[U-Boot] [RFC PATCH] kbuild: turn of dtc unit address warnings by default
DTC 1.4.2 or later checks DT unit-address without reg property and vice-versa, and generates lots of warnings. Fixing DT files will take for a while. Until then, let's turn off the check unless building with W=*.
Introduce a new helper dtc-option to check if the option is supported in order to suppress warnings on older versions.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
This is one possible answer to Tom's: https://www.mail-archive.com/u-boot@lists.denx.de/msg240328.html
He fixed the problem on travis-ci by commit a0f3e3d, but it is still annoying during the regular development. Perhaps we may want to hide the warnings (at least hidden in Linux Kernel by default). Or, is it better to keep it noisy to motivate people to fix their DT files? I am not quite sure...
Now I am sending this as RFC patch in case people may want to start discussion.
BTW, this is a counter-part of the patch I sent to the Kbuild sub-system (https://patchwork.kernel.org/patch/9592747/) because I want the U-Boot build system with Linux as much as possible. Let's see if I will get possible opinions in the Kbuild review.
Makefile | 2 +- scripts/Kbuild.include | 5 +++++ scripts/Makefile.extrawarn | 6 ++++++ 3 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 38b42da..b258de8 100644 --- a/Makefile +++ b/Makefile @@ -371,7 +371,7 @@ export ARCH CPU BOARD VENDOR SOC CPUDIR BOARDDIR export CONFIG_SHELL HOSTCC HOSTCFLAGS HOSTLDFLAGS CROSS_COMPILE AS LD CC export CPP AR NM LDR STRIP OBJCOPY OBJDUMP export MAKE AWK PERL PYTHON -export HOSTCXX HOSTCXXFLAGS DTC CHECK CHECKFLAGS +export HOSTCXX HOSTCXXFLAGS CHECK CHECKFLAGS DTC DTC_FLAGS
export KBUILD_CPPFLAGS NOSTDINC_FLAGS UBOOTINCLUDE OBJCOPYFLAGS LDFLAGS export KBUILD_CFLAGS KBUILD_AFLAGS diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 30e6e31..1b62aed 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -172,6 +172,11 @@ ld-version = $(shell $(LD) --version | $(srctree)/scripts/ld-version.sh) # Usage: $(call ld-ifversion, -ge, 22252, y) ld-ifversion = $(shell [ $(ld-version) $(1) $(2) ] && echo $(3) || echo $(4))
+# dtc-option +# Usage: DTC_FLAGS += $(call dtc-option,-Wno-unit_address_vs_reg) +dtc-option = $(call try-run,\ + echo '/dts-v1/; / {};' | $(DTC) $(1),$(1),$(2)) + ######
### diff --git a/scripts/Makefile.extrawarn b/scripts/Makefile.extrawarn index 6547e57..7b2cffc 100644 --- a/scripts/Makefile.extrawarn +++ b/scripts/Makefile.extrawarn @@ -57,4 +57,10 @@ ifeq ("$(strip $(warning))","") endif
KBUILD_CFLAGS += $(warning) + +else + +# Disable noisy checks by default +DTC_FLAGS += $(call dtc-option,-Wno-unit_address_vs_reg) + endif
On 26 February 2017 at 23:24, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Seems like a good idea to me, at least until more are converted.
On Mon, Feb 27, 2017 at 2:24 PM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Tested-by: Bin Meng bmeng.cn@gmail.com
2017-02-27 15:24 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
I sent a similar patch for Linux, but the response was negative in the Kbuild subsystem.
So, this patch will be our own, if applied.
I think the necessity for this patch comes down to how long we expect for fixing DT files.
The only difficulty is in our basic rule: Send patches to Linux first, then import DT to U-Boot.
Without this, fixing the warnings would be pretty easy...
I think we should be proactive here and take this patch. Newer dtc will be seen more widely I believe as various overlay related changes go in upstream. Do you have anything you would change in a v2 non-RFC?
I guess I would suggest that for the DT files we really own, we should update them. Otherwise, just make the warnings happen in the kernel and correct them and upstream them there. Thanks!
Hi Tom,
2017-03-08 3:10 GMT+09:00 Tom Rini trini@konsulko.com:
No more update. If you like this patch, please feel free to take it.
For reference they updated the kernel included dtc to upstream commit 0931cea3ba20 in 4.11 for overlay support [1] so I similarly updated the Fedora dtc to the same revision for consistency so I think this is a pragmatic approach.
Peter
[1] http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=6f...
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Bin Meng bmeng.cn@gmail.com
participants (5)
Bin Meng
Masahiro Yamada
Peter Robinson
