3, 0) -MX6_PAD_DECL(SD3_DAT1__FLEXCAN2_RX, 0x06AC, 0x02C4, 2, 0x07E8, 1, 0) -MX6_PAD_DECL(SD3_DAT1__GPIO7_IO05, 0x06AC, 0x02C4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT2__SD3_DATA2, 0x06B0, 0x02C8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT2__GPIO7_IO06, 0x06B0, 0x02C8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT3__SD3_DATA3, 0x06B4, 0x02CC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT3__UART3_CTS_B, 0x06B4, 0x02CC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_DAT3__UART3_RTS_B, 0x06B4, 0x02CC, 1, 0x092C, 4, 0) -MX6_PAD_DECL(SD3_DAT3__GPIO7_IO07, 0x06B4, 0x02CC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_RST__SD3_RESET, 0x06B8, 0x02D0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_RST__UART3_CTS_B, 0x06B8, 0x02D0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD3_RST__UART3_RTS_B, 0x06B8, 0x02D0, 1, 0x092C, 5, 0) -MX6_PAD_DECL(SD3_RST__GPIO7_IO08, 0x06B8, 0x02D0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CLE__NAND_CLE, 0x06BC, 0x02D4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CLE__IPU2_SISG4, 0x06BC, 0x02D4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CLE__GPIO6_IO07, 0x06BC, 0x02D4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_ALE__NAND_ALE, 0x06C0, 0x02D8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_ALE__SD4_RESET, 0x06C0, 0x02D8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_ALE__GPIO6_IO08, 0x06C0, 0x02D8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_WP_B__NAND_WP_B, 0x06C4, 0x02DC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_WP_B__IPU2_SISG5, 0x06C4, 0x02DC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_WP_B__GPIO6_IO09, 0x06C4, 0x02DC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_RB0__NAND_READY_B, 0x06C8, 0x02E0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_RB0__IPU2_DI0_PIN01, 0x06C8, 0x02E0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_RB0__GPIO6_IO10, 0x06C8, 0x02E0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS0__NAND_CE0_B, 0x06CC, 0x02E4, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS0__GPIO6_IO11, 0x06CC, 0x02E4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__NAND_CE1_B, 0x06D0, 0x02E8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__SD4_VSELECT, 0x06D0, 0x02E8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__SD3_VSELECT, 0x06D0, 0x02E8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS1__GPIO6_IO14, 0x06D0, 0x02E8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__NAND_CE2_B, 0x06D4, 0x02EC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__IPU1_SISG0, 0x06D4, 0x02EC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__ESAI_TX0, 0x06D4, 0x02EC, 2, 0x0874, 1, 0) -MX6_PAD_DECL(NANDF_CS2__EIM_CRE, 0x06D4, 0x02EC, 3, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__CCM_CLKO2, 0x06D4, 0x02EC, 4, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__GPIO6_IO15, 0x06D4, 0x02EC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS2__IPU2_SISG0, 0x06D4, 0x02EC, 6, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__NAND_CE3_B, 0x06D8, 0x02F0, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__IPU1_SISG1, 0x06D8, 0x02F0, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__ESAI_TX1, 0x06D8, 0x02F0, 2, 0x0878, 1, 0) -MX6_PAD_DECL(NANDF_CS3__EIM_ADDR26, 0x06D8, 0x02F0, 3, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__GPIO6_IO16, 0x06D8, 0x02F0, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_CS3__IPU2_SISG1, 0x06D8, 0x02F0, 6, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__SD4_CMD, 0x06DC, 0x02F4, 16, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__NAND_RE_B, 0x06DC, 0x02F4, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__UART3_TX_DATA, 0x06DC, 0x02F4, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CMD__UART3_RX_DATA, 0x06DC, 0x02F4, 2, 0x0930, 2, 0) -MX6_PAD_DECL(SD4_CMD__GPIO7_IO09, 0x06DC, 0x02F4, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__SD4_CLK, 0x06E0, 0x02F8, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__NAND_WE_B, 0x06E0, 0x02F8, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__UART3_TX_DATA, 0x06E0, 0x02F8, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_CLK__UART3_RX_DATA, 0x06E0, 0x02F8, 2, 0x0930, 3, 0) -MX6_PAD_DECL(SD4_CLK__GPIO7_IO10, 0x06E0, 0x02F8, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D0__NAND_DATA00, 0x06E4, 0x02FC, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D0__SD1_DATA4, 0x06E4, 0x02FC, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D0__GPIO2_IO00, 0x06E4, 0x02FC, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D1__NAND_DATA01, 0x06E8, 0x0300, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D1__SD1_DATA5, 0x06E8, 0x0300, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D1__GPIO2_IO01, 0x06E8, 0x0300, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D2__NAND_DATA02, 0x06EC, 0x0304, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D2__SD1_DATA6, 0x06EC, 0x0304, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D2__GPIO2_IO02, 0x06EC, 0x0304, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D3__NAND_DATA03, 0x06F0, 0x0308, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D3__SD1_DATA7, 0x06F0, 0x0308, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D3__GPIO2_IO03, 0x06F0, 0x0308, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D4__NAND_DATA04, 0x06F4, 0x030C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D4__SD2_DATA4, 0x06F4, 0x030C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D4__GPIO2_IO04, 0x06F4, 0x030C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D5__NAND_DATA05, 0x06F8, 0x0310, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D5__SD2_DATA5, 0x06F8, 0x0310, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D5__GPIO2_IO05, 0x06F8, 0x0310, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D6__NAND_DATA06, 0x06FC, 0x0314, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D6__SD2_DATA6, 0x06FC, 0x0314, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D6__GPIO2_IO06, 0x06FC, 0x0314, 5, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D7__NAND_DATA07, 0x0700, 0x0318, 0, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D7__SD2_DATA7, 0x0700, 0x0318, 1, 0x0000, 0, 0) -MX6_PAD_DECL(NANDF_D7__GPIO2_IO07, 0x0700, 0x0318, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT0__SD4_DATA0, 0x0704, 0x031C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT0__NAND_DQS, 0x0704, 0x031C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT0__GPIO2_IO08, 0x0704, 0x031C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT1__SD4_DATA1, 0x0708, 0x0320, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT1__PWM3_OUT, 0x0708, 0x0320, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT1__GPIO2_IO09, 0x0708, 0x0320, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT2__SD4_DATA2, 0x070C, 0x0324, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT2__PWM4_OUT, 0x070C, 0x0324, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT2__GPIO2_IO10, 0x070C, 0x0324, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT3__SD4_DATA3, 0x0710, 0x0328, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT3__GPIO2_IO11, 0x0710, 0x0328, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT4__SD4_DATA4, 0x0714, 0x032C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT4__UART2_TX_DATA, 0x0714, 0x032C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT4__UART2_RX_DATA, 0x0714, 0x032C, 2, 0x0928, 6, 0) -MX6_PAD_DECL(SD4_DAT4__GPIO2_IO12, 0x0714, 0x032C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT5__SD4_DATA5, 0x0718, 0x0330, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT5__UART2_CTS_B, 0x0718, 0x0330, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT5__UART2_RTS_B, 0x0718, 0x0330, 2, 0x0924, 4, 0) -MX6_PAD_DECL(SD4_DAT5__GPIO2_IO13, 0x0718, 0x0330, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT6__SD4_DATA6, 0x071C, 0x0334, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT6__UART2_CTS_B, 0x071C, 0x0334, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT6__UART2_RTS_B, 0x071C, 0x0334, 2, 0x0924, 5, 0) -MX6_PAD_DECL(SD4_DAT6__GPIO2_IO14, 0x071C, 0x0334, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT7__SD4_DATA7, 0x0720, 0x0338, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT7__UART2_TX_DATA, 0x0720, 0x0338, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD4_DAT7__UART2_RX_DATA, 0x0720, 0x0338, 2, 0x0928, 7, 0) -MX6_PAD_DECL(SD4_DAT7__GPIO2_IO15, 0x0720, 0x0338, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__SD1_DATA1, 0x0724, 0x033C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__ECSPI5_SS0, 0x0724, 0x033C, 1, 0x0834, 1, 0) -MX6_PAD_DECL(SD1_DAT1__PWM3_OUT, 0x0724, 0x033C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__GPT_CAPTURE2, 0x0724, 0x033C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT1__GPIO1_IO17, 0x0724, 0x033C, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT0__SD1_DATA0, 0x0728, 0x0340, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT0__ECSPI5_MISO, 0x0728, 0x0340, 1, 0x082C, 1, 0) -MX6_PAD_DECL(SD1_DAT0__GPT_CAPTURE1, 0x0728, 0x0340, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT0__GPIO1_IO16, 0x0728, 0x0340, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__SD1_DATA3, 0x072C, 0x0344, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__ECSPI5_SS2, 0x072C, 0x0344, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__GPT_COMPARE3, 0x072C, 0x0344, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__PWM1_OUT, 0x072C, 0x0344, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__WDOG2_B, 0x072C, 0x0344, 4, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT3__GPIO1_IO21, 0x072C, 0x0344, 5, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__EIM_DATA15, 0x0674, 0x02A4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_CTS_B, 0x0674, 0x02A4, 3, 0x0000, 0, 0) +MX6_PAD_DECL(CSI0_DAT19__UART5_RTS_B, 0x0674, 0x02A4, 3, 0x093C, 3, 0) +MX6_PAD_DECL(CSI0_DAT19__GPIO6_IO05, 0x0674, 0x02A4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__SD3_DATA7, 0x0690, 0x02A8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_TX_DATA, 0x0690, 0x02A8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT7__UART1_RX_DATA, 0x0690, 0x02A8, 1, 0x0920, 2, 0) +MX6_PAD_DECL(SD3_DAT7__GPIO6_IO17, 0x0690, 0x02A8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__SD3_DATA6, 0x0694, 0x02AC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_TX_DATA, 0x0694, 0x02AC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT6__UART1_RX_DATA, 0x0694, 0x02AC, 1, 0x0920, 3, 0) +MX6_PAD_DECL(SD3_DAT6__GPIO6_IO18, 0x0694, 0x02AC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__SD3_DATA5, 0x0698, 0x02B0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_TX_DATA, 0x0698, 0x02B0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT5__UART2_RX_DATA, 0x0698, 0x02B0, 1, 0x0928, 4, 0) +MX6_PAD_DECL(SD3_DAT5__GPIO7_IO00, 0x0698, 0x02B0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__SD3_DATA4, 0x069C, 0x02B4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_TX_DATA, 0x069C, 0x02B4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT4__UART2_RX_DATA, 0x069C, 0x02B4, 1, 0x0928, 5, 0) +MX6_PAD_DECL(SD3_DAT4__GPIO7_IO01, 0x069C, 0x02B4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__SD3_CMD, 0x06A0, 0x02B8, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_CTS_B, 0x06A0, 0x02B8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__UART2_RTS_B, 0x06A0, 0x02B8, 1, 0x0924, 2, 0) +MX6_PAD_DECL(SD3_CMD__FLEXCAN1_TX, 0x06A0, 0x02B8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CMD__GPIO7_IO02, 0x06A0, 0x02B8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__SD3_CLK, 0x06A4, 0x02BC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__UART2_CTS_B, 0x06A4, 0x02BC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_CLK__UART2_RTS_B, 0x06A4, 0x02BC, 1, 0x0924, 3, 0) +MX6_PAD_DECL(SD3_CLK__FLEXCAN1_RX, 0x06A4, 0x02BC, 2, 0x07E4, 2, 0) +MX6_PAD_DECL(SD3_CLK__GPIO7_IO03, 0x06A4, 0x02BC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__SD3_DATA0, 0x06A8, 0x02C0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_CTS_B, 0x06A8, 0x02C0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__UART1_RTS_B, 0x06A8, 0x02C0, 1, 0x091C, 2, 0) +MX6_PAD_DECL(SD3_DAT0__FLEXCAN2_TX, 0x06A8, 0x02C0, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT0__GPIO7_IO04, 0x06A8, 0x02C0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__SD3_DATA1, 0x06AC, 0x02C4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_CTS_B, 0x06AC, 0x02C4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT1__UART1_RTS_B, 0x06AC, 0x02C4, 1, 0x091C, 3, 0) +MX6_PAD_DECL(SD3_DAT1__FLEXCAN2_RX, 0x06AC, 0x02C4, 2, 0x07E8, 1, 0) +MX6_PAD_DECL(SD3_DAT1__GPIO7_IO05, 0x06AC, 0x02C4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__SD3_DATA2, 0x06B0, 0x02C8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT2__GPIO7_IO06, 0x06B0, 0x02C8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__SD3_DATA3, 0x06B4, 0x02CC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_CTS_B, 0x06B4, 0x02CC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_DAT3__UART3_RTS_B, 0x06B4, 0x02CC, 1, 0x092C, 4, 0) +MX6_PAD_DECL(SD3_DAT3__GPIO7_IO07, 0x06B4, 0x02CC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__SD3_RESET, 0x06B8, 0x02D0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_CTS_B, 0x06B8, 0x02D0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD3_RST__UART3_RTS_B, 0x06B8, 0x02D0, 1, 0x092C, 5, 0) +MX6_PAD_DECL(SD3_RST__GPIO7_IO08, 0x06B8, 0x02D0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__NAND_CLE, 0x06BC, 0x02D4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__IPU2_SISG4, 0x06BC, 0x02D4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CLE__GPIO6_IO07, 0x06BC, 0x02D4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__NAND_ALE, 0x06C0, 0x02D8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__SD4_RESET, 0x06C0, 0x02D8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_ALE__GPIO6_IO08, 0x06C0, 0x02D8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__NAND_WP_B, 0x06C4, 0x02DC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__IPU2_SISG5, 0x06C4, 0x02DC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_WP_B__GPIO6_IO09, 0x06C4, 0x02DC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__NAND_READY_B, 0x06C8, 0x02E0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__IPU2_DI0_PIN01, 0x06C8, 0x02E0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_RB0__GPIO6_IO10, 0x06C8, 0x02E0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__NAND_CE0_B, 0x06CC, 0x02E4, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS0__GPIO6_IO11, 0x06CC, 0x02E4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__NAND_CE1_B, 0x06D0, 0x02E8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD4_VSELECT, 0x06D0, 0x02E8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__SD3_VSELECT, 0x06D0, 0x02E8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS1__GPIO6_IO14, 0x06D0, 0x02E8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__NAND_CE2_B, 0x06D4, 0x02EC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__IPU1_SISG0, 0x06D4, 0x02EC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__ESAI_TX0, 0x06D4, 0x02EC, 2, 0x0874, 1, 0) +MX6_PAD_DECL(NANDF_CS2__EIM_CRE, 0x06D4, 0x02EC, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__CCM_CLKO2, 0x06D4, 0x02EC, 4, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__GPIO6_IO15, 0x06D4, 0x02EC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS2__IPU2_SISG0, 0x06D4, 0x02EC, 6, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__NAND_CE3_B, 0x06D8, 0x02F0, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__IPU1_SISG1, 0x06D8, 0x02F0, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__ESAI_TX1, 0x06D8, 0x02F0, 2, 0x0878, 1, 0) +MX6_PAD_DECL(NANDF_CS3__EIM_ADDR26, 0x06D8, 0x02F0, 3, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__GPIO6_IO16, 0x06D8, 0x02F0, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_CS3__IPU2_SISG1, 0x06D8, 0x02F0, 6, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__SD4_CMD, 0x06DC, 0x02F4, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__NAND_RE_B, 0x06DC, 0x02F4, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_TX_DATA, 0x06DC, 0x02F4, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CMD__UART3_RX_DATA, 0x06DC, 0x02F4, 2, 0x0930, 2, 0) +MX6_PAD_DECL(SD4_CMD__GPIO7_IO09, 0x06DC, 0x02F4, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__SD4_CLK, 0x06E0, 0x02F8, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__NAND_WE_B, 0x06E0, 0x02F8, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_TX_DATA, 0x06E0, 0x02F8, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_CLK__UART3_RX_DATA, 0x06E0, 0x02F8, 2, 0x0930, 3, 0) +MX6_PAD_DECL(SD4_CLK__GPIO7_IO10, 0x06E0, 0x02F8, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__NAND_DATA00, 0x06E4, 0x02FC, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__SD1_DATA4, 0x06E4, 0x02FC, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D0__GPIO2_IO00, 0x06E4, 0x02FC, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__NAND_DATA01, 0x06E8, 0x0300, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__SD1_DATA5, 0x06E8, 0x0300, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D1__GPIO2_IO01, 0x06E8, 0x0300, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__NAND_DATA02, 0x06EC, 0x0304, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__SD1_DATA6, 0x06EC, 0x0304, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D2__GPIO2_IO02, 0x06EC, 0x0304, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__NAND_DATA03, 0x06F0, 0x0308, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__SD1_DATA7, 0x06F0, 0x0308, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D3__GPIO2_IO03, 0x06F0, 0x0308, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__NAND_DATA04, 0x06F4, 0x030C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__SD2_DATA4, 0x06F4, 0x030C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D4__GPIO2_IO04, 0x06F4, 0x030C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__NAND_DATA05, 0x06F8, 0x0310, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__SD2_DATA5, 0x06F8, 0x0310, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D5__GPIO2_IO05, 0x06F8, 0x0310, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__NAND_DATA06, 0x06FC, 0x0314, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__SD2_DATA6, 0x06FC, 0x0314, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D6__GPIO2_IO06, 0x06FC, 0x0314, 5, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__NAND_DATA07, 0x0700, 0x0318, 0, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__SD2_DATA7, 0x0700, 0x0318, 1, 0x0000, 0, 0) +MX6_PAD_DECL(NANDF_D7__GPIO2_IO07, 0x0700, 0x0318, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__SD4_DATA0, 0x0704, 0x031C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__NAND_DQS, 0x0704, 0x031C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT0__GPIO2_IO08, 0x0704, 0x031C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__SD4_DATA1, 0x0708, 0x0320, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__PWM3_OUT, 0x0708, 0x0320, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT1__GPIO2_IO09, 0x0708, 0x0320, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__SD4_DATA2, 0x070C, 0x0324, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__PWM4_OUT, 0x070C, 0x0324, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT2__GPIO2_IO10, 0x070C, 0x0324, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__SD4_DATA3, 0x0710, 0x0328, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT3__GPIO2_IO11, 0x0710, 0x0328, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__SD4_DATA4, 0x0714, 0x032C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_TX_DATA, 0x0714, 0x032C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT4__UART2_RX_DATA, 0x0714, 0x032C, 2, 0x0928, 6, 0) +MX6_PAD_DECL(SD4_DAT4__GPIO2_IO12, 0x0714, 0x032C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__SD4_DATA5, 0x0718, 0x0330, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_CTS_B, 0x0718, 0x0330, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT5__UART2_RTS_B, 0x0718, 0x0330, 2, 0x0924, 4, 0) +MX6_PAD_DECL(SD4_DAT5__GPIO2_IO13, 0x0718, 0x0330, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__SD4_DATA6, 0x071C, 0x0334, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_CTS_B, 0x071C, 0x0334, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT6__UART2_RTS_B, 0x071C, 0x0334, 2, 0x0924, 5, 0) +MX6_PAD_DECL(SD4_DAT6__GPIO2_IO14, 0x071C, 0x0334, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__SD4_DATA7, 0x0720, 0x0338, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_TX_DATA, 0x0720, 0x0338, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD4_DAT7__UART2_RX_DATA, 0x0720, 0x0338, 2, 0x0928, 7, 0) +MX6_PAD_DECL(SD4_DAT7__GPIO2_IO15, 0x0720, 0x0338, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__SD1_DATA1, 0x0724, 0x033C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__ECSPI5_SS0, 0x0724, 0x033C, 1, 0x0834, 1, 0) +MX6_PAD_DECL(SD1_DAT1__PWM3_OUT, 0x0724, 0x033C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPT_CAPTURE2, 0x0724, 0x033C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT1__GPIO1_IO17, 0x0724, 0x033C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__SD1_DATA0, 0x0728, 0x0340, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__ECSPI5_MISO, 0x0728, 0x0340, 1, 0x082C, 1, 0) +MX6_PAD_DECL(SD1_DAT0__GPT_CAPTURE1, 0x0728, 0x0340, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT0__GPIO1_IO16, 0x0728, 0x0340, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__SD1_DATA3, 0x072C, 0x0344, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__ECSPI5_SS2, 0x072C, 0x0344, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPT_COMPARE3, 0x072C, 0x0344, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__PWM1_OUT, 0x072C, 0x0344, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__WDOG2_B, 0x072C, 0x0344, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT3__GPIO1_IO21, 0x072C, 0x0344, 5, 0x0000, 0, 0) MX6_PAD_DECL(SD1_DAT3__WDOG2_RESET_B_DEB, 0x072C, 0x0344, 6, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__SD1_CMD, 0x0730, 0x0348, 16, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__ECSPI5_MOSI, 0x0730, 0x0348, 1, 0x0830, 0, 0) -MX6_PAD_DECL(SD1_CMD__PWM4_OUT, 0x0730, 0x0348, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__GPT_COMPARE1, 0x0730, 0x0348, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CMD__GPIO1_IO18, 0x0730, 0x0348, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__SD1_DATA2, 0x0734, 0x034C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__ECSPI5_SS1, 0x0734, 0x034C, 1, 0x0838, 1, 0) -MX6_PAD_DECL(SD1_DAT2__GPT_COMPARE2, 0x0734, 0x034C, 2, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__PWM2_OUT, 0x0734, 0x034C, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__WDOG1_B, 0x0734, 0x034C, 4, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_DAT2__GPIO1_IO19, 0x0734, 0x034C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__SD1_CMD, 0x0730, 0x0348, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__ECSPI5_MOSI, 0x0730, 0x0348, 1, 0x0830, 0, 0) +MX6_PAD_DECL(SD1_CMD__PWM4_OUT, 0x0730, 0x0348, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPT_COMPARE1, 0x0730, 0x0348, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CMD__GPIO1_IO18, 0x0730, 0x0348, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__SD1_DATA2, 0x0734, 0x034C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__ECSPI5_SS1, 0x0734, 0x034C, 1, 0x0838, 1, 0) +MX6_PAD_DECL(SD1_DAT2__GPT_COMPARE2, 0x0734, 0x034C, 2, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__PWM2_OUT, 0x0734, 0x034C, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__WDOG1_B, 0x0734, 0x034C, 4, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_DAT2__GPIO1_IO19, 0x0734, 0x034C, 5, 0x0000, 0, 0) MX6_PAD_DECL(SD1_DAT2__WDOG1_RESET_B_DEB, 0x0734, 0x034C, 6, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CLK__SD1_CLK, 0x0738, 0x0350, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CLK__ECSPI5_SCLK, 0x0738, 0x0350, 1, 0x0828, 0, 0) -MX6_PAD_DECL(SD1_CLK__GPT_CLKIN, 0x0738, 0x0350, 3, 0x0000, 0, 0) -MX6_PAD_DECL(SD1_CLK__GPIO1_IO20, 0x0738, 0x0350, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CLK__SD2_CLK, 0x073C, 0x0354, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CLK__ECSPI5_SCLK, 0x073C, 0x0354, 1, 0x0828, 1, 0) -MX6_PAD_DECL(SD2_CLK__KEY_COL5, 0x073C, 0x0354, 2, 0x08E8, 3, 0) -MX6_PAD_DECL(SD2_CLK__AUD4_RXFS, 0x073C, 0x0354, 3, 0x07C0, 1, 0) -MX6_PAD_DECL(SD2_CLK__GPIO1_IO10, 0x073C, 0x0354, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CMD__SD2_CMD, 0x0740, 0x0358, 16, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_CMD__ECSPI5_MOSI, 0x0740, 0x0358, 1, 0x0830, 1, 0) -MX6_PAD_DECL(SD2_CMD__KEY_ROW5, 0x0740, 0x0358, 2, 0x08F4, 2, 0) -MX6_PAD_DECL(SD2_CMD__AUD4_RXC, 0x0740, 0x0358, 3, 0x07BC, 1, 0) -MX6_PAD_DECL(SD2_CMD__GPIO1_IO11, 0x0740, 0x0358, 5, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT3__SD2_DATA3, 0x0744, 0x035C, 0, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT3__ECSPI5_SS3, 0x0744, 0x035C, 1, 0x0000, 0, 0) -MX6_PAD_DECL(SD2_DAT3__KEY_COL6, 0x0744, 0x035C, 2, 0x08EC, 2, 0) -MX6_PAD_DECL(SD2_DAT3__AUD4_TXC, 0x0744, 0x035C, 3, 0x07C4, 1, 0) -MX6_PAD_DECL(SD2_DAT3__GPIO1_IO12, 0x0744, 0x035C, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__SD1_CLK, 0x0738, 0x0350, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__ECSPI5_SCLK, 0x0738, 0x0350, 1, 0x0828, 0, 0) +MX6_PAD_DECL(SD1_CLK__GPT_CLKIN, 0x0738, 0x0350, 3, 0x0000, 0, 0) +MX6_PAD_DECL(SD1_CLK__GPIO1_IO20, 0x0738, 0x0350, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CLK__SD2_CLK, 0x073C, 0x0354, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CLK__ECSPI5_SCLK, 0x073C, 0x0354, 1, 0x0828, 1, 0) +MX6_PAD_DECL(SD2_CLK__KEY_COL5, 0x073C, 0x0354, 2, 0x08E8, 3, 0) +MX6_PAD_DECL(SD2_CLK__AUD4_RXFS, 0x073C, 0x0354, 3, 0x07C0, 1, 0) +MX6_PAD_DECL(SD2_CLK__GPIO1_IO10, 0x073C, 0x0354, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__SD2_CMD, 0x0740, 0x0358, 16, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_CMD__ECSPI5_MOSI, 0x0740, 0x0358, 1, 0x0830, 1, 0) +MX6_PAD_DECL(SD2_CMD__KEY_ROW5, 0x0740, 0x0358, 2, 0x08F4, 2, 0) +MX6_PAD_DECL(SD2_CMD__AUD4_RXC, 0x0740, 0x0358, 3, 0x07BC, 1, 0) +MX6_PAD_DECL(SD2_CMD__GPIO1_IO11, 0x0740, 0x0358, 5, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__SD2_DATA3, 0x0744, 0x035C, 0, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__ECSPI5_SS3, 0x0744, 0x035C, 1, 0x0000, 0, 0) +MX6_PAD_DECL(SD2_DAT3__KEY_COL6, 0x0744, 0x035C, 2, 0x08EC, 2, 0) +MX6_PAD_DECL(SD2_DAT3__AUD4_TXC, 0x0744, 0x035C, 3, 0x07C4, 1, 0) +MX6_PAD_DECL(SD2_DAT3__GPIO1_IO12, 0x0744, 0x035C, 5, 0x0000, 0, 0) #endif /* __ASM_ARCH_MX6_MX6Q_PINS_H__ */
Eric Nelson
Stefano Babic
