[U-Boot] [PATCH] ARM926: Add mb to the cache invalidate/flush
Add memory barrier to cache invalidate and flush calls.
Signed-off-by: Marek Vasut marex@denx.de CC: Albert Aribaud albert.u.boot@aribaud.net Cc: Fabio Estevam festevam@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/cache.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 2740ad7..1c67608 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -30,7 +30,7 @@
void invalidate_dcache_all(void) { - asm volatile("mcr p15, 0, %0, c7, c6, 0\n" : : "r"(0)); + asm volatile("mcr p15, 0, %0, c7, c6, 0\n" : : "r"(0) : "memory"); }
void flush_dcache_all(void) @@ -67,7 +67,8 @@ void invalidate_dcache_range(unsigned long start, unsigned long stop) return;
while (start < stop) { - asm volatile("mcr p15, 0, %0, c7, c6, 1\n" : : "r"(start)); + asm volatile("mcr p15, 0, %0, c7, c6, 1\n" + : : "r"(start) : "memory"); start += CONFIG_SYS_CACHELINE_SIZE; } } @@ -78,11 +79,12 @@ void flush_dcache_range(unsigned long start, unsigned long stop) return;
while (start < stop) { - asm volatile("mcr p15, 0, %0, c7, c14, 1\n" : : "r"(start)); + asm volatile("mcr p15, 0, %0, c7, c14, 1\n" + : : "r"(start) : "memory"); start += CONFIG_SYS_CACHELINE_SIZE; }
- asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0)); + asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0) : "memory"); }
void flush_cache(unsigned long start, unsigned long size)
Hi Marek,
Memory barrier...
"You keep using that word. I do not think it means what you think it means." :)
A memory barrier's effect is only that all of the volatile accesses placed before it in the source code finish when the barrier executes, and that none of the volatile accesses placed after it in the source code starts before the barrier has executed.
Non-volatile accesses are not guaranteed to stay on one side of the barrier, and the barrier itself is not guaranteed to stay put during optimizations.
If what you intended was to ensure that e.g. all writes be finished when a flush occurs, or that no read happens before an invalide has executed, then adding memory clobbers is not an adequate solution.
If you were aiming for something else entirely, please don't hesitate to develop a description of the problem you wish to solve.
Amicalement,
Dear Albert ARIBAUD,
Hi Marek,
Memory barrier...
Yes, that's pretty much it. To ensure that all writes to the flushed memory area are finished before the flushing happens.
What do you suggest?
Amicalement,
Best regards, Marek Vasut
On 10/11/2012 12:31:46 AM, Albert ARIBAUD wrote:
Hi Marek,
Memory barrier...
Could we wait on the condescension until your assertion of what a memory clobber does and does not do is resolved?
Cite from official GCC documentation please, or example code that shows a problem.
We've use memory barriers like this all the time. It works and is standard practice. If it doesn't work like that it needs to be fixed.
That AVR/ARM example you showed on IRC is special because it's calling a libgcc function and GCC knows that the function doesn't access memory (loading constant data for the argument doesn't count). I couldn't get the same thing to happen with a normal function, even when declared with __attribute__((const)). Yes, it's a problem for ordering code in general and thus keeping slow stuff out of critical sections, but it shouldn't be a problem for ordering memory accesses.
-Scott
Hi Scott,
On Thu, 11 Oct 2012 13:03:13 -0500, Scott Wood scottwood@freescale.com wrote:
Hi Marek,
Memory barrier...
Scott, I think you should not mistake as condescension what is just humo(u)r. What I wrote above is a quotation from a (light, quite humorous and above all, self-mocking) movie, meant to be read by, but in no way directed against, Marex. Besides, since you followed the IRC discussion, you knew the actual exact meanings of "memory barrier" and of the "memory" clobber are not that easy to grasp, which makes the quotation quite appropriate without necessarily.
http://gcc.gnu.org/onlinedocs/gcc/Extended-Asm.html#Extended-Asm
"If your assembler instructions access memory in an unpredictable fashion, add `memory' to the list of clobbered registers. This will cause GCC to not keep memory values cached in registers across the assembler instruction and not optimize stores or loads to that memory. You will also want to add the volatile keyword if the memory affected is not listed in the inputs or outputs of the asm, as the `memory' clobber does not count as a side-effect of the asm".
I have used memory barriers too, and I've already seen some weird things happening because they were used in ways that did not match their effects. Particularly, we did not use memory clobbers on cache flush or invalidate operations, we used them on actual barrier operations -- dsb, dmb and their cp15 incarnations.
Can you *guarantee* that no valid C code will ever let a non-volatile write slip across a memory clobber?
Memory clobbers do not guarantee this, at least not explicitly in their description, whereas C sequence points do. For instance, the call to a function is a sequence point, reached only after its arguments have been evaluated.
-Scott
Amicalement,
On 10/11/2012 03:03:29 PM, Albert ARIBAUD wrote:
Hi Scott,
Hi Marek,
Memory barrier...
it
means." :)
Sure, it just seemed an odd way to resume a conversation that had already begun on the topic.
accesses
executes,
source
shows
a problem.
"and not optimize stores or loads to that memory". It's not clear what "that" refers to, since the memory clobber does not refer to specific memory, but given that the purpose is "if your assembler instructions access memory in an unpredictable fashion", I don't see how it could be interpreted as anything other than "any memory which could possibly be modified by the program". So it excludes constant data, but that's about it.
The only reference to volatile is to tell you to add it to the asm statement (not to other memory accesses) so that the asm statement does not get removed altogether.
fixed.
What specifically did you see the compiler do?
calling
memory
get
in
I don't know GCC internals, so I personally can't guarantee anything. What I know is that they're used for this purpose all over the place, and if there really is a problem it needs to be fixed. If the use in this patch is wrong, then so are Linux synchronization primitives, for example. How would you make a spinlock? Certainly you can't insist that all the variables protected by the lock be volatile.
-Scott
Hi Scott,
On Thu, 11 Oct 2012 15:21:28 -0500, Scott Wood scottwood@freescale.com wrote:
It felt odd to you obviously. But does oddity imply condescension? Seems to me like you're assuming a lot on what or how I think.
accesses
executes,
source
shows
a problem.
It does not necessarily include "all memory". Besides, "that" -- to me -- cleary means "the memory mentioned in the statement, for instance in the inputs or outputs.
The memory clobber definition says no memory values are kept cached in registers across the instruction, that implies that if a volatile access was prepared (a memory value was cached in a register) it is finished before the asm statement executes, and similarly, since the desciption says "across" the instruction, volatiles reads or writes located after the instruction won't have been started before ithe instruction executest, or they would have needed to cache the value, which is contrary to the memory clobber definition.
This is not to say that only volatiles are affected by the barrier; but volatiles certainly are.
fixed.
I'll have to look up the repositories. I'll keep you posted once I find back examples.
calling
memory
get
in
My point is that memory clobbers have some effect, but just because a memory clobber appears somewhere does not mean it is responsible for all that happens there.
Regarding Linux spinlocks vs these patches: it's not the same situation. spinlock functions are inlined, as you noted, thus a code sequence that takes a spinlock, does some accesses, then releases the spinlock ends up as a long sequence of instructions. On the contrary, the cache functions (which are not going to be inlined any time soon as they are strong versions of weak symbols, incompatible with inlining) contain a single asm statement, thus adding a memory clobber to this statement won't have any effect for lack of preceding or following instructions to (not) reorder.
-Scott
Amicalement,
On 10/11/2012 06:37:40 PM, Albert ARIBAUD wrote:
Hi Scott,
will
memory.
affected
what
specific
instructions
could be
be
The whole point of the memory clobber is for when you can't easily express the memory in terms of input/output constraints.
does
Sure, but that first paragraph without the second is misleading as it implies that it is only volatiles that are affected. Maybe not in terms of logical inference, but in terms of natural language and the meaning people are likely to take from it.
Fine. I still think it's good practice to always use the memory clobber in these situations, as it doesn't hurt anything, and if nothing else you'd be setting a good example for others in situations that may not be as inline-averse -- but such style issues are up to you as maintainer.
-Scott
Hi Marek,
First, a (long) preamble with some general considerations:
A. This patch does not fix an actual issues; it is a prospective patch, modifying code which so far has not malfunctioned, or at least has not been reported to malfunction.
B. My comments on the patch below are based on the general consideration that the effect of a memory clobber is to contrain the reordering of statements around the clobbering. For the sake of simplicity -- and serenity :) -- my comments are also made under the assumption that the clobber prevents any access (volatile or not, write or read) from crossing it.
C. Another general comment is that adding clobber to instructions other than barriers is IMO not a good thing and isb() should be used instead, for two reasons:
1) it mixes an implicit secondary purpose into a statement written for another, explicit purpose; this can drown the implicit purpose into oblivion, when it should actually be emphasized, which is the goal and effect of isb();
2) it mixes the ends and the means. The end of your patch is to put instruction barriers between statements so that their relative order is preserved during optimization; adding "memory" to the clobber list of an asm instruction that happens to be one of the statements is a means, but so is isb() with the added benefit that using isb() allows architectures to use whatever means (memory clobber, specialized instruction, other) are best for the arch.
D. My comments on the patch below are based on the current source code.
One could argue that this may change if the function becomes inline. While this is true, I do not consider this right now because 1) the function is a strong replacement of a weak symbol, which AFAIU is not compatible with inlining, and 2) this patch is against the current tree, not a potential future tree. If/when a patch arrives to make the function inline, we'll consider the implications and how to solve them *then*.
Ther may be another impact on this function, namely LTO; but --again, AFAIU -- LTO does not rewrite the inside of functions; it only optimizes between functions. And again, we'll deal with LTO if/when patches for LTO get submitted.
... and, there may be future changes not imagined here that will break things. We'll deal with them then.
- asm volatile("mcr p15, 0, %0, c7, c6, 0\n" : : "r"(0) : "memory");
This one is useless since there are no accesses in the function to be reordered.
start += CONFIG_SYS_CACHELINE_SIZE; }: : "r"(start) : "memory");
This one is useless too, as the only access it could constrain is the one affecting start, which is also affected by the would-be-clobbered statement (and the enclosing while's condition, thus already preventing the compiler from reordering.
Here again, the only access the clobber could constrain is the one affecting start, which is also affected by the would-be-clobbered statement (and the enclosing while's condition, thus already preventing the compiler from reordering.
- asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0) : "memory");
Now this asm statement might potentially move around as it does not have input or output dependencies that the compiler could possibly use to assess ordering constraints. I would thus suggest replacing the memory clobber with an 'isb();' placed on the line before the asm volatile, for the reasons indicated in part C of my (long) preamble above.
Amicalement,
Albert ARIBAUD
Scott Wood
