[U-Boot] [GIT PULL] u-boot-uniphier/master
Hi Tom,
Please pull UniPhier updates + Kconfig warning fix.
Thanks.
The following changes since commit 323a73adc9a1bf2de43fe03bdd9c3038ce7c2784:
mtd: nand: add new enum for storing ECC algorithm (2018-07-23 14:33:21 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 7ef5b1e7ed040683ff551f0234c471ce0d76828c:
ARM: uniphier: enable distro boot (2018-07-25 08:47:53 +0900)
---------------------------------------------------------------- Luis Araneda (1): kconfig: Avoid format overflow warning from GCC 8.1
Masahiro Yamada (8): mtd: nand: denali: correct buffer alignment for DMA transfer fdt_support: make fdt_fixup_mtdparts() prototype more specific board: constify struct node_info array ARM: uniphier: clean-up ft_board_setup() ARM: uniphier: split ft_board_setup() out to a separate file ARM: uniphier: support fdt_fixup_mtdparts ARM: uniphier: enable MTD partition and UBI ARM: uniphier: enable distro boot
arch/arm/Kconfig | 2 + arch/arm/mach-uniphier/Kconfig | 1 - arch/arm/mach-uniphier/Makefile | 1 + arch/arm/mach-uniphier/board_late_init.c | 8 +-- arch/arm/mach-uniphier/dram_init.c | 35 --------- arch/arm/mach-uniphier/fdt-fixup.c | 64 +++++++++++++++++ board/CarMediaLab/flea3/flea3.c | 2 +- board/compulab/cm_fx6/cm_fx6.c | 2 +- board/freescale/bsc9131rdb/bsc9131rdb.c | 2 +- board/freescale/bsc9132qds/bsc9132qds.c | 2 +- board/gateworks/gw_ventana/gw_ventana.c | 2 +- board/isee/igep003x/board.c | 2 +- board/isee/igep00x0/igep00x0.c | 2 +- board/toradex/colibri_imx7/colibri_imx7.c | 2 +- board/toradex/colibri_vf/colibri_vf.c | 2 +- common/fdt_support.c | 13 ++-- configs/uniphier_ld4_sld8_defconfig | 6 +- configs/uniphier_v7_defconfig | 6 +- configs/uniphier_v8_defconfig | 5 +- doc/README.uniphier | 55 ++++++++++++++ drivers/mtd/nand/denali.c | 2 +- include/configs/uniphier.h | 84 +++++++++++----------- include/fdt_support.h | 11 ++- scripts/kconfig/confdata.c | 2 +- 24 files changed, 206 insertions(+), 107 deletions(-) create mode 100644 arch/arm/mach-uniphier/fdt-fixup.c
On Wed, Jul 25, 2018 at 08:52:40AM +0900, Masahiro Yamada wrote:
Hi Tom,
Thanks.
Masahiro Yamada
