[PATCH v4] mtd: gpmi: fix the bch setting backward compatible issue
Previous u-boot code changed the default bch setting behavior and caused backward compatible issue. This fix choose the legacy bch geometry back again as the default option. If the minimum ecc strength that NAND chips required need to be chosen, it can be enabled by either adding DT flag "fsl,use-minimum-ecc" or CONFIG_NAND_MXS_USE_MINIMUM_ECC in configs. The unused flag "fsl,legacy-bch-geometry" get removed.
Fixes: 51cdf83eea (mtd: gpmi: provide the option to use legacy bch geometry) Fixes: 616f03daba (mtd: gpmi: change the BCH layout setting for large oob NAND) Tested-by: Tim Harvey tharvey@gateworks.com Tested-by: Sean Nyekjaer sean@geanix.com Signed-off-by: Han Xu han.xu@nxp.com
--- Changes in v2: - change the commit log about backward compatible issue is in u-boot - removed the unused flag - add fixes and test tag
Changes in v3: - fix the fixes syntax - fix the change log syntax - add more test tag
Changes in v4: - change the fix tag to single line --- drivers/mtd/nand/raw/mxs_nand.c | 71 ++++++++++++++++++++++++++---- drivers/mtd/nand/raw/mxs_nand_dt.c | 2 - include/mxs_nand.h | 2 - 3 files changed, 62 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/nand/raw/mxs_nand.c b/drivers/mtd/nand/raw/mxs_nand.c index 748056a43e..ee5d7fde9c 100644 --- a/drivers/mtd/nand/raw/mxs_nand.c +++ b/drivers/mtd/nand/raw/mxs_nand.c @@ -195,6 +195,7 @@ static inline int mxs_nand_legacy_calc_ecc_layout(struct bch_geometry *geo, struct nand_chip *chip = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(chip); unsigned int block_mark_bit_offset; + int corr, ds_corr;
/* The default for the length of Galois Field. */ geo->gf_len = 13; @@ -225,6 +226,17 @@ static inline int mxs_nand_legacy_calc_ecc_layout(struct bch_geometry *geo, geo->ecc_strength = min(round_down(geo->ecc_strength, 2), nand_info->max_ecc_strength_supported);
+ /* check ecc strength, same as nand_ecc_is_strong_enough() did*/ + if (chip->ecc_step_ds) { + corr = mtd->writesize * geo->ecc_strength / + geo->ecc_chunkn_size; + ds_corr = mtd->writesize * chip->ecc_strength_ds / + chip->ecc_step_ds; + if (corr < ds_corr || + geo->ecc_strength < chip->ecc_strength_ds) + return -EINVAL; + } + block_mark_bit_offset = mtd->writesize * 8 - (geo->ecc_strength * geo->gf_len * (geo->ecc_chunk_count - 1) + MXS_NAND_METADATA_SIZE * 8); @@ -1111,6 +1123,7 @@ static int mxs_nand_set_geometry(struct mtd_info *mtd, struct bch_geometry *geo) struct nand_chip *chip = mtd_to_nand(mtd); struct nand_chip *nand = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(nand); + int err;
if (chip->ecc_strength_ds > nand_info->max_ecc_strength_supported) { printf("unsupported NAND chip, minimum ecc required %d\n" @@ -1118,19 +1131,57 @@ static int mxs_nand_set_geometry(struct mtd_info *mtd, struct bch_geometry *geo) return -EINVAL; }
- if ((!(chip->ecc_strength_ds > 0 && chip->ecc_step_ds > 0) && - mtd->oobsize < 1024) || nand_info->legacy_bch_geometry) { - dev_warn(mtd->dev, "use legacy bch geometry\n"); - return mxs_nand_legacy_calc_ecc_layout(geo, mtd); + /* use the legacy bch setting by default */ + if ((!nand_info->use_minimum_ecc && mtd->oobsize < 1024) || + !(chip->ecc_strength_ds > 0 && chip->ecc_step_ds > 0)) { + dev_dbg(mtd->dev, "use legacy bch geometry\n"); + err = mxs_nand_legacy_calc_ecc_layout(geo, mtd); + if (!err) + return 0; }
- if (mtd->oobsize > 1024 || chip->ecc_step_ds < mtd->oobsize) - return mxs_nand_calc_ecc_for_large_oob(geo, mtd); + /* for large oob nand */ + if (mtd->oobsize > 1024) { + dev_dbg(mtd->dev, "use large oob bch geometry\n"); + err = mxs_nand_calc_ecc_for_large_oob(geo, mtd); + if (!err) + return 0; + }
- return mxs_nand_calc_ecc_layout_by_info(geo, mtd, - chip->ecc_strength_ds, chip->ecc_step_ds); + /* otherwise use the minimum ecc nand chips required */ + dev_dbg(mtd->dev, "use minimum ecc bch geometry\n"); + err = mxs_nand_calc_ecc_layout_by_info(geo, mtd, chip->ecc_strength_ds, + chip->ecc_step_ds);
- return 0; + if (err) + dev_err(mtd->dev, "none of the bch geometry setting works\n"); + + return err; +} + +void mxs_nand_dump_geo(struct mtd_info *mtd) +{ + struct nand_chip *nand = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(nand); + struct bch_geometry *geo = &nand_info->bch_geometry; + + dev_dbg(mtd->dev, "BCH Geometry :\n" + "GF Length\t\t: %u\n" + "ECC Strength\t\t: %u\n" + "ECC for Meta\t\t: %u\n" + "ECC Chunk0 Size\t\t: %u\n" + "ECC Chunkn Size\t\t: %u\n" + "ECC Chunk Count\t\t: %u\n" + "Block Mark Byte Offset\t: %u\n" + "Block Mark Bit Offset\t: %u\n", + geo->gf_len, + geo->ecc_strength, + geo->ecc_for_meta, + geo->ecc_chunk0_size, + geo->ecc_chunkn_size, + geo->ecc_chunk_count, + geo->block_mark_byte_offset, + geo->block_mark_bit_offset); }
/* @@ -1159,6 +1210,8 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) if (ret) return ret;
+ mxs_nand_dump_geo(mtd); + /* Configure BCH and set NFC geometry */ mxs_reset_block(&bch_regs->hw_bch_ctrl_reg);
diff --git a/drivers/mtd/nand/raw/mxs_nand_dt.c b/drivers/mtd/nand/raw/mxs_nand_dt.c index 878796d555..b9833a646f 100644 --- a/drivers/mtd/nand/raw/mxs_nand_dt.c +++ b/drivers/mtd/nand/raw/mxs_nand_dt.c @@ -92,8 +92,6 @@ static int mxs_nand_dt_probe(struct udevice *dev)
info->use_minimum_ecc = dev_read_bool(dev, "fsl,use-minimum-ecc");
- info->legacy_bch_geometry = dev_read_bool(dev, "fsl,legacy-bch-geometry"); - if (IS_ENABLED(CONFIG_CLK) && IS_ENABLED(CONFIG_IMX8)) { /* Assigned clock already set clock */ struct clk gpmi_clk; diff --git a/include/mxs_nand.h b/include/mxs_nand.h index 66c909318d..741dc8734e 100644 --- a/include/mxs_nand.h +++ b/include/mxs_nand.h @@ -44,8 +44,6 @@ struct mxs_nand_info { struct udevice *dev; unsigned int max_ecc_strength_supported; bool use_minimum_ecc; - /* legacy bch geometry flag */ - bool legacy_bch_geometry; int cur_chip;
uint32_t cmd_queue_len;
Hi Han,
han.xu@nxp.com wrote on Fri, 25 Mar 2022 08:36:38 -0500:
One nit below.
- struct nand_chip *nand = mtd_to_nand(mtd);
- struct mxs_nand_info *nand_info = nand_get_controller_data(nand);
- struct bch_geometry *geo = &nand_info->bch_geometry;
- dev_dbg(mtd->dev, "BCH Geometry :\n"
geo->gf_len,
geo->ecc_strength,
geo->ecc_for_meta,
- mxs_nand_dump_geo(mtd);
- /* Configure BCH and set NFC geometry */ mxs_reset_block(&bch_regs->hw_bch_ctrl_reg);
The above addition should not be part of the commit fixing the situation, they should be in a separate patch.
With this fixed,
Reviewed-by: Miquel Raynal miquel.raynal@bootlin.com
Thanks, Miquèl
Fixes: 51cdf83eea (mtd: gpmi: provide the option to use legacy bch geometry) Fixes: 616f03daba (mtd: gpmi: change the BCH layout setting for large oob NAND) Tested-by: Tim Harvey tharvey@gateworks.com Tested-by: Sean Nyekjaer sean@geanix.com Signed-off-by: Han Xu han.xu@nxp.com Reviewed-by: Miquel Raynal miquel.raynal@bootlin.com
Han Xu
Miquel Raynal
