[U-Boot] [STATUS] v2010.03-rc2 is out
U-Boot v2010.03-rc2 has been released.
Summary status (as far as I know so far):
- PowerPC:
Looks mostly acceptable; main issues are with all the boards using Marvell 64260 (EVB64260, P3G4, ZUMA, ...) plus the "ml300" board, which is 1) seriously broken and 2) unmaintained.
If somebody cares about the "ml300" board then please submit patches _now_, or I'll remove the code for this board.
It seems to me that nobody is interested in 64260 support any more, to, so I guess we should remove these boards, too. Comments (or patches) ?
- ARM:
A few boards are broken or produce tons of warnings: otc570, suen3, a320evb, etc. Fixes welcome / needed.
- MIPS:
looks good.
ARM:
Nomadik nhk8815 is broken as the timer fix is still missing (nand write doesn't work reliably, for example saveenv). Shall I repost "Nomadik: fix reset_timer()" ?
Also, but this is less important, I don't understand what's the status of the other patches sent months ago.
This is, as a reminder, my sequence from master, in the order they are applied (log --reverse). The first one is in the video queue, but for the others i don't know.
9cbed53... lcd: make 16bpp work 6a02362... Nomadik: fix reset_timer() 9df8630... nhk8815: change the order of initialization 45e9c21... drivers/misc: add stmpe2401 port extender and keypad controller cb55d95... nhk8815.h: define we need stmpe 43619fe... nhk8815: added keypad 0f31f00... nhk8815: start lower in RAM, so the 800x480 frame buffer fits 9112252... nhk8815: added lcd support
Thanks a lot for you patience.
/alessandro
Dear Alessandro Rubini,
In message 20100324075120.GA20099@morgana.gnudd.com you wrote:
ARM:
Tom, do you have this patch in your queue? It should go in _now_.
Good question.
Tom, can you please comment on the state of these patches (and any other ARM patches you might have queued):
Thanks.
Alessandro Rubini
Mike Frysinger
