Pull request: u-boot-sunxi/master for 2025.01
Hi Tom,
please pull the first sunxi changes for this cycle:
This switches all boards with the Allwinner H616/H618/H313/H700 SoCs over to use OF_UPSTREAM. We are doing it for this SoC family only since the DTs between the U-Boot and the kernel repo are exactly identical, whereas other families have one compatibility fix in U-Boot to allow booting older kernels. Other will follow if this plays out well.
The biggest chunk otherwise is adding support for an Anbernic game console, using the H700 SoC. For that we need to enhance the DRAM support code, and pick two DT commits from the mainline kernel/DT rebasing repo, followed by the defconfig patch.
On top of that two small fixes for the old Allwinner A80.
Gitlab CI passed, and I booted that briefly on some boards, including an H616 and an H618 one (with LPDDR4).
Thanks, Andre
=========================================================== The following changes since commit f8efc68b30e29360f7a419fe4968432179d7368b:
Merge patch series "spi-nor: Add parallel and stacked memories support" (2024-10-09 09:02:22 -0600)
https://source.denx.de/u-boot/custodians/u-boot-sunxi.git master
for you to fetch changes up to 2f7ab49644ed38b6e3fe5eb6cd3f7e3f683fc6a7:
sunxi: Add support for Anbernic RG35XX-2024 (2024-10-10 00:43:51 +0100)
---------------------------------------------------------------- Andre Przywara (3): sunxi: H616: switch to OF_UPSTREAM clk: sunxi: a80: Fix reset description sunxi: power: axp809: Fix DCDC4 programming
Chris Morgan (4): sunxi: H616: DRAM: Add alternative pin mapping arm64: dts: allwinner: h616: Change RG35XX Series from r_rsb to r_i2c arm64: dts: allwinner: h616: Add r_i2c pinctrl nodes sunxi: Add support for Anbernic RG35XX-2024
Jernej Skrabec (4): sunxi: H616: dram: LPDDR4: adjust settings sunxi: H616: DRAM: Adjust configuration procedure sunxi: H616: DRAM: Adjust size scan procedure sunxi: H616: dram: Update mbus priorities
arch/arm/dts/Makefile | 7 - arch/arm/dts/sun50i-h313-tanix-tx1.dts | 183 ---- arch/arm/dts/sun50i-h616-bigtreetech-cb1-manta.dts | 35 - arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi | 143 ---- arch/arm/dts/sun50i-h616-bigtreetech-pi.dts | 63 -- arch/arm/dts/sun50i-h616-cpu-opp.dtsi | 115 --- arch/arm/dts/sun50i-h616-orangepi-zero.dtsi | 131 --- arch/arm/dts/sun50i-h616-orangepi-zero2.dts | 145 ---- arch/arm/dts/sun50i-h616-x96-mate.dts | 207 ----- arch/arm/dts/sun50i-h616.dtsi | 930 --------------------- arch/arm/dts/sun50i-h618-longan-module-3h.dtsi | 80 -- arch/arm/dts/sun50i-h618-longanpi-3h.dts | 144 ---- arch/arm/dts/sun50i-h618-orangepi-zero2w.dts | 181 ---- arch/arm/dts/sun50i-h618-orangepi-zero3.dts | 101 --- arch/arm/dts/sun50i-h618-transpeed-8k618-t.dts | 189 ----- arch/arm/dts/sun50i-h700-anbernic-rg35xx-2024.dts | 327 -------- arch/arm/dts/sun50i-h700-anbernic-rg35xx-h.dts | 36 - arch/arm/dts/sun50i-h700-anbernic-rg35xx-plus.dts | 53 -- arch/arm/mach-sunxi/Kconfig | 18 + arch/arm/mach-sunxi/dram_sun50i_h616.c | 137 ++- .../arm/mach-sunxi/dram_timings/h616_lpddr4_2133.c | 2 +- board/sunxi/MAINTAINERS | 5 + configs/anbernic_rg35xx_h700_defconfig | 27 + configs/orangepi_zero2_defconfig | 2 +- configs/orangepi_zero2w_defconfig | 2 +- configs/orangepi_zero3_defconfig | 2 +- configs/tanix_tx1_defconfig | 2 +- configs/transpeed-8k618-t_defconfig | 2 +- configs/x96_mate_defconfig | 2 +- drivers/clk/sunxi/clk_a80.c | 8 +- drivers/power/axp809.c | 2 +- dts/upstream/src/arm64/allwinner/sun50i-h616.dtsi | 2 + .../allwinner/sun50i-h700-anbernic-rg35xx-2024.dts | 6 +- include/dt-bindings/clock/sun50i-h616-ccu.h | 116 --- include/dt-bindings/reset/sun50i-h616-ccu.h | 70 -- 35 files changed, 159 insertions(+), 3316 deletions(-) delete mode 100644 arch/arm/dts/sun50i-h313-tanix-tx1.dts delete mode 100644 arch/arm/dts/sun50i-h616-bigtreetech-cb1-manta.dts delete mode 100644 arch/arm/dts/sun50i-h616-bigtreetech-cb1.dtsi delete mode 100644 arch/arm/dts/sun50i-h616-bigtreetech-pi.dts delete mode 100644 arch/arm/dts/sun50i-h616-cpu-opp.dtsi delete mode 100644 arch/arm/dts/sun50i-h616-orangepi-zero.dtsi delete mode 100644 arch/arm/dts/sun50i-h616-orangepi-zero2.dts delete mode 100644 arch/arm/dts/sun50i-h616-x96-mate.dts delete mode 100644 arch/arm/dts/sun50i-h616.dtsi delete mode 100644 arch/arm/dts/sun50i-h618-longan-module-3h.dtsi delete mode 100644 arch/arm/dts/sun50i-h618-longanpi-3h.dts delete mode 100644 arch/arm/dts/sun50i-h618-orangepi-zero2w.dts delete mode 100644 arch/arm/dts/sun50i-h618-orangepi-zero3.dts delete mode 100644 arch/arm/dts/sun50i-h618-transpeed-8k618-t.dts delete mode 100644 arch/arm/dts/sun50i-h700-anbernic-rg35xx-2024.dts delete mode 100644 arch/arm/dts/sun50i-h700-anbernic-rg35xx-h.dts delete mode 100644 arch/arm/dts/sun50i-h700-anbernic-rg35xx-plus.dts create mode 100644 configs/anbernic_rg35xx_h700_defconfig delete mode 100644 include/dt-bindings/clock/sun50i-h616-ccu.h delete mode 100644 include/dt-bindings/reset/sun50i-h616-ccu.h
On Mon, Oct 14, 2024 at 12:45:31AM +0100, Andre Przywara wrote:
Hi Tom,
Thanks, Andre
Andre Przywara
