[U-Boot] [PATCH RESEND] phy: atheros: add support for RGMII_ID, RGMII_TXID and RGMII_RXID
This adds support for internal delay on RX and TX on RGMII interface for the AR8035 phy.
This is basically the same Linux driver do. Tested on a Zynq Zturn board (for which u-boot support in is my tree; first patch waiting ML approval)
Signed-off-by: Andrea Merello andrea.merello@gmail.com
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index e57c412..694a338 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -31,6 +31,22 @@ static int ar8035_config(struct phy_device *phydev) regval = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, (regval|0x0100));
+ if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) { + /* select debug reg 5 */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1D, 0x5); + /* enable tx delay */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x0100); + } + + if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) { + /* select debug reg 0 */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1D, 0x0); + /* enable rx delay */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x8000); + } + phydev->supported = phydev->drv->features;
genphy_config_aneg(phydev); -- 2.1.4
Reviewed-by: Marek Vasut marex@denx.de Acked-by: Marek Vasut marex@denx.de
Can we get this applied ? Thanks
-- 2.1.4 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
This is assigned to Michal in patchwork, so at least someone thinks that's the correct path. I'm good either way.
-Joe
Well that doesn't make any sense, so please pick it.
Probably was done because it mentions it's for a Zynq board. Sure would be nice if patchwork listed a history of who changed what fields.
-Joe
I would rather avoid fingerpointing, but probably Tom, he's the one doing the hard work of reassigning patches and is alone at it I think. Thus, accidents can happen.
I also assign some, mostly unassigned and pertaining to me. I certainly try to not take patches assigned to others when there's any doubt in case they are in progress. I'm not interested in finger-pointing so much as knowing who to ask about the assignment.
-Joe
On 05/26/2016 06:24 PM, Andrea Merello wrote: > This adds support for internal delay on RX and TX on RGMII interface for the > AR8035 phy. > > This is basically the same Linux driver do. Tested on a Zynq Zturn board (for > which u-boot support in is my tree; first patch waiting ML approval) > > Signed-off-by: Andrea Merello andrea.merello@gmail.com
Joe: :-) Definitely take it via your tree.
Thanks, Michal
On Thu, May 26, 2016 at 11:24 AM, Andrea Merello andrea.merello@gmail.com wrote:
participants (5)
Andrea Merello
Joe Hershberger
Joe Hershberger
Michal Simek
