[U-Boot] [PATCH] Remove ${objtree}/include/asm/proc/ link
mkconfig links ${objtree}/include/asm/proc/ to ${srctree}/arch/${arch}/include/asm/proc-armv/. This seems to be a remnant from the past. Ever since its introduction in 2003 it is used only in ARM build and always links to same place, so let's simplify the code, remove it and reference directly where needed.
Successful MAKEALL for ARM and PowerPC verified on Linux.
Signed-off-by: Vasili Galka vvv444@gmail.com --- arch/arm/include/asm/atomic.h | 2 +- arch/arm/include/asm/bitops.h | 2 +- arch/arm/include/asm/proc-armv/processor.h | 2 +- arch/arm/include/asm/processor.h | 2 +- arch/arm/include/asm/ptrace.h | 2 +- mkconfig | 5 ----- 6 files changed, 5 insertions(+), 10 deletions(-)
diff --git a/arch/arm/include/asm/atomic.h b/arch/arm/include/asm/atomic.h index 1b22eeb..34c07fe 100644 --- a/arch/arm/include/asm/atomic.h +++ b/arch/arm/include/asm/atomic.h @@ -25,7 +25,7 @@ typedef struct { volatile int counter; } atomic_t; #define ATOMIC_INIT(i) { (i) }
#ifdef __KERNEL__ -#include <asm/proc/system.h> +#include <asm/proc-armv/system.h>
#define atomic_read(v) ((v)->counter) #define atomic_set(v,i) (((v)->counter) = (i)) diff --git a/arch/arm/include/asm/bitops.h b/arch/arm/include/asm/bitops.h index 879e20e..597dafb 100644 --- a/arch/arm/include/asm/bitops.h +++ b/arch/arm/include/asm/bitops.h @@ -17,7 +17,7 @@
#ifdef __KERNEL__
#define smp_mb__before_clear_bit() do { } while (0) #define smp_mb__after_clear_bit() do { } while (0) diff --git a/arch/arm/include/asm/proc-armv/processor.h b/arch/arm/include/asm/proc-armv/processor.h index 5bfab7f..532f207 100644 --- a/arch/arm/include/asm/proc-armv/processor.h +++ b/arch/arm/include/asm/proc-armv/processor.h @@ -18,7 +18,7 @@ #ifndef __ASM_PROC_PROCESSOR_H #define __ASM_PROC_PROCESSOR_H
-#include <asm/proc/domain.h> +#include <asm/proc-armv/domain.h>
#define KERNEL_STACK_SIZE PAGE_SIZE
diff --git a/arch/arm/include/asm/processor.h b/arch/arm/include/asm/processor.h index 445d449..83481c6 100644 --- a/arch/arm/include/asm/processor.h +++ b/arch/arm/include/asm/processor.h @@ -45,7 +45,7 @@ typedef unsigned long mm_segment_t; /* domain register */ #if 0 /* XXX###XXX */ #include <asm/arch/memory.h> #endif /* XXX###XXX */ -#include <asm/proc/processor.h> +#include <asm/proc-armv/processor.h> #include <asm/types.h>
union debug_insn { diff --git a/arch/arm/include/asm/ptrace.h b/arch/arm/include/asm/ptrace.h index 73c9087..a836f6c 100644 --- a/arch/arm/include/asm/ptrace.h +++ b/arch/arm/include/asm/ptrace.h @@ -11,7 +11,7 @@ /* options set using PTRACE_SETOPTIONS */ #define PTRACE_O_TRACESYSGOOD 0x00000001
-#include <asm/proc/ptrace.h> +#include <asm/proc-armv/ptrace.h>
#ifndef __ASSEMBLY__ #define pc_pointer(v) \ diff --git a/mkconfig b/mkconfig index cd911a9..2bf5897 100755 --- a/mkconfig +++ b/mkconfig @@ -120,11 +120,6 @@ else ln -s ${LNPREFIX}arch-${soc} asm/arch fi
-if [ "${arch}" = "arm" ] ; then - rm -f asm/proc - ln -s ${LNPREFIX}proc-armv asm/proc -fi - if [ -z "$KBUILD_SRC" ] ; then cd ${srctree}/include fi
Vasili Galka
