[PATCH 1/2] phy: Fix node description of phy_get_by_node
node is most of device related API's are termed as device node and without device related API's are termed as ofnode.
generic_phy_get_by_node API is without device API, so fixed the node description as ofnode.
Cc: Neil Armstrong narmstrong@baylibre.com Cc: Tom Rini trini@konsulko.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- include/generic-phy.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/generic-phy.h b/include/generic-phy.h index 73537025c2..e30440d35e 100644 --- a/include/generic-phy.h +++ b/include/generic-phy.h @@ -198,7 +198,7 @@ int generic_phy_get_by_index(struct udevice *user, int index, /** * generic_phy_get_by_node() - Get a PHY device by integer index on ofnode * - * @node: the device node + * @node: The client ofnode. * @index: The index in the list of available PHYs * @phy: A pointer to the PHY port *
Clients that are requesting some of uclass API's without a device (with ofnode) usually have _nodev naming convention.
- clk_get_by_index_nodev - clk_get_by_name_nodev - reset_get_by_index_nodev - gpio_request_by_name_nodev
So, update the same naming convention PHY framework.
This doesn't change the existing functionality.
Cc: Neil Armstrong narmstrong@baylibre.com Cc: Tom Rini trini@konsulko.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/mach-meson/board-gx.c | 3 ++- drivers/phy/phy-uclass.c | 4 ++-- include/generic-phy.h | 7 +++++-- 3 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index 3da99017a5..b591c924ea 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -183,7 +183,8 @@ int board_usb_init(int index, enum usb_init_type init)
/* get the PHYs */ for (i = 0; i < 2; i++) { - ret = generic_phy_get_by_node(dwc2_node, i, &usb_phys[i]); + ret = generic_phy_get_by_index_nodev(dwc2_node, i, + &usb_phys[i]); if (ret && ret != -ENOENT) { pr_err("Failed to get USB PHY%d for %s\n", i, ofnode_get_name(dwc2_node)); diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c index e463b0b400..8091fc0969 100644 --- a/drivers/phy/phy-uclass.c +++ b/drivers/phy/phy-uclass.c @@ -31,7 +31,7 @@ static int generic_phy_xlate_offs_flags(struct phy *phy, return 0; }
-int generic_phy_get_by_node(ofnode node, int index, struct phy *phy) +int generic_phy_get_by_index_nodev(ofnode node, int index, struct phy *phy) { struct ofnode_phandle_args args; struct phy_ops *ops; @@ -93,7 +93,7 @@ err: int generic_phy_get_by_index(struct udevice *dev, int index, struct phy *phy) { - return generic_phy_get_by_node(dev_ofnode(dev), index, phy); + return generic_phy_get_by_index_nodev(dev_ofnode(dev), index, phy); }
int generic_phy_get_by_name(struct udevice *dev, const char *phy_name, diff --git a/include/generic-phy.h b/include/generic-phy.h index e30440d35e..07e4c6f7a0 100644 --- a/include/generic-phy.h +++ b/include/generic-phy.h @@ -196,12 +196,15 @@ int generic_phy_get_by_index(struct udevice *user, int index, struct phy *phy);
/** - * generic_phy_get_by_node() - Get a PHY device by integer index on ofnode + * generic_phy_get_by_index_nodev() - Get a PHY device by integer index + * without a device * * @node: The client ofnode. * @index: The index in the list of available PHYs * @phy: A pointer to the PHY port * + * This is a version of generic_phy_get_by_index() that does not use a device. + * * This looks up a PHY device for a client device based on its ofnode and on * its position in the list of the possible PHYs. * @@ -220,7 +223,7 @@ int generic_phy_get_by_index(struct udevice *user, int index, * * @return 0 if OK, or a negative error code */ -int generic_phy_get_by_node(ofnode node, int index, struct phy *phy); +int generic_phy_get_by_index_nodev(ofnode node, int index, struct phy *phy);
/** * generic_phy_get_by_name() - Get a PHY device by its name.
Hi Tom,
Planning to apply these via spi tree, let me know if you have any questions? thanks!
Jagan.
Applied both to u-boot-spi/master
Jagan Teki
