[U-Boot] [PATCH] imx: Make NAND BCB dependent on ARCH_MX6
The options to enable CMD_NANDBCB appear when the i.MX6 is not the target architecture, but it only applies to the i.MX6.
This patch makes the option depend on ARCH_MX6 so it's hidden from irrelevant platforms.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index b0b9d2c070..2b8d223b92 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -80,8 +80,8 @@ config CMD_HDMIDETECT
config CMD_NANDBCB bool "i.MX6 NAND Boot Control Block(BCB) command" - depends on NAND && CMD_MTDPARTS - default y if ARCH_MX6 && NAND_MXS + depends on NAND && CMD_MTDPARTS && ARCH_MX6 + default y if NAND_MXS help Unlike normal 'nand write/erase' commands, this command update Boot Control Block(BCB) for i.MX6 platform NAND IP's.
Adam Ford
