[U-Boot] [PATCH] cmd_mem.c: Fix warning when CONFIG_CMD_MEMTEST is not set
mem_test_quick and mem_test_alt functions are only called by do_mem_mtest, so move them under the #ifdef
Signed-off-by: Tom Rini trini@ti.com --- common/cmd_mem.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 53572f7..64dd76a 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -631,6 +631,7 @@ int do_mem_loopw (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } #endif /* CONFIG_LOOPW */
+#ifdef CONFIG_CMD_MEMTEST static ulong mem_test_alt(vu_long *buf, ulong start_addr, ulong end_addr, vu_long *dummy) { @@ -910,7 +911,6 @@ static ulong mem_test_quick(vu_long *buf, ulong start_addr, ulong end_addr, return 0; }
-#ifdef CONFIG_CMD_MEMTEST /* * Perform a memory test. A more complete alternative test can be * configured using CONFIG_SYS_ALT_MEMTEST. The complete test loops until
As I've build-tested this on arm (where a few platforms didn't have CONFIG_CMD_MTEST) and one of the PowerPC boards I also saw this on, applied to u-boot/master.
