[PATCH 1/1] disk: simplify print_part_header()
Using uclass_get_name() reduces the code size.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- disk/part.c | 47 +++----------------------------------- test/py/tests/test_scsi.py | 2 +- 2 files changed, 4 insertions(+), 45 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 36b88205eca..65289a31e30 100644 --- a/disk/part.c +++ b/disk/part.c @@ -14,6 +14,7 @@ #include <malloc.h> #include <part.h> #include <ubifs_uboot.h> +#include <dm/uclass.h>
#undef PART_DEBUG
@@ -305,50 +306,8 @@ static void print_part_header(const char *type, struct blk_desc *desc) CONFIG_IS_ENABLED(ISO_PARTITION) || \ CONFIG_IS_ENABLED(AMIGA_PARTITION) || \ CONFIG_IS_ENABLED(EFI_PARTITION) - puts ("\nPartition Map for "); - switch (desc->uclass_id) { - case UCLASS_IDE: - puts ("IDE"); - break; - case UCLASS_AHCI: - puts ("SATA"); - break; - case UCLASS_SCSI: - puts ("SCSI"); - break; - case UCLASS_USB: - puts ("USB"); - break; - case UCLASS_MMC: - puts ("MMC"); - break; - case UCLASS_HOST: - puts ("HOST"); - break; - case UCLASS_NVME: - puts ("NVMe"); - break; - case UCLASS_PVBLOCK: - puts("PV BLOCK"); - break; - case UCLASS_RKMTD: - puts("RKMTD"); - break; - case UCLASS_VIRTIO: - puts("VirtIO"); - break; - case UCLASS_EFI_MEDIA: - puts("EFI"); - break; - case UCLASS_BLKMAP: - puts("BLKMAP"); - break; - default: - printf("UNKNOWN(%d)", desc->uclass_id); - break; - } - printf (" device %d -- Partition Type: %s\n\n", - desc->devnum, type); + printf("\nPartition Map for %s device %d -- Partition Type: %s\n\n", + uclass_get_name(desc->uclass_id), desc->devnum, type); #endif /* any CONFIG_..._PARTITION */ }
diff --git a/test/py/tests/test_scsi.py b/test/py/tests/test_scsi.py index be2e283e7d2..445693cafd7 100644 --- a/test/py/tests/test_scsi.py +++ b/test/py/tests/test_scsi.py @@ -87,6 +87,6 @@ def test_scsi_dev(u_boot_console): def test_scsi_part(u_boot_console): test_scsi_dev(u_boot_console) output = u_boot_console.run_command('scsi part') - assert 'Partition Map for SCSI device' in output + assert 'Partition Map for scsi device' in output output = u_boot_console.run_command('echo $?') assert output.endswith('0')
