[U-Boot] [GIT PULL] AVR32: NGW100 fix for 2009.08
Hi Wolfgang,
Please pull
git://git.denx.de/u-boot-avr32.git master
to receive the following fix for a fairly longstanding and annoying ATNGW100 bug.
Haavard Skinnemoen (1): atngw100: Use virtual address in CONFIG_ENV_ADDR
include/configs/atngw100.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
Dear Haavard Skinnemoen,
In message 20090828105050.0ddb0a53@hskinnemoen-d830 you wrote:
Please pull
I'm unsure what to do about that. I understand this patch is needed to get the system working at all, untill we find a permanent solution. Right?
So you want me to apply this even though we agree it's not a nice chance?
Please pull
Yeah...I'm unsure myself. The system will boot, but the 'saveenv' command doesn't work...so while I really want to fix this issue _properly_, I'm not sure if there's enough time to do that before the next release.
If the 2009.08 release is around the corner, I would appreciate if you applied it before making the release.
Haavard
On Sun, 30 Aug 2009 22:45:27 +0200 Haavard Skinnemoen haavard.skinnemoen@atmel.com wrote:
Please pull
Did you test loading something from JFFS2? I have a bad feeling it might still be broken.
<snipp>
Right. Does anyone have any clue about why it's broken?
Haavard
On Mon, 31 Aug 2009 09:44:40 +0200 Haavard Skinnemoen haavard.skinnemoen@atmel.com wrote:
Trying to do ls just hangs the bootloader.
U-Boot> ls Scanning JFFS2 FS:
I did not dig into the code, but I think the discussion about the same topic this winter/spring saw the same behavior.
Haavard Skinnemoen
