[PATCH] Fix spelling of "followed" in kwboot.1
Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
doc/kwboot.1 | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/kwboot.1 b/doc/kwboot.1 index f555ff26a2..d663bf1f77 100644 --- a/doc/kwboot.1 +++ b/doc/kwboot.1 @@ -74,7 +74,7 @@ BootROM's standard input and BootROM's terminal echo are active and working fine. To workaround this BootROM bug with standard output, it is possible to manually overwrite BootROM variables stored in SRAM which BootROM use for checking if standard output is enabled or not. To enable BootROM -standard output on UART, type this command folled by ENTER key: +standard output on UART, type this command followed by ENTER key:
.RS 1.2i .TP
On Sat, 16 Apr 2022 15:42:00 -0700 Vagrant Cascadian vagrant@debian.org wrote:
Hello Vagrant,
The commit title should be prefixed with tools: kwboot:
The commit message shouldn't be empty. If you don't have anything to say, just copy commit title.
Marek
Marek Behún
Vagrant Cascadian
