Re: [PATCH v2 11/11] net: dwc_eth_qos: Add support for st, ext-phyclk property
-----Original Message----- From: Marek Vasutmarex@denx.de Sent: Tuesday, March 26, 2024 1:08 PM To:u-boot@lists.denx.de Cc: Marek Vasutmarex@denx.de; Christophe ROULLIERchristophe.roullier@st.com; Joe Hershbergerjoe.hershberger@ni.com; Patrice CHOTARD - fosspatrice.chotard@foss.st.com; Patrick DELAUNAY - fosspatrick.delaunay@foss.st.com; Ramon Friedrfried.dev@gmail.com;u-boot@dh-electronics.com;uboot-stm32@st-md-mailman.stormreply.com Subject: [PATCH v2 11/11] net: dwc_eth_qos: Add support for st,ext-phyclk property
The "st,ext-phyclk" property is a unification of "st,eth-clk-sel" and "st,eth-ref-clk-sel" properties. All three properties define ETH CK clock direction, however:
- "st,eth-clk-sel" selects clock direction for GMII/RGMII mode
- "st,eth-ref-clk-sel" selects clock direction for RMII mode
- "st,ext-phyclk" selects clock direction for all RMII/GMII/RGMII modes The "st,ext-phyclk" is the preferrable property to use.
Signed-off-by: Marek Vasutmarex@denx.de
Cc: Christophe Roullierchristophe.roullier@st.com Cc: Joe Hershbergerjoe.hershberger@ni.com Cc: Patrice Chotardpatrice.chotard@foss.st.com Cc: Patrick Delaunaypatrick.delaunay@foss.st.com Cc: Ramon Friedrfried.dev@gmail.com Cc:u-boot@dh-electronics.com Cc:uboot-stm32@st-md-mailman.stormreply.com
V2: New patch
drivers/net/dwc_eth_qos_stm32.c | 30 +++++++++++++++++++++++++++--- 1 file changed, 27 insertions(+), 3 deletions(-)
diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index 435473f99a6..9ee82b54c62 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -140,6 +140,8 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, const bool is_mp13 = device_is_compatible(dev, "st,stm32mp13-dwmac"); /* Gigabit Ethernet 125MHz clock selection. */ const bool eth_clk_sel = dev_read_bool(dev, "st,eth-clk-sel");
/* Ethernet clock source is RCC. */
const bool ext_phyclk = dev_read_bool(dev, "st,ext-phyclk"); struct regmap *regmap; u32 regmap_mask; u32 value;
@@ -156,6 +158,12 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, dev_dbg(dev, "PHY_INTERFACE_MODE_MII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII);
* STM32MP15xx supports both MII and GMII, STM32MP13xx MII only.
* SYSCFG_PMCSETR ETH_SELMII is present only on STM32MP15xx and
* acts as a selector between 0:GMII and 1:MII. As STM32MP13xx
* supports only MII, ETH_SELMII is not present.
*/ if (!is_mp13) /* Select MII mode on STM32MP15xx */ value |= SYSCFG_PMCSETR_ETH_SELMII; break;
@@ -163,14 +171,25 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, dev_dbg(dev, "PHY_INTERFACE_MODE_GMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII);
if (eth_clk_sel)
* If eth_clk_sel is set, use internal ETH_CLKx clock from RCC,
* otherwise use external clock from IO pin (requires matching
* GPIO block AF setting of that pin).
if (eth_clk_sel || ext_phyclk) value |= SYSCFG_PMCSETR_ETH_CLK_SEL; break; case PHY_INTERFACE_MODE_RMII: dev_dbg(dev, "PHY_INTERFACE_MODE_RMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RMII);
if (eth_ref_clk_sel)
* If eth_ref_clk_sel is set, use internal clock from RCC,
* otherwise use external clock from ETHn_RX_CLK/ETHn_REF_CLK
* IO pin (requires matching GPIO block AF setting of that
* pin).
if (eth_ref_clk_sel || ext_phyclk) value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL; break; case PHY_INTERFACE_MODE_RGMII:
@@ -180,7 +199,12 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, dev_dbg(dev, "PHY_INTERFACE_MODE_RGMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RGMII);
if (eth_clk_sel)
* otherwise use external clock from ETHx_CLK125 pin (requires
* matching GPIO block AF setting of that pin).
if (eth_clk_sel || ext_phyclk) value |= SYSCFG_PMCSETR_ETH_CLK_SEL; break; default:
-- 2.43.0
Reviewed-by: Christophe ROULLIER christophe.roullier@foss.st.com
V2: New patch
diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index 435473f99a6..9ee82b54c62 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -140,6 +140,8 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, const bool is_mp13 = device_is_compatible(dev, "st,stm32mp13-dwmac"); /* Gigabit Ethernet 125MHz clock selection. */ const bool eth_clk_sel = dev_read_bool(dev, "st,eth-clk-sel"); + /* Ethernet clock source is RCC. */ + const bool ext_phyclk = dev_read_bool(dev, "st,ext-phyclk"); struct regmap *regmap; u32 regmap_mask; u32 value; @@ -156,6 +158,12 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, dev_dbg(dev, "PHY_INTERFACE_MODE_MII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); + /* + * STM32MP15xx supports both MII and GMII, STM32MP13xx MII only. + * SYSCFG_PMCSETR ETH_SELMII is present only on STM32MP15xx and + * acts as a selector between 0:GMII and 1:MII. As STM32MP13xx + * supports only MII, ETH_SELMII is not present. + */ if (!is_mp13) /* Select MII mode on STM32MP15xx */ value |= SYSCFG_PMCSETR_ETH_SELMII; break; @@ -163,14 +171,25 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, dev_dbg(dev, "PHY_INTERFACE_MODE_GMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); - if (eth_clk_sel) + /* + * If eth_clk_sel is set, use internal ETH_CLKx clock from RCC, + * otherwise use external clock from IO pin (requires matching + * GPIO block AF setting of that pin). + */ + if (eth_clk_sel || ext_phyclk) value |= SYSCFG_PMCSETR_ETH_CLK_SEL; break; case PHY_INTERFACE_MODE_RMII: dev_dbg(dev, "PHY_INTERFACE_MODE_RMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RMII); - if (eth_ref_clk_sel) + /* + * If eth_ref_clk_sel is set, use internal clock from RCC, + * otherwise use external clock from ETHn_RX_CLK/ETHn_REF_CLK + * IO pin (requires matching GPIO block AF setting of that + * pin). + */ + if (eth_ref_clk_sel || ext_phyclk) value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL; break; case PHY_INTERFACE_MODE_RGMII: @@ -180,7 +199,12 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, dev_dbg(dev, "PHY_INTERFACE_MODE_RGMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_RGMII); - if (eth_clk_sel) + /* + * If eth_clk_sel is set, use internal ETH_CLKx clock from RCC, + * otherwise use external clock from ETHx_CLK125 pin (requires + * matching GPIO block AF setting of that pin). + */ + if (eth_clk_sel || ext_phyclk) value |= SYSCFG_PMCSETR_ETH_CLK_SEL; break; default: -- 2.43.0
Applied on u-boot-stm32/master
Christophe ROULLIER
Patrice CHOTARD
