[PATCH] ARM: dts: imx8mq-evk: Remove u-boot,off-on-delay-us property
Commit 247bbeb74c18 ("ARM: dts: imx8m: increase off-on delay on the SD Vcc regulator") caused the imx8mq-evk board to not be able to store the environment variables in the SD card.
Remove the u-boot,off-on-delay-us property to fix the regression.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/imx8mq-evk-u-boot.dtsi | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/arch/arm/dts/imx8mq-evk-u-boot.dtsi b/arch/arm/dts/imx8mq-evk-u-boot.dtsi index 44af66372712..2cfc12b7e0a4 100644 --- a/arch/arm/dts/imx8mq-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-evk-u-boot.dtsi @@ -1,9 +1,5 @@ // SPDX-License-Identifier: (GPL-2.0 OR MIT)
-®_usdhc2_vmmc { - u-boot,off-on-delay-us = <20000>; -}; - &usdhc1 { mmc-hs400-1_8v; };
Hello Fabio,
Thanks for taking care of this!
I believe this fix still applies to mx8m mini series, as without it - some SD Cards are failed to be recognized.
-----Original Message----- From: Fabio Estevam festevam@gmail.com Sent: Monday, February 22, 2021 6:41 PM To: sbabic@denx.de Cc: u-boot@lists.denx.de; trini trini@konsulko.com; lorusak@gmail.com; ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com; peng.fan@nxp.com; Fabio Estevam festevam@gmail.com Subject: [PATCH] ARM: dts: imx8mq-evk: Remove u-boot,off-on-delay-us property
diff --git a/arch/arm/dts/imx8mq-evk-u-boot.dtsi b/arch/arm/dts/imx8mq-evk- u-boot.dtsi index 44af66372712..2cfc12b7e0a4 100644 --- a/arch/arm/dts/imx8mq-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-evk-u-boot.dtsi @@ -1,9 +1,5 @@ // SPDX-License-Identifier: (GPL-2.0 OR MIT)
-®_usdhc2_vmmc {
&usdhc1 { mmc-hs400-1_8v; }; -- 2.25.1
Reviewed-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com
Hi Fabio,
It is board dependent, some board may has a big capacitance, the off-on-delay is to give enough time for the capacitance to leak its voltage.
Regards, Peng.
-®_usdhc2_vmmc {
Hi Peng,
Ok, but not clear from your comment if you agree with my change or not.
Please clarify.
Subject: Re: [PATCH] ARM: dts: imx8mq-evk: Remove u-boot,off-on-delay-us property
Hi Peng,
I think remove it is not correct, the exact time should be measured using oscilloscope, removing it might make sd3.0 not work. But anyway 20000 seems too large a value.
Regards, Peng.
Please clarify.
Do you plan to submit a fix for this then? If you don't have the bandwidth for working on this, then we could go with my proposal.
I would like to be able to boot a kernel from the SD card in the 2021.04 release and fix the regression.
Also, why don't we have such property in the imx8mq-evk.dts in the kernel?
I don't think U-Boot dts should deviate from the Linux devicetree in this aspect.
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: 2021年2月23日 10:11 To: Peng Fan peng.fan@nxp.com Cc: sbabic@denx.de; u-boot@lists.denx.de; trini@konsulko.com; lorusak@gmail.com; andrey.zhizhikin@leica-geosystems.com Subject: Re: [PATCH] ARM: dts: imx8mq-evk: Remove u-boot,off-on-delay-us property
See https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dt...
NXP vendor tree has off-on-delay-us.
Regards Peng.
Ok, but are you able to determine the appropriate off-on-delay-us for imx8mq-evk in U-Boot to avoid the existing regression?
Commit 247bbeb74c18 ("ARM: dts: imx8m: increase off-on delay on the SD Vcc regulator") caused the imx8mq-evk board to not be able to store the environment variables in the SD card. Remove the u-boot,off-on-delay-us property to fix the regression. Signed-off-by: Fabio Estevam festevam@gmail.com Reviewed-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com
Best regards, Stefano Babic
participants (5)
Fabio Estevam
Peng Fan
Peng Fan (OSS)
sbabic@denx.de
ZHIZHIKIN Andrey
