[U-Boot] [POWERPC] mgcoge, mgsuvd: cleanups
mgcoge: Second Flash on CS5 use in_*/out_* accessors mgsuvd: fix Codingstyle issues use in_*/out_* accessors
Signed-off-by: Heiko Schocher hs@denx.de ---
This Patch replaces the Patches:
http://lists.denx.de/pipermail/u-boot/2008-October/041881.html [U-Boot] [POWERPC] mgcoge: correct init of the UPIOx
http://lists.denx.de/pipermail/u-boot/2008-October/041892.html [U-Boot] [POWERPC] mgcoge: Second Flash on CS5 not on CS1
board/keymile/mgcoge/mgcoge.c | 9 +++-- board/keymile/mgsuvd/mgsuvd.c | 73 ++++++++++++++++++---------------------- 2 files changed, 39 insertions(+), 43 deletions(-)
diff --git a/board/keymile/mgcoge/mgcoge.c b/board/keymile/mgcoge/mgcoge.c index 7d4d9e6..9c6039d 100644 --- a/board/keymile/mgcoge/mgcoge.c +++ b/board/keymile/mgcoge/mgcoge.c @@ -25,6 +25,7 @@ #include <mpc8260.h> #include <ioports.h> #include <malloc.h> +#include <asm/io.h>
#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) #include <libfdt.h> @@ -295,8 +296,10 @@ int checkboard(void) int board_early_init_r (void) { /* setup the UPIOx */ - *(char *)(CONFIG_SYS_PIGGY_BASE + 0x02) = 0xc0; - *(char *)(CONFIG_SYS_PIGGY_BASE + 0x03) = 0x15; + out_8((volatile unsigned char __iomem *) + (CONFIG_SYS_PIGGY_BASE + 0x02), 0xc0); + out_8((volatile unsigned char __iomem *) + (CONFIG_SYS_PIGGY_BASE + 0x03), 0x15); return 0; }
@@ -334,7 +337,7 @@ void ft_blob_update (void *blob, bd_t *bd) /* update Flash addr, size */ flash_data[2] = cpu_to_be32 (CONFIG_SYS_FLASH_BASE); flash_data[3] = cpu_to_be32 (CONFIG_SYS_FLASH_SIZE); - flash_data[4] = cpu_to_be32 (1); + flash_data[4] = cpu_to_be32 (5); flash_data[5] = cpu_to_be32 (0); flash_data[6] = cpu_to_be32 (CONFIG_SYS_FLASH_BASE_1); flash_data[7] = cpu_to_be32 (CONFIG_SYS_FLASH_SIZE_1); diff --git a/board/keymile/mgsuvd/mgsuvd.c b/board/keymile/mgsuvd/mgsuvd.c index 912e177..ec13746 100644 --- a/board/keymile/mgsuvd/mgsuvd.c +++ b/board/keymile/mgsuvd/mgsuvd.c @@ -20,11 +20,6 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ - -#if 0 -#define DEBUG -#endif - #include <common.h> #include <mpc8xx.h>
@@ -142,8 +137,10 @@ phys_size_t initdram (int board_type) int board_early_init_r(void) { /* setup the UPIOx */ - *(char *)(CONFIG_SYS_PIGGY_BASE + 0x02) = 0xc0; - *(char *)(CONFIG_SYS_PIGGY_BASE + 0x03) = 0x35; + out_8((volatile unsigned char __iomem *) + (CONFIG_SYS_PIGGY_BASE + 0x02), 0xc0); + out_8((volatile unsigned char __iomem *) + (CONFIG_SYS_PIGGY_BASE + 0x03), 0x35); return 0; }
@@ -157,80 +154,76 @@ int hush_init_var (void) /* * update "memory" property in the blob */ -void ft_blob_update(void *blob, bd_t *bd) +void ft_blob_update (void *blob, bd_t *bd) { int ret, nodeoffset = 0; ulong brg_data[1] = {0}; ulong memory_data[2] = {0}; ulong flash_data[4] = {0};
- memory_data[0] = cpu_to_be32(bd->bi_memstart); - memory_data[1] = cpu_to_be32(bd->bi_memsize); + memory_data[0] = cpu_to_be32 (bd->bi_memstart); + memory_data[1] = cpu_to_be32 (bd->bi_memsize);
- nodeoffset = fdt_path_offset (blob, "/memory"); - if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "reg", memory_data, - sizeof(memory_data)); + nodeoffset = fdt_path_offset (blob, "/memory"); + if (nodeoffset >= 0) { + ret = fdt_setprop (blob, nodeoffset, "reg", memory_data, + sizeof (memory_data)); if (ret < 0) printf("ft_blob_update(): cannot set /memory/reg " - "property err:%s\n", fdt_strerror(ret)); - } - else { + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ printf("ft_blob_update(): cannot find /memory node " - "err:%s\n", fdt_strerror(nodeoffset)); + "err:%s\n", fdt_strerror (nodeoffset)); }
- flash_data[2] = cpu_to_be32(bd->bi_flashstart); - flash_data[3] = cpu_to_be32(bd->bi_flashsize); + flash_data[2] = cpu_to_be32 (bd->bi_flashstart); + flash_data[3] = cpu_to_be32 (bd->bi_flashsize); nodeoffset = fdt_path_offset (blob, "/localbus"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "ranges", flash_data, - sizeof(flash_data)); + ret = fdt_setprop (blob, nodeoffset, "ranges", flash_data, + sizeof (flash_data)); if (ret < 0) printf("ft_blob_update(): cannot set /localbus/ranges " - "property err:%s\n", fdt_strerror(ret)); - } - else { + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ printf("ft_blob_update(): cannot find /localbus node " - "err:%s\n", fdt_strerror(nodeoffset)); + "err:%s\n", fdt_strerror (nodeoffset)); } /* BRG */ - brg_data[0] = cpu_to_be32(bd->bi_busfreq); + brg_data[0] = cpu_to_be32 (bd->bi_busfreq); nodeoffset = fdt_path_offset (blob, "/soc/cpm"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "brg-frequency", brg_data, - sizeof(brg_data)); + ret = fdt_setprop (blob, nodeoffset, "brg-frequency", brg_data, + sizeof (brg_data)); if (ret < 0) printf("ft_blob_update(): cannot set /soc/cpm/brg-frequency " "property err:%s\n", fdt_strerror(ret)); - } - else { + } else { /* memory node is required in dts */ printf("ft_blob_update(): cannot find /soc/cpm node " - "err:%s\n", fdt_strerror(nodeoffset)); + "err:%s\n", fdt_strerror (nodeoffset)); } /* MAC Adresse */ nodeoffset = fdt_path_offset (blob, "/soc/cpm/ethernet"); if (nodeoffset >= 0) { - ret = fdt_setprop(blob, nodeoffset, "mac-address", bd->bi_enetaddr, - sizeof(uchar) * 6); + ret = fdt_setprop (blob, nodeoffset, "mac-address", bd->bi_enetaddr, + sizeof (uchar) * 6); if (ret < 0) printf("ft_blob_update(): cannot set /soc/cpm/scc/mac-address " - "property err:%s\n", fdt_strerror(ret)); - } - else { + "property err:%s\n", fdt_strerror (ret)); + } else { /* memory node is required in dts */ printf("ft_blob_update(): cannot find /soc/cpm/ethernet node " - "err:%s\n", fdt_strerror(nodeoffset)); + "err:%s\n", fdt_strerror (nodeoffset)); } }
void ft_board_setup(void *blob, bd_t *bd) { - ft_cpu_setup( blob, bd); - ft_blob_update(blob, bd); + ft_cpu_setup (blob, bd); + ft_blob_update (blob, bd); } #endif /* defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) */
Dear Heiko Schocher,
Please split into separate patches: one for the CS5, second for the coding style fixes, and a third for the change to use in_*/out_* accessors
Thanks.
Heiko Schocher
