[PATCH 1/2] arm64: zynqmp: Describe TI phy as ethernet-phy-id
TI DP83867 is using strapping based on MIO pins. Tristate setup can influce PHY address. That's why switch description with ethernet-phy-id compatible string which enable calling reset. PHY itself setups phy address after power up or reset. Reset description will be added in separate commit.
Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/dts/zynqmp-zcu102-revA.dts | 20 +++++++++++++------- arch/arm/dts/zynqmp-zcu104-revA.dts | 18 ++++++++++++------ arch/arm/dts/zynqmp-zcu104-revC.dts | 18 ++++++++++++------ arch/arm/dts/zynqmp-zcu111-revA.dts | 18 ++++++++++++------ arch/arm/dts/zynqmp-zcu208-revA.dts | 18 ++++++++++++------ arch/arm/dts/zynqmp-zcu216-revA.dts | 19 ++++++++++++------- 6 files changed, 73 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index 71c3dde4bf21..f04bc9969bd0 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -217,13 +217,19 @@ phy-mode = "rgmii-id"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gem3_default>; - phy0: ethernet-phy@21 { - reg = <21>; - ti,rx-internal-delay = <0x8>; - ti,tx-internal-delay = <0xa>; - ti,fifo-depth = <0x1>; - ti,dp83867-rxctrl-strap-quirk; - /* reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; */ + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@21 { + #phy-cells = <1>; + compatible = "ethernet-phy-id2000.a231"; + reg = <21>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + /* reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; */ + }; }; };
diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index 1418cffb2042..6df9a1343859 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -109,12 +109,18 @@ phy-mode = "rgmii-id"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gem3_default>; - phy0: ethernet-phy@c { - reg = <0xc>; - ti,rx-internal-delay = <0x8>; - ti,tx-internal-delay = <0xa>; - ti,fifo-depth = <0x1>; - ti,dp83867-rxctrl-strap-quirk; + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@c { + #phy-cells = <1>; + compatible = "ethernet-phy-id2000.a231"; + reg = <0xc>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + }; }; };
diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index 7fd19ca3a8c0..0721516bd109 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -114,12 +114,18 @@ phy-mode = "rgmii-id"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gem3_default>; - phy0: ethernet-phy@c { - reg = <0xc>; - ti,rx-internal-delay = <0x8>; - ti,tx-internal-delay = <0xa>; - ti,fifo-depth = <0x1>; - ti,dp83867-rxctrl-strap-quirk; + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@c { + #phy-cells = <1>; + compatible = "ethernet-phy-id2000.a231"; + reg = <0xc>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + }; }; };
diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index e412992ff1bd..c37c4b8b6177 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -172,12 +172,18 @@ phy-mode = "rgmii-id"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gem3_default>; - phy0: ethernet-phy@c { - reg = <0xc>; - ti,rx-internal-delay = <0x8>; - ti,tx-internal-delay = <0xa>; - ti,fifo-depth = <0x1>; - ti,dp83867-rxctrl-strap-quirk; + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@c { + #phy-cells = <1>; + compatible = "ethernet-phy-id2000.a231"; + reg = <0xc>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + }; }; };
diff --git a/arch/arm/dts/zynqmp-zcu208-revA.dts b/arch/arm/dts/zynqmp-zcu208-revA.dts index c5cdd58af6ed..3e8ee429eb79 100644 --- a/arch/arm/dts/zynqmp-zcu208-revA.dts +++ b/arch/arm/dts/zynqmp-zcu208-revA.dts @@ -169,12 +169,18 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: ethernet-phy@c { - reg = <0xc>; - ti,rx-internal-delay = <0x8>; - ti,tx-internal-delay = <0xa>; - ti,fifo-depth = <0x1>; - ti,dp83867-rxctrl-strap-quirk; + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@c { + #phy-cells = <1>; + compatible = "ethernet-phy-id2000.a231"; + reg = <0xc>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + }; }; };
diff --git a/arch/arm/dts/zynqmp-zcu216-revA.dts b/arch/arm/dts/zynqmp-zcu216-revA.dts index caae16965d6f..80e7ddb97080 100644 --- a/arch/arm/dts/zynqmp-zcu216-revA.dts +++ b/arch/arm/dts/zynqmp-zcu216-revA.dts @@ -176,15 +176,20 @@ status = "okay"; phy-handle = <&phy0>; phy-mode = "rgmii-id"; - phy0: ethernet-phy@c { - reg = <0xc>; - ti,rx-internal-delay = <0x8>; - ti,tx-internal-delay = <0xa>; - ti,fifo-depth = <0x1>; - ti,dp83867-rxctrl-strap-quirk; + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@c { + #phy-cells = <1>; + compatible = "ethernet-phy-id2000.a231"; + reg = <0xc>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + ti,dp83867-rxctrl-strap-quirk; + }; }; }; - &gpio { status = "okay"; gpio-line-names = "QSPI_LWR_CLK", "QSPI_LWR_DQ1", "QSPI_LWR_DQ2", "QSPI_LWR_DQ3", "QSPI_LWR_DQ0", /* 0 - 4 */
With ethernet-phy-id driver ETH phy reset can be properly handle that's why describe it in DT.
arch/arm/dts/zynqmp-zcu102-revA.dts | 2 +- arch/arm/dts/zynqmp-zcu104-revA.dts | 1 + arch/arm/dts/zynqmp-zcu104-revC.dts | 1 + arch/arm/dts/zynqmp-zcu111-revA.dts | 1 + arch/arm/dts/zynqmp-zcu208-revA.dts | 1 + arch/arm/dts/zynqmp-zcu216-revA.dts | 1 + 6 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index f04bc9969bd0..5c890d898ce1 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -228,7 +228,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; - /* reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; */ + reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; }; }; }; diff --git a/arch/arm/dts/zynqmp-zcu104-revA.dts b/arch/arm/dts/zynqmp-zcu104-revA.dts index 6df9a1343859..b9d82afc5188 100644 --- a/arch/arm/dts/zynqmp-zcu104-revA.dts +++ b/arch/arm/dts/zynqmp-zcu104-revA.dts @@ -120,6 +120,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; }; }; }; diff --git a/arch/arm/dts/zynqmp-zcu104-revC.dts b/arch/arm/dts/zynqmp-zcu104-revC.dts index 0721516bd109..6f24e335a19c 100644 --- a/arch/arm/dts/zynqmp-zcu104-revC.dts +++ b/arch/arm/dts/zynqmp-zcu104-revC.dts @@ -125,6 +125,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + reset-gpios = <&tca6416_u97 6 GPIO_ACTIVE_LOW>; }; }; }; diff --git a/arch/arm/dts/zynqmp-zcu111-revA.dts b/arch/arm/dts/zynqmp-zcu111-revA.dts index c37c4b8b6177..2e95f22c3f08 100644 --- a/arch/arm/dts/zynqmp-zcu111-revA.dts +++ b/arch/arm/dts/zynqmp-zcu111-revA.dts @@ -183,6 +183,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + reset-gpios = <&tca6416_u22 6 GPIO_ACTIVE_LOW>; }; }; }; diff --git a/arch/arm/dts/zynqmp-zcu208-revA.dts b/arch/arm/dts/zynqmp-zcu208-revA.dts index 3e8ee429eb79..7e7e1577eb5b 100644 --- a/arch/arm/dts/zynqmp-zcu208-revA.dts +++ b/arch/arm/dts/zynqmp-zcu208-revA.dts @@ -180,6 +180,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + reset-gpios = <&tca6416_u15 6 GPIO_ACTIVE_LOW>; }; }; }; diff --git a/arch/arm/dts/zynqmp-zcu216-revA.dts b/arch/arm/dts/zynqmp-zcu216-revA.dts index 80e7ddb97080..35a30971cb73 100644 --- a/arch/arm/dts/zynqmp-zcu216-revA.dts +++ b/arch/arm/dts/zynqmp-zcu216-revA.dts @@ -187,6 +187,7 @@ ti,tx-internal-delay = <0xa>; ti,fifo-depth = <0x1>; ti,dp83867-rxctrl-strap-quirk; + reset-gpios = <&tca6416_u15 6 GPIO_ACTIVE_LOW>; }; }; };
reg = <21>;
- mdio: mdio {
#size-cells = <0>;
#phy-cells = <1>;
reg = <21>;
reg = <0xc>;
- mdio: mdio {
#size-cells = <0>;
#phy-cells = <1>;
reg = <0xc>;
reg = <0xc>;
- mdio: mdio {
#size-cells = <0>;
#phy-cells = <1>;
reg = <0xc>;
reg = <0xc>;
- mdio: mdio {
#size-cells = <0>;
#phy-cells = <1>;
reg = <0xc>;
reg = <0xc>;
- mdio: mdio {
#size-cells = <0>;
#phy-cells = <1>;
reg = <0xc>;
reg = <0xc>;
- mdio: mdio {
#size-cells = <0>;
#phy-cells = <1>;
reg = <0xc>;
Applied both. M
Michal Simek
