[U-Boot-Users] [PATCH] Clean up smsc911x driver
Replace direct register address derefencing with accessor functions. Restrict explicitly 32-bit bus-width, extend affected configurations respectively.
Signed-off-by: Guennadi Liakhovetski lg@denx.de
Sascha, please test.
diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index c332189..c17dcf4 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -30,321 +30,332 @@ #include <net.h> #include <miiphy.h>
-#define mdelay(n) udelay((n)*1000) +#ifdef CONFIG_DRIVER_SMC911X_32_BIT +static inline u32 reg_read(u32 addr) +{ + return *(volatile u32*)addr; +} +static inline void reg_write(u32 addr, u32 val) +{ + *(volatile u32*)addr = val; +} +#else +#error "SMC911X: Only 32-bit bus is supported" +#endif
-#define __REG(x) (*((volatile u32 *)(x))) +#define mdelay(n) udelay((n)*1000)
/* Below are the register offsets and bit definitions * of the Lan911x memory space */ -#define RX_DATA_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x00) - -#define TX_DATA_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x20) -#define TX_CMD_A_INT_ON_COMP (0x80000000) -#define TX_CMD_A_INT_BUF_END_ALGN (0x03000000) -#define TX_CMD_A_INT_4_BYTE_ALGN (0x00000000) -#define TX_CMD_A_INT_16_BYTE_ALGN (0x01000000) -#define TX_CMD_A_INT_32_BYTE_ALGN (0x02000000) -#define TX_CMD_A_INT_DATA_OFFSET (0x001F0000) -#define TX_CMD_A_INT_FIRST_SEG (0x00002000) -#define TX_CMD_A_INT_LAST_SEG (0x00001000) -#define TX_CMD_A_BUF_SIZE (0x000007FF) -#define TX_CMD_B_PKT_TAG (0xFFFF0000) -#define TX_CMD_B_ADD_CRC_DISABLE (0x00002000) -#define TX_CMD_B_DISABLE_PADDING (0x00001000) -#define TX_CMD_B_PKT_BYTE_LENGTH (0x000007FF) - -#define RX_STATUS_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x40) -#define RX_STS_PKT_LEN (0x3FFF0000) -#define RX_STS_ES (0x00008000) -#define RX_STS_BCST (0x00002000) -#define RX_STS_LEN_ERR (0x00001000) -#define RX_STS_RUNT_ERR (0x00000800) -#define RX_STS_MCAST (0x00000400) -#define RX_STS_TOO_LONG (0x00000080) -#define RX_STS_COLL (0x00000040) -#define RX_STS_ETH_TYPE (0x00000020) -#define RX_STS_WDOG_TMT (0x00000010) -#define RX_STS_MII_ERR (0x00000008) -#define RX_STS_DRIBBLING (0x00000004) -#define RX_STS_CRC_ERR (0x00000002) -#define RX_STATUS_FIFO_PEEK __REG(CONFIG_DRIVER_SMC911X_BASE + 0x44) -#define TX_STATUS_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x48) -#define TX_STS_TAG (0xFFFF0000) -#define TX_STS_ES (0x00008000) -#define TX_STS_LOC (0x00000800) -#define TX_STS_NO_CARR (0x00000400) -#define TX_STS_LATE_COLL (0x00000200) -#define TX_STS_MANY_COLL (0x00000100) -#define TX_STS_COLL_CNT (0x00000078) -#define TX_STS_MANY_DEFER (0x00000004) -#define TX_STS_UNDERRUN (0x00000002) -#define TX_STS_DEFERRED (0x00000001) -#define TX_STATUS_FIFO_PEEK __REG(CONFIG_DRIVER_SMC911X_BASE + 0x4C) -#define ID_REV __REG(CONFIG_DRIVER_SMC911X_BASE + 0x50) -#define ID_REV_CHIP_ID (0xFFFF0000) /* RO */ -#define ID_REV_REV_ID (0x0000FFFF) /* RO */ - -#define INT_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x54) -#define INT_CFG_INT_DEAS (0xFF000000) /* R/W */ -#define INT_CFG_INT_DEAS_CLR (0x00004000) -#define INT_CFG_INT_DEAS_STS (0x00002000) -#define INT_CFG_IRQ_INT (0x00001000) /* RO */ -#define INT_CFG_IRQ_EN (0x00000100) /* R/W */ -#define INT_CFG_IRQ_POL (0x00000010) /* R/W Not Affected by SW Reset */ -#define INT_CFG_IRQ_TYPE (0x00000001) /* R/W Not Affected by SW Reset */ - -#define INT_STS __REG(CONFIG_DRIVER_SMC911X_BASE + 0x58) -#define INT_STS_SW_INT (0x80000000) /* R/WC */ -#define INT_STS_TXSTOP_INT (0x02000000) /* R/WC */ -#define INT_STS_RXSTOP_INT (0x01000000) /* R/WC */ -#define INT_STS_RXDFH_INT (0x00800000) /* R/WC */ -#define INT_STS_RXDF_INT (0x00400000) /* R/WC */ -#define INT_STS_TX_IOC (0x00200000) /* R/WC */ -#define INT_STS_RXD_INT (0x00100000) /* R/WC */ -#define INT_STS_GPT_INT (0x00080000) /* R/WC */ -#define INT_STS_PHY_INT (0x00040000) /* RO */ -#define INT_STS_PME_INT (0x00020000) /* R/WC */ -#define INT_STS_TXSO (0x00010000) /* R/WC */ -#define INT_STS_RWT (0x00008000) /* R/WC */ -#define INT_STS_RXE (0x00004000) /* R/WC */ -#define INT_STS_TXE (0x00002000) /* R/WC */ -/*#define INT_STS_ERX (0x00001000)*/ /* R/WC */ -#define INT_STS_TDFU (0x00000800) /* R/WC */ -#define INT_STS_TDFO (0x00000400) /* R/WC */ -#define INT_STS_TDFA (0x00000200) /* R/WC */ -#define INT_STS_TSFF (0x00000100) /* R/WC */ -#define INT_STS_TSFL (0x00000080) /* R/WC */ -/*#define INT_STS_RXDF (0x00000040)*/ /* R/WC */ -#define INT_STS_RDFO (0x00000040) /* R/WC */ -#define INT_STS_RDFL (0x00000020) /* R/WC */ -#define INT_STS_RSFF (0x00000010) /* R/WC */ -#define INT_STS_RSFL (0x00000008) /* R/WC */ -#define INT_STS_GPIO2_INT (0x00000004) /* R/WC */ -#define INT_STS_GPIO1_INT (0x00000002) /* R/WC */ -#define INT_STS_GPIO0_INT (0x00000001) /* R/WC */ -#define INT_EN __REG(CONFIG_DRIVER_SMC911X_BASE + 0x5C) -#define INT_EN_SW_INT_EN (0x80000000) /* R/W */ -#define INT_EN_TXSTOP_INT_EN (0x02000000) /* R/W */ -#define INT_EN_RXSTOP_INT_EN (0x01000000) /* R/W */ -#define INT_EN_RXDFH_INT_EN (0x00800000) /* R/W */ -/*#define INT_EN_RXDF_INT_EN (0x00400000)*/ /* R/W */ -#define INT_EN_TIOC_INT_EN (0x00200000) /* R/W */ -#define INT_EN_RXD_INT_EN (0x00100000) /* R/W */ -#define INT_EN_GPT_INT_EN (0x00080000) /* R/W */ -#define INT_EN_PHY_INT_EN (0x00040000) /* R/W */ -#define INT_EN_PME_INT_EN (0x00020000) /* R/W */ -#define INT_EN_TXSO_EN (0x00010000) /* R/W */ -#define INT_EN_RWT_EN (0x00008000) /* R/W */ -#define INT_EN_RXE_EN (0x00004000) /* R/W */ -#define INT_EN_TXE_EN (0x00002000) /* R/W */ -/*#define INT_EN_ERX_EN (0x00001000)*/ /* R/W */ -#define INT_EN_TDFU_EN (0x00000800) /* R/W */ -#define INT_EN_TDFO_EN (0x00000400) /* R/W */ -#define INT_EN_TDFA_EN (0x00000200) /* R/W */ -#define INT_EN_TSFF_EN (0x00000100) /* R/W */ -#define INT_EN_TSFL_EN (0x00000080) /* R/W */ -/*#define INT_EN_RXDF_EN (0x00000040)*/ /* R/W */ -#define INT_EN_RDFO_EN (0x00000040) /* R/W */ -#define INT_EN_RDFL_EN (0x00000020) /* R/W */ -#define INT_EN_RSFF_EN (0x00000010) /* R/W */ -#define INT_EN_RSFL_EN (0x00000008) /* R/W */ -#define INT_EN_GPIO2_INT (0x00000004) /* R/W */ -#define INT_EN_GPIO1_INT (0x00000002) /* R/W */ -#define INT_EN_GPIO0_INT (0x00000001) /* R/W */ - -#define BYTE_TEST __REG(CONFIG_DRIVER_SMC911X_BASE + 0x64) -#define FIFO_INT __REG(CONFIG_DRIVER_SMC911X_BASE + 0x68) -#define FIFO_INT_TX_AVAIL_LEVEL (0xFF000000) /* R/W */ -#define FIFO_INT_TX_STS_LEVEL (0x00FF0000) /* R/W */ -#define FIFO_INT_RX_AVAIL_LEVEL (0x0000FF00) /* R/W */ -#define FIFO_INT_RX_STS_LEVEL (0x000000FF) /* R/W */ - -#define RX_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x6C) -#define RX_CFG_RX_END_ALGN (0xC0000000) /* R/W */ -#define RX_CFG_RX_END_ALGN4 (0x00000000) /* R/W */ -#define RX_CFG_RX_END_ALGN16 (0x40000000) /* R/W */ -#define RX_CFG_RX_END_ALGN32 (0x80000000) /* R/W */ -#define RX_CFG_RX_DMA_CNT (0x0FFF0000) /* R/W */ -#define RX_CFG_RX_DUMP (0x00008000) /* R/W */ -#define RX_CFG_RXDOFF (0x00001F00) /* R/W */ -/*#define RX_CFG_RXBAD (0x00000001)*/ /* R/W */ - -#define TX_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x70) -/*#define TX_CFG_TX_DMA_LVL (0xE0000000)*/ /* R/W */ -/*#define TX_CFG_TX_DMA_CNT (0x0FFF0000)*/ /* R/W Self Clearing */ -#define TX_CFG_TXS_DUMP (0x00008000) /* Self Clearing */ -#define TX_CFG_TXD_DUMP (0x00004000) /* Self Clearing */ -#define TX_CFG_TXSAO (0x00000004) /* R/W */ -#define TX_CFG_TX_ON (0x00000002) /* R/W */ -#define TX_CFG_STOP_TX (0x00000001) /* Self Clearing */ - -#define HW_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x74) -#define HW_CFG_TTM (0x00200000) /* R/W */ -#define HW_CFG_SF (0x00100000) /* R/W */ -#define HW_CFG_TX_FIF_SZ (0x000F0000) /* R/W */ -#define HW_CFG_TR (0x00003000) /* R/W */ -#define HW_CFG_PHY_CLK_SEL (0x00000060) /* R/W */ -#define HW_CFG_PHY_CLK_SEL_INT_PHY (0x00000000) /* R/W */ -#define HW_CFG_PHY_CLK_SEL_EXT_PHY (0x00000020) /* R/W */ -#define HW_CFG_PHY_CLK_SEL_CLK_DIS (0x00000040) /* R/W */ -#define HW_CFG_SMI_SEL (0x00000010) /* R/W */ -#define HW_CFG_EXT_PHY_DET (0x00000008) /* RO */ -#define HW_CFG_EXT_PHY_EN (0x00000004) /* R/W */ -#define HW_CFG_32_16_BIT_MODE (0x00000004) /* RO */ -#define HW_CFG_SRST_TO (0x00000002) /* RO */ -#define HW_CFG_SRST (0x00000001) /* Self Clearing */ - -#define RX_DP_CTRL __REG(CONFIG_DRIVER_SMC911X_BASE + 0x78) -#define RX_DP_CTRL_RX_FFWD (0x80000000) /* R/W */ -#define RX_DP_CTRL_FFWD_BUSY (0x80000000) /* RO */ - -#define RX_FIFO_INF __REG(CONFIG_DRIVER_SMC911X_BASE + 0x7C) -#define RX_FIFO_INF_RXSUSED (0x00FF0000) /* RO */ -#define RX_FIFO_INF_RXDUSED (0x0000FFFF) /* RO */ - -#define TX_FIFO_INF __REG(CONFIG_DRIVER_SMC911X_BASE + 0x80) -#define TX_FIFO_INF_TSUSED (0x00FF0000) /* RO */ -#define TX_FIFO_INF_TDFREE (0x0000FFFF) /* RO */ - -#define PMT_CTRL __REG(CONFIG_DRIVER_SMC911X_BASE + 0x84) -#define PMT_CTRL_PM_MODE (0x00003000) /* Self Clearing */ -#define PMT_CTRL_PHY_RST (0x00000400) /* Self Clearing */ -#define PMT_CTRL_WOL_EN (0x00000200) /* R/W */ -#define PMT_CTRL_ED_EN (0x00000100) /* R/W */ -#define PMT_CTRL_PME_TYPE (0x00000040) /* R/W Not Affected by SW Reset */ -#define PMT_CTRL_WUPS (0x00000030) /* R/WC */ -#define PMT_CTRL_WUPS_NOWAKE (0x00000000) /* R/WC */ -#define PMT_CTRL_WUPS_ED (0x00000010) /* R/WC */ -#define PMT_CTRL_WUPS_WOL (0x00000020) /* R/WC */ -#define PMT_CTRL_WUPS_MULTI (0x00000030) /* R/WC */ -#define PMT_CTRL_PME_IND (0x00000008) /* R/W */ -#define PMT_CTRL_PME_POL (0x00000004) /* R/W */ -#define PMT_CTRL_PME_EN (0x00000002) /* R/W Not Affected by SW Reset */ -#define PMT_CTRL_READY (0x00000001) /* RO */ - -#define GPIO_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x88) -#define GPIO_CFG_LED3_EN (0x40000000) /* R/W */ -#define GPIO_CFG_LED2_EN (0x20000000) /* R/W */ -#define GPIO_CFG_LED1_EN (0x10000000) /* R/W */ -#define GPIO_CFG_GPIO2_INT_POL (0x04000000) /* R/W */ -#define GPIO_CFG_GPIO1_INT_POL (0x02000000) /* R/W */ -#define GPIO_CFG_GPIO0_INT_POL (0x01000000) /* R/W */ -#define GPIO_CFG_EEPR_EN (0x00700000) /* R/W */ -#define GPIO_CFG_GPIOBUF2 (0x00040000) /* R/W */ -#define GPIO_CFG_GPIOBUF1 (0x00020000) /* R/W */ -#define GPIO_CFG_GPIOBUF0 (0x00010000) /* R/W */ -#define GPIO_CFG_GPIODIR2 (0x00000400) /* R/W */ -#define GPIO_CFG_GPIODIR1 (0x00000200) /* R/W */ -#define GPIO_CFG_GPIODIR0 (0x00000100) /* R/W */ -#define GPIO_CFG_GPIOD4 (0x00000010) /* R/W */ -#define GPIO_CFG_GPIOD3 (0x00000008) /* R/W */ -#define GPIO_CFG_GPIOD2 (0x00000004) /* R/W */ -#define GPIO_CFG_GPIOD1 (0x00000002) /* R/W */ -#define GPIO_CFG_GPIOD0 (0x00000001) /* R/W */ - -#define GPT_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x8C) -#define GPT_CFG_TIMER_EN (0x20000000) /* R/W */ -#define GPT_CFG_GPT_LOAD (0x0000FFFF) /* R/W */ - -#define GPT_CNT __REG(CONFIG_DRIVER_SMC911X_BASE + 0x90) -#define GPT_CNT_GPT_CNT (0x0000FFFF) /* RO */ - -#define ENDIAN __REG(CONFIG_DRIVER_SMC911X_BASE + 0x98) -#define FREE_RUN __REG(CONFIG_DRIVER_SMC911X_BASE + 0x9C) -#define RX_DROP __REG(CONFIG_DRIVER_SMC911X_BASE + 0xA0) -#define MAC_CSR_CMD __REG(CONFIG_DRIVER_SMC911X_BASE + 0xA4) -#define MAC_CSR_CMD_CSR_BUSY (0x80000000) /* Self Clearing */ -#define MAC_CSR_CMD_R_NOT_W (0x40000000) /* R/W */ -#define MAC_CSR_CMD_CSR_ADDR (0x000000FF) /* R/W */ - -#define MAC_CSR_DATA __REG(CONFIG_DRIVER_SMC911X_BASE + 0xA8) -#define AFC_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0xAC) -#define AFC_CFG_AFC_HI (0x00FF0000) /* R/W */ -#define AFC_CFG_AFC_LO (0x0000FF00) /* R/W */ -#define AFC_CFG_BACK_DUR (0x000000F0) /* R/W */ -#define AFC_CFG_FCMULT (0x00000008) /* R/W */ -#define AFC_CFG_FCBRD (0x00000004) /* R/W */ -#define AFC_CFG_FCADD (0x00000002) /* R/W */ -#define AFC_CFG_FCANY (0x00000001) /* R/W */ - -#define E2P_CMD __REG(CONFIG_DRIVER_SMC911X_BASE + 0xB0) -#define E2P_CMD_EPC_BUSY (0x80000000) /* Self Clearing */ -#define E2P_CMD_EPC_CMD (0x70000000) /* R/W */ -#define E2P_CMD_EPC_CMD_READ (0x00000000) /* R/W */ -#define E2P_CMD_EPC_CMD_EWDS (0x10000000) /* R/W */ -#define E2P_CMD_EPC_CMD_EWEN (0x20000000) /* R/W */ -#define E2P_CMD_EPC_CMD_WRITE (0x30000000) /* R/W */ -#define E2P_CMD_EPC_CMD_WRAL (0x40000000) /* R/W */ -#define E2P_CMD_EPC_CMD_ERASE (0x50000000) /* R/W */ -#define E2P_CMD_EPC_CMD_ERAL (0x60000000) /* R/W */ -#define E2P_CMD_EPC_CMD_RELOAD (0x70000000) /* R/W */ -#define E2P_CMD_EPC_TIMEOUT (0x00000200) /* RO */ -#define E2P_CMD_MAC_ADDR_LOADED (0x00000100) /* RO */ -#define E2P_CMD_EPC_ADDR (0x000000FF) /* R/W */ - -#define E2P_DATA __REG(CONFIG_DRIVER_SMC911X_BASE + 0xB4) -#define E2P_DATA_EEPROM_DATA (0x000000FF) /* R/W */ +#define RX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x00) + +#define TX_DATA_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x20) +#define TX_CMD_A_INT_ON_COMP 0x80000000 +#define TX_CMD_A_INT_BUF_END_ALGN 0x03000000 +#define TX_CMD_A_INT_4_BYTE_ALGN 0x00000000 +#define TX_CMD_A_INT_16_BYTE_ALGN 0x01000000 +#define TX_CMD_A_INT_32_BYTE_ALGN 0x02000000 +#define TX_CMD_A_INT_DATA_OFFSET 0x001F0000 +#define TX_CMD_A_INT_FIRST_SEG 0x00002000 +#define TX_CMD_A_INT_LAST_SEG 0x00001000 +#define TX_CMD_A_BUF_SIZE 0x000007FF +#define TX_CMD_B_PKT_TAG 0xFFFF0000 +#define TX_CMD_B_ADD_CRC_DISABLE 0x00002000 +#define TX_CMD_B_DISABLE_PADDING 0x00001000 +#define TX_CMD_B_PKT_BYTE_LENGTH 0x000007FF + +#define RX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x40) +#define RX_STS_PKT_LEN 0x3FFF0000 +#define RX_STS_ES 0x00008000 +#define RX_STS_BCST 0x00002000 +#define RX_STS_LEN_ERR 0x00001000 +#define RX_STS_RUNT_ERR 0x00000800 +#define RX_STS_MCAST 0x00000400 +#define RX_STS_TOO_LONG 0x00000080 +#define RX_STS_COLL 0x00000040 +#define RX_STS_ETH_TYPE 0x00000020 +#define RX_STS_WDOG_TMT 0x00000010 +#define RX_STS_MII_ERR 0x00000008 +#define RX_STS_DRIBBLING 0x00000004 +#define RX_STS_CRC_ERR 0x00000002 +#define RX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x44) +#define TX_STATUS_FIFO (CONFIG_DRIVER_SMC911X_BASE + 0x48) +#define TX_STS_TAG 0xFFFF0000 +#define TX_STS_ES 0x00008000 +#define TX_STS_LOC 0x00000800 +#define TX_STS_NO_CARR 0x00000400 +#define TX_STS_LATE_COLL 0x00000200 +#define TX_STS_MANY_COLL 0x00000100 +#define TX_STS_COLL_CNT 0x00000078 +#define TX_STS_MANY_DEFER 0x00000004 +#define TX_STS_UNDERRUN 0x00000002 +#define TX_STS_DEFERRED 0x00000001 +#define TX_STATUS_FIFO_PEEK (CONFIG_DRIVER_SMC911X_BASE + 0x4C) +#define ID_REV (CONFIG_DRIVER_SMC911X_BASE + 0x50) +#define ID_REV_CHIP_ID 0xFFFF0000 /* RO */ +#define ID_REV_REV_ID 0x0000FFFF /* RO */ + +#define INT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x54) +#define INT_CFG_INT_DEAS 0xFF000000 /* R/W */ +#define INT_CFG_INT_DEAS_CLR 0x00004000 +#define INT_CFG_INT_DEAS_STS 0x00002000 +#define INT_CFG_IRQ_INT 0x00001000 /* RO */ +#define INT_CFG_IRQ_EN 0x00000100 /* R/W */ +#define INT_CFG_IRQ_POL 0x00000010 /* R/W Not Affected by SW Reset */ +#define INT_CFG_IRQ_TYPE 0x00000001 /* R/W Not Affected by SW Reset */ + +#define INT_STS (CONFIG_DRIVER_SMC911X_BASE + 0x58) +#define INT_STS_SW_INT 0x80000000 /* R/WC */ +#define INT_STS_TXSTOP_INT 0x02000000 /* R/WC */ +#define INT_STS_RXSTOP_INT 0x01000000 /* R/WC */ +#define INT_STS_RXDFH_INT 0x00800000 /* R/WC */ +#define INT_STS_RXDF_INT 0x00400000 /* R/WC */ +#define INT_STS_TX_IOC 0x00200000 /* R/WC */ +#define INT_STS_RXD_INT 0x00100000 /* R/WC */ +#define INT_STS_GPT_INT 0x00080000 /* R/WC */ +#define INT_STS_PHY_INT 0x00040000 /* RO */ +#define INT_STS_PME_INT 0x00020000 /* R/WC */ +#define INT_STS_TXSO 0x00010000 /* R/WC */ +#define INT_STS_RWT 0x00008000 /* R/WC */ +#define INT_STS_RXE 0x00004000 /* R/WC */ +#define INT_STS_TXE 0x00002000 /* R/WC */ +/*#define INT_STS_ERX 0x00001000*/ /* R/WC */ +#define INT_STS_TDFU 0x00000800 /* R/WC */ +#define INT_STS_TDFO 0x00000400 /* R/WC */ +#define INT_STS_TDFA 0x00000200 /* R/WC */ +#define INT_STS_TSFF 0x00000100 /* R/WC */ +#define INT_STS_TSFL 0x00000080 /* R/WC */ +/*#define INT_STS_RXDF 0x00000040*/ /* R/WC */ +#define INT_STS_RDFO 0x00000040 /* R/WC */ +#define INT_STS_RDFL 0x00000020 /* R/WC */ +#define INT_STS_RSFF 0x00000010 /* R/WC */ +#define INT_STS_RSFL 0x00000008 /* R/WC */ +#define INT_STS_GPIO2_INT 0x00000004 /* R/WC */ +#define INT_STS_GPIO1_INT 0x00000002 /* R/WC */ +#define INT_STS_GPIO0_INT 0x00000001 /* R/WC */ +#define INT_EN (CONFIG_DRIVER_SMC911X_BASE + 0x5C) +#define INT_EN_SW_INT_EN 0x80000000 /* R/W */ +#define INT_EN_TXSTOP_INT_EN 0x02000000 /* R/W */ +#define INT_EN_RXSTOP_INT_EN 0x01000000 /* R/W */ +#define INT_EN_RXDFH_INT_EN 0x00800000 /* R/W */ +/*#define INT_EN_RXDF_INT_EN 0x00400000*/ /* R/W */ +#define INT_EN_TIOC_INT_EN 0x00200000 /* R/W */ +#define INT_EN_RXD_INT_EN 0x00100000 /* R/W */ +#define INT_EN_GPT_INT_EN 0x00080000 /* R/W */ +#define INT_EN_PHY_INT_EN 0x00040000 /* R/W */ +#define INT_EN_PME_INT_EN 0x00020000 /* R/W */ +#define INT_EN_TXSO_EN 0x00010000 /* R/W */ +#define INT_EN_RWT_EN 0x00008000 /* R/W */ +#define INT_EN_RXE_EN 0x00004000 /* R/W */ +#define INT_EN_TXE_EN 0x00002000 /* R/W */ +/*#define INT_EN_ERX_EN 0x00001000*/ /* R/W */ +#define INT_EN_TDFU_EN 0x00000800 /* R/W */ +#define INT_EN_TDFO_EN 0x00000400 /* R/W */ +#define INT_EN_TDFA_EN 0x00000200 /* R/W */ +#define INT_EN_TSFF_EN 0x00000100 /* R/W */ +#define INT_EN_TSFL_EN 0x00000080 /* R/W */ +/*#define INT_EN_RXDF_EN 0x00000040*/ /* R/W */ +#define INT_EN_RDFO_EN 0x00000040 /* R/W */ +#define INT_EN_RDFL_EN 0x00000020 /* R/W */ +#define INT_EN_RSFF_EN 0x00000010 /* R/W */ +#define INT_EN_RSFL_EN 0x00000008 /* R/W */ +#define INT_EN_GPIO2_INT 0x00000004 /* R/W */ +#define INT_EN_GPIO1_INT 0x00000002 /* R/W */ +#define INT_EN_GPIO0_INT 0x00000001 /* R/W */ + +#define BYTE_TEST (CONFIG_DRIVER_SMC911X_BASE + 0x64) +#define FIFO_INT (CONFIG_DRIVER_SMC911X_BASE + 0x68) +#define FIFO_INT_TX_AVAIL_LEVEL 0xFF000000 /* R/W */ +#define FIFO_INT_TX_STS_LEVEL 0x00FF0000 /* R/W */ +#define FIFO_INT_RX_AVAIL_LEVEL 0x0000FF00 /* R/W */ +#define FIFO_INT_RX_STS_LEVEL 0x000000FF /* R/W */ + +#define RX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x6C) +#define RX_CFG_RX_END_ALGN 0xC0000000 /* R/W */ +#define RX_CFG_RX_END_ALGN4 0x00000000 /* R/W */ +#define RX_CFG_RX_END_ALGN16 0x40000000 /* R/W */ +#define RX_CFG_RX_END_ALGN32 0x80000000 /* R/W */ +#define RX_CFG_RX_DMA_CNT 0x0FFF0000 /* R/W */ +#define RX_CFG_RX_DUMP 0x00008000 /* R/W */ +#define RX_CFG_RXDOFF 0x00001F00 /* R/W */ +/*#define RX_CFG_RXBAD 0x00000001*/ /* R/W */ + +#define TX_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x70) +/*#define TX_CFG_TX_DMA_LVL 0xE0000000*/ /* R/W */ +/*#define TX_CFG_TX_DMA_CNT 0x0FFF0000*/ /* R/W Self Clearing */ +#define TX_CFG_TXS_DUMP 0x00008000 /* Self Clearing */ +#define TX_CFG_TXD_DUMP 0x00004000 /* Self Clearing */ +#define TX_CFG_TXSAO 0x00000004 /* R/W */ +#define TX_CFG_TX_ON 0x00000002 /* R/W */ +#define TX_CFG_STOP_TX 0x00000001 /* Self Clearing */ + +#define HW_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x74) +#define HW_CFG_TTM 0x00200000 /* R/W */ +#define HW_CFG_SF 0x00100000 /* R/W */ +#define HW_CFG_TX_FIF_SZ 0x000F0000 /* R/W */ +#define HW_CFG_TR 0x00003000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL 0x00000060 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_INT_PHY 0x00000000 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_EXT_PHY 0x00000020 /* R/W */ +#define HW_CFG_PHY_CLK_SEL_CLK_DIS 0x00000040 /* R/W */ +#define HW_CFG_SMI_SEL 0x00000010 /* R/W */ +#define HW_CFG_EXT_PHY_DET 0x00000008 /* RO */ +#define HW_CFG_EXT_PHY_EN 0x00000004 /* R/W */ +#define HW_CFG_32_16_BIT_MODE 0x00000004 /* RO */ +#define HW_CFG_SRST_TO 0x00000002 /* RO */ +#define HW_CFG_SRST 0x00000001 /* Self Clearing */ + +#define RX_DP_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x78) +#define RX_DP_CTRL_RX_FFWD 0x80000000 /* R/W */ +#define RX_DP_CTRL_FFWD_BUSY 0x80000000 /* RO */ + +#define RX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x7C) +#define RX_FIFO_INF_RXSUSED 0x00FF0000 /* RO */ +#define RX_FIFO_INF_RXDUSED 0x0000FFFF /* RO */ + +#define TX_FIFO_INF (CONFIG_DRIVER_SMC911X_BASE + 0x80) +#define TX_FIFO_INF_TSUSED 0x00FF0000 /* RO */ +#define TX_FIFO_INF_TDFREE 0x0000FFFF /* RO */ + +#define PMT_CTRL (CONFIG_DRIVER_SMC911X_BASE + 0x84) +#define PMT_CTRL_PM_MODE 0x00003000 /* Self Clearing */ +#define PMT_CTRL_PHY_RST 0x00000400 /* Self Clearing */ +#define PMT_CTRL_WOL_EN 0x00000200 /* R/W */ +#define PMT_CTRL_ED_EN 0x00000100 /* R/W */ +#define PMT_CTRL_PME_TYPE 0x00000040 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_WUPS 0x00000030 /* R/WC */ +#define PMT_CTRL_WUPS_NOWAKE 0x00000000 /* R/WC */ +#define PMT_CTRL_WUPS_ED 0x00000010 /* R/WC */ +#define PMT_CTRL_WUPS_WOL 0x00000020 /* R/WC */ +#define PMT_CTRL_WUPS_MULTI 0x00000030 /* R/WC */ +#define PMT_CTRL_PME_IND 0x00000008 /* R/W */ +#define PMT_CTRL_PME_POL 0x00000004 /* R/W */ +#define PMT_CTRL_PME_EN 0x00000002 /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_READY 0x00000001 /* RO */ + +#define GPIO_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x88) +#define GPIO_CFG_LED3_EN 0x40000000 /* R/W */ +#define GPIO_CFG_LED2_EN 0x20000000 /* R/W */ +#define GPIO_CFG_LED1_EN 0x10000000 /* R/W */ +#define GPIO_CFG_GPIO2_INT_POL 0x04000000 /* R/W */ +#define GPIO_CFG_GPIO1_INT_POL 0x02000000 /* R/W */ +#define GPIO_CFG_GPIO0_INT_POL 0x01000000 /* R/W */ +#define GPIO_CFG_EEPR_EN 0x00700000 /* R/W */ +#define GPIO_CFG_GPIOBUF2 0x00040000 /* R/W */ +#define GPIO_CFG_GPIOBUF1 0x00020000 /* R/W */ +#define GPIO_CFG_GPIOBUF0 0x00010000 /* R/W */ +#define GPIO_CFG_GPIODIR2 0x00000400 /* R/W */ +#define GPIO_CFG_GPIODIR1 0x00000200 /* R/W */ +#define GPIO_CFG_GPIODIR0 0x00000100 /* R/W */ +#define GPIO_CFG_GPIOD4 0x00000010 /* R/W */ +#define GPIO_CFG_GPIOD3 0x00000008 /* R/W */ +#define GPIO_CFG_GPIOD2 0x00000004 /* R/W */ +#define GPIO_CFG_GPIOD1 0x00000002 /* R/W */ +#define GPIO_CFG_GPIOD0 0x00000001 /* R/W */ + +#define GPT_CFG (CONFIG_DRIVER_SMC911X_BASE + 0x8C) +#define GPT_CFG_TIMER_EN 0x20000000 /* R/W */ +#define GPT_CFG_GPT_LOAD 0x0000FFFF /* R/W */ + +#define GPT_CNT (CONFIG_DRIVER_SMC911X_BASE + 0x90) +#define GPT_CNT_GPT_CNT 0x0000FFFF /* RO */ + +#define ENDIAN (CONFIG_DRIVER_SMC911X_BASE + 0x98) +#define FREE_RUN (CONFIG_DRIVER_SMC911X_BASE + 0x9C) +#define RX_DROP (CONFIG_DRIVER_SMC911X_BASE + 0xA0) +#define MAC_CSR_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xA4) +#define MAC_CSR_CMD_CSR_BUSY 0x80000000 /* Self Clearing */ +#define MAC_CSR_CMD_R_NOT_W 0x40000000 /* R/W */ +#define MAC_CSR_CMD_CSR_ADDR 0x000000FF /* R/W */ + +#define MAC_CSR_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xA8) +#define AFC_CFG (CONFIG_DRIVER_SMC911X_BASE + 0xAC) +#define AFC_CFG_AFC_HI 0x00FF0000 /* R/W */ +#define AFC_CFG_AFC_LO 0x0000FF00 /* R/W */ +#define AFC_CFG_BACK_DUR 0x000000F0 /* R/W */ +#define AFC_CFG_FCMULT 0x00000008 /* R/W */ +#define AFC_CFG_FCBRD 0x00000004 /* R/W */ +#define AFC_CFG_FCADD 0x00000002 /* R/W */ +#define AFC_CFG_FCANY 0x00000001 /* R/W */ + +#define E2P_CMD (CONFIG_DRIVER_SMC911X_BASE + 0xB0) +#define E2P_CMD_EPC_BUSY 0x80000000 /* Self Clearing */ +#define E2P_CMD_EPC_CMD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_CMD_READ 0x00000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWDS 0x10000000 /* R/W */ +#define E2P_CMD_EPC_CMD_EWEN 0x20000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRITE 0x30000000 /* R/W */ +#define E2P_CMD_EPC_CMD_WRAL 0x40000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERASE 0x50000000 /* R/W */ +#define E2P_CMD_EPC_CMD_ERAL 0x60000000 /* R/W */ +#define E2P_CMD_EPC_CMD_RELOAD 0x70000000 /* R/W */ +#define E2P_CMD_EPC_TIMEOUT 0x00000200 /* RO */ +#define E2P_CMD_MAC_ADDR_LOADED 0x00000100 /* RO */ +#define E2P_CMD_EPC_ADDR 0x000000FF /* R/W */ + +#define E2P_DATA (CONFIG_DRIVER_SMC911X_BASE + 0xB4) +#define E2P_DATA_EEPROM_DATA 0x000000FF /* R/W */ /* end of LAN register offsets and bit definitions */
/* MAC Control and Status registers */ -#define MAC_CR (0x01) /* R/W */ +#define MAC_CR 0x01 /* R/W */
/* MAC_CR - MAC Control Register */ -#define MAC_CR_RXALL (0x80000000) +#define MAC_CR_RXALL 0x80000000 /* TODO: delete this bit? It is not described in the data sheet. */ -#define MAC_CR_HBDIS (0x10000000) -#define MAC_CR_RCVOWN (0x00800000) -#define MAC_CR_LOOPBK (0x00200000) -#define MAC_CR_FDPX (0x00100000) -#define MAC_CR_MCPAS (0x00080000) -#define MAC_CR_PRMS (0x00040000) -#define MAC_CR_INVFILT (0x00020000) -#define MAC_CR_PASSBAD (0x00010000) -#define MAC_CR_HFILT (0x00008000) -#define MAC_CR_HPFILT (0x00002000) -#define MAC_CR_LCOLL (0x00001000) -#define MAC_CR_BCAST (0x00000800) -#define MAC_CR_DISRTY (0x00000400) -#define MAC_CR_PADSTR (0x00000100) -#define MAC_CR_BOLMT_MASK (0x000000C0) -#define MAC_CR_DFCHK (0x00000020) -#define MAC_CR_TXEN (0x00000008) -#define MAC_CR_RXEN (0x00000004) - -#define ADDRH (0x02) /* R/W mask 0x0000FFFFUL */ -#define ADDRL (0x03) /* R/W mask 0xFFFFFFFFUL */ -#define HASHH (0x04) /* R/W */ -#define HASHL (0x05) /* R/W */ - -#define MII_ACC (0x06) /* R/W */ -#define MII_ACC_PHY_ADDR (0x0000F800) -#define MII_ACC_MIIRINDA (0x000007C0) -#define MII_ACC_MII_WRITE (0x00000002) -#define MII_ACC_MII_BUSY (0x00000001) - -#define MII_DATA (0x07) /* R/W mask 0x0000FFFFUL */ - -#define FLOW (0x08) /* R/W */ -#define FLOW_FCPT (0xFFFF0000) -#define FLOW_FCPASS (0x00000004) -#define FLOW_FCEN (0x00000002) -#define FLOW_FCBSY (0x00000001) - -#define VLAN1 (0x09) /* R/W mask 0x0000FFFFUL */ -#define VLAN1_VTI1 (0x0000ffff) - -#define VLAN2 (0x0A) /* R/W mask 0x0000FFFFUL */ -#define VLAN2_VTI2 (0x0000ffff) - -#define WUFF (0x0B) /* WO */ - -#define WUCSR (0x0C) /* R/W */ -#define WUCSR_GUE (0x00000200) -#define WUCSR_WUFR (0x00000040) -#define WUCSR_MPR (0x00000020) -#define WUCSR_WAKE_EN (0x00000004) -#define WUCSR_MPEN (0x00000002) +#define MAC_CR_HBDIS 0x10000000 +#define MAC_CR_RCVOWN 0x00800000 +#define MAC_CR_LOOPBK 0x00200000 +#define MAC_CR_FDPX 0x00100000 +#define MAC_CR_MCPAS 0x00080000 +#define MAC_CR_PRMS 0x00040000 +#define MAC_CR_INVFILT 0x00020000 +#define MAC_CR_PASSBAD 0x00010000 +#define MAC_CR_HFILT 0x00008000 +#define MAC_CR_HPFILT 0x00002000 +#define MAC_CR_LCOLL 0x00001000 +#define MAC_CR_BCAST 0x00000800 +#define MAC_CR_DISRTY 0x00000400 +#define MAC_CR_PADSTR 0x00000100 +#define MAC_CR_BOLMT_MASK 0x000000C0 +#define MAC_CR_DFCHK 0x00000020 +#define MAC_CR_TXEN 0x00000008 +#define MAC_CR_RXEN 0x00000004 + +#define ADDRH 0x02 /* R/W mask 0x0000FFFFUL */ +#define ADDRL 0x03 /* R/W mask 0xFFFFFFFFUL */ +#define HASHH 0x04 /* R/W */ +#define HASHL 0x05 /* R/W */ + +#define MII_ACC 0x06 /* R/W */ +#define MII_ACC_PHY_ADDR 0x0000F800 +#define MII_ACC_MIIRINDA 0x000007C0 +#define MII_ACC_MII_WRITE 0x00000002 +#define MII_ACC_MII_BUSY 0x00000001 + +#define MII_DATA 0x07 /* R/W mask 0x0000FFFFUL */ + +#define FLOW 0x08 /* R/W */ +#define FLOW_FCPT 0xFFFF0000 +#define FLOW_FCPASS 0x00000004 +#define FLOW_FCEN 0x00000002 +#define FLOW_FCBSY 0x00000001 + +#define VLAN1 0x09 /* R/W mask 0x0000FFFFUL */ +#define VLAN1_VTI1 0x0000ffff + +#define VLAN2 0x0A /* R/W mask 0x0000FFFFUL */ +#define VLAN2_VTI2 0x0000ffff + +#define WUFF 0x0B /* WO */ + +#define WUCSR 0x0C /* R/W */ +#define WUCSR_GUE 0x00000200 +#define WUCSR_WUFR 0x00000040 +#define WUCSR_MPR 0x00000020 +#define WUCSR_WAKE_EN 0x00000004 +#define WUCSR_MPEN 0x00000002
/* Chip ID values */ #define CHIP_9115 0x115 @@ -377,19 +388,23 @@ static const struct chip_id chip_ids[] = {
u32 smc911x_get_mac_csr(u8 reg) { - while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); - MAC_CSR_CMD = MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg; - while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ;
- return MAC_CSR_DATA; + return reg_read(MAC_CSR_DATA); }
void smc911x_set_mac_csr(u8 reg, u32 data) { - while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); - MAC_CSR_DATA = data; - MAC_CSR_CMD = MAC_CSR_CMD_CSR_BUSY | reg; - while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; + reg_write(MAC_CSR_DATA, data); + reg_write(MAC_CSR_CMD, MAC_CSR_CMD_CSR_BUSY | reg); + while (reg_read(MAC_CSR_CMD) & MAC_CSR_CMD_CSR_BUSY) + ; }
static int smx911x_handle_mac_address(bd_t *bd) @@ -431,11 +446,13 @@ static int smx911x_handle_mac_address(bd_t *bd)
static int smc911x_miiphy_read(u8 phy, u8 reg, u16 *val) { - while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY) + ;
- smc911x_set_mac_csr( MII_ACC, phy << 11 | reg << 6 | MII_ACC_MII_BUSY); + smc911x_set_mac_csr(MII_ACC, phy << 11 | reg << 6 | MII_ACC_MII_BUSY);
*val = smc911x_get_mac_csr(MII_DATA);
@@ -444,13 +461,15 @@ static int smc911x_miiphy_read(u8 phy, u8 reg, u16 *val)
static int smc911x_miiphy_write(u8 phy, u8 reg, u16 val) { - while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY) + ;
smc911x_set_mac_csr(MII_DATA, val); smc911x_set_mac_csr(MII_ACC, phy << 11 | reg << 6 | MII_ACC_MII_BUSY | MII_ACC_MII_WRITE);
- while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY) + ; return 0; }
@@ -458,10 +477,10 @@ static int smc911x_phy_reset(void) { u32 reg;
- reg = PMT_CTRL; + reg = reg_read(PMT_CTRL); reg &= ~0xfffff030; reg |= PMT_CTRL_PHY_RST; - PMT_CTRL = reg; + reg_write(PMT_CTRL, reg);
mdelay(100);
@@ -503,13 +522,13 @@ static void smc911x_reset(void) int timeout;
/* Take out of PM setting first */ - if (PMT_CTRL & PMT_CTRL_READY) { + if (reg_read(PMT_CTRL) & PMT_CTRL_READY) { /* Write to the bytetest will take out of powerdown */ - BYTE_TEST = 0x0; + reg_write(BYTE_TEST, 0x0);
timeout = 10;
- while ( timeout-- && !(PMT_CTRL & PMT_CTRL_READY)) + while (timeout-- && !(reg_read(PMT_CTRL) & PMT_CTRL_READY)) udelay(10); if (!timeout) { printf(DRIVERNAME @@ -519,38 +538,38 @@ static void smc911x_reset(void) }
/* Disable interrupts */ - INT_EN = 0; + reg_write(INT_EN, 0);
- HW_CFG = HW_CFG_SRST; + reg_write(HW_CFG, HW_CFG_SRST);
timeout = 1000; - while (timeout-- && E2P_CMD & E2P_CMD_EPC_BUSY) + while (timeout-- && reg_read(E2P_CMD) & E2P_CMD_EPC_BUSY) udelay(10);
- if(!timeout) { + if (!timeout) { printf(DRIVERNAME ": reset timeout\n"); return; }
/* Reset the FIFO level and flow control settings */ smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); - AFC_CFG = 0x0050287F; + reg_write(AFC_CFG, 0x0050287F);
/* Set to LED outputs */ - GPIO_CFG = 0x70070000; + reg_write(GPIO_CFG, 0x70070000); }
static void smc911x_enable(void) { /* Enable TX */ - HW_CFG = 8 << 16 | HW_CFG_SF; + reg_write(HW_CFG, 8 << 16 | HW_CFG_SF);
- GPT_CFG = GPT_CFG_TIMER_EN | 10000; + reg_write(GPT_CFG, GPT_CFG_TIMER_EN | 10000);
- TX_CFG = TX_CFG_TX_ON; + reg_write(TX_CFG, TX_CFG_TX_ON);
/* no padding to start of packets */ - RX_CFG = 0; + reg_write(RX_CFG, 0);
smc911x_set_mac_csr(MAC_CR, MAC_CR_TXEN | MAC_CR_RXEN | MAC_CR_HBDIS);
@@ -562,14 +581,14 @@ int eth_init(bd_t *bd)
printf(DRIVERNAME ": initializing\n");
- val = BYTE_TEST; - if(val != 0x87654321) { + val = reg_read(BYTE_TEST); + if (val != 0x87654321) { printf(DRIVERNAME ": Invalid chip endian 0x08%x\n", val); goto err_out; }
- val = ID_REV >> 16; - for(i = 0; chip_ids[i].id != 0; i++) { + val = reg_read(ID_REV) >> 16; + for (i = 0; chip_ids[i].id != 0; i++) { if (chip_ids[i].id == val) break; } if (!chip_ids[i].id) { @@ -602,24 +621,24 @@ int eth_send(volatile void *packet, int length) u32 tmplen; u32 status;
- TX_DATA_FIFO = TX_CMD_A_INT_FIRST_SEG | TX_CMD_A_INT_LAST_SEG | length; - TX_DATA_FIFO = length; + reg_write(TX_DATA_FIFO, TX_CMD_A_INT_FIRST_SEG | TX_CMD_A_INT_LAST_SEG | length); + reg_write(TX_DATA_FIFO, length);
tmplen = (length + 3) / 4;
- while(tmplen--) - TX_DATA_FIFO = *data++; + while (tmplen--) + reg_write(TX_DATA_FIFO, *data++);
/* wait for transmission */ - while (!((TX_FIFO_INF & TX_FIFO_INF_TSUSED) >> 16)); + while (!((reg_read(TX_FIFO_INF) & TX_FIFO_INF_TSUSED) >> 16));
/* get status. Ignore 'no carrier' error, it has no meaning for * full duplex operation */ - status = TX_STATUS_FIFO & (TX_STS_LOC | TX_STS_LATE_COLL | + status = reg_read(TX_STATUS_FIFO) & (TX_STS_LOC | TX_STS_LATE_COLL | TX_STS_MANY_COLL | TX_STS_MANY_DEFER | TX_STS_UNDERRUN);
- if(!status) + if (!status) return 0;
printf(DRIVERNAME ": failed to send packet: %s%s%s%s%s\n", @@ -643,17 +662,17 @@ int eth_rx(void) u32 pktlen, tmplen; u32 status;
- if((RX_FIFO_INF & RX_FIFO_INF_RXSUSED) >> 16) { - status = RX_STATUS_FIFO; + if ((reg_read(RX_FIFO_INF) & RX_FIFO_INF_RXSUSED) >> 16) { + status = reg_read(RX_STATUS_FIFO); pktlen = (status & RX_STS_PKT_LEN) >> 16;
tmplen = (pktlen + 2+ 3) / 4; - while(tmplen--) - *data++ = RX_DATA_FIFO; + while (tmplen--) + *data++ = reg_read(RX_DATA_FIFO);
- if(status & RX_STS_ES) + if (status & RX_STS_ES) printf(DRIVERNAME ": dropped bad packet. Status: 0x%08x\n", status); diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index eb8435b..9961e05 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -92,6 +92,7 @@
#define CONFIG_DRIVER_SMC911X 1 #define CONFIG_DRIVER_SMC911X_BASE 0xb4020000 +#define CONFIG_DRIVER_SMC911X_32_BIT 1
/* * Miscellaneous configurable options diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 3fbc50f..1fe2979 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -108,6 +108,7 @@
#define CONFIG_DRIVER_SMC911X 1 #define CONFIG_DRIVER_SMC911X_BASE 0xa8000000 +#define CONFIG_DRIVER_SMC911X_32_BIT 1
Much better! Thanks for doing all this work. The only problem is that you're providing it relative to another patch that hasn't been accepted.
regards, Ben
Well, the merge window is closed, so, I cannot send in any more new features. Whereas if we consider this as a fix - maybe it would be possible?
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
I know the timetable says the merge window is closed, but there hasn't been any type of announcement and history tells me that there's probably still time. I have some things I'd still like to get in if possible, but only WD can say for sure, of course.
regards, Ben
He has:
* Now talking on #u-boot * Topic for #u-boot is: Merge Window for 1.3.3 is over - only bug fixes accepted now. * Topic for #u-boot set by wdenk at Tue Apr 1 10:27:53 2008
He has:
- Now talking on #u-boot
- Topic for #u-boot is: Merge Window for 1.3.3 is over - only bug fixes accepted now.
- Topic for #u-boot set by wdenk at Tue Apr 1 10:27:53 2008
OK then. Next revision it is.
regards, Ben
Nope. We're not bureaucrats. We do what technically makes sense. And to me it makes much sense to see this go in now. Thanks in advance.
Works for me. I'll make it happen.
regards, Ben
Oh, there has been an announcement:
Topic for #u-boot: Merge Window for 1.3.3 is over - only bug fixes accepted now. Topic for #u-boot set by wdenk at 2008-04-01 10:27:53
And we don't need formal announcements, or do we? We all know that fe follow the deadlines of our timetable with the precision of a Rolex(*).
(*) one of those you get on ebay really cheap, that is :-)
OK, where do you announce these things, so I can be sure to notice next time? I'm not trying to be a smart-ass, but am really curious.
Who needs eBay when I get all these wonderful e-mails? And it's not only watches!
cheers, Ben
i.e. "#u-boot" IRC channel on irc.freenode.net.
Oh, I didn't know there was a U-boot IRC channel. That will surely make me more productive!
regards, Ben
Well, the quote above refers to the subject on the "u-boot" IRC channel.
Which would be #u-boot on Freenode (irc.freenode.net) for those that don't know the channel even exists.
josh
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of Josh Boyer Sent: 04 April 2008 03:49 To: Wolfgang Denk Cc: u-boot-users@lists.sourceforge.net; Ben Warren Subject: Re: [U-Boot-Users] [PATCH] Clean up smsc911x driver
to notice
really curious.
josh
Thanks josh
Regards
Peter
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.n et/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
It isn't exactly a U-Boot Weather Forecast[1], but I've updated the status page. http://www.denx.de/wiki/UBoot/ReleaseCycle
gvb
[1] http://www.linux-foundation.org/index.php?title=Linux_Weather_Forecast
Providing a different version of a patch is a fix of some kind.
Yes, "we" consider this as a fix.
participants (6)
Ben Warren
Jerry Van Baren
Josh Boyer
Peter Pearse
