[U-Boot] [PATCH] mx31: Setup AIPS registers
Setup mx31 AIPS registers.
It was verified on a mx31pdk that without the AIPS settings it is not possible to run audio playback.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm1136/mx31/generic.c | 40 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx31/imx-regs.h | 13 +++++++++ 2 files changed, 53 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx31/generic.c b/arch/arm/cpu/arm1136/mx31/generic.c index d60afc9..cc2e3d5 100644 --- a/arch/arm/cpu/arm1136/mx31/generic.c +++ b/arch/arm/cpu/arm1136/mx31/generic.c @@ -228,3 +228,43 @@ int print_cpuinfo(void) return 0; } #endif + +void init_aips(void) +{ + struct aipstz_regs *aips1, *aips2; + + aips1 = (struct aipstz_regs *)MX31_AIPS1_BASE_ADDR; + aips2 = (struct aipstz_regs *)MX31_AIPS2_BASE_ADDR; + + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + writel(0x77777777, &aips1->mprot0); + writel(0x77777777, &aips1->mprot1); + writel(0x77777777, &aips2->mprot0); + writel(0x77777777, &aips2->mprot1); + + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips1->opacr0); + writel(0x00000000, &aips1->opacr1); + writel(0x00000000, &aips1->opacr2); + writel(0x00000000, &aips1->opacr3); + writel(0x00000000, &aips1->opacr4); + writel(0x00000000, &aips2->opacr0); + writel(0x00000000, &aips2->opacr1); + writel(0x00000000, &aips2->opacr2); + writel(0x00000000, &aips2->opacr3); + writel(0x00000000, &aips2->opacr4); +} + +int arch_cpu_init(void) +{ + init_aips(); + + return 0; +} diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h index 6454acb..11069af 100644 --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -539,6 +539,18 @@ struct esdc_regs { u32 dlyl; };
+/* AIPS registers */ +struct aipstz_regs { + u32 mprot0; + u32 mprot1; + u32 rsvd[0xe]; + u32 opacr0; + u32 opacr1; + u32 opacr2; + u32 opacr3; + u32 opacr4; +}; + #endif
#define __REG(x) (*((volatile u32 *)(x))) @@ -873,6 +885,7 @@ struct esdc_regs { #define IRAM_SIZE (16 * 1024)
#define MX31_AIPS1_BASE_ADDR 0x43f00000 +#define MX31_AIPS2_BASE_ADDR 0x53f00000 #define IMX_USB_BASE (MX31_AIPS1_BASE_ADDR + 0x88000)
/* USB portsc */
Stefano,
Please ignore this version. Will need to fix it and post a v2.
Am 29/02/2012 18:05, schrieb Fabio Estevam:
Stefano,
Ok, understood.
Stefano
Fabio Estevam
stefano babic
