[U-Boot] Pull request: u-boot-riscv/master
Hi Tom,
Please pull some riscv updates:
- sbi: Add newline to error message - fu540: dts: Correct reg size of otp and dmc nodes - Enhance reserved memory fixup about PMP information passed from OpenSbi - sifive: fu540: Add gpio-restart support - qemu: Add syscon reboot and poweroff support - qemu-riscv: Update QEMU run command - Assorted fixes related to reserved memory - fu540: enable all cache ways from U-Boot proper - use log functions in fdt_fixup
Thanks Rick
https://travis-ci.org/github/rickchen36/u-boot-riscv/builds/703843003
The following changes since commit bcfe764ee925d0820e82c69ccf75b71d142644c7:
Merge tag 'efi-2020-07-rc6-2' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2020-06-30 17:15:39 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to f889e3183a003e4e238f87cc9bb01bfcbd5548a5:
riscv: use log functions in fdt_fixup (2020-07-02 10:31:39 +0800)
---------------------------------------------------------------- Atish Patra (2): riscv: Do not return error if reserved node already exists riscv: Use optimized version of fdtdec_get_addr_size_no_parent
Bin Meng (11): riscv: fu540: dts: Remove the unnecessary space in the cpu2_intc node riscv: fu540: dts: Correct reg size of otp and dmc nodes riscv: Avoid the reserved memory fixup if src and dst point to the same place riscv: Expand the DT size before copy reserved memory node riscv: Enable CONFIG_OF_BOARD_FIXUP by default for OF_SEPARATE sysreset: syscon: Don't assume default value for offset and mask property sysreset: syscon: Support value property riscv: Do not build reset.c if SYSRESET is on riscv: qemu: Add syscon reboot and poweroff support riscv: sifive: fu540: Add gpio-restart support doc: qemu-riscv: Update QEMU run command
Heinrich Schuchardt (1): riscv: use log functions in fdt_fixup
Pragnesh Patel (1): riscv: sifive: fu540: enable all cache ways from U-Boot proper
Sean Anderson (1): riscv: sbi: Add newline to error message
arch/riscv/Kconfig | 3 +++ arch/riscv/cpu/fu540/Makefile | 1 + arch/riscv/cpu/fu540/cache.c | 53 +++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/riscv/dts/fu540-c000-u-boot.dtsi | 10 +++++++--- arch/riscv/include/asm/arch-fu540/cache.h | 14 ++++++++++++++ arch/riscv/lib/Makefile | 2 ++ arch/riscv/lib/fdt_fixup.c | 46 ++++++++++++++++++++++++++++++++-------------- board/emulation/qemu-riscv/Kconfig | 4 ++++ board/sifive/fu540/Kconfig | 2 ++ board/sifive/fu540/fu540.c | 10 +++++++++- common/spl/spl_opensbi.c | 2 +- configs/sifive_fu540_defconfig | 1 - doc/board/emulation/qemu-riscv.rst | 10 +++++----- drivers/sysreset/sysreset_syscon.c | 28 +++++++++++++++++++++++++--- 14 files changed, 158 insertions(+), 28 deletions(-) create mode 100644 arch/riscv/cpu/fu540/cache.c create mode 100644 arch/riscv/include/asm/arch-fu540/cache.h
On Thu, Jul 02, 2020 at 10:51:48AM +0800, uboot@andestech.com wrote:
Hi Tom,
This changes a few MIPS and ARM platforms. We're a few days away from release, so I don't feel comfortable taking this right now as I assume it hasn't been tested on the other platforms as well. Sorry.
uboot@andestech.com
