[U-Boot] [PATCH 0/2] ARM: davinci: omapl138_lcdk: fix MMC/SD boot breakage.
Here is a set of patches that fixes MMC/SD boot breakage introduced after 2018.09 release.
This was tested with MMC/SD boot on OMAP-L138 LCDK. I still need to do SPI and NAND boot on this board.
Thanks, Sekhar
Sekhar Nori (2): ARM: davinci: omal138_lcdk: fix MMC boot breakage due to driver model conversion ARM: davinci: SPL: fix BSS initialization
arch/arm/mach-davinci/spl.c | 6 +++++- board/davinci/da8xxevm/omapl138_lcdk.c | 2 +- 2 files changed, 6 insertions(+), 2 deletions(-)
commit 21af33ed0319 ("ARM: davinci: omapl138_lcdk: Enable DM_MMC") wanted to enable DM_MMC only for U-Boot and not for SPL.
But CONFIG_DM_MMC is defined for SPL build too. Because of this MMC device was not getting registered for SPL causing MMC/SD boot breakage.
Instead use CONFIG_IS_ENABLED(DM_MMC) which will remain false until CONFIG_SPL_DM_MMC is defined.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- board/davinci/da8xxevm/omapl138_lcdk.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 2c2f885d43e4..fe1bf4410145 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -353,7 +353,7 @@ int misc_init_r(void) return 0; }
-#ifndef CONFIG_DM_MMC +#if !CONFIG_IS_ENABLED(DM_MMC) #ifdef CONFIG_MMC_DAVINCI static struct davinci_mmc mmc_sd0 = { .reg_base = (struct davinci_mmc_regs *)DAVINCI_MMC_SD0_BASE,
Tested-by: Peter Howard phoward@gme.net.au
U-Boot README recommends initializing SDRAM in board_init_f(). DA850 was doing it as part of board_init_r() (through call to spl_board_init() which calls arch_cpu_init() which calls da850_ddr_setup())
This worked fine till commit 15b8c7505819 ("davinci: da850evm/omapl138-lcdk: Move BSS to SDRAM because SRAM is full") moved BSS to SDRAM.
Functions like mmc_initialize() called in board_init_r() assume BSS is available. Since SDRAM was not initialized when arch/arm/lib/crt0.S tried to initialize BSS to 0, BSS is not initialized correctly.
Fix this by simply calling arch_cpu_init() from board_init_f(). Since the README recommends calling preloader_console_init() from spl_board_init(), we keep it as-it-is.
Tested using MMC/SD boot on OMAP-L138 LCDK board.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- arch/arm/mach-davinci/spl.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-davinci/spl.c b/arch/arm/mach-davinci/spl.c index 103639e34757..117b5ee836f8 100644 --- a/arch/arm/mach-davinci/spl.c +++ b/arch/arm/mach-davinci/spl.c @@ -33,10 +33,14 @@ void putc(char c)
void spl_board_init(void) { - arch_cpu_init(); preloader_console_init(); }
+void board_init_f(ulong dummy) +{ + arch_cpu_init(); +} + u32 spl_boot_device(void) { switch (davinci_syscfg_regs->bootcfg) {
The README also states preloader_console_init() can get called from board_init_f(). Doing this enables for debugging of board_init_r
arch_cpu_init();
What about a reference to board_early_init_f()? Looking at other boards, it appears that we should call that here. Both the LCDK and da850 evm have the function enabled to configure the DSP.
adam
u32 spl_boot_device(void) { switch (davinci_syscfg_regs->bootcfg) { -- 2.16.2
Okay, I can change it. spl_board_init() will be empty so I will turn off CONFIG_SPL_BOARD_INIT also.
I was put off by README saying "preloader_console_init() can be called here in extremis" which I meant as saying it should be rare to do that.
Debugging board_init_r() should be pretty useful, so perhaps the wording there should be more easy.
arch_cpu_init();
This is only needed at U-Boot stage, right? Looks like it will be called because CONFIG_BOARD_EARLY_INIT_F is enabled.
Thanks, Sekhar
At least for the da850evm which uses the device tree, you'll need to call spl_early_init() before the preloader_console_init() in order for the UART to work correctly and debug board_init_r.
arch_cpu_init();
That is my understanding.
Thanks for being flexible on this. Sorry I broke the lcdk, but I'm willing to help modernize it as well (ie, help support SPL_OF_CONTROL) if someone can get me a board. The general trend is to try and support these newer DM functions and remove the old legacy code functions.
adam
Thanks, Sekhar
arch_cpu_init();
Alright, so I wont do anything about board_early_init_f() in this series.
Sure, working on getting a board!
A lot of modernization of DA850 support has been due to your attention on the EVM. Its much appreciated :)
Regards, Sekhar
diff --git a/arch/arm/mach-davinci/spl.c b/arch/arm/mach- davinci/spl.c index 103639e34757..117b5ee836f8 100644 --- a/arch/arm/mach-davinci/spl.c +++ b/arch/arm/mach-davinci/spl.c @@ -33,10 +33,14 @@ void putc(char c)
- arch_cpu_init();
Hi Sekhar
I have tested NAND boot with the two patches and it seems to work fine. I can confirm MMC boot (at least on the original LCDK)
The original LCDK didn't have SPI NAND - has that changed with the latest board?
Thanks, Sekhar
On 22/05/19 5:07 AM, Peter Howard wrote:
Hi Sekhar
Just checked - nope, no SPI flash on LCDK. I was speaking from (wrong) memory there!
Thanks for the testing!
Thanks, Sekhar
Adam Ford
Peter Howard
Sekhar Nori
