[U-Boot] [PATCH] usb: xhci-dwc3: Add support for dis_u2_susphy_quirk
This quirk is necessary for the Amlogic GXL SoCs otherwise the Port 2 PHY doesn't get out of suspend and U-Boot resets the board after:
XHCI timeout on event type 33... cannot recover. BUG: failure at drivers/usb/host/xhci-ring.c:474/xhci_wait_for_event()! BUG!
This quirk is also handled in the dwc3 core code, but until the xhci-dwc3 driver uses the dwc3 core, the quirk must be handled here to fix USB support on the Amlogic libretech-cc and libretech-ac board when a device is only plugged in the OTG port.
Cc: Yuri Frolov crashing.kernel@gmail.com Cc: Bin Meng bmeng.cn@gmail.com Fixes: dc9cdf859e ("usb: dwc3: Add DWC3 controller driver support") Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/usb/host/xhci-dwc3.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index 9e8cae7ae4..55a1b22cf6 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -150,6 +150,9 @@ static int xhci_dwc3_probe(struct udevice *dev) if (dev_read_bool(dev, "snps,dis-u2-freeclk-exists-quirk")) reg &= ~DWC3_GUSB2PHYCFG_U2_FREECLK_EXISTS;
+ if (dev_read_bool(dev, "snps,dis_u2_susphy_quirk")) + reg &= ~DWC3_GUSB2PHYCFG_SUSPHY; + writel(reg, &dwc3_reg->g_usb2phycfg[0]);
dr_mode = usb_get_dr_mode(dev_of_offset(dev));
On Tue, Sep 10, 2019 at 2:52 AM Neil Armstrong narmstrong@baylibre.com wrote:
Thanks for your efforts tracing this down!
Hi Bin, Marek,
Should I take it into my amlogic tree or you'll handle it ?
Thanks, Neil
Hi Neil,
On Tue, Sep 10, 2019 at 3:58 PM Neil Armstrong narmstrong@baylibre.com wrote:
Hi Bin, Marek,
I think you can take it via your tree. Thanks!
Regards, Bin
Bin Meng
Neil Armstrong
